  4. Yahka schaltet nicht
    6.5k
12 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
    @robse
    Log file sagt?
    robse
    im iobroker log steht nix vom yahka Adapter im Debug modus
    • R robse
      @robse Trotzdem posten.
      Adapter Neustart, Ausgaben posten
      R 1 Antwort Letzte Antwort
        robse
        • R robse
          @robse
          Keine Screenshots, Auszüge aus dem Log file in CodeTags hier rein posten.
            @robse
            robse
            2021-09-06 21:58:10.589  - info: host.a4ddf15dc862 stopInstance system.adapter.yahka.0 (force=false, process=true)
            2021-09-06 21:58:10.591  - info: host.a4ddf15dc862 stopInstance system.adapter.yahka.0 send kill signal
            2021-09-06 21:58:10.591  - info: yahka.0 (12662) Got terminate signal TERMINATE_YOURSELF
            2021-09-06 21:58:10.592  - info: yahka.0 (12662) cleaning up ...
            2021-09-06 21:58:10.592  - info: yahka.0 (12662) cleaned up ...
            2021-09-06 21:58:10.592  - info: yahka.0 (12662) terminating
            2021-09-06 21:58:10.592  - info: yahka.0 (12662) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-09-06 21:58:11.112  - info: host.a4ddf15dc862 instance system.adapter.yahka.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-09-06 21:58:11.113  - info: node-red.0 (24781) State value to set for "0_userdata.0.Heizung_Leistung" has to be type "string" but received type "number"
            2021-09-06 21:58:11.114  - info: node-red.0 (24781) State value to set for "0_userdata.0.Heizung_Quelltemperatur_Eingang" has to be type "string" but received type "number"
            2021-09-06 21:58:11.114  - info: node-red.0 (24781) State value to set for "0_userdata.0.Heizung_Quelltemperatur_Ausgang" has to be type "string" but received type "number"
            2021-09-06 21:58:13.604  - info: host.a4ddf15dc862 instance system.adapter.yahka.0 started with pid 12779
            2021-09-06 21:58:14.206  - info: yahka.0 (12779) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.yahka, node: v12.22.5, js-controller: 3.3.15
            2021-09-06 21:58:14.215  - info: yahka.0 (12779) adapter ready, checking config
            2021-09-06 21:58:14.218  - info: yahka.0 (12779) adding Test Gerät with UUID: a95a1b70-1d0a-49ad-b5eb-2b392fb86145
            2021-09-06 21:58:14.221  - info: yahka.0 (12779) adding Büro Licht with UUID: 68404733-0ee7-4d39-8189-b8a42e2bb7ec
            2021-09-06 21:58:14.221  - info: yahka.0 (12779) adding Heizung Bad with UUID: d49eeda6-88b7-447b-b247-a344b4a47128
            2021-09-06 21:58:14.222  - info: yahka.0 (12779) adding Wohnzimmer Decke with UUID: 3e9c26a7-45f9-4d35-b2df-fdbb20358ed2
            2021-09-06 21:58:14.222  - info: yahka.0 (12779) adding Bodenlampe with UUID: cdfee335-ada1-4f9d-9805-e93cc3bb1340
            2021-09-06 21:58:14.222  - info: yahka.0 (12779) adding Stehlampe with UUID: 09378103-6ba9-4771-9dcf-95ff50333f98
            2021-09-06 21:58:14.223  - info: yahka.0 (12779) adding Test 2 with UUID: 0f0a1774-efa5-4e16-aead-c60c87cd8ebd
            2021-09-06 21:58:14.223  - info: yahka.0 (12779) publishing bridge HomeKit-iobroker on 0.0.0.0
            • R robse
              @robse
              Spielt da node-red noch mit rein?
              R 2 Antworten Letzte Antwort
                @robse
                robse
                Nein, das sind nur Log Einträge aus node-red, die zwischen, beenden und starten des Yahka Adapters kamen.
                • R robse
                  robse
                  schrieb am zuletzt editiert von robse
                  hat noch jemand eine Idee? Ich habe bereits eine neue iobroker Instanz aufgesetzt. Auch dort funktioniert yahka nicht :(
                    @robse
                    robse
                    @thomas-braun hast du noch irgendeinen Tip für mich?
                    • R robse
                      @robse
                      Von yahka hab ich keine Ahnung.
