  4. Gelöst: Raspi stirbt nach Backup ab
    6.4k
64 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
    Steinmetz_4
    schrieb am zuletzt editiert von Steinmetz_4
    ich habe das Problem, dass der Raspi 4 ( 8GB, SSD als Datenträger) nach dem Backup hängen bleibt. Ich muss ihn dann morgens stromlos machen und dann läuft er wieder bis zum nächsten Backup.
    2021-10-13 02:30:37.975 - info: host.raspberrypi instance system.adapter.ical.4 terminated with code 0 (NO_ERROR)
    2021-10-13 02:30:41.789 - info: daswetter.0 (25820) Terminated (NO_ERROR): Without reason
    2021-10-13 02:30:42.308 - info: daswetter.0 (25820) cleaned everything up...
    2021-10-13 02:30:42.329 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-10-13 02:35:00.132 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26139
    2021-10-13 02:35:02.437 - info: dwd.0 (26139) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:35:04.163 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26154
    2021-10-13 02:35:06.958 - info: netatmo-crawler.0 (26154) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:35:07.037 - info: netatmo-crawler.0 (26154) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 02:35:07.187 - info: dwd.0 (26139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 02:35:07.727 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:35:09.214 - info: netatmo-crawler.0 (26154) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 02:35:09.373 - info: netatmo-crawler.0 (26154) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 02:35:09.912 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:35:53.765 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 02:40:00.115 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26398
    2021-10-13 02:40:02.416 - info: netatmo-crawler.0 (26398) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:40:02.484 - info: netatmo-crawler.0 (26398) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 02:40:02.744 - info: netatmo-crawler.0 (26398) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 02:40:02.908 - info: netatmo-crawler.0 (26398) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 02:40:03.449 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:40:04.166 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26413
    2021-10-13 02:40:06.352 - info: dwd.0 (26413) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:40:07.757 - info: dwd.0 (26413) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 02:40:08.313 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:45:00.205 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26670
    2021-10-13 02:45:02.880 - info: dwd.0 (26670) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:45:04.241 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26685
    2021-10-13 02:45:07.437 - info: netatmo-crawler.0 (26685) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:45:07.533 - info: netatmo-crawler.0 (26685) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 02:45:07.688 - info: dwd.0 (26670) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 02:45:07.860 - info: netatmo-crawler.0 (26685) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 02:45:08.037 - info: netatmo-crawler.0 (26685) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 02:45:08.223 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:45:08.272 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 26700
    2021-10-13 02:45:08.576 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:45:10.785 - info: daswetter.0 (26700) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:45:12.303 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 26715
    2021-10-13 02:45:15.331 - info: coronavirus-statistics.0 (26715) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:45:27.603 - info: coronavirus-statistics.0 (26715) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-10-13 02:45:28.149 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:45:34.482 - info: daswetter.0 (26700) still wrong data structure from server received! repaired...
    2021-10-13 02:45:40.431 - info: daswetter.0 (26700) Terminated (NO_ERROR): Without reason
    2021-10-13 02:45:40.946 - info: daswetter.0 (26700) cleaned everything up...
    2021-10-13 02:45:40.960 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-10-13 02:45:53.759 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 02:50:00.165 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26961
    2021-10-13 02:50:02.864 - info: netatmo-crawler.0 (26961) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:50:02.964 - info: netatmo-crawler.0 (26961) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 02:50:03.286 - info: netatmo-crawler.0 (26961) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 02:50:03.462 - info: netatmo-crawler.0 (26961) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 02:50:04.018 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:50:04.200 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26976
    2021-10-13 02:50:06.827 - info: dwd.0 (26976) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:50:08.131 - info: dwd.0 (26976) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 02:50:08.659 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:55:00.128 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 27217
    2021-10-13 02:55:02.903 - info: dwd.0 (27217) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:55:04.163 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 27232
    2021-10-13 02:55:07.283 - info: netatmo-crawler.0 (27232) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:55:07.376 - info: netatmo-crawler.0 (27232) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 02:55:07.465 - info: dwd.0 (27217) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 02:55:08.025 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:55:08.707 - info: netatmo-crawler.0 (27232) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 02:55:08.875 - info: netatmo-crawler.0 (27232) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 02:55:09.423 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:55:53.757 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 03:00:00.036 - info: javascript.0 (825) script.js.Astro_ausführlich: Astro: Gültige Zeiten: [aktueller Tag: 13] | [nächster Tag: 1] | [Aktualisiert: 0] | Aktuelle Tageszeit: Mitternacht | Kommende Tageszeit: Früher Morgen
    2021-10-13 03:00:00.278 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 27477
    2021-10-13 03:00:03.067 - info: netatmo-crawler.0 (27477) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:03.137 - info: netatmo-crawler.0 (27477) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:00:04.251 - info: netatmo-crawler.0 (27477) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:00:04.325 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 27492
    2021-10-13 03:00:05.115 - info: netatmo-crawler.0 (27477) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:00:05.676 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:00:06.912 - info: dwd.0 (27492) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:08.364 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 27507
    2021-10-13 03:00:08.793 - info: dwd.0 (27492) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:00:09.343 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:00:10.914 - info: coronavirus-statistics.0 (27507) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:12.408 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 27523
    2021-10-13 03:00:15.514 - info: daswetter.0 (27523) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:16.458 - info: host.raspberrypi instance system.adapter.ical.4 started with pid 27538
    2021-10-13 03:00:20.273 - info: ical.4 (27538) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:20.495 - info: host.raspberrypi instance system.adapter.ical.3 started with pid 27553
    2021-10-13 03:00:21.088 - info: ical.4 (27538) processing URL: calendar1 https://calendar.google.com/calendar/ical/bodb8db8cl9aj6ks81gq0rvsv0%40group.calendar.google.com/private-a297fa24a9c2ccd3c422eab38644d026/basic.ics
    2021-10-13 03:00:21.280 - info: coronavirus-statistics.0 (27507) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-10-13 03:00:21.828 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:00:24.148 - info: ical.3 (27553) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:24.530 - info: host.raspberrypi instance system.adapter.ical.1 started with pid 27568
    2021-10-13 03:00:24.633 - info: ical.3 (27553) processing URL: Tom https://calendar.google.com/calendar/ical/k6qjv6gq9102nheldtj973mdu0%40group.calendar.google.com/private-c35a23b62937bd516a7637b1c02e7941/basic.ics
    2021-10-13 03:00:26.610 - info: ical.4 (27538) Terminated (NO_ERROR): Without reason
    2021-10-13 03:00:27.216 - info: host.raspberrypi instance system.adapter.ical.4 terminated with code 0 (NO_ERROR)
    2021-10-13 03:00:28.449 - info: ical.1 (27568) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:28.586 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 27628
    2021-10-13 03:00:29.038 - info: ical.1 (27568) processing URL: Schichtplan https://calendar.google.com/calendar/ical/opljlsoo63f4urc934b94kfpr4%40group.calendar.google.com/private-d8521c5f76a79bff0e8c5bfd4a94f90c/basic.ics
    2021-10-13 03:00:29.754 - info: ical.3 (27553) Terminated (NO_ERROR): Without reason
    2021-10-13 03:00:30.297 - info: host.raspberrypi instance system.adapter.ical.3 terminated with code 0 (NO_ERROR)
    2021-10-13 03:00:32.207 - info: ical.0 (27628) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:32.949 - info: ical.0 (27628) processing URL: Geburtstage und Termine https://calendar.google.com/calendar/ical/stadlmayrs.strass%40gmail.com/private-505b1877c7abcf82f8d2949452f471f1/basic.ics
    2021-10-13 03:00:34.271 - info: ical.1 (27568) Terminated (NO_ERROR): Without reason
    2021-10-13 03:00:34.804 - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
    2021-10-13 03:00:38.539 - info: ical.0 (27628) Terminated (NO_ERROR): Without reason
    2021-10-13 03:00:39.080 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2021-10-13 03:00:42.469 - info: daswetter.0 (27523) still wrong data structure from server received! repaired...
    2021-10-13 03:00:47.938 - info: daswetter.0 (27523) Terminated (NO_ERROR): Without reason
    2021-10-13 03:00:48.454 - info: daswetter.0 (27523) cleaned everything up...
    2021-10-13 03:00:48.470 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-10-13 03:05:00.115 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 27827
    2021-10-13 03:05:02.591 - info: dwd.0 (27827) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:05:04.154 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 27842
    2021-10-13 03:05:07.118 - info: netatmo-crawler.0 (27842) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:05:07.224 - info: netatmo-crawler.0 (27842) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:05:07.371 - info: dwd.0 (27827) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:05:07.527 - info: netatmo-crawler.0 (27842) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:05:07.707 - info: netatmo-crawler.0 (27842) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:05:07.919 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:05:08.249 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:05:53.753 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 03:09:19.881 - warn: sonnen.0 (1363) [REQUEST] <== Error: connect ECONNREFUSED 192.168.178.84:80
    2021-10-13 03:09:19.899 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:09:45.396 - warn: sonnen.0 (1363) [REQUEST] <== Error: connect EHOSTUNREACH 192.168.178.84:80
    2021-10-13 03:09:45.396 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:09:52.400 - warn: sonnen.0 (1363) [REQUEST] <== Error: connect ECONNREFUSED 192.168.178.84:80
    2021-10-13 03:09:52.400 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:10:00.136 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28084
    2021-10-13 03:10:03.048 - info: netatmo-crawler.0 (28084) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:10:03.125 - info: netatmo-crawler.0 (28084) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:10:03.406 - info: netatmo-crawler.0 (28084) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:10:03.582 - info: netatmo-crawler.0 (28084) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:10:04.126 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:10:04.181 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28099
    2021-10-13 03:10:06.489 - warn: sonnen.0 (1363) [REQUEST] <== 502 - "\n\n\n\n\n\n\n\n\n\n\n
    \n
    \n
    \n
    Something went wrong
    \n
    sonnen Services not running, yet?
    \n
    Try again
    \n
    \n
    \n\n\n"
    2021-10-13 03:10:06.489 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:10:06.522 - info: dwd.0 (28099) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:10:07.803 - info: dwd.0 (28099) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:10:08.336 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:10:13.494 - warn: sonnen.0 (1363) [REQUEST] <== 502 - "\n\n\n\n\n\n\n\n\n\n\n
    \n
    \n
    \n
    \n
    \n
    Try again
    \n
    \n
    \n\n\n"
    2021-10-13 03:10:13.494 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:10:20.498 - warn: sonnen.0 (1363) [REQUEST] <== 502 - "\n\n\n\n\n\n\n\n\n\n\n
    \n
    \n
    \n
    \n
    \n
    Try again
    \n
    \n
    \n\n\n"
    2021-10-13 03:10:20.499 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:12:00.092 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 28208
    2021-10-13 03:12:02.880 - info: weatherunderground.0 (28208) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:12:11.165 - info: weatherunderground.0 (28208) Terminated (NO_ERROR): Without reason
    2021-10-13 03:12:11.700 - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2021-10-13 03:15:00.142 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28362
    2021-10-13 03:15:02.678 - info: dwd.0 (28362) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:15:04.186 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28377
    2021-10-13 03:15:07.309 - info: netatmo-crawler.0 (28377) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:15:07.442 - info: netatmo-crawler.0 (28377) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:15:07.538 - info: dwd.0 (28362) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:15:07.752 - info: netatmo-crawler.0 (28377) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:15:07.932 - info: netatmo-crawler.0 (28377) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:15:08.073 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:15:08.216 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 28392
    2021-10-13 03:15:08.473 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:15:10.787 - info: daswetter.0 (28392) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:15:12.248 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 28407
    2021-10-13 03:15:15.219 - info: coronavirus-statistics.0 (28407) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:15:29.033 - info: coronavirus-statistics.0 (28407) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-10-13 03:15:29.571 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:15:32.730 - info: daswetter.0 (28392) still wrong data structure from server received! repaired...
    2021-10-13 03:15:38.516 - info: daswetter.0 (28392) Terminated (NO_ERROR): Without reason
    2021-10-13 03:15:39.038 - info: daswetter.0 (28392) cleaned everything up...
    2021-10-13 03:15:39.060 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-10-13 03:15:53.751 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 03:20:00.078 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28659
    2021-10-13 03:20:02.985 - info: netatmo-crawler.0 (28659) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:20:03.063 - info: netatmo-crawler.0 (28659) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:20:03.380 - info: netatmo-crawler.0 (28659) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:20:03.563 - info: netatmo-crawler.0 (28659) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:20:04.129 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28674
    2021-10-13 03:20:04.135 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:20:06.718 - info: dwd.0 (28674) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:20:08.255 - info: dwd.0 (28674) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:20:08.786 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:20:51.839 - warn: telegram.0 (706) polling_error: EFATAL, EFATAL: Error: read ECONNRESET
    2021-10-13 03:21:16.837 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 error: Error: read ECONNRESET
    2021-10-13 03:21:16.882 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 closed: null
    2021-10-13 03:21:16.885 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 error: Error: read ECONNRESET
    2021-10-13 03:21:16.890 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 closed: null
    2021-10-13 03:21:17.214 - error: worx.0 (1475) MQTT ERROR: Error: read ECONNRESET
    2021-10-13 03:21:21.882 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 reconnected
    2021-10-13 03:21:21.907 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 reconnected
    2021-10-13 03:21:22.090 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 connected
    2021-10-13 03:21:22.097 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 connected
    2021-10-13 03:21:42.096 - warn: meross.0 (934) Can not get Abilities for Device 2007226276811490821748e1e9264b44: Error: Timeout / undefined
    2021-10-13 03:21:42.099 - warn: meross.0 (934) Can not get Abilities for Device 2007220281502290821748e1e9264585: Error: Timeout / undefined
    2021-10-13 03:23:00.099 - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 28825
    2021-10-13 03:23:02.594 - info: openweathermap.0 (28825) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:23:07.978 - info: openweathermap.0 (28825) Terminated (NO_ERROR): Without reason
    2021-10-13 03:23:08.511 - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2021-10-13 03:25:00.108 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28931
    2021-10-13 03:25:02.642 - info: dwd.0 (28931) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:25:04.164 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28946
    2021-10-13 03:25:07.154 - info: netatmo-crawler.0 (28946) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:25:07.250 - info: netatmo-crawler.0 (28946) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:25:07.309 - info: dwd.0 (28931) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:25:07.773 - info: netatmo-crawler.0 (28946) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:25:07.845 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:25:09.480 - info: netatmo-crawler.0 (28946) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:25:10.011 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:25:53.748 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 03:17:17.743 - info: host.raspberrypi iobroker.js-controller version 3.3.18 js-controller starting
    2021-10-13 03:17:17.748 - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-10-13 03:17:17.749 - info: host.raspberrypi hostname: raspberrypi, node: v12.22.6
    2021-10-13 03:17:17.750 - info: host.raspberrypi ip addresses: 192.168.178.185 fe80::8570:e996:c644:2cf9
    2021-10-13 03:17:18.625 - info: host.raspberrypi connected to Objects and States
    2021-10-13 03:17:18.729 - info: host.raspberrypi added notifications configuration of host
    2021-10-13 03:17:19.830 - info: host.raspberrypi 65 instances found
    2021-10-13 03:17:19.935 - info: host.raspberrypi starting 43 instances
    2021-10-13 03:17:20.077 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 647
    2021-10-13 03:17:21.877 - error: admin.0 (647) admin.0 already running
    2021-10-13 03:17:21.880 - warn: admin.0 (647) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-10-13 03:17:22.561 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-10-13 03:17:22.562 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2021-10-13 03:17:24.583 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 658
    2021-10-13 03:17:27.188 - error: javascript.0 (658) javascript.0 already running
    2021-10-13 03:17:27.191 - warn: javascript.0 (658) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-10-13 03:17:27.864 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-10-13 03:17:27.866 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
    2021-10-13 03:17:28.052 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 669
    2021-10-13 03:17:29.240 - error: node-red.0 (669) node-red.0 already running
    2021-10-13 03:17:29.242 - warn: node-red.0 (669) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-10-13 03:17:29.848 - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-10-13 03:17:29.849 - info: host.raspberrypi Restart adapter system.adapter.node-red.0 because enabled
    2021-10-13 03:17:32.101 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 680
    2021-10-13 03:17:34.086 - error: telegram.0 (680) telegram.0 already running
    2021-10-13 03:17:34.088 - warn: telegram.0 (680) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-10-13 03:17:34.695 - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-10-13 03:17:34.696 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    Auf dem Pi sieht das ganze dann so aus:
    Was läuft hier falsch?
    Mfg
    Tom
    Raspi 4 mit aktuellem IoBroker Master (The Brain)
    Raspi 4 mit aktuellem IoBroker Slave und DS18b20 für Warmwasser und Pufferspeicher
    Raspi 4 mit aktuellem Motioneye
    3 x Heizstab zur PV-Eigenverbrauchsoptimierung
    ETS 5 Professionel - 5.7.5
    Samsung Tab 2 - 10.1
    Buskomponenten von MDT
    • S Steinmetz_4
      \n
      \n
      \n
      \n
      \n
      Try again
      \n
      \n
      \n\n\n"
      \n
      \n
      \n
      \n
      \n
      Try again
      \n
      \n
      \n\n\n"
      \n
      \n
      \n
      \n
      \n
      Try again
      \n
      \n
      \n\n\n"
      Mfg
      Tom
      @steinmetz_4
      Dateisystem defekt.
      SD-Karte (?) austauschen, Neuinstallation, Backup (von vor dem Defekt) einspielen.
        @steinmetz_4
        Dateisystem defekt.
        Steinmetz_4
        Eine SD karte habe ich nicht, läuft über externe SSD.
        Du meinst, dass die hin ist?
        • S Steinmetz_4
          @steinmetz_4 Zumindest das Dateisystem hat 'nen Schuss. Defekte inodes. Kann z.B. durch 'Stromausfall' passieren. Also nie einfach den Saft abdrehen, immer sauber herunterfahren.
            Steinmetz_4
            Stimmt, da war was. Nachts war mal der Strom weg...
            Eine Reparatur kommt nicht in frage?
            Also:
            jetzt meine ganzen Daten manuell kopieren und dann nach Neuinstallation wieder einfügen?
            • S Steinmetz_4
              Also:
              @steinmetz_4
              Du hast kein Backup?
              Die Daten da jetzt runterzukratzen ist wenig sinnvoll, wer sagt denn das die nicht auch defekt sind?
                @steinmetz_4
                Steinmetz_4
                Die Backups werden dann wohl auch im Eimer sein, weil das ja nicht so geklappt hat wie es soll...
                • S Steinmetz_4
                  @steinmetz_4
                  Hast du kein Backup von vorher auf einem externen Speichermedium?
                    @steinmetz_4
                    Steinmetz_4
                    Es ging alles schief, was schief gehen kann...
                    Es waren zwar Backups da, aber die waren unbrauchbar, weil schon fast zwei Wochen alt.
                    Irgendwann muss irgendwer (evtl. Ich) während des Schreibprozesses versehentlich im Wohnzimmer auf den MasterPowerOff-Schalter gedrückt haben.
                    Ich hab mir erst nichts dabei gedacht, lief ja noch alles.
                    Dann ein paar Tage keine Zeit gehabt was zu tun und siehe da, alles im Eimer.
                    Nun gut, is hald so. Mal kräftig geflucht, ein paar Frustbier und von vorn...
                    Hab mich jetzt zwei Tage hin gesetzt und mehr oder minder bei null angefangen und alles neu installiert. Nun läufts!
                    NAS mount und Automatische Sicherung waren das erste und laufen fehlerfrei. Meine Visu Daten habe ich aus manuellen Sicherungen weitestgehend wieder herstellen können, da ich als Windows Nutzer immer mal gerne sicherheitshalber den ein oder anderen Ordner Kopiere und auf mein NAS lege.
                    Jetzt aktuell gibt es noch zwei Probleme:
                    1. iobroker findet den Source Analytics Adapter nicht
                    2. mein FLOT-Adapter zeigt nach ein paar Stunden nur noch grün, der Link in der Visu läuft aber noch.
                    Mfg
                    Tom
                    • S Steinmetz_4
                      Mfg
                      Tom
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @steinmetz_4 sagte in Raspi stirbt nach Backup ab:
                      Das heißt , für uns Außenstehende was ?
                      ... steht was im Log , oder was meinst du !?
                      • GlasfaserG Glasfaser
                        Steinmetz_4
                        @glasfaser
                        sorry, Du hast recht...
                        Das war natürlich ein Hilferuf, wenn auch nicht ganz offensichtlich.
                        Vielleicht hat jemand das selbe, oder ein ähnliches Problem schon mal gehabt und kann mir einen Schubs in die richtige Richtung geben. Ich hab in der Suche nichts gefunden und in der Log-Datei kann ich auch keinen Hinweis erkennen (weil ich auch gar nicht weis, wonach ich suchen soll).
                        • S Steinmetz_4
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Nochmal , wie erkennst du denn das
                          Fehlt der Adapter in der Liste
                          Fehlt die Instanz
                          Fehlt im Datenpunkt die Einstellung
                            Fehlt die Instanz
                            Steinmetz_4
                            @glasfaser
                            Er taucht bei der Suche nicht auf.
                            • S Steinmetz_4
                              @glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @steinmetz_4
                              Die Seite ist nicht richtig geladen , da fehlt z.b . die Ordner
                                @steinmetz_4
                                @glasfaser sagte in Gelöst: Raspi stirbt nach Backup ab:
                                das wird es nicht sein ;-)
                                github:	0.4.12-1
                                latest:	0.4.12-1 for 49 days
                                stable:	-.-.-
                                  github:	0.4.12-1
                                  stable:	-.-.-
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @homoran sagte in Gelöst: Raspi stirbt nach Backup ab:
                                  Ja .. ist ja gut , sehe gerade ist default ... aber man weiß ja nicht ober er den Link geändert hat :) ( brauchte eine Ausrede ... )
                                  Es wäre mal interessant ,
                                  ob auch so die Ordner fehlen , wenn er etwas in stable sucht !?
                                    puuuh!
                                    oder weil alles herausgefiltert ist und keinerlei Ordner existieren?
                                    habe gerade keine v5 zur Verfügung zum Testen
                                      puuuh!
                                      Steinmetz_4
                                      Klingt, als hättet Ihr eine Idee?
                                      • S Steinmetz_4
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @steinmetz_4
                                        Nimm mal Source Analytics aus der Suche .
                                        Fehlen da Ordner ?
                                        Zeige mal dann ein Screenshot davon mit der normalen Auflistung
                                          @steinmetz_4
                                          Fehlen da Ordner ?
                                          Steinmetz_4
                                          @glasfaser
                                          Ja, fehlen.
                                          GlasfaserG S 2 Antworten Letzte Antwort
