  4. Javascript Adapter Update auf v5.2.11 schlägt fehl
adapter update fehlerjavascript adapter
5 Beiträge 3 Kommentatoren 680 Aufrufe 4 Beobachtet
  • BBTownB Offline
    BBTownB Offline
    BBTown
    Bei mir schlägt das Update des Javascript Adapter von v5.2.10 auf v5.2.11 fehl und im Log habe ich interessante Fehlermeldungen
    javascript.0
    2021-09-12 00:03:41.982	error	axios-cookiejar-support@1.0.1 requires a peer of @types/tough-cookie@>=2.3.3 but none is installed. You must install peer dependencies yourself.
    javascript.0
    2021-09-12 00:03:39.548	error	deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    javascript.0
    2021-09-12 00:03:37.230	error	deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    javascript.0
    2021-09-12 00:03:37.124	error	deprecated har-validator@5.1.5: this library is no longer supported
    2021-09-12 00:03:36.884	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    javascript.0
    2021-09-12 00:03:35.174	error	WARN axios-cookiejar-support@1.0.1 requires a peer of @types/tough-cookie@>=2.3.3 but none is installed. You must install peer dependencies yourself.
    javascript.0
    2021-09-12 00:03:32.003	error	WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    Bin ich damit alleine? 😎
    Ehrlich gesagt habe ich noch keine Idee was ich im einzelnen unternehmen sollte 🙃
    • BBTownB BBTown
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      @bbtown Nein, bist nicht alleine. Gibt ein Issue dazu.
      Wobei die Fehlermeldungen da andere bzw. nicht vorhanden sind
      sissiwupS 1 Antwort Letzte Antwort
        sissiwupS Offline
        sissiwupS Offline
        sissiwup
        bei mir sagt er immer "updated" nur die Version ist nicht neu ...
        MfG
        Sissi
        1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
        BBTownB Thomas BraunT 2 Antworten Letzte Antwort
        • sissiwupS sissiwup
          BBTownB Offline
          BBTownB Offline
          BBTown
          @sissiwup es gibt eine neue Version (zumindest bereits auf github)
            @sissiwup
            5.2.12 kommt wohl diese Nacht rüber. Einfach abwarten.
