  4. TV Spielfilm Filme an Telegram senden
    5.1k
36 Beiträge 10 Kommentatoren 4.8k Aufrufe 10 Beobachtet
  • David G.D Online
    David G.D Online
    David G.
    Hab grad das mal auf die schnelle gemacht.
    Man kann das ja mit Fetter Schrift, kursiv oder leerzeilen formatieren.
    <block xmlns="https://developers.google.com/blockly/xml" type="on" id="1Z_#H`ujsP8l].Z1TJ[h" x="1987.0000305175781" y="287.5555419921875">
      <statement name="STATEMENT">
        <block type="variables_set" id="M!TQivTQ,+VWysWpCd.,">
          <field name="VAR" id="(m}dH@gw]g]CrCq4X:^O">Liste</field>
          <value name="VALUE">
            <block type="convert_json2object" id="dM4lavh,1pCid])r;%2c">
                <block type="get_value" id="qv%0_.TPM$N1TY=q/x3P">
                  <field name="OID">tvspielfilm.0.json.raw.heute2015</field>
                </block>
              </value>
            </block>
          </value>
          <next>
            <block type="variables_set" id="78_w.^4bKwlqu%)}!Oen">
              <field name="VAR" id=",O=|~X+ILjebgj|dif6S">telegram</field>
                <block type="text" id="x5c2en6c{Gk%3[*)^e?]">
                  <field name="TEXT"></field>
                </block>
              </value>
              <next>
                <block type="controls_for" id="D4)$pB!idN1DS(._I|=_">
                  <field name="VAR" id="x(8OtWm-n$bsM}t4],DO">i</field>
                  <value name="FROM">
                    <shadow type="math_number" id="6^JKhl_wAvCT3mSBuofN">
                      <field name="NUM">1</field>
                    </shadow>
                  </value>
                  <value name="TO">
                    <shadow type="math_number">
                      <field name="NUM">10</field>
                    </shadow>
                    <block type="lists_length" id="1s3,ktY?W|NY!9%7mi4o">
                        <block type="variables_get" id="hOIQCUl!0Ft,SwqYOZq-">
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="BY">
                    <shadow type="math_number" id="mI36517]YmvM;uMuXrmo">
                    </shadow>
                  </value>
                  <statement name="DO">
                    <block type="variables_set" id="KySfrK1Suk1u6)cP#f6I">
                      <field name="VAR" id="B=:MPlbZ]`U`oQR_H1ZO">obj</field>
                        <block type="lists_getIndex" id="Wvq~=LJHX~b95e^f@74v">
                          <mutation statement="false" at="true"></mutation>
                          <field name="MODE">GET</field>
                          <field name="WHERE">FROM_START</field>
                            <block type="variables_get" id="t[}cHoM=weQm`?1ai;TZ">
                            </block>
                          </value>
                          <value name="AT">
                            <block type="variables_get" id="h^w#]e)1h=syQp:ZP|=m">
                            </block>
                          </value>
                        </block>
                      </value>
                      <next>
                        <block type="variables_set" id="Yd5jU5}J1B-yEXsA+*Do">
                          <field name="VAR" id="WND~1`M#LY[oSWchGJ;/">Titel</field>
                            <block type="get_attr" id="ORQVV$6GG~dkc..Bj6q}">
                              <value name="PATH">
                                <shadow type="text" id=".krO~Wa1nxCsThY,Or)s">
                                  <field name="TEXT">title</field>
                                </shadow>
                              </value>
                              <value name="OBJECT">
                                <block type="variables_get" id="hkT%Hkr|IM=mWD?knzCJ">
                                </block>
                              </value>
                            </block>
                          </value>
                          <next>
                            <block type="variables_set" id="QztnJOR.#o)qFwAI;!o%">
                              <field name="VAR" id="qkP}SP]Wsh}w_3jlwPM=">Sender</field>
                                <block type="get_attr" id="3?TOMPpMEyT/^a`HENI@">
                                  <value name="PATH">
                                    <shadow type="text" id="x;4kco4V~Dcv^s/0G20t">
                                      <field name="TEXT">station</field>
                                    </shadow>
                                  </value>
                                    <block type="variables_get" id="eb!`WL:PQGOQjAizPrFt">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                <block type="variables_set" id="`w0$1;D)phdPz+aUOnvK">
                                  <field name="VAR" id="Cb`$KNa=.y/wQjyFtN6F">Zeit</field>
                                    <block type="get_attr" id="2MBZdp6-Gf5)N5#tnTQs">
                                      <value name="PATH">
                                        <shadow type="text" id="kNWoH^-F1E4zw)@P8udA">
                                          <field name="TEXT">time</field>
                                        </shadow>
                                      </value>
                                        <block type="variables_get" id="5`j=K8Hjpibh-d8K5`),">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <next>
                                    <block type="variables_set" id="*{2rtH+9+7vMynnk$8r-">
                                      <field name="VAR" id="=H4KnMf9.v,`_]uv_6#?">Bild</field>
                                        <block type="get_attr" id=";YzvMK)Z-nmNj]j{;dF/">
                                          <value name="PATH">
                                            <shadow type="text" id="1}p?I;;)lDh=})-o!$Bd">
                                              <field name="TEXT">imgUrl</field>
                                            </shadow>
                                          </value>
                                            <block type="variables_get" id="(!CM(TzS8yTQoHF1V;*!">
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                        <block type="variables_set" id="J$xo8;~~=G(DeA-en[-V">
                                          <field name="VAR" id=",,-mG}Ve8pp=2QR3G0v$">Beschreibung</field>
                                            <block type="get_attr" id=".QugAIBg|68]t]r~[GT)">
                                              <value name="PATH">
                                                <shadow type="text" id="%!-6_b%CO;ha$|0v-}p-">
                                                  <field name="TEXT">description</field>
                                                </shadow>
                                              </value>
                                                <block type="variables_get" id=".2]rKoOB%~[Tubj_AD4z">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                            <block type="variables_set" id="OB/3nI~98D])#$Gz@1Ed">
                                                <block type="text_join" id="M4u[=cBqcx+BjsB=c/TI">
                                                  <mutation items="14"></mutation>
                                                  <value name="ADD0">
                                                    <block type="variables_get" id="kEZYFbwo%gWJinYV`oiO">
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                    <block type="text_newline" id="A[@`X%9F,RM_JBuBu*YD">
                                                      <field name="Type">\n</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                    <block type="variables_get" id="CAg7YBG4BPg|-t-of+zl">
                                                    </block>
                                                  </value>
                                                  <value name="ADD3">
                                                    <block type="text" id="s#l)mk?D^/om=[`8o/4L">
                                                      <field name="TEXT"> </field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD4">
                                                    <block type="variables_get" id="BldT2bsS88@tM.TNGvs.">
                                                    </block>
                                                  </value>
                                                  <value name="ADD5">
                                                    <block type="text_newline" id="=;cD[pNjG-:1E2M7l-1!">
                                                    </block>
                                                  </value>
                                                  <value name="ADD6">
                                                    <block type="variables_get" id="2o2o7^}xDm_%6c=y~+lc">
                                                    </block>
                                                  </value>
                                                  <value name="ADD7">
                                                    <block type="text_newline" id="Im[ERJ[v`MM9e]lD:~O8">
                                                    </block>
                                                  </value>
                                                  <value name="ADD8">
                                                    <block type="text_getSubstring" id=";RCNIwQ9-t2g#x6$X:VH">
                                                      <mutation at1="true" at2="true"></mutation>
                                                      <field name="WHERE1">FROM_START</field>
                                                      <field name="WHERE2">FROM_START</field>
                                                      <value name="STRING">
                                                        <block type="variables_get" id="]?O~N!(N$bgDbrr*0y$=">
                                                        </block>
                                                      </value>
                                                      <value name="AT1">
                                                        <block type="math_number" id="@4+DWD@c};URnPF6G@!@">
                                                        </block>
                                                      </value>
                                                      <value name="AT2">
                                                        <block type="math_number" id="f!XP7|$,Pp$q$43J~P,5">
                                                          <field name="NUM">300</field>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="ADD9">
                                                    <block type="text_newline" id=",./hLpuhff)K5N[j(.s_">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                  <next>
                    <block type="telegram" id="Rkw#zZ_x(#0(RDG_KqQ?">
                      <field name="LOG"></field>
                      <field name="PARSEMODE">HTML</field>
                      <value name="MESSAGE">
                        <shadow type="text" id="g0t/M_q}p|6VaNH~fkTd">
                        </shadow>
                        <block type="variables_get" id="@|-}^99,I8M.u~?Z#+Sx">
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </statement>
    </block>
    EDIT:
    Habe die Beschreibung für meine Visualisierung auf 300 Zeichen gekürzt. Für Telegram reichen evtl. sogar weniger. Lässt sich ja leicht anpassen oder entfernen.
    SeiteBallon74S 2 Antworten Letzte Antwort
    • SeiteBallon74S SeiteBallon74
      @david-g sieht echt super aus. Tolle Arbeit.
      Mir reicht aber Telegram, darüber habe ich eigentlich alles laufen und bin super zufrieden.
      Wie gesagt, das TV Programm wäre noch klasse wenn ich hinbekommen würde.
      David G.D Online
      David G.D Online
      David G.
      Doppelpost
      • David G.D David G.
                    </block>
                  </value>
                </block>
              </value>
              <next>
                    </block>
                  </value>
                  <next>
                      <value name="FROM">
                        </shadow>
                      </value>
                      <value name="TO">
                        </shadow>
                            </block>
                          </value>
                        </block>
                      </value>
                      <value name="BY">
                        </shadow>
                      </value>
                                </block>
                              </value>
                              <value name="AT">
                                </block>
                              </value>
                            </block>
                          </value>
                          <next>
                                  <value name="PATH">
                                    </shadow>
                                  </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                      <value name="PATH">
                                        </shadow>
                                      </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <next>
                                          <value name="PATH">
                                            </shadow>
                                          </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                              <value name="PATH">
                                                </shadow>
                                              </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                                  <value name="PATH">
                                                    </shadow>
                                                  </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <next>
                                                      <value name="ADD0">
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                        </block>
                                                      </value>
                                                      <value name="ADD3">
                                                        </block>
                                                      </value>
                                                      <value name="ADD4">
                                                        </block>
                                                      </value>
                                                      <value name="ADD5">
                                                        </block>
                                                      </value>
                                                      <value name="ADD6">
                                                        </block>
                                                      </value>
                                                      <value name="ADD7">
                                                        </block>
                                                      </value>
                                                      <value name="ADD8">
                                                            </block>
                                                          </value>
                                                          <value name="AT1">
                                                            </block>
                                                          </value>
                                                          <value name="AT2">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="ADD9">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <next>
                            </shadow>
                            </block>
                          </value>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
        EDIT:
        SeiteBallon74S Offline
        SeiteBallon74
        @david-g
        Mei Klasse. Richtig toll. Wenn die Kinder später im Bett sind, werde ich es gleich probieren. Vielen vielen Dank. .
        Achja und deine Oberfläche ist wirklich megamäßig..
                      </block>
                    </value>
                  </block>
                </value>
                <next>
                      </block>
                    </value>
                    <next>
                        <value name="FROM">
                          </shadow>
                        </value>
                        <value name="TO">
                          </shadow>
                              </block>
                            </value>
                          </block>
                        </value>
                        <value name="BY">
                          </shadow>
                        </value>
                                  </block>
                                </value>
                                <value name="AT">
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                                    <value name="PATH">
                                      </shadow>
                                    </value>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                        <value name="PATH">
                                          </shadow>
                                        </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                            <value name="PATH">
                                              </shadow>
                                            </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                                <value name="PATH">
                                                  </shadow>
                                                </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                                    <value name="PATH">
                                                      </shadow>
                                                    </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                        <value name="ADD0">
                                                          </block>
                                                        </value>
                                                        <value name="ADD1">
                                                          </block>
                                                        </value>
                                                        <value name="ADD2">
                                                          </block>
                                                        </value>
                                                        <value name="ADD3">
                                                          </block>
                                                        </value>
                                                        <value name="ADD4">
                                                          </block>
                                                        </value>
                                                        <value name="ADD5">
                                                          </block>
                                                        </value>
                                                        <value name="ADD6">
                                                          </block>
                                                        </value>
                                                        <value name="ADD7">
                                                          </block>
                                                        </value>
                                                        <value name="ADD8">
                                                              </block>
                                                            </value>
                                                            <value name="AT1">
                                                              </block>
                                                            </value>
                                                            <value name="AT2">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="ADD9">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </statement>
                        <next>
                              </shadow>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
          EDIT:
          SeiteBallon74
          @david-g
          Wie meinst du das mit gekürzt und Telegram? Das man deine Visualisierung in Telegram hat oder was meinst du damit?
          Ich bin total platt wenn ich so ein blockly sehe.
          Ich Frage mich da immer wie man nur auf sowas kommt. Richtig heftig. Riesen Respekt dafür.
            @david-g
            David G.D Online
            David G.D Online
            David G.
            @seiteballon74
            Hab es auch mit Hilfe aus dem forum gemacht.
            Die Beschreibungen der Filme sind oft SEHR lang.
            Habe diese auf 300 Zeichen gekürzt.
            Da wo die 300 im Skript steht.
            Kann man eintragen was man will.
            Egal ob 50 oder 1000
            SeiteBallon74S 1 Antwort Letzte Antwort
              @seiteballon74
              SeiteBallon74
              @david-g
              Okay, Script läuft. Super. Aber sollten da nicht auch Bilder laut Script angezeigt werden?
              Kommt "nur" der Text.
                @david-g
                David G.D Online
                David G.D Online
                David G.
                @seiteballon74
                Bilder wirst du (meiner Meinung nach) in telegram so nicht eingebunden bekommen.
                Du hast ja noch die Variable Bild. Die kannst du ja mit in den Text erstellen Block packen.
                Da wird dann aber nur der link eingefügt.
                In telegram sieht man dann eine Vorschau vom ersten Bild am Ende der nachricht.
                Dafür sieht man dann überall die links....
                  @seiteballon74
                  SeiteBallon74
                  @david-g
                  Okay, alles klar. So ist es auch top. Vielleicht sogar besser.
                  Aber kann man das nicht noch auch genauso machen wenn man sich News anzeigen lassen will??
                  Wenn ja, mit welchem Adapter?
                    @david-g
                    David G.D Online
                    David G.D Online
                    David G.
                    @seiteballon74
                    Für newas habe ich nichts. Hab ich auch keinen Adapter für.
                    Wenn du viel über telegram machst wäre das evtl was für dich:
                    Tägliche Terminübersicht
                    Zusätzlich bekomme ich jeden Sonntag Abend diese Nachricht:
                    Oder morgens das Wetter
                    SeiteBallon74S C M 3 Antworten Letzte Antwort
                      @seiteballon74
                      SeiteBallon74
                      @david-g
                      Boah, wie geil. Du bist ja der Wahnsinn!!!!! Ich mach alles nur mit Telegram. Kann ich dir gern mal zeigen.
                        @david-g
                        David G.D Online
                        David G.D Online
                        David G.
                        @seiteballon74
                        Basiert alles auf dem System von dem Skript mit den Fernsehprogramm oder es werden nur Datenpunkte abgefragt. Wenn man einmal eins hat kann man alles andere ableiten.
                        Kannst ja mal Screenshots senden.
                        Meine Visualisierung siehst du in meiner Signatur.
                          @seiteballon74
                          SeiteBallon74
                          @david-g
                          Ja wahrscheinlich ist das nur für dich ein kinkerlitz aber für mich schon jahrelange Arbeit eigl..immer wieder..als Hobby Anwender mit Kindern die einem auf trap halten.
                            @david-g
                            David G.D Online
                            David G.D Online
                            David G.
                            @seiteballon74
                            Mit den Kindern sagst du was.
                            Mache fast alles abends vom Sofa auf am Handy wenn die Kleinen schlafen (1 und 3).
                            Bis dann meine Frau kommt, dass ich das Handy mal weglegen soll (was ja auch stimmt).
                            Kann das alles selber auch nicht so gut.
                            Fast alles hier im Forum mit Hilfe entstandenen.
                              @seiteballon74
                              SeiteBallon74
                              @david-g
                              Ja genau. Versteh ich nur allzu gut. Nochmal Danke für deine Hilfe.
                                @seiteballon74
                                ClausenPIT
                                @david-g Moin, Kannst du das Skript für das heutige Wetter mal zeigen? Wäre echt nett
                                • C ClausenPIT
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  @clausenpit
                                    <variables>
                                      <variable id="wU:WJBv/~A+RZE}xc~8^">Wetter abends und nachts</variable>
                                      <variable id="2wOK:bRE.{]s]-=wj?e/">Gewitter</variable>
                                      <variable id="q-e#RrXR7XxU7a}TgCnL">Regen</variable>
                                      <variable id="%I`G-G2W.sGbe-*A%M?;">Schnee</variable>
                                      <variable id="4CJZHtKTh;o?NzYiYI#I">Eis</variable>
                                    </variables>
                                    <block type="schedule" id="[Kr;4!ovzV,@cc*QCJZy" x="-412" y="-562">
                                      <field name="SCHEDULE">15 7 * * *</field>
                                        <block type="controls_if" id="]_Y{2hQrDIkjQW0cIaO1">
                                          <value name="IF0">
                                            <block type="logic_operation" id="=zG2eq`TsRHra)L$1+;g">
                                              <field name="OP">OR</field>
                                              <value name="A">
                                                <block type="logic_compare" id="a54+cJ^=9a+Ri8qQRlzw">
                                                  <field name="OP">GT</field>
                                                  <value name="A">
                                                    <block type="get_value" id="#k]MlIAx}!=A_Jo^1R[7">
                                                      <field name="OID">accuweather.0.Daily.Day1.Day.ThunderstormProbability</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="math_number" id="/N2N5})tdIN~XSR{wD0D">
                                                      <field name="NUM">0</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <block type="logic_compare" id="G#!ToN1S-j+0#$L4,]v7">
                                                  <value name="A">
                                                    <block type="get_value" id="xs/hy+WGs#T]h/t/cZE9">
                                                      <field name="OID">accuweather.0.Daily.Day1.Night.ThunderstormProbability</field>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="math_number" id="x~q|mQ3~m2~_e~(5*hhP">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <statement name="DO0">
                                            <block type="variables_set" id="W?MOyl*}Z.9KS8GLQ5s8">
                                              <field name="VAR" id="2wOK:bRE.{]s]-=wj?e/">Gewitter</field>
                                                <block type="text_join" id="TwW:m1G_f)(Pe]G+e*C2">
                                                  <mutation items="8"></mutation>
                                                  <value name="ADD0">
                                                    <block type="text" id="`gubI44R|V~+w%fTH(#c">
                                                      <field name="TEXT">Gewitter Tag:    </field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD1">
                                                    <block type="get_value" id="mBmzKRfH=:$N0vF7zZEQ">
                                                    </block>
                                                  </value>
                                                  <value name="ADD2">
                                                    <block type="text" id="L.|kX#8redT5r@Fad5sH">
                                                      <field name="TEXT">%</field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD3">
                                                    <block type="text_newline" id="-031]?Y)7aFc$QCtF@j-">
                                                    </block>
                                                  </value>
                                                  <value name="ADD4">
                                                    <block type="text" id="Hk2fh({:F(EtSQNSl~kI">
                                                      <field name="TEXT">Gewitter Nacht: </field>
                                                    </block>
                                                  </value>
                                                  <value name="ADD5">
                                                    <block type="get_value" id="u5}5N@y/k7,]~%AVJ|O#">
                                                    </block>
                                                  </value>
                                                  <value name="ADD6">
                                                    <block type="text" id="44LN_F@;Y4gvcdwfE-;0">
                                                    </block>
                                                  </value>
                                                  <value name="ADD7">
                                                    <block type="text_newline" id="Kt$hGf5P;r#ZyzzzO5`}">
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <statement name="ELSE">
                                            <block type="variables_set" id="gE)JbW0,:K+$Mx,rnL/I">
                                                <block type="text" id="r;|EZDDd?7de12KTn2@i">
                                                </block>
                                              </value>
                                            </block>
                                          </statement>
                                          <next>
                                            <block type="controls_if" id="V8i0qp@:Tn3a-)hDuU6{">
                                              <value name="IF0">
                                                <block type="logic_operation" id="ZpFzT;qT:L`T}xn;}|7g">
                                                  <value name="A">
                                                    <block type="logic_compare" id="]|o%Tlm)ko/CAm,cLfaa">
                                                      <value name="A">
                                                        <block type="get_value" id=")7#OY5$bh:hc]#VC[*O/">
                                                          <field name="OID">accuweather.0.Daily.Day1.Day.RainProbability</field>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="math_number" id="5u4A0pmPsN*//UZg%%og">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <block type="logic_compare" id="t$o_Sjd71oKcXM|lEhoS">
                                                      <value name="A">
                                                        <block type="get_value" id="MyBvA)ug)E=Om|:#*HeB">
                                                          <field name="OID">accuweather.0.Daily.Day1.Night.RainProbability</field>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="math_number" id="EkZVGK^0TS/|gY.C|;q6">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                                <block type="variables_set" id="Q$`BG//=2xUTPn*ih8.g">
                                                  <field name="VAR" id="q-e#RrXR7XxU7a}TgCnL">Regen</field>
                                                    <block type="text_join" id="SVft1iG=NL`]4T]xHw#M">
                                                      <mutation items="12"></mutation>
                                                      <value name="ADD0">
                                                        <block type="text" id="b6*QmDsN#lL}ZX:Y4M;?">
                                                          <field name="TEXT">Regen Tag:        </field>
                                                        </block>
                                                      </value>
                                                      <value name="ADD1">
                                                        <block type="get_value" id="56j#pbezNW_rAmF^~ow:">
                                                        </block>
                                                      </value>
                                                      <value name="ADD2">
                                                        <block type="text" id="9^;ZM*nCb5=V#J8`Z+an">
                                                          <field name="TEXT">%, </field>
                                                        </block>
                                                      </value>
                                                      <value name="ADD3">
                                                        <block type="get_value" id="]1QN6g?p#e[b)[o^,^WD">
                                                          <field name="OID">accuweather.0.Daily.Day1.Day.RainVolume</field>
                                                        </block>
                                                      </value>
                                                      <value name="ADD4">
                                                        <block type="text" id="W[)VPX@eeMjLZ_DXTd*g">
                                                          <field name="TEXT">mm</field>
                                                        </block>
                                                      </value>
                                                      <value name="ADD5">
                                                        <block type="text_newline" id=";oQR|mWe-E~Jw?zxv][^">
                                                        </block>
                                                      </value>
                                                      <value name="ADD6">
                                                        <block type="text" id="O,THQ8DHEA0(16Pt!0E#">
                                                          <field name="TEXT">Regen Nacht:    </field>
                                                        </block>
                                                      </value>
                                                      <value name="ADD7">
                                                        <block type="get_value" id="MU|+[9HkH{R4M(_K9TV5">
                                                        </block>
                                                      </value>
                                                      <value name="ADD8">
                                                        <block type="text" id="(hfP,AHDdq7aZyma%gOv">
                                                        </block>
                                                      </value>
                                                      <value name="ADD9">
                                                        <block type="get_value" id="pKq4a|z7RTZ8uEqTMZ+t">
                                                          <field name="OID">accuweather.0.Daily.Day1.Night.RainVolume</field>
                                                        </block>
                                                      </value>
                                                      <value name="ADD10">
                                                        <block type="text" id=":?E4Q`C;2:%.,$-y;m4p">
                                                        </block>
                                                      </value>
                                                      <value name="ADD11">
                                                        <block type="text_newline" id="m:Ee+`{Q3Y.uGba=cACL">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                                <block type="variables_set" id="B0oX__hLU.#},Lr9DJoV">
                                                    <block type="text" id="1Di.J5WK|*48j87$]VDm">
                                                    </block>
                                                  </value>
                                                </block>
                                              </statement>
                                              <next>
                                                <block type="controls_if" id="O4SgrP*mPcDvj,zbg|8S">
                                                  <value name="IF0">
                                                    <block type="logic_operation" id="lLU0D6lEqN[SHnh0lPVc">
                                                      <value name="A">
                                                        <block type="logic_compare" id="k2]`6ka?;2u%RAL`Man`">
                                                          <value name="A">
                                                            <block type="get_value" id="23f[3|F?@dxZdw~3Hra~">
                                                              <field name="OID">accuweather.0.Daily.Day1.Day.SnowProbability</field>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="math_number" id="9{C|,_{zIgIV/29D^b45">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <block type="logic_compare" id="GV0ch,0U[X+(cvrLt${C">
                                                          <value name="A">
                                                            <block type="get_value" id="HS^WO`B|`Fh4*aXWP#z)">
                                                              <field name="OID">accuweather.0.Daily.Day1.Night.SnowProbability</field>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="math_number" id="Xnq;-eAkR]#H)ezjrd14">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                    <block type="variables_set" id="Q7;?M]rIMjHB|jvFJw|$">
                                                      <field name="VAR" id="%I`G-G2W.sGbe-*A%M?;">Schnee</field>
                                                        <block type="text_join" id=")*7L=2IGgw@dwE%9Ghw^">
                                                          <value name="ADD0">
                                                            <block type="text" id="[y9#@AHpP_Hz6O{bsO}7">
                                                              <field name="TEXT">Schnee Tag:      </field>
                                                            </block>
                                                          </value>
                                                          <value name="ADD1">
                                                            <block type="get_value" id="qXlg#k8B7Z-mocSs_0(?">
                                                            </block>
                                                          </value>
                                                          <value name="ADD2">
                                                            <block type="text" id="Bg0i27r(SX~E[A{EKC$o">
                                                            </block>
                                                          </value>
                                                          <value name="ADD3">
                                                            <block type="get_value" id="~^Sd~_RHc_gp6mSXESON">
                                                              <field name="OID">accuweather.0.Daily.Day1.Day.SnowVolume</field>
                                                            </block>
                                                          </value>
                                                          <value name="ADD4">
                                                            <block type="text" id="|`_-%X{3c#c_|7q0W,a*">
                                                            </block>
                                                          </value>
                                                          <value name="ADD5">
                                                            <block type="text_newline" id="wrh3-KE4mO=Uw00#(TNL">
                                                            </block>
                                                          </value>
                                                          <value name="ADD6">
                                                            <block type="text" id="Ojn@`Vx!X#nDQv?PxkcC">
                                                              <field name="TEXT">Schnee Nacht:  </field>
                                                            </block>
                                                          </value>
                                                          <value name="ADD7">
                                                            <block type="get_value" id="9j8y1MO@CY5-H?)ITa~~">
                                                            </block>
                                                          </value>
                                                          <value name="ADD8">
                                                            <block type="text" id="L|bniu0d0b}8J?ZFx]fD">
                                                            </block>
                                                          </value>
                                                          <value name="ADD9">
                                                            <block type="get_value" id="3bU!Wbcby3=`tfp}^{b8">
                                                              <field name="OID">accuweather.0.Daily.Day1.Night.SnowVolume</field>
                                                            </block>
                                                          </value>
                                                            <block type="text" id="Z=8_fOXlOXU.ihdfje;a">
                                                            </block>
                                                          </value>
                                                            <block type="text_newline" id="b0g@I6;vi-i#V2`-l#lp">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                    <block type="variables_set" id="(s/PLKON:3Iu@~3p[$6b">
                                                        <block type="text" id="7dX]Y0QtHY_B]2fr;1cX">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                  <next>
                                                    <block type="controls_if" id="p2RYlE8bRInpj~p)1Gs=">
                                                      <value name="IF0">
                                                        <block type="logic_operation" id=".kckR`E-*BuC4nF#Q/S0">
                                                          <value name="A">
                                                            <block type="logic_compare" id="rP:8DLgoIUJ6W(RDCmcf">
                                                              <value name="A">
        <block type="get_value" id="A0Cwcu.(H{D4]%{cc[kY">
        <field name="OID">accuweather.0.Daily.Day1.Day.IceProbability</field>
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="math_number" id="8Ma#KF,da@w=z)qp0ssd">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            <block type="logic_compare" id="^y]VEY2Wm{@hpbr$Q.wP">
                                                              <value name="A">
        <block type="get_value" id="aB-uc0F#tk*h~oJAlJ@Z">
        <field name="OID">accuweather.0.Daily.Day1.Night.IceProbability</field>
        </block>
                                                              </value>
                                                              <value name="B">
        <block type="math_number" id="|ubXQW#w6a:fkxX}]Z|T">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                        <block type="variables_set" id="2)m#:l]NjF3iW`(-K@5e">
                                                          <field name="VAR" id="4CJZHtKTh;o?NzYiYI#I">Eis</field>
                                                            <block type="text_join" id="9?5ic-GC4)YD#aZ6H%*z">
                                                              <value name="ADD0">
        <block type="text" id="O=aj%Up1aVQMxTW-,_5-">
        <field name="TEXT">Hagel Tag:         </field>
        </block>
                                                              </value>
                                                              <value name="ADD1">
        <block type="get_value" id="1k/s]s/zad.82*s0ReV:">
        </block>
                                                              </value>
                                                              <value name="ADD2">
        <block type="text" id="=Lnn5KU)M{=Le{|]9?V)">
        </block>
                                                              </value>
                                                              <value name="ADD3">
        <block type="get_value" id="PNRf,XsIBSgMsGHl$Fmp">
        <field name="OID">accuweather.0.Daily.Day1.Day.IceVolume</field>
        </block>
                                                              </value>
                                                              <value name="ADD4">
        <block type="text" id="crX}Q]F![onL3Vg==T44">
        </block>
                                                              </value>
                                                              <value name="ADD5">
        <block type="text_newline" id="@KnWHCY9Q[Bh9X5VRGW%">
        </block>
                                                              </value>
                                                              <value name="ADD6">
        <block type="text" id="K)Eu}^m0ey9Z[x_=^R{)">
        <field name="TEXT">Hagel Nacht:     </field>
        </block>
                                                              </value>
                                                              <value name="ADD7">
        <block type="get_value" id="N5P1eE.wpn.I7U{rDG]}">
        </block>
                                                              </value>
                                                              <value name="ADD8">
        <block type="text" id="tB`C.EgcZzABTW!v#a[4">
        </block>
                                                              </value>
                                                              <value name="ADD9">
        <block type="get_value" id=";Yv.g,_Lqytw`ud:WG7?">
        <field name="OID">accuweather.0.Daily.Day1.Night.IceVolume</field>
        </block>
                                                              </value>
        <block type="text" id="nWbR[q}@6|@#}`Y-f5zv">
        </block>
                                                              </value>
        <block type="text_newline" id="[[9buxuBW)UTvA7sq/!B">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                        <block type="variables_set" id="gyQN7)({Xf9{`9J?z5Jd">
                                                            <block type="text" id="I:{$21YBMJ]!yY,6sx6o">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </statement>
                                                      <next>
                                                        <block type="telegram" id="_JowVE{OC7T1Yp%QsrWH">
                                                            <shadow type="text" id="5yMyM2ub5l0Z~{.nVh@F">
                                                            </shadow>
                                                            <block type="text_join" id="goMcz%ux:*Auwv`]cD3R">
                                                              <mutation items="26"></mutation>
                                                              <value name="ADD0">
        <block type="text_join" id=";i;r*8VtsMlyLXj,iV=U">
        <mutation items="6"></mutation>
        <value name="ADD0">
        <block type="text" id="T2#XlmrmlodP-i),_htm">
        <field name="TEXT">&lt;b&gt;&lt;u&gt;</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="t8_)H~RPIgys,KMM8dAT">
        <field name="TEXT">Das heutige Wetter am </field>
        </block>
        </value>
        <value name="ADD2">
        <block type="get_value" id="iGkDuQ,E=6oAP:2,u(AQ">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_1.Tag_value</field>
        </block>
        </value>
        <value name="ADD3">
        <block type="text" id="l,|CuNUp}[W;RI281_]V">
        <field name="TEXT"> dem </field>
        </block>
        </value>
        <value name="ADD4">
        <block type="time_get" id="IY@.ixSvx{o2$o30#r16">
        <field name="OPTION">DD.MM.YY</field>
        </block>
        </value>
        <value name="ADD5">
        <block type="text" id="totR%[vsua9H:{03)G.Y">
        <field name="TEXT">&lt;/u&gt;&lt;/b&gt;</field>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="ADD1">
        <block type="text_newline" id="9~l!Fie83=OJ0fyI[jD.">
        </block>
                                                              </value>
                                                              <value name="ADD2">
        <block type="text_newline" id=";*?=IR.~%9^WtR%XUn?^">
        </block>
                                                              </value>
                                                              <value name="ADD3">
        <block type="text" id="=g]i8(RUyv)u`9%^Gk6X">
        <field name="TEXT">&lt;b&gt;Übersicht:&lt;/b&gt;</field>
        </block>
                                                              </value>
                                                              <value name="ADD4">
        <block type="text_newline" id=",b,{0O?YAuu2c5u$[s?0">
        </block>
                                                              </value>
                                                              <value name="ADD5">
        <block type="text_join" id="L,?g=Y9rU2}ME_qGjA%$">
        <value name="ADD0">
        <block type="text" id="3wrb:K5e2b@!D0D#nGL:">
        <field name="TEXT">Max. Temp.       </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="get_value" id=":iePse]`rD,(=$Wd^Wzj">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_1.Maximale_Temperatur_value</field>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id=",Mo+pVZ0g|iT%RT;$/(-">
        <field name="TEXT">°C</field>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="ADD6">
        <block type="text_newline" id="-Upl}-d-85)Yj|zWeh:0">
        </block>
                                                              </value>
                                                              <value name="ADD7">
        <block type="text_join" id="(40fn2*0=-)DH$4U5dCC">
        <value name="ADD0">
        <block type="text" id="|54]AJ^5z#~]Gi#I2|fS">
        <field name="TEXT">Min. Temp.        </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="get_value" id="(:ucR([h7@OX{dG0lm2o">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_1.Minimale_Temperatur_value</field>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="-*7@{|UFF9%o;Y)$1A{r">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="ADD8">
        <block type="text_newline" id="Wyn.^jXQGs(18I,GRx/[">
        </block>
                                                              </value>
                                                              <value name="ADD9">
        <block type="variables_get" id="4W:sK$xXxZeea35%SB2F">
        </block>
                                                              </value>
        <block type="variables_get" id="4M5`C*}=[#,!BT6P9Hz_">
        </block>
                                                              </value>
        <block type="variables_get" id="@Dw5:7+*OLi0mJ@5)yzN">
        </block>
                                                              </value>
                                                              <value name="ADD12">
        <block type="variables_get" id="ejg%#V|q3_li%51u#1LV">
        </block>
                                                              </value>
                                                              <value name="ADD13">
        <block type="text_join" id="6MMZRV@gusO$S-qo?7x;">
        <mutation items="11"></mutation>
        <value name="ADD0">
        <block type="text" id="y-595$~MhBl5Uc4[ao|s">
        <field name="TEXT">Wind Tag:          </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="get_value" id="$7}$DIAgRgj@N#dt+_7J">
        <field name="OID">accuweather.0.Daily.Day1.Day.WindSpeed</field>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="cZ8:)-^}g(M)var+-v[8">
        <field name="TEXT"> km/h, Böhen </field>
        </block>
        </value>
        <value name="ADD3">
        <block type="get_value" id="=L)zyBwToAs,radExwvy">
        <field name="OID">accuweather.0.Daily.Day1.Day.WindGust</field>
        </block>
        </value>
        <value name="ADD4">
        <block type="text" id="hkW0+`i$}qSjiVQgca:^">
        <field name="TEXT"> km/h</field>
        </block>
        </value>
        <value name="ADD5">
        <block type="text_newline" id="((9@}QJ*YEX;RpK/BLOJ">
        </block>
        </value>
        <value name="ADD6">
        <block type="text" id="NlV@F7BoKn{jw3mNje$q">
        <field name="TEXT">Wind Nacht:      </field>
        </block>
        </value>
        <value name="ADD7">
        <block type="get_value" id="pAn@lK~HSB)}Gf|qgH:h">
        <field name="OID">accuweather.0.Daily.Day1.Night.WindSpeed</field>
        </block>
        </value>
        <value name="ADD8">
        <block type="text" id="~APt+HWKA*P{67#lv[0z">
        </block>
        </value>
        <value name="ADD9">
        <block type="get_value" id="jR_qKbN$Uz6x{7%3OZg~">
        <field name="OID">accuweather.0.Daily.Day1.Night.WindGust</field>
        </block>
        </value>
        <block type="text" id="7#WdZ7?HFOhuJVvJ-Emj">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="ADD14">
        <block type="text_newline" id="+U#m#+7d,N(zq)GoH,UU">
        </block>
                                                              </value>
                                                              <value name="ADD15">
        <block type="text_newline" id="fn:CB[=psD`31-q/Sq(q">
        </block>
                                                              </value>
                                                              <value name="ADD16">
        <block type="text" id="SND:6WtGc3{3wa%pGt4p">
        <field name="TEXT">&lt;b&gt;Am Tag:&lt;/b&gt;</field>
        </block>
                                                              </value>
                                                              <value name="ADD17">
        <block type="text_newline" id="9IPpVN=L,erDa4`~]@w6">
        </block>
                                                              </value>
                                                              <value name="ADD18">
        <block type="text_join" id="8|pR0k:s1pfl;7cSN)74">
        <value name="ADD0">
        <block type="get_value" id="z^QkVJgh)!b_OgEkx7M2">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_1.Wind_value</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="@C?rO:;*[@xuiz[N$S/f">
        <field name="TEXT">. </field>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="ADD19">
        <block type="text_newline" id=")yA#]!tJeS.brbz{fJ[y">
        </block>
                                                              </value>
                                                              <value name="ADD20">
        <block type="text_join" id="iU3]]qN]mSbG4RQ_BC(]">
        <value name="ADD0">
        <block type="get_value" id="-J]@;[UhtWwN9YoJ.ODl">
        <field name="OID">daswetter.0.NextDays.Location_1.Day_1.Wetterbedingungen_value</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="|KU~_Xh/b~K?hh-Rj%s/">
        <field name="TEXT">.</field>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="ADD21">
        <block type="text_newline" id="*}qVoGSjC4wDd{cG^x{b">
        </block>
                                                              </value>
                                                              <value name="ADD22">
        <block type="text" id="kX@OztB{DYRhBxy9swBP">
        <field name="TEXT">&lt;b&gt;Nachts:&lt;/b&gt;</field>
        </block>
                                                              </value>
                                                              <value name="ADD23">
        <block type="text_newline" id="@twt!c.}h+b67m2]$Yp$">
        </block>
                                                              </value>
                                                              <value name="ADD24">
        <block type="text_join" id="`b!N:0GZHhTcgNpg2~*J">
        <value name="ADD0">
        <block type="get_value" id="!*+23(q!2xH!dziS!lb]">
        <field name="OID">accuweather.0.Daily.Day1.Night.LongPhrase</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="text" id="Y4xn![JP{asLE+787f@1">
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="ADD25">
        <block type="text_newline" id="d[j;$oC=1sqv:cm:][AQ">
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </next>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                    <block type="variables_get" id="2tX}fIuGfXR:^h,U=rge" x="1238" y="1862">
                                      <field name="VAR" id="wU:WJBv/~A+RZE}xc~8^">Wetter abends und nachts</field>
                                    </block>
                                  </xml>
                                  Verwendet wird Accuwheather. Werte mit 0% Wahrscheinlichkeit werden nicht mit gesendet.
                                    @seiteballon74
                                    michaell
                                    @david-g Morgen, würdest du das Script zu der wöchentlichen Übersicht bereitstellen. Mich würde vor allem interessieren, wie du das mit den Wetter Emojis gemacht hast.
                                    • M michaell
                                      David G.D Online
                                      David G.D Online
                                      David G.
                                      @michaell
                                      Klar,
                                      anbei der Export.
                                      wochenuebersicht.txt
                                      Das Skribt ist bedingt durch das Wetter SEEEEHHHHR lang.
                                      Deshalb nur als txt.
                                      Benötigte Adapter:
                                      Wetter --> DasWetter-Adapter.
                                      Mülltermine --> TrashShedule
                                      Termine aus --> ical-Adapter
                                      M B 2 Antworten Letzte Antwort
                                        @michaell
                                        Klar,
                                        anbei der Export.
                                        Benötigte Adapter:
                                        michaell
                                        @david-g Sehr cool. Vielen Dank. Werde ich gleich mal ausprobieren.
                                          @michaell
                                          Klar,
                                          anbei der Export.
                                          Benötigte Adapter:
                                          Boeck
                                          @david-g sagte in TV Spielfilm Filme an Telegram senden:
                                          @michaell
                                          Klar,
                                          anbei der Export.
                                          Benötigte Adapter:
                                          das Skript ist super! Nur wird es bei mir nicht richtig dargestellt! Es sind überall Sonderzeichen vorhanden...
                                          Hier ein Auszug:
                                          <block type="procedures_defnoreturn" id="{$U+D3|wKA!isKhZBTTP" x="2687" y="-587">
                                          <field name="NAME">wetter_erstellen</field>
                                          <statement name="STACK">
                                          <block type="variables_set" id="HkhK{QjHn@;BDzcIa$">
                                          <field name="VAR" id=",/kFhL~sQ~@NB1BG{y~5">wetter_url_d2</field>
                                          <block type="get_value" id="7wK|:p^2y5|AG|$Wv.">
                                          <field name="OID">daswetter.0.NextDays.Location_1.Day_2.iconURL</field>
                                          </block>
                                          </value>
                                          <next>
                                          <block type="controls_if" id="E2B)TQGD37px8Ib.U:j">
                                          <mutation elseif="21"></mutation>
                                          <value name="IF0">
                                          <block type="logic_compare" id="s!8Ucq+_Mv%Z[Yg?X
                                          q6">
                                          <field name="OP">EQ</field>
                                          <value name="A">
                                          <block type="variables_get" id="RJT[%v27IVGG^IwKPZ=|">
                                          </block>
                                          Was ist da falsch bzw. kannst du das Skript bitte nochmal einstellen?
                                          Das TV Telegram Skript bekomme ich leider nicht ans laufen. Den Fehler habe ich aber noch nicht gefunden.
                                          Freue mich über diese Tollen anregungen hier :-)
                                          LG
                                          Boeck
                                          R D4vED 2 Antworten Letzte Antwort
