  2. Nederlands
  3. ioBroker algemeen
  4. Iobroker brug niet in beeld bij Homekit
    6.7k
Geplant Angeheftet Gesperrt Verschoben ioBroker algemeen
13 Beiträge 2 Kommentatoren 6.5k Aufrufe 2 Beobachtet
  • J JH
    @wendy2702
    Hi Wendy, ik gebruik Yahka v0.13.1
    Ik heb eerst Iobroker geinstalleerd en Yahka (kwam niet in beeld bij Homekit), toen ben ik allerlei updates gaan doen, Node, Processor, Iobroker, maar elke keer zonder resultaat
    JH
    @jeroenhermus
    Processor bedoel ik : js-controller: 3.3.22
    • wendy2702W Offline
      wendy2702W Offline
      It's a long time ago that i configured my YAHKA but can you please:
      a) change the logging to "Debug" for the instance
      b) add a device to YAHKA
      c) open Homekit app an select: add a device
      d) if the new Device/Bridge is not shown you might need to add it manually via Code
      e) post the logfile from YAHKA if it still not OK
      IOS Device and iobroker YAHKA Instanz are within the same Network?
      • wendy2702W wendy2702
        JH
        @wendy2702
        Helaas, alles gedaan maar komt nog steeds niet in beeld:
        • J JH
          @wendy2702
          JH
          @jeroenhermus Bevinden zich inderdaad in hetzelfde netwerk.
            wendy2702W Offline
            Did you define a USER Name at YAHKA ? Can't see it on the provided screenshots.
            Bye the way, you need to change the log level by following these steps:
            1. Activate "Expert Mode" by clicking this icon: 01ed34e7-0e46-43ff-9b18-0cd94c27dd43-image.png
            2. select the Instanz you like to modify and klick at this icon: de4d53c0-f69a-46ea-ba54-4545f2de55a0-image.png
            3. klick on the pencil and change the log level at the drop down menu which appears: ef66587b-1f44-4e16-9cd9-bf25959f5a24-image.png
            Exit with "OK"
            The iobroker logfile information should be taken from the log stored at your iobroker device. File can be found at
            /opt/iobroker/log
            if you are running on Linux.
            Post the YAHKA log within "Code Tags"
              Exit with "OK"
              /opt/iobroker/log
              JH
              @wendy2702 said in Iobroker brug niet in beeld bij Homekit:
              /opt/iobroker/log
              Thanks!!! Ik heb de logging aangepast en heb inderdaad een username ingevuld. De logging begrijp ik nog niet helemaal hoe ik die in beeld kan brengen, is dit ook oke?
              • J JH
                /opt/iobroker/log
                JH
                @jeroenhermus Ik heb geen Linux :(
                • J JH
                  JH
                  @jeroenhermus Zie bijgaande logging van vandaag:
                  • J JH
                    JH
                    @jeroenhermus Anyone?
                    • J JH
                      wendy2702W Offline
                      wendy2702W Offline
                      @jeroenhermus please post logs via cool and paste with Code Tags and not as screenshots!
                      Did you check windows defender and firewall settings?
                      Any additional antivirus sw or something similar running?
