  4. Adapter bleiben einfach im Status Gelb
14 Beiträge 3 Kommentatoren 348 Aufrufe 2 Beobachtet
  • Stefan H. 0S Offline
    Stefan H. 0
    |Systemdata|
    daswetter.0
    	2022-01-08 15:30:28.827	info	cleaned everything up...
    daswetter.0
    	2022-01-08 15:30:28.298	info	Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    daswetter.0
    	2022-01-08 15:30:24.282	info	still wrong data structure from server received! repaired...
    daswetter.0
    	2022-01-08 15:30:06.161	info	starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.2, js-controller: 3.3.22
    daswetter.0
    	2022-01-08 15:15:29.586	info	cleaned everything up...
    daswetter.0
    	2022-01-08 15:15:29.072	info	Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    daswetter.0
    	2022-01-08 15:15:25.118	info	still wrong data structure from server received! repaired...
    daswetter.0
    	2022-01-08 15:15:10.139	info	starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.daswetter, node: v14.18.2, js-controller: 3.3.22
    daswetter.0
    	2022-01-08 15:00:29.026	info	cleaned everything up...
    dwd.0
    	2022-01-08 15:36:02.872	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    dwd.0
    	2022-01-08 15:36:01.987	info	starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22
    dwd.0
    	2022-01-08 15:35:07.219	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    dwd.0
    	2022-01-08 15:35:02.085	info	starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22
    dwd.0
    	2022-01-08 15:34:03.063	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    dwd.0
    	2022-01-08 15:34:02.124	info	starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v14.18.2, js-controller: 3.3.22
    dwd.0
    	2022-01-08 15:33:02.915	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    openweathermap.0
    	2022-01-08 15:30:13.960	info	Terminated (NO_ERROR): Without reason
    openweathermap.0
    	2022-01-08 15:30:10.654	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v14.18.2, js-controller: 3.3.22
    openweathermap.0
    	2022-01-08 15:15:09.310	info	Terminated (NO_ERROR): Without reason
    openweathermap.0
    	2022-01-08 15:15:06.247	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node:
    Hardwaresystem: Pi4
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: raspbian OS
    Node-Version: 14.18.2
    Nodejs-Version: 14.18.2
    NPM-Version: 6.14.15
    Installationsart: Manuell
    Image genutzt: Ja
    Ort/Name der Imagedatei: https://www.raspberrypi.com/software/operating-systems/#raspberry-pi-os-32-bit
    • GlasfaserG Offline
      GlasfaserG Offline
      @stefan-h-0
      Welche , die mit der Uhr !?
      Stefan H. 0S 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        @stefan-h-0
        Stefan H. 0
        @glasfaser Hi danke für die schnelle Antowrt, ja
        • Stefan H. 0S Stefan H. 0
          |Systemdata|
          daswetter.0
          daswetter.0
          daswetter.0
          daswetter.0
          daswetter.0
          daswetter.0
          daswetter.0
          daswetter.0
          daswetter.0
          dwd.0
          dwd.0
          dwd.0
          dwd.0
          dwd.0
          dwd.0
          dwd.0
          openweathermap.0
          openweathermap.0
          openweathermap.0
          openweathermap.0
          Hardwaresystem: Pi4
          Festplattenart: SSD
          Image genutzt: Ja
          HomoranH Offline
          HomoranH Offline
          @stefan-h-0
          was ist da gelb?
            GlasfaserG Offline
            GlasfaserG Offline
            @stefan-h-0
            Die bleiben so ,
            die haben eine Cron , das heißt zu einer bestimmten Zeit werden sie Aktiviert.
            GlasfaserG Stefan H. 0S 2 Antworten Letzte Antwort
              @stefan-h-0
              Die bleiben so ,
              GlasfaserG Offline
              GlasfaserG Offline
              @stefan-h-0
              Expertenmodus ...
              Beispiel :
                @stefan-h-0
                Die bleiben so ,
                Stefan H. 0
                @glasfaser Hi Glasfase, danke aber ich meine ich hätte alle Timer schon rausgenommen aber wenn es ok ist dann lass ich es so nur wie schon im Log zu sehen sieht es halt immer aus als wenn er die kom abbricht. Also eurer Rat so lassen und alles funktioniert i.O?
                HomoranH GlasfaserG 2 Antworten Letzte Antwort
                  HomoranH Offline
                  HomoranH Offline
                  @stefan-h-0 sagte in Adapter bleiben einfach im Status Gelb:
                  Wieso nimmst du Timer bei scheduled Adaptern raus?
                  wie sollen die denn dann arbeiten?
                  Wo genau?
                    Wo genau?
                    Stefan H. 0
                    So wie ich das sehe gibt es heir garkeine
                    GlasfaserG HomoranH 2 Antworten Letzte Antwort
                      GlasfaserG Offline
                      GlasfaserG Offline
                      ?? warum die Timer löschen .
                      Alle Adapter die so sind , werden nur einmal mit dem Cron aktiviert un gehen wieder schlafen .
                      Oder brauchst du . z.B . jede senkunde eine Abfrage !?
                      Stefan H. 0S HomoranH 2 Antworten Letzte Antwort
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Schalte mal im Expertenmodus :
                        Ja werden so nicht angezeigt , wäre aber dann beim betroffenen Adapter ein Issues zu eröffnen .
                          Stefan H. 0
                          @glasfaser HI,
                          nein brauche ich nicht aber ich schaue sie mir noch mal genauer an und werde das noch mal checken, danke erstmal für eure schnelle Hilfe (Ich binecht freudig überrascht und danke euch für eure Hilfe)
                            HomoranH Offline
                            HomoranH Offline
                            so ist es.
                            Es gibt Adapter die dauernd laufen, die haben eine "Ampel"
                            dann gibt es Adapter die zeitgesteuert starten, ihre Aufgabe abarbeiten und dann wieder stoppen
                            mit
                            @homoran sagte in Adapter bleiben einfach im Status Gelb:
                            Wo genau?
                            meinte ich den Logeintrag
                              HomoranH Offline
                              HomoranH Offline
                              @glasfaser sagte in Adapter bleiben einfach im Status Gelb:
                              eventuell meinte @Stefan-H-0 die restart-CRONs
