  4. alte iobroker images
45 Beiträge 4 Kommentatoren 5.0k Aufrufe 2 Beobachtet
    @flinke-flasche sagte in alte iobroker images:
    Leider kommt keine Reaktion vom Ersteller.
    natürlich nicht wenn der seit 4 Jahren nicht mehr aktiv ist
    kopiere die fehlermeldungen.
    gut so
    Flinke Flasche
    host.iobroker-pi
    2022-01-15 11:23:15.141	info	Restart adapter system.adapter.arcam.0 because enabled
    host.iobroker-pi
    2022-01-15 11:23:15.140	error	instance system.adapter.arcam.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker-pi
    2022-01-15 11:23:15.139	error	Caught by controller[0]: }
    host.iobroker-pi
    2022-01-15 11:23:15.139	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.arcam/arcam.js' ]
    host.iobroker-pi
    2022-01-15 11:23:15.138	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker-pi
    2022-01-15 11:23:15.138	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12) {
    host.iobroker-pi
    2022-01-15 11:23:15.138	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.iobroker-pi
    2022-01-15 11:23:15.137	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.iobroker-pi
    2022-01-15 11:23:15.129	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.iobroker-pi
    2022-01-15 11:23:15.128	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.iobroker-pi
    2022-01-15 11:23:15.128	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.arcam/arcam.js:11:9)
    host.iobroker-pi
    2022-01-15 11:23:15.128	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.iobroker-pi
    2022-01-15 11:23:15.127	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.iobroker-pi
    2022-01-15 11:23:15.127	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    host.iobroker-pi
    2022-01-15 11:23:15.127	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    host.iobroker-pi
    2022-01-15 11:23:15.126	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.arcam/arcam.js
    host.iobroker-pi
    2022-01-15 11:23:15.126	error	Caught by controller[0]: Require stack:
    host.iobroker-pi
    2022-01-15 11:23:15.126	error	Caught by controller[0]: Error: Cannot find module 'string'
    host.iobroker-pi
    2022-01-15 11:23:15.125	error	Caught by controller[0]: ^
    host.iobroker-pi
    2022-01-15 11:23:15.125	error	Caught by controller[0]: throw err;
    host.iobroker-pi
    2022-01-15 11:23:15.124	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
    host.iobroker-pi
    2022-01-15 11:23:14.175	info	instance system.adapter.arcam.0 started with pid 737
    host.iobroker-pi
    2022-01-15 11:23:14.131	info	"system.adapter.arcam.0" enabled
    • F Flinke Flasche
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      host.iobroker-pi
      da muss sich mal einer einarbeiten und herausbekommen, wofür dieses Modul sein soll, warum es nicht vorhanden ist
      F 1 Antwort Letzte Antwort
        Flinke Flasche
        leider bin ich da zu schlecht,
        weshalb ich einfach iobroker 4.2.1 installieren wollte.
        Leider scheitert es gerade schon daran 😞
        hatte mir immer ein Image gezogen und das installiert.
        • F Flinke Flasche
          wenn du damit den controller meinst, müsste das gehen.
          Aber warum meinst du, dass es am controller liegt und nicht an der neuen Debian-, node-, npm- oder sonst einer Version
          • F Flinke Flasche
            @flinke-flasche
            Ich vermute, das hängt eher mit der nodejs Version zusammen, nicht direkt mit dem iobroker Admin.
              @flinke-flasche
              @thomas-braun sagte in alte iobroker images:
              den hatte ich jetzt gar nicht auf dem Schirm.
              Was soll der denn bewirken?
                Ich rate nur munter mit, was denn mit
                iobroker 4.2.1
                gemeint sein könnte.
                  Flinke Flasche
                  Es kann überall dran liegen.
                  Wie gesagt bin ich da zu wenig in der Materie drinnen.
                  Dachte ich installiere einfach ein altes Image, das es nicht mehr gibt, und es geht wieder.
                  Wollte schon meinen anderen iobroker clonen, allerdings gab es damals für raspberry pi 4 andere images.
                  Weiß nicht ob das dann auf dem 3+ läuft.
                    iobroker 4.2.1
                    Flinke Flasche
                    Sorry.
                    In meinem anderen iobroker steht oben 4.2.1 dran.
                    Das habe ich als Version genommen.
                    Die beiden habe ich damals am gleichen Tag erstellt.
                    • F Flinke Flasche
                      @flinke-flasche jetzt beantworte doch mal unsere Frage:
                      was denn mit
                      iobroker 4.2.1
                      @homoran sagte in alte iobroker images:
                      Ich suche 4.2.1.
                      Kernel-Version?
                        was denn mit
                        iobroker 4.2.1
                        Ich suche 4.2.1.
                        Kernel-Version?
                        Flinke Flasche
                        folgendes Versionen sind auf dem wo es funktioniert installiert
                        Node.js: v10.19.0
                        NPM: 6.13.4
                        Kernel version? wo finde ich die?
                        • F Flinke Flasche
                          Node.js: v10.19.0
                          NPM: 6.13.4
                          folgendes Versionen
                          und wer hat 4.2.1???????
                          habe mal nach dem Modul gegoogelt:
                          https://www.npmjs.com/package/string
                          Das ist auch seit 5 jahren nicht mehr aktiv.
                            folgendes Versionen
                            Flinke Flasche
                            es muss doch ne Möglichkeit geben das Teil irgendwie zum laufen zu bringen. 😕
                            Ob irgendwas alt ist, ist mir da eigentlich egal.
                            Der Pi ist ja nur zur Steuerung meines ARCAM Receiver
                            • F Flinke Flasche
                              Dir vielleicht, aber anscheinend hat npm es aus dem System gekickt, weil es über 10 Jahre alt ist und seit 5 Jahren nicht mehr gepflegt wurde.
                              Du kannst ja den Entwickler mal bitten da etwas gegen zu unternehmen:
                              https://github.com/jprichardson/string.js
                                Flinke Flasche
                                glaub nicht, das da was wegen mir gemacht wird. Zumal ich ja auch nicht viel Ahnung da habe.
                                Dachte ich finde noch ein Altes Image in ner Datenbank von damals, installiere es und gut ist es 😖
                                Leider ist das wohl nicht so einfach.
                                • F Flinke Flasche
                                  @flinke-flasche
                                  Oder du stellst eine Adapter-Anfrage, vielleicht mag sich das einer der Adapter-Schrauber Mal ansehen und einen Fork machen?
                                  • F Flinke Flasche
                                    auf der "dein" Adapter bereits installiert war?
                                    Ich glaube so ein Image gibt es weltweit nicht
                                    Ich habe auch nicht allzuviel Ahnung, aber im Moment sieht es für mich aus, als ob das notwendige npm-Modul nicht mehr zur Verfügung steht.
                                    Daher kann es dann auch nicht mehr von einem Adapter genutzt werden, egal wie alt die Grundinstallation war.
                                      Flinke Flasche
                                      Ich hatte mir damals nur ein Image für den pi von iobroker heruntergeladen. Dann den Adapter drauf und es lief.
                                      Das Image war ja so gesehen fertig und ich musste nichts mehr machen.
                                      • F Flinke Flasche
                                        aber jetzt geht es nicht mehr - npm hat inzwischen aufgeräumt!!
                                          M Online
                                          M Online
                                          mrjeschke
                                          Sorry wenn mal ganz doof fragen darf. Wenn nur das Modul String fehlt,
                                          reicht dann nicht ein
                                          cd /opt/iobroker
                                          npm install string
                                          HomoranH F 3 Antworten Letzte Antwort
