  4. IOBroker Anbindung an einen Kostal Plenticore
    6.3k
1.3k Beiträge 83 Kommentatoren 565.1k Aufrufe 72 Beobachtet
  • G gjo
    @homeuser ok, bei mir sind alle forecast Werte aus dem Plenticore Adapter verschwunden.
    Sprich die Verhersagewerte tauchen nicht mehr auf.
    Im Log kann ich leider keine Fehler finden:
    2022-02-15 00:00:08.277 - info: plenticore.0 (940) Delete object forecast.day1.power.1h.generated
    2022-02-15 00:00:08.293 - info: plenticore.0 (940) Delete object forecast.day1.power.2h.generated
    2022-02-15 00:00:08.293 - info: plenticore.0 (940) Delete object forecast.day1.power.3h.generated
    2022-02-15 00:00:08.293 - info: plenticore.0 (940) Delete object forecast.day1.power.4h.generated
    2022-02-15 00:00:08.293 - info: plenticore.0 (940) Delete object forecast.day1.power.5h.generated
    2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.6h.generated
    2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.7h.generated
    2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.8h.generated
    2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.9h.generated
    2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.10h.generated
    2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.11h.generated
    2022-02-15 00:00:08.324 - info: plenticore.0 (940) Forecast data file written to disk.
    2022-02-15 00:00:08.325 - info: plenticore.0 (940) Power generation statistics written to disk.
    2022-02-15 00:00:08.325 - info: plenticore.0 (940) Power consumption statistics written to disk.
    2022-02-15 00:00:08.325 - info: plenticore.0 (940) JSON states written to disk.
    2022-02-15 00:03:14.185 - info: plenticore.0 (940) Read forecast data before calcMinSoC.
    2022-02-15 00:03:14.195 - info: plenticore.0 (940) calcMinSoC for day 1.
    2022-02-15 00:03:14.196 - info: plenticore.0 (940) Using forecast of day 1 for MinSoC calculation.
    2022-02-15 00:03:14.280 - info: plenticore.0 (940) calcMinSoC for day 2.
    2022-02-15 00:18:14.186 - info: plenticore.0 (940) Read forecast data before calcMinSoC.
    2022-02-15 00:18:14.194 - info: plenticore.0 (940) calcMinSoC for day 1.
    2022-02-15 00:18:14.195 - info: plenticore.0 (940) Using forecast of day 1 for MinSoC calculation.
    2022-02-15 00:18:14.283 - info: plenticore.0 (940) calcMinSoC for day 2.
    2022-02-15 00:33:14.187 - info: plenticore.0 (940) Read forecast data before calcMinSoC.
    2022-02-15 00:33:14.198 - info: plenticore.0 (940) calcMinSoC for day 1.
    2022-02-15 00:33:14.199 - info: plenticore.0 (940) Using forecast of day 1 for MinSoC calculation.
    2022-02-15 00:33:14.289 - info: plenticore.0 (940) calcMinSoC for day 2.
    2022-02-15 00:48:14.187 - info: plenticore.0 (940) Read forecast data before calcMinSoC.
    2022-02-15 00:48:14.205 - info: plenticore.0 (940) calcMinSoC for day 1.
    2022-02-15 00:48:14.206 - info: plenticore.0 (940) Using forecast of day 1 for MinSoC calculation.
    2022-02-15 00:48:14.303 - info: plenticore.0 (940) calcMinSoC for day 2.
    Was läuft da wohl schief???
    HomeUser
    #1203
    @gjo Habe ich aus dem Bauch heraus auch keine Idee. @StrathCole : Eine Idee, wie sich das aus der Ferne am leichtesten eingrenzen lässt?
    • Bernd 0B Bernd 0
      wenn ich den DynamicSoc Wert auf true oder auch false setzen möchte, bekomme ich die folgende Meldung:
      	PUT to settings devices:local / Battery:DynamicSoc:Enable (true) resulted in code 500: {"message":"Internal Server Error"}
      Ich habe den Datenpunkt
      plenticore.0.devices.local.battery.DynamicSoc und
      plenticore.0.devices.local.battery.SmartBatteryControl
      so verstanden, wie in den Settings. Habe ich hier einen Denkfehler?
      StrathColeS Offline
      StrathColeS Offline
      StrathCole
      #1204
      @bernd-0 Ist es denn ein normeler Plenticore und kein Piko Wechselrichter? Gibt es in der Oberfläche des Wechselrichters die entsprechenden Einstellungen?
      SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
      Bernd 0B 1 Antwort Letzte Antwort
      • G gjo
        StrathColeS Offline
        StrathColeS Offline
        StrathCole
        #1205
        @gjo Ist es die aktuelle git-Version des Adapters? Wenn ja, kommen beim Restart des Adapters irgendwelche Fehler oder Warnungen im Log?
        G 1 Antwort Letzte Antwort
        • StrathColeS StrathCole
          gjo
          schrieb am zuletzt editiert von gjo
          #1206
          @strathcole das war der Hinweis. Nach dem Neustart des Systems sind heute morgen alle forecastwerte wieder da.
          Fehlermeldungen gab es aber weder während den fehlenden Werten noch beim Neustart.
          Danke für die schnelle Hilfe
          • DiginixD Offline
            DiginixD Offline
            Diginix
            #1207
            Gibt eine neue Firmware.
            2022.02.16
            KOSTAL_Update_PLENTICORE_PIKO_IQ_01.21.06586 (FW01.60/PAR03.44)
            Änderungen
            • Neues Verhalten des Ruhemode:
              • Bei Entladung auf den konfigurierten min. SoC wird die Trennstelle des Speichersystems geöffnet.
              • Sofortiges Aufwachen aus dem Ruhemode und Zuschalten der Batterie, sobald Überschussleistung zur Ladung vorhanden ist oder Ladung durch externe Steuerung angefordert wird.
            • Batterie-Notladung: Autom. Erhöhung des Delta-SoCs auf bis zu 15%, wenn während einer Schlechtwetterperiode die Batterie nicht geladen werden kann. Dadurch werden die Notlade-Vorgänge minimiert.
            • Serviceladung auf 100% kann in den Batterieeinstellungen des Webmenüs gestartet werden. (Nur mit Installateurs-Login möglich.)
            • PLENTICORE BI 10/26: CEI 0-16 und CEI 0-21 in den Ländereinstellungen hinzu
            Klingt für mich nach sinnvollen Verbesserungen.
            ..:: So long! Tom ::..
            U DiginixD 2 Antworten Letzte Antwort
              Bernd 0B Offline
              Bernd 0B Offline
              Bernd 0
              #1208
              @strathcole Hi, ja das ist ein normaler Plenticore und die Weboberfläche zeigt unter Service-Menü, Batteriemanagement den entsprechenden Haken für intelligente Batteriesteuerung.
              Ich würde gerne mit dem Ändern des Datenpunktes den Haken in den Apdapter-Einstellungen entfernen und ebenso dann im Wechselrichter. Ich hoffe, ich konnte es verständlich erklären.
              Es ist doch oftmals so, dass die intelligente Steuerung (über den WR oder auch den Adapter) ziemlich daneben liegt. Dann habe ich nur eine Batterieladung bis 60 / 70% und ärgere mich, dass ich zuvor eingespeist habe. Manchmal stimmt das eigene Bauchgefühl doch besser. Dann würde ich gerne "umschalten" können durch Veränderung des Datenpunktes.
              StrathColeS H 2 Antworten Letzte Antwort
              • DiginixD Diginix
                2022.02.16
                Änderungen
                U Offline
                U Offline
                ukl
                #1209
                @diginix
                ich habe das update jetzt eingespielt, keine Probleme soweit in der kurzen Zeit
                Ein interressanter Teil in den neuen Batterieeinstellungen ist der graue Hinweis
                d.h. dass Kostal sich dem Problem mit dem Nachladen angenommen hat und die Lösung von strathcole teilweise nachgebaut hat. Mal sehen wie das funktioniert.
                @StrathCole, kann es jetzt Probleme bei der dynamischen minSoC Steuerung mit Deinen Adapter geben? Es versuchen ja dann 2 Programme den minSoC zu regeln :-(
                TRINA_HoneyM_330-340W: 9,86kwp, Plentcore Plus 8.5, BYD HVS10.2
                StrathColeS 1 Antwort Letzte Antwort
                • U ukl
                  @diginix
                  StrathColeS Offline
                  StrathColeS Offline
                  StrathCole
                  #1210
                  @ukl sagte in IOBroker Anbindung an einen Kostal Plenticore:
                  Ich vermute jetzt einfach mal, dass es keine Probleme geben sollte. Es kann höchstens sein, dass KOSTAL den MinSoC dann noch stärker anhebt als der Adapter.
                  • Bernd 0B Bernd 0
                    StrathColeS Offline
                    StrathColeS Offline
                    StrathCole
                    #1211
                    @bernd-0 sagte in IOBroker Anbindung an einen Kostal Plenticore:
                    Ach so, nein, das geht leider nicht. Der Datenpunkt müsste eigentlich read-only sein, wenn ich es korrekt im Kopf habe. Es geht nur entweder manuell (also in den Einstellungen des Adapters deaktivieren) oder den Adapter entscheiden lassen.
                      Bernd 0B Offline
                      Bernd 0B Offline
                      Bernd 0
                      schrieb am zuletzt editiert von Bernd 0
                      #1212
                      @strathcole Danke für deine Antwort. Durch Änderung des Datenpunktes plenticore.0.devices.local.battery.SmartBatteryControl schaltet der Checkhaken im Webinterface des Wechselrichters. Das ist schonmal nicht schlecht. Aber die Checkbox in den Adaptersettings bei dir wird nicht verändert. Würde sich das vielleicht verknüpfen lassen? Oder ggf. ein zweiter Datenpunkt für die Adaptersettings hinzufügen?
                      Was die Veränderung des Datenpunktes plenticore.0.devices.local.battery.DynamicSoc bewirkt, habe ich noch nicht herausgefunden. :) Im Webinterface konnte ich keine Veränderung sehen.
                      Vermutlich, weil dies ja auch die Fehlermeldung erzeugt und somit ggf. nur readonly ist
                      • DiginixD Diginix
                        @StrathCole minSOC hab ich ja auch nicht aktiv, da gäbe es nur den Dummy.
                        Hier die letzten 2 Tage, noch ohne intelligente Bat Steuerung.
                        Die Ladeleistung ist jetzt nicht mehr invertiert und beginnt bei 0W, alles darüber erhöht den SOC. Wie man ja auch gut sehen kann.
                        Maverick
                        #1213
                        @diginix sagte in IOBroker Anbindung an einen Kostal Plenticore:
                        ich habe einen Plenticore 10 (11,1kWp) O/W Ausrichtung mit BYD Batteriespeicher (7,68kWh) und diesen Adapter erfolgreich installiert bekommen.
                        Der Adapter hat mein Interesse geweckt bzgl. der dynamischen minSoC Steuerung. In den Wintermonaten habe ich den SoC auf 15% gestellt, intelligente Batteriesteuerung deaktiviert und Batterientladung zwischen 08:00 Uhr - 16:00 Uhr deaktiviert.
                        Kann mir jemand erklären, wie ich so ein Diagramm erzeugt bekomme? Explizit das Thema Prognose würde mich interessieren.
                        S DiginixD 2 Antworten Letzte Antwort
                        • M Maverick
                          SigiMOE
                          #1214
                          @maverick da hänge ich mich mal dran, ebenfalls eine ich dies sehr interessant.
                          • M Maverick
                            DiginixD Offline
                            DiginixD Offline
                            Diginix
                            #1215
                            @maverick, @SigiMOE
                            Alles was man für das Diagramm braucht ist hier im Thread zu finden.
                            Das ist aber immer rückwirkend für den Tag. Mit dem pvforecast Adapter kann man sich die Tageskurve auch schon früh zeichnen lassen.
                            Auch das ist alles in dessen Thread zu finden.
                            • DiginixD Diginix
                              @maverick, @SigiMOE
                              Maverick
                              #1216
                              @maverick, @SigiMOE
                              Hi @Diginix ... nun der Thread ist nicht gerade kurz, mag sein dass ich es überlesen habe. Gelesen habe ich immer nur etwas von VIS.
                              Kleine Hilfestellung mit Link wäre super!
                              Ich habe auf dem iobroker mal etwas mit vis und Homematic gemacht. Handelt es sich um den gleichen Adapter?
                              • M Maverick
                                @maverick, @SigiMOE
                                DiginixD Offline
                                DiginixD Offline
                                Diginix
                                #1217
                                @maverick Das gezeigte Diagramm ist einfach nur ein Screenshot vom flot Adapter.
                                Alle nötigen Datenpunkte werden per influxDB erfasst und können dann mit flot, e-chart, grafana usw. in jeglicher Form visualisiert werden. Wie man das allerdings in eine iob VIS bekommt, k.a.
                                Ich habe jarvis im Einsatz, da könnte ich sicher was von Grafana einbinden.
                                • Bernd 0B Bernd 0
                                  Hans-K
                                  #1218
                                  Hallo Bernd, hallo Strathcole, hallo Gemeinde,
                                  ich habe einen Plenticore 10 mit BYD HVS 7.7 im Einsatz. Mit dem Plenticore-Adapter logge ich schon seit einiger Zeit die Daten mit.
                                  Nun möchte ich die Register 1038 (Maximum charge power limit) bzw. 1044 (Maximum SOC) des Batteriemanagements schreiben können, um das Ladeverhalten der Batterie in Abhängigkeit vom Wetter beeinflussen zu können und der 70%-Kappung über Mittag zu begegnen.
                                  Da ich die Register über den Plenticore-Adapter nicht schreiben kann, habe ich den Modbus-Adapter installiert und mir vom Installateur die Batteriesteuerung auf "extern über Protokoll (Modbus TCP)" umstellen lassen:
                                  Folgende Einstellungen habe ich am modbus-Adapter vorgenommen:
                                  Unter Holding-Register habe ich folgendes eingestellt:
                                  Setze ich anschließend unter der Objekten der Wert für Adresse 1042 nun auf 80%, kommt vorerst folgendes:
                                  Nachdem ich zurückschalte auf Lesemodus (Adresse 1042 in der Instanz CW deaktivieren), kommt ein Wert von 5%:
                                  Es ist egal, ob ich vorher 80% oder irgend einen anderen Wert eintrage, die Einstellung geht immer auf den Wert 5%.
                                  Bleibe ich mit irgendeinem Wert in Adresse 1042 im zyklischen Schreibmodus (CW), dann hört die Batterie auf zu laden (vermutlich, weil er auf den Wert 5% geht). Das spricht schon mal dafür, dass die Batterie auf die Einstellung reagiert.
                                  Es hängt scheinbar "nur" noch daran, korrekte Werte in die Register zu bekommen:
                                  • 1042 (z.B. vor dem Mittag nur bis 50% aufladen) und ertragsabhängig vor der Kappung auf 90% oder mehr wieder zu öffnen)
                                  • 1038 (z.B. über die Kappungszeit auf beispielsweise 2000W zu begrenzen, damit die Batterie schonend geladen wird, aber vor allem nur so viel vom Ertrag weggekappt wird, dass man unter die 70%-Grenze kommt).
                                  Habe ich einen Fehler in der Konfiguration "Allgemein" in der Instanz oder bei "Holding Register" der Adresse 1042 (Float Big Endian, WP, CW, SF)?
                                  Wäre prima, wenn mir jemand helfen könnte.
                                  Plenticore 10: UI-Version: 01.21.06586
                                  Modbus: v3.4.17
                                  SwantuS 1 Antwort Letzte Antwort
                                  • H Offline
                                    HomeUser
                                    #1219
                                    mal eine vermutlich relativ einfache Frage: Wenn ich den Wert von plenticore.0.forecast.day1.power.day_adjusted mit dem History-Adapter aufzeichne und in Flot darstelle, zeigt sich immer ein gewisser Zick-Zack-Verlauf.
                                    Ist das nur bei mir so oder bei mehr von euch?
                                    Ich habe schon probiert die Ursache zu verstehen, war aber bislang noch nicht erfolgreich.
                                    • H HomeUser
                                      DiginixD Offline
                                      DiginixD Offline
                                      Diginix
                                      #1220
                                      @homeuser Zeig doch mal ein Diagramm und ggf. noch die History Einstellungen von dem Objekt.
                                      H 1 Antwort Letzte Antwort
                                      • DiginixD Diginix
                                        HomeUser
                                        #1221
                                        @diginix Hier die History-Einstellungen des Objektes und ein Chart als Beispiel (aus History und Flot, aber mit unterschiedlichem Zeitraum).
                                        • H HomeUser
                                          DiginixD Offline
                                          DiginixD Offline
                                          Diginix
                                          #1222
                                          @homeuser Ich komme erst am WE wieder an meine Daten. Aber möglicherweise schwankt der Wert eben tatsächlich so. Dass du alle 900 s zwingend ein Wert schreibst auch wenn er sich ggf. nicht geändert hat, willst du so?
                                          Das wäre ansonsten noch ein Versuch und ggf. die Entprellzeit auch noch auf mehr als 5 s. Dann logt der Adapter nicht jeden Sprung. Und dazu noch die minimale Diff. zum letzten Wert noch höher, vllt 1000.
                                          Dann glättet sich die Kurve sicher schon. Weitere Glättung stellt man dann in Flot ein.
                                          M H 2 Antworten Letzte Antwort
