  4. [gelöst] Update HS100 funktioniert nicht.
    2.0k
hs100 adapterupdate adapter
4 Beiträge 2 Kommentatoren 181 Aufrufe 2 Beobachtet
  • GregorSG Offline
    GregorSG Offline
    GregorS
    schrieb am zuletzt editiert von GregorS
    das Update des hs100-Adapters funktioniert nicht.
    Hier der Log:
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.hs100@2.0.6',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.12
    3 info using node@v12.22.1
    4 verbose npm-session cfeb51e0eb8e7abd
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 304 https://registry.npmjs.org/iobroker.hs100 432ms (from cache)
    8 silly registry:manifest no matching version for iobroker.hs100@2.0.6 in the cache. Forcing revalidation.
    9 http fetch GET 200 https://registry.npmjs.org/iobroker.hs100 141ms
    10 silly fetchPackageMetaData error for iobroker.hs100@2.0.6 No matching version found for iobroker.hs100@2.0.6.
    11 timing stage:rollbackFailedOptional Completed in 5ms
    12 timing stage:runTopLevelLifecycles Completed in 13744ms
    13 verbose type version
    14 verbose stack iobroker.hs100: No matching version found for iobroker.hs100@2.0.6.
    14 verbose stack     at pickManifest (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
    14 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:43:18
    14 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    14 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
    14 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
    14 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
    14 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
    14 verbose stack     at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
    14 verbose stack     at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
    14 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
    14 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
    14 verbose stack     at processImmediate (internal/timers.js:461:21)
    15 verbose cwd /opt/iobroker
    16 verbose Linux 4.19.57-rockchip
    17 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.hs100@2.0.6" "--loglevel" "error" "--prefix" "/opt/iobroker"
    18 verbose node v12.22.1
    19 verbose npm  v6.14.12
    20 error code ETARGET
    21 error notarget No matching version found for iobroker.hs100@2.0.6.
    22 error notarget In most cases you or one of your dependencies are requesting
    22 error notarget a package version that doesn't exist.
    23 verbose exit [ 1, true ]
    Danke !!!
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      Hier der Log:
      1 verbose cli ]
      Danke !!!
      @gregors
      Ich glaube da ist beim einchecken was komisch gelaufen.
      github:	2.0.6
      latest:	2.0.5 for 32 days
      stable:	2.0.6
      Das ist imho ungewöhnlich, dass die stable aktueller als die Beta ist. Muss vielleicht @arteck mal reinschauen.
      GregorSG 1 Antwort Letzte Antwort
        @gregors
        github:	2.0.6
        stable:	2.0.6
        GregorSG Offline
        GregorSG Offline
        GregorS
        Habe es heute nochmals probiert.
        Jetzt ist der Adapter up-to-date.
        Selbstheilung ?
        • GregorSG GregorS
          Selbstheilung ?
          @gregors
          Da ist mit Sicherheit der Adapter nochmal 'ordentlich' im Repo eingecheckt worden.
