  5. Zeitdifferenz berechnen
    6.4k
blockly
106 Beiträge 20 Kommentatoren 29.2k Aufrufe 24 Beobachtet
    @patrickfro sagte: Jede Wertänderung
    Vorschlag:
     <variables>
       <variable id="P4J/pC!qmBM/1Z__aRWg">cnt</variable>
       <variable id="xE-PO6fl5.;X+JU}_9rQ">Zeitdifferenz in ms</variable>
       <variable type="timeout" id="timeout">timeout</variable>
     </variables>
     <block type="variables_set" id="d/jNs%DT4J/1*l?SN03^" x="63" y="13">
       <field name="VAR" id="P4J/pC!qmBM/1Z__aRWg">cnt</field>
       <value name="VALUE">
         <block type="math_number" id="brpfPFO4,hfnn0rb%N^C">
           <field name="NUM">0</field>
         </block>
       </value>
       <next>
         <block type="on" id="jK!Srf4|s?My,i]Z?.e_">
           <field name="OID">zigbee.1.00158d000799f9ae.opened</field>
           <statement name="STATEMENT">
             <block type="variables_set" id="zqFe_u[sWLj;+]dMW##1">
               <field name="VAR" id="xE-PO6fl5.;X+JU}_9rQ">Zeitdifferenz in ms</field>
                 <block type="math_arithmetic" id="MQ6nN[*zAT8GVfWg1;-O" inline="false">
                   <value name="A">
                     <shadow type="math_number" id="uvD{f=e]!:O/B,9ALM*y">
                       <field name="NUM">1</field>
                     </shadow>
                     <block type="on_source" id="93mqKHm(M`hLmElkJQ5S">
                       <field name="ATTR">state.lc</field>
                     </block>
                   </value>
                   <value name="B">
                     <shadow type="math_number" id="Bz#Vj4[#pNfW8n`Wr+[m">
                     </shadow>
                     <block type="on_source" id="^rsOSwuTg[J@hdSSu2~l">
                       <field name="ATTR">oldState.lc</field>
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="controls_if" id="Y%_)H%AK@R)fvL,aB4D$">
                   <value name="IF0">
                     <block type="logic_negate" id=":?FlLsbYm{.zN-[bZ)g^">
                       <value name="BOOL">
                         <block type="variables_get" id="]0?!t;E9Hq~?)pwd+#WM">
                           <field name="VAR" id="timeout" variabletype="timeout">timeout</field>
                         </block>
                       </value>
                     </block>
                   </value>
                   <statement name="DO0">
                     <block type="timeouts_settimeout" id="-@~Mtif+cgDPP[L:r-Nh">
                       <field name="DELAY">20</field>
                         <block type="variables_set" id="/ZG17;!yVU9?#U@ow`cc">
                             <block type="math_number" id="P|Z3akKr[K_Tu:s~krie">
                             </block>
                           </value>
                           <next>
                             <block type="variables_set" id="}re]Vg2D?(?fU^.|grmh">
                                 <block type="logic_null" id="o}f]#}r:KRbuDc?O|jBb"></block>
                               </value>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </statement>
                   <next>
                     <block type="comment" id="dKTi=DXeE:d~t:`oElVJ">
                       <field name="COMMENT">Zeitdifferenz darf maximal &lt;10 Sekunden sein</field>
                       <next>
                         <block type="controls_if" id="HMVL(8UgPCqNF2+seN/5">
                           <value name="IF0">
                             <block type="logic_compare" id=":GPAg!:7I%ju?fd)KX0E">
                               <field name="OP">LT</field>
                               <value name="A">
                                 <block type="variables_get" id="SROQT(0H9:`1U/|,B7Fc">
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="math_number" id="0unIA@)v2Q~w@0CT[C%F">
                                   <field name="NUM">10000</field>
                                 </block>
                               </value>
                             </block>
                           </value>
                             <block type="math_change" id="FiiU:QQ/R^C;+(/wf]vt">
                               <value name="DELTA">
                                 <shadow type="math_number" id="+Anx@MLF)~l?PXLWmm;(">
                                 </shadow>
                               </value>
                               <next>
                                 <block type="controls_if" id=":rgk1rFp!Sf@d6G86`4P">
                                   <value name="IF0">
                                     <block type="logic_operation" id="6XTSj{c@b[/og!~-lyx=" inline="false">
                                       <field name="OP">AND</field>
                                       <value name="A">
                                         <block type="logic_compare" id="-M|#UyHG+Q)0o$L$Vafr">
                                           <field name="OP">GT</field>
                                           <value name="A">
                                             <block type="variables_get" id="brKuBe9M`3K..voGI.nf">
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="math_number" id="GVx0yXUe6}Rad10Qz#/~">
                                               <field name="NUM">2</field>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <value name="B">
                                         <block type="logic_compare" id="{p,x[K=9#5HqN6]e4/;8">
                                           <field name="OP">EQ</field>
                                           <value name="A">
                                             <block type="get_value" id="~`RyQBMVd+],i;a3%/Ou">
                                               <field name="OID">0_userdata.0.Hometrainer_Skripte.Aussetzung_Benachrichtigungen</field>
                                             </block>
                                           </value>
                                           <value name="B">
                                             <block type="logic_boolean" id="At+vP+3x:dXo*226VG:1">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                     <block type="update" id="x]/[eU$U^~U?E~Yb%2Z)">
                                         <block type="logic_boolean" id="i.NxT_cZm:D3pDq|nfYY">
                                         </block>
                                       </value>
                                       <next>
                                         <block type="update" id="CqBYKGD%HdGVtp.D-`=}">
                                           <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="true"></mutation>
                                           <field name="DELAY_MS">2</field>
                                           <field name="UNIT">min</field>
                                             <block type="logic_boolean" id="U6f`+?oKBw0xTIG*|lsb">
                                             </block>
                                           </value>
                                           <next>
                                             <block type="telegram" id="pB:;!`u9TxYb{eB+GSJO">
                                               <field name="LOG"></field>
                                               <value name="MESSAGE">
                                                 <shadow type="text" id="`w]AkcjR$}Tus_1HsmPo">
                                                   <field name="TEXT">Testnachricht: Kurbeln längere Zeit gedreht</field>
                                                 </shadow>
                                               </value>
                                               <value name="USERNAME">
                                                 <block type="text" id="%?/-9(?N0.HXoD4gOL:l">
                                                   <field name="TEXT">Patrick</field>
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
    </xml>
    PatrickFro
    @paul53 Super, vielen Dank.
    Ich glaube, ich habe mich unglücklich ausgedrückt.
    Bei Start des möglichen Trainings, also der auf/zu-Schaltung, soll nicht sofort eine Benachrichtigung per Telegram kommen. Nach den ersten 20 Sekunden soll geschaut werden, ob innerhalb der letzten 10 Sekunden eine Bewegung, also eine auf/zu-Schaltung passierte. Ob danach weitere Schaltungen registriert werden, ist egal. Eine Benachrichtigung per Telegram erfolgt nur einmalig, wenn nach erster Schaltung weitere folgen. Nach der ersten Benachrichtigung ist eine Sperre von 60 Minuten (ich habe aus Testgründen 2 Minuten eingetragen). Würde die Aktion länger als eine Stunde durchgeführt werden, so erhielte ich eben eine weitere Nachricht.
    Ich hoffe, das ist verständlicher. Es soll also geprüft werden, ob die fortlaufenden Schaltungen nur sehr kurz (<10 Sekunden) oder länger (> 10 Sekunden) durchgeführt werden.
    • P PatrickFro
      @patrickfro sagte: Nach den ersten 20 Sekunden soll geschaut werden, ob innerhalb der letzten 10 Sekunden eine Bewegung, also eine auf/zu-Schaltung passierte.
      Dann versuche es mal so:
       <variables>
       </variables>
       <block type="on" id="jK!Srf4|s?My,i]Z?.e_" x="63" y="41">
               <block type="math_arithmetic" id="MQ6nN[*zAT8GVfWg1;-O">
                 <value name="A">
                   </shadow>
                   <block type="on_source" id="y=]AFt2r|~27tDV]yONe">
                   </block>
                 </value>
                 <value name="B">
                   </shadow>
                   </block>
                 </value>
               </block>
             </value>
             <next>
                 <value name="IF0">
                   <block type="logic_negate" id="]`I~gk6?fLvb}jm+$u5`">
                     <value name="BOOL">
                       </block>
                     </value>
                   </block>
                 </value>
                       </block>
                     </value>
                     <next>
                           </block>
                         </value>
                         <next>
                                 <next>
                                     <value name="IF0">
                                         <value name="A">
                                           </block>
                                         </value>
                                         <value name="B">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                           </shadow>
                                         </value>
                                           </block>
                                         </value>
                                       </block>
                                     </statement>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
         </statement>
       </block>
      </xml>
      P 1 Antwort Letzte Antwort
         <variables>
         </variables>
                   <value name="A">
                     </shadow>
                     </block>
                   </value>
                   <value name="B">
                     </shadow>
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                   <value name="IF0">
                       <value name="BOOL">
                         </block>
                       </value>
                     </block>
                   </value>
                         </block>
                       </value>
                       <next>
                             </block>
                           </value>
                           <next>
                                   <next>
                                       <value name="IF0">
                                           <value name="A">
                                             </block>
                                           </value>
                                           <value name="B">
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                             </shadow>
                                           </value>
                                             </block>
                                           </value>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </statement>
                 </block>
               </next>
             </block>
           </statement>
         </block>
        </xml>
        PatrickFro
        schrieb am zuletzt editiert von PatrickFro
        @paul53 Vielen Dank für die Arbeit.
        Ich bin gerade "schon" auf eine Lösung gekommen. Dein erster Code hat mir mit etwas Zeitversatz viel gebracht. Ich achte nun nicht mehr auf die Zeit, sondern nutze die "erhöhe um"-Funktion.
        Danke nochmal
          @matthias-i sagte: Mein Plan ist deshalb den Zeitplan des Mähroboters zu erweitern, ihn aber nur dann mähen zu lassen, wenn die wöchentliche max. Mähzeit nicht überschritten ist und ihn bei unterschreiten einer minimalen Mähzeit am Wochenende auch außerhalb des Zeitplans mähen zulassen, um "Mähzeit nachzuholen".
          Der Aussage entnehme ich, dass es um die wöchentliche Mäh-Dauer geht? Das Prinzip der Kumulation der Mäh-Dauer habe ich schon hier gezeigt (es wird mit ms gerechnet). Einmal in der Woche muss dann per Zeitplan die Mäh-Dauer zurück gesetzt werden. Unter der Woche kann die schon erreichte Mäh-Dauer ausgewertet werden.
          erazor86
          @paul53 said in Zeitdifferenz berechnen:
          Hallo, Ich habe das blockly für die Laufzeit meiner Lüftungsanlage genutzt. Allerdings habe ich es auf eine Tagesauswertung geändert. D.h. jeden Abend um 0 Uhr wird der Wert genullt.
          Das Blockly ist bis auf den Trigger für mich nachvollziehbar. Ich verstehe die Auflösung "ist kleiner als letztes" in dem Zusammenhang nicht... Jede andere Auslösung funktioniert hingegen nicht..
          Was mich etwas stört, ist dass der Wert nicht live aktualisiert wird... Wenn also die Anlage 4 Stunden ohne Stillstand läuft, werden die 4 Stunden erst nach der ersten Unterbrechung geschrieben. Was müsste ich ändern, wenn der Wert der tatsächlichen Laufzeit, alle 5 min aktualisiert wird?
          • E erazor86
            @erazor86 sagte: Ich verstehe die Auflösung "ist kleiner als letztes" in dem Zusammenhang nicht... Jede andere Auslösung funktioniert hingegen nicht..
            Triggert beim Ausschalten (Änderung true --> false).
            @erazor86 sagte in Zeitdifferenz berechnen:
            Trigger auf "wurde geändert" und mit Einschalten ein 5-Minuten-Intervall starten, das beim Ausschalten gestoppt wird.
            E 1 Antwort Letzte Antwort
              erazor86
              Danke für die Infos.
              Ich habe die Änderung mit dem Intervall getestet, leider wird die Zeit aber nicht korrekt summiert... hast du eine Idee wo der Fehler liegt?
                <variables>
                  <variable id="-8jUk([-^/E4KtM^jFpH">Einschaltdauer</variable>
                  <variable type="interval" id="Intervall">Intervall</variable>
                </variables>
                <block type="on_ext" id="$kEbY#R6hv*pK~*3s7f~" x="-137" y="-887">
                  <value name="OID0">
                    <shadow type="field_oid" id="]RDHZN_H_)V(`JXk!Elr">
                      <field name="oid">shelly.0.SHSW-PM#76B4A1#1.Relay0.Power</field>
                    </shadow>
                  </value>
                    <block type="controls_if" id="Z1deQeC:Wf9EFWSp*9d.">
                      <value name="IF0">
                        <block type="logic_compare" id="Und_gySW1{EKGEii[HCF">
                          <value name="A">
                            <block type="get_value" id="||QIbPAQe`%W;0wg-{?#">
                              <field name="OID">shelly.0.SHSW-PM#76B4A1#1.Relay0.Power</field>
                            </block>
                          </value>
                          <value name="B">
                            <block type="math_number" id="HqE;j0Kf4sCPS7;z?]Q^">
                              <field name="NUM">30</field>
                            </block>
                          </value>
                        </block>
                      </value>
                        <block type="control" id="[,#g!m*(]K+img?eH=QG">
                          <field name="OID">0_userdata.0.Datenpunkte.Rechengrößen.Lüftung</field>
                            <block type="logic_boolean" id="^Ac4Kzc_h}0.obCgF:E|">
                            </block>
                          </value>
                        </block>
                      </statement>
                      <value name="IF1">
                        <block type="logic_compare" id="6KG7eQnX[B.%@aRx=z9d">
                          <value name="A">
                            <block type="get_value" id="=F75;y^mPd(wsy0hYvB`">
                            </block>
                          </value>
                          <value name="B">
                            <block type="math_number" id="/!c,7EU$*|vt)O4#EhMu">
                            </block>
                          </value>
                        </block>
                      </value>
                      <statement name="DO1">
                        <block type="control" id="mJ:W^[k+%f!(T#!`:)qC">
                            <block type="logic_boolean" id="gFpUSs2H!_esXCo(IRSp">
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
                <block type="variables_set" id=")vn_uk6$xwFtS;?LfqDk" x="-137" y="-588">
                  <field name="VAR" id="-8jUk([-^/E4KtM^jFpH">Einschaltdauer</field>
                    <block type="get_value" id="lxYUqLH.{;ScEd8_W{^t">
                      <field name="OID">0_userdata.0.Datenpunkte.Rechengrößen.Dauer</field>
                    </block>
                  </value>
                  <next>
                    <block type="on_ext" id="g10!%+,PQcoL^1CtCc1M">
                      <field name="CONDITION">true</field>
                      <value name="OID0">
                        <shadow type="field_oid" id="1^6dn_Y//1Ld.:S1*pg/">
                          <field name="oid">0_userdata.0.Datenpunkte.Rechengrößen.Lüftung</field>
                        </shadow>
                      </value>
                        <block type="timeouts_setinterval" id="F%|n+bdyr1u[T$eOo-O+">
                          <field name="NAME">Intervall</field>
                          <field name="INTERVAL">1</field>
                            <block type="math_change" id="W|~lE[Qwmq@OL@N)v/_4">
                                <shadow type="math_number" id="fWsz,$6i4tL0Y7%pNn7F">
                                </shadow>
                                <block type="math_arithmetic" id="8dbw%mT9A/DW6~o1_^,q" inline="false">
                                  <value name="A">
                                    <shadow type="math_number" id="{,*U53G|oL{_f}d)G^$*">
                                    </shadow>
                                    <block type="on_source" id="TK$!iiMRM!%JRabhC~fo">
                                    </block>
                                  </value>
                                  <value name="B">
                                    <shadow type="math_number" id="9`6U/6qXEXc(}AK3z5/:">
                                    </shadow>
                                    <block type="on_source" id="MDsgyx~9/!NR^RbOGcUb">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                <block type="update" id="+zK*btZIiTCUL)S.~[8D">
                                    <block type="variables_get" id="5wD}KRR8({98*0W6r6o}">
                                    </block>
                                  </value>
                                  <next>
                                    <block type="update" id="g}hdq5eRT$=;qHw^zDv@">
                                        <block type="convert_from_date" id="5zYzKU@-kYT+vYrXHim~">
                                          <field name="OPTION">hh:mm:ss</field>
                                            <block type="math_arithmetic" id="de6Osb3N2jOv]1ZE8LKs">
                                              <field name="OP">ADD</field>
                                              <value name="A">
                                                <shadow type="math_number" id="L,;}sdh*6EgE2`Me1YYz">
                                                </shadow>
                                                <block type="variables_get" id="?OEdL._f`+/(Z.!r^}`O">
                                                </block>
                                              </value>
                                              <value name="B">
                                                <shadow type="math_number" id="v|/~JK[UhMh,%Mn!Xgh9">
                                                </shadow>
                                                <block type="convert_from_date" id="K:i9{k,$dbC{cRF0m%/e">
                                                  <field name="OPTION">object</field>
                                                    <block type="text" id="qhKVkD25/vl9XM(CX`Q0">
                                                      <field name="TEXT">1970-01-01 00:00</field>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </statement>
                      <next>
                        <block type="timeouts_clearinterval" id="PJ51GE9hrAOoR{osIItE">
                          <next>
                            <block type="schedule" id="|kytfE5cp$@M5Mjr?=aH">
                              <field name="SCHEDULE">0 0 * * *</field>
                                <block type="variables_set" id="eS9Yhju/DoLFarLL^QXj">
                                    <block type="math_number" id="50RLcx#=~4Lt|(*Ts50@">
                                    </block>
                                  </value>
                                  <next>
                                    <block type="update" id="Ldq+96Oy#$LhNj2?O@o+">
                                        <block type="math_number" id="VAB-z1%//`0bxPwp14r,">
                                        </block>
                                      </value>
                                      <next>
                                        <block type="update" id="O-+G9zJ.R4,~Y8b,(n+!">
                                            <block type="text" id="8jFlvBl*%rTvcjRF;3^l">
                                              <field name="TEXT">00:00:00</field>
                                            </block>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </next>
                                </block>
                              </statement>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </xml>
              • E erazor86
                  <variables>
                  </variables>
                    <value name="OID0">
                      </shadow>
                    </value>
                        <value name="IF0">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                        <value name="IF1">
                            <value name="A">
                              </block>
                            </value>
                            <value name="B">
                              </block>
                            </value>
                          </block>
                        </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                      </block>
                    </value>
                    <next>
                        <value name="OID0">
                          </shadow>
                        </value>
                                  </shadow>
                                    <value name="A">
                                      </shadow>
                                      </block>
                                    </value>
                                    <value name="B">
                                      </shadow>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                      </block>
                                    </value>
                                    <next>
                                                <value name="A">
                                                  </shadow>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </shadow>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </statement>
                        <next>
                            <next>
                                      </block>
                                    </value>
                                    <next>
                                          </block>
                                        </value>
                                        <next>
                                              </block>
                                            </value>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </xml>
                @erazor86 Man kann nicht den gleichen Datenpunkt für einen String ("SS:mm:ss") und auch für die Zeitdifferenz in ms verwenden. Das müssen verschiedene Datenpunkte sein.
                Versuche es mal hiermit:
                 <variables>
                   <variable id=".M;hWc%-tKkr1@W+1LrA">aktuelleED</variable>
                 </variables>
                   <value name="OID0">
                     </shadow>
                   </value>
                           <value name="A">
                             </block>
                           </value>
                           <value name="B">
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </statement>
                   <next>
                     <block type="variables_set" id=")vn_uk6$xwFtS;?LfqDk">
                         <block type="math_arithmetic" id="|OpM`7r4*#g{V(atOXeP" inline="false">
                           <value name="A">
                             <shadow type="math_number" id="b]+0ib3EcZ~2_oMcuWye">
                             </shadow>
                             <block type="convert_from_date" id="R366`43-0$M-yx[Ho$-S">
                                 </block>
                               </value>
                             </block>
                           </value>
                           <value name="B">
                             <shadow type="math_number" id="Maco,i~T7aXgM%`$#ZH=">
                             </shadow>
                             <block type="convert_from_date" id="iZ|uy?-0G:C=QT{p_G.Y">
                                 <block type="text" id="/JUQfzjSZ0|9RZsQqyYE">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                           <value name="OID0">
                             </shadow>
                           </value>
                             <block type="controls_if" id=".PO:1M;FRU?d].Nd5sPc">
                               <value name="IF0">
                                 <block type="on_source" id="W+aPPoh~~slVC@YQcf;@">
                                 </block>
                               </value>
                                 <block type="variables_set" id="!OE$Ko{1N9#?t.4BPSg,">
                                   <field name="VAR" id=".M;hWc%-tKkr1@W+1LrA">aktuelleED</field>
                                     <block type="math_number" id="Re%ze)=eXwGl[S84%(G#">
                                     </block>
                                   </value>
                                   <next>
                                         <block type="math_change" id="4`4wkv(iK;LhA;jCuNZL">
                                             <shadow type="math_number" id="m4-Y_9;xuDdomh3@HwQ}">
                                               <field name="NUM">60000</field>
                                             </shadow>
                                           </value>
                                           <next>
                                                 <block type="convert_from_date" id="lFVMWNt-~#geUqV:%$YI">
                                                     <block type="math_arithmetic" id="Y,Wo/G)odmv`):~[qQBc">
                                                       <value name="A">
                                                         <shadow type="math_number" id="CnZ2|N^8d|}1:oyCMS2I">
                                                         </shadow>
                                                         <block type="math_arithmetic" id="FGgA^p;#:H7W;hU-LpHs">
                                                           <value name="A">
                                                             <shadow type="math_number" id=".=cyKFyxrA=s-Wk4Wwt#">
                                                             </shadow>
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <shadow type="math_number" id="5|iqT4XOgkKp4XTFP_,S">
                                                             </shadow>
                                                             <block type="variables_get" id="%eY8G+BT{E$3`DI:)sGp">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         <shadow type="math_number" id="bnO%l+X9Gx/_M)S,d7[g">
                                                         </shadow>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </statement>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                               <statement name="ELSE">
                                 <block type="timeouts_clearinterval" id="ii#;LBc`SXmzlL?)5[0h">
                                   <next>
                                         </shadow>
                                           <value name="A">
                                             </shadow>
                                             </block>
                                           </value>
                                           <value name="B">
                                             </shadow>
                                             </block>
                                           </value>
                                         </block>
                                       </value>
                                       <next>
                                                   <value name="A">
                                                     </shadow>
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     </shadow>
                                                     <block type="convert_from_date" id="7vdBgw4zJVyR%+9o0iuW">
                                                         <block type="text" id="kNJ7`:@%CLI`KBJ:(peF">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                           </statement>
                           <next>
                                     </block>
                                   </value>
                                   <next>
                                         </block>
                                       </value>
                                     </block>
                                   </next>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
                </xml>
                E 2 Antworten Letzte Antwort
                   <variables>
                   </variables>
                     <value name="OID0">
                       </shadow>
                     </value>
                             <value name="A">
                               </block>
                             </value>
                             <value name="B">
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </statement>
                     <next>
                             <value name="A">
                               </shadow>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="B">
                               </shadow>
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                         <next>
                             <value name="OID0">
                               </shadow>
                             </value>
                                 <value name="IF0">
                                   </block>
                                 </value>
                                       </block>
                                     </value>
                                     <next>
                                               </shadow>
                                             </value>
                                             <next>
                                                         <value name="A">
                                                           </shadow>
                                                             <value name="A">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               </shadow>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                         <value name="B">
                                                           </shadow>
                                                               </block>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </next>
                                           </block>
                                         </statement>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                                     <next>
                                           </shadow>
                                             <value name="A">
                                               </shadow>
                                               </block>
                                             </value>
                                             <value name="B">
                                               </shadow>
                                               </block>
                                             </value>
                                           </block>
                                         </value>
                                         <next>
                                                     <value name="A">
                                                       </shadow>
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </shadow>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                               </block>
                                             </value>
                                           </block>
                                         </next>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                               </block>
                             </statement>
                             <next>
                                       </block>
                                     </value>
                                     <next>
                                           </block>
                                         </value>
                                       </block>
                                     </next>
                                   </block>
                                 </statement>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                  </xml>
                  erazor86
                  @paul53 es funktioniert 👍 super und besten Dank... auch wenn ich noch nicht ganz durch steige ;) muss ich mir nochmal in einer ruhigen Minute zu Gemüte führen ;)
                     <variables>
                     </variables>
                       <value name="OID0">
                         </shadow>
                       </value>
                               <value name="A">
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                         </block>
                       </statement>
                       <next>
                               <value name="A">
                                 </shadow>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 </shadow>
                                     </block>
                                   </value>
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                               <value name="OID0">
                                 </shadow>
                               </value>
                                   <value name="IF0">
                                     </block>
                                   </value>
                                         </block>
                                       </value>
                                       <next>
                                                 </shadow>
                                               </value>
                                               <next>
                                                           <value name="A">
                                                             </shadow>
                                                               <value name="A">
        </shadow>
        </block>
                                                               </value>
                                                               <value name="B">
        </shadow>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             </shadow>
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </next>
                                             </block>
                                           </statement>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                       <next>
                                             </shadow>
                                               <value name="A">
                                                 </shadow>
                                                 </block>
                                               </value>
                                               <value name="B">
                                                 </shadow>
                                                 </block>
                                               </value>
                                             </block>
                                           </value>
                                           <next>
                                                       <value name="A">
                                                         </shadow>
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         </shadow>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                 </block>
                               </statement>
                               <next>
                                         </block>
                                       </value>
                                       <next>
                                             </block>
                                           </value>
                                         </block>
                                       </next>
                                     </block>
                                   </statement>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                    </xml>
                    erazor86
                    schrieb am zuletzt editiert von erazor86
                    @paul53 jetzt wird die Dauer der Lüftung in ss:mm:ss in den Datenpunkt geschrieben.
                    Wie kann ich dieses Format jetzt in eine Dezimalzahl konvertieren? Bspw. aus 08:30:00 soll dann 8,5 werden.
                    Ich habe es wie folgt probiert, allerdings wird mir nur die 8h ausgegeben..
                    <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="g10!%+,PQcoL^1CtCc1M" x="-162" y="-487">
                      <value name="OID0">
                          <field name="oid">0_userdata.0.Datenpunkte.Rechengrößen.Dauer</field>
                        </shadow>
                      </value>
                        <block type="update" id="Qg5uQ5,C~h#CP}OXp,n|">
                          <field name="OID">0_userdata.0.Datenpunkte.Rechengrößen.Dauer_dezimal</field>
                            <block type="convert_tonumber" id="7`9D*4n16D87os~S.wgX">
                                <block type="on_source" id="6QPqXzV(jXa`:A/Jy*s|">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                    • E erazor86
                        <value name="OID0">
                          </shadow>
                        </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </statement>
                      </block>
                      @erazor86 sagte: Format jetzt in eine Dezimalzahl konvertieren?
                      Schreibe besser den Wert als Dezimalzahl im ursprünglichen Skript:
                      Der untere Datenpunkt erhält den Dezimalwert.
                      • E erazor86
                          <value name="OID0">
                            </shadow>
                          </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                        @erazor86
                        Die Wandlung des Strings "SS:mm:ss" in eine Dezimalzahl ist etwas aufwändiger.
                          @erazor86
                          erazor86
                          @erazor86
                          danke, doch irgendwie gibt es hierbei ein Problem... steige nicht ganz durch, wo das Problem liegt:
                          • E erazor86
                            @erazor86
                            @erazor86 sagte: wo das Problem liegt:
                            Poste bitte den Javascript-Code ohne die letzte Zeile in Code tags.
                              erazor86
                                <variables>
                                  <variable id="H_b:)/lk~U=V#?2Fm-_6">Einschaltdauer</variable>
                                  <variable id="9zZ/z:qt+2ur[Mg(U{^@">Liste</variable>
                                </variables>
                                <block type="on_ext" id="g10!%+,PQcoL^1CtCc1M" x="-187" y="-487">
                                  <value name="OID0">
                                    </shadow>
                                  </value>
                                    <block type="variables_set" id="jmdG%dMd*=ZRFyjN};FO">
                                      <field name="VAR" id="H_b:)/lk~U=V#?2Fm-_6">Einschaltdauer</field>
                                        <block type="lists_split" id="UrkwL9|$/`pGV6dtQ4=#">
                                          <mutation mode="SPLIT"></mutation>
                                          <field name="MODE">SPLIT</field>
                                          <value name="INPUT">
                                            <block type="on_source" id="/tG2*O8M2}DxPJBVce+(">
                                            </block>
                                          </value>
                                          <value name="DELIM">
                                            <shadow type="text" id="jddb#N[0ZokH]@uv|$^L">
                                              <field name="TEXT">:</field>
                                            </shadow>
                                          </value>
                                        </block>
                                      </value>
                                      <next>
                                        <block type="variables_set" id="yo,~CC4vFjRQ+!BI[Dj3">
                                            <block type="math_arithmetic" id=";{JdB#Q(L~2pI)@VEq]X" inline="false">
                                              <value name="A">
                                                <shadow type="math_number" id="3c9}N}KuPq4SPU`Vi.}0">
                                                </shadow>
                                                <block type="convert_tonumber" id="6tSv_rtVlamrBt%%sdNk">
                                                    <block type="lists_getIndex" id="j;YZ-#|;ymc?7Z!/}m`$">
                                                      <mutation statement="false" at="true"></mutation>
                                                      <field name="MODE">GET</field>
                                                      <field name="WHERE">FROM_START</field>
                                                        <block type="variables_get" id="*zdTBCpC?k.-sQA7_Jd6">
                                                          <field name="VAR" id="9zZ/z:qt+2ur[Mg(U{^@">Liste</field>
                                                        </block>
                                                      </value>
                                                      <value name="AT">
                                                        <block type="math_number" id="8e{^1DPK0hDM:M;#X-S2">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                <shadow type="math_number" id="pL0;D`,uYz`_FzqS0iED">
                                                </shadow>
                                                <block type="math_rndfixed" id="dngO+Sv-~SYJ@nbcCD?}">
                                                  <field name="n">1</field>
                                                  <value name="x">
                                                    <shadow type="math_number" id="IkY$?m}d-0oo0[1S/kHE">
                                                      <field name="NUM">3.1234</field>
                                                    </shadow>
                                                    <block type="math_arithmetic" id="W{h5)61$s9~M5v9,Fi-O">
                                                      <field name="OP">DIVIDE</field>
                                                      <value name="A">
                                                        <shadow type="math_number" id="]yL|:!R]:vuM,{XmCAR+">
                                                        </shadow>
                                                        <block type="lists_getIndex" id="}XJb*fL,oH]:}i%XL1@/">
                                                            <block type="variables_get" id="}~3#`VQg2s=7HTPvh~,0">
                                                            </block>
                                                          </value>
                                                          <value name="AT">
                                                            <block type="math_number" id="ge_58=bFeMNGFo7bk8`9">
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        <shadow type="math_number" id="1mGyZqUY*qCf4zf!K^TZ">
                                                          <field name="NUM">60</field>
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                                <block type="variables_get" id=";*9U=xcn:`{pl^f5-rs,">
                                                </block>
                                              </value>
                                            </block>
                                          </next>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </xml>
                              • E erazor86
                                  <variables>
                                  </variables>
                                    <value name="OID0">
                                      </shadow>
                                    </value>
                                              </block>
                                            </value>
                                              </shadow>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                                <value name="A">
                                                  </shadow>
                                                          </block>
                                                        </value>
                                                        <value name="AT">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </shadow>
                                                    <value name="x">
                                                      </shadow>
                                                        <value name="A">
                                                          </shadow>
                                                              </block>
                                                            </value>
                                                            <value name="AT">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                                  </block>
                                                </value>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </xml>
                                @erazor86
                                Tausche an 2 Stellen die Variable Liste gegen Einschaltdauer.
                                E B 2 Antworten Letzte Antwort
                                  @erazor86
                                  erazor86
                                  🤦 manchmal könnte es so einfach sein.... Vielen Dank.. :)
                                    @erazor86
                                    brofelscher
                                    ich komme mit meiner Differenzzeit in Minuten ebenfalls nicht weiter. Ich versuche die Zeitdifferenz zwischen "Jetzt" und der letzten Aktualisierung eines Datenpunktes in Minuten zu errechnen und diese in den Datenpunkt "AbwesendSeitMinuten" zu schreiben.
                                    Das folgende Blockly funktioniert bis 59 Minuten prima, alles darüber hinaus funktioniert jedoch nicht. Es werden also zum Beispiel nicht 67 Minuten Differenz dargestellt, sondern nur "7". Die restlichen 60 Minuten verschwinden.
                                      <block type="comment" id="vdO3Z/b-^J_@l)?Eq_R+" x="13" y="38">
                                        <field name="COMMENT">Abwesenheitszeit berechnen</field>
                                        <next>
                                          <block type="on" id="-Se3D{`):B`]p/=p_aOI">
                                            <field name="OID">fb-checkpresence.0.presentCount</field>
                                              <block type="controls_if" id="g$$Mh+_gT[pE?%~wmOw7">
                                                <value name="IF0">
                                                  <block type="logic_compare" id="B~cGcXi@sZ~Vuxeg9NrH">
                                                    <value name="A">
                                                      <block type="get_value" id="Ra3xND;{0=Gx-[pw@??P">
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      <block type="text" id="|2l5jEGj$arki%U@aI1*">
                                                        <field name="TEXT">0</field>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  <block type="update" id="fO*d3{jQ-Q,Muo5?^aHF">
                                                    <field name="OID">0_userdata.0.AbwesendSeitMinuten</field>
                                                      <block type="convert_from_date" id="xF2Wqp~s/~y5PUaC_;7^">
                                                        <field name="OPTION">m</field>
                                                          <block type="math_arithmetic" id="{)*krPx!rRWcV.lMNvs9">
                                                            <value name="A">
                                                              <shadow type="math_number" id="rD[[`+/pH}Z,=`RaZDKb">
                                                              </shadow>
                                                              <block type="time_get" id="{YtxVX%(xd!aZrGPIR%/">
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="U}:)~D1u/;(DT4d+kNZM">
                                                              </shadow>
                                                              <block type="get_value" id="}D,-3Ku3mkH){l1UJ|o?">
        <field name="ATTR">lc</field>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </statement>
                                              </block>
                                            </statement>
                                          </block>
                                        </next>
                                      </block>
                                    </xml>
                                    • B brofelscher
                                          <next>
                                                  <value name="IF0">
                                                      <value name="A">
                                                        </block>
                                                      </value>
                                                      <value name="B">
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                              <value name="A">
        </shadow>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </statement>
                                                </block>
                                              </statement>
                                            </block>
                                          </next>
                                        </block>
                                      </xml>
                                      @brofelscher sagte: Blockly funktioniert bis 59 Minuten prima
                                      Das sind die Minuten der Uhrzeit.
                                      Vorschlag:
                                         <next>
                                                 <value name="IF0">
                                                     <value name="A">
                                                       </block>
                                                     </value>
                                                     <value name="B">
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </value>
                                                       <block type="math_round" id="jh5X6wfE6}koDRuR}h,7">
                                                         <field name="OP">ROUND</field>
                                                         <value name="NUM">
                                                           <shadow type="math_number" id="dsl{1yg*UVLul@F2*}_x">
                                                             <field name="NUM">3.1</field>
                                                           </shadow>
                                                           <block type="math_arithmetic" id="CG|Sg`nEt;fkO/q}:-Eg">
                                                             <value name="A">
                                                               <shadow type="math_number" id="r16alN.iyJ)%|~KKF{p5">
                                                               </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        <block type="on_source" id="75tkb;IKslfqIl;1JyN#">
        </block>
        </value>
                                                               </block>
                                                             </value>
                                                             <value name="B">
                                                               <shadow type="math_number" id="7o1So,{6-3V~;lGxE-;P">
                                                               </shadow>
                                                             </value>
                                                           </block>
                                                         </value>
                                                       </block>
                                                     </value>
                                                   </block>
                                                 </statement>
                                               </block>
                                             </statement>
                                           </block>
                                         </next>
                                       </block>
                                      </xml>
                                        Vorschlag:
                                           <next>
                                                   <value name="IF0">
                                                       <value name="A">
                                                         </block>
                                                       </value>
                                                       <value name="B">
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </value>
                                                           <value name="NUM">
                                                             </shadow>
                                                               <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
                                                               </value>
                                                               <value name="B">
        </shadow>
                                                               </value>
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                     </block>
                                                   </statement>
                                                 </block>
                                               </statement>
                                             </block>
                                           </next>
                                         </block>
                                        </xml>
                                        brofelscher
                                        Vorschlag:
                                        Hi, dein Vorschlag passt perfekt :) Danke dir.
                                        Ich habe wohl die Funktion "Minuten" missverstanden, da ich für die Minuten auch die Formatierung "mm" hätte nutzen können.
                                        Und wieder ist man ein wenig schlauer :)
                                        • E Offline
                                          erazor86
                                          Ich habe wieder eine neue Aufgabenstellung bzgl. Zeitverrechnung. Diesmal möchte ich die mittlere Außentemperatur der letzten 3h berechnen. Ich habe hierzu mal ein Blockly erstellt. Jedoch ist es nicht ganz korrekt, da die durchschnittliche Temp nur alle 3h neu berechnet wird. Habe es leider nicht hinbekommen wie ich es gerne hätte. Vielleicht hat jemand einen Tip?
