  4. Portainer Fehler ungültiges Token?
    6.3k
15 Beiträge 2 Kommentatoren 2.0k Aufrufe 2 Beobachtet
  • ? Offline
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Nuc Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
    Arbeitsspeicher: 4 GB
    Festplattenart: HDD
    Betriebssystem: Ubuntu/Windows/Mac
    Node-Version: 14.18.2
    Nodejs-Version: 14.18.2
    NPM-Version: v6.14.15
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link
    level=info msg="2022/01/09 11:36:54 [FATAL] [internal,init] No administrator account was created in 5.000000 mins. Shutting down the Portainer instance for security reasons",
    2022/01/09 11:36:55 server: Reverse tunnelling enabled,
    2022/01/09 11:36:55 server: Fingerprint e9:5c:0b:1e:71:72:df:f6:04:27:83:e5:fb:57:8b:22,
    2022/01/09 11:36:55 server: Listening on 0.0.0.0:8000...,
    level=info msg="2022/01/09 11:36:55 [INFO] [cmd,main] Starting Portainer version 2.9.3",
    level=info msg="2022/01/09 11:36:55 [DEBUG] [chisel, monitoring] [check_interval_seconds: 10.000000] [message: starting tunnel management process]",
    level=info msg="2022/01/09 11:36:55 [DEBUG] [internal,init] [message: start initialization monitor ]",
    level=info msg="2022/01/09 11:36:55 [INFO] [http,server] [message: starting HTTPS server on port :9443]",
    level=info msg="2022/01/09 11:36:55 [INFO] [http,server] [message: starting HTTP server on port :9000]",
    level=info msg="2022/01/09 11:41:55 [FATAL] [internal,init] No administrator account was created in 5.000000 mins. Shutting down the Portainer instance for security reasons",
    2022/01/09 11:41:56 server: Reverse tunnelling enabled,
    2022/01/09 11:41:56 server: Fingerprint e9:5c:0b:1e:71:72:df:f6:04:27:83:e5:fb:57:8b:22,
    2022/01/09 11:41:56 server: Listening on 0.0.0.0:8000...,
    level=info msg="2022/01/09 11:41:56 [INFO] [cmd,main] Starting Portainer version 2.9.3",
    level=info msg="2022/01/09 11:41:56 [DEBUG] [chisel, monitoring] [check_interval_seconds: 10.000000] [message: starting tunnel management process]",
    level=info msg="2022/01/09 11:41:56 [DEBUG] [internal,init] [message: start initialization monitor ]",
    level=info msg="2022/01/09 11:41:56 [INFO] [http,server] [message: starting HTTPS server on port :9443]",
    level=info msg="2022/01/09 11:41:56 [INFO] [http,server] [message: starting HTTP server on port :9000]",
    level=info msg="2022/01/09 11:42:11 http error: Unable to initiate communications with environment (err=unable to load in-cluster configuration, KUBERNETES_SERVICE_HOST and KUBERNETES_SERVICE_PORT must be defined) (code=500)",
    level=info msg="2022/01/09 19:17:36 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:18:02 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:18:57 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:19:11 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:19:31 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:19:56 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:20:54 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:21:37 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:22:43 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:24:38 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:24:46 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:25:58 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:39:28 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:40:25 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/09 19:42:22 http error: Invalid JWT token (err=Invalid JWT token) (code=401)",
    level=info msg="2022/01/10 07:15:23 http error: Invalid JWT token (err=Invalid JWT token) (code=401)",
    level=info msg="2022/01/10 07:16:25 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/10 07:17:13 http error: Unable to retrieve DockerHub token from DockerHub (err=Get \"https://auth.docker.io/token?service=registry.docker.io&scope=repository:ratelimitpreview/test:pull\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)) (code=500)",
    level=info msg="2022/01/10 07:17:26 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/10 07:19:09 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/10 07:24:49 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/10 07:33:38 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/01/10 07:35:20 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    2022/02/04 19:58:27 server: Reverse tunnelling enabled,
    2022/02/04 19:58:27 server: Fingerprint e9:5c:0b:1e:71:72:df:f6:04:27:83:e5:fb:57:8b:22,
    2022/02/04 19:58:27 server: Listening on 0.0.0.0:8000...,
    level=info msg="2022/02/04 19:58:27 [DEBUG] [chisel, monitoring] [check_interval_seconds: 10.000000] [message: starting tunnel management process]",
    level=info msg="2022/02/04 19:58:27 [INFO] [cmd,main] Starting Portainer version 2.9.3",
    level=info msg="2022/02/04 19:58:27 [DEBUG] [internal,init] [message: start initialization monitor ]",
    level=info msg="2022/02/04 19:58:27 [INFO] [http,server] [message: starting HTTPS server on port :9443]",
    level=info msg="2022/02/04 19:58:27 [INFO] [http,server] [message: starting HTTP server on port :9000]",
    level=info msg="2022/02/04 19:58:38 http error: Invalid JWT token (err=Invalid JWT token) (code=401)",
    level=info msg="2022/02/04 19:58:43 [ERROR] [http,client] [message: unexpected status code] [status_code: 403]",
    level=info msg="2022/02/04 19:58:50 [ERROR] [http,client] [message: unexpected status code] [status_code: 403]",
    level=info msg="2022/02/04 19:58:58 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 19:59:59 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 20:06:34 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 20:06:36 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 20:12:29 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 20:12:31 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 20:14:32 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 20:14:33 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 20:15:14 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 20:15:15 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 20:23:22 http error: Unable to retrieve DockerHub token from DockerHub (err=Get \"https://auth.docker.io/token?service=registry.docker.io&scope=repository:ratelimitpreview/test:pull\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)) (code=500)",
    level=info msg="2022/02/04 20:23:26 http error: Unable to retrieve DockerHub token from DockerHub (err=Get \"https://auth.docker.io/token?service=registry.docker.io&scope=repository:ratelimitpreview/test:pull\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)) (code=500)",
    2022/02/04 20:26:23 server: Reverse tunnelling enabled,
    2022/02/04 20:26:23 server: Fingerprint e9:5c:0b:1e:71:72:df:f6:04:27:83:e5:fb:57:8b:22,
    2022/02/04 20:26:23 server: Listening on 0.0.0.0:8000...,
    level=info msg="2022/02/04 20:26:23 [DEBUG] [chisel, monitoring] [check_interval_seconds: 10.000000] [message: starting tunnel management process]",
    level=info msg="2022/02/04 20:26:23 [INFO] [cmd,main] Starting Portainer version 2.9.3",
    level=info msg="2022/02/04 20:26:23 [DEBUG] [internal,init] [message: start initialization monitor ]",
    level=info msg="2022/02/04 20:26:23 [INFO] [http,server] [message: starting HTTPS server on port :9443]",
    level=info msg="2022/02/04 20:26:23 [INFO] [http,server] [message: starting HTTP server on port :9000]",
    level=info msg="2022/02/04 20:26:32 http error: Invalid JWT token (err=Invalid JWT token) (code=401)",
    level=info msg="2022/02/04 20:26:33 http error: Invalid JWT token (err=Invalid JWT token) (code=401)",
    level=info msg="2022/02/04 20:26:37 [ERROR] [http,client] [message: unexpected status code] [status_code: 403]",
    level=info msg="2022/02/04 20:26:53 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    level=info msg="2022/02/04 20:27:20 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)",
    2022/02/04 20:31:50 server: Reverse tunnelling enabled,
    2022/02/04 20:31:50 server: Fingerprint e9:5c:0b:1e:71:72:df:f6:04:27:83:e5:fb:57:8b:22,
    2022/02/04 20:31:50 server: Listening on 0.0.0.0:8000...,
    level=info msg="2022/02/04 20:31:50 [DEBUG] [chisel, monitoring] [check_interval_seconds: 10.000000] [message: starting tunnel management process]",
    level=info msg="2022/02/04 20:31:50 [INFO] [cmd,main] Starting Portainer version 2.9.3",
    level=info msg="2022/02/04 20:31:50 [DEBUG] [internal,init] [message: start initialization monitor ]",
    level=info msg="2022/02/04 20:31:50 [INFO] [http,server] [message: starting HTTPS server on port :9443]",
    level=info msg="2022/02/04 20:31:50 [INFO] [http,server] [message: starting HTTP server on port :9000]",
    level=info msg="2022/02/04 20:31:51 http error: Invalid JWT token (err=Invalid JWT token) (code=401)",
    level=info msg="2022/02/04 20:32:48 [ERROR] [http,client] [message: unexpected status code] [status_code: 403]"
    abd99683-ccf8-448e-b5b6-1d5ad6221e2c-grafik.png code_text
      Festplattenart: HDD
      @marcel-drzal
      6e50303f-528c-4496-9604-a70f0fd306d2-grafik.png code_text
      Verstehe nicht warum hier Port 9000 steht? habe doch  9443  eingestelt?
      Hoffe es hat eine eine Idee?
      Danke euch
      GlasfaserG ? 2 Antworten Letzte Antwort
        @marcel-drzal
        Danke euch
        GlasfaserG Offline
        GlasfaserG Offline
        @marcel-drzal
        Port ist bei mir 8020 , im Docker 9000
        über Syn Docker .
        59035473-f3d3-4a16-942d-3f834cb4af1c-grafik.png.
        portainer/portainer-ce              "/portainer"             16 months ago   Up 2 weeks                   8000/tcp, 0.0.0.0:8020->9000/tcp
        ? GlasfaserG 2 Antworten Letzte Antwort
        • GlasfaserG Glasfaser
          @marcel-drzal
          über Syn Docker .
          @glasfaser
          54779ec1-2d01-47cc-86fd-2b17739101d3-grafik.png code_text
          wie kann ich das beheben?
            @marcel-drzal
            über Syn Docker .
            GlasfaserG Offline
            GlasfaserG Offline
            @marcel-drzal
            @glasfaser sagte in Portainer Fehler ungültiges Token?:
            über Syn Docker .
            Siehe oben :
            Mit der normalen Syn Docker Oberfläche , Docker stoppen , bearbeiten
              @marcel-drzal
              über Syn Docker .
              Siehe oben :
              @glasfaser Leider ist das nonch neuland für mich.
              wenn ich den Container Stoppe muss ich die Maschine neu Starten, da dann alle Container weg sind
              e886d7d8-f992-415c-84f3-c7f2dc652056-grafik.png code_text
                GlasfaserG Offline
                GlasfaserG Offline
                @marcel-drzal sagte in Portainer Fehler ungültiges Token?:
                ? keine Ahnung was du machst .
                Einfach in der Synology anmelden , dann unter Docker :
                b9fb5d3e-4381-42da-b7f2-616c2adee345-grafik.png .
                Portainer stoppen :
                Dann auf Portainer , rechte Maustaste ... bearbeiten
                  Portainer stoppen :
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @glasfaser
                  Sorry ,,, du hättest auch schreiben können ... du hast keine Synology ...
                  habe es auch oben überlesen :(
                    Portainer stoppen :
                    @glasfaser Habe den Portainer auf einen IntelNUC in Proxmox laufen auf den port 9443
                    00b4ae6a-acd2-4495-bc13-7c01e020ad54-grafik.png code_text
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @marcel-drzal
                      In Container Portainer ... Edit
                        @glasfaser
                        @glasfaser ich müsste doch den Port dann auch Routen? was ich bei der Installation glaub ich auch gemacht habe, siehe Bild
                          @glasfaser
                          @glasfaser
                          habe versucht ihn neu zu installieren
                          ohen Erfolg
                          a37a8f64-82d8-419e-a968-cd65bf61c6b6-grafik.png code_text
                            @marcel-drzal
                            Danke euch
                            Habe nun meine Docker version auf 2.11 gebraht
                            leider immer noch der Fehler im Log hängt es mit https usammen?
                            2022/02/05 18:36:51 server: Reverse tunnelling enabled,
                            2022/02/05 18:36:51 server: Fingerprint e9:5c:0b:1e:71:72:df:f6:04:27:83:e5:fb:57:8b:22,
                            2022/02/05 18:36:51 server: Listening on 0.0.0.0:8000...,
                            level=info msg="2022/02/05 18:36:51 [DEBUG] [chisel, monitoring] [check_interval_seconds: 10.000000] [message: starting tunnel management process]",
                            level=info msg="2022/02/05 18:36:51 [INFO] [cmd,main] Starting Portainer version 2.11.0",
                            level=info msg="2022/02/05 18:36:51 [DEBUG] [internal,init] [message: start initialization monitor ]",
                            level=info msg="2022/02/05 18:36:51 [INFO] [http,server] [message: starting HTTPS server on port :9443]",
                            level=info msg="2022/02/05 18:36:51 [INFO] [http,server] [message: starting HTTP server on port :9000]",
                            level=info msg="2022/02/05 18:37:08 http error: A valid authorisation token is missing (err=Unauthorized) (code=401)",
                            level=info msg="2022/02/05 18:37:12 [ERROR] [http,client] [message: unexpected status code] [status_code: 403]",
                            level=info msg="2022/02/05 18:37:21 http error: Unable to retrieve DockerHub token from DockerHub (err=failed fetching dockerhub token) (code=500)"
                              @marcel-drzal
                              @glasfaser
                              habe es hinbekommen, aber der fehler wird immer noch angezeigt
                              denke es ist eine Meldung das http nicht geht da ich mit https drin bin
                              was denkst du?
                                @glasfaser
                                was denkst du?
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @marcel-drzal
                                ich nutze Portainer so nicht .... ,
                                habe ja eine Synology und mache alles über Konsolenbefehle oder Dockeroberfläche
