  4. Cloudadapter stürzt regelmäßig ab
    5.6k
42 Beiträge 5 Kommentatoren 4.0k Aufrufe
  • eric2905E Offline
    eric2905E Offline
    eric2905
    Versuche es mal mit
    sudo iobroker upgrade self
    Noch eine Bitte :
    Poste Logs, usw. bitte in Code-Tags und ggf. auch als Spoiler.
    Das ließt sich besser.
    Gruß,
    Eric
    Von unterwegs getippert
    • J Offline
      jwedenig
      Hier das Ergebnis von Sudo…: Ich hoffe, dass passt so mit dem Code
      und ein Screenshot vom LOG:
      admin@Landisk:/volume1/homes/admin/opt/iobroker$ sudo iobroker upgrade self
      Password:
      npm install iobroker.js-controller --production --prefix "/volume1/homes/admin/opt/iobroker" (System call)
      npm WARN engine request@2.81.0: wanted: {"node":">= 4"} (current: {"node":"0.10.46","npm":"2.15.1"})
      npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to localhost.daplie.me-certificates
      npm WARN engine form-data@2.1.2: wanted: {"node":">= 0.12"} (current: {"node":"0.10.46","npm":"2.15.1"})
      npm WARN engine har-validator@4.2.1: wanted: {"node":">=4"} (current: {"node":"0.10.46","npm":"2.15.1"})
      npm WARN engine har-schema@1.0.5: wanted: {"node":">=4"} (current: {"node":"0.10.46","npm":"2.15.1"})
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/0.10.46"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/volume1/homes/admin/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram/.node-gyp"
      gyp ERR! build error
      gyp ERR! stack Error: not found: make
      gyp ERR! stack     at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
      gyp ERR! stack     at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)
      gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
      gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
      gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/mode.js:8:5
      gyp ERR! stack     at Object.oncomplete (fs.js:108:15)
      gyp ERR! System Linux 2.6.32.12
      gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
      gyp ERR! node -v v0.10.46
      gyp ERR! node-gyp -v v3.3.1
      gyp ERR! not ok
      npm WARN optional dep failed, continuing unix-dgram@0.2.3
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/volume1/homes/admin/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa/.node-gyp"
      gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.js-controller/node_modules/greenlock/node_modules/rsa-compat/node_modules/ursa
      gyp ERR! not ok
      npm WARN optional dep failed, continuing ursa@0.9.4
      npm WARN engine co@4.6.0: wanted: {"iojs":">= 1.0.0","node":">= 0.12.0"} (current: {"node":"0.10.46","npm":"2.15.1"})
      Cannot write file. Not critical: Error: EACCES, permission denied '/volume1/homes/admin/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
      Host "Landisk" (linux) updated
      Execute: chmod 777 -R /volume1/homes/admin/opt/iobroker
      Chmod finished. Restart controller
      Starting node restart.js
      • J Offline
        jwedenig
        Jetzt schaut so aus - was nun?
        • eric2905E Offline
          eric2905E Offline
          eric2905
          "iobroker restart" (oder reboot, tut gut) - die 0.17.2 ist drauf, aber die 0.16.2 ist noch aktiv.
          • J Offline
            jwedenig
            restart hat nix gebracht
            admin@Landisk:/volume1/homes/admin/opt/iobroker$ iobroker restart
            iobroker controller daemon is not running
            Starting iobroker controller daemon...
            iobroker controller daemon started. PID: 25034
            ich werde mal das nas Neustarten
            • eric2905E Offline
              eric2905E Offline
              eric2905
              Moment, da passt was nicht …
              Du postest einen Screenshot der Admin-Oberfläche ==> IoBroker muss also laufen
              Dann schreibst Du, das bei "IoBroker restart" die Meldung "iobroker controller daemon is not running" usw. kommt
              Das geht nicht ... IoBroker läuft nicht, aber Admin-Oberfläche ist da.
              Hast Du evtl. 2 Installationen in versch. Verzeichnissen laufen?
              • J Offline
                jwedenig
                nene, das war ja nur beim Restart, danach schreibt er eh dass es geht:
                Starting iobroker controller daemon…
                • eric2905E Offline
                  eric2905E Offline
                  eric2905
                  Das ist es ja : Der Daemon soll restarted werden, also gestoppt und gestartet.
                  Beim Stop kommt die Meldung, das er nicht läuft und dann gestartet wird - und das passt nicht.
                  Nachtrag:
                  Versuch mal nur "iobroker stop" und schau Dir die Meldung mal an.
                  • J Offline
                    jwedenig
                    mein Nas ist leider nach dem Reboot scheinbar abgeschmiert, ich bin in der Arbeit via VPN dran, muss zu Hause mal schauen und melde mich dann.
                    Danke derweilen
                    Liebe Grüße Jürgen
                    • eric2905E Offline
                      eric2905E Offline
                      eric2905
                      Kannst Du nicht die VM auf dem NAS rebootet?
                      Ober hast Du IoBroker direkt im NAS-OS installiert?
                      • J Offline
                        jwedenig
                        Naja, iobroker läuft in diesem Ordner von meiner Synology:
                        volume1\homes\admin\opt\iobroker
                        • eric2905E Offline
                          eric2905E Offline
                          eric2905
                          Ah, ok. Bei meinem NAS kann ich eine VM erzeugen, ein eigens OS installieren und das quasi wie eine eigene Maschine verwenden (und auch rebooten).
                          • J Offline
                            jwedenig
                            also nach Biobroker stop kommt wie ich finde die richtige Meldung:
                            admin@Landisk:/$ iobroker stop
                            admin@Landisk:/$ iobroker start
                            iobroker controller daemon started. PID: 23005
                            admin@Landisk:/$
                            Liebe Grüße Jürgen
                            P.S.: Leider wird noch immer die alter Version ausgeführt
                            installiert 0.17.2(Ausgeführt: 0.16.2)
                            • J Offline
                              jwedenig
                              halt stop zurück - jetzt zeigt er die aktuelle Version an!
                              • eric2905E Offline
                                eric2905E Offline
                                eric2905
                                @jwedenig:
                                Nach "iobroker stop" sollte eigentlich sowas kommen :
                                Stopping iobroker controller daemon...
                                iobroker controller daemon stopped.
                                Exit code for "killall.sh": 0
                                root@iobroker:/opt/iobroker#
                                Gruß,
                                Eric
                                • J Offline
                                  jwedenig
                                  tja, ich weiss nimmer weiter, aber der Cloudadapter ist jetzt mal aktuell, mal schauen, ob dieser auch wieder abstürzt, oder?
                                  Was meinst Du?
                                  • eric2905E Offline
                                    eric2905E Offline
                                    eric2905
                                    Sind alle Reiter schwarz und keiner mehr grün?
                                    Welches Repository hast Du nun ausgewählt?
                                    Gruß,
                                    Eric
                                    • J Offline
                                      jwedenig
                                      nur der Adapter Reiter ist grün - Repository finde ich wo?
                                      • eric2905E Offline
                                        eric2905E Offline
                                        eric2905
                                        Schau mal ein paar Postings zurück - Deine eigene Frage und die Antwort dazu : http://forum.iobroker.net/viewtopic.php?t=5994#p61515
                                        Gruß,
                                        Eric
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          Konnte Fehler reproduzieren und fixen.
                                          Falls jemand von "latest" repo den Cloud 0.7.1 testen konnte, wäre toll.
                                          Dann werde ich schon morgen den Adapter ins "stable" nehmen, so dass alle endlich den Fix haben.
