  4. Kann Adapter nicht installieren
    6.4k
21 Beiträge 5 Kommentatoren 2.3k Aufrufe 4 Beobachtet
    stenmic
    beim Versuch den "sainlogic" Adapter zu installieren kommt folgender Fehler.
    (Hatte ich aber die Tage aber auch schon beim HS100)
    $ ./iobroker add sainlogic 0 --host ioBroker-Master
    NPM version: 6.14.14
    npm install iobroker.sainlogic@0.7.2 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ETARGET
    npm ERR! notarget No matching version found for iobroker.sainlogic@0.7.2.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-08-04T04_19_47_549Z-debug.log
    ERROR: host.ioBroker-Master Cannot install iobroker.sainlogic@0.7.2: 1
    log:
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.sainlogic@0.7.2',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.14
    3 info using node@v12.22.4
    4 verbose npm-session 9ca16e53a6913013
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 304 https://registry.npmjs.org/iobroker.sainlogic 950ms (from cache)
    8 silly registry:manifest no matching version for iobroker.sainlogic@0.7.2 in the cache. Forcing revalidation.
    9 http fetch GET 200 https://registry.npmjs.org/iobroker.sainlogic 961ms
    10 silly fetchPackageMetaData error for iobroker.sainlogic@0.7.2 No matching version found for iobroker.sainlogic@0.7.2.
    11 timing stage:rollbackFailedOptional Completed in 1ms
    12 timing stage:runTopLevelLifecycles Completed in 5356ms
    13 verbose type version
    14 verbose stack iobroker.sainlogic: No matching version found for iobroker.sainlogic@0.7.2.
    14 verbose stack     at pickManifest (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
    14 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:43:18
    14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    14 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
    14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
    14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
    14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
    14 verbose stack     at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
    14 verbose stack     at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
    14 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
    14 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
    14 verbose stack     at processImmediate (internal/timers.js:461:21)
    15 verbose cwd /opt/iobroker
    16 verbose Linux 4.19.0-17-amd64
    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.sainlogic@0.7.2" "--loglevel" "error" "--prefix" "/opt/iobroker"
    18 verbose node v12.22.4
    19 verbose npm  v6.14.14
    20 error code ETARGET
    21 error notarget No matching version found for iobroker.sainlogic@0.7.2.
    22 error notarget In most cases you or one of your dependencies are requesting
    22 error notarget a package version that doesn't exist.
    23 verbose exit [ 1, true ]
    Jemand ne Idee?
    • S stenmic
      log:
      1 verbose cli [
      1 verbose cli ]
      Jemand ne Idee?
      GlasfaserG Offline
      GlasfaserG Offline
      @stenmic sagte in Kann Adapter nicht installieren:
      Jemand ne Idee?
      Ja , im Thread schauen :
      https://forum.iobroker.net/topic/33611/test-adapter-iobroker-sainlogic-v0-6-x-github-latest/199?_=1628052607158
      EDIT:
      siehe auch GitHub , im Issues
      https://github.com/phifogg/ioBroker.sainlogic/issues/91
      FoggF 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        Jemand ne Idee?
        EDIT:
        FoggF Offline
        FoggF Offline
        Fogg
        @glasfaser Hab heute eine neue Version frei gegeben... Repo ist aktualisiert, irgendwie will es trotzdem nicht. Ich warte drauf dass mir jemand sagt was falsch ist...
        • FoggF Fogg
          GlasfaserG Offline
          GlasfaserG Offline
          @fogg sagte in Kann Adapter nicht installieren:
          was meinst du , ob Fehler vorhanden sind ?
          2021-10-07 20:39:38.630 - error: sainlogic.0 (11685) DB closed
          2021-10-07 20:39:38.632 - error: sainlogic.0 (11685) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2021-10-07 20:39:38.633 - error: sainlogic.0 (11685) unhandled promise rejection: DB closed
          2021-10-07 20:39:38.633 - error: sainlogic.0 (11685) Error: DB closed
          FoggF GlasfaserG 2 Antworten Letzte Antwort
            FoggF Offline
            FoggF Offline
            Fogg
            @glasfaser Nein, ich kriege diese Meldung in meinem ioB wenn ich ein update machen will:
            npm install iobroker.sainlogic@0.7.3 --loglevel error --prefix "/opt/iobroker" (System call)
            npm ERR! notarget No matching version found for iobroker.sainlogic@0.7.3.
            Thomas BraunT GlasfaserG FabioF 3 Antworten Letzte Antwort
            • FoggF Fogg
              @fogg
              Bei mir taucht der auch (noch?) nicht im latest-Repo auf:
              echad@chet:~ $ iobroker update
              Used repository: live-beta
              hash unchanged, use cached sources
              update done
              Adapter    "sainlogic"     : 0.6.1    , installed 0.7.2
              [Edit:]
              Oh...
              echad@chet:~ $ iobroker upgrade sainlogic@0.7.3
              This upgrade of "sainlogic" will introduce the following changes:
              -> 0.7.3:
              Security fixes in dependencies, Travis pipeline update
              Would you like to upgrade sainlogic from @0.7.2 to @0.7.3 now? [(y)es, (n)o]: y
              Update sainlogic from @0.7.2 to @0.7.3
              NPM version: 7.24.0
              npm ERR!     /home/iobroker/.npm/_logs/2021-10-07T21_02_35_619Z-debug.log
              upload [4] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/words.js words.js application/javascript
              Update "system.adapter.sainlogic.0"
              upload [3] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/style.css style.css text/css
              upload [2] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/sainlogic.png sainlogic.png image/png
              upload [1] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/index_m.html index_m.html text/html
              upload [0] sainlogic.admin /opt/iobroker/node_modules/iobroker.sainlogic/admin/admin.d.ts admin.d.ts video/mp2t
              Adapter "sainlogic" updated
              • FoggF Fogg
                GlasfaserG Offline
                GlasfaserG Offline
                Keine Ahnung , habe ihn ohne Probleme installiert ... , nur kommen dann andere Fehlermeldungen .
                Siehe auch Screenshot oben .
                Habe auch dir hier geantwortet :
                https://forum.iobroker.net/topic/48293/adapter-version-wird-nicht-gefunden
                  @glasfaser
                  Regulär im Repo drin?
                  iobroker update -i
                  zeigt mir noch die 0.6.1 als verfügbar an.
                  Edith: Ah, stable zeigt 0.7.3, latest 0.6.1.
                  Aber auch aus stable kann ich das nicht ziehen. No target, wie oben schon gepostet.
                  • FoggF Fogg
                    FabioF Offline
                    FabioF Offline
                    Fabio
                    schrieb am zuletzt editiert von Fabio
                    @fogg also ich kann die Version 0.7.3 auch nicht installieren. Bekomme den selben Fehler.
                    Wenn ich aber über die Katze gehe dann kann ich Version 0.7.3 ohne Fehler installieren.
                    Es sieht so aus als ob die neue Version nicht am richtigen Platz liegt.
                    Iobroker:
                    • Matter over Thread Hilfe
                    • FabioF Fabio
                      FoggF Offline
                      FoggF Offline
                      Fogg
                      @fa-bio Ja genau, darum gehts ja :D
                      Ich weiss nicht wo ich den sonst hinlegen soll....
                      FabioF 1 Antwort Letzte Antwort
                        @glasfaser
                        iobroker update -i
                        FoggF Offline
                        FoggF Offline
                        Fogg
                        iobroker update -i
                        Im Latest wird soweit ich das sehe keine Version angegeben. Wo er die 0.6.1 hernimmt weiss ich nicht 🤷
                        • FoggF Fogg
                          FabioF Offline
                          FabioF Offline
                          Fabio
                          @fogg es tut mir leid ich würde dir ja sehr gerne helfen aber ich habe echt keine Ahnung. Ich hoffe jemand kann helfen.
                          Iobroker:
                          • FabioF Fabio
                            FoggF Offline
                            FoggF Offline
                            Fogg
                            Ich glaube ich weiss woran es liegt... ich habe das ganze noch nicht mit npm publish freigegeben. Da suche ich noch wie das geht...
                            • FoggF Offline
                              FoggF Offline
                              Fogg
                              Gefunden.... ein login hat gefehlt. Jetzt ist 0.7.3 komplett verfügbar. Puh.. was für eine Geburt :D
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @Fogg
                                @glasfaser sagte in Kann Adapter nicht installieren:
                                Und was ist mit dem Fehler !?
                                  @Fogg
                                  FoggF Offline
                                  FoggF Offline
                                  Fogg
                                  schrieb am zuletzt editiert von Fogg
                                  @glasfaser said in Kann Adapter nicht installieren:
                                  @Fogg
                                  Und was ist mit dem Fehler !?`
                                  Die sehe ich bei mir nicht. Welche node.js und js.controller Version hast Du?
                                  • FoggF Fogg
                                    FabioF Offline
                                    FabioF Offline
                                    Fabio
                                    @fogg Super gut gemacht.👍 😊
                                    Iobroker:
                                    • FoggF Fogg
                                      @Fogg
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @fogg
                                      v14.17.6
                                      v14.17.6
                                      6.14.15
                                      3.3.18
                                        @fogg
                                        v14.17.6
                                        v14.17.6
                                        6.14.15
                                        3.3.18
                                        FoggF Offline
                                        FoggF Offline
                                        Fogg
                                        @fogg
                                        v14.17.6
                                        v14.17.6
                                        6.14.15
                                        3.3.18
                                        Hm.. ich bin hier:
                                        NODE.JS: V13.14.0
                                        NPM: 6.14.5
                                        JSControler: 3.3.18
                                        Könnte quasi das Node-js sein. Aber sicher bin ich mir da nicht.
                                        • FoggF Fogg
                                          @fogg
                                          v14.17.6
                                          v14.17.6
                                          6.14.15
                                          3.3.18
                                          Hm.. ich bin hier:
                                          NODE.JS: V13.14.0
                                          NPM: 6.14.5
                                          JSControler: 3.3.18
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          V13.14.0
                                          Das ist aber eine ungerade Version
                                          Node.js Versions-Anforderungen Die unterstützten Node.js Versionen bleiben in diesem Update gleich: 10.x, 12.x und auch 14.x werden offiziell unterstützt. Aufgrund der übergreifenden Adapter-Kompatibilität bleibt die empfohlene Node.js Version für ioBroker aktuell weiterhin auf 12.x. Falls jemand bereits mit Node.js 16.x arbeiten möchte, dann bitte im Moment AUSSCHLIESSLICH mit npm 6 !! (Bei npm 7 gibt es noch Probleme mit GitHub Installs bei einigen Adaptern)
