  4. [Gelöst] IOT Pro Lizenz Problem
    6.3k
lizenz iobroker
54 Beiträge 6 Kommentatoren 5.8k Aufrufe 5 Beobachtet
    @bass-t sagte in IOT Pro Lizenz Problem:
    gemacht, aber fehler bleibt
    Das war auch nicht anders zu erwarten.
    Bass-TB Offline
    Bass-TB Offline
    Bass-T
    @thomas-braun sagte in IOT Pro Lizenz Problem:
    LOL 🤣
    Proxmox Cluster
    • NUC7i5 ioBroker Server (Proxmox)
    • HP Elitedesk 800 G4 SSF (Proxmox)
    • HP Elitedesk 800 G2 DM (Proxmox)
      mein Proxmox-Updater für euch
    KNX / Broadlink / Tasmota ESPs / Zigbee
    Vis: 15" Touchmonitor mit Raspi4 / 10" Tablet (Dauerstrom umbau) / Sonoff NSPanel (alle)
    • Bass-TB Bass-T
      Jetzt geht nichts mehr, ...
      host.iobroker
      2022-01-02 14:21:52.561	error	instance system.adapter.iot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2022-01-02 14:21:52.561	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.iobroker
      2022-01-02 14:21:52.561	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.iobroker
      2022-01-02 14:21:52.561	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/remote.js:1:15)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.iobroker
      2022-01-02 14:21:52.560	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
      host.iobroker
      2022-01-02 14:21:52.559	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
      host.iobroker
      2022-01-02 14:21:52.559	error	Caught by controller[0]: SyntaxError: Unexpected token '.'
      host.iobroker
      2022-01-02 14:21:52.559	error	Caught by controller[0]: ^
      host.iobroker
      2022-01-02 14:21:52.559	error	Caught by controller[0]: const networkInterfaces = obj?.native?.hardware?.networkInterfaces;
      host.iobroker
      2022-01-02 14:21:52.558	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.iot/lib/Utils.js:218
      Adapter wird nicht mehr grün und Anmeldedaten kann ich nicht mehr aktualisieren :(
      URL Key in Datenpunkt bleibt bei (null)
      Auch nach sudo iobroker restart
      @bass-t Wie haste denn das jetzt hinbekommen? Welche nodejs Version?
      Bass-TB 1 Antwort Letzte Antwort
      • apollon77A apollon77
        Bass-TB Offline
        Bass-TB Offline
        Bass-T
        @apollon77 sagte in IOT Pro Lizenz Problem:
        v12.22.8
        bin noch nicht dazu gekommen auf 14 zu upgraden, ... sry
        Proxmox Cluster
        J apollon77A 2 Antworten Letzte Antwort
        • Bass-TB Bass-T
          v12.22.8
          Jan1
          @bass-t
          das dauert keine 5 Minuten ;)
          • Bass-TB Bass-T
            v12.22.8
            @bass-t Alles gut.
            ich wrde jetzt mal folgendes tun:kopier idir die iot Einstellungen, dann deinstallierst du die Instanz UND den Adapter. Danach neu installieren und neu einrichten. Dann Skill neu verknüpfen. Tut es so?
            • Meister MopperM Online
              Meister Mopper
              @bass-t Tatsächlich hatte ich das auch nach der Verlängerung der Pro-Lizenz.
              Ich habe allerdings keine certs oder Ähnliches neu angefordert und musste lediglich im google home assistant die Verbindung zum ioBroker erneuern (reconnect account) und mit den alten Zugangsdaten bestätigen.
              Das ist die übliche Vorgehensweise nach einer Verlängerung.
              Proxmox und HA ...
                Jan1
                @meister-mopper
                betrifft das nur Google? Ich habe Alexa und musst da noch nie was machen.
                • J Jan1
                  @meister-mopper
                  Meister Mopper
                  @jan1 sagte in IOT Pro Lizenz Problem:
                  K. A. ich hatte bisher nur google. Es passierte aber im vorvorigen Jahr genau so.
                  Proxmox und HA ...
                    Jan1
                    @meister-mopper
                    Ich habe diesmal wegen nem Hänger am PC versehentlich gleich zwei mal verlängert und lief einfach alles weiter wie vorher auch. Jetzt habe ich halt für 2 Jahre ne Lizenz :)
                    Bass-TB haselchenH 2 Antworten Letzte Antwort
                    • J Jan1
                      @meister-mopper
                      Bass-TB Offline
                      Bass-TB Offline
                      Bass-T
                      Bin leider gerade unterwegs. Werde das alles heute abend in ruhe versuchen.
                      Proxmox Cluster
                      • J Jan1
                        @meister-mopper
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @jan1
                        Gibt schlimmeres 😂
                          @bass-t Alles gut.
                          Bass-TB Offline
                          Bass-TB Offline
                          Bass-T
                          schrieb am zuletzt editiert von Bass-T
                          @bass-t Alles gut.
                          Genau das war auch meine idee, jedoch führte genau das zu den Fehlern in Post #15 (v1.8.25)
                          Proxmox Cluster
                          • Bass-TB Bass-T
                            @bass-t Alles gut.
                            @bass-t Also eine Neuinstallation der iot Adapters führt zu dem Problem das es nicht mehr tut?
                            • apollon77A Offline
                              Bitte nimm iot 1.8.24 ... ich glaube die 25 hat da ein Issue mit nodejs 12
                              Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                node 12
                                @Bass-T
                                Oder gleich den Sprung auf node14 machen. Ist ja eh die empfohlene Version.
                                  @apollon77 STOP!!!
                                  1.8.25 ist nicht das Problem ... wie hast du iot denn neu installiert? Sag bitte nicht über GitHub? Das wäre dann der Fehler. Nimm die 1.8.25 ganz normal
                                    node 12
                                    @Bass-T
                                    @thomas-braun In Dem Fall ist GitHub gerade "mitten in Entwicklung der nächsten Version" ... also nicht nutzen!
                                      @apollon77 Falscher Adressat. Ich nutze eigentlich nie github-Versionen.
                                      Das war wohl an @Bass-T gerichtet?
                                        Bass-TB Offline
                                        Bass-TB Offline
                                        Bass-T
                                        @thomas-braun und @apollon77
                                        Bringe jetzt erst meine Kids ins Bett.
                                        Dann node 14 und dann hatte ich tatsächlich via git installiert, ...
                                        Proxmox Cluster
                                        J Thomas BraunT 2 Antworten Letzte Antwort
                                        • Bass-TB Bass-T
                                          Jan1
                                          @bass-t
                                          Ich glaube die Schrift ist doch noch etwas zu klein und sollte auch blinken ;)
