Adapter bleiben einfach im Status Gelb
@glasfaser Hi danke für die schnelle Antowrt, ja
|Systemdata|
daswetter.0 2022-01-08 15:30:28.827 info cleaned everything up... daswetter.0 2022-01-08 15:30:28.298 info Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment daswetter.0 2022-01-08 15:30:24.282 info still wrong data structure from server received! repaired... daswetter.0 2022-01-08 15:30:06.161 info starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.2, js-controller: 3.3.22 daswetter.0 2022-01-08 15:15:29.586 info cleaned everything up... daswetter.0 2022-01-08 15:15:29.072 info Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment daswetter.0 2022-01-08 15:15:25.118 info still wrong data structure from server received! repaired... daswetter.0 2022-01-08 15:15:10.139 info starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.2, js-controller: 3.3.22 daswetter.0 2022-01-08 15:00:29.026 info cleaned everything up... dwd.0 2022-01-08 15:36:02.872 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason dwd.0 2022-01-08 15:36:01.987 info starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22 dwd.0 2022-01-08 15:35:07.219 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason dwd.0 2022-01-08 15:35:02.085 info starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22 dwd.0 2022-01-08 15:34:03.063 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason dwd.0 2022-01-08 15:34:02.124 info starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22 dwd.0 2022-01-08 15:33:02.915 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason openweathermap.0 2022-01-08 15:30:13.960 info Terminated (NO_ERROR): Without reason openweathermap.0 2022-01-08 15:30:10.654 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.18.2, js-controller: 3.3.22 openweathermap.0 2022-01-08 15:15:09.310 info Terminated (NO_ERROR): Without reason openweathermap.0 2022-01-08 15:15:06.247 info starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node:MOD-EDIT: Code in code-tags gesetzt!
-- -- Hardwaresystem: Pi4 Arbeitsspeicher: 4GB Festplattenart: SSD Betriebssystem: raspbian OS Node-Version: 14.18.2 Nodejs-Version: 14.18.2 NPM-Version: 6.14.15 Installationsart: Manuell Image genutzt: Ja Ort/Name der Imagedatei: https://www.raspberrypi.com/software/operating-systems/#raspberry-pi-os-32-bit @stefan-h-0
was ist da gelb? -
@stefan-h-0
Die bleiben so ,
die haben eine Cron , das heißt zu einer bestimmten Zeit werden sie Aktiviert. -
@stefan-h-0
Die bleiben so ,
die haben eine Cron , das heißt zu einer bestimmten Zeit werden sie Aktiviert.@glasfaser Hi Glasfase, danke aber ich meine ich hätte alle Timer schon rausgenommen aber wenn es ok ist dann lass ich es so nur wie schon im Log zu sehen sieht es halt immer aus als wenn er die kom abbricht. Also eurer Rat so lassen und alles funktioniert i.O?
@stefan-h-0 sagte in Adapter bleiben einfach im Status Gelb:
Wieso nimmst du Timer bei scheduled Adaptern raus?
wie sollen die denn dann arbeiten?@stefan-h-0 sagte in Adapter bleiben einfach im Status Gelb:
Wo genau?
Wo genau?
So wie ich das sehe gibt es heir garkeine
?? warum die Timer löschen .
Alle Adapter die so sind , werden nur einmal mit dem Cron aktiviert un gehen wieder schlafen .
Oder brauchst du . z.B . jede senkunde eine Abfrage !? -
Schalte mal im Expertenmodus :
Ja werden so nicht angezeigt , wäre aber dann beim betroffenen Adapter ein Issues zu eröffnen .
Oder brauchst du . z.B . jede senkunde eine Abfrage !?@glasfaser HI,
nein brauche ich nicht aber ich schaue sie mir noch mal genauer an und werde das noch mal checken, danke erstmal für eure schnelle Hilfe (Ich binecht freudig überrascht und danke euch für eure Hilfe)
so ist es.
Es gibt Adapter die dauernd laufen, die haben eine "Ampel"
dann gibt es Adapter die zeitgesteuert starten, ihre Aufgabe abarbeiten und dann wieder stoppenmit
@homoran sagte in Adapter bleiben einfach im Status Gelb:Wo genau?
meinte ich den Logeintrag
Oder brauchst du . z.B . jede senkunde eine Abfrage !?@glasfaser sagte in Adapter bleiben einfach im Status Gelb:
eventuell meinte @Stefan-H-0 die restart-CRONs
