  4. ioBroker und openhabian image
31 Beiträge 3 Kommentatoren 2.1k Aufrufe 2 Beobachtet
    @marko1974
    curl -fsSL https://deb.nodesource.com/gpgkey/nodesource.gpg.key | sudo apt-key add -
    Was kommt zu
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
    Marko1974M Offline
    Marko1974M Offline
    Marko1974
    [21:37:06] openhabian@openhab:/var/homebridge$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/local/bin/npm
    v14.17.0
    v12.14.0
    6.14.8
    Hit:1 https://deb.nodesource.com/node_14.x buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:4 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
    Reading package lists... Done
    Building dependency tree
    7 packages can be upgraded. Run 'apt list --upgradable' to see them.
    nodejs:
     Installed: 14.17.0-1nodesource1
     Candidate: 14.17.0-1nodesource1
     Version table:
    *** 14.17.0-1nodesource1 500
           500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
        10.24.0~dfsg-1~deb10u1 500
    • Marko1974M Marko1974
      @thomas-braun das war schonmal gut :-)
      aber ich habs wohl auch im falschen verzeichnis und node ist immer noch auf 12
      [21:33:22] openhabian@openhab:/var/homebridge$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v14.17.0
      v12.14.0
      6.14.8
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
      Hit:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
      nodejs:
        Version table:
      @marko1974 sagte in ioBroker und openhabian image:
      /usr/local/bin/node
      /usr/local/bin/npm
      Das ist aus ioBroker Sicht falsch.
      Marko1974M 1 Antwort Letzte Antwort
        /usr/local/bin/node
        /usr/local/bin/npm
        Marko1974M Offline
        Marko1974M Offline
        Marko1974
        @thomas-braun wenn ich das ändere geht meine homebridge nicht mehr, oder?
          @marko1974 Das weiß ich nicht.
          Hängt davon ab ob die das statisch verlinkt haben und/oder ob deren Code mit node14 sauber tickt.
          Unter der Voraussetzung, die Installation in /usr/local/bin kommt schon so in deren Image mit und nicht von dir.
            Marko1974M Offline
            Marko1974M Offline
            Marko1974
            @thomas-braun `lass mal probieren....notfalls gibts n backup.
            haste den befehl für mich?
              @marko1974
              Die stehen in dem HowTo drin.
              https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
                @marko1974
                Marko1974M Offline
                Marko1974M Offline
                Marko1974
                @thomas-braun Die Verzeichnisse kommen daher weil homebridge da installiert ist.....puh...dann muesste ich alles umfrickeln
                  @marko1974
                  Du sollst ja auch nicht die Verzeichnisse löschen sonder nur die Dateien npm und node
                  Oder nenn die um. Z. B. in npm_TEST und node_TEST
                    @marko1974
                    Marko1974M Offline
                    Marko1974M Offline
                    Marko1974
                    @thomas-braun das hatte ich ja schon getan, aber dann installiert er sie wieder da ✌
                      @marko1974
                      Wer installiert das wieder dort?
                        @marko1974
                        Marko1974M Offline
                        Marko1974M Offline
                        Marko1974
                        ich probiere es gleich nochmal
                          Marko1974M Offline
                          Marko1974M Offline
                          Marko1974
                          @marko1974 ```
                          [00:34:15] openhabian@openhab:/usr/local/bin$ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          v14.17.0
                          v14.17.0
                          6.14.13
                          nodejs:
                          Version table:
                            @marko1974 ```
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v14.17.0
                            v14.17.0
                            6.14.13
                            nodejs:
                            Version table:
                            @marko1974
                            Das schaut ganz gut aus. Was sagt openhab?
                            Marko1974M 3 Antworten Letzte Antwort
                              @marko1974
                              Marko1974M Offline
                              Marko1974M Offline
                              Marko1974
                              @thomas-braun alles gut....jetzt schaue ich mal ob ich iobroker installiert bekomme
                                @marko1974
                                Marko1974M Offline
                                Marko1974M Offline
                                Marko1974
                                npm ERR! code ELIFECYCLE
                                npm ERR! errno 22
                                npm ERR! iobroker.js-controller@3.2.16 install: node iobroker.js setup first
                                npm ERR! Exit status 22
                                npm ERR!
                                npm ERR! Failed at the iobroker.js-controller@3.2.16 install script.
                                npm ERR! /home/openhabian/.npm/_logs/2021-05-23T22_50_34_693Z-debug.log
                                Finalizing installation (4/4)
                                Enabling autostart...
                                Autostart enabled!
                                ioBroker was installed successfully
                                Open http://192.168.178.72:8081 in a browser and start configuring!
                                You need to re-login before doing anything else on the console!
                                [00:50:37] openhabian@openhab:/$
                                  @marko1974
                                  Marko1974M Offline
                                  Marko1974M Offline
                                  Marko1974
                                  schrieb am zuletzt editiert von Marko1974
                                  Jetzt hatte ich alles nochmal schön gemacht und node und nodejs nach einem Backup neu installiert. Hatte darauf geachtet, dass zuerst wenigstens meine homebridges laufen.
                                  Das tun sie nun auch nach nem rebuild.
                                  Dann wollte ich mich zurücklehnen und einfach iobroker installieren.....irgendwie wieder ein ähnliches Problem.
                                  [00:46:27] openhabian@openhab:/opt/iobroker$ curl -sLf https://iobroker.net/install.sh | bash -
                                  library: loaded
                                  Library version=2021-04-07
                                      Welcome to the ioBroker installer!
                                      Installer version: 2021-04-07
                                      You might need to enter your password a couple of times.
                                      Installing prerequisites (1/4)
                                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                  Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
                                  Changing npm registry to https://registry.npmjs.org
                                  Installed gcc-c++
                                      Creating ioBroker user and directory (2/4)
                                  Directory /opt/iobroker created
                                      Installing ioBroker (3/4)
                                  In file included from ../../nan/nan.h:56,
                                                   from ../src/main.cpp:3:
                                  /home/openhabian/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                         (node::addon_register_func) (regfunc),                          \
                                  /home/openhabian/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
                                     NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                  ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                                   NODE_MODULE(diskusage, Init)
                                                   from ../src/unix_dgram.cc:5:
                                  ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                                   NODE_MODULE(unix_dgram, Initialize)
                                  npm ERR! errno 22
                                  npm ERR! iobroker.js-controller@3.2.16 install: `node iobroker.js setup first`
                                  npm ERR!
                                  npm ERR!     /home/openhabian/.npm/_logs/2021-05-31T22_47_41_873Z-debug.log
                                  Autostart enabled!
                                  [00:47:44] openhabian@openhab:/opt/iobroker$ which iobroker
                                  /usr/bin/iobroker
                                  [00:47:49] openhabian@openhab:/opt/iobroker$
                                  [00:47:49] openhabian@openhab:/opt/iobroker$ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && apt policy nodejs
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v12.22.1
                                  v12.22.1
                                  6.14.12
                                  nodejs:
                                    Installed: 12.22.1-1nodesource1
                                    Candidate: 12.22.1-1nodesource1
                                    Version table:
                                   *** 12.22.1-1nodesource1 500
                                          500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                  [00:52:01] openhabian@openhab:/opt/iobroker$
                                    library: loaded
                                    Installed gcc-c++
                                    npm ERR! errno 22
                                    npm ERR!
                                    Autostart enabled!
                                    /usr/bin/iobroker
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v12.22.1
                                    v12.22.1
                                    6.14.12
                                    nodejs:
                                      Version table:
                                    Marko1974M Offline
                                    Marko1974M Offline
                                    Marko1974
                                    Auch geschafft.
                                    node iobroker.js nachinstalliert ....noch schnell die ports geändert und dann lief es wieder durch
