  4. Js.controller update auf 0.14.x (vorher0.13.2) => totalausfall
    5.6k
85 Beiträge 8 Kommentatoren 14.2k Aufrufe
  • E Offline
    Elektroman
    #67
    Hallo Fitti,
    Funktioniert leider immer noch nicht
     admin@nasserver:/volume1/iobroker$ sudo npm install iobroker --unsafe-perm
    > iobroker@0.7.1 install /volume1/iobroker/node_modules/iobroker
    > node lib/setup.js
    npm install iobroker.js-controller --production --prefix /volume1/iobroker
    npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to greenlock. Please find it at npm greenlock
    npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to localhost.daplie.me-certificates
    gyp ERR! build error
    gyp ERR! stack Error: not found: make
    gyp ERR! stack     at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
    gyp ERR! stack     at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)
    gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
    gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:82:15)
    gyp ERR! System Linux 3.2.40
    gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /volume1/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
    gyp ERR! node -v v4.4.2
    gyp ERR! node-gyp -v v3.3.1
    gyp ERR! not ok
    npm WARN optional dep failed, continuing unix-dgram@0.2.3
    gyp ERR! cwd /volume1/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
    gyp ERR! not ok
    npm WARN optional dep failed, continuing ursa@0.9.4
    npm install iobroker.admin --production --prefix /volume1/iobroker
    Write "./iobroker start" to start the ioBroker
    iobroker@0.7.1 node_modules/iobroker
    └── yargs@4.8.1 (get-caller-file@1.0.2, lodash.assign@4.2.0, decamelize@1.2.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, window-size@0.2.0, require-main-filename@1.0.1, require-directory@2.1.1, yargs-parser@2.4.1, os-locale@1.4.0, cliui@3.2.0, string-width@1.0.2, read-pkg-up@1.0.1)
    • E Offline
      Elektroman
      #68
      habe auch noch einmal versucht die Rechte anzupassen
      admin@nasserver:/volume1/iobroker$ cd /
      admin@nasserver:/$ sudo chmod 777 /volume1/iobroker
      Password:
      admin@nasserver:/$ cd /volume1/iobroker
      npm ERR! not a package /volume1/iobroker/iobroker
      npm ERR! addLocal Could not install /volume1/iobroker/iobroker
      npm ERR! Linux 3.2.40
      npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker" "--unsafe-perm"
      npm ERR! node v4.4.2
      npm ERR! npm  v2.15.1
      npm ERR! path /tmp/npm-25944-73a624ce/unpack-360c1fe834e6/package.json
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-25944-73a624ce/unpack-360c1fe834e6/package.json'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR! Please include the following file with any support request:
      npm ERR!     /volume1/iobroker/npm-debug.log
        #69
        Bitte benutze code-Tags!
        • und die edit-Funktion.
        Hier liegt ein Fehler.
        @Elektroman:
        gyp ERR! stack Error: not found: make `
        • E Offline
          Elektroman
          #70
          Mein Problem ist das ich gezwungen bin mit Tapatalk zu arbeiten
          glaube ich zumindest
          habe das Psw für IOBroker vergessen, und komme nur über Tapatalk rein
          Tapatalk unter Win finde ich noch besch …..
          • E Offline
            Elektroman
            #71
            Danke für die Antwort,
            die bringt mich aber leider nicht weiter
              BabooN-Syno
              #72
              hey zusammen,
              ich klinke mich mal hier mit ein. Habe heute mein ioBroker.js-controller von 0.14.0 auf die aktuelle 0.15.3 aktualisieren wollen. Das ganze ging leider in die Hose und ich habe mittlerweile, mehrfrach iobroker neuinstalliert.
              Meine Installationsablauf sieht genauso aus wie deiner, hast du schon probiert iobroker zu starten?
              cd volume1/iobroker
              sudo ./iobroker start
              wie Rainer schon schrieb liegt unser Problem beim "make", leider finde ich null Infos darüber.. Weder in diesem, noch im Synology Forum..
              mein iobroker startet und ich kann problemlos darauf zugreifen. Momentan kämpfe ich jedoch stark damit meine alten Daten, vorallem die Pakete inkl. Einstellungen zu übernehmen…
              Ich habe zuvor den kompletten iobroker Ordner gesichert, kann mir jemand sagen welche Ordner ich auf die neue Installation übernehmen muss?
              Nehme ich den ganzen /volume1/iobroker Ordner so bekomme ich den gleichen Fehler wie nach dem Updateversuch =/
              EDIT: ich habe nun anders gelöst. Ich habe aus dem neuinstallierten iobroker den js-controller ordner aus node_modules in meine Datensicherung kopiert und konnte iobroker wie zuvor starten...
              Dennoch verunsichert mich der bereits oben erwähnte Fehler - kann ich da noch Probleme bekommen?
              Außerdem bekomme ich den Harmony Adapter nicht installiert wegen fehlendem git -.-
              • F Offline
                Fitti
                #73
                @BabooN-Syno:
                hey zusammen,
                wie Rainer schon schrieb liegt unser Problem beim "make", leider finde ich null Infos darüber.. Weder in diesem, noch im Synology Forum.. `
                Na gut - irgendwie drehen wir uns ja nur im Kreis und verschiedenes wiederholst Du nur, was wir zuvor ja schon geschrieben haben.
                Einschließlich auch der Antwort zu Deiner Frage, die du dir selbst beantwortet hast:
                Siehe mal hier in diesem Thread, ein paar Einträge zuvor:
                http://forum.iobroker.net/viewtopic.php … ake#p44448
                http://forum.iobroker.net/viewtopic.php ... ake#p47504
                Hast Du meinen Tipp angesehen, wie man make auf Symo installiert?
                http://forum.iobroker.net/viewtopic.php ... hilit=make
                Verstehe ich es richtig, dass Du es auch auf einer Symo verwendest oder welches System benutzt Du?
                "Es wird die Zeit kommen, da ihr euch entscheiden müsst zwischen dem, was richtig ist, und dem, was bequem ist."
                Plural von Status ist auch Status!
                • F Offline
                  Fitti
                  #74
                  @Elektroman:
                  Ist schon verzwíckt bei Dir…
                  Na wir schauen weiter wenn Du magst:
                  geb bitte mal folgenden Befehl ein - der Ordner wo Du das machst ist egal:
                  ls -al / |grep volume1
                  Das Ergebniss bitte wieder hier posten.
                  Dann auch ein
                  ls -al /volume1 |grep iobroker
                  So, und dann hätte ich noch gerne die Infos, die Du nach den beiden Befehlen bekommst:
                  npm cache clean
                  npm find iobroker
                  • E Offline
                    Elektroman
                    #75
                    Hallo Fitti,
                    hier das Ergebnis:
                    admin@nasserver:~$ ls -al / |grep volume1
                    drwxr-xr-x  33 root root 4096 Feb 26 18:54 volume1
                    admin@nasserver:~$ ls -al /volume1 |grep iobroker
                    drwxrwxrwx    6 root                root                     4096 Feb 19 12:22 iobroker
                    admin@nasserver:~$ npm cache clean
                    admin@nasserver:~$
                    admin@nasserver:~$ npm find iobroker
                    npm WARN Building the local index for the first time, please be patient
                    npm WARN notice update to the newest npm client for improved search results: npmjs.com/get-npm
                    NAME                        DESCRIPTION                                                  AUTHOR               DATE       VERSION KEYWORDS
                    iobroker                    ...domesticate the Internet of Things                        =bluefox             2016-03-14 0.7.1
                    iobroker.admin              The adapter opens a webserver for the ioBroker admin UI.     =bluefox             2017-01-21 1.6.11
                    iobroker.cul                Javascript/Node.js based Busware CUL USB / culfw adapter     =bluefox             2017-01-23 0.2.2
                    iobroker.dwd                Wetterwarnungen des deutschen Wetterdienstes                 =bluefox             2016-07-01 2.1.1
                    iobroker.email              Send e-mails from ioBroker                                   =bluefox             2017-02-06 1.0.2
                    iobroker.feiertage          Deutsche Feiertage                                           =bluefox =pix---     2017-01-04 0.3.6
                    iobroker.history            Log state history in a two-stages process (first to RAM,…    =apollon77 =bluefox  2017-02-23 1.5.3
                    iobroker.hm-rega            Connects HomeMatic CCU "Logic Layer" ("ReGaHSS") to ioBroker =bluefox             2017-02-06 1.4.3
                    iobroker.hm-rpc             Connects HomeMatic Interface-Processes (BidCos-Services,…    =bluefox             2017-02-22 1.4.2
                    iobroker.icons-mfd-png      Icon set for visualisation of the home automation as PNG.    =bluefox             2017-01-05 1.0.2
                    iobroker.icons-mfd-svg      Icon set for visualisation of the home automation as SVG.    =bluefox             2017-01-05 1.0.2
                    iobroker.influxdb           Log states in InfluxDB                                       =apollon77 =bluefox  2017-02-23 1.3.4
                    iobroker.javascript         Javascript/Coffescript Script Engine for ioBroker            =bluefox             2017-02-14 3.2.6
                    iobroker.jeelink            ioBroker jeelink Adapter                                     =foxthefox           2017-02-07 0.0.2
                    iobroker.js-controller      ...domesticate the Internet of Things                        =bluefox             2017-01-20 0.15.3
                    iobroker.knx                ioBroker knx Adapter                                         =bluefox…            2017-02-25 0.8.2
                    iobroker.kodi               iobroker.kodi Adapter                                        =bluefox =instalator 2017-01-06 0.2.0
                    iobroker.lightify           OSRAM Lightify Adapter                                       =soef                2017-02-18 0.0.27
                    iobroker.megad              Lets control the MegaD-328 over ethernet…                    =bluefox             2016-08-14 1.2.1
                    iobroker.milight            ioBroker milight Adapter                                     =foxthefox           2017-02-15 0.2.2
                    iobroker.mpd                ioBroker mpd Adapter                                         =instalator          2017-01-28 0.2.4
                    iobroker.mqtt               The adapter allows to send and receive MQTT messages from…   =bluefox             2017-02-08 1.3.2
                    iobroker.mysensors          ioBroker mysensors Adapter                                   =bluefox             2016-12-18 1.0.6
                    iobroker.mysensors-2        ioBroker mysensors-2 Adapter                                 =soef                2017-02-01 2.0.22
                    iobroker.node-red           This adapter uses node-red as a service of ioBroker. No…     =bluefox             2017-01-25 1.1.6
                    iobroker.nut                Network UPS Adapter                                          =apollon77           2016-11-30 1.0.0
                    iobroker.pilight            ioBroker pilight Adapter                                     =sja                 2017-01-15 0.5.1
                    iobroker.ping               This adapter cyclic polls configured IPs.                    =bluefox             2017-01-23 1.2.0
                    iobroker.radar              This adapter interfaces ioBroker with Raspberry GPIO pins    =frankjoke           2016-12-27 0.7.3
                    iobroker.rflink             ioBroker RFLink Adapter                                      =bluefox             2017-01-20 1.0.8
                    iobroker.rpi2               RPI-Monitor for ioBroker Installations                       =bluefox             2017-01-10 0.3.1
                    iobroker.rtv                TV Programm (jetzt, 20:15 Uhr, 22:00 Uhr und Tipps) aus den… =pix---              2016-12-18 1.0.0
                    iobroker.sayit              Text to speech interface for ioBroker.                       =bluefox             2017-02-15 1.5.1
                    iobroker.simple-api         RESTful interface for ioBroker.                              =bluefox             2016-09-05 1.3.0
                    iobroker.smartmeter         Smartmeter Adapter                                           =apollon77           2017-02-24 0.4.1
                    iobroker.socketio           This adapter allows to communicate different web…            =bluefox             2017-01-04 1.7.4
                    iobroker.sonos              The adapter opens a webserver for the ioBroker admin UI      =bluefox             2017-01-03 1.4.2
                    iobroker.sql                Log state sql in a two-stages process (first to Redis, then… =apollon77 =bluefox  2017-02-25 1.4.6
                    iobroker.tankerkoenig       Spritpreise von tankerkoenig.de                              =pix---              2016-10-14 1.0.0
                    iobroker.telegram           The adapter allows to send and receive telegram messages…    =bluefox             2017-01-14 1.0.2
                    iobroker.text2command       Convert texts to ioBroker commands.                          =bluefox             2016-09-01 1.1.3
                    iobroker.tr-064             ioBroker tr-064 Adapter                                      =soef                2017-02-18 0.1.33
                    iobroker.vis-beta           BETA graphical user interface for ioBroker.                  =bluefox             2017-02-11 0.12.8
                    iobroker.vis-timeandweather Time and weather widgets for ioBroker.vis                    =bluefox             2017-01-05 1.1.7
                    iobroker.web                ioBroker simple web Adapter                                  =bluefox             2017-02-11 2.0.2
                    iobroker.wifilight          WiFi Light Adapter                                           =soef                2017-02-18 0.1.1
                    iobroker.xs1                ioBroker EZcontrol XS1 Adapter                               =frankjoke           2017-01-15 0.5.2
                    iobroker.yamaha             ioBroker Yamaha Adapter                                      =soef                2017-02-24 0.3.5
                    iobroker.yr                 Fetches 48h weather forecast from yr.no                      =bluefox             2016-10-10 1.0.5
                    soef                        library for ioBroker                                         =soef                2017-02-21 0.2.0
                    admin@nasserver:~$
                    • F Offline
                      Fitti
                      #76
                      Okay - das sieht gut aus.
                      Wir versuchen noch einmal eine Installation, habe zwar noch eine andere Idee, aber vorher sollten wir es noch herkömmlich testen.
                      Fehlermeldungen kommen ganz bestimmt. Versuche dennoch einfach mal danach
                      iobroker start
                      und dich im Browser anzumelden.
                      • E Offline
                        Elektroman
                        #77
                        Password:
                        npm ERR! path /tmp/npm-31256-8e63c4c8/unpack-941379bd274e/package.json
                        npm ERR! errno -2
                        npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-31256-8e63c4c8/unpack-941379bd274e/package.json'
                        npm ERR! enoent
                        admin@nasserver:/volume1/iobroker$ iobroker start
                        -sh: iobroker: command not found
                        • E Offline
                          Elektroman
                          #78
                          vielen dank für die schnelle Antwort
                          • F Offline
                            Fitti
                            #79
                            Den 'npm ERR! not a package' finde ich komisch. :shock:
                            Als ob im iobroker-Paket ein Fehler wäre. Doch dann hätten es die anderen ja auch. :?
                            gebe bitte mal folgendes ein:
                            npm test iobroker
                            Und wie immer: Ergebnis hier her.
                              #80
                              Das ist IMHO der einzige Fehler wo nichts mehr repariert werden kann.
                              Zumindest ich hab es nicht hinbekommen.
                              Und…tatsächlich diese Datei fehlt in den Fällen tatsächlich.
                              • F Offline
                                Fitti
                                #81
                                @Fitti:
                                npm test iobroker
                                Und wie immer: Ergebnis hier her. `
                                Und bitte noch den Befehl:
                                npm ls
                                • E Offline
                                  Elektroman
                                  #82
                                  admin@nasserver:~$ npm test iobroker
                                  npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin        /npm" "test" "iobroker"
                                  npm ERR! path /volume1/homes/admin/package.json
                                  npm ERR! errno -2
                                  npm ERR! enoent ENOENT: no such file or directory, open '/volume1/homes/admin/pa        ckage.json'
                                  npm ERR! enoent
                                  npm ERR!     /volume1/homes/admin/npm-debug.log
                                  admin@nasserver:~$ npm ls
                                  └── (empty)
                                  admin@nasserver:~$
                                  • F Offline
                                    Fitti
                                    #83
                                    Bitte gebe mal folgenden Befehl ein:
                                    ls -al /volume1/homes/admin/
                                    und````
                                    cd /volume1/homes/admin/
                                    ls -al
                                    __Wie immer - Ergebnis hierher.__
                                    Nicht wundern, fast das Gleiche, jedoch bin ich mir nicht sicher, ob Du das Home-Verzeichnis hast. Die Fehlermeldungen sind leicht anders (oder auch nicht), daher aber die beiden nahezu identischen Befehle.
                                    Du kannst auch mal auf der normalen Weboberfläche der Synology schauen, ob Du die Homeverzeichnisse aktiviert hast. Per Default sind die nämlich nicht da.
                                    Siehe hier [https://www.synology.com/de-de/knowledg … r_advanced](https://www.synology.com/de-de/knowledgebase/DSM/help/DSM/AdminCenter/file_user_advanced)
                                    Etwas weiter runter unter ****Benutzer-Home****
                                    Oder als Video hier: (springt gleich an die richtige Stelle). [https://youtu.be/VvRkx-17Gu4?t=425](https://youtu.be/VvRkx-17Gu4?t=425) =>Siehe im Bild den Text "Benutzerbasis"
                                    • E Offline
                                      Elektroman
                                      #84
                                      admin@nasserver:~$ ls -al /volume1/homes/admin/
                                      total 32
                                      drwxrwxrwx+ 7 admin users 4096 Feb 28 17:30 .
                                      drwxrwxrwx+ 8 root  root  4096 Oct 16 08:40 ..
                                      drwxrwxrwx+ 9 admin users 4096 Sep  4 18:07 .Maildir
                                      drwxrwxrwx+ 3 admin users 4096 Feb 12 19:06 .node-gyp
                                      drwxrwxrwx+ 3 admin users 4096 Feb 27 15:18 .npm
                                      drwxrwxrwx+ 2 admin users 4096 Feb 11 12:00 opt
                                      drwxrwxrwx+ 2 admin users 4096 Jul 20  2014 www
                                      admin@nasserver:~$ cd /volume1/homes/admin/
                                      admin@nasserver:/volume1/homes/admin$ ls -al
                                      total 32
                                      • E Offline
                                        Elektroman
                                        #85
                                        Hallo Fitti,
                                        würde mich über weitere hilfe sehr freuen!!!!
