  4. Gelöst: Backitup mountet Nas nicht
    6.4k
15 Beiträge 4 Kommentatoren 1.8k Aufrufe 3 Beobachtet
  • S Steinmetz_4
    mein Backitup schafft es nicht mein Nas zu finden. Es kommt immer der Fehler:
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=IoBroker,password=****,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.178.3/Volume_1/Sicherungen /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=IoBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.3/Volume_1/Sicherungen /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=IoBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.3/Volume_1/Sicherungen /opt/iobroker/backups
    mount error(112): Host is down
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    auf dem Raspi steht folgendes:
    pi@raspberrypi:/opt/iobroker/iobroker-data $ tail -f  /var/log/kern.log
    Oct  8 10:08:35 raspberrypi kernel: [ 9292.739607] CIFS: Attempting to mount //192.168.178.3/Volume_1/Sicherungen
    Oct  8 10:08:35 raspberrypi kernel: [ 9292.739662] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    Oct  8 10:08:35 raspberrypi kernel: [ 9292.766983] CIFS: VFS: cifs_mount failed w/return code = -13
    Oct  8 10:08:35 raspberrypi kernel: [ 9292.818170] CIFS: Attempting to mount //192.168.178.3/Volume_1/Sicherungen
    Oct  8 10:08:35 raspberrypi kernel: [ 9292.826646] CIFS: VFS: cifs_mount failed w/return code = -112
    Oct  8 10:08:51 raspberrypi kernel: [ 9309.050644] CIFS: Attempting to mount //192.168.178.3/Volume_1/Sicherungen
    Oct  8 10:08:51 raspberrypi kernel: [ 9309.050695] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    Oct  8 10:08:51 raspberrypi kernel: [ 9309.077106] CIFS: VFS: cifs_mount failed w/return code = -13
    Oct  8 10:08:51 raspberrypi kernel: [ 9309.125520] CIFS: Attempting to mount //192.168.178.3/Volume_1/Sicherungen
    Oct  8 10:08:51 raspberrypi kernel: [ 9309.133902] CIFS: VFS: cifs_mount failed w/return code = -112
    Ich finde auch bei Google keine lösung.
    Hat jemand eine Idee?
    Mfg
    Tom
    amg_666A Offline
    amg_666A Offline
    amg_666
    @steinmetz_4 dann hast du ein anderes google alsi ch :-)
    "cifs mount error 13" = Permission denied.
    Scheint ein Rechteproblem zu sein, passen user, passwort etc, stimmen die Freigaben auf dem Volume?
    "cifs mount 112" = Host ist down.
    Sicher, dass der Raspi den NAS überhaupt erreichen kann?
    • amg_666A amg_666
      Steinmetz_4
      @amg_666
      Sicher bin ich mir nicht.
      pi@raspberrypi:/opt/iobroker/iobroker-data $ showmount -e 192.168.178.3
      Export list for 192.168.178.3:
      /mnt/HD/HD_a2             *
      /mnt/HD/HD_a2/Name von der Redaktion geändert      *
      /mnt/HD/HD_a2/Sicherungen *
      Raspi 4 mit aktuellem IoBroker Master (The Brain)
      Raspi 4 mit aktuellem IoBroker Slave und DS18b20 für Warmwasser und Pufferspeicher
      Raspi 4 mit aktuellem Motioneye
      3 x Heizstab zur PV-Eigenverbrauchsoptimierung
      ETS 5 Professionel - 5.7.5
      Samsung Tab 2 - 10.1
      Buskomponenten von MDT
      • S Steinmetz_4
        Mfg
        Tom
        GlasfaserG Offline
        GlasfaserG Offline
        @steinmetz_4 sagte in Backitup mountet Nas nicht:
        Laut deiner Backitup Einstellung:
        Laut showmount
        Was ist das für eine NAS
        S GlasfaserG 2 Antworten Letzte Antwort
        • GlasfaserG Glasfaser
          Laut showmount
          Steinmetz_4
          @glasfaser
          Ist ein Dlink - ShareCenter™ 2-Bay Network Storage Enclosure DNS-320
          GlasfaserG amg_666A 2 Antworten Letzte Antwort
          • S Steinmetz_4
            @glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            @steinmetz_4
            Dlink
            kenne ich leider nicht .
            Die Meldung hast du auch gesehen !
            SMB auch richtig eingestellt :
            CIFS
              @steinmetz_4
              Dlink
              CIFS
              Steinmetz_4
              schrieb am zuletzt editiert von Steinmetz_4
              @glasfaser
              Ein altes NAS, das aber bisher immer zuverlässig seinen Dienst vollzogen hat...
              Ja, habe ich gesehen. Ich weiß aber damit nichts anzufangen. Ich habe keine Ahnung, welche Version mein NAS denn bevorzugt. Soll ich das im Backitup mal ändern auf 2.0 oder höher?
              Hab ich gerade gemacht, bringt alles nix...
                Laut showmount
                GlasfaserG Offline
                GlasfaserG Offline
                @Steinmetz_4
                @glasfaser sagte in Backitup mountet Nas nicht:
                Laut showmount
                wie kommst du auf /Volume_1 in der Pfandangabe
                  @Steinmetz_4
                  Laut showmount
                  Steinmetz_4
                  @glasfaser
                  Keine Ahnung, hab ich aus Windows so im Kopf...
                  Hab es schon geändert auf /mnt/HD/HD_a2/Sicherungen, aber es ändert sich nichts. Es ist wohl irgendwo ein Fehler in den NAS- Einstellungen...
                  • S Steinmetz_4
                    @glasfaser
                    @glasfaser
                    IMHO auch nicht richtig.
                    Bei CIFS musst du den Freigabenamen eingeben, wie er auf dem NAS dafür definiert ist (Das ist es doch hoffentlich!)
                      @glasfaser
                      Steinmetz_4
                      @homoran Du Goldschatz!
                      Wald vor lauter Bäumen und so...
                      Ich hab natürlich immer den ganzen Pfad angegeben mit "Volume_1"
                      Nun scheint sich was zu tun...
                      Tausend Dank!
                      Wenn Du mal Richtung PLZ 866.. kommst, melde Dich. Es gibt ein Bier...
                      • S Steinmetz_4
                        Tausend Dank!
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Oh je ... 😁 😎
                        @Steinmetz_4
                        deshalb auch meine Frage dazu ;)
                        • S Steinmetz_4
                          @glasfaser
                          amg_666A Offline
                          amg_666A Offline
                          amg_666
                          Ist ein Dlink - ShareCenter 2-Bay Network Storage Enclosure DNS-320
                          Habs leider erst jetzt gelesen. Läuft es jetzt?
                          Falls nicht, das DLINK Sharecenter hab ich auch (sogar 2mal :-) ). Ich kann dir da gerne meine Settings senden, mit denen es funktioniert.
                          • amg_666A amg_666
                            Steinmetz_4
                            @amg_666
                            Ja, läuft!
                            Du kannst mir aber trotzdem alles senden was Du hat, ich lass mich gerne eines besseren belehren....
                            • S Steinmetz_4
                              @amg_666
                              Ja, läuft!
                              amg_666A Offline
                              amg_666A Offline
                              amg_666
                              schrieb am zuletzt editiert von amg_666
                              @steinmetz_4 Also, im Sharecenter habe ich im Account Managemenrt einen Network Share "Volume1" angelegt
                              Darunter liegt ein Ordner "SicherungRaspi\Auto", den hab ich im Windows-Explorer auf dem Share angelegt.
                              Unter Usermanagement einen user "raspi" mit Passwort und Lese/Schreibrechten.
                              Dann im Backupadapter FTP einrichten mit IP Adresse und standardport 21, User und Passwort und der genauen Pfadangabe (Achtung Pfad mit "Slash" nicht "Backslash":
