  4. Probleme nach Update von 3.3.21 auf 3.3.22
    1.0k
    6.1k
3 Beiträge 2 Kommentatoren 362 Aufrufe 2 Beobachtet
  • SMSS Offline
    SMSS Offline
    SMS
    Hi zusammen,
    wollte gerade das Update machen. Master ist schon eine Weile auf 3.3.22 und jetzt wollte ich die Slaves nachziehen.
    Folgendes Problem:
    pi@MotionEye:~ $ iob update
    internal/modules/cjs/loader.js:905
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iob        roker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js        :75:12)
        at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    pi@MotionEye:~ $ iob upgrade self
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
      requireStack: []
    Dann dachte ich, OK machst mal ein Update vom Pi, was auch funktioniert hat.
    Danach immer noch die o.g. Meldungen.
    pi@MotionEye:~ $ iob start
    pi@MotionEye:~ $ iobroker start
    Job for iobroker.service failed because the control process exited with error code.
    See "systemctl status iobroker.service" and "journalctl -xe" for details.
    pi@MotionEye:~ $ systemctl status iobroker.service
    ● iobroker.service - ioBroker Server
       Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Fri 2022-02-04 23:15:09 CET; 29s ago
         Docs: http://iobroker.net
      Process: 853 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, sta
     Main PID: 853 (code=exited, status=1/FAILURE)
    Feb 04 23:15:09 MotionEye systemd[1]: iobroker.service: Service RestartSec=100ms expired, scheduling restart.
    Feb 04 23:15:09 MotionEye systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 5.
    Feb 04 23:15:09 MotionEye systemd[1]: Stopped ioBroker Server.
    Feb 04 23:15:09 MotionEye systemd[1]: iobroker.service: Start request repeated too quickly.
    Feb 04 23:15:09 MotionEye systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Feb 04 23:15:09 MotionEye systemd[1]: Failed to start ioBroker Server.
    Feb 04 23:15:15 MotionEye systemd[1]: iobroker.service: Start request repeated too quickly.
    Feb 04 23:15:15 MotionEye systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Feb 04 23:15:15 MotionEye systemd[1]: Failed to start ioBroker Server.
    pi@MotionEye:~ $ journalctl -xe
    -- Automatic restarting of the unit iobroker.service has been scheduled, as the result for
    -- the configured Restart= setting for the unit.
    -- Subject: A stop job for unit iobroker.service has finished
    -- Defined-By: systemd
    -- Support: https://www.debian.org/support
    -- A stop job for unit iobroker.service has finished.
    -- The job identifier is 1283 and the job result is done.
    -- Subject: Unit failed
    -- The unit iobroker.service has entered the 'failed' state with result 'exit-code'.
    -- Subject: A start job for unit iobroker.service has failed
    -- A start job for unit iobroker.service has finished with a failure.
    -- The job identifier is 1283 and the job result is failed.
    Feb 04 23:15:15 MotionEye sudo[864]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/systemctl start iobroker
    Feb 04 23:15:15 MotionEye sudo[864]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
    -- The job identifier is 1340 and the job result is failed.
    Feb 04 23:15:15 MotionEye sudo[864]: pam_unix(sudo:session): session closed for user root
    Was ist da passiert?
    So sieht es aktuell aus:
    Danke!!
    SMSS 1 Antwort Letzte Antwort
    • SMSS SMS
      Hi zusammen,
      Folgendes Problem:
        throw err;
        requireStack: []
        throw err;
        requireStack: []
      Danke!!
      SMSS Offline
      SMSS Offline
      SMS
      keiner eine Ahnung? Ein Backup von kurz davor hat leider nichts gebracht.
      Das komische ist wieder, das ich nicht auf die Konsole zugreifen kann.
      • SMSS SMS
        @sms
        Installier nochmal drüber.
