  4. Spritpreise der letzten 3 Tage abfragen, ist das möglich?
    5.6k
14 Beiträge 6 Kommentatoren 1.7k Aufrufe
  • P Offline
    pix
    das geht mit dem javascript-Adapter, der auf die Daten des SQL-Adapters zugreift.
    Allerdings kann ich das nicht.
    Schau dir mal die Github-Doku des Adapters und im Speziellen die GetHistory()-Funktion an: https://github.com/ioBroker/ioBroker.sql#get-history
    Du solltest eine immer gleiche Uhrzeit/Tageszeit für das Berechnen des Mittelwertes und das Senden der Email festlegen, da der Spritpreis über den Tank stark schwankt.
    Pix
      moebius
      hier der flow:````
      [{"id":"8b98c55f.5f46e8","type":"tab","label":"MinMax Message"},{"id":"e3446696.958f58","type":"mysql","z":"8b98c55f.5f46e8","mydb":"ddaa010d.680b2","name":"","x":753,"y":288,"wires":[["15ab98e3.c37b47"]]},{"id":"ea8aba6f.a32d98","type":"function","z":"8b98c55f.5f46e8","name":"prepare sql","func":"var hours = 72; //Zeitraum in Stunden\n\n/*jshint multistr: true */\nmsg.topic = 'SELECT min(val) As Min \\n,max(val) as Max \\n,avg(val) as Avg \\n,"' + msg.topic + '" as point \\n,"' + msg.payload + '" as val \\nFROM ts_number WHERE \\nfrom_unixtime(ts/1000) >= (CURRENT_DATE - INTERVAL '+ hours +' HOUR) \\nAND id=(SELECT id FROM datapoints WHERE name = \'' + msg.topic + '\') \\nGROUP BY id having Min >= ' + msg.payload + ';';\nreturn msg;","outputs":"1","noerr":0,"x":619,"y":228,"wires":[["e3446696.958f58"]]},{"id":"c08a285e.ddf918","type":"change","z":"8b98c55f.5f46e8","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Neuer Spritpreis","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1040,"y":376,"wires":[["10c5376a.f3f949"]]},{"id":"15ab98e3.c37b47","type":"split","z":"8b98c55f.5f46e8","name":"","splt":"\n","x":885,"y":334,"wires":[["c08a285e.ddf918"]]},{"id":"747d7406.39bc6c","type":"ioBroker in","z":"8b98c55f.5f46e8","name":"","topic":"admin.0.ws333.Temp3","payloadType":"value","onlyack":"","func":"all","gap":"","x":112,"y":74,"wires":[["11dc0cc1.51cc43"]]},{"id":"b601827a.7a01b","type":"change","z":"8b98c55f.5f46e8","name":"correct datapoint","rules":[{"t":"change","p":"topic","pt":"msg","from":"/","fromt":"str","to":".","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":445,"y":183,"wires":[["ea8aba6f.a32d98"]]},{"id":"10c5376a.f3f949","type":"template","z":"8b98c55f.5f46e8","name":"prepare message","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Aktueller Spritpreis {{payload.val}} - Kleinster Preis war {{payload.Min}}, Durchschnitt {{payload.Avg}}, Maximum {{payload.Max}}!","x":1218,"y":426,"wires":[["644a66c.8672a98"]]},{"id":"11dc0cc1.51cc43","type":"switch","z":"8b98c55f.5f46e8","name":"no 0 values","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"0","vt":"num"}],"checkall":"true","outputs":1,"x":289,"y":128,"wires":[["b601827a.7a01b"]]},{"id":"644a66c.8672a98","type":"e-mail","z":"8b98c55f.5f46e8","server":"smtp.gmail.com","port":"465","name":"","dname":"","x":1362,"y":477,"wires":[]},{"id":"ddaa010d.680b2","type":"MySQLdatabase","z":"","host":"big","port":"3306","db":"iobroker","tz":""}]
      du musst nur mehr den Datenpunkt mit dem Spritpreis ändern, und Datenbank und email konfigurieren.
      Edith: Preis 0 gefiltert
      • J Offline
        jensus11
        Wo fügt man diese Zeile ein?
          moebius
          node-red adapter installieren -> zeile kopieren -> bei node-red im menü auf importieren clipboard
            simpixo
            @moebius:
            node-red adapter installieren -> zeile kopieren -> bei node-red im menü auf importieren clipboard `
            Hallo Moebius
            also ich habe den Flow importiert und alles soweit angepasst aber ich erhalte eine unvollständige
            Email geschickt
            > "Aktueller Spritpreis ****0**** - Kleinster Preis war ****0****, Durchschnitt 0.7369115128449051, Maximum 1.259!"
            Warum sind diese Angaben leer. Habe ich was falsch gemacht?
            Adrian
              moebius
              @simpixio: wenn der aktuelle Preis 0 ist, dürfte was mit dem ioBroker input nicht stimmen. Die payload sollte den Spritpreis enthalten und nicht 0.
                Wenn die Tanke zu ist kommt 0!
                Außerdem habe ich auch im Adapter immer wieder 0 wenn der Wertsich nicht ändert.
                Da stimmt IMHO etwas bei der Auswertung der Antwort vom Tankerkönig nicht.
                  moebius
                  ok, falls 0 kommen kann, einfach mit einem switch node ausfiltern.
                  Werde den ursprünglichen Flow aktualisieren.
                    simpixo
                    @moebius:
                    @simpixio: wenn der aktuelle Preis 0 ist, dürfte was mit dem ioBroker input nicht stimmen. Die payload sollte den Spritpreis enthalten und nicht 0. `
                    ich glaube da ist bei mir noch was verkehrt…. kann es sein das ich was falsch gemacht habe? Hier mein FLOW, vielleicht findest du da ein Fehler :lol:
                    [{"id":"ad56718f.b42d68","type":"tab","label":"Flow 1"},{"id":"5bcd3a47.668764","type":"mysql","z":"ad56718f.b42d68","mydb":"2f6a4409.a618fc","name":"","x":583,"y":159,"wires":[["5d6b53ac.be0404"]]},{"id":"2ebf397b.f25ef6","type":"function","z":"ad56718f.b42d68","name":"prepare sql","func":"var hours = 6; //Zeitraum in Stunden\n\n/*jshint multistr: true*/\nmsg.topic = 'SELECT min(val) As Min \\\n,max(val) as Max \\\n,avg(val) as Avg \\\n,\"' + msg.topic + '\" as point \\\n,\"' + msg.payload + '\" as val \\\nFROM ts_number WHERE \\\nfrom_unixtime(ts/1000) >= (CURRENT_DATE - INTERVAL '+ hours +' HOUR) \\\nAND id=(SELECT id FROM datapoints WHERE name = \\'' + msg.topic + '\\') \\\nGROUP BY id having Min >= ' + msg.payload + ';';\nreturn msg;","outputs":"1","noerr":0,"x":452,"y":116,"wires":[["5bcd3a47.668764"]]},{"id":"d4afff98.2d0d8","type":"change","z":"ad56718f.b42d68","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"Neuer Spritpreis","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":825,"y":249,"wires":[["174b63f0.a9b514"]]},{"id":"5d6b53ac.be0404","type":"split","z":"ad56718f.b42d68","name":"","splt":"\\n","x":690,"y":206,"wires":[["d4afff98.2d0d8"]]},{"id":"1e617ee.2d86801","type":"ioBroker in","z":"ad56718f.b42d68","name":"diesel feed","topic":"tankerkoenig.0.stations.0.diesel.feed","payloadType":"value","onlyack":"","func":"all","gap":"","x":72,"y":74,"wires":[["103a19a2.54bc4e"]]},{"id":"103a19a2.54bc4e","type":"change","z":"ad56718f.b42d68","name":"correct datapoint","rules":[{"t":"change","p":"topic","pt":"msg","from":"/","fromt":"str","to":".","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":277,"y":77,"wires":[["2ebf397b.f25ef6"]]},{"id":"174b63f0.a9b514","type":"template","z":"ad56718f.b42d68","name":"prepare message","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Aktueller Spritpreis {{payload.val}} - Kleinster Preis war {{payload.Min}}, Durchschnitt {{payload.Avg}}, Maximum {{payload.Max}}!","x":992,"y":291,"wires":[["d735865c.ac126","a93b28a.dc00fd8"]]},{"id":"d735865c.ac126","type":"e-mail","z":"ad56718f.b42d68","server":"smtp.gmail.com","port":"465","name":"xxxx@gmail.com","dname":"","x":1010,"y":459,"wires":[]},{"id":"a93b28a.dc00fd8","type":"debug","z":"ad56718f.b42d68","name":"","active":true,"console":"false","complete":"false","x":1140.5,"y":190,"wires":[]},{"id":"2f6a4409.a618fc","type":"MySQLdatabase","z":"","host":"192.168.160.21","port":"3306","db":"iobroker","tz":""}]
                    hab nur persönliche Angaben entfernt!!!
                    Gruss
                    Adrian
                      moebius
                      @simpixio: du hast nichts falsch gemacht. Mein Beispiel hat nur nicht berücksichtigt, daß der Preis auch 0 sein kann.
                      Habe das Beispiel schon erweitert, oder du fügst selber einfach einen switch Knoten nach dem Input hinzu, der nur plausible Werte durchlässt.
                        buzii12
                        Wow, ein kompletter Flow, das habe ich nicht erwartet, DANKE moebius und pix. Ich kämpfe schon seit Tagen damit rum, habe es auch zum laufen gebracht aber nicht so elegant wie bei moebius.
                        Ich habe versucht den Flow zu importieren, bei mit kommt eine Fehlermeldung, dass der SQL Typ nicht erkannt wurde und im Flow habe ich ein Roten Node da steht "unknown: mySQL", hast du eine Idee wie ich das zu laufen bekommen?
                        LG
                          moebius
                          @buzii12: kein Problem, helf gerne weiter. Finde Node-red wird unterschätzt - so schnelle und elegante Lösungen schaffe ich mit scripts nicht…und ich bin auch erst node-red Anfänger.
                          Den mysql Knoten kannst du so installieren: Node red menü -> "Manage palette" -> Reiter "Install" -> "mysql" eingeben -> "install" beim mysql node.
                            buzii12
                            OK, noch mal danke hat geklappt, das ist echt cool.
                            LG
