  4. Läuft der Synology Adapter mit DSM 7 auch
    6.1k
adapter synology
67 Beiträge 7 Kommentatoren 7.6k Aufrufe 7 Beobachtet
    @megaron sagte in Läuft der Synology Adapter mit DSM 7 auch:
    Du hast recht. Ich dachte. Ich hab den Adapter im Experten Modus über die Katze gesucht (Synology) und dann installiert.
    Aber jetzt hast du die Doku gelesen und befolgt?
    Und jetzt hat sich was geändert?
    megaron
    Doku gelesen und befolgt. Keine Veränderung
    Viele Grüße megaron
    • M megaron
      @glasfaser
      2022-01-22 17:14:24.719 - debug: synology.1 (1009225) * The response is received, parse:
      2022-01-22 17:14:24.719 - debug: synology.1 (1009225) SystemUtilization - Response: {"cpu":{"15min_load":113,"1min_load":128,"5min_load":125,"device":"System","other_load":3,"system_load":4,"user_load":17},"disk":{"disk":[{"device":"sda","display_name":"Drive 1","read_access":0,"read_byte":0,"type":"internal","utilization":8,"write_access":16,"write_byte":422229}],"total":{"device":"total","read_access":0,"read_byte":0,"utilization":8,"write_access":16,"write_byte":422229}},"lun":[],"memory":{"avail_real":139996,"avail_swap":8122284,"buffer":85284,"cached":8758980,"device":"Memory","memory_size":10485760,"real_usage":10,"si_disk":0,"so_disk":0,"swap_usage":0,"total_real":10041556,"total_swap":8122284},"network":[{"device":"total","rx":4757577,"tx":37952},{"device":"bond0","rx":4757577,"tx":37952}],"nfs":[{"device":"nfs","read_OPS":0,"read_max_latency":0,"total_OPS":0,"total_max_latency":0,"write_OPS":0,"write_max_latency":0}],"space":{"total":{"device":"total","read_access":0,"read_byte":0,"utilization":5,"write_access":12,"write_byte":384341},"volume":[{"device":"dm-0","display_name":"volume1","read_access":0,"read_byte":0,"utilization":5,"write_access":12,"write_byte":384341}]},"time":1642871662}
      2022-01-22 17:14:24.719 - debug: synology.1 (1009225) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:24.719 - debug: synology.1 (1009225) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
      2022-01-22 17:14:24.719 - debug: synology.1 (1009225) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
      2022-01-22 17:14:24.937 - debug: synology.1 (1009225) * The response is received, parse:
      2022-01-22 17:14:24.937 - debug: synology.1 (1009225) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
      2022-01-22 17:14:24.937 - debug: synology.1 (1009225) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:24.938 - debug: synology.1 (1009225) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
      2022-01-22 17:14:24.938 - debug: synology.1 (1009225) * Get info from (fastPoll) api: DSM method: getInfo params: {}
      2022-01-22 17:14:24.983 - debug: synology.1 (1009225) * The response is received, parse:
      2022-01-22 17:14:24.984 - debug: synology.1 (1009225) TempInfo - Response: {"codepage":"ger","model":"DS718+","ram":10240,"serial":"1841PEN993700","temperature":40,"temperature_warn":false,"time":"Sat Jan 22 18:14:24 2022","uptime":33742,"version":"42218","version_string":"DSM 7.0.1-42218 Update 2"}
      2022-01-22 17:14:24.984 - debug: synology.1 (1009225) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:24.984 - debug: synology.1 (1009225) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
      2022-01-22 17:14:24.984 - debug: synology.1 (1009225) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
      2022-01-22 17:14:25.145 - debug: synology.1 (1009225) * The response is received, parse:
      2022-01-22 17:14:25.146 - debug: synology.1 (1009225) InfoSystem - Response: {"hdd_info":[{"capacity":"750156374016","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"WD7500AAKS-00RBA0","order":1,"overview_status":"normal","pciSlot":-1,"portType":"normal","status":"normal","summary_status_category":"space","summary_status_key":"normal","temp":37,"testing_progress":"","testing_type":"idle","volume":"reuse_1"}],"vol_info":[{"desc":"SHR","inode_free":"0","inode_total":"0","name":"volume_1","status":"normal","total_size":"715397939200","used_size":"414857166848","vol_desc":"","volume":"volume_1"}]}
      2022-01-22 17:14:25.146 - debug: synology.1 (1009225) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:25.146 - debug: synology.1 (1009225) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
      2022-01-22 17:14:25.146 - debug: synology.1 (1009225) * Packet SS non installed, skipped
      2022-01-22 17:14:25.146 - debug: synology.1 (1009225) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
      2022-01-22 17:14:25.146 - debug: synology.1 (1009225) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
      2022-01-22 17:14:25.146 - debug: synology.1 (1009225) * Get info from (fastPoll) api: FS method: listSharings params: {}
      2022-01-22 17:14:25.321 - debug: synology.1 (1009225) * The response is received, parse:
      2022-01-22 17:14:25.321 - debug: synology.1 (1009225) parseListSharings - Response: {"links":[],"offset":0,"total":0}
      2022-01-22 17:14:25.321 - debug: synology.1 (1009225) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:25.321 - debug: synology.1 (1009225) >>>>>>>>>>>>>>> Read all data, save received data.
      2022-01-22 17:14:25.321 - debug: synology.1 (1009225) setStates
      2022-01-22 17:14:25.322 - debug: synology.1 (1009225) setObject "DiskStationManager.info.time"
      2022-01-22 17:14:25.322 - debug: synology.1 (1009225) setObject "DiskStationManager.info.uptime"
      2022-01-22 17:14:25.322 - debug: synology.1 (1009225) setObject "DiskStationManager.info.cpu_load"
      2022-01-22 17:14:25.870 - info: mihome-vacuum.0 (1007366) State value to set for "mihome-vacuum.0.info.water_box" has to be type "string" but received type "boolean"
      2022-01-22 17:14:29.070 - info: host.IoBroker stopInstance system.adapter.synology.1 (force=false, process=true)
      2022-01-22 17:14:29.074 - info: synology.1 (1009225) Got terminate signal TERMINATE_YOURSELF
      2022-01-22 17:14:29.074 - info: host.IoBroker stopInstance system.adapter.synology.1 send kill signal
      2022-01-22 17:14:29.074 - debug: synology.1 (1009225) cleaned everything up...
      2022-01-22 17:14:29.074 - info: synology.1 (1009225) terminating
      2022-01-22 17:14:29.074 - debug: synology.1 (1009225) Plugin sentry destroyed
      2022-01-22 17:14:29.075 - info: synology.1 (1009225) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-01-22 17:14:29.610 - info: host.IoBroker instance system.adapter.synology.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-01-22 17:14:32.120 - info: host.IoBroker instance system.adapter.synology.1 started with pid 1009242
      2022-01-22 17:14:32.355 - debug: synology.1 (1009242) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-01-22 17:14:32.362 - debug: synology.1 (1009242) Objects client ready ... initialize now
      2022-01-22 17:14:32.363 - debug: synology.1 (1009242) Objects create System PubSub Client
      2022-01-22 17:14:32.363 - debug: synology.1 (1009242) Objects create User PubSub Client
      2022-01-22 17:14:32.363 - debug: synology.1 (1009242) Objects client initialize lua scripts
      2022-01-22 17:14:32.368 - debug: synology.1 (1009242) Objects connected to redis: 127.0.0.1:9001
      2022-01-22 17:14:32.370 - debug: synology.1 (1009242) objectDB connected
      2022-01-22 17:14:32.371 - debug: synology.1 (1009242) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-01-22 17:14:32.374 - debug: synology.1 (1009242) States create System PubSub Client
      2022-01-22 17:14:32.374 - debug: synology.1 (1009242) States create User PubSub Client
      2022-01-22 17:14:32.378 - debug: synology.1 (1009242) States connected to redis: 127.0.0.1:9000
      2022-01-22 17:14:32.378 - debug: synology.1 (1009242) statesDB connected
      2022-01-22 17:14:32.468 - debug: synology.1 (1009242) Plugin sentry Initialize Plugin (enabled=true)
      2022-01-22 17:14:32.549 - info: synology.1 (1009242) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.synology, node: v12.22.8, js-controller: 3.3.22
      2022-01-22 17:14:32.557 - info: synology.1 (1009242) Connecting to Synology 192.168.178.88:5000
      2022-01-22 17:14:32.825 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:32.826 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
      2022-01-22 17:14:32.826 - debug: synology.1 (1009242) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
      2022-01-22 17:14:33.355 - debug: synology.1 (1009242) * The response is received, parse:
      2022-01-22 17:14:33.356 - debug: synology.1 (1009242) InstallingPackets - Response: {"diskList":[]}
      2022-01-22 17:14:33.356 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:33.356 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
      2022-01-22 17:14:33.356 - debug: synology.1 (1009242) * Get info from (firstPoll) api: DSM method: getInfo params: {}
      2022-01-22 17:14:33.424 - debug: synology.1 (1009242) * The response is received, parse:
      2022-01-22 17:14:33.424 - debug: synology.1 (1009242) Info - Response: {"codepage":"ger","model":"DS718+","ram":10240,"serial":"1841PEN993700","temperature":40,"temperature_warn":false,"time":"Sat Jan 22 18:14:33 2022","uptime":33751,"version":"42218","version_string":"DSM 7.0.1-42218 Update 2"}
      2022-01-22 17:14:33.425 - info: synology.1 (1009242) DSM 2
      2022-01-22 17:14:33.425 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:33.425 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 2 | typeof poll = object | poll = {"api":"fs","method":"getInfo","params":{}}
      2022-01-22 17:14:33.425 - debug: synology.1 (1009242) * Get info from (firstPoll) api: FS method: getInfo params: {}
      2022-01-22 17:14:33.909 - debug: synology.1 (1009242) * The response is received, parse:
      2022-01-22 17:14:33.909 - debug: synology.1 (1009242) Info - Response: {"enable_list_usergrp":false,"enable_send_email_attachment":true,"enable_view_google":true,"enable_view_microsoft":true,"hostname":"CamStation","is_manager":true,"items":[{"gid":100},{"gid":101}],"support_file_request":true,"support_sharing":true,"support_vfs":true,"support_virtual":{"enable_iso_mount":true,"enable_remote_mount":true},"support_virtual_protocol":["cifs","nfs","iso"],"system_codepage":"ger","uid":1026}
      2022-01-22 17:14:33.909 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:33.909 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 3 | typeof poll = object | poll = {"api":"dl","method":"getInfo","params":{}}
      2022-01-22 17:14:33.909 - debug: synology.1 (1009242) * Packet DL non installed, skipped
      2022-01-22 17:14:33.910 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:33.910 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 4 | typeof poll = object | poll = {"api":"as","method":"getInfo","params":{}}
      2022-01-22 17:14:33.910 - debug: synology.1 (1009242) * Packet AS non installed, skipped
      2022-01-22 17:14:33.910 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 5 | typeof poll = object | poll = {"api":"vs","method":"getInfo","params":{}}
      2022-01-22 17:14:33.910 - debug: synology.1 (1009242) * Packet VS non installed, skipped
      2022-01-22 17:14:33.910 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 6 | typeof poll = object | poll = {"api":"dtv","method":"GetInfoTuner","params":{}}
      2022-01-22 17:14:33.910 - debug: synology.1 (1009242) * Packet DTV non installed, skipped
      2022-01-22 17:14:33.910 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 7 | typeof poll = object | poll = {"api":"ss","method":"getInfo","params":{}}
      2022-01-22 17:14:33.910 - debug: synology.1 (1009242) * Packet SS non installed, skipped
      2022-01-22 17:14:33.910 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 8 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
      2022-01-22 17:14:33.911 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:33.911 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 9 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
      2022-01-22 17:14:33.911 - debug: synology.1 (1009242) * Packet SS non installed, skipped
      2022-01-22 17:14:33.911 - debug: synology.1 (1009242) * sendPolling. namePolling = firstPoll | iteration = 10 | typeof poll = object | poll = {"api":"as","method":"listRemotePlayers","params":{"type":"all","additional":"subplayer_list"}}
      2022-01-22 17:14:33.911 - debug: synology.1 (1009242) * Packet AS non installed, skipped
      2022-01-22 17:14:33.911 - debug: synology.1 (1009242) >>>>>>>>>>>>>>> Read all data, save received data.
      2022-01-22 17:14:33.911 - debug: synology.1 (1009242) setStates
      2022-01-22 17:14:33.911 - debug: synology.1 (1009242) setObject "DiskStationManager.info.codepage"
      2022-01-22 17:14:33.912 - debug: synology.1 (1009242) setObject "DiskStationManager.info.model"
      2022-01-22 17:14:33.912 - debug: synology.1 (1009242) setObject "DiskStationManager.info.ram"
      2022-01-22 17:14:33.912 - debug: synology.1 (1009242) setObject "DiskStationManager.info.serial"
      2022-01-22 17:14:33.912 - debug: synology.1 (1009242) setObject "DiskStationManager.info.temperature"
      2022-01-22 17:14:33.912 - debug: synology.1 (1009242) setObject "DiskStationManager.info.temperature_warn"
      2022-01-22 17:14:33.912 - debug: synology.1 (1009242) setObject "DiskStationManager.info.time"
      2022-01-22 17:14:33.912 - debug: synology.1 (1009242) setObject "DiskStationManager.info.uptime"
      2022-01-22 17:14:33.912 - debug: synology.1 (1009242) setObject "DiskStationManager.info.version"
      2022-01-22 17:14:33.912 - debug: synology.1 (1009242) setObject "DiskStationManager.info.version_string"
      2022-01-22 17:14:33.913 - debug: synology.1 (1009242) setObject "FileStation.info.enable_list_usergrp"
      2022-01-22 17:14:33.913 - debug: synology.1 (1009242) setObject "FileStation.info.enable_send_email_attachment"
      2022-01-22 17:14:33.913 - debug: synology.1 (1009242) setObject "FileStation.info.enable_view_google"
      2022-01-22 17:14:33.913 - debug: synology.1 (1009242) setObject "FileStation.info.enable_view_microsoft"
      2022-01-22 17:14:33.913 - debug: synology.1 (1009242) setObject "FileStation.info.hostname"
      2022-01-22 17:14:33.913 - debug: synology.1 (1009242) setObject "FileStation.info.is_manager"
      2022-01-22 17:14:33.913 - debug: synology.1 (1009242) setObject "FileStation.info.items.0"
      2022-01-22 17:14:33.913 - debug: synology.1 (1009242) setObject "FileStation.info.items.1"
      2022-01-22 17:14:33.913 - debug: synology.1 (1009242) setObject "FileStation.info.support_file_request"
      2022-01-22 17:14:33.913 - debug: synology.1 (1009242) setObject "FileStation.info.support_sharing"
      2022-01-22 17:14:33.914 - debug: synology.1 (1009242) setObject "FileStation.info.support_vfs"
      2022-01-22 17:14:33.914 - debug: synology.1 (1009242) setObject "FileStation.info.support_virtual.enable_iso_mount"
      2022-01-22 17:14:33.914 - debug: synology.1 (1009242) setObject "FileStation.info.support_virtual.enable_remote_mount"
      2022-01-22 17:14:33.914 - debug: synology.1 (1009242) setObject "FileStation.info.support_virtual_protocol.0"
      2022-01-22 17:14:33.914 - debug: synology.1 (1009242) setObject "FileStation.info.support_virtual_protocol.1"
      2022-01-22 17:14:33.914 - debug: synology.1 (1009242) setObject "FileStation.info.support_virtual_protocol.2"
      2022-01-22 17:14:33.914 - debug: synology.1 (1009242) setObject "FileStation.info.system_codepage"
      2022-01-22 17:14:33.914 - debug: synology.1 (1009242) setObject "FileStation.info.uid"
      2022-01-22 17:14:33.931 - info: synology.1 (1009242) State value to set for "synology.1.FileStation.info.enable_send_email_attachment" has to be type "string" but received type "boolean"
      2022-01-22 17:14:33.931 - info: synology.1 (1009242) State value to set for "synology.1.FileStation.info.enable_view_google" has to be type "string" but received type "boolean"
      2022-01-22 17:14:33.931 - info: synology.1 (1009242) State value to set for "synology.1.FileStation.info.enable_view_microsoft" has to be type "string" but received type "boolean"
      2022-01-22 17:14:33.931 - info: synology.1 (1009242) State value to set for "synology.1.FileStation.info.items.0" has to be stringified but received type "object"
      2022-01-22 17:14:33.931 - info: synology.1 (1009242) State value to set for "synology.1.FileStation.info.items.1" has to be stringified but received type "object"
      2022-01-22 17:14:38.915 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:38.915 - debug: synology.1 (1009242) * sendPolling. namePolling = fastPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getSystemUtilization","params":{}}
      2022-01-22 17:14:38.915 - debug: synology.1 (1009242) * Get info from (fastPoll) api: DSM method: getSystemUtilization params: {}
      2022-01-22 17:14:39.981 - debug: synology.1 (1009242) * The response is received, parse:
      2022-01-22 17:14:39.982 - debug: synology.1 (1009242) SystemUtilization - Response: {"cpu":{"15min_load":113,"1min_load":129,"5min_load":125,"device":"System","other_load":5,"system_load":2,"user_load":14},"disk":{"disk":[{"device":"sda","display_name":"Drive 1","read_access":0,"read_byte":0,"type":"internal","utilization":21,"write_access":27,"write_byte":2783616}],"total":{"device":"total","read_access":0,"read_byte":0,"utilization":21,"write_access":27,"write_byte":2783616}},"lun":[],"memory":{"avail_real":138112,"avail_swap":8122284,"buffer":85284,"cached":8761248,"device":"Memory","memory_size":10485760,"real_usage":10,"si_disk":0,"so_disk":0,"swap_usage":0,"total_real":10041556,"total_swap":8122284},"network":[{"device":"total","rx":5172784,"tx":40562},{"device":"bond0","rx":5172784,"tx":40562}],"nfs":[{"device":"nfs","read_OPS":0,"read_max_latency":0,"total_OPS":0,"total_max_latency":0,"write_OPS":0,"write_max_latency":0}],"space":{"total":{"device":"total","read_access":0,"read_byte":0,"utilization":5,"write_access":58,"write_byte":2741248},"volume":[{"device":"dm-0","display_name":"volume1","read_access":0,"read_byte":0,"utilization":5,"write_access":58,"write_byte":2741248}]},"time":1642871678}
      2022-01-22 17:14:39.982 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:39.982 - debug: synology.1 (1009242) * sendPolling. namePolling = fastPoll | iteration = 1 | typeof poll = object | poll = {"api":"dsm","method":"getSystemStatus","params":{}}
      2022-01-22 17:14:39.982 - debug: synology.1 (1009242) * Get info from (fastPoll) api: DSM method: getSystemStatus params: {}
      2022-01-22 17:14:40.201 - debug: synology.1 (1009242) * The response is received, parse:
      2022-01-22 17:14:40.201 - debug: synology.1 (1009242) SystemStatus - Response: {"is_system_crashed":false,"upgrade_ready":false}
      2022-01-22 17:14:40.201 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:40.201 - debug: synology.1 (1009242) * sendPolling. namePolling = fastPoll | iteration = 2 | typeof poll = object | poll = {"api":"dsm","method":"getInfo","params":{}}
      2022-01-22 17:14:40.201 - debug: synology.1 (1009242) * Get info from (fastPoll) api: DSM method: getInfo params: {}
      2022-01-22 17:14:40.262 - debug: synology.1 (1009242) * The response is received, parse:
      2022-01-22 17:14:40.262 - debug: synology.1 (1009242) TempInfo - Response: {"codepage":"ger","model":"DS718+","ram":10240,"serial":"1841PEN993700","temperature":40,"temperature_warn":false,"time":"Sat Jan 22 18:14:40 2022","uptime":33757,"version":"42218","version_string":"DSM 7.0.1-42218 Update 2"}
      2022-01-22 17:14:40.262 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:40.262 - debug: synology.1 (1009242) * sendPolling. namePolling = fastPoll | iteration = 3 | typeof poll = object | poll = {"api":"dsm","method":"infoSystem","params":{"type":"storage","version":1}}
      2022-01-22 17:14:40.262 - debug: synology.1 (1009242) * Get info from (fastPoll) api: DSM method: infoSystem params: {"type":"storage","version":1}
      2022-01-22 17:14:40.415 - debug: synology.1 (1009242) * The response is received, parse:
      2022-01-22 17:14:40.415 - debug: synology.1 (1009242) InfoSystem - Response: {"hdd_info":[{"capacity":"750156374016","diskPath":"/dev/sda","diskType":"SATA","diskno":"Drive 1","ebox_order":0,"model":"WD7500AAKS-00RBA0","order":1,"overview_status":"normal","pciSlot":-1,"portType":"normal","status":"normal","summary_status_category":"space","summary_status_key":"normal","temp":37,"testing_progress":"","testing_type":"idle","volume":"reuse_1"}],"vol_info":[{"desc":"SHR","inode_free":"0","inode_total":"0","name":"volume_1","status":"normal","total_size":"715397939200","used_size":"414866636800","vol_desc":"","volume":"volume_1"}]}
      2022-01-22 17:14:40.415 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:40.415 - debug: synology.1 (1009242) * sendPolling. namePolling = fastPoll | iteration = 4 | typeof poll = object | poll = {"api":"ss","method":"getInfoHomeMode","params":{"need_mobiles":true}}
      2022-01-22 17:14:40.415 - debug: synology.1 (1009242) * Packet SS non installed, skipped
      2022-01-22 17:14:40.415 - debug: synology.1 (1009242) * sendPolling. namePolling = fastPoll | iteration = 5 | typeof poll = object | poll = {"api":"ss","method":"listCameras","params":{"basic":true,"version":7}}
      2022-01-22 17:14:40.416 - debug: synology.1 (1009242) * sendPolling. namePolling = fastPoll | iteration = 6 | typeof poll = object | poll = {"api":"fs","method":"listSharings","params":{}}
      2022-01-22 17:14:40.416 - debug: synology.1 (1009242) * Get info from (fastPoll) api: FS method: listSharings params: {}
      2022-01-22 17:14:40.587 - debug: synology.1 (1009242) * The response is received, parse:
      2022-01-22 17:14:40.587 - debug: synology.1 (1009242) parseListSharings - Response: {"links":[],"offset":0,"total":0}
      2022-01-22 17:14:40.587 - debug: synology.1 (1009242) -----------------------------------------------------------------------------------------------------
      2022-01-22 17:14:40.587 - debug: synology.1 (1009242) >>>>>>>>>>>>>>> Read all data, save received data.
      2022-01-22 17:14:40.587 - debug: synology.1 (1009242) setStates
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.info.time"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.info.uptime"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.info.cpu_load"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.info.memory_usage"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.info.memory_size"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.info.is_system_crashed"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.info.upgrade_ready"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.hdd_info.sata_drive_1.diskno"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.hdd_info.sata_drive_1.model"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.hdd_info.sata_drive_1.overview_status"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.hdd_info.sata_drive_1.ebox_order"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.hdd_info.sata_drive_1.temperature"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.hdd_info.sata_drive_1.storage_pool"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.hdd_info.sata_drive_1.capacity"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.vol_info.volume_1.name"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.vol_info.volume_1.status"
      2022-01-22 17:14:40.588 - debug: synology.1 (1009242) setObject "DiskStationManager.vol_info.volume_1.total_size"
      2022-01-22 17:14:40.589 - debug: synology.1 (1009242) setObject "DiskStationManager.vol_info.volume_1.used_size"
      2022-01-22 17:14:40.589 - debug: synology.1 (1009242) setObject "DiskStationManager.vol_info.volume_1.used"
      2022-01-22 17:14:40.589 - debug: synology.1 (1009242) setObject "DiskStationManager.vol_info.volume_1.desc"
      GlasfaserG Offline
      GlasfaserG Offline
      Sollte so aussehen {"version":1} , das fehlt bei dir
      * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"listPackages","params":{"version":1}}
      Get info from (firstPoll) api: DSM method: listPackages params: {"version":1}
      Zeige mal die Instanzeinstellung als Screenshot
      HomoranH M 2 Antworten Letzte Antwort
      • GlasfaserG Glasfaser
        @glasfaser sagte in Läuft der Synology Adapter mit DSM 7 auch:
        kann das sein, dass das eine Meldung vom host ist?
          GlasfaserG Offline
          GlasfaserG Offline
          irgendwie fehlt bei Ihm die Pollingeinstellung vom Adapter .
          EDIT :
          der Log mit {"version":1} ist von mir
            EDIT :
            ich stochere ja auch nur im Nebel.
            Ich nutze den Adapter nicht mehr, habe noch keine DSM7 und auch die Surveillance-Station gar nicht in Betrieb
            Ich suche nur nach möglichen Ansatzpunkten und streue diese Ideen hier immer mal wieder ein
            Ebenfalls Edit:
            war mir klar!
            stammt der vom host, oder von syno-Adapter?
              megaron
              Viele Grüße megaron
              • GlasfaserG Offline
                GlasfaserG Offline
                @homoran sagte in Läuft der Synology Adapter mit DSM 7 auch:
                Kommt vom Adapter :
                PollCmd.firstPoll[0] = {api: 'dsm', method: 'listPackages', params: {version: 1}, ParseFunction: parseInstallingPackets};
                https://github.com/iobroker-community-adapters/ioBroker.synology/blob/master/main.js#L1372
                • M megaron
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @megaron
                  Stelle mal auf 7 // API Version
                    @megaron
                    megaron
                    @glasfaser
                    Kameras sind wieder da. Ich probier sie jetzt in der Visualisierung einzubinden
                    Viele Grüße megaron
                    • M megaron
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      und wieder Logo ...
                      du hast doch DSM 7 ;)
                      deshalb :
                      M HomoranH 2 Antworten Letzte Antwort
                        und wieder Logo ...
                        deshalb :
                        megaron
                        #66
                        @glasfaser
                        Ihr zwei seid echt der Hammer. Vielen Dank für die schnelle und unkomplizierte Hilfe. Das Forum hat echt seinen Namen verdient.
                        Viele Grüße megaron
                          und wieder Logo ...
                          deshalb :
                          #67
                          und wieder Logo ...
                          muss immer an meine alte Turtle denken
