  4. Adapter Update Alexa2. ERROR: Process exited with code 25
6 Beiträge 2 Kommentatoren 533 Aufrufe 1 Beobachtet
    MrPit
    schrieb am zuletzt editiert von MrPit
    Hi Leute,
    anbei die Popup Fehlermeldung beim Adapter Update, unten noch zusätzlich der die NPM LOG-File:
    Ist mein erster Post hier :). Falls Ihr noch mehr Input, Version nr etc. benötigt, bitte einfach kurz schreiben.
    $ iobroker upgrade alexa2@3.11.2
    Update alexa2 from @3.9.3 to @3.11.2
    NPM version: 8.1.4
    npm install iobroker.alexa2@3.11.2 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ENOTEMPTYnpm ERR! syscall renamenpm ERR! path /opt/iobroker/node_modules/alexa-remote2npm ERR! dest /opt/iobroker/node_modules/.alexa-remote2-kZSFkHDanpm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/alexa-remote2' -> '/opt/iobroker/node_modules/.alexa-remote2-kZSFkHDa'
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-01-02T13_54_26_506Z-debug.log
    host.iob Cannot install iobroker.alexa2@3.11.2: 217
    NPM Update Log-File :
    cat /home/iobroker/.npm/_logs/2022-01-02T13_54_26_506Z-debug.log
    0 verbose cli [
    0 verbose cli   '/usr/local/bin/node',
    0 verbose cli   '/usr/local/bin/npm',
    0 verbose cli   'install',
    0 verbose cli   'iobroker.alexa2@3.11.2',
    0 verbose cli   '--loglevel',
    0 verbose cli   'error',
    0 verbose cli   '--prefix',
    0 verbose cli   '/opt/iobroker'
    0 verbose cli ]
    1 info using npm@8.1.4
    2 info using node@v14.17.4
    3 timing npm:load:whichnode Completed in 2ms
    4 timing config:load:defaults Completed in 15ms
    5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 32ms
    6 timing config:load:builtin Completed in 33ms
    7 timing config:load:cli Completed in 98ms
    8 timing config:load:env Completed in 2ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 46ms
    10 timing config:load:project Completed in 49ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 11ms
    12 timing config:load:user Completed in 11ms
    13 timing config:load:file:/opt/iobroker/etc/npmrc Completed in 6ms
    14 timing config:load:global Completed in 7ms
    15 timing config:load:validate Completed in 10ms
    16 timing config:load:credentials Completed in 37ms
    17 timing config:load:setEnvs Completed in 34ms
    18 timing config:load Completed in 300ms
    19 timing npm:load:configload Completed in 310ms
    20 timing npm:load:setTitle Completed in 4ms
    21 timing npm:load:setupLog Completed in 19ms
    22 timing config:load:flatten Completed in 108ms
    23 timing npm:load:cleanupLog Completed in 77ms
    24 timing npm:load:configScope Completed in 0ms
    25 timing npm:load:projectScope Completed in 13ms
    26 timing npm:load Completed in 547ms
    27 timing arborist:ctor Completed in 13ms
    28 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
    29 timing idealTree:init Completed in 23333ms
    30 timing idealTree:userRequests Completed in 358ms
    31 silly idealTree buildDeps
    32 silly fetch manifest iobroker.alexa2@3.11.2
    33 http fetch GET 200 https://registry.npmjs.org/iobroker.alexa2 33382ms (cache miss)
    34 silly placeDep ROOT iobroker.alexa2@3.11.2 REPLACE for: iobroker.inst@2.0.3 want: 3.11.2
    35 silly fetch manifest alexa-remote2@^4.0.3
    36 silly fetch manifest https@^1.0.0
    37 silly fetch manifest @sentry/node@^6.13.3
    38 silly fetch manifest @sentry/integrations@^6.13.3
    39 http fetch GET 200 https://registry.npmjs.org/alexa-remote2 3200ms (cache miss)
    40 http fetch GET 200 https://registry.npmjs.org/@sentry%2fintegrations 3173ms (cache miss)
    41 http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 3219ms (cache miss)
    42 http fetch GET 200 https://registry.npmjs.org/https 3292ms (cache miss)
    43 timing idealTree:#root Completed in 37132ms
    44 silly placeDep ROOT @sentry/integrations@6.16.1 REPLACE for: iobroker.alexa2@3.11.2 want: ^6.13.3
    45 silly placeDep ROOT @sentry/node@6.16.1 REPLACE for: iobroker.alexa2@3.11.2 want: ^6.13.3
    46 silly placeDep ROOT alexa-remote2@4.1.1 OK for: iobroker.alexa2@3.11.2 want: ^4.0.3
    47 silly placeDep ROOT https@1.0.0 OK for: iobroker.alexa2@3.11.2 want: ^1.0.0
    48 silly fetch manifest @sentry/types@6.16.1
    49 silly fetch manifest @sentry/utils@6.16.1
    50 silly fetch manifest @sentry/core@6.16.1
    51 silly fetch manifest @sentry/hub@6.16.1
    52 silly fetch manifest @sentry/tracing@6.16.1
    53 silly fetch manifest alexa-cookie2@^4.0.1
    54 silly fetch manifest querystring@^0.2.1
    55 silly fetch manifest ws@^8.2.3
    56 silly fetch manifest uuid@^8.3.2
    57 http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 1571ms (cache miss)
    58 http fetch GET 200 https://registry.npmjs.org/@sentry%2fhub 1611ms (cache miss)
    59 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 1691ms (cache miss)
    60 http fetch GET 200 https://registry.npmjs.org/querystring 1801ms (cache miss)
    61 http fetch GET 200 https://registry.npmjs.org/alexa-cookie2 1838ms (cache miss)
    62 http fetch GET 200 https://registry.npmjs.org/@sentry%2ftracing 1881ms (cache miss)
    63 http fetch GET 200 https://registry.npmjs.org/uuid 1837ms (cache miss)
    64 http fetch GET 200 https://registry.npmjs.org/ws 1873ms (cache miss)
    65 http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 2020ms (cache miss)
    66 timing idealTree:node_modules/iobroker.alexa2 Completed in 2313ms
    67 silly placeDep ROOT @sentry/types@6.16.1 OK for: @sentry/integrations@6.16.1 want: 6.16.1
    68 silly placeDep ROOT @sentry/utils@6.16.1 OK for: @sentry/integrations@6.16.1 want: 6.16.1
    69 timing idealTree:node_modules/@sentry/integrations Completed in 90ms
    70 silly placeDep ROOT @sentry/core@6.16.1 OK for: @sentry/node@6.16.1 want: 6.16.1
    71 silly placeDep ROOT @sentry/hub@6.16.1 OK for: @sentry/node@6.16.1 want: 6.16.1
    72 silly placeDep ROOT @sentry/tracing@6.16.1 OK for: @sentry/node@6.16.1 want: 6.16.1
    73 silly fetch manifest @sentry/minimal@6.16.1
    74 http fetch GET 200 https://registry.npmjs.org/@sentry%2fminimal 1122ms (cache miss)
    75 timing idealTree:node_modules/@sentry/node Completed in 1378ms
    76 silly placeDep ROOT @sentry/minimal@6.16.1 OK for: @sentry/core@6.16.1 want: 6.16.1
    77 timing idealTree:node_modules/@sentry/core Completed in 36ms
    78 timing idealTree:node_modules/@sentry/hub Completed in 0ms
    79 timing idealTree:node_modules/@sentry/minimal Completed in 0ms
    80 timing idealTree:node_modules/@sentry/tracing Completed in 1ms
    81 timing idealTree:node_modules/@sentry/types Completed in 0ms
    82 timing idealTree:node_modules/@sentry/utils Completed in 0ms
    83 silly fetch manifest bufferutil@^4.0.1
    84 http fetch GET 200 https://registry.npmjs.org/bufferutil 96ms (cache miss)
    85 silly fetch manifest utf-8-validate@^5.0.2
    86 http fetch GET 200 https://registry.npmjs.org/utf-8-validate 187ms (cache miss)
    87 silly placeDep ROOT alexa-cookie2@4.0.1 OK for: alexa-remote2@4.1.1 want: ^4.0.1
    88 silly placeDep ROOT querystring@0.2.1 OK for: alexa-remote2@4.1.1 want: ^0.2.1
    89 silly placeDep node_modules/alexa-remote2 uuid@8.3.2 OK for: alexa-remote2@4.1.1 want: ^8.3.2
    90 silly placeDep node_modules/alexa-remote2 ws@8.4.0 OK for: alexa-remote2@4.1.1 want: ^8.2.3
    91 silly fetch manifest http-proxy-middleware@^2.0.1
    92 silly fetch manifest http-proxy-response-rewrite@^0.0.1
    93 http fetch GET 200 https://registry.npmjs.org/http-proxy-middleware 185ms (cache miss)
    94 http fetch GET 200 https://registry.npmjs.org/http-proxy-response-rewrite 866ms (cache miss)
    95 timing idealTree:node_modules/alexa-remote2 Completed in 1481ms
    96 silly placeDep ROOT http-proxy-middleware@2.0.1 OK for: alexa-cookie2@4.0.1 want: ^2.0.1
    97 silly placeDep ROOT http-proxy-response-rewrite@0.0.1 OK for: alexa-cookie2@4.0.1 want: ^0.0.1
    98 silly fetch manifest @types/http-proxy@^1.17.5
    99 silly fetch manifest http-proxy@^1.18.1
    100 silly fetch manifest is-plain-obj@^3.0.0
    101 silly fetch manifest micromatch@^4.0.2
    102 silly fetch manifest bufferhelper@^0.2.1
    103 http fetch GET 200 https://registry.npmjs.org/@types%2fhttp-proxy 315ms (cache miss)
    104 http fetch GET 200 https://registry.npmjs.org/micromatch 297ms (cache miss)
    105 http fetch GET 200 https://registry.npmjs.org/http-proxy 328ms (cache miss)
    106 http fetch GET 200 https://registry.npmjs.org/is-plain-obj 336ms (cache miss)
    107 http fetch GET 200 https://registry.npmjs.org/bufferhelper 959ms (cache miss)
    108 timing idealTree:node_modules/alexa-cookie2 Completed in 1097ms
    109 silly placeDep ROOT @types/http-proxy@1.17.8 OK for: http-proxy-middleware@2.0.1 want: ^1.17.5
    110 silly placeDep ROOT http-proxy@1.18.1 OK for: http-proxy-middleware@2.0.1 want: ^1.18.1
    111 silly placeDep ROOT is-plain-obj@3.0.0 OK for: http-proxy-middleware@2.0.1 want: ^3.0.0
    112 silly placeDep ROOT micromatch@4.0.4 OK for: http-proxy-middleware@2.0.1 want: ^4.0.2
    113 silly fetch manifest eventemitter3@^4.0.0
    114 http fetch GET 200 https://registry.npmjs.org/eventemitter3 120ms (cache miss)
    115 timing idealTree:node_modules/http-proxy-middleware Completed in 256ms
    116 timing idealTree:node_modules/@types/http-proxy Completed in 0ms
    117 silly placeDep ROOT eventemitter3@4.0.7 OK for: http-proxy@1.18.1 want: ^4.0.0
    118 timing idealTree:node_modules/http-proxy Completed in 26ms
    119 timing idealTree:node_modules/eventemitter3 Completed in 1ms
    120 silly placeDep ROOT bufferhelper@0.2.1 OK for: http-proxy-response-rewrite@0.0.1 want: ^0.2.1
    121 timing idealTree:node_modules/http-proxy-response-rewrite Completed in 38ms
    122 timing idealTree:node_modules/bufferhelper Completed in 0ms
    123 timing idealTree:node_modules/https Completed in 0ms
    124 timing idealTree:node_modules/is-plain-obj Completed in 0ms
    125 timing idealTree:node_modules/micromatch Completed in 0ms
    126 timing idealTree:node_modules/querystring Completed in 0ms
    127 timing idealTree:node_modules/alexa-remote2/node_modules/uuid Completed in 0ms
    128 timing idealTree:node_modules/alexa-remote2/node_modules/ws Completed in 0ms
    129 timing idealTree:buildDeps Completed in 43888ms
    130 timing idealTree:fixDepFlags Completed in 2108ms
    131 timing idealTree Completed in 69840ms
    132 timing reify:loadTrees Completed in 69847ms
    133 timing reify:diffTrees Completed in 329ms
    134 silly reify mark retired [ '/opt/iobroker/node_modules/alexa-remote2' ]
    135 silly reify mark retired [ '/opt/iobroker/node_modules/alexa-cookie2' ]
    136 silly reify mark retired [ '/opt/iobroker/node_modules/http-proxy-middleware' ]
    137 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.alexa2' ]
    138 silly reify mark retired [ '/opt/iobroker/node_modules/@sentry/core' ]
    139 silly reify mark retired [ '/opt/iobroker/node_modules/@sentry/hub' ]
    140 silly reify mark retired [ '/opt/iobroker/node_modules/@sentry/integrations' ]
    141 silly reify mark retired [ '/opt/iobroker/node_modules/@sentry/minimal' ]
    142 silly reify mark retired [ '/opt/iobroker/node_modules/@sentry/tracing' ]
    143 silly reify mark retired [ '/opt/iobroker/node_modules/@sentry/types' ]
    144 silly reify mark retired [ '/opt/iobroker/node_modules/@sentry/utils' ]
    145 silly reify mark retired [ '/opt/iobroker/node_modules/@sentry/node' ]
    146 silly reify mark retired [ '/opt/iobroker/node_modules/@types/http-proxy' ]
    147 silly reify moves {
    147 silly reify   '/opt/iobroker/node_modules/alexa-remote2': '/opt/iobroker/node_modules/.alexa-remote2-kZSFkHDa',
    147 silly reify   '/opt/iobroker/node_modules/alexa-cookie2': '/opt/iobroker/node_modules/.alexa-cookie2-yH4YGJkw',
    147 silly reify   '/opt/iobroker/node_modules/http-proxy-middleware': '/opt/iobroker/node_modules/.http-proxy-middleware-sWmIfRvF',
    147 silly reify   '/opt/iobroker/node_modules/iobroker.alexa2': '/opt/iobroker/node_modules/.iobroker.alexa2-qF1nHAGP',
    147 silly reify   '/opt/iobroker/node_modules/@sentry/core': '/opt/iobroker/node_modules/@sentry/.core-8aLh8ekZ',
    147 silly reify   '/opt/iobroker/node_modules/@sentry/hub': '/opt/iobroker/node_modules/@sentry/.hub-qVWa7JYS',
    147 silly reify   '/opt/iobroker/node_modules/@sentry/integrations': '/opt/iobroker/node_modules/@sentry/.integrations-oUb3aaur',
    147 silly reify   '/opt/iobroker/node_modules/@sentry/minimal': '/opt/iobroker/node_modules/@sentry/.minimal-RfCkvQXI',
    147 silly reify   '/opt/iobroker/node_modules/@sentry/tracing': '/opt/iobroker/node_modules/@sentry/.tracing-iu5u8Scf',
    147 silly reify   '/opt/iobroker/node_modules/@sentry/types': '/opt/iobroker/node_modules/@sentry/.types-aFtRyDms',
    147 silly reify   '/opt/iobroker/node_modules/@sentry/utils': '/opt/iobroker/node_modules/@sentry/.utils-hx1Gtaez',
    147 silly reify   '/opt/iobroker/node_modules/@sentry/node': '/opt/iobroker/node_modules/@sentry/.node-fcFhT34r',
    147 silly reify   '/opt/iobroker/node_modules/@types/http-proxy': '/opt/iobroker/node_modules/@types/.http-proxy-W5B8m9CF'
    147 silly reify }
    148 timing reify:rollback:retireShallow Completed in 33ms
    149 timing command:install Completed in 70398ms
    150 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/alexa-remote2' -> '/opt/iobroker/node_modules/.alexa-remote2-kZSFkHDa'
    151 verbose cwd /opt/iobroker
    152 verbose Linux 5.10.63-v7l+
    153 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.alexa2@3.11.2" "--loglevel" "error" "--prefix" "/opt/iobroker"
    154 verbose node v14.17.4
    155 verbose npm  v8.1.4
    156 error code ENOTEMPTY
    157 error syscall rename
    158 error path /opt/iobroker/node_modules/alexa-remote2
    159 error dest /opt/iobroker/node_modules/.alexa-remote2-kZSFkHDa
    160 error errno -39
    161 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/alexa-remote2' -> '/opt/iobroker/node_modules/.alexa-remote2-kZSFkHDa'
    162 verbose exit -39
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Raspberry 4.
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte 256GB Transcend 256GB microSDXC/SDHC 300S Speicherkarte TS256GUSD300S inklusive SD-Adapter
    Betriebssystem / Iobroker Version: IOBROKER: V3.3.22
    Node-Version: 10.x.x
    Nodejs-Version: v14.17.4
    NPM-Version: 8.1.4
    Installationsart: Image Auto update
    Image genutzt: JA
    Ort/Name der Imagedatei: Link
    • M MrPit
      Hi Leute,
      NPM version: 8.1.4
      0 verbose cli [
      0 verbose cli ]
      147 silly reify }
      160 error errno -39
      NPM-Version: 8.1.4
      Image genutzt: JA
      @mrpit sagte in Adapter Update Alexa2. ERROR: Process exited with code 25:
      Bitte Ausfüllen
      Und genauere Fehlerbeschreibung bitte.
      • M MrPit
        Hi Leute,
        NPM version: 8.1.4
        0 verbose cli [
        0 verbose cli ]
        147 silly reify }
        160 error errno -39
        NPM-Version: 8.1.4
        Image genutzt: JA
        Nodejs-Version:
        v14.17.4
        NPM-Version:
        8.1.4
        seufz Wie schafft man das eigentlich immer?
        nodeJS falsch installiert. Schau in meiner Signatur wie es richtig geht.
        M 2 Antworten Letzte Antwort
          Nodejs-Version:
          v14.17.4
          NPM-Version:
          8.1.4
          MrPit
          ok danke Thomas. Versuche es gleich
            Nodejs-Version:
            v14.17.4
            NPM-Version:
            8.1.4
            MrPit
            Hab nun, denke ich, die richtige nodejs und npm Versionen:
            /opt/iobroker/iobroker-data/zigbee_0 $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            #v14.18.2
            v14.18.2
            6.14.15
            Leider bei Alexa2 Update nun andere Fehler :-
            Alexa2 (Amazon Echo)
            Verfügbare Version:
            3.11.2
            Installierte Version:
            3.9.3
            ERROR:
            NPM version: 6.14.15npm install iobroker.alexa2@3.11.2 --loglevel error --prefix "/opt/iobroker" (System call)
            npm ERR! Error while executing:npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/TA2k/ioBroker.lg-thinq.gitnpm ERR! npm ERR! Host key verification failed.npm ERR! fatal: Could not read from remote repository.npm ERR! npm ERR! Please make sure you have the correct access rightsnpm ERR! and the repository exists.npm ERR! npm ERR! exited with error code: 128
            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-01-03T12_41_43_684Z-debug.log
            upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
            upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
            upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
            upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
            upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
            upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
            upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
            upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
            upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
            upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
            upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
            upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
            upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
            upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
            upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot.png icons/echo_dot.png image/png
            upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo4.png icons/echo4.png image/png
            upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo2.png icons/echo2.png image/png
            upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo.png icons/echo.png image/png
            upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo-input.png icons/echo-input.png image/png
            upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/apps.png icons/apps.png image/png
            upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
            Adapter "alexa2" updated
            Process exited with code 0
            • M MrPit
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              #v14.18.2
              v14.18.2
              6.14.15
              Verfügbare Version:
              3.11.2
              3.9.3
              ERROR:
              Sollte jetzt passen.
              Den lg-thinq solltest du aus latest fischen, nicht aus git:
              lg-thinq
              github:	0.0.2
              latest:	0.0.3 for 4 days
              stable:	-.-.-
