  4. Kann keine Adapter mehr Installieren
    6.1k
40 Beiträge 4 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    @andreas-6 Mach die Installation neu, nach dieser einfachen Anleitung:
    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht?_=1644263751055
    Wenn dann alles läuft backup einspielen und das logfile beobachten mit:
    tail -f /opt/iobroker/log/iobroker.current.log
    Andreas 6
    @wendy2702
    2022-02-08 14:04:21.830  - info: host.raspberrypi iobroker node-aead-crypto not needed on this system, since all ciphers are natively supported
    2022-02-08 14:04:33.583  - info: host.raspberrypi iobroker In file included from ../../nan/nan.h:58,                 from ../src/unix_dgram.cc:5:/home/iobroker/.cache/node-gyp/12.22.10/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]  736 |       (node::addon_register_func) (regfunc),                          \      |       ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.22.10/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’  770 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)      |   ^~~~~~~~~~~~~../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’  404 | NODE_MODULE(unix_dgram, Initialize)      | ^~~~~~~~~~~
    2022-02-08 14:04:37.963  - warn: tuya.0 (29664) 06013133f4cfa22fd965: Error on Reconnectconnect EHOSTUNREACH 192.168.178.137:6668
    2022-02-08 14:04:44.040  - warn: host.raspberrypi-Server Objects 127.0.0.1:39164 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
    2022-02-08 14:04:44.048  - warn: host.raspberrypi-Server Objects 127.0.0.1:39164 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
    2022-02-08 14:04:44.055  - warn: host.raspberrypi-Server States 127.0.0.1:48798 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
    2022-02-08 14:04:44.108  - warn: host.raspberrypi-Server States 127.0.0.1:48800 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
    2022-02-08 14:04:44.118  - warn: host.raspberrypi-Server Objects 127.0.0.1:39164 Error from InMemDB: Error: Unknown LUA script load
    2022-02-08 14:04:44.123  - warn: host.raspberrypi-Server Objects 127.0.0.1:39164 Error from InMemDB: Error: Unknown LUA script load
    2022-02-08 14:04:44.127  - warn: host.raspberrypi-Server Objects 127.0.0.1:39164 Error from InMemDB: Error: Unknown LUA script load
    2022-02-08 14:04:45.465  - warn: host.raspberrypi-Server Objects 127.0.0.1:39164 Error from InMemDB: Error: SET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets",{"type":"Buffer","data":[49]}]
    Hi! den Iobroker hab ich jetzt noch nicht neu gemacht.
    das steht in den log files wenn ich ein Adapter neu installiere....
    • A Andreas 6
      @wendy2702
      wendy2702W Offline
      wendy2702W Offline
      @andreas-6 Keine Ahnung was du da machst und welchen Adapter du versuchst zu installieren. Das Log ist nicht komplett.
      Ich kann lediglich sehen das es ein Problem mit Tuya gibt da diese Adresse/Port nicht erreichbar zu sein scheint:
      @Homoran hat schon gefragt was du mit „iobroker Maske meinst“ ?
      Du hast doch mit irgendeinem Tool ein Backup gemacht und irgendwo gesichert… will ich hoffen. Ist das so?
        Andreas 6
        @wendy2702
        hab versucht den Flot Adapter zu installieren...
        aber eigendlich ist das egal was für ein adpter ich installiere es macht immer den gleichen fehler...
        er macht die installation nicht zu ende...
        mit maske mein ich, wo ich mich beim iobroker anmelden kann und wo all die Adapter und Instanzen sind.. und wo ich auf das backup zugreifen kann....
        ja hab mit diesen tool ein backup gemacht und das ist auf den laufwerk wo ich das tool installiert hab...
        • A Andreas 6
          @wendy2702
          wendy2702W Offline
          wendy2702W Offline
          @andreas-6 kannst du mal ein Screenshot davon zeigen.
          Und was kommt wenn du in der Konsole das eingibst:
          ls -la /opt/iobroker/backups/
            Andreas 6
            @wendy2702 said in Kann keine Adapter mehr Installieren:
            pi@raspberrypi:~ $ ls -la /opt/iobroker/backups/
            total 158684
            drwxrwxr-x+ 2 iobroker iobroker     4096 Feb  8 16:33 .
            drwxr-xr-x+ 6 iobroker iobroker     4096 Feb  8 15:46 ..
            -rw-rw-r--+ 1 iobroker iobroker 40631352 Feb  8 13:47 2022_02_08-13_46_41_backupiobroker.tar.gz
            -rw-rwxr--+ 1 iobroker iobroker 40626168 Feb  5 14:00 iobroker_2022_02_05-13_59_52_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 40631465 Feb  8 02:41 iobroker_2022_02_08-02_40_10_backupiobroker.tar.gz
            -rw-rw-r--+ 1 iobroker iobroker 40589664 Feb  8 16:33 iobroker_2022_02_08-16_33_18_backupiobroker.tar.gz
            • wendy2702W Offline
              wendy2702W Offline
              @andreas-6 ist da ein Backup bei mit Datum bevor deine Probleme begonnen haben?
              Wenn nein, hast du deine Backups noch irgendwo anders gesichert?
              Wo ist der Screenshot auf dem das „Tool“ zu sehen ist?
              A 2 Antworten Letzte Antwort
                Andreas 6
                schrieb am zuletzt editiert von Andreas 6
                @wendy2702
                  Andreas 6
                  @wendy2702
                    Andreas 6
                    @wendy2702
                    • A Andreas 6
                      @wendy2702
                      wendy2702W Offline
                      wendy2702W Offline
                      @andreas-6 die letzte „1Backup….tar.gz“ mal auf dem Windows Rechner entpacken und dann den Inhalt hier Zeigen.
                        Andreas 6
                        @wendy2702
                        Ich weis nicht wie ich es sagen soll... ich weis auch nicht woran es gelegen hat oder was ich jetzt genau gemacht hab aber es läuft wieder...
                        Nachdem ich dir den Fehler mit den Adapter geschickt hab, habe ich es noch mal und noch mal versucht den Adapter zu installieren und dann hat er es auf einmal gemacht... und kann jetzt wie gewohnt alle Adapter installieren ohne das der io abschmiert.... sehr merkwürdig das ganze....
                        Ich habe den Iobroker noch nicht so lange und mach das alles Hobby mäßig... ich kenn mich mit den befehlen im terminal/Konsole nicht so gut aus, bzw. wo ich was suchen muss....
                        ich wüsste jetzt auch nicht wie ich das entpacken könnte..... wenn ich auf das Backup gehe macht der mir den Raspberry PI Imager los...
                        Das Iobroker Tool fliegt runter und ich mach die Backups im Iobroker.
                        Danke für eure zeit und tipps!!!! DANKE!
                        • A Andreas 6
                          @wendy2702
                          @andreas-6 sagte in Kann keine Adapter mehr Installieren:
                          Iobroker Tool
                          Nenn das Ding bitte nicht 'Iobroker Tool'. Es könnte sonst jemand auf die Idee kommen das sei was offzielles.
                            Andreas 6
                            OK! Alles klar! 👍
                            wie gesagt im terminal/konsole bin ich noch nicht so fit drin..
                            das Ding nimmt ein son bischen was ab. aber anscheinend macht es mehr kaputt als es hilft...☹
                            da ist man hier besser aufgehoben wen man probleme mit den io hat!!! 👍
                            nochmals danke!!!
                            • A Andreas 6
                              OK! Alles klar! 👍
                              nochmals danke!!!
                              Nicht wirklich.
                              Ich weiß bis heute nicht, was das dolle Ding einfacher machen soll. Eigentlich ist schon mit der krummen Installation von dem Murks der iobroker kaputt gefummelt.
