  4. Adapter für Buderus KM200 (und eventuell auch anderen KMxxx)
    6.7k
686 Beiträge 99 Kommentatoren 289.0k Aufrufe 56 Beobachtet
  • D DarkSun
    Hi ich habe das Problem mit dem ioBroker plugin KM200 (2.0.3 / Node.js v12.22.1 / NPM 6.14.12) das ich keine States bekomme.
    IP / Gerätepasswort ( von Aufkleber mit und ohne '-' ) / Privates Passwort (Web/App) eingetragen.
    Heizung ist eine Bosch Condens 9000i WM / Regler CW400 / Bosch MB LANi V2 (FW 04.07.06)
    km200.0 2021-04-24 02:41:05.826 info (623688) Adapter km200 initialization finished with 0 states.
    km200.0 2021-04-24 02:41:05.760 info (623688) debug: updateStates: 'all' @2021-04-24T02:41:05.759Z
    km200.0 2021-04-24 02:41:05.759 info (623688) Slow Interval=6 hours, Slow-List:
    km200.0 2021-04-24 02:41:05.759 info (623688) Fast Interval=2 min, Fast-List:
    km200.0 2021-04-24 02:41:05.759 info (623688) Interval=30 min, Norm-list:
    km200.0 2021-04-24 02:41:05.757 info (623688) KM200 found 0 states, get their values now.
    km200.0 2021-04-24 02:41:05.756 info (623688) Services found: 41
    km200.0 2021-04-24 02:41:05.756 warn (623688) Did not get any Services from KLM200!: {}
    km200.0 2021-04-24 02:41:04.714 info (623688) debug: add to blocked /..holidayModes.$/
    km200.0 2021-04-24 02:41:04.714 info (623688) debug: add to blocked /..switchPrograms.$/
    km200.0 2021-04-24 02:41:04.714 info (623688) debug: add to blocked /^/gateway.*$/
    km200.0 2021-04-24 02:41:04.713 info (623688) debug: KM200 init(10.0.9.4, 222,78,66,49,226,239,75,234,107,47,125,24,247,5,142,110,65,157,3,64,57,186,60,83,191,145,30,233,38,179,57,250) done!
    km200.0 2021-04-24 02:41:04.713 info (623688) km200.0 address: http://10.0.9.4
    km200.0 2021-04-24 02:41:04.712 info (623688) km200 initialization started...
    km200.0 2021-04-24 02:41:04.711 info (623688) debug: km200 received undefined objects and 0 states, with config adresse,blacklist,fastlist,slowlist,interval,fastinterval,slowinterval,deletestates,accesskey,privatepassword,lang,latitude,
    km200.0 2021-04-24 02:41:04.544 info (623688) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.km200, node: v12.22.1, js-controller: 3.2.16
    km200.0 2021-04-24 02:41:04.516 debug (623688) statesDB connected
    km200.0 2021-04-24 02:41:04.515 debug (623688) States connected to redis: 127.0.0.1:6379
    km200.0 2021-04-24 02:41:04.513 debug (623688) States create User PubSub Client
    km200.0 2021-04-24 02:41:04.512 debug (623688) States create System PubSub Client
    km200.0 2021-04-24 02:41:04.509 debug (623688) Redis States: Use Redis connection: 127.0.0.1:6379
    km200.0 2021-04-24 02:41:04.507 debug (623688) objectDB connected
    km200.0 2021-04-24 02:41:04.503 debug (623688) Objects connected to redis: 127.0.0.1:6379
    km200.0 2021-04-24 02:41:04.494 debug (623688) Objects client initialize lua scripts
    km200.0 2021-04-24 02:41:04.494 debug (623688) Objects create User PubSub Client
    km200.0 2021-04-24 02:41:04.493 debug (623688) Objects create System PubSub Client
    km200.0 2021-04-24 02:41:04.492 debug (623688) Objects client ready ... initialize now
    km200.0 2021-04-24 02:41:04.464 debug (623688) Redis Objects: Use Redis connection: 127.0.0.1:6379
    Degto
    #492
    @darksun sagte in Adapter für Buderus KM200 (und eventuell auch anderen KMxxx):
    Guten Tag liebe Wissende. Ich habe leider das Gleiche Problem, wie hier beschrieben, bei gleichen Hardwarekomponenten. Bitte helft uns doch mal etwas auf die Sprünge. Wo liegt das Problem. Ich habe leider keine Möglichkeit dies zu erkennen. Danke euch schon jetzt.
    • D Degto
      manrum1
      #493
      @degto Wie hast Du denn dein MB LAN angeschlossen? Passt das überhaupt zur Heizung?
      • M manrum1
        Degto
        #494
        @manrum1 lan ist angeschlossen. LAN ist bereits installiert in der Steuerung der Anlage. Das Steuerungspanel ist das cw400. Alles war bereits fertig von bosch. Ich habe nur das Lankabel eingesteckt. Die App von bosch funktioniert auch einwandfrei.
        • D Degto
          tp1de
          #495
          @degto
          Geräte PW muss mit "-" eingegeben werden. Welches privates PW hast Du angegeben?
          Die neue App MyBuderus nutzt das Bosch account PW. Dies ist aber anders als in der älteren MyDevice App.
          Nur das PW der MyDevice App funktioniert. Dies setzt Du selber bei der Einrichtung ....
          M D 2 Antworten Letzte Antwort
          • T tp1de
            @degto
            manrum1
            schrieb am zuletzt editiert von manrum1
            #496
            Hallo zusammen, Mir ist aufgefallen, dass nach dem Update des js controllers (host) auf 3.3.12 in den recordings plötzlich Blanks auftauchen. Das war vorher nicht so, woher kommt das ?
            • T tp1de
              @degto
              Degto
              #497
              @tp1de Geräte pw habe ich mit - eingegeben. Das persönliche PW habe ich von der App bosch Home Come easy, das gleich ist mit bosch HomeCome, genommen. Dahin werden die Daten auch ordentlich gesendet.
              • D Degto
                tp1de
                #498
                @degto .... dann bleibt eigentlich nur die IP-Adresse übrig
                • T tp1de
                  Degto
                  #499
                  @tp1de die IP habe ich in der fritzbox fixiert. Über die IP und Port 80 ist das Gerät auch erreichbar. Danke für deine Hilfe! Ich komme wirklich nicht weiter und habe von Programmierung keine Ahnung.
                  T D 2 Antworten Letzte Antwort
                  • D Degto
                    tp1de
                    #500
                    @degto sagte in Adapter für Buderus KM200 (und eventuell auch anderen KMxxx):
                    Erreichbar ... wie? Gib mal ip/heatSources im Browser ein ... was kommt zurück?
                    • D Degto
                      Degto
                      #501
                      @degto hier noch die logs:km200.0 2021-06-18 10:46:10.169 warn (13994) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                      km200.0 2021-06-18 10:46:10.168 info (13994) KM200 finished creation of 0 states: []
                      km200.0 2021-06-18 10:46:10.165 info (13994) Services found: 41
                      km200.0 2021-06-18 10:46:10.163 warn (13994) Did not get any Services from KLM200!: {}
                      km200.0 2021-06-18 10:46:09.510 info (13994) Interval=15 min, Black/Push-list: /gateway*,/recordings*,.switchPrograms.,/heatSource*,.holidayModes.
                      km200.0 2021-06-18 10:46:09.503 info (13994) km200.0. address: http://192.168.2.40
                      km200.0 2021-06-18 10:46:08.362 warn (13994) adapter.objects.getObjectList is deprecated, and will be removed in the future. Please use adapter.getObjectList/Async. Report this to Developer!
                      km200.0 2021-06-18 10:46:08.326 info (13994) starting. Version 1.1.6 in /opt/iobroker/node_modules/iobroker.km200, node: v12.19.0, js-controller: 3.2.16
                      • M manrum1
                        tp1de
                        #502
                        @manrum1
                        Ich verzweifle auch am js-controller 3.3.13. Der ist Beta !!! und überprüft nun die Datentypen sehr strict beim insert/update der states. Ich musste viele meiner scripts und meinen Adapter anpassen. War Einiges an Arbeit.
                        Der km200-Adapter ist schon länger nicht upgedated worden. Ich vermute es liegt daran.
                        • D Degto
                          tp1de
                          #503
                          Diese Version ist recht alt. Aktuell ist 2.0.3. Probier die mal aus
                          • T tp1de
                            Degto
                            #504
                            @tp1de Antwort : Sorry, the requested file does not exist on this server.
                            • D Degto
                              tp1de
                              #505
                              @degto Ja ist richtig, da die Headers nicht gesetzt sind. Benutzt Du wirklich die Adapterversion 1.1.6 ???
                              • T tp1de
                                @manrum1
                                manrum1
                                #506
                                @tp1de Hi, danke für deineAntwort. Das betrifft wohl generell alle Adapter, erklärt wohl auch folgende Fehlermeldungen bzgl. falschen Datentypen, anbei ein Auszug:
                                sonoff: State value to set for "sonoff.0.shelly-studio.ENERGY_TotalStartTime" has to be type "number" but received type "string"
                                fritzdect: State value to set for "fritzdect.0.DECT_133560197704.boostactiveendtime" has to be type "number" but received type "object"
                                Das alles sorg dafür, dass das Log zugemüllt wird. Ich bin neugierig, bis wann alle Adapter das nach neuer Konvenntion handeln un dwurde wohl beim Update auf die neue iobroker Version nicht bedacht?
                                • M manrum1
                                  tp1de
                                  #507
                                  @manrum1 Ja genau. Einige Adapter weden gar nicht mehr weiter entwickelt. Da hilft aktuell nur zur js-controller version 3.2.x zurückzugehen ....
                                  • T tp1de
                                    Degto
                                    #508
                                    @tp1de ja, 1.1.6. Es ist bei mir auch keine neuere Version verfügbar.
                                    • D Degto
                                      tp1de
                                      schrieb am zuletzt editiert von tp1de
                                      #509
                                      @degto Installiere von Github ... dann musst Du manuell einen Upload machen
                                      • T tp1de
                                        Degto
                                        #510
                                        @tp1de ok, mach ich dann mal. Dankeschön!
                                        • T tp1de
                                          manrum1
                                          #511
                                          @frankjoke Hi, hast Du bzgl. Datentypen nähere Infos? Danke im Voraus!
