  5. "im Text suche...."
    2.8k
    4.9k
    4.1k
"im Text suche...."
3 Beiträge 2 Kommentatoren 282 Aufrufe 2 Beobachtet
  • J Offline
    jwerlsdf
    ich möchte gerne folgendes Json auslesen:
    {"input": "stelle mir einen wecker für Montag auf 6 uhr 10",
    "intent": {
       		"intentName": "SetAlarm",
       		"confidenceScore": 1.0},
       		"siteId": "Wohnzimmer",
       		"id": "f19",
       		"slots":
       				"entity": "rhasspy/days",
       				"value": {"kind": "Unknown", "value": "Montag"},
       				"slotName": "Tag",
       				"rawValue": "Montag",
       				"confidence": 1.0,
       				"range": {"start": 28, "end": 34, "rawStart": 28, "rawEnd": 34}
       				"entity": "rhasspy/number",
       				"value": {"kind": "Number", "value": 6},
       				"slotName": "stunde",
       				"rawValue": "sechs",
       				"confidence": 1.0,
       				"range": {"start": 39, "end": 40, "rawStart": 39, "rawEnd": 44}
       				"value": {"kind": "Number", "value": 10},
       				"slotName": "minute",
       				"rawValue": "zehn",
       				"confidence": 1.0,
       				"range": {"start": 45, "end": 47, "rawStart": 49, "rawEnd": 53}
       		"sessionId": "f194af5b-c162-4643-92e8-7a746c95c676",
       		"customData": null,
       		"asrTokens": [
       				"value": "stelle",
       				"confidence": 1.0,
       				"rangeStart": 0,
       				"rangeEnd": 6,
       				"time": null
       				"value": "mir",
       				"confidence": 1.0,
       				"rangeStart": 7,
       				"rangeEnd": 10,
       				"time": null
       				"value": "einen",
       				"confidence": 1.0,
       				"rangeStart": 11,
       				"rangeEnd": 16,
       				"time": null
       				"value": "wecker",
       				"confidence": 1.0,
       				"rangeStart": 17,
       				"rangeEnd": 23,
       				"time": null
       				"value": "für",
       				"confidence": 1.0,
       				"rangeStart": 24,
       				"rangeEnd": 27,
       				"time": null
       				"value": "Montag",
       				"confidence": 1.0,
       				"rangeStart": 28,
       				"rangeEnd": 34,
       				"time": null
       				"value": "auf",
       				"confidence": 1.0,
       				"rangeStart": 35,
       				"rangeEnd": 38,
       				"time": null
       				"value": "6",
       				"confidence": 1.0,
       				"rangeStart": 39,
       				"rangeEnd": 40,
       				"time": null
       				"value": "uhr",
       				"confidence": 1.0,
       				"rangeStart": 41,
       				"rangeEnd": 44,
       				"time": null
       				"value": "10",
       				"confidence": 1.0,
       				"rangeStart": 45,
       				"rangeEnd": 47,
       				"time": null
       		"asrConfidence": null,
       		"rawInput": "stelle mir einen Wecker für Montag auf 6 Uhr 10",
       		"wakewordId": null,
       		"lang": null
    Jetzt habe ich es schon mal so weit hinbekommen, dass ich die Stunde im Datenpunkt angezeigt bekomme.
     <variables>
       <variable id="|A(#s1Q|dT6w7z+zQyHz">value</variable>
       <variable id="OP[n8/:%8L#3S*:zFXMV">Tag</variable>
       <variable id="T!V%u*?{Lo@u?5]B+)H$">Zahl</variable>
     </variables>
     <block type="variables_set" id="e{I*$T]o}hp8Q8}L+#{f" x="213" y="113">
       <field name="VAR" id="|A(#s1Q|dT6w7z+zQyHz">value</field>
       <value name="VALUE">
         <block type="math_number" id="DL+[[L|{=(4u](q7eF.o">
           <field name="NUM">0</field>
         </block>
       </value>
       <next>
         <block type="on" id="iLJj3nj3c/!TmdW8Yh$f">
           <field name="OID">mqtt.0.hermes.intent.SetAlarm</field>
           <statement name="STATEMENT">
             <block type="variables_set" id="2Pk.06df8uC29xlRePa*">
               <field name="VAR" id="OP[n8/:%8L#3S*:zFXMV">Tag</field>
                 <block type="text_indexOf" id="8+qMs?x;=:Fpi;q~+VMa">
                   <field name="END">FIRST</field>
                     <block type="get_value" id="dc!siC#~|0eWHgt4QXqr">
                     </block>
                   </value>
                   <value name="FIND">
                     <shadow type="text" id="TlK#%NYO+FjqZlfL:HJx">
                       <field name="TEXT">Tag</field>
                     </shadow>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id="pGY[b~[G:)cfBCrc91=U">
                     <block type="text_indexOf" id="q9ki9#CsxV/{_4TMZasW">
                         <block type="get_value" id="$~2Y|lp;Z;[ECrGJC%@-">
                         </block>
                       </value>
                       <value name="FIND">
                         <shadow type="text" id=":yfmC+l}Y[Z4v+$t_wOc">
                           <field name="TEXT">"Number", "value": </field>
                         </shadow>
                       </value>
                     </block>
                   </value>
                   <next>
                     <block type="variables_set" id="Q.|`xbPB9Kc/4)3tii:,">
                       <field name="VAR" id="T!V%u*?{Lo@u?5]B+)H$">Zahl</field>
                         <block type="text_getSubstring" id="goWC9Y]:eah~9zv(DW/t">
                           <mutation at1="true" at2="true"></mutation>
                           <field name="WHERE1">FROM_START</field>
                           <field name="WHERE2">FROM_START</field>
                           <value name="STRING">
                             <block type="get_value" id="vAmx4X^mtrf|=x8N4N*k">
                             </block>
                           </value>
                           <value name="AT1">
                             <block type="math_arithmetic" id="8SkLCGA1aZ:WeznQlVfR">
                               <field name="OP">ADD</field>
                               <value name="A">
                                 <shadow type="math_number" id="gmY92N!JXY,+!_^O/6s_">
                                   <field name="NUM">1</field>
                                 </shadow>
                                 <block type="variables_get" id="I(_okp%snZFDZ{RpU5^c">
                                 </block>
                               </value>
                               <value name="B">
                                 <shadow type="math_number" id="i`$j`5XKn6s~*sq|tvgP">
                                   <field name="NUM">18</field>
                                 </shadow>
                               </value>
                             </block>
                           </value>
                           <value name="AT2">
                             <block type="math_arithmetic" id="_s+dNi*+FuD+/2rp3^oq">
                               <value name="A">
                                 <shadow type="math_number" id=")43cmDFXu^?4F*AN~+rD">
                                 </shadow>
                                 <block type="variables_get" id="k#tgw*/aI.jc+*`7n+vv">
                                 </block>
                               </value>
                               <value name="B">
                                 <shadow type="math_number" id="fvDbF#_Y$vk*Sm/;hV%f">
                                   <field name="NUM">21</field>
                                 </shadow>
                               </value>
                             </block>
                           </value>
                         </block>
                       </value>
                       <next>
                         <block type="variables_set" id="DYC-tC_HX!sfPbf}bIo#">
                             <block type="convert_tonumber" id="WNXgm]`S(C=E_-`Oc;yz">
                                 <block type="variables_get" id=".8PZm%eiejMn=Nfew=KJ">
                                 </block>
                               </value>
                             </block>
                           </value>
                           <next>
                             <block type="controls_if" id="4PtA40X1C(NhBM}s_7p4">
                               <value name="IF0">
                                 <block type="logic_compare" id="D}5KH:mC%)Zcbh3mf-Fr">
                                   <field name="OP">GT</field>
                                   <value name="A">
                                     <block type="convert_tonumber" id="!nbou9Iq@I^*#33L/M[[">
                                         <block type="variables_get" id="N*B1XtEy++Lm!5XI8N7i">
                                         </block>
                                       </value>
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="#d[P5e$#w!_|x%nXdi9#">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <statement name="DO0">
                                 <block type="control" id="86iHv3LXsiT1xbiKCp}f">
                                   <field name="OID">0_userdata.0.Datenpunkte.Rhasspy.Wecker.Stunde</field>
                                     <block type="variables_get" id="tAqiD9nM/kiPv@BrlrDz">
                                     </block>
                                   </value>
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
     <block type="logic_boolean" id="VJ@nv6*~Q;W,@*6MXJ0b" x="-762" y="238">
     </block>
    </xml>
    Meine Frage wäre aber nun, wie ich aus dem "im Text XXX suche erstes...." zu "im Text XXX suche zweites..." machen kann?
    Würde mir bitte jemand helfen?
    F 1 Antwort Letzte Antwort
    • J jwerlsdf
      "intent": {
         		"id": "f19",
         		"slots":
         				"slotName": "Tag",
         				"confidence": 1.0,
         				"confidence": 1.0,
         				"rawValue": "zehn",
         				"confidence": 1.0,
         		"customData": null,
         		"asrTokens": [
         				"value": "stelle",
         				"confidence": 1.0,
         				"rangeStart": 0,
         				"rangeEnd": 6,
         				"time": null
         				"value": "mir",
         				"confidence": 1.0,
         				"rangeStart": 7,
         				"rangeEnd": 10,
         				"time": null
         				"value": "einen",
         				"confidence": 1.0,
         				"rangeStart": 11,
         				"rangeEnd": 16,
         				"time": null
         				"value": "wecker",
         				"confidence": 1.0,
         				"rangeStart": 17,
         				"rangeEnd": 23,
         				"time": null
         				"value": "für",
         				"confidence": 1.0,
         				"rangeStart": 24,
         				"rangeEnd": 27,
         				"time": null
         				"value": "Montag",
         				"confidence": 1.0,
         				"rangeStart": 28,
         				"rangeEnd": 34,
         				"time": null
         				"value": "auf",
         				"confidence": 1.0,
         				"rangeStart": 35,
         				"rangeEnd": 38,
         				"time": null
         				"value": "6",
         				"confidence": 1.0,
         				"rangeStart": 39,
         				"rangeEnd": 40,
         				"time": null
         				"value": "uhr",
         				"confidence": 1.0,
         				"rangeStart": 41,
         				"rangeEnd": 44,
         				"time": null
         				"value": "10",
         				"confidence": 1.0,
         				"rangeStart": 45,
         				"rangeEnd": 47,
         				"time": null
         		"wakewordId": null,
         		"lang": null
       <variables>
       </variables>
           </block>
         </value>
         <next>
                       </block>
                     </value>
                     <value name="FIND">
                       </shadow>
                     </value>
                   </block>
                 </value>
                 <next>
                           </block>
                         </value>
                         <value name="FIND">
                           </shadow>
                         </value>
                       </block>
                     </value>
                     <next>
                               </block>
                             </value>
                             <value name="AT1">
                                 <value name="A">
                                   </shadow>
                                   </block>
                                 </value>
                                 <value name="B">
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                             <value name="AT2">
                                 <value name="A">
                                   </shadow>
                                   </block>
                                 </value>
                                 <value name="B">
                                   </shadow>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                         <next>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <next>
                                 <value name="IF0">
                                     <value name="A">
                                           </block>
                                         </value>
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                       </block>
                                     </value>
                                   </block>
                                 </statement>
                               </block>
                             </next>
                           </block>
                         </next>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </statement>
           </block>
         </next>
       </block>
       </block>
      </xml>
      F Online
      F Online
      fastfoot
      @jwerlsdf das json kannst du so auswerten
      • F fastfoot
        jwerlsdf
        schrieb am zuletzt editiert von jwerlsdf
        @fastfoot
        vielen Dank mit Attribut ging es :)
