  4. Wollte mal wieder updaten, leider nur Probleme
    6.0k
    1.5k
93 Beiträge 5 Kommentatoren 7.5k Aufrufe 4 Beobachtet
  • P Offline
    pingps
    wollte den neuen Admin updaten, leider gehts nicht wie gewollt:
    Plattform: linux
    Betriebssystem: linux
    Die Architektur: x64
    Node.js: v14.19.0
    So hier noch mein Versuch:
    root@debian-uli:/opt/iobroker# ./iobroker upgrade admin
    (node:9456) Warning: Accessing non-existent property 'count' of module exports inside circular dependency
    (Use `node --trace-warnings ...` to show where the warning was created)
    (node:9456) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency
    (node:9456) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency
    (node:9456) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
    This upgrade of "admin" will at least introduce the following changes:
    -> 5.2.3:
    Fixed error in `AutocompleteSendTo`
    Fixed error in charts
    -> 5.2.2:
    Changed the minimal required js-controller version to 3.3.22
    Used web-socket library 8 (no node 10 support anymore)
    -> 5.2.1:
    Allow in expert mode the creation of states and channels in mqtt branch
    -> 5.2.0:
    Fix crash cases reported via sentry
    Added support for multi-repositories
    -> 5.1.29:
    -> 5.1.28:
    Fixed discovery function
    Fixed some GUI bugs
    -> 5.1.25:
    Corrected some errors reported via sentry and the github issues
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade admin from @4.2.1 to @5.2.3 now? [(y)es, (n)o]: y
    Update admin from @4.2.1 to @5.2.3
    host.debian-uli Adapter "system.adapter.admin.0" is stopped.
    NPM version: 6.14.16
    Installing iobroker.admin@5.2.3... (System call)
    Could not check npm version: This directory tree does not contain a package.json
    Assuming that correct version is installed.
    host.debian-uli Adapter "system.adapter.admin.0" is started
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    root@debian-uli:/opt/iobroker# sudo iobroker stop
    root@debian-uli:/opt/iobroker# sudo iobroker update
    (node:22299) Warning: Accessing non-existent property 'count' of module exports inside circular dependency
    (node:22299) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency
    (node:22299) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency
    (node:22299) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
    Used repository: beta
    Adapter    "admin"        : 5.2.3    , installed 4.2.1  [Updatable]
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.2.4    , installed 2.2.4
    Adapter    "ble"          : 0.12.0   , installed 0.12.0
    Adapter    "calendar"     : 1.2.0    , installed 1.2.0
    Adapter    "digitalstrom" : 2.3.0    , installed 2.3.0
    Adapter    "discovery"    : 2.7.5    , installed 2.7.5
    Adapter    "ds18b20"      : 1.6.0    , installed 1.6.0
    Adapter    "dwd"          : 2.7.7    , installed 2.7.7
    Adapter    "echarts"      : 1.0.3    , installed 1.0.3
    Adapter    "email"        : 1.0.10   , installed 1.0.10
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.10.7   , installed 1.10.7
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
    Adapter    "heizoel"      : 1.0.2    , installed 1.0.2
    Adapter    "history"      : 1.10.5   , installed 1.10.5
    Adapter    "hm-rega"      : 3.0.35   , installed 3.0.35
    Adapter    "hm-rpc"       : 1.15.2   , installed 1.15.2
    Adapter    "ical"         : 1.11.6   , installed 1.11.6
    Adapter    "influxdb"     : 2.4.0    , installed 1.9.4  [Updatable]
    Adapter    "info"         : 1.9.18   , installed 1.9.16 [Updatable]
    Adapter    "javascript"   : 5.2.21   , installed 4.10.9 [Updatable]
    Controller "js-controller": 4.0.4    , installed 4.0.4
    Adapter    "luftdaten"    : 2.1.3    , installed 1.0.1  [Updatable]
    Adapter    "mihome-plug"  : 0.2.1    , installed 0.2.1
    Adapter    "mihome-vacuum": 3.3.3    , installed 3.3.3
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
    Adapter    "mysensors"    : 2.0.3    , installed 2.0.3
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 2.4.2    , installed 2.4.1  [Updatable]
    Adapter    "nut"          : 1.5.0    , installed 1.5.0
    Adapter    "odl"          : 1.1.4    , installed 1.1.4
    Adapter    "owfs"         : 0.6.4    , installed 0.6.4
    Adapter    "parser"       : 1.0.7    , installed 1.0.7
    Adapter    "ping"         : 1.5.2    , installed 1.5.2
    Adapter    "scenes"       : 2.3.8    , installed 2.3.8
    Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
    Adapter    "shelly"       : 5.1.2    , installed 4.1.2  [Updatable]
    Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
    Adapter    "socketio"     : 4.1.0    , installed 3.1.5  [Updatable]
    Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
    Adapter    "sony-bravia"  : 1.0.3    , installed 1.0.3
    Adapter    "sql"          : 1.16.1   , installed 1.15.7 [Updatable]
    Adapter    "synology"     : 1.1.3    , installed 1.1.3
    Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "telegram"     : 1.11.1   , installed 1.10.0 [Updatable]
    Adapter    "terminal"     : 0.1.2    , installed 0.1.2
    Adapter    "text2command" : 2.1.1    , installed 2.1.1
    Adapter    "tr-064"       : 4.2.15   , installed 4.2.14 [Updatable]
    Adapter    "trashschedule": 1.4.2    , installed 1.0.3  [Updatable]
    Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
    Adapter    "vis"          : 1.4.8    , installed 1.4.5  [Updatable]
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
    Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
    Adapter    "vis-weather"  : 2.5.5    , installed 2.5.3  [Updatable]
    Adapter    "web"          : 4.1.1    , installed 3.2.3  [Updatable]
    Adapter    "yr"           : 5.0.0    , installed 3.0.5  [Updatable]
    Wäre nett, wenn sich ein "Profi" das mal anschaut und mir ein paar Tipps geben könnte. Danke schon im Vorraus!
    • P pingps
      Plattform: linux
      Node.js: v14.19.0
      -> 5.2.3:
      -> 5.2.2:
      -> 5.2.1:
      -> 5.2.0:
      -> 5.1.29:
      -> 5.1.28:
      Fixed some GUI bugs
      -> 5.1.25:
      @pingps
      Profi-Tipp 1: Ein Profi meldet sich nicht als root an. Nie.
      Profi-Tipp 2: Professionel werden Konsolentexte in CodeTags gepostet. Dann kann ein Profi die auch lesen.
      Profi-Tipp 3: Niemals 'sudo iobroker' verwenden. iobroker wird IMMER ohne sudo aufgerufen.
      P 1 Antwort Letzte Antwort
        @pingps
        pingps
        @thomas-braun ok, sollte jetzt so gepackt sein, wie das wohl richtig ist. Danke vielmals!
        Muss ich jetzt noch die Frage erneut stellen?
        • P pingps
          @pingps
          Zuerstmal als user anmelden, nicht als root.
          Dann
          iobroker stop
          iobroker fix
          iobroker update
          iobroker upgrade
          • P pingps
            Plattform: linux
            Node.js: v14.19.0
            -> 5.2.3:
            -> 5.2.2:
            -> 5.2.1:
            -> 5.2.0:
            -> 5.1.29:
            -> 5.1.28:
            Fixed some GUI bugs
            -> 5.1.25:
            @pingps sagte in Wollte mal wieder updaten, leider nur Probleme:
            wie kommst du denn an den?
            der ist gerade aus dem Alpha-Stadium raus
              Aber da ist insgesamt halt Chaos in der Installation.
              Zu einer 'ordentlichen' Installation trägt der root login und die Verwendung von sudo iobroker dann auch nicht gerade bei.
                pingps
                @thomas-braun habe jetzt alle Adapter deaktiviert und den fix durchgeführt, lief durch und ich sollte wieder mit "iobroker start" starten. Leider tut sich nix mehr.
                    Welcome to the ioBroker installation fixer!
                    Script version: 2021-12-27
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/3)
                [sudo] Passwort für uli:
                Installed gcc-c++
                    Checking ioBroker user and directory permissions (2/3)
                    Checking autostart (3/3)
                Enabling autostart...
                Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                $ iobroker start
                MOD-Edit: Code in code-tags gesetzt!
                auch ein reboot hat nicht geholfen.
                iobroker startet leider nicht mehr. Hast du eine Idee, was noch helfen könnte?
                • P pingps
                  Installed gcc-c++
                  Autostart enabled!
                  $ iobroker start
                  und was steht im log warum das nicht klappt?
                  Hast du denn inzwischen auch deine gesamte Basis auf aktuellen Stand gebracht?
                    pingps
                    @homoran said in Wollte mal wieder updaten, leider nur Probleme:
                    aktuellen
                    wo finde ich den log?
                    Was meinst du mit der Basis? Die Adapter, die nicht aktuell waren ließen sich nicht updaten. Nach dem Update war immer noch die alte Version angezeigt.
                    • P pingps
                      aktuellen
                      u.a. Debian, node, nodejs, npm, js-controller....
                      /opt/iobroker/logs/
                        /opt/iobroker/logs/
                        pingps
                        @homoran ../logs/ gibt es nicht. in /log/ finde ich die Meldungen zu den Adaptern. Das Ende ist dann:
                        iobroker.current.log:
                        2022-02-09 14:02:32.770  - ^[[32minfo^[[39m: host.debian-uli connected to Objects and States
                        2022-02-09 14:02:32.798  - ^[[32minfo^[[39m: host.debian-uli added notifications configuration of host
                        2022-02-09 14:02:33.020  - ^[[32minfo^[[39m: host.debian-uli Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2022-02-09 14:02:33.137  - ^[[32minfo^[[39m: host.debian-uli 68 instances found
                        2022-02-09 14:02:33.211  - ^[[32minfo^[[39m: host.debian-uli starting 9 instances
                        2022-02-09 14:02:08.077  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.vis-history.0 (force=false, process=false)
                        2022-02-09 14:02:08.077  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.tvspielfilm.0 (force=false, process=false)
                        2022-02-09 14:02:08.077  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.tankerkoenig.0 (force=false, process=false)
                        2022-02-09 14:02:08.077  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.feiertage.0 (force=false, process=false)
                        2022-02-09 14:02:08.078  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.info.0 (force=false, process=false)
                        2022-02-09 14:02:08.078  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.odl.0 (force=false, process=false)
                        2022-02-09 14:02:08.078  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.parser.0 (force=false, process=false)
                        2022-02-09 14:02:08.078  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.parser.1 (force=false, process=false)
                        2022-02-09 14:02:08.078  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.text2command.0 (force=false, process=false)
                        2022-02-09 14:02:08.078  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.vis.0 (force=false, process=false)
                        2022-02-09 14:02:08.078  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.vis-justgage.0 (force=false, process=false)
                        2022-02-09 14:02:08.079  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.trashschedule.0 (force=false, process=false)
                        2022-02-09 14:02:08.079  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
                        2022-02-09 14:02:08.113  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.calendar.0 (force=false, process=false)
                        2022-02-09 14:02:08.113  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.ble.0 (force=false, process=false)
                        2022-02-09 14:02:08.113  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
                        2022-02-09 14:02:08.114  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.ds18b20.0 (force=false, process=false)
                        2022-02-09 14:02:08.114  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.luftdaten.1 (force=false, process=false)
                        2022-02-09 14:02:08.114  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.luftdaten.2 (force=false, process=false)
                        2022-02-09 14:02:08.195  - ^[[32minfo^[[39m: host.debian-uli terminated
                        2022-02-09 14:02:31.682  - ^[[32minfo^[[39m: host.debian-uli iobroker.js-controller version 4.0.4 js-controller starting
                        2022-02-09 14:02:31.685  - ^[[32minfo^[[39m: host.debian-uli Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2022-02-09 14:02:31.686  - ^[[32minfo^[[39m: host.debian-uli hostname: debian-uli, node: v14.19.0
                        2022-02-09 14:02:31.686  - ^[[32minfo^[[39m: host.debian-uli ip addresses:
                        Ich kann da aber leider nichts finden, was mir da helfen würde. Natürlich passt da einiges nicht, aber ich denke, das ist wohl das falsche???
                        Evtl. sollte es doch ../logs/ heißen?
                        • P pingps
                          sorry mein Fehler.
                          Aber da ist er schon am runterfahren. Etwas früher wäre interessant
                            sorry mein Fehler.
                            pingps
                            @Homoran Mal sehen, ob dir das besser gefällt:
                            2022-02-08 17:24:08.307  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:08.597  - ^[[32minfo^[[39m: host.debian-uli iobroker upgrade admin
                            2022-02-08 17:24:09.325  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:10.226  - ^[[31merror^[[39m: host.debian-uli iobroker (node:24403) Warning: Accessing non-existent property 'count' of module exports inside circul$
                            2022-02-08 17:24:10.227  - ^[[31merror^[[39m: host.debian-uli iobroker (node:24403) Warning: Accessing non-existent property 'findOne' of module exports inside circ$
                            2022-02-08 17:24:10.333  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:10.561  - ^[[32minfo^[[39m: host.debian-uli iobroker Update admin from @4.2.1 to @5.2.3
                            2022-02-08 17:24:10.581  - ^[[32minfo^[[39m: host.debian-uli iobroker host.debian-uli Adapter "system.adapter.admin.0" is stopped.
                            2022-02-08 17:24:10.620  - ^[[32minfo^[[39m: admin.0 (6385) Adapter is disabled => stop
                            2022-02-08 17:24:10.624  - ^[[32minfo^[[39m: admin.0 (6385) terminating http server on port 8081
                            2022-02-08 17:24:10.627  - ^[[32minfo^[[39m: host.debian-uli "system.adapter.admin.0" disabled
                            2022-02-08 17:24:10.628  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.admin.0 (force=false, process=true)
                            2022-02-08 17:24:10.679  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.admin.0 send kill signal
                            2022-02-08 17:24:10.683  - ^[[32minfo^[[39m: admin.0 (6385) Got terminate signal TERMINATE_YOURSELF
                            2022-02-08 17:24:10.684  - ^[[32minfo^[[39m: admin.0 (6385) terminating
                            2022-02-08 17:24:10.685  - ^[[32minfo^[[39m: admin.0 (6385) Terminated (NO_ERROR): Without reason
                            2022-02-08 17:24:10.888  - ^[[32minfo^[[39m: host.debian-uli iobroker NPM version: 6.14.16
                            2022-02-08 17:24:10.889  - ^[[32minfo^[[39m: host.debian-uli iobroker Installing iobroker.admin@5.2.3... (System call)
                            2022-02-08 17:24:10.896  - ^[[31merror^[[39m: host.debian-uli iobroker Could not check npm version: This directory tree does not contain a package.json
                            2022-02-08 17:24:10.897  - ^[[31merror^[[39m: host.debian-uli iobroker Assuming that correct version is installed.
                            2022-02-08 17:24:10.898  - ^[[32minfo^[[39m: host.debian-uli iobroker host.debian-uli Adapter "system.adapter.admin.0" is started
                            2022-02-08 17:24:10.932  - ^[[32minfo^[[39m: host.debian-uli "system.adapter.admin.0" enabled
                            2022-02-08 17:24:10.933  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.admin.0 (force=false, process=true)
                            2022-02-08 17:24:10.936  - ^[[32minfo^[[39m: admin.0 (6385) Got terminate signal TERMINATE_YOURSELF
                            2022-02-08 17:24:10.985  - ^[[32minfo^[[39m: host.debian-uli stopInstance system.adapter.admin.0 send kill signal
                            2022-02-08 17:24:11.014  - ^[[32minfo^[[39m: host.debian-uli iobroker upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png ima$
                            2022-02-08 17:24:11.057  - ^[[32minfo^[[39m: host.debian-uli iobroker upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html t$
                            2022-02-08 17:24:11.063  - ^[[32minfo^[[39m: host.debian-uli iobroker upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.ht$
                            2022-02-08 17:24:11.068  - ^[[32minfo^[[39m: host.debian-uli iobroker upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js appli$
                            2022-02-08 17:24:11.289  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                            2022-02-08 17:24:11.350  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:12.102  - ^[[32minfo^[[39m: host.debian-uli iobroker exit 0
                            2022-02-08 17:24:12.357  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:13.204  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [Tasmota-Heizungssteuerung-8]  has invalid password(8) or username(Tasmota-Heizungssteuerung-8)
                            2022-02-08 17:24:13.372  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:14.141  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.admin.0 started with pid 24635
                            2022-02-08 17:24:14.384  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:15.403  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:15.729  - ^[[32minfo^[[39m: admin.0 (24635) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v14.19.0, js-controller: 4.$
                            2022-02-08 17:24:15.779  - ^[[32minfo^[[39m: admin.0 (24635) requesting all states
                            2022-02-08 17:24:15.779  - ^[[32minfo^[[39m: admin.0 (24635) requesting all objects
                            2022-02-08 17:24:16.421  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:16.547  - ^[[32minfo^[[39m: admin.0 (24635) received all objects
                            2022-02-08 17:24:16.642  - ^[[32minfo^[[39m: admin.0 (24635) http server listening on port 8081
                            2022-02-08 17:24:16.643  - ^[[32minfo^[[39m: admin.0 (24635) Use link "http://localhost:8081" to configure.
                            2022-02-08 17:24:17.435  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:18.456  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:19.471  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:24:20.485  - ^[[33mwarn^[[39m: sonoff.8 (13012) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            und dann noch
                            2022-02-08 17:44:59.835  - ^[[32minfo^[[39m: feiertage.0 (26759) adapter feiertage objects written
                            2022-02-08 17:45:00.053  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.dwd.0 started with pid 26774
                            2022-02-08 17:45:00.082  - ^[[31merror^[[39m: telegram.0 (26392) Cannot send message [chatId - 573617805]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                            2022-02-08 17:45:00.340  - ^[[32minfo^[[39m: feiertage.0 (26759) Terminated (NO_ERROR): Without reason
                            2022-02-08 17:45:00.681  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:00.959  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
                            2022-02-08 17:45:01.469  - ^[[32minfo^[[39m: dwd.0 (26774) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.19.0, js-controller: 4.0.4
                            2022-02-08 17:45:01.699  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:02.291  - ^[[32minfo^[[39m: dwd.0 (26774) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2022-02-08 17:45:02.584  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.info.0 started with pid 26790
                            2022-02-08 17:45:02.710  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:02.818  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2022-02-08 17:45:03.727  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:04.085  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.luftdaten.0 started with pid 26809
                            2022-02-08 17:45:04.454  - ^[[33mwarn^[[39m: info.0 (26790) Object info.0.sysinfo.cpu.currentLoad.currentLoad is invalid: obj.common.min has an invalid type! Expect$
                            2022-02-08 17:45:04.456  - ^[[33mwarn^[[39m: info.0 (26790) This object will not be created in future versions. Please report this to the developer.
                            2022-02-08 17:45:04.475  - ^[[33mwarn^[[39m: info.0 (26790) Object info.0.sysinfo.cpu.currentLoad.currentLoadUser is invalid: obj.common.min has an invalid type! Ex$
                            2022-02-08 17:45:04.476  - ^[[33mwarn^[[39m: info.0 (26790) This object will not be created in future versions. Please report this to the developer.
                            2022-02-08 17:45:04.480  - ^[[33mwarn^[[39m: info.0 (26790) Object info.0.sysinfo.cpu.currentLoad.currentLoadSystem is invalid: obj.common.min has an invalid type! $
                            2022-02-08 17:45:04.480  - ^[[33mwarn^[[39m: info.0 (26790) This object will not be created in future versions. Please report this to the developer.
                            2022-02-08 17:45:04.484  - ^[[33mwarn^[[39m: info.0 (26790) Object info.0.sysinfo.cpu.currentLoad.currentLoadNice is invalid: obj.common.min has an invalid type! Ex$
                            2022-02-08 17:45:04.484  - ^[[33mwarn^[[39m: info.0 (26790) This object will not be created in future versions. Please report this to the developer.
                            2022-02-08 17:45:04.493  - ^[[33mwarn^[[39m: info.0 (26790) Object info.0.sysinfo.cpu.currentLoad.currentLoadIdle is invalid: obj.common.min has an invalid type! Ex$
                            2022-02-08 17:45:04.494  - ^[[33mwarn^[[39m: info.0 (26790) This object will not be created in future versions. Please report this to the developer.
                            2022-02-08 17:45:04.497  - ^[[33mwarn^[[39m: info.0 (26790) Object info.0.sysinfo.cpu.currentLoad.currentLoadIrq is invalid: obj.common.min has an invalid type! Exp$
                            2022-02-08 17:45:04.498  - ^[[33mwarn^[[39m: info.0 (26790) This object will not be created in future versions. Please report this to the developer.
                            2022-02-08 17:45:04.740  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:04.953  - ^[[32minfo^[[39m: info.0 (26790) starting. Version 1.9.16 in /opt/iobroker/node_modules/iobroker.info, node: v14.19.0, js-controller: 4.0$
                            2022-02-08 17:45:05.055  - ^[[32minfo^[[39m: info.0 (26790) Reading/updating systemdata.
                            2022-02-08 17:45:05.641  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [Tasmota-Heizungssteuerung-8]  has invalid password(8) or username(Tasmota-Heizungssteuerung-8)
                            2022-02-08 17:45:05.641  - ^[[32minfo^[[39m: info.0 (26790) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number$
                            2022-02-08 17:45:05.674  - ^[[32minfo^[[39m: info.0 (26790) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "str$
                            2022-02-08 17:45:05.720  - ^[[32minfo^[[39m: info.0 (26790) Reading CPU data every 3 seconds.
                            2022-02-08 17:45:05.748  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:05.752  - ^[[32minfo^[[39m: info.0 (26790) cpu Temp res = {"main":53,"cores":[54,54],"max":54,"socket":[49],"chipset":null}
                            2022-02-08 17:45:05.771  - ^[[32minfo^[[39m: info.0 (26790) Reading CPU temp data every 3 seconds.
                            2022-02-08 17:45:05.786  - ^[[32minfo^[[39m: info.0 (26790) Reading CPU current speed every 3 seconds.
                            2022-02-08 17:45:05.820  - ^[[32minfo^[[39m: info.0 (26790) Reading memory data every 3 seconds.
                            2022-02-08 17:45:05.927  - ^[[32minfo^[[39m: info.0 (26790) Reading battery data every 8 seconds.
                            2022-02-08 17:45:06.161  - ^[[32minfo^[[39m: luftdaten.0 (26809) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v14.19.0, js-contro$
                            2022-02-08 17:45:06.412  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.systeminfo.0 started with pid 26987
                            2022-02-08 17:45:06.766  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:06.797  - ^[[32minfo^[[39m: host.debian-uli instance scheduled system.adapter.odl.0 30 * * * *
                            2022-02-08 17:45:06.801  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [DVES_AEE787]  has invalid password(undefined) or username(Temp_05)
                            2022-02-08 17:45:06.855  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.odl.0 started with pid 27035
                            2022-02-08 17:45:07.025  - ^[[32minfo^[[39m: info.0 (26790) Reading user data every 8 seconds.
                            2022-02-08 17:45:07.192  - ^[[32minfo^[[39m: info.0 (26790) Reading process data every 8 seconds.
                            2022-02-08 17:45:07.502  - ^[[32minfo^[[39m: info.0 (26790) Reading disk data every 8 seconds.
                            2022-02-08 17:45:07.791  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:08.818  - ^[[31merror^[[39m: systeminfo.0 (26987) Unhandled promise rejection. This error originated either by throwing inside of an async function$
                            2022-02-08 17:45:08.818  - ^[[31merror^[[39m: systeminfo.0 (26987) unhandled promise rejection: Cannot read property 'getObjectList' of undefined
                            2022-02-08 17:45:08.824  - ^[[31merror^[[39m: systeminfo.0 (26987) TypeError: Cannot read property 'getObjectList' of undefined
                                at Function.initAdapter (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:44:55)
                                at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.systeminfo/myAdapter.js:118:37)
                                at Adapter.emit (events.js:400:28)
                                at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:8226:26
                            2022-02-08 17:45:08.824  - ^[[31merror^[[39m: systeminfo.0 (26987) Cannot read property 'getObjectList' of undefined
                            2022-02-08 17:45:08.854  - ^[[32minfo^[[39m: systeminfo.0 (26987) terminating
                            2022-02-08 17:45:08.858  - ^[[33mwarn^[[39m: systeminfo.0 (26987) Terminated (UNCAUGHT_EXCEPTION): Without reason
                            2022-02-08 17:45:09.280  - ^[[32minfo^[[39m: info.0 (26790) Reading network data every 3 seconds.
                            2022-02-08 17:45:09.467  - ^[[31merror^[[39m: host.debian-uli instance system.adapter.systeminfo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                            2022-02-08 17:45:09.467  - ^[[32minfo^[[39m: host.debian-uli Restart adapter system.adapter.systeminfo.0 because enabled
                            2022-02-08 17:45:09.566  - ^[[32minfo^[[39m: odl.0 (27035) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.odl, node: v14.19.0, js-controller: 4.0.4
                            2022-02-08 17:45:09.812  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:09.940  - ^[[32minfo^[[39m: odl.0 (27035) Terminated (NO_ERROR): Without reason
                            2022-02-08 17:45:10.540  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.odl.0 terminated with code 0 (NO_ERROR)
                            2022-02-08 17:45:10.631  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.text2command.0 started with pid 27392
                            2022-02-08 17:45:10.829  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:11.839  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:12.030  - ^[[32minfo^[[39m: text2command.0 (27392) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.text2command, node: v14.19.0, js-$
                            2022-02-08 17:45:12.854  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:13.870  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:14.877  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:15.728  - ^[[32minfo^[[39m: vis.0 (27444) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 4.0.4
                            2022-02-08 17:45:15.892  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:15.895  - ^[[32minfo^[[39m: vis.0 (27444) vis license is OK.
                            2022-02-08 17:45:16.243  - ^[[32minfo^[[39m: luftdaten.0 (26809) Terminated (NO_ERROR): Without reason
                            2022-02-08 17:45:16.759  - ^[[32minfo^[[39m: vis.0 (27444) Terminated (NO_ERROR): Without reason
                            2022-02-08 17:45:16.774  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                            2022-02-08 17:45:16.907  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:17.355  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.vis.0 terminated while should be started once
                            2022-02-08 17:45:17.919  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:18.776  - ^[[32minfo^[[39m: host.debian-uli instance scheduled system.adapter.luftdaten.2 */30 * * * *
                            2022-02-08 17:45:18.803  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.luftdaten.2 started with pid 27673
                            2022-02-08 17:45:18.938  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:19.969  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:20.174  - ^[[32minfo^[[39m: luftdaten.2 (27673) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v14.19.0, js-contro$
                            2022-02-08 17:45:20.994  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:22.009  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:23.030  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:24.040  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:25.057  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-08 17:45:26.071  - ^[[33mwarn^[[39m: sonoff.8 (26536) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:00.013  - ^[[32minfo^[[39m: javascript.0 (18182) script.js.Heizung.HeizungspumpeFürHeizkörper: getState(id=sonoff.0.Tasmota-Heizungssteuerung-8.DS1$
                            2022-02-09 10:30:00.013  - ^[[32minfo^[[39m: javascript.0 (18182) script.js.Heizung.HeizungspumpeFürHeizkörper: sendTo(adapter=telegram.1, cmd=send, msg={"text":"55$
                            2022-02-09 10:30:00.019  - ^[[31merror^[[39m: javascript.0 (18182) script.js.Heizung.Warmwasserpumpe_temperaturgesteuert: 55.5
                            2022-02-09 10:30:00.052  - ^[[31merror^[[39m: telegram.0 (25767) Cannot send message [chatId - 573617805]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                            2022-02-09 10:30:00.064  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.luftdaten.0 started with pid 31002
                            2022-02-09 10:30:00.407  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:00.831  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [Tasmota-Heizungssteuerung-8]  has invalid password(8) or username(Tasmota-Heizungssteuerung-8)
                            2022-02-09 10:30:01.433  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:01.456  - ^[[32minfo^[[39m: luftdaten.0 (31002) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v14.19.0, js-contro$
                            2022-02-09 10:30:02.476  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:03.390  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [DVES_AEE787]  has invalid password(undefined) or username(Temp_05)
                            2022-02-09 10:30:03.498  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:04.086  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.dwd.0 started with pid 31017
                            2022-02-09 10:30:04.539  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:05.563  - ^[[32minfo^[[39m: dwd.0 (31017) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.19.0, js-controller: 4.0.4
                            2022-02-09 10:30:05.597  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:06.476  - ^[[32minfo^[[39m: dwd.0 (31017) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2022-02-09 10:30:06.660  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:07.000  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2022-02-09 10:30:07.707  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:08.107  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.ical.0 started with pid 31033
                            2022-02-09 10:30:08.751  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:09.763  - ^[[32minfo^[[39m: ical.0 (31033) starting. Version 1.11.6 in /opt/iobroker/node_modules/iobroker.ical, node: v14.19.0, js-controller: 4.0$
                            2022-02-09 10:30:09.812  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:09.883  - ^[[33mwarn^[[39m: ical.0 (31033) Error reading "192.168.0.20:5001/Abfallkalender/rosensteinstrassebartholomae.ics": File does not exist: $
                            2022-02-09 10:30:09.884  - ^[[32minfo^[[39m: ical.0 (31033) All calenders could not be processed, Do not clean up events
                            2022-02-09 10:30:10.864  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:11.926  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:12.130  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.luftdaten.2 started with pid 31050
                            2022-02-09 10:30:12.967  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:13.542  - ^[[32minfo^[[39m: luftdaten.2 (31050) starting. Version 1.0.1 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v14.19.0, js-contro$
                            2022-02-09 10:30:14.012  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:14.895  - ^[[32minfo^[[39m: ical.0 (31033) Terminated (NO_ERROR): Without reason
                            2022-02-09 10:30:15.048  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:15.423  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            2022-02-09 10:30:16.093  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:16.151  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.odl.0 started with pid 31065
                            2022-02-09 10:30:17.135  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:17.610  - ^[[32minfo^[[39m: odl.0 (31065) starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.odl, node: v14.19.0, js-controller: 4.0.4
                            2022-02-09 10:30:17.959  - ^[[32minfo^[[39m: odl.0 (31065) Terminated (NO_ERROR): Without reason
                            2022-02-09 10:30:18.210  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:18.485  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.odl.0 terminated with code 0 (NO_ERROR)
                            2022-02-09 10:30:19.268  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:20.326  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:21.376  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:22.428  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:23.473  - ^[[33mwarn^[[39m: sonoff.8 (937) Client [mqtt-explorer-2df6de9e]  has invalid password(undefined) or username(undefined)
                            2022-02-09 10:30:23.578  - ^[[32minfo^[[39m: luftdaten.2 (31050) Terminated (NO_ERROR): Without reason
                            2022-02-09 10:30:24.101  - ^[[32minfo^[[39m: host.debian-uli instance system.adapter.luftdaten.2 terminated with code 0 (NO_ERROR)
                            so, ichhoffe, da ist was dabei
                            • P pingps
                              und dann noch
                              @pingps
                              which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              cd /opt/iobroker
                              iobroker update
                              iobroker upgrade
                                @pingps
                                cd /opt/iobroker
                                iobroker update
                                iobroker upgrade
                                pingps
                                broker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                upload [4] info.admin /opt/iobroker/node_modu$ les/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
                                -sh: 69: Syntax error: "(" unexpecte$ d
                                -sh: 124: $: not found
                                $ $ $ upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/systemInformation.js lib/js/systemInformation.js application/javascript
                                -sh: 125: upload: not found
                                $ -sh: 126: upload: not found
                                $ -sh: 127: upload: not found
                                upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter$ .js lib/js/upda-sh: 69: $ teAdapter.js application/javascript
                                upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
                                upload [0] info.admin /opt/iobroker/node_mCould: not foundodules/iobroker.info/admin/words.js words.js application/javascript
                                Cannot check dependencies: Invalid version of "admin". Installed
                                "4.2.1", required ">=5.1.19
                                Thomas BraunT P 2 Antworten Letzte Antwort
                                • P pingps
                                  @pingps
                                  Was soll das sein?
                                  • P pingps
                                    pingps
                                    @pingps
                                    Hallo, ich hatte die Befehle ausgeführt. Das sollte das Resultat sein. Kurzum. Der Admin war immer noch der alte...
                                    • P pingps
                                      @pingps
                                      @pingps
                                      Wäre hilfreich, wenn man die Ausgaben komplett sehen würde. Meine Glaskugel ist gerade in der Spülmaschine.
                                        @pingps
                                        pingps
                                        @thomas-braun sorry, ok, die muss natürlich auch mal wieder gereinigt werden 😀
                                        $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                        ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                        $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v14.19.0
                                        v14.19.0
                                        Holen:1 http://security.debian.org/debian-security stretch/updates InRelease [53,0 kB]
                                        Ign:2 http://ftp.de.debian.org/debian stretch InRelease
                                        OK:3 http://ftp.de.debian.org/debian stretch-updates InRelease
                                        OK:4 http://ftp.de.debian.org/debian stretch Release
                                        0% [1 InRelease gpgv 53,0 kB]6.14.16
                                        uli
                                        /opt/iobroker
                                        OK:5 https://dl.yarnpkg.com/debian stable InRelease
                                        Es wurden 53,0 kB in 0 s geholt (81,5 kB/s).
                                        E: Konnte Sperre /var/lib/apt/lists/lock nicht bekommen - open (11: Die Ressource ist zur Zeit nicht verfügbar)
                                        E: Das Verzeichnis /var/lib/apt/lists/ kann nicht gesperrt werden.
                                        Alle Pakete sind aktuell.
                                        nodejs:
                                          Installiert:           14.19.0-1nodesource1
                                          Installationskandidat: 14.19.0-1nodesource1
                                          Versionstabelle:
                                         *** 14.19.0-1nodesource1 100
                                             4.8.2~dfsg-1 500
                                                500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
                                        [1] + Done(100)                  which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update
                                        $ cd /opt/iobroker
                                        $ iobroker update
                                        Controller "js-controller": 4.0.5    , installed 4.0.4  [Updatable]
                                        $ iobroker upgrade
                                        This upgrade of "yr" will introduce the following changes:
                                        -> 5.0.0:
                                        Fixed translations
                                        Update dates data type
                                        -> 4.0.0:
                                        Would you like to upgrade yr from @3.0.5 to @5.0.0 now? [(y)es, (n)o]: y
                                        Update yr from @3.0.5 to @5.0.0
                                        Installing iobroker.yr@5.0.0... (System call)
                                        upload [96] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [90] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                        upload [80] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/fair_night.svg icons/fair_night.svg image/svg+xml
                                        upload [70] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/heavyrainshowersandthunder_polartwilight.svg icons/heavyrainshowersandthunder_polartwilight.svg image/svg+xml
                                        upload [60] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/heavysnowandthunder.svg icons/heavysnowandthunder.svg image/svg+xml
                                        upload [50] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/lightrainshowers_night.svg icons/lightrainshowers_night.svg image/svg+xml
                                        upload [40] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/lightsnow.svg icons/lightsnow.svg image/svg+xml
                                        upload [30] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/lightssnowshowersandthunder_polartwilight.svg icons/lightssnowshowersandthunder_polartwilight.svg image/svg+xml
                                        upload [20] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/rainshowersandthunder_night.svg icons/rainshowersandthunder_night.svg image/svg+xml
                                        upload [19] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/rainshowersandthunder_polartwilight.svg icons/rainshowersandthunder_polartwilight.svg image/svg+xml
                                        upload [18] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/sleet.svg icons/sleet.svg image/svg+xml
                                        upload [17] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/sleetandthunder.svg icons/sleetandthunder.svg image/svg+xml
                                        upload [16] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/sleetshowers_day.svg icons/sleetshowers_day.svg image/svg+xml
                                        upload [15] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/sleetshowers_night.svg icons/sleetshowers_night.svg image/svg+xml
                                        upload [14] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/sleetshowers_polartwilight.svg icons/sleetshowers_polartwilight.svg image/svg+xml
                                        upload [13] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/sleetshowersandthunder_day.svg icons/sleetshowersandthunder_day.svg image/svg+xml
                                        upload [12] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/sleetshowersandthunder_night.svg icons/sleetshowersandthunder_night.svg image/svg+xml
                                        upload [11] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/sleetshowersandthunder_polartwilight.svg icons/sleetshowersandthunder_polartwilight.svg image/svg+xml
                                        upload [10] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/snow.svg icons/snow.svg image/svg+xml
                                        upload [9] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/snowandthunder.svg icons/snowandthunder.svg image/svg+xml
                                        upload [8] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/snowshowers_day.svg icons/snowshowers_day.svg image/svg+xml
                                        upload [7] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/snowshowers_night.svg icons/snowshowers_night.svg image/svg+xml
                                        upload [6] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/snowshowers_polartwilight.svg icons/snowshowers_polartwilight.svg image/svg+xml
                                        upload [5] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/snowshowersandthunder_day.svg icons/snowshowersandthunder_day.svg image/svg+xml
                                        upload [4] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/snowshowersandthunder_night.svg icons/snowshowersandthunder_night.svg image/svg+xml
                                        upload [3] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/icons/snowshowersandthunder_polartwilight.svg icons/snowshowersandthunder_polartwilight.svg image/svg+xml
                                        upload [2] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/index_m.html index_m.html text/html
                                        upload [1] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/words.js words.js application/javascript
                                        upload [0] yr.admin /opt/iobroker/node_modules/iobroker.yr/admin/yr.png yr.png image/png
                                        This upgrade of "vis-weather" will introduce the following changes:
                                        -> 2.5.5:
                                        bug fix color of labels in widget
                                        -> 2.5.4:
                                        avoid endles loops
                                        Would you like to upgrade vis-weather from @2.5.3 to @2.5.5 now? [(y)es, (n)o]: y
                                        Update vis-weather from @2.5.3 to @2.5.5
                                        Installing iobroker.vis-weather@2.5.5... (System call)
                                        INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-weather/www" was not found! Nothing was uploaded or deleted.
                                        upload [3] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index.html index.html text/html
                                        upload [2] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index_m.html index_m.html text/html
                                        upload [1] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/vis-weather.png vis-weather.png image/png
                                        upload [0] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/words.js words.js application/javascript
                                        This upgrade of "tr-064" will introduce the following changes:
                                        -> 4.2.15:
                                        fix crash case (Sentry IOBROKER-TR-064-35)
                                        Would you like to upgrade tr-064 from @4.2.14 to @4.2.15 now? [(y)es, (n)o]: y
                                        Update tr-064 from @4.2.14 to @4.2.15
                                        Installing iobroker.tr-064@4.2.15... (System call)
                                        upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                        upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                        upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                        This upgrade of "telegram" will introduce the following changes:
                                        -> 1.11.1:
                                        fixed the receiving files
                                        -> 1.11.0:
                                        Added bruteforce protection
                                        Extended blockly with `disable_web_preview` option
                                        added `communicate.responseSilent` state to answer silently
                                        -> 1.10.1:
                                        Updated telegram library
                                        Would you like to upgrade telegram from @1.10.0 to @1.11.1 now? [(y)es, (n)o]: y
                                        Update telegram from @1.10.0 to @1.11.1
                                        Installing iobroker.telegram@1.11.1... (System call)
                                        upload [6] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                        upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/custom_m.html custom_m.html text/html
                                        upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index.html index.html text/html
                                        upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/index_m.html index_m.html text/html
                                        upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                                        upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                        upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                        This upgrade of "sql" will introduce the following changes:
                                        -> 1.16.1:
                                        Hide settings not relevant when "log changes only" is not used
                                        Allow all number values for debounce again
                                        -> 1.16.0:
                                        Support only `js.controller` >= 3.3.x
                                        Used system/custom view for collecting the objects
                                        Implemented option to ignore zero- or/and below zero- values
                                        Would you like to upgrade sql from @1.15.7 to @1.16.1 now? [(y)es, (n)o]: y
                                        Update sql from @1.15.7 to @1.16.1
                                        Installing iobroker.sql@1.16.1... (System call)
                                        upload [7] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html custom.html text/html
                                        upload [6] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom_m.html custom_m.html text/html
                                        upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
                                        upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index_m.html index_m.html text/html
                                        upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/jsonConfig.json jsonConfig.json application/json
                                        upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/jsonCustom.json jsonCustom.json application/json
                                        upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
                                        upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
                                        Would you like to upgrade node-red from @2.4.1 to @2.4.2 now? [(y)es, (n)o]: y
                                        Update node-red from @2.4.1 to @2.4.2
                                        Installing iobroker.node-red@2.4.2... (System call)
                                        upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
                                        upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                        upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                        upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                        upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                        upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                        upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                        upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                        upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                        upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                        upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
                                        upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
                                        upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
                                        upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
                                        -> 5.2.3:
                                        -> 5.2.2:
                                        -> 5.2.1:
                                        -> 5.2.0:
                                        -> 5.1.29:
                                        -> 5.1.28:
                                        Fixed some GUI bugs
                                        Cannot check dependencies: Invalid version of "admin". Installed "4.2.1", required ">=5.1.0
                                        This upgrade of "vis" will introduce the following changes:
                                        -> 1.4.8:
                                        Added support for js-controller 4.x
                                        -> 1.4.7:
                                        Fixed subscribeOidAtRuntime if called with invalid IDs
                                        Added support of license manager
                                        -> 1.4.6:
                                        Added the license check even without internet
                                        Would you like to upgrade vis from @1.4.5 to @1.4.8 now? [(y)es, (n)o]: y
                                        Update vis from @1.4.5 to @1.4.8
                                        Installing iobroker.vis@1.4.8... (System call)
                                        upload [680] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                        upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
                                        upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
                                        upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/mine/24/css.png js/fm/icon/mine/24/css.png image/png
                                        upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/css/superfish/superfish-vertical.css lib/css/superfish/superfish-vertical.css text/css
                                        upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/img/Prev_AckBool.png widgets/basic/img/Prev_AckBool.png image/png
                                        upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/calendar/img/calendar.png widgets/calendar/img/calendar.png image/png
                                        upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_JquiDialog.png widgets/jqui/img/Prev_JquiDialog.png image/png
                                        upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_window_1w.svg widgets/jqui-mfd/img/fts_window_1w.svg image/svg+xml
                                        upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_20.png widgets/jqui-mfd/img/sani_valve_20.png image/png
                                        upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/metro/fonts/iconFont.ttf widgets/metro/fonts/iconFont.ttf font/ttf
                                        upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/jquery.sliderTabs.min.css widgets/tabs/styles/jquery.sliderTabs.min.css text/css
                                        upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/31-1.png widgets/timeandweather/img/clock/31-1.png image/png
                                        upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/41-1.png widgets/timeandweather/img/clock/41-1.png image/png
                                        upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/511-1.png widgets/timeandweather/img/clock/511-1.png image/png
                                        upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/7.png widgets/timeandweather/img/clock/7.png image/png
                                        upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/apm.png widgets/timeandweather/img/clock/apm.png image/png
                                        upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/icon_right.png widgets/timeandweather/img/icon_right.png image/png
                                        upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/todo/dev.html widgets/todo/dev.html text/html
                                        upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.canvaswrapper.js widgets/weather/lib/js/flot/jquery.canvaswrapper.js application/javascript
                                        upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.fillbetween.js widgets/weather/lib/js/flot/jquery.flot.fillbetween.js application/javascript
                                        upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.flatdata.js widgets/weather/lib/js/flot/jquery.flot.flatdata.js application/javascript
                                        upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.hover.js widgets/weather/lib/js/flot/jquery.flot.hover.js application/javascript
                                        upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.image.js widgets/weather/lib/js/flot/jquery.flot.image.js application/javascript
                                        upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.js widgets/weather/lib/js/flot/jquery.flot.js application/javascript
                                        upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.legend.js widgets/weather/lib/js/flot/jquery.flot.legend.js application/javascript
                                        upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.logaxis.js widgets/weather/lib/js/flot/jquery.flot.logaxis.js application/javascript
                                        upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.navigate.js widgets/weather/lib/js/flot/jquery.flot.navigate.js application/javascript
                                        upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.pie.js widgets/weather/lib/js/flot/jquery.flot.pie.js application/javascript
                                        upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.resize.js widgets/weather/lib/js/flot/jquery.flot.resize.js application/javascript
                                        upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.saturated.js widgets/weather/lib/js/flot/jquery.flot.saturated.js application/javascript
                                        upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.selection.js widgets/weather/lib/js/flot/jquery.flot.selection.js application/javascript
                                        upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.stack.js widgets/weather/lib/js/flot/jquery.flot.stack.js application/javascript
                                        upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.symbol.js widgets/weather/lib/js/flot/jquery.flot.symbol.js application/javascript
                                        upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.threshold.js widgets/weather/lib/js/flot/jquery.flot.threshold.js application/javascript
                                        upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.time.js widgets/weather/lib/js/flot/jquery.flot.time.js application/javascript
                                        upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touch.js widgets/weather/lib/js/flot/jquery.flot.touch.js application/javascript
                                        upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js widgets/weather/lib/js/flot/jquery.flot.touchNavigate.js application/javascript
                                        upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.flot.uiConstants.js widgets/weather/lib/js/flot/jquery.flot.uiConstants.js application/javascript
                                        upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.js widgets/weather/lib/js/flot/jquery.js application/javascript
                                        upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather.html widgets/weather.html text/html
                                        upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                        upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                                        upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                        upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                                        Cannot check dependencies: Invalid version of "admin". Installed "4.2.1", required ">=5.1.28
                                        Cannot check dependencies: Invalid version of "admin". Installed "4.2.1", required ">=5.0.0
                                        Cannot check dependencies: Invalid version of "admin". Installed "4.2.1", required ">=5.1.25
                                        Cannot check dependencies: Invalid version of "admin". Installed "4.2.1", required ">=5.1.9
                                        This upgrade of "info" will introduce the following changes:
                                        -> 1.9.18:
                                        Fix invalid object definition to prevent errors in js-controller 4
                                        -> 1.9.17:
                                        Design fix
                                        Update dependencies
                                        Would you like to upgrade info from @1.9.16 to @1.9.18 now? [(y)es, (n)o]: y
                                        Update info from @1.9.16 to @1.9.18
                                        Installing iobroker.info@1.9.18... (System call)
                                        upload [85] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                        upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                                        upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                                        upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/memory.png lib/img/icons/memory.png image/png
                                        upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                                        upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                                        upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                                        upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                                        upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/chartist.min.js lib/js/chartist.min.js application/javascript
                                        upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/clock.js lib/js/clock.js application/javascript
                                        upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/commons.js lib/js/commons.js application/javascript
                                        upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/documentation.js lib/js/documentation.js application/javascript
                                        upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/feednami.min.js lib/js/feednami.min.js application/javascript
                                        upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/format-google-calender.js lib/js/format-google-calender.js application/javascript
                                        upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/forum.js lib/js/forum.js application/javascript
                                        upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/githubData.js lib/js/githubData.js application/javascript
                                        upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/helper.js lib/js/helper.js application/javascript
                                        upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                                        upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/info.js lib/js/info.js application/javascript
                                        upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/news.js lib/js/news.js application/javascript
                                        upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/popupnews.js lib/js/popupnews.js application/javascript
                                        upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/searchGithub.js lib/js/searchGithub.js application/javascript
                                        upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                        upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/simplemde.min.js lib/js/simplemde.min.js application/javascript
                                        upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapter.js application/javascript
                                        upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                        Cannot check dependencies: Invalid version of "admin". Installed "4.2.1", required ">=5.1.19
                                        $ ^C
                                        • P pingps
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          v14.19.0
                                          v14.19.0
                                          uli
                                          /opt/iobroker
                                          nodejs:
                                            Versionstabelle:
                                               4.8.2~dfsg-1 500
                                          $ cd /opt/iobroker
                                          $ iobroker update
                                          Used repository: beta
                                          Adapter    "admin"        : 5.2.3    , installed 4.2.1  [Updatable]
                                          Adapter    "alias-manager": 1.2.4    , installed 1.2.4
                                          Adapter    "backitup"     : 2.2.4    , installed 2.2.4
                                          Adapter    "ble"          : 0.12.0   , installed 0.12.0
                                          Adapter    "calendar"     : 1.2.0    , installed 1.2.0
                                          Adapter    "digitalstrom" : 2.3.0    , installed 2.3.0
                                          Adapter    "discovery"    : 2.7.5    , installed 2.7.5
                                          Adapter    "ds18b20"      : 1.6.0    , installed 1.6.0
                                          Adapter    "dwd"          : 2.7.7    , installed 2.7.7
                                          Adapter    "echarts"      : 1.0.3    , installed 1.0.3
                                          Adapter    "email"        : 1.0.10   , installed 1.0.10
                                          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                                          Adapter    "flot"         : 1.10.7   , installed 1.10.7
                                          Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
                                          Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
                                          Adapter    "heizoel"      : 1.0.2    , installed 1.0.2
                                          Adapter    "history"      : 1.10.5   , installed 1.10.5
                                          Adapter    "hm-rega"      : 3.0.35   , installed 3.0.35
                                          Adapter    "hm-rpc"       : 1.15.2   , installed 1.15.2
                                          Adapter    "ical"         : 1.11.6   , installed 1.11.6
                                          Adapter    "influxdb"     : 2.4.0    , installed 1.9.4  [Updatable]
                                          Adapter    "info"         : 1.9.18   , installed 1.9.16 [Updatable]
                                          Adapter    "javascript"   : 5.2.21   , installed 4.10.9 [Updatable]
                                          Adapter    "luftdaten"    : 2.1.3    , installed 1.0.1  [Updatable]
                                          Adapter    "mihome-plug"  : 0.2.1    , installed 0.2.1
                                          Adapter    "mihome-vacuum": 3.3.3    , installed 3.3.3
                                          Adapter    "moma"         : 1.2.9    , installed 1.2.9
                                          Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
                                          Adapter    "mysensors"    : 2.0.3    , installed 2.0.3
                                          Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                          Adapter    "node-red"     : 2.4.2    , installed 2.4.1  [Updatable]
                                          Adapter    "nut"          : 1.5.0    , installed 1.5.0
                                          Adapter    "odl"          : 1.1.4    , installed 1.1.4
                                          Adapter    "owfs"         : 0.6.4    , installed 0.6.4
                                          Adapter    "parser"       : 1.0.7    , installed 1.0.7
                                          Adapter    "ping"         : 1.5.2    , installed 1.5.2
                                          Adapter    "scenes"       : 2.3.8    , installed 2.3.8
                                          Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                                          Adapter    "shelly"       : 5.1.2    , installed 4.1.2  [Updatable]
                                          Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
                                          Adapter    "socketio"     : 4.1.0    , installed 3.1.5  [Updatable]
                                          Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
                                          Adapter    "sony-bravia"  : 1.0.3    , installed 1.0.3
                                          Adapter    "sql"          : 1.16.1   , installed 1.15.7 [Updatable]
                                          Adapter    "synology"     : 1.1.3    , installed 1.1.3
                                          Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
                                          Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                                          Adapter    "telegram"     : 1.11.1   , installed 1.10.0 [Updatable]
                                          Adapter    "terminal"     : 0.1.2    , installed 0.1.2
                                          Adapter    "text2command" : 2.1.1    , installed 2.1.1
                                          Adapter    "tr-064"       : 4.2.15   , installed 4.2.14 [Updatable]
                                          Adapter    "trashschedule": 1.4.2    , installed 1.0.3  [Updatable]
                                          Adapter    "tvspielfilm"  : 2.0.4    , installed 2.0.4
                                          Adapter    "vis"          : 1.4.8    , installed 1.4.5  [Updatable]
                                          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                          Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
                                          Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
                                          Adapter    "vis-weather"  : 2.5.5    , installed 2.5.3  [Updatable]
                                          Adapter    "web"          : 4.1.1    , installed 3.2.3  [Updatable]
                                          Adapter    "yr"           : 5.0.0    , installed 3.0.5  [Updatable]
                                          $ iobroker upgrade
                                          -> 5.0.0:
                                          Fixed translations
                                          -> 4.0.0:
                                          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                          -> 2.5.5:
                                          -> 2.5.4:
                                          avoid endles loops
                                          -> 4.2.15:
                                          -> 1.11.1:
                                          -> 1.11.0:
                                          -> 1.10.1:
                                          -> 1.16.1:
                                          -> 1.16.0:
                                          This upgrade of "admin" will at least introduce the following changes:
                                          -> 5.2.3:
                                          Fixed error in `AutocompleteSendTo`
                                          Fixed error in charts
                                          -> 5.2.2:
                                          Changed the minimal required js-controller version to 3.3.22
                                          Used web-socket library 8 (no node 10 support anymore)
                                          -> 5.2.1:
                                          Allow in expert mode the creation of states and channels in mqtt branch
                                          -> 5.2.0:
                                          Fix crash cases reported via sentry
                                          Added support for multi-repositories
                                          -> 5.1.29:
                                          -> 5.1.28:
                                          Fixed discovery function
                                          Fixed some GUI bugs
                                          Would you like to upgrade admin from @4.2.1 to @5.2.3 now? [(y)es, (n)o]: y
                                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                                          -> 1.4.8:
                                          -> 1.4.7:
                                          -> 1.4.6:
                                          -> 1.9.18:
                                          -> 1.9.17:
                                          Design fix
                                          Update dependencies
                                          $ ^C
                                          @pingps sagte in Wollte mal wieder updaten, leider nur Probleme:
                                          Wo kommt die Quelle her? Braucht kein Mensch beim ioBroker.
                                          Und kürz dein login prompt nicht. Man muss sehen in welchem Verzeichnis du da rumspringst.
                                          82.6k
