  4. Backitup macht keine Backups nach Plan
10 Beiträge 3 Kommentatoren 393 Aufrufe 2 Beobachtet
    tourer4778
    schrieb am zuletzt editiert von tourer4778
    Hallo, ich nutze Backitup und habe festgestellt, das er keine backups macht laut Zeitplan.
    Manuell speichert er meine History, Java und Iobroker Daten Lokal und auf GoogleDrive.
    Habe ich etwas falsch verstanden bzw. falsch eingestellt?
    Er soll täglich um 02:40 die Daten abspeichern.
    Gerade habe mir noch das Log angesehen, dort steht das drin 😕
    2022-01-11 02:40:24.631  - error: backitup.0 (17359) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2022-01-11 02:40:24.657  - error: backitup.0 (17359) unhandled promise rejection: Rate Limit Exceeded
    2022-01-11 02:40:24.726  - error: backitup.0 (17359) Error: Rate Limit Exceeded
        at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:158:15)
        at runMicrotasks (<anonymous>)
        at processTicksAndRejections (internal/process/task_queues.js:97:5)
        at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:368:18)
    2022-01-11 02:40:24.726  - error: backitup.0 (17359) Exception-Code: 403: Rate Limit Exceeded
    2022-01-11 02:40:24.740  - info: backitup.0 (17359) cleaned everything up...
    2022-01-11 02:40:24.741  - info: backitup.0 (17359) terminating
    2022-01-11 02:40:24.743  - warn: backitup.0 (17359) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-01-11 02:40:25.172  - warn: mqtt.0 (5707) Client [EPEVER_e1e194] Message 46725 deleted after 11 retries
    2022-01-11 02:40:25.336  - error: host.raspberrypi Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-01-11 02:40:25.348  - error: host.raspberrypi Caught by controller[1]: Error: Rate Limit Exceeded
    2022-01-11 02:40:25.348  - error: host.raspberrypi Caught by controller[1]:     at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:158:15)
    2022-01-11 02:40:25.348  - error: host.raspberrypi Caught by controller[1]:     at runMicrotasks (<anonymous>)
    2022-01-11 02:40:25.349  - error: host.raspberrypi Caught by controller[1]:     at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2022-01-11 02:40:25.349  - error: host.raspberrypi Caught by controller[1]:     at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:368:18)
    2022-01-11 02:40:25.349  - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-01-11 02:40:25.350  - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
    • T tourer4778
      @tourer4778
      Da scheint es beim Login auf das GoogleDrive zu haken. Schau dir das nochmal an.
        tourer4778
        Habe es mir nochmals angesehen. Für mich sieht alles iO aus.
        Was ich seltsam finde, vom IoBroker hat er ein Backup gemacht um 02:40, aber kein Java oder Historry.
        Habe dann Manuell einen gemacht, da macht er sofort alles mit Benachichtigung.
        Habe auch schon Backitup neu installiert und immer noch genau das selbe problem.
        • T tourer4778
          @thomas-braun sagte in Backitup macht keine Backups nach Paln:
          @tourer4778 sagte in Backitup macht keine Backups nach Paln:
          könnte ja auch ein temporäres Problem bi Google gewesen sein
            tourer4778
            Ist denn ein unterschied, ob Zeitgesteuert oder manuell ?
            Und wenn nicht, warum wird dann nur der iobroker gespeichert beo Google?
            • T tourer4778
              nein, eigentlich nicht
              Da kann ich auch nur raten.
              Fakt ist:
              Zuerst wird ioBroker gesichert, dann wird history lokal gepackt, was einiges an Zeit kostet und dann erst gesichert.
              Ob dann in der Zwischenzeit etwas mit der Leitung passiert ist oder google per timeout die Verbindung gekappt????
              Keine Ahnung, da muss sich jemand mit Ahnung durch das log wühlen
              Mich würde diese Meldung neugierig machn
                Fakt ist:
                @homoran sagte in Backitup macht keine Backups nach Paln:
                Schaust du in API-Beschreibung:
                Resolve a 403 error: Usage limit exceeded
                An error 403 occurs when a usage limit has been exceeded or the user doesn't have the correct privileges. To determine the specific type of error, evaluate the reason field of the returned JSON. This error occurs for the following situations:
                The daily limit was exceeded.
                The user rate limit was exceeded.
                The project rate limit was exceeded.
                The sharing rate limit was exceeded.
                The user hasn't granted your app rights to a file.
                The user doesn't have sufficient permissions for a file.
                Your app can't be used within the authenticated user's domain.
                Number of items in a folder was exceeded.
                Könnte also auch wieder mit Rechten zusammenhängen. Da deutet ja auch der oauth-Kram aus dem logfile hin.
                  tourer4778
                  Ich war jetzt noch einmal über Google drin und habe alles überprüft. Einmal musste ich den IoBroker bestätigen, bezüglich zugriffsrecht. Vielleicht war es das schon, wenn auch ich das ganze beim anmelden schon gemacht habe.
                  Danke für die Hilfe.
                  • T tourer4778
                    @tourer4778 sagte in Backitup macht keine Backups nach Plan:
                    das scheint zu passen
                      tourer4778
                      Leider imme rnoch das gleiche Problem.
                      Ich änder es auf meine NAS. Keine Ahnung warum das nun so ist. Vor meiner Neuinstallation ging es immer ...
