  4. Adapter für Telnet Daten
105 Beiträge 3 Kommentatoren 14.2k Aufrufe 3 Beobachtet
  • mickymM mickym
    @nwh Mach bitte den Haken - iobroker-Werte in String konvertieren noch raus - hat zwar für diesen Flow keine Relevanz, aber ggf. für später - erspart Dir viel Konvertiererei.
    NWHN Offline
    NWHN Offline
    NWH
    @mickym sagte in Adapter für Telnet Daten:
    erledigt
    • NWHN NWH
      erledigt
      mickymM Offline
      mickymM Offline
      mickym
      @nwh Gut - dann importiere folgende Nodes und verbinde sie mit Deiner TCP request Node (Elios4You - Node) - es passiert noch nichts, da die iobroker-out Node noch deaktiviert ist:
             "id": "a3c08591.8dd148",
             "type": "split",
             "z": "6e170384.60c96c",
             "name": "",
             "splt": "\\n",
             "spltType": "str",
             "arraySplt": 1,
             "arraySpltType": "len",
             "stream": false,
             "addname": "",
             "x": 1640,
             "y": 4440,
             "wires": [
                     "a5ab7164.7d8da"
             "id": "a5ab7164.7d8da",
             "type": "function",
             "name": "Buffer to String",
             "func": "msg.payload=msg.payload.toString();\nreturn msg;",
             "outputs": 1,
             "noerr": 0,
             "initialize": "",
             "finalize": "",
             "libs": [],
             "x": 1800,
             "y": 4440,
             "wires": [
                     "4de00e67.b031"
             "id": "efb459df.e33e58",
             "type": "change",
             "name": "Create Topic",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "$trim(payload)\t",
                     "tot": "jsonata"
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "payload",
                     "tot": "msg"
                     "t": "set",
                     "p": "stateUnit",
                     "pt": "msg",
                     "to": "payload",
                     "tot": "msg"
                     "t": "change",
                     "p": "stateUnit",
                     "pt": "msg",
                     "from": ";(.*?);(.*?);(.*);$",
                     "fromt": "re",
                     "to": "$3",
                     "tot": "str"
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "fromt": "re",
                     "to": "$1",
                     "tot": "str"
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "from": " ",
                     "fromt": "str",
                     "to": ".",
                     "tot": "str"
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "from": "_",
                     "fromt": "str",
                     "to": "",
                     "tot": "str"
                     "t": "set",
                     "p": "topic",
                     "pt": "msg",
                     "to": "'0_userdata.0.Elios4You.' & topic",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2130,
             "y": 4440,
             "wires": [
                     "e14023cc.c08a7"
             "id": "e14023cc.c08a7",
             "type": "switch",
             "name": "Topic Exceptions",
             "property": "topic",
             "propertyType": "msg",
             "rules": [
                     "t": "cont",
                     "v": "UTC.Time",
                     "vt": "str"
                     "t": "cont",
                     "v": "MBS",
                     "vt": "str"
                     "t": "else"
             "checkall": "true",
             "repair": false,
             "outputs": 3,
             "x": 2330,
             "y": 4440,
             "wires": [
                     "3a5c7458.fe621c"
                     "e405626a.fdf0b"
                     "770dc167.2cbf1"
             "id": "96271f37.f0e62",
             "type": "ioBroker out",
             "d": true,
             "name": "",
             "topic": "",
             "ack": "true",
             "autoCreate": "true",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 2940,
             "y": 4440,
             "wires": []
             "id": "d72760c4.a3bd4",
             "type": "change",
             "name": "payload = Number",
             "rules": [
                     "t": "change",
                     "p": "payload",
                     "pt": "msg",
                     "fromt": "re",
                     "to": "$2",
                     "tot": "str"
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "to": "$number(payload)\t",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2710,
             "y": 4500,
             "wires": [
                     "f0c2b56a.70ee38",
                     "96271f37.f0e62"
             "id": "4de00e67.b031",
             "type": "switch",
             "name": "",
             "property": "payload",
             "rules": [
                     "t": "regex",
                     "v": ";.*",
                     "vt": "str",
                     "case": false
             "checkall": "true",
             "repair": false,
             "outputs": 1,
             "x": 1970,
             "y": 4440,
             "wires": [
                     "efb459df.e33e58"
             "id": "e405626a.fdf0b",
             "type": "change",
             "name": "Topic MBS",
             "rules": [
                     "t": "change",
                     "p": "payload",
                     "pt": "msg",
                     "from": ";MBS;(.*);$",
                     "fromt": "re",
                     "to": "$1",
                     "tot": "str"
                     "t": "delete",
                     "p": "stateUnit",
                     "pt": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2730,
             "y": 4440,
             "wires": [
                     "f0c2b56a.70ee38",
                     "96271f37.f0e62"
             "id": "770dc167.2cbf1",
             "type": "switch",
             "name": "Filter",
             "rules": [
                     "t": "regex",
                     "v": ";.*?;.*?;.*;$",
                     "vt": "str",
                     "case": false
             "checkall": "true",
             "repair": false,
             "outputs": 1,
             "x": 2520,
             "y": 4500,
             "wires": [
                     "d72760c4.a3bd4"
             "id": "3a5c7458.fe621c",
             "type": "change",
             "name": "UTC Time",
             "rules": [
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "from": "UTC.Time",
                     "fromt": "str",
                     "to": "UTC-Time",
                     "tot": "str"
                     "t": "change",
                     "p": "payload",
                     "pt": "msg",
                     "fromt": "re",
                     "to": "$2",
                     "tot": "str"
                     "t": "delete",
                     "p": "stateUnit",
                     "pt": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 2740,
             "y": 4380,
             "wires": [
                     "f0c2b56a.70ee38",
                     "96271f37.f0e62"
             "id": "f0c2b56a.70ee38",
             "type": "debug",
             "name": "",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "complete": "false",
             "statusVal": "",
             "statusType": "auto",
             "x": 2950,
             "y": 4380,
             "wires": []
      Dein Flow sollte dann wie folgt aussehen - und im Debug - Fenster - das könntest Du bitte posten, sollten dann eine Menge Einzelnachrichten auftauchen:
      Sollte dann so ähnlich aussehen:
      NWHN 1 Antwort Letzte Antwort
      • mickymM mickym
               "type": "split",
               "name": "",
               "splt": "\\n",
               "spltType": "str",
               "arraySplt": 1,
               "stream": false,
               "addname": "",
               "x": 1640,
               "y": 4440,
               "wires": [
                       "a5ab7164.7d8da"
               "type": "function",
               "outputs": 1,
               "noerr": 0,
               "initialize": "",
               "finalize": "",
               "libs": [],
               "x": 1800,
               "y": 4440,
               "wires": [
                       "4de00e67.b031"
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "to": "payload",
                       "tot": "msg"
                       "t": "set",
                       "p": "stateUnit",
                       "pt": "msg",
                       "to": "payload",
                       "tot": "msg"
                       "t": "change",
                       "p": "stateUnit",
                       "pt": "msg",
                       "fromt": "re",
                       "to": "$3",
                       "tot": "str"
                       "t": "change",
                       "p": "topic",
                       "pt": "msg",
                       "fromt": "re",
                       "to": "$1",
                       "tot": "str"
                       "t": "change",
                       "p": "topic",
                       "pt": "msg",
                       "from": " ",
                       "fromt": "str",
                       "to": ".",
                       "tot": "str"
                       "t": "change",
                       "p": "topic",
                       "pt": "msg",
                       "from": "_",
                       "fromt": "str",
                       "to": "",
                       "tot": "str"
                       "t": "set",
                       "p": "topic",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2130,
               "y": 4440,
               "wires": [
                       "e14023cc.c08a7"
               "type": "switch",
               "rules": [
                       "t": "cont",
                       "v": "UTC.Time",
                       "vt": "str"
                       "t": "cont",
                       "v": "MBS",
                       "vt": "str"
                       "t": "else"
               "checkall": "true",
               "repair": false,
               "outputs": 3,
               "x": 2330,
               "y": 4440,
               "wires": [
                       "3a5c7458.fe621c"
                       "e405626a.fdf0b"
                       "770dc167.2cbf1"
               "d": true,
               "name": "",
               "topic": "",
               "ack": "true",
               "stateName": "",
               "role": "",
               "payloadType": "",
               "readonly": "",
               "stateUnit": "",
               "stateMin": "",
               "stateMax": "",
               "x": 2940,
               "y": 4440,
               "wires": []
               "type": "change",
               "rules": [
                       "t": "change",
                       "p": "payload",
                       "pt": "msg",
                       "fromt": "re",
                       "to": "$2",
                       "tot": "str"
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2710,
               "y": 4500,
               "wires": [
                       "f0c2b56a.70ee38",
                       "96271f37.f0e62"
               "type": "switch",
               "name": "",
               "rules": [
                       "t": "regex",
                       "v": ";.*",
                       "vt": "str",
                       "case": false
               "checkall": "true",
               "repair": false,
               "outputs": 1,
               "x": 1970,
               "y": 4440,
               "wires": [
                       "efb459df.e33e58"
               "type": "change",
               "rules": [
                       "t": "change",
                       "p": "payload",
                       "pt": "msg",
                       "fromt": "re",
                       "to": "$1",
                       "tot": "str"
                       "t": "delete",
                       "p": "stateUnit",
                       "pt": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2730,
               "y": 4440,
               "wires": [
                       "f0c2b56a.70ee38",
                       "96271f37.f0e62"
               "type": "switch",
               "name": "Filter",
               "rules": [
                       "t": "regex",
                       "vt": "str",
                       "case": false
               "checkall": "true",
               "repair": false,
               "outputs": 1,
               "x": 2520,
               "y": 4500,
               "wires": [
                       "d72760c4.a3bd4"
               "type": "change",
               "name": "UTC Time",
               "rules": [
                       "t": "change",
                       "p": "topic",
                       "pt": "msg",
                       "from": "UTC.Time",
                       "fromt": "str",
                       "to": "UTC-Time",
                       "tot": "str"
                       "t": "change",
                       "p": "payload",
                       "pt": "msg",
                       "fromt": "re",
                       "to": "$2",
                       "tot": "str"
                       "t": "delete",
                       "p": "stateUnit",
                       "pt": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 2740,
               "y": 4380,
               "wires": [
                       "f0c2b56a.70ee38",
                       "96271f37.f0e62"
               "type": "debug",
               "name": "",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 2950,
               "y": 4380,
               "wires": []
        NWHN Offline
        NWHN Offline
        NWH
        • NWHN NWH
          mickymM Offline
          mickymM Offline
          mickym
          @nwh Na das schaut doch schon ausgezeichnet aus. :)
          Dann brauchst Du eigentlich durch Drücken auf die Schaltfläche bei den Debug Nodes - diese zu deaktivieren:
          und dann gehst Du in die iobroker -out Node und aktivierst diese:
          Und dann solltest Du Deine Datenpunkte im iobroker haben.
          Wenn das soweit geklappt hat - dann überlegen wir uns noch was zum Triggern. ;)
          • mickymM mickym
            NWHN Offline
            NWHN Offline
            NWH
            schrieb am zuletzt editiert von NWH
            Alles wunderbar :-)
            Eigentlich sollte er die Daten permanent auslesen, oder?
            • NWHN NWH
              Alles wunderbar :-)
              mickymM Offline
              mickymM Offline
              mickym
              @nwh OK - super.
              Wie willst Du den Flow nun triggern. Soll das zyklisch in einem Intervall gepollt werden oder möchtest Du den Abruf der Daten über VIS - über einen Button aktualisieren?
              • NWHN NWH
                Alles wunderbar :-)
                mickymM Offline
                mickymM Offline
                mickym
                @nwh sagte in Adapter für Telnet Daten:
                Diese Frage habe ich Dir gerade gestellt, wie Du es denn gerne hättest. ;)
                • mickymM mickym
                  @nwh OK - super.
                  NWHN Offline
                  NWHN Offline
                  NWH
                  @nwh OK - super.
                  In der App sieht es so aus.
                  Da ist es eigentlich permanent.
                  Aber ob das Sinn macht ist die Frage.
                  Das wäre cool nach zu bauen.
                  • NWHN NWH
                    @nwh OK - super.
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @nwh Also - wenn Du pollst - also zyklisch abfragen willst, kannst Du das direkt in der Inject Node machen. Kannst sogar den Zeitraum, indem gepollt wird eintragen.
                    Ansonsten erstellst Du unter userdata wieder einen Datenpunkt, denn Du über Deine VIS diesen triggerst und der triggert Dir den Flow und refresht Deine Daten - kannst auch beides machen.
                    • mickymM mickym
                      NWHN Offline
                      NWHN Offline
                      NWH
                      Wie heißt der Datenpunkt "refresh" ? und welchen Wert soll der dann haben?
                      Ich hätte hier jetzt mal 5 sec eingetragen.
                      Allerdings ändern sich die Daten jetzt nicht.
                      • NWHN NWH
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @nwh Na dann macht das halt keinen Sinn - weil sich die Werte nicht alle 5 sekunden ändern.
                        Ich kann mir vorstellen, dass sich das vielleicht alle paar Minuten oder länger ändert
                        • mickymM mickym
                          NWHN Offline
                          NWHN Offline
                          NWH
                          Naja doch denn der Stromverbrauch ändert sich ja auch ständig.
                          Es muss eh nicht alle Sekunden sein, allerdings in der App wird es in Echtzeit angezeigt.
                          Deswegen dachte ich nur.
                          • NWHN NWH
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @nwh Nun dann klappt es aber auch manuell nicht mehr. Du hast aber schon in der Inject Node noch das \r hinter dem @DAT drinnen? (nicht wie bei mir im Screenshot?)
                            NWHN 2 Antworten Letzte Antwort
                            • mickymM mickym
                              NWHN Offline
                              NWHN Offline
                              NWH
                              @mickym Komisch es kommen keine Daten mehr im Iobroker an.
                              Ja die debug note habe ich gerade aktiviert. da kommt auch nix.
                              Sehr komisch. Netzwerk passt aber. gerade im Unifi nachgeschaut alles brav online.
                              • mickymM mickym
                                NWHN Offline
                                NWHN Offline
                                NWH
                                Es sieht so aus.
                                Allerdings habe ich nix gegenüber zuvor nichts verändert.
                                Frage wo sehe ich jetzt eigentlich den Code, der bei dem alten Flow in der Function stand.
                                • NWHN NWH
                                  Es sieht so aus.
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @nwh Mach einfach \r hinten dran.
                                  In der function stand nicht mehr - nur in Kleinbuchstaben:
                                  msg.payload = "@dat\r";
                                  return msg;
                                  Wie gesagt mach hinter das @DAT einfach das \r
                                  • mickymM mickym
                                    return msg;
                                    NWHN Offline
                                    NWHN Offline
                                    NWH
                                    Irgendwas hat es jetzt, bekomme auch mit der App keine Daten mehr.
                                    So ein Mist das Ding. Italienisch halt :)
                                    • NWHN NWH
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @nwh Na vielleicht war das mit den 5s pollen einfach zuviel für das Teil.
                                      Wie Du es wieder zum Laufen bringst, da kann ich Dir nicht helfen, aber ich hätte auch eher im Minutenbereich abgefragt.
                                      • mickymM mickym
                                        NWHN Offline
                                        NWHN Offline
                                        NWH
                                        @mickym Ja ich dreh dem Ding jetzt mal den Strom ab. Mal sehen ob er sich dann wieder ansprechen lässt.
                                        Kann mir nicht vorstellen das 5 sec zu viel sind da die Daten in der App ja auch permanent aktualisiert werden.
                                        Kann es sein das mehrere Zugriffe das übel sind.
                                        • NWHN NWH
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @nwh Das kann alles sein, dass sich das gegenseitig blockiert. Ich wäre jedenfalls vorsichtig mit zu häufigem Aktualisieren. Aber das sind jetzt Dinge, die haben mit NodeRed oder dem iobroker wenig zu tun.
                                          Keine Ahnung ob die App auch immer pollt oder diese aktiv von der Firmware benachrichtigt wird.
                                          Ab jetzt bist Du diesbezüglich wieder auf Dich gestellt, da kann ich nicht mehr helfen.
