  4. Js.controller update auf 0.14.x (vorher0.13.2) => totalausfall
    5.6k
85 Beiträge 8 Kommentatoren 14.2k Aufrufe
  • E Offline
    Elektroman
    Sorry ich bekomme das anders leider nicht hin es einzufügen
    admin@nasserver:~$ cd ..
    admin@nasserver:/var/services/homes$ cd ..
    admin@nasserver:/var/services$ cd ..
    admin@nasserver:/var$ cd ..
    admin@nasserver:/$ cd volume1
    admin@nasserver:/volume1$ sudo chmod 777 -R /opt/iobroker
    Password:
    admin@nasserver:/volume1$ cd /opt/iobroker
    admin@nasserver:/opt/iobroker$ sudo npm install iobroker --unsafe-perm
     > iobroker@0.7.1 install /opt/iobroker/node_modules/iobroker
     > node lib/setup.js
    npm install iobroker.js-controller --production --prefix /opt/iobroker
    npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to
    greenlock. Please find it at npm greenlock
    npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to
    localhost.daplie.me-certificates
    gyp ERR! build error
    gyp ERR! stack Error: not found: make
    gyp ERR! stack     at F
    (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
    gyp ERR! stack     at E
    (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)
    gyp ERR! stack     at
    /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
    gyp ERR! stack     at
    /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    gyp ERR! stack     at
    /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:82:15)
    gyp ERR! System Linux 3.2.40
    gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node"
    "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js"
    "rebuild"
    gyp ERR! cwd
    /opt/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
    gyp ERR! node -v v4.4.2
    gyp ERR! node-gyp -v v3.3.1
    gyp ERR! not ok
    npm WARN optional dep failed, continuing unix-dgram@0.2.3
    gyp ERR! stack     at F
    gyp ERR! stack     at E
    gyp ERR! stack     at
    gyp ERR! stack     at
    gyp ERR! stack     at
    "rebuild"
    gyp ERR! cwd
    /opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
    gyp ERR! not ok
    npm WARN optional dep failed, continuing ursa@0.9.4
    npm install iobroker.admin --production --prefix /opt/iobroker
    Write "./iobroker start" to start the ioBroker
    iobroker@0.7.1 node_modules/iobroker
    └── yargs@4.8.1 (get-caller-file@1.0.2, decamelize@1.2.0,
    lodash.assign@4.2.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0,
    window-size@0.2.0, require-main-filename@1.0.1, require-directory@2.1.1,
    yargs-parser@2.4.1, cliui@3.2.0, string-width@1.0.2, os-locale@1.4.0,
    read-pkg-up@1.0.1)
    admin@nasserver:/opt/iobroker$ ./iobroker start
    Starting iobroker controller daemon...
    iobroker controller daemon failed to start:  2
    Error: 2
    Diese E-Mail wurde von Avast Antivirus-Software auf Viren geprüft.
    https://www.avast.com/antivirus
    • BluefoxB Offline
      BluefoxB Offline
      @Elektroman:
      Password:
       > node lib/setup.js
      gyp ERR! stack     at F
      gyp ERR! stack     at E
      gyp ERR! stack     at
      gyp ERR! stack     at
      gyp ERR! stack     at
      "rebuild"
      gyp ERR! cwd
      gyp ERR! not ok
      gyp ERR! stack     at F
      gyp ERR! stack     at E
      gyp ERR! stack     at
      gyp ERR! stack     at
      gyp ERR! stack     at
      "rebuild"
      gyp ERR! cwd
      gyp ERR! not ok
      read-pkg-up@1.0.1)
      Error: 2
      NasFehler.JPG `
      Hast du build-essential installiert?
      • E Offline
        Elektroman
        ? [emoji15]
        • E Offline
          Elektroman
          Ich glaube beim ersten mal habe ich auch nichts anderes gemacht , oder?
          • F Offline
            Fitti
            #66
            Also zuerst mal der /opt Ordner ist in Deinem Fall tabu!. Da holst Du Dir wieder die Fehler rein!
            Du darfst auf der Synologie wirklich nur im /volume1 Ordner "arbeiten"! Bei den anderen Ordner operierst Du am offenen Herzen und beim nächsten Update ist sowieso alles weg oder anders.
            Iobroker muss nicht im /opt Ordner rein - das kann man getrost auch woanders insatllieren - und wir Synologies müssen es sogar!
            <u>Okay nochmal Basics:</u> Wenn du ein cd /volume1 eingibst, Bist du vom absulut höchsten Ordner (dem Basisordner oder auch root=Wurzel) in den richtigen Ordner volume1 gelandet.
            Das erspart Dir die cd …
            Das / ist der höchste Ordner.
            In diesem Ordner - und nur da! - legst du den Ordner iobroker an.
            Das kannst du auch direkt mit einem Befehl:
            sudo mkdir /volume1/iobroker
            Dann wechselst Du in diesen Ordner:
            cd /volume1/iobroker
            Nun kannst Du mal versuchen iobroker zu installieren:
            Du wirst immer ein paar Fehler sehen. Aber am Ende sollte doch alles funktionieren.
            Schreib mal was passiert, wenn Du die Befehle hier nach und nach eingibst.
            "Es wird die Zeit kommen, da ihr euch entscheiden müsst zwischen dem, was richtig ist, und dem, was bequem ist."
            Plural von Status ist auch Status!
            • E Offline
              Elektroman
              #67
              Hallo Fitti,
              Funktioniert leider immer noch nicht
               admin@nasserver:/volume1/iobroker$ sudo npm install iobroker --unsafe-perm
              > iobroker@0.7.1 install /volume1/iobroker/node_modules/iobroker
              > node lib/setup.js
              npm install iobroker.js-controller --production --prefix /volume1/iobroker
              npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to greenlock. Please find it at npm greenlock
              npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to localhost.daplie.me-certificates
              gyp ERR! stack     at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
              gyp ERR! stack     at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)
              gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
              gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
              gyp ERR! stack     at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
              gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /volume1/iobroker/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
              gyp ERR! not ok
              gyp ERR! cwd /volume1/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
              gyp ERR! not ok
              npm install iobroker.admin --production --prefix /volume1/iobroker
              └── yargs@4.8.1 (get-caller-file@1.0.2, lodash.assign@4.2.0, decamelize@1.2.0, y18n@3.2.1, which-module@1.0.0, set-blocking@2.0.0, window-size@0.2.0, require-main-filename@1.0.1, require-directory@2.1.1, yargs-parser@2.4.1, os-locale@1.4.0, cliui@3.2.0, string-width@1.0.2, read-pkg-up@1.0.1)
              • E Offline
                Elektroman
                #68
                habe auch noch einmal versucht die Rechte anzupassen
                admin@nasserver:/volume1/iobroker$ cd /
                admin@nasserver:/$ sudo chmod 777 /volume1/iobroker
                Password:
                admin@nasserver:/$ cd /volume1/iobroker
                npm ERR! not a package /volume1/iobroker/iobroker
                npm ERR! addLocal Could not install /volume1/iobroker/iobroker
                npm ERR! Linux 3.2.40
                npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker" "--unsafe-perm"
                npm ERR! node v4.4.2
                npm ERR! npm  v2.15.1
                npm ERR! path /tmp/npm-25944-73a624ce/unpack-360c1fe834e6/package.json
                npm ERR! code ENOENT
                npm ERR! errno -2
                npm ERR! syscall open
                npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-25944-73a624ce/unpack-360c1fe834e6/package.json'
                npm ERR! enoent This is most likely not a problem with npm itself
                npm ERR! enoent and is related to npm not being able to find a file.
                npm ERR! enoent
                npm ERR! Please include the following file with any support request:
                npm ERR!     /volume1/iobroker/npm-debug.log
                  #69
                  Bitte benutze code-Tags!
                  • und die edit-Funktion.
                  Hier liegt ein Fehler.
                  @Elektroman:
                  gyp ERR! stack Error: not found: make `
                  • E Offline
                    Elektroman
                    #70
                    Mein Problem ist das ich gezwungen bin mit Tapatalk zu arbeiten
                    glaube ich zumindest
                    habe das Psw für IOBroker vergessen, und komme nur über Tapatalk rein
                    Tapatalk unter Win finde ich noch besch …..
                    • E Offline
                      Elektroman
                      #71
                      Danke für die Antwort,
                      die bringt mich aber leider nicht weiter
                        BabooN-Syno
                        #72
                        hey zusammen,
                        ich klinke mich mal hier mit ein. Habe heute mein ioBroker.js-controller von 0.14.0 auf die aktuelle 0.15.3 aktualisieren wollen. Das ganze ging leider in die Hose und ich habe mittlerweile, mehrfrach iobroker neuinstalliert.
                        Meine Installationsablauf sieht genauso aus wie deiner, hast du schon probiert iobroker zu starten?
                        cd volume1/iobroker
                        sudo ./iobroker start
                        wie Rainer schon schrieb liegt unser Problem beim "make", leider finde ich null Infos darüber.. Weder in diesem, noch im Synology Forum..
                        mein iobroker startet und ich kann problemlos darauf zugreifen. Momentan kämpfe ich jedoch stark damit meine alten Daten, vorallem die Pakete inkl. Einstellungen zu übernehmen…
                        Ich habe zuvor den kompletten iobroker Ordner gesichert, kann mir jemand sagen welche Ordner ich auf die neue Installation übernehmen muss?
                        Nehme ich den ganzen /volume1/iobroker Ordner so bekomme ich den gleichen Fehler wie nach dem Updateversuch =/
                        EDIT: ich habe nun anders gelöst. Ich habe aus dem neuinstallierten iobroker den js-controller ordner aus node_modules in meine Datensicherung kopiert und konnte iobroker wie zuvor starten...
                        Dennoch verunsichert mich der bereits oben erwähnte Fehler - kann ich da noch Probleme bekommen?
                        Außerdem bekomme ich den Harmony Adapter nicht installiert wegen fehlendem git -.-
                        • F Offline
                          Fitti
                          #73
                          @BabooN-Syno:
                          hey zusammen,
                          wie Rainer schon schrieb liegt unser Problem beim "make", leider finde ich null Infos darüber.. Weder in diesem, noch im Synology Forum.. `
                          Na gut - irgendwie drehen wir uns ja nur im Kreis und verschiedenes wiederholst Du nur, was wir zuvor ja schon geschrieben haben.
                          Einschließlich auch der Antwort zu Deiner Frage, die du dir selbst beantwortet hast:
                          Siehe mal hier in diesem Thread, ein paar Einträge zuvor:
                          http://forum.iobroker.net/viewtopic.php … ake#p44448
                          http://forum.iobroker.net/viewtopic.php ... ake#p47504
                          Hast Du meinen Tipp angesehen, wie man make auf Symo installiert?
                          http://forum.iobroker.net/viewtopic.php ... hilit=make
                          Verstehe ich es richtig, dass Du es auch auf einer Symo verwendest oder welches System benutzt Du?
                          • F Offline
                            Fitti
                            #74
                            @Elektroman:
                            Ist schon verzwíckt bei Dir…
                            Na wir schauen weiter wenn Du magst:
                            geb bitte mal folgenden Befehl ein - der Ordner wo Du das machst ist egal:
                            ls -al / |grep volume1
                            Das Ergebniss bitte wieder hier posten.
                            Dann auch ein
                            ls -al /volume1 |grep iobroker
                            So, und dann hätte ich noch gerne die Infos, die Du nach den beiden Befehlen bekommst:
                            npm cache clean
                            npm find iobroker
                            • E Offline
                              Elektroman
                              #75
                              Hallo Fitti,
                              hier das Ergebnis:
                              admin@nasserver:~$ ls -al / |grep volume1
                              drwxr-xr-x  33 root root 4096 Feb 26 18:54 volume1
                              admin@nasserver:~$ ls -al /volume1 |grep iobroker
                              drwxrwxrwx    6 root                root                     4096 Feb 19 12:22 iobroker
                              admin@nasserver:~$ npm cache clean
                              admin@nasserver:~$
                              admin@nasserver:~$ npm find iobroker
                              npm WARN Building the local index for the first time, please be patient
                              npm WARN notice update to the newest npm client for improved search results: npmjs.com/get-npm
                              NAME                        DESCRIPTION                                                  AUTHOR               DATE       VERSION KEYWORDS
                              iobroker                    ...domesticate the Internet of Things                        =bluefox             2016-03-14 0.7.1
                              iobroker.admin              The adapter opens a webserver for the ioBroker admin UI.     =bluefox             2017-01-21 1.6.11
                              iobroker.cul                Javascript/Node.js based Busware CUL USB / culfw adapter     =bluefox             2017-01-23 0.2.2
                              iobroker.dwd                Wetterwarnungen des deutschen Wetterdienstes                 =bluefox             2016-07-01 2.1.1
                              iobroker.email              Send e-mails from ioBroker                                   =bluefox             2017-02-06 1.0.2
                              iobroker.feiertage          Deutsche Feiertage                                           =bluefox =pix---     2017-01-04 0.3.6
                              iobroker.history            Log state history in a two-stages process (first to RAM,…    =apollon77 =bluefox  2017-02-23 1.5.3
                              iobroker.hm-rega            Connects HomeMatic CCU "Logic Layer" ("ReGaHSS") to ioBroker =bluefox             2017-02-06 1.4.3
                              iobroker.hm-rpc             Connects HomeMatic Interface-Processes (BidCos-Services,…    =bluefox             2017-02-22 1.4.2
                              iobroker.icons-mfd-png      Icon set for visualisation of the home automation as PNG.    =bluefox             2017-01-05 1.0.2
                              iobroker.icons-mfd-svg      Icon set for visualisation of the home automation as SVG.    =bluefox             2017-01-05 1.0.2
                              iobroker.influxdb           Log states in InfluxDB                                       =apollon77 =bluefox  2017-02-23 1.3.4
                              iobroker.javascript         Javascript/Coffescript Script Engine for ioBroker            =bluefox             2017-02-14 3.2.6
                              iobroker.jeelink            ioBroker jeelink Adapter                                     =foxthefox           2017-02-07 0.0.2
                              iobroker.js-controller      ...domesticate the Internet of Things                        =bluefox             2017-01-20 0.15.3
                              iobroker.knx                ioBroker knx Adapter                                         =bluefox…            2017-02-25 0.8.2
                              iobroker.kodi               iobroker.kodi Adapter                                        =bluefox =instalator 2017-01-06 0.2.0
                              iobroker.lightify           OSRAM Lightify Adapter                                       =soef                2017-02-18 0.0.27
                              iobroker.megad              Lets control the MegaD-328 over ethernet…                    =bluefox             2016-08-14 1.2.1
                              iobroker.milight            ioBroker milight Adapter                                     =foxthefox           2017-02-15 0.2.2
                              iobroker.mpd                ioBroker mpd Adapter                                         =instalator          2017-01-28 0.2.4
                              iobroker.mqtt               The adapter allows to send and receive MQTT messages from…   =bluefox             2017-02-08 1.3.2
                              iobroker.mysensors          ioBroker mysensors Adapter                                   =bluefox             2016-12-18 1.0.6
                              iobroker.mysensors-2        ioBroker mysensors-2 Adapter                                 =soef                2017-02-01 2.0.22
                              iobroker.node-red           This adapter uses node-red as a service of ioBroker. No…     =bluefox             2017-01-25 1.1.6
                              iobroker.nut                Network UPS Adapter                                          =apollon77           2016-11-30 1.0.0
                              iobroker.pilight            ioBroker pilight Adapter                                     =sja                 2017-01-15 0.5.1
                              iobroker.ping               This adapter cyclic polls configured IPs.                    =bluefox             2017-01-23 1.2.0
                              iobroker.radar              This adapter interfaces ioBroker with Raspberry GPIO pins    =frankjoke           2016-12-27 0.7.3
                              iobroker.rflink             ioBroker RFLink Adapter                                      =bluefox             2017-01-20 1.0.8
                              iobroker.rpi2               RPI-Monitor for ioBroker Installations                       =bluefox             2017-01-10 0.3.1
                              iobroker.rtv                TV Programm (jetzt, 20:15 Uhr, 22:00 Uhr und Tipps) aus den… =pix---              2016-12-18 1.0.0
                              iobroker.sayit              Text to speech interface for ioBroker.                       =bluefox             2017-02-15 1.5.1
                              iobroker.simple-api         RESTful interface for ioBroker.                              =bluefox             2016-09-05 1.3.0
                              iobroker.smartmeter         Smartmeter Adapter                                           =apollon77           2017-02-24 0.4.1
                              iobroker.socketio           This adapter allows to communicate different web…            =bluefox             2017-01-04 1.7.4
                              iobroker.sonos              The adapter opens a webserver for the ioBroker admin UI      =bluefox             2017-01-03 1.4.2
                              iobroker.sql                Log state sql in a two-stages process (first to Redis, then… =apollon77 =bluefox  2017-02-25 1.4.6
                              iobroker.tankerkoenig       Spritpreise von tankerkoenig.de                              =pix---              2016-10-14 1.0.0
                              iobroker.telegram           The adapter allows to send and receive telegram messages…    =bluefox             2017-01-14 1.0.2
                              iobroker.text2command       Convert texts to ioBroker commands.                          =bluefox             2016-09-01 1.1.3
                              iobroker.tr-064             ioBroker tr-064 Adapter                                      =soef                2017-02-18 0.1.33
                              iobroker.vis-beta           BETA graphical user interface for ioBroker.                  =bluefox             2017-02-11 0.12.8
                              iobroker.vis-timeandweather Time and weather widgets for ioBroker.vis                    =bluefox             2017-01-05 1.1.7
                              iobroker.web                ioBroker simple web Adapter                                  =bluefox             2017-02-11 2.0.2
                              iobroker.wifilight          WiFi Light Adapter                                           =soef                2017-02-18 0.1.1
                              iobroker.xs1                ioBroker EZcontrol XS1 Adapter                               =frankjoke           2017-01-15 0.5.2
                              iobroker.yamaha             ioBroker Yamaha Adapter                                      =soef                2017-02-24 0.3.5
                              iobroker.yr                 Fetches 48h weather forecast from yr.no                      =bluefox             2016-10-10 1.0.5
                              soef                        library for ioBroker                                         =soef                2017-02-21 0.2.0
                              admin@nasserver:~$
                              • F Offline
                                Fitti
                                #76
                                Okay - das sieht gut aus.
                                Wir versuchen noch einmal eine Installation, habe zwar noch eine andere Idee, aber vorher sollten wir es noch herkömmlich testen.
                                Fehlermeldungen kommen ganz bestimmt. Versuche dennoch einfach mal danach
                                iobroker start
                                und dich im Browser anzumelden.
                                • E Offline
                                  Elektroman
                                  #77
                                  Password:
                                  npm ERR! path /tmp/npm-31256-8e63c4c8/unpack-941379bd274e/package.json
                                  npm ERR! errno -2
                                  npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-31256-8e63c4c8/unpack-941379bd274e/package.json'
                                  npm ERR! enoent
                                  admin@nasserver:/volume1/iobroker$ iobroker start
                                  -sh: iobroker: command not found
                                  • E Offline
                                    Elektroman
                                    #78
                                    vielen dank für die schnelle Antwort
                                    • F Offline
                                      Fitti
                                      #79
                                      Den 'npm ERR! not a package' finde ich komisch. :shock:
                                      Als ob im iobroker-Paket ein Fehler wäre. Doch dann hätten es die anderen ja auch. :?
                                      gebe bitte mal folgendes ein:
                                      npm test iobroker
                                      Und wie immer: Ergebnis hier her.
                                        #80
                                        Das ist IMHO der einzige Fehler wo nichts mehr repariert werden kann.
                                        Zumindest ich hab es nicht hinbekommen.
                                        Und…tatsächlich diese Datei fehlt in den Fällen tatsächlich.
                                        • F Offline
                                          Fitti
                                          #81
                                          @Fitti:
                                          npm test iobroker
                                          Und wie immer: Ergebnis hier her. `
                                          Und bitte noch den Befehl:
                                          npm ls
