  4. Test Alpha Homekit-Controller 0.0.x
260 Beiträge 27 Kommentatoren 62.5k Aufrufe 24 Beobachtet
  • R Ritter
    Laut Lampen Karton wird es unterstützt. Es sind auch bei beiden Lampen diese Pins mit QR Code drauf und die Meross APP zeigt auch diesen PIN an.
    Windows Rechner wo iobroker inst. ist hat IP: 192.168.1.31 SUB: 255.255.255.252.0
    Die Lampe: 192.168.3.142
    homekit-controller.0
    2021-12-05 15:37:30.175	debug	state homekit-controller.0.info.connection changed: false (ack = true)
    2021-12-05 15:37:30.109	info	starting. Version 0.3.3 in C:/iobroker/node_modules/iobroker.homekit-controller, node: v14.15.4, js-controller: 3.3.21
    2021-12-05 15:37:29.005	debug	Plugin sentry Initialize Plugin (enabled=true)
    2021-12-05 15:37:28.786	debug	statesDB connected
    2021-12-05 15:37:28.786	debug	States connected to redis: 0.0.0.0:9000
    2021-12-05 15:37:28.760	debug	States create User PubSub Client
    2021-12-05 15:37:28.760	debug	States create System PubSub Client
    2021-12-05 15:37:28.743	debug	Redis States: Use Redis connection: 0.0.0.0:9000
    2021-12-05 15:37:28.741	debug	objectDB connected
    2021-12-05 15:37:28.734	debug	Objects connected to redis: 0.0.0.0:9001
    2021-12-05 15:37:28.705	debug	Objects client initialize lua scripts
    2021-12-05 15:37:28.704	debug	Objects create User PubSub Client
    2021-12-05 15:37:28.703	debug	Objects create System PubSub Client
    2021-12-05 15:37:28.702	debug	Objects client ready ... initialize now
    2021-12-05 15:37:28.655	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
    2021-12-05 15:37:24.397	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-12-05 15:37:24.397	debug	Plugin sentry destroyed
    2021-12-05 15:37:24.396	info	terminating
    2021-12-05 15:37:24.394	info	Got terminate signal TERMINATE_YOURSELF
    2021-12-05 15:36:22.991	debug	sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
    2021-12-05 15:36:22.990	debug	Response to Command getDiscoveredDevices: {"success":true,"error":false}
    2021-12-05 15:36:22.990	debug	Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":302,"ack":false,"time":1638714982989},"_id":95084731})
    2021-12-05 15:36:21.524	debug	sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
    2021-12-05 15:36:21.524	debug	Response to Command getDiscoveredDevices: {"success":true,"error":false}
    2021-12-05 15:36:21.520	debug	Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":301,"ack":false,"time":1638714981508},"_id":95084730})
    @ritter Naja 192.168.1 vs 192.168.3 sind zwei Netzsegmente ... Ich kenne jetzt Deine Routerkonfiguration nicht oder du musst sicherstellen das UDP Pakete geroutet werden oder einen ioBroker Slave in das andere Netzsegment stellen.
    Ohne UDP Pakete gibt es generell kein Apple HomeKit (auch nicht mit Apple App - es sei denn das Handy wäre dann auch in dem netz wie die Lampe).
    R 1 Antwort Letzte Antwort
    • apollon77A apollon77
      Ritter
      @apollon77 Aber ist es mit der Netzmaske: 255.255.255.252.0 nicht ein Segment? Alle anderen Geräte finden sich untereinander wie das mit UDP ist weis ich nicht, braucht man das nicht auch für VOIP das geht jedenfalls.
      • R Offline
        Ritter
        Hab der Lampe über die FritzBox jetzt diese Adresse zugewiesen: 192.168.1.142 aber keine Änderung.
        • R Ritter
          Ritter
          @ritter sagte in Test Alpha Homekit-Controller 0.0.x:
          Hab jetzt noch ein Firmwareupdate für den 24 Port Switch gemacht und nun findet er die Lampe und kann gesteuert werden.
          • R Ritter
            @ritter Na Cool, also war da doch irgendwas mit UDP Routing
            • R Offline
              Ritter
              Ja, vielleicht aber nur Zufall denn die zweite Lampe findet er nicht.
              • R Ritter
                @ritter Vllt auch ins gleiche Netzsegment bringen?
                • R Offline
                  Ritter
                  schrieb am zuletzt editiert von Ritter
                  Auch schon probiert. Zumindest weis ich jetzt das die Lampen es generell können.
                  • R Ritter
                    @ritter Generell versuch doch mal ob Du sie per iOS Handy an Apple Home anlernen kannst ... wenn das geht lern Sie wieder ab und versuch nochmal
                    F 1 Antwort Letzte Antwort
                      Fortune95
                      @apollon77
                      kann man die Eve Geräte nur über einen Extend koppeln, oder geht das auch direkt über Bluetooth?
                      Über bluetooth sehe ich die Geräte im Adapter kann sie identifizieren aber nicht erfolgreich pairen,
                      über den Extend funktierte es einwandfrei.
                      2021-12-11 11:09:50.667 - debug: homekit-controller.0 (55192) BLE-F5:A0:3F:34:7E:71 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"f5:a0:3f:34:7e:71","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"f5:a0:3f:34:7e:71","ci":10,"availableToPair":true}
                      2021-12-11 11:09:50.669 - debug: homekit-controller.0 (55192) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"f5:a0:3f:34:7e:71","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"f5:a0:3f:34:7e:71","ci":10,"availableToPair":true}
                      2021-12-11 11:09:51.163 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-F5:A0:3F:34:7E:71.info.connectionType changed: BLE (ack = true)
                      2021-12-11 11:09:51.181 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-F5:A0:3F:34:7E:71.info.id changed: f5:a0:3f:34:7e:71 (ack = true)
                      2021-12-11 11:09:51.195 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-F5:A0:3F:34:7E:71.info.connected changed: false (ack = true)
                      2021-12-11 11:09:51.215 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-F5:A0:3F:34:7E:71.admin.isPaired changed: false (ack = true)
                      2021-12-11 11:09:51.232 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-F5:A0:3F:34:7E:71.info.lastDiscovered changed: 1639217390670 (ack = true)
                      2021-12-11 11:11:54.863 - debug: homekit-controller.0 (55192) Discovered BLE device changed: 91:09:30:d3:27:4b/Eve Room 632D
                      2021-12-11 11:11:54.864 - debug: homekit-controller.0 (55192) BLE-91:09:30:D3:27:4B Discovered BLE device: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"91:09:30:d3:27:4b","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"91:09:30:d3:27:4b","ci":10,"availableToPair":true}
                      2021-12-11 11:11:54.865 - debug: homekit-controller.0 (55192) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"91:09:30:d3:27:4b","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"91:09:30:d3:27:4b","ci":10,"availableToPair":true}
                      2021-12-11 11:11:54.911 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-91:09:30:D3:27:4B.info.connectionType changed: BLE (ack = true)
                      2021-12-11 11:11:54.921 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-91:09:30:D3:27:4B.info.connectionType changed: BLE (ack = true)
                      2021-12-11 11:11:54.954 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-91:09:30:D3:27:4B.info.id changed: 91:09:30:d3:27:4b (ack = true)
                      2021-12-11 11:11:55.000 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-91:09:30:D3:27:4B.info.connected changed: false (ack = true)
                      2021-12-11 11:11:55.094 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-91:09:30:D3:27:4B.admin.isPaired changed: false (ack = true)
                      2021-12-11 11:11:55.117 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-91:09:30:D3:27:4B.info.lastDiscovered changed: 1639217514866 (ack = true)
                      2021-12-11 11:11:55.133 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-91:09:30:D3:27:4B.admin.pairWithPin changed: (ack = true)
                      2021-12-11 11:11:55.149 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-91:09:30:D3:27:4B.admin.identify changed: false (ack = true)
                      2021-12-11 11:12:23.945 - debug: homekit-controller.0 (55192) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":18,"ack":false,"time":1639217543942},"_id":54081580})
                      2021-12-11 11:12:23.946 - debug: homekit-controller.0 (55192) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-91:09:30:D3:27:4B","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-F5:A0:3F:34:7E:71","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false},{"id":"BLE-D9:13:F4:11:E9:11","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                      2021-12-11 11:12:23.948 - debug: homekit-controller.0 (55192) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                      2021-12-11 11:12:30.870 - debug: homekit-controller.0 (55192) Message identify received: {"command":"identify","message":{"deviceId":"BLE-91:09:30:D3:27:4B"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-91:09:30:D3:27:4B"},"id":19,"ack":false,"time":1639217550868},"_id":54081581})
                      2021-12-11 11:12:30.871 - debug: homekit-controller.0 (55192) Device BLE-91:09:30:D3:27:4B: Identify triggered
                      2021-12-11 11:12:33.562 - debug: homekit-controller.0 (55192) Response to Command identify: {"success":true,"error":false}
                      2021-12-11 11:12:33.564 - debug: homekit-controller.0 (55192) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                      2021-12-11 11:12:35.072 - debug: homekit-controller.0 (55192) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":20,"ack":false,"time":1639217555070},"_id":54081582})
                      2021-12-11 11:12:35.073 - debug: homekit-controller.0 (55192) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-91:09:30:D3:27:4B","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-F5:A0:3F:34:7E:71","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false},{"id":"BLE-D9:13:F4:11:E9:11","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                      2021-12-11 11:12:35.073 - debug: homekit-controller.0 (55192) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                      2021-12-11 11:12:40.256 - debug: homekit-controller.0 (55192) Message identify received: {"command":"identify","message":{"deviceId":"BLE-F5:A0:3F:34:7E:71"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-F5:A0:3F:34:7E:71"},"id":21,"ack":false,"time":1639217560254},"_id":54081583})
                      2021-12-11 11:12:40.256 - debug: homekit-controller.0 (55192) Device BLE-F5:A0:3F:34:7E:71: Identify triggered
                      2021-12-11 11:12:42.661 - debug: homekit-controller.0 (55192) Response to Command identify: {"success":true,"error":false}
                      2021-12-11 11:12:42.661 - debug: homekit-controller.0 (55192) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                      2021-12-11 11:12:44.179 - debug: homekit-controller.0 (55192) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":22,"ack":false,"time":1639217564177},"_id":54081584})
                      2021-12-11 11:12:44.179 - debug: homekit-controller.0 (55192) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-91:09:30:D3:27:4B","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-F5:A0:3F:34:7E:71","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false},{"id":"BLE-D9:13:F4:11:E9:11","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                      2021-12-11 11:12:44.180 - debug: homekit-controller.0 (55192) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                      2021-12-11 11:13:06.470 - debug: homekit-controller.0 (55192) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-F5:A0:3F:34:7E:71","pin":"629-15-584"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-F5:A0:3F:34:7E:71","pin":"629-15-584"},"id":23,"ack":false,"time":1639217586468},"_id":54081585})
                      2021-12-11 11:13:09.388 - debug: homekit-controller.0 (55192) BLE-F5:A0:3F:34:7E:71 Start Homekit Device Client initialization
                      2021-12-11 11:13:17.555 - debug: homekit-controller.0 (55192) BLE-F5:A0:3F:34:7E:71 Start Homekit Device Client initialization
                      2021-12-11 11:13:17.557 - debug: homekit-controller.0 (55192) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"f5:a0:3f:34:7e:71","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"f5:a0:3f:34:7e:71","ci":10,"availableToPair":false}
                      2021-12-11 11:13:17.574 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-F5:A0:3F:34:7E:71.admin.pairWithPin deleted
                      2021-12-11 11:13:17.602 - debug: homekit-controller.0 (55192) Discovered BLE device changed: f5:a0:3f:34:7e:71/Eve Degree 053B
                      2021-12-11 11:13:17.605 - debug: homekit-controller.0 (55192) BLE-F5:A0:3F:34:7E:71 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f5:a0:3f:34:7e:71","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"f5:a0:3f:34:7e:71","ci":10,"availableToPair":false}
                      2021-12-11 11:13:17.606 - debug: homekit-controller.0 (55192) BLE-F5:A0:3F:34:7E:71 Device initialization already in progress ... ignore call
                      2021-12-11 11:13:17.612 - debug: homekit-controller.0 (55192) Discovered BLE device changed: f5:a0:3f:34:7e:71/Eve Degree 053B
                      2021-12-11 11:13:17.613 - debug: homekit-controller.0 (55192) BLE-F5:A0:3F:34:7E:71 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f5:a0:3f:34:7e:71","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"f5:a0:3f:34:7e:71","ci":10,"availableToPair":false}
                      2021-12-11 11:13:17.613 - debug: homekit-controller.0 (55192) BLE-F5:A0:3F:34:7E:71 Device initialization already in progress ... ignore call
                      2021-12-11 11:13:17.622 - debug: homekit-controller.0 (55192) state homekit-controller.0.BLE-F5:A0:3F:34:7E:71.admin.identify deleted
                      2021-12-11 11:13:18.049 - debug: homekit-controller.0 (55192) Response to Command pairDevice: {"success":true,"error":false}
                      2021-12-11 11:13:18.049 - debug: homekit-controller.0 (55192) sendTo "pairDevice" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                      2021-12-11 11:19:49.584 - debug: homekit-controller.0 (55192) Discovered BLE device changed: f5:a0:3f:34:7e:71/Eve Degree 053B
                      2021-12-11 11:19:49.584 - debug: homekit-controller.0 (55192) BLE-F5:A0:3F:34:7E:71 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f5:a0:3f:34:7e:71","ACID":10,"GSN":3,"CN":3,"CV":2,"c#":3,"id":"f5:a0:3f:34:7e:71","ci":10,"availableToPair":false}
                      2021-12-11 11:19:49.585 - debug: homekit-controller.0 (55192) BLE-F5:A0:3F:34:7E:71 Start Homekit Device Client initialization
                      2021-12-11 11:19:49.585 - debug: homekit-controller.0 (55192) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"f5:a0:3f:34:7e:71","ACID":10,"GSN":3,"CN":3,"CV":2,"c#":3,"id":"f5:a0:3f:34:7e:71","ci":10,"availableToPair":false}
                      apollon77A 2 Antworten Letzte Antwort
                      • F Fortune95
                        @apollon77
                        @fortune95 also an sich sollten die pairbar sein. Ich hab nur ein eve energy und da tat es. Aber sie dürfen halt nicht schon paired sein und im log sehe ich immer „available to pair = false“ … kann sein das es schon mit dem extend gepaired ist? Oder so? Es muss komplett frei sein.
                        Aahh ok am Anfang war’s true. Da seherisch aber im log keinen pair call ?!
                        Kannst testen ob es mit Apple Home pairbar ist …
                        • F Fortune95
                          @apollon77
                          @fortune95 sagte in Test Alpha Homekit-Controller 0.0.x:
                          ooookkkkk ... also jetzt am Laptop nochmal log gelesen ...
                          Ja du hast ein pair gemacht für BLE-F5:A0:3F:34:7E:71, Eve Degree 053B und wenn ich das richtig sehe war da auch erfolgreich. hat 6 Sekunden gebraucht :-)
                          weil sonst hätte er nicht
                          geloggt.
                          Kannst Du es bitte nochmal mit Debug log versuchen? Und wenn es nicht tut bitte gepaired lassen und mal adapter stoppen, 10s warten und neu starten. Tut es dann ?
                            geloggt.
                            Fortune95
                            @apollon77
                            Hab den Adpater gestartet, dann die beiden Eve Geräte Degree & Room im Adapter gesehen.
                            Den Degree per Ident Funktion erfolgreich identifiziert und danach den Pair über den entsprechenden button ausgelöst.
                            Bis auf die Basis Objekte wurde nichts weiteres kreiert.
                            Dann habe ich den Adapter gestoppt und nach ca. 25s wieder gestartet.
                            Jetzt sehe ich den Degree wieder im Adapter aber er wird nicht als gepairt oder pairbar gekennzeichnet.
                            Mit Apple Home lässt er sich einwandfrei pairen.
                            Hier der Debug Log vom ganzen Prozedere:
                            2021-12-12 19:31:53.363 - debug: homekit-controller.0 (1208651) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2021-12-12 19:31:53.413 - debug: homekit-controller.0 (1208651) Objects client ready ... initialize now
                            2021-12-12 19:31:53.420 - debug: homekit-controller.0 (1208651) Objects create System PubSub Client
                            2021-12-12 19:31:53.424 - debug: homekit-controller.0 (1208651) Objects create User PubSub Client
                            2021-12-12 19:31:53.427 - debug: homekit-controller.0 (1208651) Objects client initialize lua scripts
                            2021-12-12 19:31:53.479 - debug: homekit-controller.0 (1208651) Objects connected to redis: 127.0.0.1:9001
                            2021-12-12 19:31:53.492 - debug: homekit-controller.0 (1208651) objectDB connected
                            2021-12-12 19:31:53.496 - debug: homekit-controller.0 (1208651) Redis States: Use Redis connection: 127.0.0.1:6379
                            2021-12-12 19:31:53.510 - debug: homekit-controller.0 (1208651) States create System PubSub Client
                            2021-12-12 19:31:53.512 - debug: homekit-controller.0 (1208651) States create User PubSub Client
                            2021-12-12 19:31:53.526 - debug: homekit-controller.0 (1208651) States connected to redis: 127.0.0.1:6379
                            2021-12-12 19:31:53.528 - debug: homekit-controller.0 (1208651) statesDB connected
                            2021-12-12 19:31:53.810 - debug: homekit-controller.0 (1208651) Plugin sentry Initialize Plugin (enabled=true)
                            2021-12-12 19:31:54.261 - info: homekit-controller.0 (1208651) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.18.2, js-controller: 3.3.21
                            2021-12-12 19:31:54.581 - debug: homekit-controller.0 (1208651) Init 2 known devices without discovery ...
                            2021-12-12 19:31:54.584 - info: homekit-controller.0 (1208651) BLE-E7:21:2E:89:7E:35 (Eve Degree 053B) found without pairing data but available for pairing: Create basic objects
                            2021-12-12 19:31:54.586 - debug: homekit-controller.0 (1208651) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"e7:21:2e:89:7e:35","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"e7:21:2e:89:7e:35","ci":10,"availableToPair":true}
                            2021-12-12 19:31:54.602 - debug: homekit-controller.0 (1208651) state homekit-controller.0.info.connection changed: false (ack = true)
                            2021-12-12 19:31:54.675 - debug: homekit-controller.0 (1208651) Discovered IP device up: 0E:6C:79:7B:0B:81/Homebridge 4B75
                            2021-12-12 19:31:54.676 - debug: homekit-controller.0 (1208651) IP-0E:6C:79:7B:0B:81 Discovered IP device: {"name":"Homebridge 4B75","address":"192.168.12.219","port":51861,"c#":3,"ff":0,"id":"0E:6C:79:7B:0B:81","md":"homebridge","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                            2021-12-12 19:31:54.677 - info: homekit-controller.0 (1208651) IP-0E:6C:79:7B:0B:81 (Homebridge 4B75) found without known pairing data and already paired: ignoring
                            2021-12-12 19:31:54.681 - debug: homekit-controller.0 (1208651) Discovered IP device up: ab:34:18:95:31:5d/IOBroker 83D1
                            2021-12-12 19:31:54.682 - debug: homekit-controller.0 (1208651) IP-AB:34:18:95:31:5D Discovered IP device: {"name":"IOBroker 83D1","address":"192.168.12.219","port":34237,"c#":157,"ff":0,"id":"ab:34:18:95:31:5d","md":"not configured","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                            2021-12-12 19:31:54.682 - info: homekit-controller.0 (1208651) IP-AB:34:18:95:31:5D (IOBroker 83D1) found without known pairing data and already paired: ignoring
                            2021-12-12 19:31:54.689 - debug: homekit-controller.0 (1208651) Discovered IP device up: 58:47:6A:51:5B:FE/IN-8003FHD-PoE(c7)
                            2021-12-12 19:31:54.689 - debug: homekit-controller.0 (1208651) IP-58:47:6A:51:5B:FE Discovered IP device: {"name":"IN-8003FHD-PoE(c7)","address":"192.168.12.199","port":23657,"c#":1,"ff":0,"id":"58:47:6A:51:5B:FE","md":"IN-8003FHD-PoE","pv":"1.0","s#":1,"sf":0,"ci":17,"availableToPair":false}
                            2021-12-12 19:31:54.690 - info: homekit-controller.0 (1208651) IP-58:47:6A:51:5B:FE (IN-8003FHD-PoE(c7)) found without known pairing data and already paired: ignoring
                            2021-12-12 19:31:54.700 - debug: homekit-controller.0 (1208651) Discovered BLE device up: e7:21:2e:89:7e:35/Eve Degree 053B
                            2021-12-12 19:31:54.701 - debug: homekit-controller.0 (1208651) BLE-E7:21:2E:89:7E:35 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"e7:21:2e:89:7e:35","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"e7:21:2e:89:7e:35","ci":10,"availableToPair":true}
                            2021-12-12 19:31:54.701 - debug: homekit-controller.0 (1208651) BLE-E7:21:2E:89:7E:35 Device initialization already in progress ... ignore call
                            2021-12-12 19:31:54.707 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.info.connectionType changed: BLE (ack = true)
                            2021-12-12 19:31:54.719 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.info.id changed: e7:21:2e:89:7e:35 (ack = true)
                            2021-12-12 19:31:54.731 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.info.connected changed: false (ack = true)
                            2021-12-12 19:31:54.749 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.admin.isPaired changed: false (ack = true)
                            2021-12-12 19:31:54.760 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.info.lastDiscovered changed: 1639333914589 (ack = true)
                            2021-12-12 19:31:54.775 - info: homekit-controller.0 (1208651) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                            2021-12-12 19:31:54.776 - debug: homekit-controller.0 (1208651) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                            2021-12-12 19:31:54.804 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                            2021-12-12 19:31:54.815 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                            2021-12-12 19:31:54.827 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                            2021-12-12 19:31:54.850 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                            2021-12-12 19:31:54.871 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639333914777 (ack = true)
                            2021-12-12 19:31:55.873 - debug: homekit-controller.0 (1208651) Discovered BLE device up: ed:b2:df:50:92:d1/Eve Room 632D
                            2021-12-12 19:31:55.874 - debug: homekit-controller.0 (1208651) BLE-ED:B2:DF:50:92:D1 Discovered BLE device: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                            2021-12-12 19:31:55.875 - info: homekit-controller.0 (1208651) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                            2021-12-12 19:31:55.875 - debug: homekit-controller.0 (1208651) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                            2021-12-12 19:31:55.907 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                            2021-12-12 19:31:55.919 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                            2021-12-12 19:31:55.932 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                            2021-12-12 19:31:55.952 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                            2021-12-12 19:31:55.963 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639333915876 (ack = true)
                            2021-12-12 19:31:57.849 - debug: homekit-controller.0 (1208651) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":209,"ack":false,"time":1639333917840},"_id":54081771})
                            2021-12-12 19:31:57.851 - debug: homekit-controller.0 (1208651) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-E7:21:2E:89:7E:35","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false}]}
                            2021-12-12 19:31:57.852 - debug: homekit-controller.0 (1208651) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                            2021-12-12 19:32:09.019 - debug: homekit-controller.0 (1208651) Message identify received: {"command":"identify","message":{"deviceId":"BLE-E7:21:2E:89:7E:35"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-E7:21:2E:89:7E:35"},"id":210,"ack":false,"time":1639333929017},"_id":54081772})
                            2021-12-12 19:32:09.020 - debug: homekit-controller.0 (1208651) Device BLE-E7:21:2E:89:7E:35: Identify triggered
                            2021-12-12 19:32:12.434 - debug: homekit-controller.0 (1208651) Response to Command identify: {"success":true,"error":false}
                            2021-12-12 19:32:12.436 - debug: homekit-controller.0 (1208651) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                            2021-12-12 19:32:13.957 - debug: homekit-controller.0 (1208651) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":211,"ack":false,"time":1639333933955},"_id":54081773})
                            2021-12-12 19:32:13.957 - debug: homekit-controller.0 (1208651) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-E7:21:2E:89:7E:35","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false}]}
                            2021-12-12 19:32:13.958 - debug: homekit-controller.0 (1208651) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                            2021-12-12 19:32:37.174 - debug: homekit-controller.0 (1208651) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-E7:21:2E:89:7E:35","pin":"629-15-584"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-E7:21:2E:89:7E:35","pin":"629-15-584"},"id":212,"ack":false,"time":1639333957172},"_id":54081774})
                            2021-12-12 19:32:44.315 - debug: homekit-controller.0 (1208651) BLE-E7:21:2E:89:7E:35 Start Homekit Device Client initialization
                            2021-12-12 19:32:53.785 - debug: homekit-controller.0 (1208651) BLE-E7:21:2E:89:7E:35 Start Homekit Device Client initialization
                            2021-12-12 19:32:53.786 - debug: homekit-controller.0 (1208651) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"e7:21:2e:89:7e:35","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"e7:21:2e:89:7e:35","ci":10,"availableToPair":false}
                            2021-12-12 19:32:53.809 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.admin.pairWithPin deleted
                            2021-12-12 19:32:53.840 - debug: homekit-controller.0 (1208651) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.admin.identify deleted
                            2021-12-12 19:33:04.086 - debug: homekit-controller.0 (1208651) Discovered BLE device changed: e7:21:2e:89:7e:35/Eve Degree 053B
                            2021-12-12 19:33:04.087 - debug: homekit-controller.0 (1208651) BLE-E7:21:2E:89:7E:35 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"e7:21:2e:89:7e:35","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"e7:21:2e:89:7e:35","ci":10,"availableToPair":false}
                            2021-12-12 19:33:04.088 - debug: homekit-controller.0 (1208651) BLE-E7:21:2E:89:7E:35 Device initialization already in progress ... ignore call
                            2021-12-12 19:33:23.430 - debug: homekit-controller.0 (1208651) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":213,"ack":false,"time":1639334003428},"_id":54081775})
                            2021-12-12 19:33:23.431 - debug: homekit-controller.0 (1208651) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-E7:21:2E:89:7E:35","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":true},{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false}]}
                            2021-12-12 19:33:23.431 - debug: homekit-controller.0 (1208651) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                            2021-12-12 19:34:04.645 - info: homekit-controller.0 (1208651) Got terminate signal TERMINATE_YOURSELF
                            2021-12-12 19:34:04.655 - info: homekit-controller.0 (1208651) terminating
                            2021-12-12 19:34:04.657 - debug: homekit-controller.0 (1208651) Plugin sentry destroyed
                            2021-12-12 19:34:04.657 - info: homekit-controller.0 (1208651) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2021-12-12 19:34:33.622 - debug: homekit-controller.0 (1208696) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2021-12-12 19:34:33.674 - debug: homekit-controller.0 (1208696) Objects client ready ... initialize now
                            2021-12-12 19:34:33.680 - debug: homekit-controller.0 (1208696) Objects create System PubSub Client
                            2021-12-12 19:34:33.684 - debug: homekit-controller.0 (1208696) Objects create User PubSub Client
                            2021-12-12 19:34:33.687 - debug: homekit-controller.0 (1208696) Objects client initialize lua scripts
                            2021-12-12 19:34:33.759 - debug: homekit-controller.0 (1208696) Objects connected to redis: 127.0.0.1:9001
                            2021-12-12 19:34:33.785 - debug: homekit-controller.0 (1208696) objectDB connected
                            2021-12-12 19:34:33.790 - debug: homekit-controller.0 (1208696) Redis States: Use Redis connection: 127.0.0.1:6379
                            2021-12-12 19:34:33.821 - debug: homekit-controller.0 (1208696) States create System PubSub Client
                            2021-12-12 19:34:33.823 - debug: homekit-controller.0 (1208696) States create User PubSub Client
                            2021-12-12 19:34:33.850 - debug: homekit-controller.0 (1208696) States connected to redis: 127.0.0.1:6379
                            2021-12-12 19:34:33.851 - debug: homekit-controller.0 (1208696) statesDB connected
                            2021-12-12 19:34:34.246 - debug: homekit-controller.0 (1208696) Plugin sentry Initialize Plugin (enabled=true)
                            2021-12-12 19:34:34.486 - info: homekit-controller.0 (1208696) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.18.2, js-controller: 3.3.21
                            2021-12-12 19:34:34.728 - debug: homekit-controller.0 (1208696) Init 2 known devices without discovery ...
                            2021-12-12 19:34:34.730 - info: homekit-controller.0 (1208696) BLE-E7:21:2E:89:7E:35 (Eve Degree 053B) found without pairing data but available for pairing: Create basic objects
                            2021-12-12 19:34:34.732 - debug: homekit-controller.0 (1208696) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"e7:21:2e:89:7e:35","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"e7:21:2e:89:7e:35","ci":10,"availableToPair":true}
                            2021-12-12 19:34:34.746 - debug: homekit-controller.0 (1208696) state homekit-controller.0.info.connection changed: false (ack = true)
                            2021-12-12 19:34:34.787 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.info.connectionType changed: BLE (ack = true)
                            2021-12-12 19:34:34.838 - debug: homekit-controller.0 (1208696) Discovered IP device up: 0E:6C:79:7B:0B:81/Homebridge 4B75
                            2021-12-12 19:34:34.839 - debug: homekit-controller.0 (1208696) IP-0E:6C:79:7B:0B:81 Discovered IP device: {"name":"Homebridge 4B75","address":"192.168.12.219","port":51861,"c#":3,"ff":0,"id":"0E:6C:79:7B:0B:81","md":"homebridge","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                            2021-12-12 19:34:34.840 - info: homekit-controller.0 (1208696) IP-0E:6C:79:7B:0B:81 (Homebridge 4B75) found without known pairing data and already paired: ignoring
                            2021-12-12 19:34:34.845 - debug: homekit-controller.0 (1208696) Discovered IP device up: ab:34:18:95:31:5d/IOBroker 83D1
                            2021-12-12 19:34:34.846 - debug: homekit-controller.0 (1208696) IP-AB:34:18:95:31:5D Discovered IP device: {"name":"IOBroker 83D1","address":"192.168.12.219","port":34237,"c#":157,"ff":0,"id":"ab:34:18:95:31:5d","md":"not configured","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                            2021-12-12 19:34:34.847 - info: homekit-controller.0 (1208696) IP-AB:34:18:95:31:5D (IOBroker 83D1) found without known pairing data and already paired: ignoring
                            2021-12-12 19:34:34.853 - debug: homekit-controller.0 (1208696) Discovered IP device up: 58:47:6A:51:5B:FE/IN-8003FHD-PoE(c7)
                            2021-12-12 19:34:34.853 - debug: homekit-controller.0 (1208696) IP-58:47:6A:51:5B:FE Discovered IP device: {"name":"IN-8003FHD-PoE(c7)","address":"192.168.12.199","port":23657,"c#":1,"ff":0,"id":"58:47:6A:51:5B:FE","md":"IN-8003FHD-PoE","pv":"1.0","s#":1,"sf":0,"ci":17,"availableToPair":false}
                            2021-12-12 19:34:34.854 - info: homekit-controller.0 (1208696) IP-58:47:6A:51:5B:FE (IN-8003FHD-PoE(c7)) found without known pairing data and already paired: ignoring
                            2021-12-12 19:34:34.863 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.info.id changed: e7:21:2e:89:7e:35 (ack = true)
                            2021-12-12 19:34:34.876 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.info.connected changed: false (ack = true)
                            2021-12-12 19:34:34.908 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.admin.isPaired changed: false (ack = true)
                            2021-12-12 19:34:34.924 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.info.lastDiscovered changed: 1639334074733 (ack = true)
                            2021-12-12 19:34:34.949 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.admin.pairWithPin changed: (ack = true)
                            2021-12-12 19:34:34.964 - info: homekit-controller.0 (1208696) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                            2021-12-12 19:34:34.965 - debug: homekit-controller.0 (1208696) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                            2021-12-12 19:34:34.966 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-E7:21:2E:89:7E:35.admin.identify changed: false (ack = true)
                            2021-12-12 19:34:35.012 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                            2021-12-12 19:34:35.026 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                            2021-12-12 19:34:35.044 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                            2021-12-12 19:34:35.072 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                            2021-12-12 19:34:35.091 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639334074965 (ack = true)
                            2021-12-12 19:34:35.221 - debug: homekit-controller.0 (1208696) Discovered BLE device up: ed:b2:df:50:92:d1/Eve Room 632D
                            2021-12-12 19:34:35.223 - debug: homekit-controller.0 (1208696) BLE-ED:B2:DF:50:92:D1 Discovered BLE device: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                            2021-12-12 19:34:35.223 - info: homekit-controller.0 (1208696) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                            2021-12-12 19:34:35.224 - debug: homekit-controller.0 (1208696) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                            2021-12-12 19:34:35.259 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                            2021-12-12 19:34:35.273 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                            2021-12-12 19:34:35.287 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                            2021-12-12 19:34:35.308 - debug: homekit-controller.0 (1208696) Discovered BLE device up: e7:21:2e:89:7e:35/Eve Degree 053B
                            2021-12-12 19:34:35.308 - debug: homekit-controller.0 (1208696) BLE-E7:21:2E:89:7E:35 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"e7:21:2e:89:7e:35","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"e7:21:2e:89:7e:35","ci":10,"availableToPair":false}
                            2021-12-12 19:34:35.309 - info: homekit-controller.0 (1208696) BLE-E7:21:2E:89:7E:35 (Eve Degree 053B) found without known pairing data and already paired: ignoring
                            2021-12-12 19:34:35.314 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                            2021-12-12 19:34:35.328 - debug: homekit-controller.0 (1208696) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639334075225 (ack = true)
                            • F Fortune95
                              @apollon77
                              @fortune95 Hi, ok sehr komisch.
                              Bitte Installiere mal die Version direkt vom GitHub. Danach bitte Instanz neu starten, Dann bitte das "gleiche" nochmal. Ich habe ne Kleinigkeit optimiert für BLE und auch mehr Logging eingebaut.
                              Nach dem pair bitte mindestens 45s warten ... falls bei der Initialisierung ein Fehler kommt dann sollte der jetzt nach 45s kommen (waren vorher 2 Minuten)
                                Fortune95
                                @apollon77 sagte in Test Alpha Homekit-Controller 0.0.x:
                                Nach dem Pairen und Neustart des Adapters wurde der Degree wieder als pairbar angezeigt.
                                Beim erneuten identifizieren, kam jetzt eine Fehlermeldung, das er ihn nicht erreichen konnte.
                                Laut dem Log konnte er das Gerät nicht ordentlich initialisieren und lief in ein Timeout.
                                Hier der dazugehörige Debug Log:
                                2021-12-13 05:29:51.938 - debug: homekit-controller.0 (1213619) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2021-12-13 05:29:52.007 - debug: homekit-controller.0 (1213619) Objects client ready ... initialize now
                                2021-12-13 05:29:52.012 - debug: homekit-controller.0 (1213619) Objects create System PubSub Client
                                2021-12-13 05:29:52.015 - debug: homekit-controller.0 (1213619) Objects create User PubSub Client
                                2021-12-13 05:29:52.017 - debug: homekit-controller.0 (1213619) Objects client initialize lua scripts
                                2021-12-13 05:29:52.060 - debug: homekit-controller.0 (1213619) Objects connected to redis: 127.0.0.1:9001
                                2021-12-13 05:29:52.086 - debug: homekit-controller.0 (1213619) objectDB connected
                                2021-12-13 05:29:52.089 - debug: homekit-controller.0 (1213619) Redis States: Use Redis connection: 127.0.0.1:6379
                                2021-12-13 05:29:52.116 - debug: homekit-controller.0 (1213619) States create System PubSub Client
                                2021-12-13 05:29:52.119 - debug: homekit-controller.0 (1213619) States create User PubSub Client
                                2021-12-13 05:29:52.143 - debug: homekit-controller.0 (1213619) States connected to redis: 127.0.0.1:6379
                                2021-12-13 05:29:52.144 - debug: homekit-controller.0 (1213619) statesDB connected
                                2021-12-13 05:29:52.444 - debug: homekit-controller.0 (1213619) Plugin sentry Initialize Plugin (enabled=true)
                                2021-12-13 05:29:52.917 - info: homekit-controller.0 (1213619) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.18.2, js-controller: 3.3.21
                                2021-12-13 05:29:53.205 - debug: homekit-controller.0 (1213619) Init 2 known devices without discovery ...
                                2021-12-13 05:29:53.207 - info: homekit-controller.0 (1213619) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                                2021-12-13 05:29:53.208 - debug: homekit-controller.0 (1213619) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                2021-12-13 05:29:53.223 - debug: homekit-controller.0 (1213619) state homekit-controller.0.info.connection changed: false (ack = true)
                                2021-12-13 05:29:53.262 - debug: homekit-controller.0 (1213619) Discovered IP device up: 0E:6C:79:7B:0B:81/Homebridge 4B75
                                2021-12-13 05:29:53.263 - debug: homekit-controller.0 (1213619) IP-0E:6C:79:7B:0B:81 Discovered IP device: {"name":"Homebridge 4B75","address":"192.168.12.219","port":51861,"c#":3,"ff":0,"id":"0E:6C:79:7B:0B:81","md":"homebridge","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                                2021-12-13 05:29:53.264 - info: homekit-controller.0 (1213619) IP-0E:6C:79:7B:0B:81 (Homebridge 4B75) found without known pairing data and already paired: ignoring
                                2021-12-13 05:29:53.268 - debug: homekit-controller.0 (1213619) Discovered IP device up: ab:34:18:95:31:5d/IOBroker 83D1
                                2021-12-13 05:29:53.268 - debug: homekit-controller.0 (1213619) IP-AB:34:18:95:31:5D Discovered IP device: {"name":"IOBroker 83D1","address":"192.168.12.219","port":34237,"c#":157,"ff":0,"id":"ab:34:18:95:31:5d","md":"not configured","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                                2021-12-13 05:29:53.269 - info: homekit-controller.0 (1213619) IP-AB:34:18:95:31:5D (IOBroker 83D1) found without known pairing data and already paired: ignoring
                                2021-12-13 05:29:53.275 - debug: homekit-controller.0 (1213619) Discovered IP device up: 58:47:6A:51:5B:FE/IN-8003FHD-PoE(c7)
                                2021-12-13 05:29:53.275 - debug: homekit-controller.0 (1213619) IP-58:47:6A:51:5B:FE Discovered IP device: {"name":"IN-8003FHD-PoE(c7)","address":"192.168.12.199","port":23657,"c#":1,"ff":0,"id":"58:47:6A:51:5B:FE","md":"IN-8003FHD-PoE","pv":"1.0","s#":1,"sf":0,"ci":17,"availableToPair":false}
                                2021-12-13 05:29:53.276 - info: homekit-controller.0 (1213619) IP-58:47:6A:51:5B:FE (IN-8003FHD-PoE(c7)) found without known pairing data and already paired: ignoring
                                2021-12-13 05:29:53.305 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                2021-12-13 05:29:53.317 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                                2021-12-13 05:29:53.329 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                                2021-12-13 05:29:53.355 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                                2021-12-13 05:29:53.369 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639369793210 (ack = true)
                                2021-12-13 05:29:53.386 - info: homekit-controller.0 (1213619) BLE-44:6F:8D:45:C2:A0 (Eve Degree 053B) found without pairing data but available for pairing: Create basic objects
                                2021-12-13 05:29:53.387 - debug: homekit-controller.0 (1213619) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"44:6f:8d:45:c2:a0","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"44:6f:8d:45:c2:a0","ci":10,"availableToPair":true}
                                2021-12-13 05:29:53.417 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.connectionType changed: BLE (ack = true)
                                2021-12-13 05:29:53.429 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.id changed: 44:6f:8d:45:c2:a0 (ack = true)
                                2021-12-13 05:29:53.441 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.connected changed: false (ack = true)
                                2021-12-13 05:29:53.460 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.admin.isPaired changed: false (ack = true)
                                2021-12-13 05:29:53.472 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.lastDiscovered changed: 1639369793387 (ack = true)
                                2021-12-13 05:29:53.915 - debug: homekit-controller.0 (1213619) Discovered BLE device up: ed:b2:df:50:92:d1/Eve Room 632D
                                2021-12-13 05:29:53.916 - debug: homekit-controller.0 (1213619) BLE-ED:B2:DF:50:92:D1 Discovered BLE device: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                2021-12-13 05:29:53.916 - info: homekit-controller.0 (1213619) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                                2021-12-13 05:29:53.917 - debug: homekit-controller.0 (1213619) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                2021-12-13 05:29:53.949 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                2021-12-13 05:29:53.961 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                                2021-12-13 05:29:53.980 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                                2021-12-13 05:29:54.003 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                                2021-12-13 05:29:54.017 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639369793917 (ack = true)
                                2021-12-13 05:29:54.030 - debug: homekit-controller.0 (1213619) Discovered BLE device up: 44:6f:8d:45:c2:a0/Eve Degree 053B
                                2021-12-13 05:29:54.030 - debug: homekit-controller.0 (1213619) BLE-44:6F:8D:45:C2:A0 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"44:6f:8d:45:c2:a0","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"44:6f:8d:45:c2:a0","ci":10,"availableToPair":true}
                                2021-12-13 05:29:54.031 - info: homekit-controller.0 (1213619) BLE-44:6F:8D:45:C2:A0 (Eve Degree 053B) found without pairing data but available for pairing: Create basic objects
                                2021-12-13 05:29:54.032 - debug: homekit-controller.0 (1213619) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"44:6f:8d:45:c2:a0","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"44:6f:8d:45:c2:a0","ci":10,"availableToPair":true}
                                2021-12-13 05:29:54.107 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.connectionType changed: BLE (ack = true)
                                2021-12-13 05:29:54.119 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.id changed: 44:6f:8d:45:c2:a0 (ack = true)
                                2021-12-13 05:29:54.133 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.connected changed: false (ack = true)
                                2021-12-13 05:29:54.155 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.admin.isPaired changed: false (ack = true)
                                2021-12-13 05:29:54.168 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.lastDiscovered changed: 1639369794033 (ack = true)
                                2021-12-13 05:30:11.800 - debug: homekit-controller.0 (1213619) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":243,"ack":false,"time":1639369811797},"_id":54081811})
                                2021-12-13 05:30:11.801 - debug: homekit-controller.0 (1213619) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-44:6F:8D:45:C2:A0","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false}]}
                                2021-12-13 05:30:11.803 - debug: homekit-controller.0 (1213619) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                2021-12-13 05:30:18.314 - debug: homekit-controller.0 (1213619) Message identify received: {"command":"identify","message":{"deviceId":"BLE-44:6F:8D:45:C2:A0"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-44:6F:8D:45:C2:A0"},"id":244,"ack":false,"time":1639369818312},"_id":54081812})
                                2021-12-13 05:30:18.315 - debug: homekit-controller.0 (1213619) Device BLE-44:6F:8D:45:C2:A0: Identify triggered
                                2021-12-13 05:30:20.787 - debug: homekit-controller.0 (1213619) Response to Command identify: {"success":true,"error":false}
                                2021-12-13 05:30:20.788 - debug: homekit-controller.0 (1213619) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                2021-12-13 05:30:22.303 - debug: homekit-controller.0 (1213619) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":245,"ack":false,"time":1639369822301},"_id":54081813})
                                2021-12-13 05:30:22.304 - debug: homekit-controller.0 (1213619) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-44:6F:8D:45:C2:A0","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false}]}
                                2021-12-13 05:30:22.305 - debug: homekit-controller.0 (1213619) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                2021-12-13 05:30:39.527 - debug: homekit-controller.0 (1213619) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-44:6F:8D:45:C2:A0","pin":"629-15-584"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-44:6F:8D:45:C2:A0","pin":"629-15-584"},"id":246,"ack":false,"time":1639369839523},"_id":54081814})
                                2021-12-13 05:30:42.413 - debug: homekit-controller.0 (1213619) BLE-44:6F:8D:45:C2:A0 Start Homekit Device Client initialization
                                2021-12-13 05:30:49.349 - info: homekit-controller.0 (1213619) BLE-44:6F:8D:45:C2:A0 Successfully paired to device.
                                2021-12-13 05:30:49.350 - debug: homekit-controller.0 (1213619) BLE-44:6F:8D:45:C2:A0 Start Homekit Device Client initialization
                                2021-12-13 05:30:49.351 - debug: homekit-controller.0 (1213619) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"44:6f:8d:45:c2:a0","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"44:6f:8d:45:c2:a0","ci":10,"availableToPair":false}
                                2021-12-13 05:30:49.368 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.admin.pairWithPin deleted
                                2021-12-13 05:30:49.397 - debug: homekit-controller.0 (1213619) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.admin.identify deleted
                                2021-12-13 05:30:49.410 - debug: homekit-controller.0 (1213619) Discovered BLE device changed: 44:6f:8d:45:c2:a0/Eve Degree 053B
                                2021-12-13 05:30:49.411 - debug: homekit-controller.0 (1213619) BLE-44:6F:8D:45:C2:A0 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"44:6f:8d:45:c2:a0","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"44:6f:8d:45:c2:a0","ci":10,"availableToPair":false}
                                2021-12-13 05:30:49.411 - debug: homekit-controller.0 (1213619) BLE-44:6F:8D:45:C2:A0 Device initialization already in progress ... ignore call
                                2021-12-13 05:30:49.416 - debug: homekit-controller.0 (1213619) BLE-44:6F:8D:45:C2:A0 Request Accessory information
                                2021-12-13 05:31:34.429 - info: homekit-controller.0 (1213619) BLE-44:6F:8D:45:C2:A0 Could not initialize device: TimeoutError:
                                at Object. (/opt/iobroker/node_modules/p-queue/dist/index.js:8:22)
                                at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                at Module.load (internal/modules/cjs/loader.js:950:32)
                                at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                at Module.require (internal/modules/cjs/loader.js:974:19)
                                at require (internal/modules/cjs/helpers.js:93:18)
                                at Object. (/opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js:38:35)
                                2021-12-13 05:31:34.430 - debug: homekit-controller.0 (1213619) Response to Command pairDevice: {"success":true,"error":false}
                                2021-12-13 05:31:34.432 - debug: homekit-controller.0 (1213619) sendTo "pairDevice" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                2021-12-13 05:31:36.473 - debug: homekit-controller.0 (1213619) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":247,"ack":false,"time":1639369896469},"_id":54081815})
                                2021-12-13 05:31:36.475 - debug: homekit-controller.0 (1213619) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-44:6F:8D:45:C2:A0","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":true},{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false}]}
                                2021-12-13 05:31:36.476 - debug: homekit-controller.0 (1213619) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                2021-12-13 05:34:09.295 - info: homekit-controller.0 (1213619) Got terminate signal TERMINATE_YOURSELF
                                2021-12-13 05:34:09.306 - info: homekit-controller.0 (1213619) terminating
                                2021-12-13 05:34:09.308 - debug: homekit-controller.0 (1213619) Plugin sentry destroyed
                                2021-12-13 05:34:09.309 - info: homekit-controller.0 (1213619) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-12-13 05:35:21.992 - debug: homekit-controller.0 (1213728) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2021-12-13 05:35:22.054 - debug: homekit-controller.0 (1213728) Objects client ready ... initialize now
                                2021-12-13 05:35:22.068 - debug: homekit-controller.0 (1213728) Objects create System PubSub Client
                                2021-12-13 05:35:22.072 - debug: homekit-controller.0 (1213728) Objects create User PubSub Client
                                2021-12-13 05:35:22.075 - debug: homekit-controller.0 (1213728) Objects client initialize lua scripts
                                2021-12-13 05:35:22.117 - debug: homekit-controller.0 (1213728) Objects connected to redis: 127.0.0.1:9001
                                2021-12-13 05:35:22.131 - debug: homekit-controller.0 (1213728) objectDB connected
                                2021-12-13 05:35:22.135 - debug: homekit-controller.0 (1213728) Redis States: Use Redis connection: 127.0.0.1:6379
                                2021-12-13 05:35:22.151 - debug: homekit-controller.0 (1213728) States create System PubSub Client
                                2021-12-13 05:35:22.153 - debug: homekit-controller.0 (1213728) States create User PubSub Client
                                2021-12-13 05:35:22.168 - debug: homekit-controller.0 (1213728) States connected to redis: 127.0.0.1:6379
                                2021-12-13 05:35:22.170 - debug: homekit-controller.0 (1213728) statesDB connected
                                2021-12-13 05:35:22.578 - debug: homekit-controller.0 (1213728) Plugin sentry Initialize Plugin (enabled=true)
                                2021-12-13 05:35:22.816 - info: homekit-controller.0 (1213728) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.18.2, js-controller: 3.3.21
                                2021-12-13 05:35:23.082 - debug: homekit-controller.0 (1213728) Init 2 known devices without discovery ...
                                2021-12-13 05:35:23.084 - info: homekit-controller.0 (1213728) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                                2021-12-13 05:35:23.086 - debug: homekit-controller.0 (1213728) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                2021-12-13 05:35:23.098 - debug: homekit-controller.0 (1213728) state homekit-controller.0.info.connection changed: false (ack = true)
                                2021-12-13 05:35:23.135 - debug: homekit-controller.0 (1213728) Discovered IP device up: ab:34:18:95:31:5d/IOBroker 83D1
                                2021-12-13 05:35:23.136 - debug: homekit-controller.0 (1213728) IP-AB:34:18:95:31:5D Discovered IP device: {"name":"IOBroker 83D1","address":"192.168.12.219","port":34237,"c#":157,"ff":0,"id":"ab:34:18:95:31:5d","md":"not configured","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                                2021-12-13 05:35:23.137 - info: homekit-controller.0 (1213728) IP-AB:34:18:95:31:5D (IOBroker 83D1) found without known pairing data and already paired: ignoring
                                2021-12-13 05:35:23.141 - debug: homekit-controller.0 (1213728) Discovered IP device up: 0E:6C:79:7B:0B:81/Homebridge 4B75
                                2021-12-13 05:35:23.141 - debug: homekit-controller.0 (1213728) IP-0E:6C:79:7B:0B:81 Discovered IP device: {"name":"Homebridge 4B75","address":"192.168.12.219","port":51861,"c#":3,"ff":0,"id":"0E:6C:79:7B:0B:81","md":"homebridge","pv":"1.1","s#":1,"sf":0,"ci":2,"availableToPair":false}
                                2021-12-13 05:35:23.142 - info: homekit-controller.0 (1213728) IP-0E:6C:79:7B:0B:81 (Homebridge 4B75) found without known pairing data and already paired: ignoring
                                2021-12-13 05:35:23.148 - debug: homekit-controller.0 (1213728) Discovered IP device up: 58:47:6A:51:5B:FE/IN-8003FHD-PoE(c7)
                                2021-12-13 05:35:23.149 - debug: homekit-controller.0 (1213728) IP-58:47:6A:51:5B:FE Discovered IP device: {"name":"IN-8003FHD-PoE(c7)","address":"192.168.12.199","port":23657,"c#":1,"ff":0,"id":"58:47:6A:51:5B:FE","md":"IN-8003FHD-PoE","pv":"1.0","s#":1,"sf":0,"ci":17,"availableToPair":false}
                                2021-12-13 05:35:23.149 - info: homekit-controller.0 (1213728) IP-58:47:6A:51:5B:FE (IN-8003FHD-PoE(c7)) found without known pairing data and already paired: ignoring
                                2021-12-13 05:35:23.162 - debug: homekit-controller.0 (1213728) Discovered BLE device up: 44:6f:8d:45:c2:a0/Eve Degree 053B
                                2021-12-13 05:35:23.163 - debug: homekit-controller.0 (1213728) BLE-44:6F:8D:45:C2:A0 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"44:6f:8d:45:c2:a0","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"44:6f:8d:45:c2:a0","ci":10,"availableToPair":false}
                                2021-12-13 05:35:23.163 - info: homekit-controller.0 (1213728) BLE-44:6F:8D:45:C2:A0 (Eve Degree 053B) found without known pairing data and already paired: ignoring
                                2021-12-13 05:35:23.185 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                2021-12-13 05:35:23.199 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                                2021-12-13 05:35:23.212 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                                2021-12-13 05:35:23.245 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                                2021-12-13 05:35:23.267 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639370123087 (ack = true)
                                2021-12-13 05:35:23.287 - info: homekit-controller.0 (1213728) BLE-44:6F:8D:45:C2:A0 (Eve Degree 053B) found without pairing data but available for pairing: Create basic objects
                                2021-12-13 05:35:23.288 - debug: homekit-controller.0 (1213728) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"44:6f:8d:45:c2:a0","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"44:6f:8d:45:c2:a0","ci":10,"availableToPair":true}
                                2021-12-13 05:35:23.321 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.connectionType changed: BLE (ack = true)
                                2021-12-13 05:35:23.333 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.id changed: 44:6f:8d:45:c2:a0 (ack = true)
                                2021-12-13 05:35:23.353 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.connected changed: false (ack = true)
                                2021-12-13 05:35:23.393 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.admin.isPaired changed: false (ack = true)
                                2021-12-13 05:35:23.426 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.info.lastDiscovered changed: 1639370123288 (ack = true)
                                2021-12-13 05:35:23.446 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.admin.pairWithPin changed: (ack = true)
                                2021-12-13 05:35:23.460 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-44:6F:8D:45:C2:A0.admin.identify changed: false (ack = true)
                                2021-12-13 05:35:25.454 - debug: homekit-controller.0 (1213728) Discovered BLE device up: ed:b2:df:50:92:d1/Eve Room 632D
                                2021-12-13 05:35:25.455 - debug: homekit-controller.0 (1213728) BLE-ED:B2:DF:50:92:D1 Discovered BLE device: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                2021-12-13 05:35:25.456 - info: homekit-controller.0 (1213728) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                                2021-12-13 05:35:25.457 - debug: homekit-controller.0 (1213728) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":1,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                2021-12-13 05:35:25.859 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                2021-12-13 05:35:25.872 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                                2021-12-13 05:35:25.884 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                                2021-12-13 05:35:25.911 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                                2021-12-13 05:35:25.925 - debug: homekit-controller.0 (1213728) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639370125457 (ack = true)
                                2021-12-13 05:35:55.790 - debug: homekit-controller.0 (1213728) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":257,"ack":false,"time":1639370155788},"_id":54081825})
                                2021-12-13 05:35:55.792 - debug: homekit-controller.0 (1213728) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-44:6F:8D:45:C2:A0","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false}]}
                                2021-12-13 05:35:55.793 - debug: homekit-controller.0 (1213728) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                2021-12-13 05:36:04.911 - debug: homekit-controller.0 (1213728) Message identify received: {"command":"identify","message":{"deviceId":"BLE-44:6F:8D:45:C2:A0"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-44:6F:8D:45:C2:A0"},"id":258,"ack":false,"time":1639370164909},"_id":54081826})
                                2021-12-13 05:36:04.913 - debug: homekit-controller.0 (1213728) Device BLE-44:6F:8D:45:C2:A0: Identify triggered
                                2021-12-13 05:36:04.917 - debug: homekit-controller.0 (1213728) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-44:6F:8D:45:C2:A0 because of error undefined: Cannot read property 'state' of undefined"}
                                2021-12-13 05:36:04.918 - debug: homekit-controller.0 (1213728) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                2021-12-13 05:36:09.205 - debug: homekit-controller.0 (1213728) Message identify received: {"command":"identify","message":{"deviceId":"BLE-44:6F:8D:45:C2:A0"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-44:6F:8D:45:C2:A0"},"id":259,"ack":false,"time":1639370169203},"_id":54081827})
                                2021-12-13 05:36:09.206 - debug: homekit-controller.0 (1213728) Device BLE-44:6F:8D:45:C2:A0: Identify triggered
                                2021-12-13 05:36:09.211 - debug: homekit-controller.0 (1213728) Response to Command identify: {"success":false,"error":"Cannot identify device BLE-44:6F:8D:45:C2:A0 because of error undefined: Cannot read property 'state' of undefined"}
                                2021-12-13 05:36:09.212 - debug: homekit-controller.0 (1213728) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                2021-12-13 05:36:11.983 - debug: homekit-controller.0 (1213728) Message identify received: {"command":"identify","message":{"deviceId":"BLE-ED:B2:DF:50:92:D1"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-ED:B2:DF:50:92:D1"},"id":260,"ack":false,"time":1639370171981},"_id":54081828})
                                2021-12-13 05:36:11.983 - debug: homekit-controller.0 (1213728) Device BLE-ED:B2:DF:50:92:D1: Identify triggered
                                2021-12-13 05:36:16.847 - debug: homekit-controller.0 (1213728) Response to Command identify: {"success":true,"error":false}
                                2021-12-13 05:36:16.848 - debug: homekit-controller.0 (1213728) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                2021-12-13 05:36:18.366 - debug: homekit-controller.0 (1213728) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":261,"ack":false,"time":1639370178364},"_id":54081829})
                                2021-12-13 05:36:18.366 - debug: homekit-controller.0 (1213728) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-44:6F:8D:45:C2:A0","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"IP-AB:34:18:95:31:5D","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IOBroker 83D1","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-0E:6C:79:7B:0B:81","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Homebridge 4B75","discoveredCategory":"Bridge","pairedWithThisInstance":false},{"id":"IP-58:47:6A:51:5B:FE","serviceType":"IP","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"IN-8003FHD-PoE(c7)","discoveredCategory":"IP Camera","pairedWithThisInstance":false}]}
                                2021-12-13 05:36:18.367 - debug: homekit-controller.0 (1213728) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                • F Fortune95
                                  @fortune95 Seeeehr komisch ... Bitte nochmal vom Github, manuell restarten und nochmal das ganze bitte
                                  F 1 Antwort Letzte Antwort
                                  • apollon77A apollon77
                                    Fortune95
                                    @apollon77
                                    Ich dachte ich hättes es über die Katze und dann Github richtig gemacht....🤔
                                    Hab es jetzt über URL und den Link vom Github Repository kopiert / installiert.
                                    2021-12-13 18:46:19.046 - debug: homekit-controller.0 (1219848) Redis States: Use Redis connection: 127.0.0.1:6379
                                    2021-12-13 18:46:19.087 - debug: homekit-controller.0 (1219848) States create System PubSub Client
                                    2021-12-13 18:46:19.089 - debug: homekit-controller.0 (1219848) States create User PubSub Client
                                    2021-12-13 18:46:19.097 - debug: homekit-controller.0 (1219848) States connected to redis: 127.0.0.1:6379
                                    2021-12-13 18:46:19.098 - debug: homekit-controller.0 (1219848) statesDB connected
                                    2021-12-13 18:46:19.427 - debug: homekit-controller.0 (1219848) Plugin sentry Initialize Plugin (enabled=true)
                                    2021-12-13 18:46:19.828 - info: homekit-controller.0 (1219848) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.18.2, js-controller: 3.3.21
                                    2021-12-13 18:46:20.168 - debug: homekit-controller.0 (1219848) state homekit-controller.0.info.connection changed: false (ack = true)
                                    2021-12-13 18:46:20.465 - debug: homekit-controller.0 (1219848) Discovered BLE device up: ed:b2:df:50:92:d1/Eve Room 632D
                                    2021-12-13 18:46:20.466 - debug: homekit-controller.0 (1219848) BLE-ED:B2:DF:50:92:D1 Discovered BLE device: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":2,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                    2021-12-13 18:46:20.468 - info: homekit-controller.0 (1219848) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                                    2021-12-13 18:46:20.470 - debug: homekit-controller.0 (1219848) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":2,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                    2021-12-13 18:46:20.509 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                    2021-12-13 18:46:20.515 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                    2021-12-13 18:46:20.532 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                                    2021-12-13 18:46:20.557 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                                    2021-12-13 18:46:20.612 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                                    2021-12-13 18:46:20.636 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639417580471 (ack = true)
                                    2021-12-13 18:46:20.653 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.pairWithPin changed: (ack = true)
                                    2021-12-13 18:46:20.675 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.identify changed: false (ack = true)
                                    2021-12-13 18:46:21.278 - debug: homekit-controller.0 (1219848) Discovered BLE device up: 8e:94:a7:96:8f:c1/Eve Degree 053B
                                    2021-12-13 18:46:21.279 - debug: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"8e:94:a7:96:8f:c1","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"8e:94:a7:96:8f:c1","ci":10,"availableToPair":true}
                                    2021-12-13 18:46:21.280 - info: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 (Eve Degree 053B) found without pairing data but available for pairing: Create basic objects
                                    2021-12-13 18:46:21.280 - debug: homekit-controller.0 (1219848) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"8e:94:a7:96:8f:c1","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"8e:94:a7:96:8f:c1","ci":10,"availableToPair":true}
                                    2021-12-13 18:46:21.317 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.info.connectionType changed: BLE (ack = true)
                                    2021-12-13 18:46:21.323 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.info.connectionType changed: BLE (ack = true)
                                    2021-12-13 18:46:21.339 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.info.id changed: 8e:94:a7:96:8f:c1 (ack = true)
                                    2021-12-13 18:46:21.353 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.info.connected changed: false (ack = true)
                                    2021-12-13 18:46:21.373 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.admin.isPaired changed: false (ack = true)
                                    2021-12-13 18:46:21.387 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.info.lastDiscovered changed: 1639417581281 (ack = true)
                                    2021-12-13 18:46:21.400 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.admin.pairWithPin changed: (ack = true)
                                    2021-12-13 18:46:21.412 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.admin.identify changed: false (ack = true)
                                    2021-12-13 18:47:27.605 - debug: homekit-controller.0 (1219848) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":341,"ack":false,"time":1639417647603},"_id":54081916})
                                    2021-12-13 18:47:27.607 - debug: homekit-controller.0 (1219848) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-8E:94:A7:96:8F:C1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                    2021-12-13 18:47:27.608 - debug: homekit-controller.0 (1219848) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                    2021-12-13 18:47:31.324 - debug: homekit-controller.0 (1219848) Message identify received: {"command":"identify","message":{"deviceId":"BLE-8E:94:A7:96:8F:C1"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-8E:94:A7:96:8F:C1"},"id":342,"ack":false,"time":1639417651322},"_id":54081917})
                                    2021-12-13 18:47:31.325 - debug: homekit-controller.0 (1219848) Device BLE-8E:94:A7:96:8F:C1: Identify triggered
                                    2021-12-13 18:47:34.244 - debug: homekit-controller.0 (1219848) Response to Command identify: {"success":true,"error":false}
                                    2021-12-13 18:47:34.245 - debug: homekit-controller.0 (1219848) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                    2021-12-13 18:47:35.752 - debug: homekit-controller.0 (1219848) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":343,"ack":false,"time":1639417655751},"_id":54081918})
                                    2021-12-13 18:47:35.753 - debug: homekit-controller.0 (1219848) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-8E:94:A7:96:8F:C1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                    2021-12-13 18:47:35.753 - debug: homekit-controller.0 (1219848) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                    2021-12-13 18:47:53.203 - debug: homekit-controller.0 (1219848) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-8E:94:A7:96:8F:C1","pin":"629-15-584"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-8E:94:A7:96:8F:C1","pin":"629-15-584"},"id":344,"ack":false,"time":1639417673202},"_id":54081919})
                                    2021-12-13 18:47:55.853 - debug: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 Start Homekit Device Client initialization
                                    2021-12-13 18:48:04.076 - info: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 Successfully paired to device.
                                    2021-12-13 18:48:04.077 - debug: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 Start Homekit Device Client initialization
                                    2021-12-13 18:48:04.078 - debug: homekit-controller.0 (1219848) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"8e:94:a7:96:8f:c1","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"8e:94:a7:96:8f:c1","ci":10,"availableToPair":false}
                                    2021-12-13 18:48:04.103 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.admin.pairWithPin deleted
                                    2021-12-13 18:48:04.117 - debug: homekit-controller.0 (1219848) Discovered BLE device changed: 8e:94:a7:96:8f:c1/Eve Degree 053B
                                    2021-12-13 18:48:04.119 - debug: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"8e:94:a7:96:8f:c1","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"8e:94:a7:96:8f:c1","ci":10,"availableToPair":false}
                                    2021-12-13 18:48:04.121 - debug: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 Device initialization already in progress ... ignore call
                                    2021-12-13 18:48:04.131 - debug: homekit-controller.0 (1219848) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.admin.identify deleted
                                    2021-12-13 18:48:04.135 - debug: homekit-controller.0 (1219848) Discovered BLE device changed: 8e:94:a7:96:8f:c1/Eve Degree 053B
                                    2021-12-13 18:48:04.136 - debug: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"8e:94:a7:96:8f:c1","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"8e:94:a7:96:8f:c1","ci":10,"availableToPair":false}
                                    2021-12-13 18:48:04.137 - debug: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 Device initialization already in progress ... ignore call
                                    2021-12-13 18:48:04.146 - debug: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 Request Accessory information
                                    2021-12-13 18:48:49.156 - info: homekit-controller.0 (1219848) BLE-8E:94:A7:96:8F:C1 Could not initialize device: TimeoutError:
                                    2021-12-13 18:48:49.157 - debug: homekit-controller.0 (1219848) Response to Command pairDevice: {"success":true,"error":false}
                                    2021-12-13 18:48:49.158 - debug: homekit-controller.0 (1219848) sendTo "pairDevice" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                    2021-12-13 18:50:40.570 - info: homekit-controller.0 (1219848) Got terminate signal TERMINATE_YOURSELF
                                    2021-12-13 18:50:40.574 - info: homekit-controller.0 (1219848) terminating
                                    2021-12-13 18:50:40.576 - debug: homekit-controller.0 (1219848) Plugin sentry destroyed
                                    2021-12-13 18:50:40.577 - info: homekit-controller.0 (1219848) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2021-12-13 18:52:05.335 - debug: homekit-controller.0 (1219909) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2021-12-13 18:52:05.388 - debug: homekit-controller.0 (1219909) Objects client ready ... initialize now
                                    2021-12-13 18:52:05.394 - debug: homekit-controller.0 (1219909) Objects create System PubSub Client
                                    2021-12-13 18:52:05.399 - debug: homekit-controller.0 (1219909) Objects create User PubSub Client
                                    2021-12-13 18:52:05.404 - debug: homekit-controller.0 (1219909) Objects client initialize lua scripts
                                    2021-12-13 18:52:05.455 - debug: homekit-controller.0 (1219909) Objects connected to redis: 127.0.0.1:9001
                                    2021-12-13 18:52:05.469 - debug: homekit-controller.0 (1219909) objectDB connected
                                    2021-12-13 18:52:05.473 - debug: homekit-controller.0 (1219909) Redis States: Use Redis connection: 127.0.0.1:6379
                                    2021-12-13 18:52:05.489 - debug: homekit-controller.0 (1219909) States create System PubSub Client
                                    2021-12-13 18:52:05.491 - debug: homekit-controller.0 (1219909) States create User PubSub Client
                                    2021-12-13 18:52:05.505 - debug: homekit-controller.0 (1219909) States connected to redis: 127.0.0.1:6379
                                    2021-12-13 18:52:05.507 - debug: homekit-controller.0 (1219909) statesDB connected
                                    2021-12-13 18:52:05.853 - debug: homekit-controller.0 (1219909) Plugin sentry Initialize Plugin (enabled=true)
                                    2021-12-13 18:52:06.096 - info: homekit-controller.0 (1219909) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.18.2, js-controller: 3.3.21
                                    2021-12-13 18:52:06.351 - debug: homekit-controller.0 (1219909) Init 2 known devices without discovery ...
                                    2021-12-13 18:52:06.353 - info: homekit-controller.0 (1219909) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                                    2021-12-13 18:52:06.354 - debug: homekit-controller.0 (1219909) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":2,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                    2021-12-13 18:52:06.367 - debug: homekit-controller.0 (1219909) state homekit-controller.0.info.connection changed: false (ack = true)
                                    2021-12-13 18:52:06.405 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                    2021-12-13 18:52:06.417 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                                    2021-12-13 18:52:06.431 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                                    2021-12-13 18:52:06.461 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                                    2021-12-13 18:52:06.473 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639417926356 (ack = true)
                                    2021-12-13 18:52:06.497 - info: homekit-controller.0 (1219909) BLE-8E:94:A7:96:8F:C1 (Eve Degree 053B) found without pairing data but available for pairing: Create basic objects
                                    2021-12-13 18:52:06.499 - debug: homekit-controller.0 (1219909) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"8e:94:a7:96:8f:c1","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"8e:94:a7:96:8f:c1","ci":10,"availableToPair":true}
                                    2021-12-13 18:52:06.538 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.info.connectionType changed: BLE (ack = true)
                                    2021-12-13 18:52:06.561 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.info.id changed: 8e:94:a7:96:8f:c1 (ack = true)
                                    2021-12-13 18:52:06.579 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.info.connected changed: false (ack = true)
                                    2021-12-13 18:52:06.604 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.admin.isPaired changed: false (ack = true)
                                    2021-12-13 18:52:06.625 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.info.lastDiscovered changed: 1639417926501 (ack = true)
                                    2021-12-13 18:52:06.668 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.admin.pairWithPin changed: (ack = true)
                                    2021-12-13 18:52:06.686 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-8E:94:A7:96:8F:C1.admin.identify changed: false (ack = true)
                                    2021-12-13 18:52:06.907 - debug: homekit-controller.0 (1219909) Discovered BLE device up: 8e:94:a7:96:8f:c1/Eve Degree 053B
                                    2021-12-13 18:52:06.908 - debug: homekit-controller.0 (1219909) BLE-8E:94:A7:96:8F:C1 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"8e:94:a7:96:8f:c1","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"8e:94:a7:96:8f:c1","ci":10,"availableToPair":false}
                                    2021-12-13 18:52:06.909 - info: homekit-controller.0 (1219909) BLE-8E:94:A7:96:8F:C1 (Eve Degree 053B) found without known pairing data and already paired: ignoring
                                    2021-12-13 18:52:07.400 - debug: homekit-controller.0 (1219909) Discovered BLE device up: ed:b2:df:50:92:d1/Eve Room 632D
                                    2021-12-13 18:52:07.401 - debug: homekit-controller.0 (1219909) BLE-ED:B2:DF:50:92:D1 Discovered BLE device: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":2,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                    2021-12-13 18:52:07.401 - info: homekit-controller.0 (1219909) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                                    2021-12-13 18:52:07.402 - debug: homekit-controller.0 (1219909) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":2,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                    2021-12-13 18:52:07.443 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                    2021-12-13 18:52:07.456 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                                    2021-12-13 18:52:07.468 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                                    2021-12-13 18:52:07.494 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                                    2021-12-13 18:52:07.510 - debug: homekit-controller.0 (1219909) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639417927402 (ack = true)
                                    2021-12-13 18:53:05.475 - debug: homekit-controller.0 (1219909) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":359,"ack":false,"time":1639417985472},"_id":54081934})
                                    2021-12-13 18:53:05.476 - debug: homekit-controller.0 (1219909) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-8E:94:A7:96:8F:C1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                    2021-12-13 18:53:05.478 - debug: homekit-controller.0 (1219909) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                    • F Fortune95
                                      @apollon77
                                      @fortune95 Meehhh ... da war was nicht aktuell auf GitHub ... Mega sorry ... Nochmal bitte :-)
                                        Fortune95
                                        #66
                                        @apollon77
                                        Hi, erstmal velen Dank für das Forschen.
                                        Hier das neue Log:
                                        2021-12-14 05:46:23.426 - info: homekit-controller.0 (1225088) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2021-12-14 05:46:27.881 - debug: homekit-controller.0 (1225142) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2021-12-14 05:46:27.984 - debug: homekit-controller.0 (1225142) Objects client ready ... initialize now
                                        2021-12-14 05:46:28.013 - debug: homekit-controller.0 (1225142) Objects create System PubSub Client
                                        2021-12-14 05:46:28.016 - debug: homekit-controller.0 (1225142) Objects create User PubSub Client
                                        2021-12-14 05:46:28.018 - debug: homekit-controller.0 (1225142) Objects client initialize lua scripts
                                        2021-12-14 05:46:28.070 - debug: homekit-controller.0 (1225142) Objects connected to redis: 127.0.0.1:9001
                                        2021-12-14 05:46:28.108 - debug: homekit-controller.0 (1225142) objectDB connected
                                        2021-12-14 05:46:28.111 - debug: homekit-controller.0 (1225142) Redis States: Use Redis connection: 127.0.0.1:6379
                                        2021-12-14 05:46:28.123 - debug: homekit-controller.0 (1225142) States create System PubSub Client
                                        2021-12-14 05:46:28.125 - debug: homekit-controller.0 (1225142) States create User PubSub Client
                                        2021-12-14 05:46:28.137 - debug: homekit-controller.0 (1225142) States connected to redis: 127.0.0.1:6379
                                        2021-12-14 05:46:28.138 - debug: homekit-controller.0 (1225142) statesDB connected
                                        2021-12-14 05:46:28.919 - debug: homekit-controller.0 (1225142) Plugin sentry Initialize Plugin (enabled=true)
                                        2021-12-14 05:46:29.194 - info: homekit-controller.0 (1225142) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.18.2, js-controller: 3.3.21
                                        2021-12-14 05:46:29.444 - debug: homekit-controller.0 (1225142) state homekit-controller.0.info.connection changed: false (ack = true)
                                        2021-12-14 05:46:29.992 - debug: homekit-controller.0 (1225142) Discovered BLE device up: d9:b3:d5:c9:e2:a9/Eve Degree 053B
                                        2021-12-14 05:46:29.993 - debug: homekit-controller.0 (1225142) BLE-D9:B3:D5:C9:E2:A9 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"d9:b3:d5:c9:e2:a9","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"d9:b3:d5:c9:e2:a9","ci":10,"availableToPair":true}
                                        2021-12-14 05:46:29.995 - info: homekit-controller.0 (1225142) BLE-D9:B3:D5:C9:E2:A9 (Eve Degree 053B) found without pairing data but available for pairing: Create basic objects
                                        2021-12-14 05:46:29.996 - debug: homekit-controller.0 (1225142) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"d9:b3:d5:c9:e2:a9","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"d9:b3:d5:c9:e2:a9","ci":10,"availableToPair":true}
                                        2021-12-14 05:46:30.047 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.info.connectionType changed: BLE (ack = true)
                                        2021-12-14 05:46:30.052 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.info.connectionType changed: BLE (ack = true)
                                        2021-12-14 05:46:30.066 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.info.id changed: d9:b3:d5:c9:e2:a9 (ack = true)
                                        2021-12-14 05:46:30.083 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.info.connected changed: false (ack = true)
                                        2021-12-14 05:46:30.122 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.admin.isPaired changed: false (ack = true)
                                        2021-12-14 05:46:30.135 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.info.lastDiscovered changed: 1639457189998 (ack = true)
                                        2021-12-14 05:46:30.150 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.admin.pairWithPin changed: (ack = true)
                                        2021-12-14 05:46:30.164 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.admin.identify changed: false (ack = true)
                                        2021-12-14 05:46:30.512 - debug: homekit-controller.0 (1225142) Discovered BLE device up: ed:b2:df:50:92:d1/Eve Room 632D
                                        2021-12-14 05:46:30.513 - debug: homekit-controller.0 (1225142) BLE-ED:B2:DF:50:92:D1 Discovered BLE device: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":2,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                        2021-12-14 05:46:30.513 - info: homekit-controller.0 (1225142) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                                        2021-12-14 05:46:30.514 - debug: homekit-controller.0 (1225142) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":2,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                        2021-12-14 05:46:30.554 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                        2021-12-14 05:46:30.559 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                        2021-12-14 05:46:30.572 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                                        2021-12-14 05:46:30.586 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                                        2021-12-14 05:46:30.606 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                                        2021-12-14 05:46:30.619 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639457190514 (ack = true)
                                        2021-12-14 05:46:30.637 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.pairWithPin changed: (ack = true)
                                        2021-12-14 05:46:30.650 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.identify changed: false (ack = true)
                                        2021-12-14 05:46:58.424 - debug: homekit-controller.0 (1225142) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":410,"ack":false,"time":1639457218420},"_id":54081989})
                                        2021-12-14 05:46:58.426 - debug: homekit-controller.0 (1225142) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-D9:B3:D5:C9:E2:A9","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                        2021-12-14 05:46:58.428 - debug: homekit-controller.0 (1225142) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                        2021-12-14 05:47:02.996 - debug: homekit-controller.0 (1225142) Message identify received: {"command":"identify","message":{"deviceId":"BLE-D9:B3:D5:C9:E2:A9"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-D9:B3:D5:C9:E2:A9"},"id":411,"ack":false,"time":1639457222994},"_id":54081990})
                                        2021-12-14 05:47:02.997 - debug: homekit-controller.0 (1225142) Device BLE-D9:B3:D5:C9:E2:A9: Identify triggered
                                        2021-12-14 05:47:05.734 - debug: homekit-controller.0 (1225142) Response to Command identify: {"success":true,"error":false}
                                        2021-12-14 05:47:05.735 - debug: homekit-controller.0 (1225142) sendTo "identify" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                        2021-12-14 05:47:07.242 - debug: homekit-controller.0 (1225142) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":412,"ack":false,"time":1639457227240},"_id":54081991})
                                        2021-12-14 05:47:07.245 - debug: homekit-controller.0 (1225142) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-D9:B3:D5:C9:E2:A9","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                        2021-12-14 05:47:07.246 - debug: homekit-controller.0 (1225142) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                        2021-12-14 05:47:28.884 - debug: homekit-controller.0 (1225142) Message pairDevice received: {"command":"pairDevice","message":{"deviceId":"BLE-D9:B3:D5:C9:E2:A9","pin":"629-15-584"},"from":"system.adapter.admin.0","callback":{"message":{"deviceId":"BLE-D9:B3:D5:C9:E2:A9","pin":"629-15-584"},"id":413,"ack":false,"time":1639457248883},"_id":54081992})
                                        2021-12-14 05:47:32.502 - debug: homekit-controller.0 (1225142) BLE-D9:B3:D5:C9:E2:A9 Start Homekit Device Client initialization
                                        2021-12-14 05:47:39.499 - info: homekit-controller.0 (1225142) BLE-D9:B3:D5:C9:E2:A9 Successfully paired to device: {"AccessoryPairingID":"44393a42333a44353a43393a45323a4139","AccessoryLTPK":"becc10cfe0e46c317585dee9831feed81f420226be1bfe25eddc586d5f46e3b7","iOSDevicePairingID":"30303235343564382d373936622d343837322d383230612d326238666163313536656536","iOSDeviceLTSK":"e2cb7d27acdcd9daece11d8c733608b247f136386a6cb4964832b6a796bad95e1316c29f6ffb03bc5d76fa9636994ec13ec5b4f84c2cab4a37ab41a677e0956f","iOSDeviceLTPK":"1316c29f6ffb03bc5d76fa9636994ec13ec5b4f84c2cab4a37ab41a677e0956f"}
                                        2021-12-14 05:47:39.503 - debug: homekit-controller.0 (1225142) BLE-D9:B3:D5:C9:E2:A9 Start Homekit Device Client initialization
                                        2021-12-14 05:47:39.507 - debug: homekit-controller.0 (1225142) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"d9:b3:d5:c9:e2:a9","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"d9:b3:d5:c9:e2:a9","ci":10,"availableToPair":false}
                                        2021-12-14 05:47:39.540 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.admin.pairWithPin deleted
                                        2021-12-14 05:47:39.547 - debug: homekit-controller.0 (1225142) Discovered BLE device changed: d9:b3:d5:c9:e2:a9/Eve Degree 053B
                                        2021-12-14 05:47:39.551 - debug: homekit-controller.0 (1225142) BLE-D9:B3:D5:C9:E2:A9 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"d9:b3:d5:c9:e2:a9","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"d9:b3:d5:c9:e2:a9","ci":10,"availableToPair":false}
                                        2021-12-14 05:47:39.552 - debug: homekit-controller.0 (1225142) BLE-D9:B3:D5:C9:E2:A9 Device initialization already in progress ... ignore call
                                        2021-12-14 05:47:39.595 - debug: homekit-controller.0 (1225142) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.admin.identify deleted
                                        2021-12-14 05:47:39.611 - debug: homekit-controller.0 (1225142) BLE-D9:B3:D5:C9:E2:A9 Request Accessory information
                                        2021-12-14 05:48:24.622 - info: homekit-controller.0 (1225142) BLE-D9:B3:D5:C9:E2:A9 Could not initialize device: TimeoutError:
                                        2021-12-14 05:48:24.623 - debug: homekit-controller.0 (1225142) Response to Command pairDevice: {"success":true,"error":false}
                                        2021-12-14 05:48:24.623 - debug: homekit-controller.0 (1225142) sendTo "pairDevice" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                        2021-12-14 05:50:18.290 - info: homekit-controller.0 (1225142) Got terminate signal TERMINATE_YOURSELF
                                        2021-12-14 05:50:18.292 - info: homekit-controller.0 (1225142) terminating
                                        2021-12-14 05:50:18.293 - debug: homekit-controller.0 (1225142) Plugin sentry destroyed
                                        2021-12-14 05:50:18.295 - info: homekit-controller.0 (1225142) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2021-12-14 05:52:10.845 - debug: homekit-controller.0 (1225204) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2021-12-14 05:52:10.890 - debug: homekit-controller.0 (1225204) Objects client ready ... initialize now
                                        2021-12-14 05:52:10.897 - debug: homekit-controller.0 (1225204) Objects create System PubSub Client
                                        2021-12-14 05:52:10.923 - debug: homekit-controller.0 (1225204) Objects create User PubSub Client
                                        2021-12-14 05:52:10.926 - debug: homekit-controller.0 (1225204) Objects client initialize lua scripts
                                        2021-12-14 05:52:10.986 - debug: homekit-controller.0 (1225204) Objects connected to redis: 127.0.0.1:9001
                                        2021-12-14 05:52:11.012 - debug: homekit-controller.0 (1225204) objectDB connected
                                        2021-12-14 05:52:11.016 - debug: homekit-controller.0 (1225204) Redis States: Use Redis connection: 127.0.0.1:6379
                                        2021-12-14 05:52:11.030 - debug: homekit-controller.0 (1225204) States create System PubSub Client
                                        2021-12-14 05:52:11.032 - debug: homekit-controller.0 (1225204) States create User PubSub Client
                                        2021-12-14 05:52:11.065 - debug: homekit-controller.0 (1225204) States connected to redis: 127.0.0.1:6379
                                        2021-12-14 05:52:11.066 - debug: homekit-controller.0 (1225204) statesDB connected
                                        2021-12-14 05:52:11.379 - debug: homekit-controller.0 (1225204) Plugin sentry Initialize Plugin (enabled=true)
                                        2021-12-14 05:52:11.639 - info: homekit-controller.0 (1225204) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.homekit-controller, node: v14.18.2, js-controller: 3.3.21
                                        2021-12-14 05:52:11.906 - debug: homekit-controller.0 (1225204) Init 2 known devices without discovery ...
                                        2021-12-14 05:52:11.907 - debug: homekit-controller.0 (1225204) Init BLE-D9:B3:D5:C9:E2:A9 as known device
                                        2021-12-14 05:52:11.908 - info: homekit-controller.0 (1225204) BLE-D9:B3:D5:C9:E2:A9 (Eve Degree 053B) found without pairing data but available for pairing: Create basic objects
                                        2021-12-14 05:52:11.910 - debug: homekit-controller.0 (1225204) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"d9:b3:d5:c9:e2:a9","ACID":10,"GSN":1,"CN":3,"CV":2,"c#":3,"id":"d9:b3:d5:c9:e2:a9","ci":10,"availableToPair":true}
                                        2021-12-14 05:52:11.917 - debug: homekit-controller.0 (1225204) state homekit-controller.0.info.connection changed: false (ack = true)
                                        2021-12-14 05:52:11.954 - debug: homekit-controller.0 (1225204) Discovered BLE device up: d9:b3:d5:c9:e2:a9/Eve Degree 053B
                                        2021-12-14 05:52:11.956 - debug: homekit-controller.0 (1225204) BLE-D9:B3:D5:C9:E2:A9 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"d9:b3:d5:c9:e2:a9","ACID":10,"GSN":2,"CN":3,"CV":2,"c#":3,"id":"d9:b3:d5:c9:e2:a9","ci":10,"availableToPair":false}
                                        2021-12-14 05:52:11.956 - debug: homekit-controller.0 (1225204) BLE-D9:B3:D5:C9:E2:A9 Device initialization already in progress ... ignore call
                                        2021-12-14 05:52:11.972 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.info.connectionType changed: BLE (ack = true)
                                        2021-12-14 05:52:11.985 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.info.id changed: d9:b3:d5:c9:e2:a9 (ack = true)
                                        2021-12-14 05:52:11.999 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.info.connected changed: false (ack = true)
                                        2021-12-14 05:52:12.020 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.admin.isPaired changed: false (ack = true)
                                        2021-12-14 05:52:12.034 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.info.lastDiscovered changed: 1639457531911 (ack = true)
                                        2021-12-14 05:52:12.063 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.admin.pairWithPin changed: (ack = true)
                                        2021-12-14 05:52:12.083 - debug: homekit-controller.0 (1225204) Init BLE-ED:B2:DF:50:92:D1 as known device
                                        2021-12-14 05:52:12.085 - info: homekit-controller.0 (1225204) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                                        2021-12-14 05:52:12.087 - debug: homekit-controller.0 (1225204) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":2,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                        2021-12-14 05:52:12.091 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.admin.identify changed: false (ack = true)
                                        2021-12-14 05:52:12.129 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                        2021-12-14 05:52:12.142 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                                        2021-12-14 05:52:12.156 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                                        2021-12-14 05:52:12.179 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                                        2021-12-14 05:52:12.191 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639457532088 (ack = true)
                                        2021-12-14 05:52:12.358 - debug: homekit-controller.0 (1225204) Discovered BLE device up: ed:b2:df:50:92:d1/Eve Room 632D
                                        2021-12-14 05:52:12.359 - debug: homekit-controller.0 (1225204) BLE-ED:B2:DF:50:92:D1 Discovered BLE device: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":2,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                        2021-12-14 05:52:12.359 - info: homekit-controller.0 (1225204) BLE-ED:B2:DF:50:92:D1 (Eve Room 632D) found without pairing data but available for pairing: Create basic objects
                                        2021-12-14 05:52:12.360 - debug: homekit-controller.0 (1225204) Service: {"name":"Eve Room 632D","CoID":76,"TY":6,"AIL":49,"SF":1,"DeviceID":"ed:b2:df:50:92:d1","ACID":10,"GSN":2,"CN":1,"CV":2,"c#":1,"id":"ed:b2:df:50:92:d1","ci":10,"availableToPair":true}
                                        2021-12-14 05:52:12.389 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connectionType changed: BLE (ack = true)
                                        2021-12-14 05:52:12.401 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.id changed: ed:b2:df:50:92:d1 (ack = true)
                                        2021-12-14 05:52:12.413 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.connected changed: false (ack = true)
                                        2021-12-14 05:52:12.434 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.admin.isPaired changed: false (ack = true)
                                        2021-12-14 05:52:12.447 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-ED:B2:DF:50:92:D1.info.lastDiscovered changed: 1639457532360 (ack = true)
                                        2021-12-14 05:52:38.784 - debug: homekit-controller.0 (1225204) Message getDiscoveredDevices received: {"command":"getDiscoveredDevices","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":421,"ack":false,"time":1639457558781},"_id":54082000})
                                        2021-12-14 05:52:38.785 - debug: homekit-controller.0 (1225204) Response to Command getDiscoveredDevices: {"success":true,"error":false,"devices":[{"id":"BLE-ED:B2:DF:50:92:D1","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":true,"discoveredName":"Eve Room 632D","discoveredCategory":"Sensor","pairedWithThisInstance":false},{"id":"BLE-D9:B3:D5:C9:E2:A9","serviceType":"BLE","connected":false,"discovered":true,"availableToPair":false,"discoveredName":"Eve Degree 053B","discoveredCategory":"Sensor","pairedWithThisInstance":false}]}
                                        2021-12-14 05:52:38.786 - debug: homekit-controller.0 (1225204) sendTo "getDiscoveredDevices" to system.adapter.admin.0 from system.adapter.homekit-controller.0
                                        2021-12-14 05:55:38.779 - debug: homekit-controller.0 (1225204) Discovered BLE device changed: d9:b3:d5:c9:e2:a9/Eve Degree 053B
                                        2021-12-14 05:55:38.779 - debug: homekit-controller.0 (1225204) BLE-D9:B3:D5:C9:E2:A9 Discovered BLE device: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"d9:b3:d5:c9:e2:a9","ACID":10,"GSN":3,"CN":3,"CV":2,"c#":3,"id":"d9:b3:d5:c9:e2:a9","ci":10,"availableToPair":false}
                                        2021-12-14 05:55:38.781 - info: homekit-controller.0 (1225204) BLE-D9:B3:D5:C9:E2:A9 Found stored Pairing data, try it ...
                                        2021-12-14 05:55:38.782 - debug: homekit-controller.0 (1225204) BLE-D9:B3:D5:C9:E2:A9 Start Homekit Device Client initialization
                                        2021-12-14 05:55:38.784 - debug: homekit-controller.0 (1225204) Service: {"name":"Eve Degree 053B","CoID":76,"TY":6,"AIL":49,"SF":0,"DeviceID":"d9:b3:d5:c9:e2:a9","ACID":10,"GSN":3,"CN":3,"CV":2,"c#":3,"id":"d9:b3:d5:c9:e2:a9","ci":10,"availableToPair":false}
                                        2021-12-14 05:55:38.810 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.admin.pairWithPin deleted
                                        2021-12-14 05:55:38.845 - debug: homekit-controller.0 (1225204) state homekit-controller.0.BLE-D9:B3:D5:C9:E2:A9.admin.identify deleted
                                        2021-12-14 05:55:38.861 - debug: homekit-controller.0 (1225204) BLE-D9:B3:D5:C9:E2:A9 Request Accessory information
                                        2021-12-14 05:56:23.872 - info: homekit-controller.0 (1225204) BLE-D9:B3:D5:C9:E2:A9 Could not initialize device: TimeoutError:
                                        • F Fortune95
                                          @apollon77
                                          Hier das neue Log:
                                          #67
                                          @fortune95 Also die realität ist gerade das das gerät nicht auf die Anfrage antwortet seine Accessory Daten rauszurücken.
                                          Dann fangen wir jetzt mal etwas mehr tricky an. Jetzt brauchen wir richtiges Debug:
                                          • Adapterinstanz stoppen im Admin
                                          • mach eine Shell auf auf den rechner
                                          • DEBUG=hap* node /opt/iobroker/node_modules/iobroker.homekit-controller/build/main.js 0 --debug --logs
                                          • Dann im Admin in de Adapter Konfig gehen (adapter nicht dort nochmal starten ... der läuft schon auf der Kommendozeile) und einmal pairen und warten bis wieder fehler kommt und so
                                          • Dann Log von der Shell bitte posten. Da sollte mehr drin sein. gern als File hier anhängen
                                          • Zusätzlich bitte im Admin unter Objekte mal das Device Objekt siuchen von dem Gerät und da rechts auf den Stift klicken und auch das JSON posten was da angezeigt wird unter "Raw" oder so
                                          Uuuuund -weil ich das noch nciht gefragt hatten - das BLE Device/Stick wird nicht zufällig noch von nem anderen Adapter genutzt oder so? Also bitte sicherstellen das das BLE Device "frei" ist für den Adapter! Also kein radar2-Adapter oder so der den gleichen BLE nutzen will!
                                          F 2 Antworten Letzte Antwort
