[gelöst] VIS - Neues Projekt lässt sich nicht erstellen
pi@ioBroker:~ $ iob update Used repository: beta Adapter "accuweather" : 1.2.4 , installed 1.2.4 Adapter "admin" : 5.3.0 , installed 5.3.0 Adapter "alexa2" : 3.12.0 , installed 3.12.0 Adapter "backitup" : 2.3.3 , installed 2.3.3 Adapter "bring" : 1.7.13 , installed 1.7.13 Adapter "chromecast" : 2.3.1 , installed 2.3.1 Adapter "daswetter" : 3.0.9 , installed 3.0.9 Adapter "denon" : 1.12.1 , installed 1.12.1 Adapter "discovery" : 2.8.0 , installed 2.7.5 [Updatable] Adapter "dwd" : 2.7.7 , installed 2.7.7 Adapter "harmony" : 1.2.2 , installed 1.2.2 Adapter "heos" : 1.9.2 , installed 1.9.2 Adapter "hue" : 3.6.5 , installed 3.6.5 Adapter "hue-extended" : 2.0.0 , installed 2.0.0 Adapter "ical" : 1.11.6 , installed 1.11.6 Adapter "javascript" : 5.2.21 , installed 5.2.21 Controller "js-controller": 4.0.15 , installed 4.0.15 Adapter "meross" : 1.10.2 , installed 1.10.2 Adapter "panasonic-viera": 2.0.0 , installed 2.0.0 Adapter "ping" : 1.5.2 , installed 1.5.2 Adapter "shelly" : 5.2.0 , installed 5.2.0 Adapter "simple-api" : 2.6.3 , installed 2.6.3 Adapter "socketio" : 4.1.4 , installed 4.1.4 Adapter "spotify-premium": 1.1.4 , installed 1.1.4 Adapter "telegram" : 1.11.1 , installed 1.11.1 Adapter "tr-064" : 4.2.15 , installed 4.2.15 Adapter "trashschedule": 1.4.2 , installed 1.4.2 Adapter "vis" : 1.4.12 , installed 1.4.12 Adapter "vis-colorpicker": 1.2.0 , installed 1.2.0 Adapter "vis-inventwo" : 3.2.8 , installed 3.2.8 Adapter "web" : 4.1.6 , installed 4.1.6 Adapter "ws" : 1.1.6 , installed 1.1.6 Adapter "yr" : 5.0.0 , installed 5.0.0 pi@ioBroker:~ $ iob list instances + system.adapter.accuweather.0 : accuweather : ioBroker - enabled + system.adapter.admin.0 : admin : ioBroker - enabled, port: 8081, bind: 0.0.0.0, run as: admi n + system.adapter.alexa2.0 : alexa2 : ioBroker - enabled + system.adapter.backitup.0 : backitup : ioBroker - enabled + system.adapter.bring.0 : bring : ioBroker - enabled + system.adapter.chromecast.0 : chromecast : ioBroker - enabled system.adapter.daswetter.0 : daswetter : ioBroker - enabled system.adapter.denon.0 : Denon AVR : ioBroker - disabled + system.adapter.discovery.0 : discovery : ioBroker - enabled system.adapter.dwd.0 : dwd : ioBroker - enabled + system.adapter.harmony.0 : harmony : ioBroker - enabled + system.adapter.heos.0 : heos : ioBroker - enabled + system.adapter.hue-extended.0 : hue-extended : ioBroker - enabled system.adapter.ical.0 : ical : ioBroker - enabled + system.adapter.javascript.0 : javascript : ioBroker - enabled + system.adapter.meross.0 : meross : ioBroker - enabled + system.adapter.panasonic-viera.0 : panasonic-viera : ioBroker - enabled + system.adapter.ping.0 : ping : ioBroker - enabled + system.adapter.shelly.0 : shelly : ioBroker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.spotify-premium.0 : spotify-premium : ioBroker - enabled + system.adapter.telegram.0 : telegram : ioBroker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.tr-064.0 : tr-064 : ioBroker - enabled + system.adapter.trashschedule.0 : trashschedule : ioBroker - enabled system.adapter.vis-colorpicker.0 : vis-colorpicker : ioBroker - enabled + system.adapter.vis-inventwo.0 : vis-inventwo : ioBroker - enabled system.adapter.vis.0 : vis : ioBroker - enabled + system.adapter.web.0 : web : ioBroker - enabled, port: 8082, bind: 0.0.0.0, run as: admi n system.adapter.yr.0 : yr : ioBrokerAdapter neustart und iob fix brachte keine Änderung
@wendy2702 gute Frage
Muss ich dann so stellen?
@wendy2702 Es lässt sich kein neues Projekt anlegen...
ok. dann lass mich mal aufzählen
- ioB fix
- Web Adapter neu gestartet
- VIS Adapter neu gestartet
- von beta auf stable gestellt
oh, und das bin ich dir noch schuldig...
- ioB fix
@iced112 sagte in VIS - Neues Projekt lässt sich nicht erstellen:
dadurch werden die Beta-Versionen aber nicht wieder zu stable.
- ioB fix
@iced112 Gab es in den Logs irgendwelche Fehler Meldungen?
Dann fällt mir nur noch das ein:
Erster Versuch:
iobroker upload allWenn es dann nicht geht das hier—>
cd /opt/iobroker iobroker stop vis npm install iobroker.vis iobroker upload vis iobroker start visWenn es immer noch nicht geht: mal den Server komplett neu starten
Im ersten Post hast du geschrieben du musstest neu aufsetzen. Wie genau gemacht?
EDIT: Und hast du ein Backup eingespielt?
Und wie mache ich sie stable?
jetzt mach erst mal mit @wendy2702 zu Ende!
du müsstest sie alle manuell downgraden.
http://download.iobroker.net/list.html#sortCol=name&sortDir=0&filter= -
Erster Versuch:
@wendy2702 said in VIS - Neues Projekt lässt sich nicht erstellen:
Erster Versuch:
iobroker upload allSuper, hiernach ging es!
@wendy2702 Ich Danke euch
