  4. NUKI und Shelly - Adapter melden werden nicht mehr grün
    6.8k
15 Beiträge 5 Kommentatoren 530 Aufrufe 4 Beobachtet
  • L legro
    @thomas-braun said in NUKI und Shelly - Adapter melden werden nicht mehr grün:
    .. > Log von einem Adapterneustart?
    Der Adapter terminiert angeblich ohne Grund.
    shelly.0
    Zeit
    debug
    Nachricht
    shelly.0
    2021-06-18 19:50:20.011	info	Shelly device 192.168.4.70 (shelly1 / shelly1-E09806961B7D / SHSW-1#E09806961B7D#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:17.926	info	Shelly device 192.168.4.78 (shelly1 / shelly1-E09806964E34 / SHSW-1#E09806964E34#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:17.891	info	Shelly device 192.168.4.75 (shelly1 / shelly1-E09806961DBD / SHSW-1#E09806961DBD#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:14.904	info	Shelly device 192.168.4.68 (shelly1 / shelly1-E0980696902C / SHSW-1#E0980696902C#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:14.623	info	Shelly device 192.168.4.76 (shellyswitch25 / shellyswitch25-483FDA7601B9 / SHSW-25#483FDA7601B9#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:14.018	info	Shelly device 192.168.4.69 (shelly1 / shelly1-E09806961C5F / SHSW-1#E09806961C5F#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:12.040	info	Shelly device 192.168.4.71 (shelly1 / shelly1-E09806961C50 / SHSW-1#E09806961C50#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:12.010	info	Shelly device 192.168.4.65 (shelly1 / shelly1-E09806968E13 / SHSW-1#E09806968E13#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:08.990	info	Shelly device 192.168.4.72 (shelly1 / shelly1-E09806961A7A / SHSW-1#E09806961A7A#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:08.470	info	Shelly device 192.168.4.79 (shellyplug-s / shellyplug-s-9DCFE0 / SHPLG-S#9DCFE0#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:07.184	info	Shelly device 192.168.4.54 (shellyswitch25 / shellyswitch25-10521CF99772 / SHSW-25#10521CF99772#1) with CoAP connected! Polltime set to 5 sec.
    shelly.0
    2021-06-18 19:50:06.541	info	Listening for Shelly packets in the network
    shelly.0
    2021-06-18 19:50:06.439	info	Starting Shelly adapter in CoAP modus.
    shelly.0
    2021-06-18 19:50:06.097	info	Starting Adapter shelly.0 in version 4.0.8
    shelly.0
    2021-06-18 19:50:06.047	info	starting. Version 4.0.8 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.3.9
    shelly.0
    2021-06-18 19:49:59.773	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    shelly.0
    2021-06-18 19:49:59.770	info	terminating
    shelly.0
    2021-06-18 19:49:59.769	info	Closing Adapter
    shelly.0
    2021-06-18 19:49:59.760	info	Got terminate signal TERMINATE_YOURSELF
    Aber irgendwie macht diese Meldung keinen Sinn, kann ich doch nach wie vor alle Geräte steuern.
    @legro Bitte keine Screenshots von LogFiles, sondern als Text in CodeTags ungekürzt hier rein.
      GlasfaserG Offline
      GlasfaserG Offline
      @legro
      https://github.com/schmupu/ioBroker.shelly/issues/398
      L 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        @legro
        legro
        @glasfaser
        Mein Verdacht ist, dass der offensichtlich ja nicht nur bei mir vorhandene Fehler am neuen admin liegen mag. Auf einem zweiten System mit altem admin ist der Adapter grün.
        Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
        L da_WoodyD 2 Antworten Letzte Antwort
        • L legro
          @glasfaser
          legro
          Nachtrag ..
          Nun habe ich den Nuki-Adapter gleich zweimal neu gestartet. Hier tritt der Fehler (glücklicherweise) nicht mehr auf.
          • L legro
            Nachtrag ..
            @legro Zum nuki-extended gibt es ein Issue.
              legro
              schrieb am zuletzt editiert von legro
              Vielen Dank für deine Hinweise.
              Da habe ich einmal vorbeigeschaut. Dort erhielt ich diese Hinweise. Leider kann ich damit überhaupt nichts anfangen.😕
              Ist allerdings nicht weiter schlimm, da der Nuki-Adapter nach seinem letzten Neustart wieder grün ist.🙂
              • L legro
                @legro
                https://github.com/Zefau/ioBroker.nuki-extended/issues/118
                ostseereiterO 1 Antwort Letzte Antwort
                • L legro
                  @glasfaser
                  da_WoodyD Offline
                  da_WoodyD Offline
                  @legro definitiv nicht.
                    @legro
                    ostseereiterO Offline
                    ostseereiter
                    das macht er schon lange wenn man es weiß ist es halb so schlimm.
                    Gruß OSR
                    Plattform
                    • ostseereiterO ostseereiter
                      @ostseereiter
                      Ja, seit mindestens Januar
                        @ostseereiter
                        legro
                        @da_Woody
                        Also bei mir hat sich seit Wochen nichts beim Shelly-Adapter geändert. Der will einfach nicht mehr grün werden, seit ich den admin 5.x verwende.
                        Obwohl der Adapter als Grund offenbar die fehlende Verbindung zum Dienst bzw. Gerät anmahnt, funktionieren alle Shellys problemlos.
                        • L legro
                          @da_Woody
                          da_WoodyD Offline
                          da_WoodyD Offline
                          @legro sültsam, ich kann den stoppen, starten, wird immer grün. auch wenn ich proxmox komplett reboote wirds was...
