  4. [GELÖST] Can't start iobroker
    6.8k
errorhilfe
3 Beiträge 2 Kommentatoren 640 Aufrufe 2 Beobachtet
  • mrFenyxM Offline
    mrFenyxM Offline
    mrFenyx
    schrieb am zuletzt editiert von mrFenyx
    ich versuche verzweifelt iobroker zu starten. "Fix" geht nicht. Was kann ich als nächstes tun? Das ist was beom starten mein Log anzeigt:
    2021-06-20 21:52:25.757  - info: host.home iobroker.js-controller version 3.3.12 js-controller starting
    2021-06-20 21:52:25.764  - info: host.home Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-06-20 21:52:25.765  - info: host.home hostname: home, node: v12.22.1
    2021-06-20 21:52:25.766  - info: host.home ip addresses: 192.168.2.21 192.168.2.22
    2021-06-20 21:52:25.876  - error: host.home Cannot read system.config: null (OK when migrating or restoring)
    2021-06-20 21:52:26.059  - info: host.home connected to Objects and States
    2021-06-20 21:52:26.141  - info: host.home added notifications configuration of host
    2021-06-20 21:52:26.181  - error: host.home Cannot find view "system" for search "instance"
    2021-06-20 21:52:26.182  - error: host.home Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-06-20 21:52:26.253  - info: host.home Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-06-20 21:52:26.262  - error: host.home Cannot find view "system" for search "host"
    2021-06-20 21:52:26.272  - error: host.home Cannot find view "system" for search "state"
    2021-06-20 21:52:26.273  - error: host.home Cannot find view "system" for search "instance"
    2021-06-20 21:52:26.276  - error: host.home Could not collect system.host.home states to check for obsolete states: Error: Cannot find view "system"
    2021-06-20 21:52:26.277  - error: host.home _design/system missing - call node iobroker.js setup
    2021-06-20 21:52:26.278  - info: host.home no instances found
    2021-06-20 21:52:26.281  - error: host.home uncaught exception: doc.rows is not iterable
    2021-06-20 21:52:26.282  - error: host.home TypeError: doc.rows is not iterable
        at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2787:27)
    2021-06-20 21:52:26.291  - info: host.home iobroker _restart
    2021-06-20 21:52:26.316  - error: host.home Cannot write host object:Error: DB closed
    2021-06-20 21:52:26.340  - info: host.home terminated
    2021-06-20 21:52:26.561  - info: host.home Created UUID: a2a53834-004b-faad-72c7-e360a3f77518
    2021-06-20 21:52:26.969  - info: host.home iobroker Starting node restart.js
    2021-06-20 21:52:27.200  - info: host.home received SIGTERM
    2021-06-20 21:52:27.206  - warn: host.home get state error: Connection is closed.
    2021-06-20 21:52:27.207  - info: host.home terminated
    2021-06-20 21:52:27.268  - info: host.home iobroker exit null
    Status gibt das zurück:
     $ iobroker status
    iobroker is not running on this host.
    Objects type: file
    States  type: file
    Danke für eure Hilfe!
    • mrFenyxM mrFenyx
       $ iobroker status
      Objects type: file
      States  type: file
      @mrfenyx
      https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1623732916049
      • mrFenyxM Offline
        mrFenyxM Offline
        mrFenyx
        Fixed thanks to this:
        https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host/2
        Thanks!
