  4. node-red fenster nach update auf 2.4.0
    6.4k
85 Beiträge 5 Kommentatoren 4.6k Aufrufe 3 Beobachtet
  • F fournierrf5
    @fournierrf5
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:/opt/iobroker $ iobroker start
    pi@raspberrypi:/opt/iobroker $ iobroker logs --watch
    2021-11-06 14:19:43.099  - info: alexa2.0 (6173) Alexa-Push-Connection Error: Error: read ECONNRESET
    2021-11-06 14:19:43.101  - info: alexa2.0 (6173) Alexa-Push-Connection disconnected - retry: Retry Connection in 60s
    2021-11-06 14:20:43.648  - info: alexa2.0 (6173) Alexa-Push-Connection disconnected - retry: Retry Connection in 60s
    2021-11-06 14:21:44.150  - info: alexa2.0 (6173) Alexa-Push-Connection disconnected - retry: Retry Connection in 60s
    2021-11-06 14:22:44.643  - info: alexa2.0 (6173) Alexa-Push-Connection disconnected - retry: Retry Connection in 60s
    2021-11-06 14:23:45.162  - info: alexa2.0 (6173) Alexa-Push-Connection disconnected - retry: Retry Connection in 60s
    2021-11-06 14:24:20.658  - info: host.raspberrypi "system.adapter.node-red.0" enabled
    2021-11-06 14:24:20.935  - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 7546
    2021-11-06 14:24:23.595  - info: node-red.0 (7546) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.7, js-controller: 3.3.18
    2021-11-06 14:24:25.400  - info: node-red.0 (7546) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2021-11-06 14:24:36.191  - info: node-red.0 (7546) node-red exited with null
    2021-11-06 14:24:41.194  - info: node-red.0 (7546) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2021-11-06 14:24:45.429  - info: alexa2.0 (6173) Alexa-Push-Connection Error: Error: read ECONNRESET
    2021-11-06 14:24:45.431  - info: alexa2.0 (6173) Alexa-Push-Connection disconnected - retry: Retry Connection in 60s
    2021-11-06 14:24:52.532  - warn: node-red.0 (7546) node: ../deps/uv/src/unix/core.c:295: uv__finish_close: Assertion `0' failed.
    2021-11-06 14:24:52.561  - info: node-red.0 (7546) node-red exited with null
    2021-11-06 14:24:57.564  - info: node-red.0 (7546) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    MOD-Edit: Code in code-tags gesetzt!
    @fournierrf5
    Deine Systemzeit geht schon mal falsch. Oder wohnst du in England oder Portugal?
    F 1 Antwort Letzte Antwort
    • mickymM mickym
      @fournierrf5 sagte in node-red fenster nach update auf 2.4.0:
      Hallo@all,
      Nach immer wieder mal endlosen nächten mit meinem leidigen problem wende ich mich nun hilfesuchend ans forum:
      Mein staus:
      iobroker auf raspi3
      node.js v10.24.1
      npm 6.14.12
      js-controller 3.3.18
      admin 5.1.25
      Das problem:
      sobald ich den node-red adapter auf 2.4.0 aktualisiere bleibt das adapterfenster von node-red leer mit der meldung verbindung abgelehnt.
      Das selbe geschieht auch sobald ich node.js auf 12.xx update. Nund ist aber node.js 10.xx schon länger auf EOL, und der alexa2 adapter geht damit schon nicht mehr uppen, womit mir auf kurz oder lang eine lösung nicht erspart bleibt...
      Bin für jede hilfe dankbar,
      Thx@all
      Geht denn das Adapterfenster nicht mehr auf - oder kommst Du nicht mehr auf Deine Flows?
      1. Das ist das Adapterfenster:
      2. Das hier zeigt die Flows - innerhalb vom iobroker:
      Geht das nicht?
      1. Dann hast Du immer noch die Möglichkeit - das über eine eigene Browsersitzung über Port 1880 aufzurufen.
      also http://<ip-Adresse des iobroker>:1880
      aber wie gesagt mach erst mal Dein Node.JS Update wie von den Kollegen empfohlen.
      Wenn alles nichts hilft - dann sichere Dir Deine flows.json weg und lösche komplett den Node-Red Adapter und importiere anschließend wieder die flows.json Datei. Eigens installierte Nodes musst Du halt ebenfalls nachinstallieren.
      fournierrf5
      @mickym
      Die flows meinte ich, sorry wenn ich das falsch ausgedrückt habe.
      Auch im Browswerfenster wird der Zugang verweigert!
        @fournierrf5
        fournierrf5
        Österreichh :)
        • F fournierrf5
          Österreichh :)
          @fournierrf5
          Dann stell die Systemzeit auf Europa/Wien
          • F fournierrf5
            @fournierrf5
            Autostart enabled!
            mickymM Offline
            mickymM Offline
            mickym
            @fournierrf5
            1. Sehe ich gerade - Node Red startet nicht. Das sollte in den Instanzen auf ROT sein. Ich sehe auch nicht in meiner settings.js - was von max-old-space - hast Du an der settings.js rumgespielt.
            Ggf. hier wieder die Originaldatei einsetzen. Nach einem Adapterupdate wurde die aber eh überschrieben. Falls Du da Änderungen drin hattest, dann musst Du die halt nachziehen.
            /opt/iobroker/node_modules/iobroker.node-red/
            {1}
            Das sieht mir so aus, als ob Du irgendwelche Nodes nachinstalliert hast, die Probleme mache. Suche Dir die Nodes raus und lösche die mit dem Paletten-Manager und aus dem entspechenden Flow.
            Um das zu machen - starte NodeRed im Sicherheitsmodus:
            Damit solltest Du den fehlerhaften Flow bearbeiten und die Nodes entfernen können. Anschließend Sicherheitsmodus ausschalten und Adapter neu starten.
            • mickymM mickym
              @fournierrf5
              {1}
              fournierrf5
              @mickym
              Ich hab an einem problemlos laufenden system node.js von 10.xx auf 12.xx umgestellt, dann ist das der zustand, hundertmal durchversucht!
              Nodered ist übringens noch auf 3.9.3 belaseen, ändert aber nichts
              Wo geht die Systemzeit einstellen???
              mickymM Thomas BraunT 2 Antworten Letzte Antwort
              • F fournierrf5
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @fournierrf5 Hast Du NodeRed im Sicherheitsmodus gestartet?
                Ein Version 3.9.3 gibts bei mir nicht.
                Die ab NR-Adapter 2.4 installierte NR Version ist:
                Dann hast Du ggf. in Deiner settings.js irgendwelche Authentifizierungseinstellungen gehabt - die Du ggf. nachziehen musst.
                Ein Beispiel:
                // The `https` setting requires the `fs` module. Uncomment the following
                // to make it available:
                //var fs = require("fs");
                    // The following property can be used to enable HTTPS
                    // See http://nodejs.org/api/https.html#https_https_createserver_options_requestlistener
                    // for details on its contents.
                    // See the comment at the top of this file on how to load the `fs` module used by
                    // this setting.
                    //https: {
                    //    key: fs.readFileSync('privatekey.pem'),
                    //    cert: fs.readFileSync('certificate.pem')
                Nach jedem Update wird das wieder überschrieben.
                Die massgebliche settings.js für den iobroker findest Du unter:
                Und falls alles nichts hilft - halt Deine Flows wegsichern, NR-Adapter komplett löschen und neu installieren.
                • mickymM mickym
                  Ein Beispiel:
                      // this setting.
                      //https: {
                  fournierrf5
                  @mickym
                  Ja, bleibt unverändert verbindung verweigert
                  • F fournierrf5
                    @mickym
                    sudo raspi-config
                    Da irgendwo in den Localizations. Menüpunkte haben sich mal geändert, weiß nicht was du da genau hast.
                    Oder per
                    sudo dpkg-reconfigure tzdata
                    • F fournierrf5
                      @mickym
                      fournierrf5
                      Ich hätte die flows eigentlich bestens aktuell gesichert, den ich versuch mal den adapter neu zu installieren...?
                        sudo raspi-config
                        Oder per
                        fournierrf5
                        @thomas-braun said in node-red fenster nach update auf 2.4.0:
                        sudo raspi-config
                        Local time is now: Sat Nov 6 14:54:28 GMT 2021.
                        Universal Time is now: Sat Nov 6 14:54:28 UTC 2021.
                        das war eingestellt...find ich nicht so falsch
                        Thomas BraunT mickymM 2 Antworten Letzte Antwort
                        • F fournierrf5
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @fournierrf5 Kannst falls Du irgendwas mit https gemacht hast noch die settings.js (s. voriges Posting) nachziehen.
                          Ansonsten aktuelle flows.json aus /opt/iobroker/iobroker-data/node-red wegsichern und Neuinstallation. Ansonsten halt die flows.json die noch funktioniert hat.
                          Entweder manuell dort hin kopieren oder über den Import reinziehen.
                          • F fournierrf5
                            sudo raspi-config
                            @fournierrf5
                            Doch, das ist nicht die richtige Zeit für Österreich/Wien. Oder hast du da jetzt 14:59? Dann gehen alle deine Uhren falsch.
                              @fournierrf5
                              fournierrf5
                              schon geändert, ohne verbesserung
                              • F fournierrf5
                                sudo raspi-config
                                mickymM Offline
                                mickymM Offline
                                mickym
                                sudo raspi-config
                                Na die GMT ist schon richtig - mE ist die Zeitzone falsch. Da LocalTime = GMT = UTC.
                                • mickymM mickym
                                  sudo raspi-config
                                  @mickym
                                  Local time GMT ist falsch für Mitteleuropa.
                                    @mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @thomas-braun Na das mein ich ja. Also stimmt die Zeit, aber die Zeitzone nicht - die muss GMT +1 sein.
                                    F Thomas BraunT 2 Antworten Letzte Antwort
                                    • mickymM mickym
                                      fournierrf5
                                      @mickym
                                      jaja...ist docch schon längst, aber keine Veränderung
                                      • mickymM mickym
                                        @mickym
                                        Ja, das wird ja immer gerne beim Pi nicht (und ist dadurch dann falsch) eingestellt. Das kann aber auch gerade im Zusammenspiel mit Servern für schwere Verwirrung sorgen, z. T. wird auch bei Besucher aus der Zukunft der Zugang gesperrt.
                                        • F fournierrf5
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @fournierrf5 Na bei mir kommt jedenfalls das:
                                          sudo raspi-config
                                          Current default time zone: 'Europe/Berlin'
                                          Local time is now:      Sat Nov  6 16:05:13 CET 2021.
                                          Universal Time is now:  Sat Nov  6 15:05:13 UTC 2021.
                                          Dann Europa => Wien - und wenn Wien nicht funktioniert dann nimmst halt Berlin. ;)
