  4. BackitUP Mount Error, Proxmox LXC mit iobroker
    1.0k
    6.1k
90 Beiträge 7 Kommentatoren 10.7k Aufrufe 7 Beobachtet
    @homoran hatte es geändert auf NFS. ist hier der Fehler?
    @marcel-drzal
    Auch die nfs-utils installiert?
      @marcel-drzal sagte in BackitUP Mount Error, Proxmox LXC mit iobroker:
      bleib doch erst mal beei einem System.
      Ständiges Wechseln, ohne es einmal richtig gemacht zu haben, hilft nicht wirklich
        @homoran ok
        Hier ist mein Ziel Ordner auf der NAS
        /Backup/Iobroker_Backup
        Started iobroker ...
        [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"}
        [DEBUG] [mount] - noserverino option: false
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups"
        [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
        [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups"
        [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups
        mount error(1): Operation not permitted
        Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
        [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups
        [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [iobroker] - host.iobroker 4760 states saved
        [DEBUG] [iobroker] - host.iobroker 7353 objects saved
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_10_18-21_49_13_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        [DEBUG] [influxDB] - Start InfluxDB Backup ...
        [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
        [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
        [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
        [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_10_18-21_49_17_backupiobroker"
        /bin/sh: 1: influxd: not found
        [DEBUG] [grafana] - Start Grafana Backup ...
        [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
        [DEBUG] [grafana] - Created dashboard directory
        [DEBUG] [grafana] - Created dashboards_manually_restore directory
        [DEBUG] [grafana] - Created datasource directory
        [DEBUG] [grafana] - start Grafana request ...
        [DEBUG] [grafana] - Grafana is not available: Error: getaddrinfo ENOTFOUND http
        [DEBUG] [grafana] - Grafana is not available!
        [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
        [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
        [DEBUG] [grafana] - Grafana Backup cannot created ...
        [DEBUG] [grafana] - done
        [DEBUG] [javascripts] - javascript directory "/media/usb/scripts" not found
        [DEBUG] [javascripts] - done
        [DEBUG] [cifs] - done
        [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
        [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
        [DEBUG] [clean] - done
        [DEBUG] [pushover] - [iobroker] used pushover-Instance: pushover.0
        [DEBUG] [pushover] - done
        [DEBUG] [pushover] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_18-21_49_13_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_18-21_49_17_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_18-21_49_19_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker \"/opt/iobroker/backups/influxDB_2021_10_18-21_49_17_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de","time":"18. Oktober 2021 um 21:49 Uhr"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [historyHTML] - new history html values created
        [DEBUG] [historyHTML] - done
        [DEBUG] [historyJSON] - new history json values created
        [DEBUG] [historyJSON] - done
        [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_18-21_49_13_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_18-21_49_17_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_18-21_49_19_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker \"/opt/iobroker/backups/influxDB_2021_10_18-21_49_17_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"18. Oktober 2021 um 21:49 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [historyJSON] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_18-21_49_13_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_18-21_49_17_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_18-21_49_19_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker \"/opt/iobroker/backups/influxDB_2021_10_18-21_49_17_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"local","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"18. Oktober 2021 um 21:49 Uhr"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups"}
          @homoran ok
          @marcel-drzal
          Da fehlt die Arbeitsgruppe soweit ich das sehe.
          Und knips Mal die nicht verwendeten Backuptypen aus. Grafana und influxdb setzt du ein?
            @marcel-drzal
            Nutze Influxdb und Grafana
              @marcel-drzal
              Dann ist es aber für das Backup nicht richtig konfiguriert:
                @homoran ok
                wie ich bereits schrob:
                @homoran sagte in BackitUP Mount Error, Proxmox LXC mit iobroker:
                kein volume1!!
                und kein führender slash!!
                  @marcel-drzal
                  Stimmt. influx DB schreibt Verbindung aber ok zu sein
                  [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"remote","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                  [DEBUG] [iobroker] - host.iobroker 4763 states saved
                  [DEBUG] [iobroker] - host.iobroker 7355 objects saved
                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_10_19-12_44_53_backupiobroker.tar.gz
                  [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host 192.168.178.17:8088 "/opt/iobroker/backups/influxDB_2021_10_19-12_44_57_backupiobroker"
                  [DEBUG] [pushover] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_19-12_44_53_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_19-12_44_57_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_19-12_44_58_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker -host 192.168.178.17:8088 \"/opt/iobroker/backups/influxDB_2021_10_19-12_44_57_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"remote","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de","time":"19. Oktober 2021 um 12:44 Uhr"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                  [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_19-12_44_53_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_19-12_44_57_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_19-12_44_58_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker -host 192.168.178.17:8088 \"/opt/iobroker/backups/influxDB_2021_10_19-12_44_57_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"remote","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"19. Oktober 2021 um 12:45 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                  [DEBUG] [historyJSON] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_19-12_44_53_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_19-12_44_57_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_19-12_44_58_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker -host 192.168.178.17:8088 \"/opt/iobroker/backups/influxDB_2021_10_19-12_44_57_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"remote","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"19. Oktober 2021 um 12:45 Uhr"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                  ich gehe mal auf Remou
                  11edb7c5-f832-4ad6-a049-45a64785e380-grafik.png ```
                  code_text
                    kein volume1!!
                    #66
                      #67
                      @marcel-drzal sagte in BackitUP Mount Error, Proxmox LXC mit iobroker:
                      was willst du mir damit zeigen?
                      das der führende slash immer noch drin ist?
                        #68
                        ups
                        geht aber immer noch nicht
                          ups
                          #69
                          das heisst?
                          Außerdem laut Screenshot ist maximal SMB3 möglich
                          du hast aber 3.1.1 in der config.
                          versuch es mal mit einer niedrigeren Version
                            das heisst?
                            #70
                            1-3 druchprobiert
                            immer der selbe Feher:
                            Started iobroker ...
                            [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"}
                            [DEBUG] [mount] - noserverino option: false
                            [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups"
                            [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
                            [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups"
                            [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups
                            [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups
                            [DEBUG] [iobroker] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":[],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n"},"done":[],"types":[]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"remote","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_10_19-13_13_49_backupiobroker.tar.gz
                            [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker -host 192.168.178.17:8088 "/opt/iobroker/backups/influxDB_2021_10_19-13_13_53_backupiobroker"
                            [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                            [DEBUG] [pushover] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_19-13_13_49_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_19-13_13_53_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_19-13_13_54_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker -host 192.168.178.17:8088 \"/opt/iobroker/backups/influxDB_2021_10_19-13_13_53_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"remote","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de","time":"19. Oktober 2021 um 13:13 Uhr"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                            [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_19-13_13_49_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_19-13_13_53_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_19-13_13_54_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker -host 192.168.178.17:8088 \"/opt/iobroker/backups/influxDB_2021_10_19-13_13_53_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"remote","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"19. Oktober 2021 um 13:13 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                            [DEBUG] [historyJSON] start with {"type":"creator","time":"02:40","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_10_19-13_13_49_backupiobroker.tar.gz","/opt/iobroker/backups/influxDB_2021_10_19-13_13_53_backupiobroker.tar.gz","/opt/iobroker/backups/javascripts_2021_10_19-13_13_54_backupiobroker.tar.gz"],"errors":{"mount":"Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/Backup/Iobroker_Backup /opt/iobroker/backups\nmount error(1): Operation not permitted\nRefer to the mount.cifs(8) manual page (e.g. man mount.cifs)\n","influxDB":"Error: Command failed: influxd backup -portable -database iobroker -host 192.168.178.17:8088 \"/opt/iobroker/backups/influxDB_2021_10_19-13_13_53_backupiobroker\"\n/bin/sh: 1: influxd: not found\n"},"done":["iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","influxDB":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"nameSuffix":"","deleteBackupAfter":5,"dbName":"iobroker","host":"192.168.178.17","port":"8088","exe":"","dbType":"remote","deleteDataBase":true},"javascripts":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"filePath":"/media/usb/scripts"},"grafana":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"local","mount":"192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"webdav":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"host":"http://192.168.178.17","port":"3000","protocol":"http","username":"admin","pass":"****","apiKey":"****"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"5","systemLang":"de","time":"19. Oktober 2021 um 13:13 Uhr"},"telegram":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"hostName":"","systemLang":"de"},"email":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"","systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":true,"pushoverWaiting":0,"hostName":"","systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Pushover","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                            [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.178.35","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"deleteOldBackup":true,"ownDir":false,"dir":"/Backup/Iobroker_Backup","dirMinimal":"sharename/backupDir","user":"Backup","pass":"****","backupDir":"/opt/iobroker/backups"}
                            14247cda-c86e-4fd1-a785-bb892b3abb59-grafik.png code_text
                              1-3 druchprobiert
                              [DEBUG] [iobroker] - done
                              [DEBUG] [influxDB] - Start InfluxDB Backup ...
                              [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                              [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                              [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                              [DEBUG] [grafana] - Start Grafana Backup ...
                              [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                              [DEBUG] [grafana] - Created dashboard directory
                              [DEBUG] [grafana] - Created dashboards_manually_restore directory
                              [DEBUG] [grafana] - Created datasource directory
                              [DEBUG] [grafana] - start Grafana request ...
                              [DEBUG] [grafana] - Grafana is not available: Error: getaddrinfo ENOTFOUND http
                              [DEBUG] [grafana] - Grafana is not available!
                              [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                              [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                              [DEBUG] [grafana] - Grafana Backup cannot created ...
                              [DEBUG] [grafana] - done
                              [DEBUG] [javascripts] - javascript directory "/media/usb/scripts" not found
                              [DEBUG] [javascripts] - done
                              [DEBUG] [cifs] - done
                              [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                              [DEBUG] [clean] - done
                              [DEBUG] [pushover] - [iobroker] used pushover-Instance: pushover.0
                              [DEBUG] [pushover] - done
                              [DEBUG] [historyHTML] - new history html values created
                              [DEBUG] [historyHTML] - done
                              [DEBUG] [historyJSON] - new history json values created
                              [DEBUG] [historyJSON] - done
                              #71
                              Da fehlt noch was. Der Pfad ist bestimmt nicht so kurz.
                              Üblicherweise ist das sowas wie
                              //192.168.178.35/FREIGABE-WORKGROUP/Backup/Iobroker_Backup
                              oder sowas.
                                1-3 druchprobiert
                                #72
                                da ist ein Leerzeichen zu viel
                                Thomas BraunT ? 2 Antworten Letzte Antwort
                                  oder sowas.
                                  #73
                                  @thomas-braun sagte in BackitUP Mount Error, Proxmox LXC mit iobroker:
                                  oder sowas.
                                  muss auch ohne Domain/Arbeitsgruppennamen gehen
                                    #74
                                    @homoran sagte in BackitUP Mount Error, Proxmox LXC mit iobroker:
                                    Nö, das eine ist das entfernte Dateisystem, das andere der lokale Mountpunkt. Getrennt durch ein Leerzeichen.
                                      #75
                                      nein das ist ein Unterstrich _ ohne Lehrzeichen. habe eben geschaut
                                        #76
                                        stimmt!
                                        Sorry, es gab schon dümmere Fehler
                                        @marcel-drzal
                                        kannst du denn im Windoof-Explorer mit //192.168.178.35/Backup/Iobroker_Backup auf den share?
                                          oder sowas.
                                          #77
                                          alles gut, danke dir, hätte ja sein können, hab das Lehreichen geprüft
