  4. ioBroker nicht mehr erreichbar
    6.7k
28 Beiträge 2 Kommentatoren 3.7k Aufrufe 2 Beobachtet
    @berti69
    So ähnlich...
    Installier es neu:
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    Berti69
    Versucht neu zu installieren
    permitted by applicable law.
    Last login: Tue Jul 13 23:02:51 2021 from 192.168.75.20
    pi@iobroker:~ $ cd /opt/iobroker
    pi@iobroker:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controll                                      er
    npm ERR! code EJSONPARSE
    npm ERR! file /opt/iobroker/package.json
    npm ERR! JSON.parse Failed to parse json
    npm ERR! JSON.parse Unexpected token  in JSON at position 320 while parsing near                                       '...{
    npm ERR! JSON.parse     "colors": "^1.,
    npm ERR! JSON.parse     "fs-extra"...'
    npm ERR! JSON.parse Failed to parse package.json data.
    npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
    npm ERR!     /home/iobroker/.npm/_logs/2021-07-14T16_12_10_154Z-debug.log
    • B Berti69
      @berti69 sagte in ioBroker nicht mehr erreichbar:
      Hmmm. Sieht alles sehr krumm aus.
      dmesg -T | grep -i ext4
      liefert?
        liefert?
        Berti69
        @thomas-braun sagte in ioBroker nicht mehr erreichbar:
        pi@iobroker:~ $ dmesg -T | grep -i ext4
        [Mi Jul 14 18:07:15 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0                            snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=65                           6 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.                           mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=596b8f27-02                            rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Mi Jul 14 18:07:18 2021] EXT4-fs (mmcblk0p2): INFO: recovery required on readon                           ly filesystem
        [Mi Jul 14 18:07:18 2021] EXT4-fs (mmcblk0p2): write access will be enabled duri                           ng recovery
        [Mi Jul 14 18:07:19 2021] EXT4-fs (mmcblk0p2): recovery complete
        [Mi Jul 14 18:07:19 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered d                           ata mode. Opts: (null)
        [Mi Jul 14 18:07:19 2021] VFS: Mounted root (ext4 filesystem) readonly on device                            179:2.
        [Mi Jul 14 18:07:22 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        pi@iobroker:~ $
        Bin jetzt auf Firefox gewechselt und schon geht das mit dem Code.
        • B Berti69
          pi@iobroker:~ $
          @berti69
          iobroker stop
          sudo reboot
          Und wenn die Kiste wieder hochgekommen ist als erstes nochmal
            @berti69
            iobroker stop
            sudo reboot
            Berti69
            [Mi Jul 14 18:24:48 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_       hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  con       sole=ttyS0,115200 console=tty1 root=PARTUUID=596b8f27-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
            [Mi Jul 14 18:24:51 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [Mi Jul 14 18:24:51 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Mi Jul 14 18:24:55 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            pi@iobroker:~ $
            • B Berti69
              pi@iobroker:~ $
              @berti69 Dann nochmal versuchen zu installieren.
                Berti69
                Komplett neu installieren ?
                oder nur iobroker?
                • B Berti69
                  oder nur iobroker?
                  @berti69 Zunächst Mal nur den js-controller.
                  Siehe oben
                    Siehe oben
                    Berti69
                    das geht nicht. Gleiche Meldungen wie vorhin
                    pi@iobroker:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                    npm ERR!     /home/iobroker/.npm/_logs/2021-07-14T17_08_41_354Z-debug.log
                    • B Berti69
                      Die Datei ist wohl defekt. Keine Ahnung ob man die wiederherstellen kann.
                      Ich würde wohl jetzt ein Backup einspielen.
                        Berti69
                        kann das sein das ich ins falsche verzeichnis installiert habe ? Ein Backup habe ich gemacht.
                        pi@iobroker:/opt/iobroker $ npm install iobroker.js-controller
                        npm ERR!     /home/iobroker/.npm/_logs/2021-07-14T17_19_21_407Z-debug.log
                        pi@iobroker:/opt/iobroker $ cd
                        pi@iobroker:~ $ npm install iobroker.js-controller
                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                        > iobroker.js-controller@3.3.14 preinstall /home/pi/node_modules/iobroker.js-controller
                        > node lib/preinstallCheck.js
                        NPM version: 6.14.13
                        > unix-dgram@2.0.3 install /home/pi/node_modules/unix-dgram
                        > node-gyp rebuild
                        make: Verzeichnis â/home/pi/node_modules/unix-dgram/buildâ wird betreten
                          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                        In file included from ../../nan/nan.h:56,
                                         from ../src/unix_dgram.cc:5:
                        /home/pi/.cache/node-gyp/12.22.2/include/node/node.h:736:43: warning: cast between incompatible function types from âvoid (*)(v8::Local<v8::Object>)â to ânode::addon_register_funcâ {aka âvoid (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)â} [-Wcast-function-type]
                               (node::addon_register_func) (regfunc),                          \
                        /home/pi/.cache/node-gyp/12.22.2/include/node/node.h:770:3: note: in expansion of macro âNODE_MODULE_Xâ
                           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                        ../src/unix_dgram.cc:404:1: note: in expansion of macro âNODE_MODULEâ
                         NODE_MODULE(unix_dgram, Initialize)
                          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                          COPY Release/unix_dgram.node
                        make: Verzeichnis â/home/pi/node_modules/unix-dgram/buildâ wird verlassen
                        > ursa-optional@0.9.10 install /home/pi/node_modules/ursa-optional
                        > node rebuild.js
                        ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                        > diskusage@1.1.3 install /home/pi/node_modules/diskusage
                        > node-gyp rebuild
                        make: Verzeichnis â/home/pi/node_modules/diskusage/buildâ wird betreten
                          CXX(target) Release/obj.target/diskusage/src/main.o
                                         from ../src/main.cpp:3:
                        ../src/main.cpp:42:1: note: in expansion of macro âNODE_MODULEâ
                         NODE_MODULE(diskusage, Init)
                          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                          SOLINK_MODULE(target) Release/obj.target/diskusage.node
                          COPY Release/diskusage.node
                        make: Verzeichnis â/home/pi/node_modules/diskusage/buildâ wird verlassen
                        > iobroker.js-controller@3.3.14 install /home/pi/node_modules/iobroker.js-controller
                        > node iobroker.js setup first
                        creating conf/iobroker.json
                        Server Cannot load /home/pi/iobroker-data/objects.json: Database file /home/pi/iobroker-data/objects.json does not exists.. We try last Backup!
                        Server Cannot load /home/pi/iobroker-data/states.json: Database file /home/pi/iobroker-data/states.json does not exists.. We try last Backup!
                        Server Cannot load /home/pi/iobroker-data/objects.json.bak: Database file /home/pi/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
                        Server If this is no Migration or initial start please restore the last backup from /home/pi/iobroker-data/backup-objects
                        Server Cannot load /home/pi/iobroker-data/states.json.bak: Database file /home/pi/iobroker-data/states.json.bak does not exists.. Continue with empty dataset!
                         Cannot read system.config: null (OK when migrating or restoring)
                        object 0_userdata.0.example_state created
                        object 0_userdata.0 created
                        object alias.0 created
                        object system.certificates created
                        object system.repositories created
                        object system.config created
                        object enum.functions created
                        object enum.rooms created
                        object system.group.user created
                        object system.group.administrator created
                        object _design/custom created
                        object _design/system created
                        object system.meta.uuid created: 88674e08-15f5-d7d6-3be0-6846412b9edd
                        object system.user.admin created
                        ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
                        ioBroker wants to make sure to deliver the most stable smart home system.
                        To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
                        THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
                        For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
                        If you want to disable the error reporting you can use the command
                        'iobroker plugin disable sentry'
                        This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
                          "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nh2iQgE8LNxYpQU04Xg2xIRbKSSnuqsVt5grrbhwGVcbnWqcr1wdpaVmv\r\n-----END RSA PRIVATE KEY-----\r\n",
                          "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nksJ+fG2myONLYlbJptbALPof4uuVAGYdVaN9woshaLLbBQ==\r\n-----END CERTIFICATE-----\r\n"
                        The object "system.certificates" was updated successfully.
                        > @root/acme@3.1.0 postinstall /home/pi/node_modules/@root/acme
                        > node scripts/postinstall
                        > esbuild@0.11.23 postinstall /home/pi/node_modules/esbuild
                        > node install.js
                        npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                        npm WARN pi No description
                        npm WARN pi No repository field.
                        npm WARN pi No README data
                        npm WARN pi No license field.
                        + iobroker.js-controller@3.3.14
                        added 298 packages from 282 contributors and audited 306 packages in 145.393s
                        11 packages are looking for funding
                          run `npm fund` for details
                        found 1 high severity vulnerability
                          run `npm audit fix` to fix them, or `npm audit` for details
                        • B Berti69
                          > node-gyp rebuild
                          > node rebuild.js
                          > node-gyp rebuild
                          > node install.js
                          @berti69
                          Im zweiten Versuch, ja. Die Installation macht man nicht im Home des Users.
                            @berti69
                            Berti69
                            wie bekomme ich das gelöscht bzw wie spiele ich das Backup ein das im Ordner backups liegt ?
                            • B Berti69
                              @berti69 Kannst du einfach löschen.
                              rm -r datei-verzeichnisname
                                Berti69
                                wie geht das Backup einspielen ?
                                Wenn das nicht geht mach ich alles neu.
                                • B Berti69
                                  @berti69 Wie angelegt?
                                  Mit dem Backitup-Adapter?
                                    Berti69
                                    Über die Konsole bzw Putty
                                    • B Berti69
                                      @berti69 Da weiß ich den Befehl nicht. Musst du mal in der Dokumentation nachschauen.
                                        Berti69
                                        Ok
                                        • B Berti69
                                          Ok
                                          Berti69
                                          Mein iobroker läuft wieder. Habe mich durch die Doku gearbeitet.
                                          Das was jetzt noch fehlt sind Adapter zum instalieren. Ich meine Neue
