  4. Gelöst: Backitup mountet Nas nicht
    6.4k
15 Beiträge 4 Kommentatoren 1.8k Aufrufe 3 Beobachtet
    Steinmetz_4
    schrieb am zuletzt editiert von Steinmetz_4
    mein Backitup schafft es nicht mein Nas zu finden. Es kommt immer der Fehler:
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=IoBroker,password=****,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.178.3/Volume_1/Sicherungen /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=IoBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.3/Volume_1/Sicherungen /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=IoBroker,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.3/Volume_1/Sicherungen /opt/iobroker/backups
    mount error(112): Host is down
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
    auf dem Raspi steht folgendes:
    pi@raspberrypi:/opt/iobroker/iobroker-data $ tail -f  /var/log/kern.log
    Oct  8 10:08:35 raspberrypi kernel: [ 9292.739607] CIFS: Attempting to mount //192.168.178.3/Volume_1/Sicherungen
    Oct  8 10:08:35 raspberrypi kernel: [ 9292.739662] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    Oct  8 10:08:35 raspberrypi kernel: [ 9292.766983] CIFS: VFS: cifs_mount failed w/return code = -13
    Oct  8 10:08:35 raspberrypi kernel: [ 9292.818170] CIFS: Attempting to mount //192.168.178.3/Volume_1/Sicherungen
    Oct  8 10:08:35 raspberrypi kernel: [ 9292.826646] CIFS: VFS: cifs_mount failed w/return code = -112
    Oct  8 10:08:51 raspberrypi kernel: [ 9309.050644] CIFS: Attempting to mount //192.168.178.3/Volume_1/Sicherungen
    Oct  8 10:08:51 raspberrypi kernel: [ 9309.050695] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
    Oct  8 10:08:51 raspberrypi kernel: [ 9309.077106] CIFS: VFS: cifs_mount failed w/return code = -13
    Oct  8 10:08:51 raspberrypi kernel: [ 9309.125520] CIFS: Attempting to mount //192.168.178.3/Volume_1/Sicherungen
    Oct  8 10:08:51 raspberrypi kernel: [ 9309.133902] CIFS: VFS: cifs_mount failed w/return code = -112
    Ich finde auch bei Google keine lösung.
    Hat jemand eine Idee?
    Mfg
    Tom
    Raspi 4 mit aktuellem IoBroker Master (The Brain)
    Raspi 4 mit aktuellem IoBroker Slave und DS18b20 für Warmwasser und Pufferspeicher
    Raspi 4 mit aktuellem Motioneye
    3 x Heizstab zur PV-Eigenverbrauchsoptimierung
    ETS 5 Professionel - 5.7.5
    Samsung Tab 2 - 10.1
    Buskomponenten von MDT
    amg_666A GlasfaserG 2 Antworten Letzte Antwort
    • S Steinmetz_4
      Mfg
      Tom
      amg_666A Offline
      amg_666A Offline
      amg_666
      @steinmetz_4 dann hast du ein anderes google alsi ch :-)
      "cifs mount error 13" = Permission denied.
      Scheint ein Rechteproblem zu sein, passen user, passwort etc, stimmen die Freigaben auf dem Volume?
      "cifs mount 112" = Host ist down.
      Sicher, dass der Raspi den NAS überhaupt erreichen kann?
      • amg_666A amg_666
        Steinmetz_4
        @amg_666
        Sicher bin ich mir nicht.
        pi@raspberrypi:/opt/iobroker/iobroker-data $ showmount -e 192.168.178.3
        Export list for 192.168.178.3:
        /mnt/HD/HD_a2             *
        /mnt/HD/HD_a2/Name von der Redaktion geändert      *
        /mnt/HD/HD_a2/Sicherungen *
        • S Steinmetz_4
          Mfg
          Tom
          GlasfaserG Offline
          GlasfaserG Offline
          @steinmetz_4 sagte in Backitup mountet Nas nicht:
          Laut deiner Backitup Einstellung:
          Laut showmount
          Was ist das für eine NAS
          S GlasfaserG 2 Antworten Letzte Antwort
          • GlasfaserG Glasfaser
            Laut showmount
            Steinmetz_4
            @glasfaser
            Ist ein Dlink - ShareCenter™ 2-Bay Network Storage Enclosure DNS-320
            GlasfaserG amg_666A 2 Antworten Letzte Antwort
            • S Steinmetz_4
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              @steinmetz_4
              Dlink
              kenne ich leider nicht .
              Die Meldung hast du auch gesehen !
              SMB auch richtig eingestellt :
              CIFS
                @steinmetz_4
                Dlink
                CIFS
                Steinmetz_4
                @glasfaser
                Ein altes NAS, das aber bisher immer zuverlässig seinen Dienst vollzogen hat...
                Ja, habe ich gesehen. Ich weiß aber damit nichts anzufangen. Ich habe keine Ahnung, welche Version mein NAS denn bevorzugt. Soll ich das im Backitup mal ändern auf 2.0 oder höher?
                Hab ich gerade gemacht, bringt alles nix...
                  Laut showmount
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @Steinmetz_4
                  @glasfaser sagte in Backitup mountet Nas nicht:
                  Laut showmount
                  wie kommst du auf /Volume_1 in der Pfandangabe
                    @Steinmetz_4
                    Laut showmount
                    Steinmetz_4
                    @glasfaser
                    Keine Ahnung, hab ich aus Windows so im Kopf...
                    Hab es schon geändert auf /mnt/HD/HD_a2/Sicherungen, aber es ändert sich nichts. Es ist wohl irgendwo ein Fehler in den NAS- Einstellungen...
                    • S Steinmetz_4
                      @glasfaser
                      @glasfaser
                      IMHO auch nicht richtig.
                      Bei CIFS musst du den Freigabenamen eingeben, wie er auf dem NAS dafür definiert ist (Das ist es doch hoffentlich!)
                        @glasfaser
                        Steinmetz_4
                        @homoran Du Goldschatz!
                        Wald vor lauter Bäumen und so...
                        Ich hab natürlich immer den ganzen Pfad angegeben mit "Volume_1"
                        Nun scheint sich was zu tun...
                        Tausend Dank!
                        Wenn Du mal Richtung PLZ 866.. kommst, melde Dich. Es gibt ein Bier...
                        • S Steinmetz_4
                          Tausend Dank!
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Oh je ... 😁 😎
                          @Steinmetz_4
                          deshalb auch meine Frage dazu ;)
                          • S Steinmetz_4
                            @glasfaser
                            amg_666A Offline
                            amg_666A Offline
                            amg_666
                            Ist ein Dlink - ShareCenter 2-Bay Network Storage Enclosure DNS-320
                            Habs leider erst jetzt gelesen. Läuft es jetzt?
                            Falls nicht, das DLINK Sharecenter hab ich auch (sogar 2mal :-) ). Ich kann dir da gerne meine Settings senden, mit denen es funktioniert.
                            • amg_666A amg_666
                              Steinmetz_4
                              @amg_666
                              Ja, läuft!
                              Du kannst mir aber trotzdem alles senden was Du hat, ich lass mich gerne eines besseren belehren....
                              • S Steinmetz_4
                                @amg_666
                                Ja, läuft!
                                amg_666A Offline
                                amg_666A Offline
                                amg_666
                                schrieb am zuletzt editiert von amg_666
                                @steinmetz_4 Also, im Sharecenter habe ich im Account Managemenrt einen Network Share "Volume1" angelegt
                                Darunter liegt ein Ordner "SicherungRaspi\Auto", den hab ich im Windows-Explorer auf dem Share angelegt.
                                Unter Usermanagement einen user "raspi" mit Passwort und Lese/Schreibrechten.
                                Dann im Backupadapter FTP einrichten mit IP Adresse und standardport 21, User und Passwort und der genauen Pfadangabe (Achtung Pfad mit "Slash" nicht "Backslash":
