  4. IOBroker Anbindung an einen Kostal Plenticore
1.3k Beiträge 83 Kommentatoren 565.0k Aufrufe 72 Beobachtet
    Deven2k
    #1192
    ich habe diesen post hier gefunden und habe die selben Warnmeldungen bei mir auch.
    Konnte aber die Lösung nicht erlesen, darauf wurde nicht genau geantwortet oder ich hab es nicht verstanden.
    Liegt das an der Modbus Einstellung?
    von burnit
    @strathcole mit einem 20s polling interval sehe ich im log alle 20s eine Warnung vom Adapter
    2021-04-15 17:16:39.187 - warn: plenticore.0 (9754) Requesting settings - [{"moduleid":"devices:local","processdataids":["Dc_P","DigitalIn","EM_State","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","LimitEvuAbs"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","S"]},{"moduleid":"devices:local:battery","processdataids":["Cycles","SoC","I","U","P"]},{"moduleid":"devices:local:pv1","processdataids":["I","U","P"]},{"moduleid":"devices:local:pv2","processdataids":["I","U","P"]},{"moduleid":"scb:export","processdataids":["PortalConActive"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Year","Statistic:CO2Saving:Total"]}]) failed with code 503: {"message":"internal communication error, try again later"}
    Liegt das evtl. an meiner alten Firmware-Version oder ist das normal? Ich kann nicht erkennen, dass es irgendwelche Fehler in den Datenpunkten gäbe.
    • StrathColeS StrathCole
      @bock-johannes Also, möglich ist das mit einem Skript.
      Dafür muss aber im Wechselrichter die externe Batteriesteuerung via ModBus erlaubt und aktiviert sein (das kann nur der Installateur-Zugang).
      Wenn das aktiv ist, kann man im Register modbus.0.holdingRegisters.1078_Max_Discharge Pwr Lim, also 1078 die Entladebegrenzung in W setzen. Wichtig ist dann nur, dass man sie mindestens alle ~10 Sekunden neu setzt, da der WR einen Timeout hat und die Steuerung dann automatisch wieder deaktiviert (auf intern umstellt).
      Vorgehen wäre also:
      Javascript schreiben, das
      1. mit openWB-Adapter ausliest, ob der Lademodus "Sofortladen" ist und das Auto eingesteckt ist
      2. wenn ja, entsprechend alle paar Sekunden das Register 1078 auf 1000 setzen
      3. wenn nein, Wert wieder auf Standard zurücksetzen
      Jost 1
      #1193
      @strathcole Erstmal vielen Dank für den Adapter, habe deswegen gleich mal wieder iobroker aktiviert. ;)
      Da man aktuell leider weder den KSEM noch TQEM kaufen kann, lasse ich den Plenticore mit der baugleichen energybase laufen. Entladen des HVS hat via energybase geklappt, nur das Laden nicht. Deswegen will ich via Modbus das Laden selber steuern. Leider sind meine Versuche über Register 1026 oder 1034 nicht erfolgreich gewesen, jegliche Werte werden sofort wieder genullt. Muss ich weitere Register setzen, damit man die Ladung über Modbus "erzwingen" kann? Über die Digitaleingänge konnte ich laden mit 25% und 50% erzwingen, mehr ging nicht.
      UI-Version 01.18.05255 / MC-Version 01.47 / IOC-Version 01.45 / HW-Version 0200
      Installateurscode habe ich und kann dementsprechend die Einstellungen im Plenticore ändern. Würde mich über Erfahrungen mit Modbus-Steuerung freuen.
      Kostal Plenticore 10 / BYD HVS 12.8 / Victron EMS / energybase / 15.8 kWp
      StrathColeS 1 Antwort Letzte Antwort
      • J Jost 1
        StrathColeS Offline
        StrathColeS Offline
        StrathCole
        #1194
        @jost-1 Du musst via Installateurscode in den Einstellungen die "Externe Steuerung" via Modbus aktivieren. Sobald diese aktiviert ist, musst du mindestens alle 10-30 Sekunden den entsprechenden Modbus Wert setzen, sonst setzt der Kostal wieder auf interne Steuerung zurück.
        SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
          Jost 1
          #1195
          @strathcole Hm, so habe ich das auch probiert.
          Also FC 16, UID 71, ab Adresse 1034 2 Register mit 0;49992 (-200[W]) beschrieben, wurde ohne Fehler quittiert aber praktisch sofort genullt. Parallel habe ich sekündlich 1026-1036 gepollt, die waren alle 0 :man-shrugging:
          Das Register 1080 wurde vorher abgefragt, das steht auf 2 für externe Modbus-Steuerung.
          Wenn ich ab Adresse 1044 2 Register mit 0;17086 beschreibe, bleibt der max.SoC wie gewollt einige Zeit bei 95% stehen.
          Was mich wundert: Als die Entladung via energybase lief, waren die Register ab 1032 alle gefüllt. Daher meine Vermutung ob man evtl. weitere Register setzen muss?
          • J Jost 1
            StrathColeS Offline
            StrathColeS Offline
            StrathCole
            #1196
            @jost-1 Ich denke die Register sind falsch. Schau mal bei Register 1078.
              Jost 1
              #1197
              @strathcole Ja, die Register ab 1078 sind Readonly und geben Auskunft über die aktuell verfügbare Lade/Entlade-Leistung. Steuern kann ich ja darüber nichts. Ich habe parallel mal in den FHEM-Adapter geschaut, da sind die Adressen ab 1024 auch für die Setpoints reserviert.
              attr WR_1 obj-h1024-len 1
              attr WR_1 obj-h1024-reading Battery_Charge_AC_P_Setpoint
              attr WR_1 obj-h1024-set 1
              attr WR_1 obj-h1025-len 1
              attr WR_1 obj-h1025-reading Battery_P_ScaleFactor
              attr WR_1 obj-h1026-reading Battery_Charge_AC_P_SetpointAbs
              attr WR_1 obj-h1026-set 1
              attr WR_1 obj-h1028-reading Battery_Charge_DC_I_SetpointRel
              attr WR_1 obj-h1028-set 1
              attr WR_1 obj-h1030-reading Battery_Charge_AC_P_SetpointRel
              attr WR_1 obj-h1030-set 1
              attr WR_1 obj-h1032-reading Battery_Charge_DC_I_SetpointAbs
              attr WR_1 obj-h1032-set 1
              attr WR_1 obj-h1034-reading Battery_Charge_DC_P_SetpointAbs
              attr WR_1 obj-h1034-set 1
              attr WR_1 obj-h1036-reading Battery_Charge_DC_P_SetpointRel
              attr WR_1 obj-h1036-set 1
              attr WR_1 obj-h1038-reading Battery_MaxChargePowerLimitAbs
              attr WR_1 obj-h1038-set 1
              Ich bin nun am Überlegen, ob man zum 1034 auch den 1038 setzen muss...
              • J Jost 1
                StrathColeS Offline
                StrathColeS Offline
                StrathCole
                #1198
                @jost-1 Wäre zumindest nicht unlogisch.
                • H HomeUser
                  @gjo said in IOBroker Anbindung an einen Kostal Plenticore:
                  @homeuser
                  Genau sowas habe ich mir vorgestellt. Wenn du das teilen könntest …
                  Vielen Dank
                  Disclaimer und Erklärung:
                  Ich bin kein Javascript-Entwickler. Vielleicht sind manche Dinge daher sehr unschön gelöst. Außerdem ist es geschrieben nach dem Motto: Hauptsache es klappt.
                  UpdateJson(): Der erste Teil der Schleife erstellt ein Json aus den Forecast-Daten. Der zweite konsolidiert das etwas, um eine leicht verständliche Ansicht für den Rest der Familie zu haben.
                  UpdateFreeEnergy(): Berechnet wie viel Strom im Moment gerade übrig ist. Der "Moment" sind die letzten 10 Minuten, wobei die letzten drei doppelt gewichtet werden.
                  Ich habe mal alles drin gelassen, falls es nützlich ist. Wenn nicht, ist es ja einfach zu löschen :-)
                  schedule ("*/1 * * * *", UpdatePlenticore)
                  function UpdatePlenticore() {
                      // free energy must be updated first because it is used by UpdateJson()
                      UpdateFreeEnergy();
                      UpdateJson();
                  function UpdateJson() {
                      let data = [];
                      let consolidatedData = [];
                      let time2;
                      let power;
                      let generated;
                      let c = 0; // used to group always 3 hours in one
                      let timeNow = new Date(Date.now());
                      let consolidatedPower = 0;
                      let consolidatedStars = 0;
                      let consolidatedTimeEnd = timeNow.getHours(); // default: if no full period is consolidated, start with now
                      // set value for now (based on the calculated currently free energy)
                      let freeEnergy = getState('0_userdata.0.Plenticore.FreeEnergy').val;
                      consolidatedData.push({'time' : 'jetzt','power' : Math.round(freeEnergy) + " Wh", 'stars' : ((freeEnergy-200)/500)});
                      // Day 1
                      data.length = 0;
                      for (let i = 1; i <= 20; i++) {
                          let forecastHour = "plenticore.0.forecast.day1.power." + i + "h"
                          // Day 1
                          if (existsState(forecastHour + '.time')) {
                              let time  = new Date(getState(forecastHour + '.time').val);
                              // convert hourly forecast to JSON
                              time2 = time.toLocaleTimeString();
                              power = getState(forecastHour + '.power').val;
                              if (existsState(forecastHour + '.generated')) {
                                  generated = getState(forecastHour + '.generated').val;
                              } else {
                                  generated = 0;
                              data.push({'time' : time2,'power' : Math.round(power), 'generated' : Math.round(generated)});
                              // consolidate to timespan and quality (JSON)
                              // check if the period is in the future (don't show forecast for past hours)
                              if (time.getHours() > timeNow.getHours()) {
                                  consolidatedPower += power;
                                  if ( (c % 3) == 2) {
                                      consolidatedTimeEnd = time.getHours();
                                      time2 = (time.getHours()-2) + " - " + consolidatedTimeEnd + " Uhr";
                                      consolidatedStars = Math.round(consolidatedPower / 2000); // translate power in stars
                                      consolidatedData.push({'time' : time2,'power' : Math.round(consolidatedPower) + " Wh", 'stars' : consolidatedStars});
                                      consolidatedPower = 0; // rest fo next timespan
                                  c++;
                      // check if there a partially consolidated period pending
                      if ( (c % 3) == 1) {
                          time2 = (consolidatedTimeEnd + 1) + " Uhr";
                          consolidatedStars = Math.round(consolidatedPower / (2000/3)); // translate power in stars; use number of remaining items as factor
                      } else if ( (c % 3) == 2) {
                          time2 = (consolidatedTimeEnd + 1) + " - " + (consolidatedTimeEnd + 2) + " Uhr";
                          consolidatedStars = Math.round(consolidatedPower / ((2000*2)/3)); // translate power in stars; use number of remaining items as factor
                      setState('0_userdata.0.Plenticore.ForecastDay1', JSON.stringify(data), true);
                      setState('0_userdata.0.Plenticore.ConsolidatedDay1', JSON.stringify(consolidatedData), true);
                      // Day 2
                      consolidatedTimeEnd = 0;
                      data.length = 0;
                      consolidatedData.length = 0;
                          let forecastHour = "plenticore.0.forecast.day2.power." + i + "h"
                          // Day 1
                              data.push({'time' : time2,'power' : Math.round(power)})
                              c++;
                      if ( (c % 3) != 0) { // not all hours are pushed to the consolidation
                          time2 = (consolidatedTimeEnd + 1) + " - " + (consolidatedTimeEnd + 1 + (c % 3) ) + " Uhr";
                      setState('0_userdata.0.Plenticore.ForecastDay2', JSON.stringify(data), true);
                      setState('0_userdata.0.Plenticore.ConsolidatedDay2', JSON.stringify(consolidatedData), true);
                  // Save free watt of past N minutes; calc average
                  function UpdateFreeEnergy() {
                      let freeEnergy = 0;
                      let batterySoc = 0;
                      const pastMinutes = 10;
                      // with forst call, create the array are set values to 0
                      if ( typeof UpdateFreeEnergy.pastValues == 'undefined' ) {
                              UpdateFreeEnergy.pastIndex = 0;
                              UpdateFreeEnergy.pastValues= [];
                          for (let i = 0; i < pastMinutes; i++) {
                              UpdateFreeEnergy.pastValues[i] = 0;
                      // calculate the current free value
                      freeEnergy = getState('plenticore.0.devices.local.Pv_P').val;
                      freeEnergy -= getState('plenticore.0.devices.local.Home_P').val;
                      if (freeEnergy < 0) {
                          freeEnergy = 0;
                      // put into array
                      UpdateFreeEnergy.pastValues[UpdateFreeEnergy.pastIndex] = freeEnergy;
                      // calc average of past values
                          //for the 3 most current values double the impact
                          if ( (i == UpdateFreeEnergy.pastIndex) || (i == (UpdateFreeEnergy.pastIndex + pastMinutes - 1) % pastMinutes)  || (i == (UpdateFreeEnergy.pastIndex + pastMinutes - 2) % pastMinutes) ){
                              freeEnergy = freeEnergy + 2 * UpdateFreeEnergy.pastValues[i];
                          } else {
                              freeEnergy = freeEnergy + UpdateFreeEnergy.pastValues[i];
                      freeEnergy = freeEnergy / (pastMinutes + 3);  // +3 for the doubled impact of the the 3 most current values
                      // if the battery is below the defined minimum, the battery has priority; so there is no free energy
                      // recommendation:
                      //    Use same value as in the settings of the plenticore adapter for "minimaler SoC zur Aktivierung des Batteriemanagements".
                      //    The plenticore adapter stops charging a little before the limit. So the value should be 2-3% lower.
                      batterySoc = getState('plenticore.0.devices.local.battery.SoC').val;
                      if (batterySoc <= 12) {
                          freeEnergy = 0;
                      // save calculated average
                      setState('0_userdata.0.Plenticore.FreeEnergy', freeEnergy, true);
                      // inc counter for cyclic buffer
                      UpdateFreeEnergy.pastIndex = (UpdateFreeEnergy.pastIndex + 1) % pastMinutes;
                  gjo
                  #1199
                  @homeuser bei mir wird schin ein paar tage nun kein forecast mehr dargestellt.
                  Ich nutze den
                  yr.no Adapter in V5.00 (wobei es vor dem Update auf die letzte Verson schon nicht mehr ging
                  Plenticore Adapter V2.2.1
                  Funktioniert es be dir noch bzw. hast du Änderunge machen müssen damit es weiterhin funktioneirt?
                  H 1 Antwort Letzte Antwort
                  • G gjo
                    Ich nutze den
                    HomeUser
                    #1200
                    @gjo Beim mir geht es ohne Probleme. Auch keine vorübergehenden Probleme in den vergangene Tagen.
                    G 1 Antwort Letzte Antwort
                    • Bernd 0B Offline
                      Bernd 0B Offline
                      Bernd 0
                      #1201
                      wenn ich den DynamicSoc Wert auf true oder auch false setzen möchte, bekomme ich die folgende Meldung:
                      	PUT to settings devices:local / Battery:DynamicSoc:Enable (true) resulted in code 500: {"message":"Internal Server Error"}
                      Ich habe den Datenpunkt
                      plenticore.0.devices.local.battery.DynamicSoc und
                      plenticore.0.devices.local.battery.SmartBatteryControl
                      so verstanden, wie in den Settings. Habe ich hier einen Denkfehler?
                      • H HomeUser
                        gjo
                        #1202
                        @homeuser ok, bei mir sind alle forecast Werte aus dem Plenticore Adapter verschwunden.
                        Sprich die Verhersagewerte tauchen nicht mehr auf.
                        Im Log kann ich leider keine Fehler finden:
                        2022-02-15 00:00:08.277 - info: plenticore.0 (940) Delete object forecast.day1.power.1h.generated
                        2022-02-15 00:00:08.293 - info: plenticore.0 (940) Delete object forecast.day1.power.2h.generated
                        2022-02-15 00:00:08.293 - info: plenticore.0 (940) Delete object forecast.day1.power.3h.generated
                        2022-02-15 00:00:08.293 - info: plenticore.0 (940) Delete object forecast.day1.power.4h.generated
                        2022-02-15 00:00:08.293 - info: plenticore.0 (940) Delete object forecast.day1.power.5h.generated
                        2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.6h.generated
                        2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.7h.generated
                        2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.8h.generated
                        2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.9h.generated
                        2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.10h.generated
                        2022-02-15 00:00:08.294 - info: plenticore.0 (940) Delete object forecast.day1.power.11h.generated
                        2022-02-15 00:00:08.324 - info: plenticore.0 (940) Forecast data file written to disk.
                        2022-02-15 00:00:08.325 - info: plenticore.0 (940) Power generation statistics written to disk.
                        2022-02-15 00:00:08.325 - info: plenticore.0 (940) Power consumption statistics written to disk.
                        2022-02-15 00:00:08.325 - info: plenticore.0 (940) JSON states written to disk.
                        2022-02-15 00:03:14.185 - info: plenticore.0 (940) Read forecast data before calcMinSoC.
                        2022-02-15 00:03:14.195 - info: plenticore.0 (940) calcMinSoC for day 1.
                        2022-02-15 00:03:14.196 - info: plenticore.0 (940) Using forecast of day 1 for MinSoC calculation.
                        2022-02-15 00:03:14.280 - info: plenticore.0 (940) calcMinSoC for day 2.
                        2022-02-15 00:18:14.186 - info: plenticore.0 (940) Read forecast data before calcMinSoC.
                        2022-02-15 00:18:14.194 - info: plenticore.0 (940) calcMinSoC for day 1.
                        2022-02-15 00:18:14.195 - info: plenticore.0 (940) Using forecast of day 1 for MinSoC calculation.
                        2022-02-15 00:18:14.283 - info: plenticore.0 (940) calcMinSoC for day 2.
                        2022-02-15 00:33:14.187 - info: plenticore.0 (940) Read forecast data before calcMinSoC.
                        2022-02-15 00:33:14.198 - info: plenticore.0 (940) calcMinSoC for day 1.
                        2022-02-15 00:33:14.199 - info: plenticore.0 (940) Using forecast of day 1 for MinSoC calculation.
                        2022-02-15 00:33:14.289 - info: plenticore.0 (940) calcMinSoC for day 2.
                        2022-02-15 00:48:14.187 - info: plenticore.0 (940) Read forecast data before calcMinSoC.
                        2022-02-15 00:48:14.205 - info: plenticore.0 (940) calcMinSoC for day 1.
                        2022-02-15 00:48:14.206 - info: plenticore.0 (940) Using forecast of day 1 for MinSoC calculation.
                        2022-02-15 00:48:14.303 - info: plenticore.0 (940) calcMinSoC for day 2.
                        Was läuft da wohl schief???
                        H StrathColeS 2 Antworten Letzte Antwort
                        • G gjo
                          HomeUser
                          #1203
                          @gjo Habe ich aus dem Bauch heraus auch keine Idee. @StrathCole : Eine Idee, wie sich das aus der Ferne am leichtesten eingrenzen lässt?
                          • Bernd 0B Bernd 0
                            StrathColeS Offline
                            StrathColeS Offline
                            StrathCole
                            #1204
                            @bernd-0 Ist es denn ein normeler Plenticore und kein Piko Wechselrichter? Gibt es in der Oberfläche des Wechselrichters die entsprechenden Einstellungen?
                            Bernd 0B 1 Antwort Letzte Antwort
                            • G gjo
                              StrathColeS Offline
                              StrathColeS Offline
                              StrathCole
                              #1205
                              @gjo Ist es die aktuelle git-Version des Adapters? Wenn ja, kommen beim Restart des Adapters irgendwelche Fehler oder Warnungen im Log?
                                gjo
                                schrieb am zuletzt editiert von gjo
                                #1206
                                @strathcole das war der Hinweis. Nach dem Neustart des Systems sind heute morgen alle forecastwerte wieder da.
                                Fehlermeldungen gab es aber weder während den fehlenden Werten noch beim Neustart.
                                Danke für die schnelle Hilfe
                                • DiginixD Offline
                                  DiginixD Offline
                                  Diginix
                                  #1207
                                  Gibt eine neue Firmware.
                                  2022.02.16
                                  KOSTAL_Update_PLENTICORE_PIKO_IQ_01.21.06586 (FW01.60/PAR03.44)
                                  Änderungen
                                  • Neues Verhalten des Ruhemode:
                                    • Bei Entladung auf den konfigurierten min. SoC wird die Trennstelle des Speichersystems geöffnet.
                                    • Sofortiges Aufwachen aus dem Ruhemode und Zuschalten der Batterie, sobald Überschussleistung zur Ladung vorhanden ist oder Ladung durch externe Steuerung angefordert wird.
                                  • Batterie-Notladung: Autom. Erhöhung des Delta-SoCs auf bis zu 15%, wenn während einer Schlechtwetterperiode die Batterie nicht geladen werden kann. Dadurch werden die Notlade-Vorgänge minimiert.
                                  • Serviceladung auf 100% kann in den Batterieeinstellungen des Webmenüs gestartet werden. (Nur mit Installateurs-Login möglich.)
                                  • PLENTICORE BI 10/26: CEI 0-16 und CEI 0-21 in den Ländereinstellungen hinzu
                                  Klingt für mich nach sinnvollen Verbesserungen.
                                  ..:: So long! Tom ::..
                                  U DiginixD 2 Antworten Letzte Antwort
                                    Bernd 0B Offline
                                    Bernd 0B Offline
                                    Bernd 0
                                    #1208
                                    @strathcole Hi, ja das ist ein normaler Plenticore und die Weboberfläche zeigt unter Service-Menü, Batteriemanagement den entsprechenden Haken für intelligente Batteriesteuerung.
                                    Ich würde gerne mit dem Ändern des Datenpunktes den Haken in den Apdapter-Einstellungen entfernen und ebenso dann im Wechselrichter. Ich hoffe, ich konnte es verständlich erklären.
                                    Es ist doch oftmals so, dass die intelligente Steuerung (über den WR oder auch den Adapter) ziemlich daneben liegt. Dann habe ich nur eine Batterieladung bis 60 / 70% und ärgere mich, dass ich zuvor eingespeist habe. Manchmal stimmt das eigene Bauchgefühl doch besser. Dann würde ich gerne "umschalten" können durch Veränderung des Datenpunktes.
                                    StrathColeS H 2 Antworten Letzte Antwort
                                    • DiginixD Diginix
                                      2022.02.16
                                      Änderungen
                                      U Offline
                                      U Offline
                                      ukl
                                      #1209
                                      @diginix
                                      ich habe das update jetzt eingespielt, keine Probleme soweit in der kurzen Zeit
                                      Ein interressanter Teil in den neuen Batterieeinstellungen ist der graue Hinweis
                                      d.h. dass Kostal sich dem Problem mit dem Nachladen angenommen hat und die Lösung von strathcole teilweise nachgebaut hat. Mal sehen wie das funktioniert.
                                      @StrathCole, kann es jetzt Probleme bei der dynamischen minSoC Steuerung mit Deinen Adapter geben? Es versuchen ja dann 2 Programme den minSoC zu regeln :-(
                                      TRINA_HoneyM_330-340W: 9,86kwp, Plentcore Plus 8.5, BYD HVS10.2
                                      • U ukl
                                        @diginix
                                        StrathColeS Offline
                                        StrathColeS Offline
                                        StrathCole
                                        #1210
                                        @ukl sagte in IOBroker Anbindung an einen Kostal Plenticore:
                                        Ich vermute jetzt einfach mal, dass es keine Probleme geben sollte. Es kann höchstens sein, dass KOSTAL den MinSoC dann noch stärker anhebt als der Adapter.
                                        • Bernd 0B Bernd 0
                                          StrathColeS Offline
                                          StrathColeS Offline
                                          StrathCole
                                          #1211
                                          @bernd-0 sagte in IOBroker Anbindung an einen Kostal Plenticore:
                                          Ach so, nein, das geht leider nicht. Der Datenpunkt müsste eigentlich read-only sein, wenn ich es korrekt im Kopf habe. Es geht nur entweder manuell (also in den Einstellungen des Adapters deaktivieren) oder den Adapter entscheiden lassen.
