  4. Dash Adapter installieren
    5.6k
22 Beiträge 3 Kommentatoren 2.9k Aufrufe
  • J Offline
    jwedenig
    Hy, irgendwie funktioniert die Installation nicht:
    Hier der Log:
    $ ./iobroker add amazon-dash
    npm install iobroker.amazon-dash --production --prefix "/volume1/homes/admin/opt/iobroker" (System call)
    sh: apt-get: command not found
    npm
    WARN
    engine
     socketwatcher@0.3.0: wanted: {"node":">=4"} (current: {"node":"0.10.46","npm":"2.15.1"})
    gyp
     WARN EACCES user "undefined" does not have permission to access the dev dir "/root/.node-gyp/0.10.46"gyp WARN EACCES attempting to reinstall using temporary dev dir "/volume1/homes/admin/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/node_modules/socketwatcher/.node-gyp"
    gyp
    ERR!
    build error
    gyp
    ERR!
    stack
     Error: not found: make
    gyp
    ERR!
     stack     at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)gyp ERR! stack     at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)
    gyp ERR! stack
         at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
    gyp
    ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/mode.js:8:5
    gyp ERR! stack     at Object.oncomplete (fs.js:108:15)
    gyp ERR! System Linux 2.6.32.12
    gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp
    ERR!
     cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/node_modules/socketwatchergyp ERR! node -v v0.10.46
    gyp ERR! node-gyp -v
     v3.3.1
    gyp
     ERR! not ok
    npm
    ERR!
     Linux 2.6.32.12npm
    ERR!
     argv
     "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.amazon-dash" "--production" "--prefix" "/volume1/homes/admin/opt/iobroker"npm
     ERR!
     node v0.10.46npm ERR! npm  v2.15.1
    npm ERR! code ELIFECYCLE
    npm ERR! socketwatcher@0.3.0 install: `node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm
    ERR! Failed at the socketwatcher@0.3.0 install script 'node-gyp rebuild'.
    npm
    ERR! This is most likely a problem with the socketwatcher package,
    npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
    npm ERR!     node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR!     npm bugs socketwatcher
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm
    ERR!     npm owner ls socketwatcher
    npm
    ERR! There is likely additional logging output above.
    npm
    ERR!
     Please include the following file with any support request:npm ERR!     /volume1/homes/admin/opt/npm-debug.log
    ERROR: host.Landisk Cannot install iobroker.amazon-dash: 1
      Ich habe mal deinen code in code-Tags gesteckt!
      @jwedenig:
      irgendwie funktioniert die Installation nicht: `
      Als welcher User bist du auf der Konsole?
      @jwedenig:
      user "undefined" does not have permission to access `
      • J Offline
        jwedenig
        Als admin
          Dann hätten wir noch einen Fehler:
          @jwedenig:
          wanted: {"node":">=4"} (current: {"node":"0.10.46","npm":"2.15.1"}) `
          • J Offline
            jwedenig
            Ich weiss nur leider nicht, was ich daran ändern kann oder soll
            • kmxakK Offline
              kmxakK Offline
              kmxak
              Hast du auch libpcap installiert?
              apt-get install libpcap-dev
              Gruß Alex
              • J Offline
                jwedenig
                hey, nein, habe ich nicht, ich dachte einfach "Dash Adapter installieren", Knopf drücken und los gehts.
                  @jwedenig:
                  Gesendet von iPhone mit Tapatalk `
                  Du hast eine uralte nodejs version. 0.10.x
                  Die wird wahrscheinlich bald gar nicht mehr unterstützt
                  Aktuell sond 4.xx und 6.xx die 8er ist beteits als 7.xx in Vorbereitung.
                  Warum hast du so eine alte Version?
                  • J Offline
                    jwedenig
                    Ich glaube, der Fehler liegt daran, dass ich laut Screenshot hier nicht auf Online war sondern auf sources und somit wurden mir keine Aktualisierungen angezeigt, kann das sein?
                    Also, jetzt heisst es also alles aktualisieren dann wird's auch klappen, oder?
                    • J Offline
                      jwedenig
                      damit ich jetzt nichts falsch mache:
                      Aktualisierung erfolgt wie?
                      Beim Reiter "Adapter" aufs Plus gehen und " Instanz hinzufügen" klicken?
                        Deine nodejs Version hat nichts mit den updates zu tun.
                        Einige, und demnäcjst wahrscheinlich alle, Adapter benötigen mindestens nodejs v4.xx.
                        Du hast, warum auch immer, bei deiner Erstinstallation diese Uraltversion 0.10.x installiert.
                        • J Offline
                          jwedenig
                          aber warte: du meinst node.js?
                          Das ist ja auf meiner Synology im Menü und siehe hier, ich habe da keine andere zur Verfügung:
                            Böse Antwort:
                            Dann kannst du nicht alle features von ioBroker nutzen!
                            Ich denke aber, dass man auf der Synology auch weitere Versionen installieren hätte können.
                            Je nach DiskStation muss es das sogar nativ geben
                            http://de.lmgtfy.com/?q=Synology+nodejs+v4
                            • J Offline
                              jwedenig
                              ich habe eine DS212+, und ich glaube dass man da keine neueren Versionen installieren kann:-((
                              Ich glaube, ich aktiviere meinen Pi 3, aber dann geht das ganze wieder von vorne los?
                              Alles Skripten neu schreiben? Ich dreh durch!
                              Bin ich mit meinem Pi3 besser aufgehoben? Glaub schon, oda?
                              Liebe Grüße
                              Jürgen
                                :P Auch wenn ich den pi3 wegen der nur 1GB RAM nicht für das bestgeeignete modell halte, ist es deutlich besser als deine Syno.
                                Laut https://www.synology.com/en-us/knowledgebase/DSM/tutorial/General/What_kind_of_CPU_does_my_NAS_have hat die 212+ gerade mal eine singlecore cpu und sogar noch weniger RAM als der RasPi nämlich gerademal 512MB.
                                > DS212+ Marvell Kirkwood 88F6282 Single Core 1 No 88f628x DDR3 512 MB
                                Damit soll sie noch weitere Aufgaben übernehmen. Dabei ist sie schon für ioBroker allein zu schwach.
                                • J Offline
                                  jwedenig
                                  alles klar, d.h. ich muss mich mal mit der Installation auf dem Pi3 vertraut machen,
                                  die Einstellungen kann man ja nicht übernehmen, sprich die Skripten exportieren oder so?
                                    @jwedenig:
                                    die Einstellungen kann man ja nicht übernehmen `
                                    Ja!
                                    @jwedenig:
                                    die Skripten exportieren oder so? `
                                    Ja, kann man.
                                    • J Offline
                                      jwedenig
                                      Hi Rainer!
                                      Habe jetzt IObroker auf dem Pi3 installiert!
                                      • J Offline
                                        jwedenig
                                        alles gut
                                          @jwedenig:
                                          ich mache alles nach Anleitung `
                                          Wirklich ;)
                                          Du bist als User pi eingeloggt. Dann musst du zumindest ein sudo voransetzen.
                                          Hast du wenigstens die Erstinstallation als root gemacht?
                                          Besser wäre das auch beim controller update.
                                          Und auf jeden Fall vorher ioBroker stoppen.
