  4. Admin funktioniert seit update auf 5.1.10 nicht mehr
    6.7k
60 Beiträge 6 Kommentatoren 3.0k Aufrufe 6 Beobachtet
  • M myssv
    Mit npm@6 bekomme ich neue Meldungen:
    root@iobroker:/opt/iobroker# iobroker upgrade
    This upgrade of "admin" will introduce the following changes:
    -> 5.1.10:
    Corrected some GUI errors
    Would you like to upgrade admin from @5.1.9 to @5.1.10 now? [(y)es, (n)o]: y
    Update admin from @5.1.9 to @5.1.10
    NPM version: 6.14.13
    npm install iobroker.admin@5.1.10 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code EINTEGRITY
    npm ERR! Verification failed while extracting iobroker.openligadb@https://github.com/oweitman/ioBroker.openligadb/tarball/master:
    npm ERR! sha512-pB22Fvp08/amIRWYLQfhozpKkRAiM2LUDrNZrEnHDhERBwidYFYWOFFJ80N54pVh9yz6Y3gbJ3VWK4/VmPl77A== integrity checksum failed when using sha512: wanted sha512-pB22Fvp08/amIRWYLQfhozpKkRAiM2LUDrNZrEnHDhERBwidYFYWOFFJ80N54pVh9yz6Y3gbJ3VWK4/VmPl77A== but got sha512-WLFcOaoHfNIu5uGyi6Q/iQ/UB+ITNjsAYShVYAUsWoefc/3RrqZzWl7odAxoQaRDmnkYP9+/s2/sE2mrAJPakQ==. (252178 bytes)
    npm ERR!     /opt/iobroker/.npm/_logs/2021-07-10T08_49_51_606Z-debug.log
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    Adapter "admin" updated
    Node ist: Node.js v14.17.3 (Empfohlene Version v12.22.3)
    @myssv
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    liefert?
      @myssv
      liefert?
      myssv
      root@iobroker:/opt/iobroker# which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v12.22.1
      v14.17.3
      6.14.13
      Holen:1 http://security.debian.org/debian-security buster/updates InRelease [65,4 kB]
      Holen:2 http://deb.debian.org/debian buster InRelease [122 kB]
      Holen:3 http://deb.debian.org/debian buster-updates InRelease [51,9 kB]
      Holen:4 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
      Holen:5 http://security.debian.org/debian-security buster/updates/main amd64 Packages [293 kB]
      Holen:6 http://deb.debian.org/debian buster/main amd64 Packages [7.907 kB]
      Holen:7 https://deb.nodesource.com/node_12.x buster/main amd64 Packages [766 B]
      Holen:8 http://deb.debian.org/debian buster-updates/main amd64 Packages [15,2 kB]
      Es wurden 8.459 kB in 8 s geholt (1.002 kB/s).
      Aktualisierung für 29 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      OK:1 http://security.debian.org/debian-security buster/updates InRelease
      OK:2 http://deb.debian.org/debian buster InRelease
      OK:3 http://deb.debian.org/debian buster-updates InRelease
      OK:4 https://deb.nodesource.com/node_12.x buster InRelease
      nodejs:
        Installiert:           12.22.1-1nodesource1
        Installationskandidat: 12.22.2-1nodesource1
        Versionstabelle:
           12.22.2-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
       *** 12.22.1-1nodesource1 100
           10.24.0~dfsg-1~deb10u1 500
              500 http://deb.debian.org/debian buster/main amd64 Packages
              500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
      • M myssv
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v12.22.1
        v14.17.3
        6.14.13
        nodejs:
          Versionstabelle:
        @myssv
        NodeJS ist ja auch krumm installiert.
        M J 2 Antworten Letzte Antwort
          @myssv
          myssv
          @thomas-braun sagte in Admin funktioniert seit update auf 5.1.10 nicht mehr:
          @myssv
          Sorry, bin nicht der Fachmann auf dem Gebiet und mache alles nach bestem Wissen und Gewissen ...
          • M myssv
            @myssv
            @myssv Schau in meiner Signatur wie man das richtig über apt installiert.
              @myssv
              Jan1
              @myssv
              genau das war meine Vermutung, deshalb der Hinweis, dass es eigentlich laufen sollte wenn der Rest auch passt ;)
              Manuell dran gefummelt und sich alles verbogen.
                myssv
                @thomas-braun woran erkenne ich, welches Linux bei mir im Docker läuft?
                • J Jan1
                  @myssv
                  myssv
                  @jan1 sagte in Admin funktioniert seit update auf 5.1.10 nicht mehr:
                  @myssv
                  Wahrscheinlich ....
                  • M myssv
                    @myssv Debian Buster auf einem 64bit-Prozessor.
                      myssv
                      @thomas-braun Danke
                      Dann will ich mal versuchen es zu verschlimmbessern ...
                      • M myssv
                        @thomas-braun Danke
                        Jan1
                        @myssv
                        Am einfachsten ist es die Node Installationen (Du hast zwei davon drauf) zu deinstallieren und dann Node 12 oder 14 zu installieren. So wird NPM gleich passen mit installiert. Wichtig ist aber dass bevor Du Node neu installiert, darf der Befehl von oben nichts mehr finden.
                        So in die Richtung steht es aber auch in der Anleitung von Thomas und daran solltest Du Dich unbedingt halten ;)
                        Ob das im Docker auch so geht, kein Plan.
                        • J Jan1
                          @myssv
                          myssv
                          @myssv
                          Wie mache ich das?
                          • M myssv
                            @myssv
                            Wie mache ich das?
                            @myssv Anleitung lesen, umsetzen, fertig.
                              myssv
                              root@iobroker:/opt/iobroker# sudo apt remove node*
                              E: Paket node_modules kann nicht gefunden werden.
                              Ich habe scheinbar schon einiges kaputt gemacht ...
                              • M myssv
                                Jan1
                                @myssv
                                Jetzt wirst gleich gesteinigt ;)
                                • J Jan1
                                  @myssv
                                  myssv
                                  @myssv
                                  Das befürchte ich auch schon, aber ich stehe aktuell echt total auf dem Schlauch ....
                                  Habe von Linux 0 Ahnung, wobei man das sicher schon an den Kommentaren gemerkt hat. Bin halt eher der Mausschubser ...
                                  J Thomas BraunT 2 Antworten Letzte Antwort
                                  • M myssv
                                    @myssv
                                    Jan1
                                    @myssv
                                    root User, ok habe da was gelesen dass das im Docker nötig wäre (oder auch nicht), aber sudo beim root User ist wirklich ein Beweis, dass Du Linux nicht verstanden hast.
                                    So jetzt bitte zur Steinigung :)
                                    • M myssv
                                      @myssv
                                      @myssv Als root wird nicht per sudo gearbeitet.
                                      Bist ja schon root.
                                        Bist ja schon root.
                                        myssv
                                        Bist ja schon root.
                                        Ich habe den Befehl so aus Deiner Anleitung genommen ... und ja, ich habe davon keine Ahnung
                                        Auch ohne sudo bekomme ich den Fehler.
                                        root@iobroker:/opt/iobroker# apt remove node*
                                        • M myssv
                                          Bist ja schon root.
                                          @myssv Dann weiter in der Anleitung.
