  4. Einbindung CC2652RB (slaesh) in ioBroker unter Docker
    5.6k
12 Beiträge 2 Kommentatoren 1.6k Aufrufe 2 Beobachtet
    MrBean 0
    @asgothian
    Hallo, wähle die Option A aus, da sie einfacher ist
    Um 13:29:00 habe ich den Adapter gestartet und um 13:29:30 beendet. Wie gewünscht die Log
    2021-06-20 13:29:02.046 - info: host.Test "system.adapter.zigbee.0" enabled
    2021-06-20 13:29:02.056 - info: host.Test instance system.adapter.zigbee.0 started with pid 1551
    2021-06-20 13:29:02.832 - info: zigbee.0 (1551) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
    2021-06-20 13:29:02.852 - info: zigbee.0 (1551) Starting Zigbee npm ...
    2021-06-20 13:29:02.942 - info: zigbee.0 (1551) Installed Version: iobroker.zigbee@1.5.6
    2021-06-20 13:29:32.026 - info: host.Test "system.adapter.zigbee.0" disabled
    2021-06-20 13:29:32.026 - info: host.Test stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-06-20 13:29:32.028 - info: host.Test stopInstance system.adapter.zigbee.0 send kill signal
    2021-06-20 13:29:32.029 - info: zigbee.0 (1551) Got terminate signal TERMINATE_YOURSELF
    2021-06-20 13:29:32.030 - info: zigbee.0 (1551) cleaned everything up...
    2021-06-20 13:29:32.032 - info: zigbee.0 (1551) Zigbee: disabling joining new devices.
    2021-06-20 13:29:32.033 - warn: zigbee.0 (1551) Failed to stop zigbee during startup
    2021-06-20 13:29:32.033 - info: zigbee.0 (1551) terminating
    2021-06-20 13:29:32.034 - info: zigbee.0 (1551) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-06-20 13:29:32.034 - error: zigbee.0 (1551) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-06-20 13:29:32.035 - error: zigbee.0 (1551) unhandled promise rejection: Cannot read property 'getEntries' of null
    2021-06-20 13:29:32.036 - error: zigbee.0 (1551) TypeError: Cannot read property 'getEntries' of null
    at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
    at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
    at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
    at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
    at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
    at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
    at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2021-06-20 13:29:32.036 - error: zigbee.0 (1551) Cannot read property 'getEntries' of null
    2021-06-20 13:29:32.565 - info: host.Test instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    Um die Funktion des Sticks zu prüfen, habe ich den Container "koenkk/zigbee2mqtt" installiert. Stick wird erkannt und konnte auch zwei Zigbee Geräte anlernen.
    Könnte ich auch die Kombination Docker "koenkk/zigbee2mqtt" & ioBroker "MQTT Broker/Client "verwenden. Hat das Vorteile/Nachteile zur oben genannten Variante?
    • M MrBean 0
      @asgothian
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @mrbean-0 sagte in Einbindung CC2652RB (slaesh) in ioBroker unter Docker:
      @asgothian
      Offensichtlich braucht dein System länger als 30 Sekunden. Bitte den Test wiederholen, dabei 3 Minuten warten bevor du den Zigbee Adapter anhältst.
      Du kannst auch zigbee2mqtt und mqtt adapter nutzen, allerdings ist da die Einbindung der Geräte komplexer, da du die Nachrichten zum steuern von Hand selber zusammen bauen musst.
      A.
      M 2 Antworten Letzte Antwort
      • AsgothianA Asgothian
        @asgothian
        A.
        MrBean 0
        @asgothian
        Gestartet um 13:54:00 und um 13:57:00 beendet
        2021-06-20 13:54:02.193 - info: host.Test "system.adapter.zigbee.0" enabled
        2021-06-20 13:54:02.203 - info: host.Test instance system.adapter.zigbee.0 started with pid 2769
        2021-06-20 13:54:02.978 - info: zigbee.0 (2769) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
        2021-06-20 13:54:02.997 - info: zigbee.0 (2769) Starting Zigbee npm ...
        2021-06-20 13:54:03.087 - info: zigbee.0 (2769) Installed Version: iobroker.zigbee@1.5.6
        2021-06-20 13:55:15.980 - error: zigbee.0 (2769) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
        2021-06-20 13:55:15.981 - error: zigbee.0 (2769) Failed to start Zigbee
        2021-06-20 13:55:15.981 - error: zigbee.0 (2769) Error herdsman start
        2021-06-20 13:55:25.983 - info: zigbee.0 (2769) Try to reconnect. 1 attempts left
        2021-06-20 13:55:25.984 - info: zigbee.0 (2769) Starting Zigbee npm ...
        2021-06-20 13:55:25.993 - info: zigbee.0 (2769) Installed Version: iobroker.zigbee@1.5.6
        2021-06-20 13:55:26.084 - error: zigbee.0 (2769) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        2021-06-20 13:55:26.084 - error: zigbee.0 (2769) Failed to start Zigbee
        2021-06-20 13:55:26.084 - error: zigbee.0 (2769) Error herdsman start
        2021-06-20 13:57:01.756 - info: host.Test "system.adapter.zigbee.0" disabled
        2021-06-20 13:57:01.756 - info: host.Test stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2021-06-20 13:57:01.758 - info: host.Test stopInstance system.adapter.zigbee.0 send kill signal
        2021-06-20 13:57:01.758 - info: zigbee.0 (2769) Got terminate signal TERMINATE_YOURSELF
        2021-06-20 13:57:01.759 - info: zigbee.0 (2769) cleaned everything up...
        2021-06-20 13:57:01.761 - info: zigbee.0 (2769) Zigbee: disabling joining new devices.
        2021-06-20 13:57:01.762 - warn: zigbee.0 (2769) Failed to stop zigbee during startup
        2021-06-20 13:57:01.763 - info: zigbee.0 (2769) terminating
        2021-06-20 13:57:01.763 - info: zigbee.0 (2769) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2021-06-20 13:57:01.764 - error: zigbee.0 (2769) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-06-20 13:57:01.764 - error: zigbee.0 (2769) unhandled promise rejection: Cannot read property 'getEntries' of null
        2021-06-20 13:57:01.765 - error: zigbee.0 (2769) TypeError: Cannot read property 'getEntries' of null
        2021-06-20 13:57:01.765 - error: zigbee.0 (2769) Cannot read property 'getEntries' of null
        2021-06-20 13:57:02.296 - info: host.Test instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          @asgothian
          A.
          MrBean 0
          @asgothian
          In der Log steht es
          Habe beides geändert. Dann wird der Adapter auch grün
          Danke für deine Hilfe
          P.S. Habe noch ein zweites Zigbee Netz am gleichen Rechner mit fhem. Möchte langsam von fhem nach ioBroker wechseln. Daher zwei Zigbee Adapter/Netze.
          • M MrBean 0
            @asgothian
            In der Log steht es
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @mrbean-0 ist es möglich das ein anderes zigbee Netz mit den gleichen netzwerkparametn existiert (panID, Kanal, ExtPan ID ?)
            A.
              A.
              MrBean 0
              @asgothian
              wäre Denkbar. Das fhem Zigbee Netz...
              • M MrBean 0
                @asgothian
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @mrbean-0
                Dann gib dem zigbee Adapter doch mal komplett andere Werte.
                A.
                  MrBean 0
                  @asgothian
                  habe gestern panId und extendedPanId schon geändert, nachdem ich im
                  log die oben genannte Fehlermeldung gesehen habe. Danach wurde der Adapter sofort grün.
                  • M MrBean 0
                    @asgothian
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @mrbean-0 Fein. Und sorry - ich hatte die weiteren Posts nicht gesehen und nur auf den mit dem Log reagiert. Gestern war es einfach zu heiss.
                    A.
                      A.
                      MrBean 0
                      @asgothian
                      Kein Problem
                      Nochmal Danke
