  4. [Gelöst] Bekomme keine latest Versionen mehr angezeigt
    1.0k
    6.1k
16 Beiträge 4 Kommentatoren 1.0k Aufrufe 3 Beobachtet
    @rewenode
    iobroker repo list
    iobroker update -i
    rewenode
    @thomas-braun sagte in Bekomme keine latest Versionen mehr angezeigt:
    iobroker update -i
    root@iobroker:/opt/iobroker# iobroker repo list
    stable      : http://download.iobroker.net/sources-dist.json
    latest      : http://download.iobroker.net/sources-dist-latest.json
    Active repo: stable
    root@iobroker:/opt/iobroker# iobroker update -i
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.2.3    , installed 5.2.3
    Adapter    "alexa2"        : 3.11.2   , installed 3.11.2
    Adapter    "alias-manager" : 1.2.4    , installed 1.2.4
    Adapter    "backitup"      : 2.2.3    , installed 2.2.3
    Adapter    "discovery"     : 2.7.3    , installed 2.7.3
    Adapter    "email"         : 1.0.10   , installed 1.0.10
    Adapter    "hm-rega"       : 3.0.33   , installed 3.0.33
    Adapter    "hm-rpc"        : 1.15.0   , installed 1.15.0
    Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
    Adapter    "info"          : 1.9.8    , installed 1.9.8
    Adapter    "iot"           : 1.8.24   , installed 1.8.24
    Adapter    "javascript"    : 5.2.13   , installed 5.2.13
    Controller "js-controller" : 3.3.22   , installed 3.3.22
    Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
    Adapter    "node-red"      : 2.4.1    , installed 2.4.1
    Adapter    "openweathermap": 0.1.0    , installed 0.1.0
    Adapter    "proxy"         : 1.2.2    , installed 1.2.2
    Adapter    "scenes"        : 2.3.8    , installed 2.3.8
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "socketio"      : 3.1.5    , installed 3.1.5
    Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
    Adapter    "tuya"          : 3.6.14   , installed 3.6.14
    Adapter    "web"           : 3.4.16   , installed 3.4.16
    Adapter    "zigbee"        : 1.6.6    , installed 1.6.6
    Bekomme aber nur stable angezeigt ?
    was mache ich falsch?
    Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
    • R rewenode
      iobroker update -i
      Active repo: stable
      update done
      @rewenode
      Dein Login als root ist falsch.
      R 1 Antwort Letzte Antwort
      • R rewenode
        iobroker update -i
        Active repo: stable
        update done
        GlasfaserG Offline
        GlasfaserG Offline
        @rewenode sagte in Bekomme keine latest Versionen mehr angezeigt:
        Active repo: stable
        Du bist auch stable und nicht latest
        • GlasfaserG Glasfaser
          Active repo: stable
          rewenode
          @glasfaser Ja eben, habe aber latest auch eingetragen;-(
          • R rewenode
            @rewenode
            Das muss aber auch aktiv gesetzt werden.
            iobroker repo set latest
            iobroker update -i
            GlasfaserG R 2 Antworten Letzte Antwort
              @rewenode
              rewenode
              @thomas-braun Ja, war schnell mal über die Container Shell. Ändert aber auch nichts.
              iobroker@iobroker:~$ iobroker repo list
              Active repo: stable
              iobroker@iobroker:~$ iobroker update -i
              update done
                @rewenode
                iobroker update -i
                GlasfaserG Offline
                GlasfaserG Offline
                @rewenode
                Bei Einstellungen !!
                Verstehe dann den Threadtitel dann nicht ... wie kommst du dann da drauf
                • R rewenode
                  Active repo: stable
                  update done
                  Man wird GAR NICHT root. Nicht kurz, nicht mal nur eben, nicht nur für eine Aktion. Gar nicht!
                  Stell latest halt auf aktiv.
                    @rewenode
                    iobroker update -i
                    rewenode
                    @thomas-braun Danke, das wars.
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @rewenode
                      Hast du eine Synology ... oder Qnap
                        @rewenode
                        rewenode
                        @glasfaser Rock64
                        Hab's dank eures Hinweises schon gefunden. Wer Augen hat...
                          rewenode
                          @thomas-braun Schon gut, mach's nie wieder. Versprochen!
                          • R rewenode
                            und warum, um alles in der Welt, willst du unbedingt unstabile Versionen testen?
                              rewenode
                              @homoran Wollte nur mal den zigbee 1.6.14 in einer 2ten Instance testen, weil da eine Änderung für ein Gerät drin ist was ich gerne hätte.
