  4. ioBroker - keine Datenbank-Verbindung
20 Beiträge 3 Kommentatoren 2.8k Aufrufe 2 Beobachtet
  • S sunshineh
    @thomas-braun said in ioBroker - keine Datenbank-Verbindung:
    sudo -H -u iobroker npm install iobroker.js-controller
    Ich erhalten dann folgende Meldung
    [..................] / rollbackFailedOptional: verb npm-session 4dd9bb70681b3b8
    @sunshineh
    Da kommt noch mehr. Davor und danach.
      @sunshineh
      sunshineh
      @thomas-braun OK, diesmal ist ne Menge durchgelaufen:
      /opt/iobroker $ sudo -H -u iobroker npm install iobroker                                        .js-controller
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/acorn-globals
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/char-regex
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/jest-pnp-resolver
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/bser
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/fb-watchman
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/capture-exit
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/ecc-jsbn
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/tr46
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/w3c-hr-time
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/acorn-globals
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/char-regex
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest-pnp-resolver
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/bser
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fb-watchman
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/capture-exit
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/ecc-jsbn
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/tr46
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/w3c-hr-time
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/acorn-globals
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/char-regex
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/jest-pnp-resolver
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/bser
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/fb-watchman
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/capture-exit
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/ecc-jsbn
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/tr46
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/w3c-hr-time
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/acorn-globals
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/acorn-globals'
      npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/acorn-globals'] {
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/acorn-globals'
      npm ERR! }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /home/iobroker/.npm/_logs/2021-05-14T15_39_52_968Z-debug.log
      • S sunshineh
        npm ERR! errno -13
        npm ERR! }
        npm ERR!
        npm ERR!
        @sunshineh
        Als welcher user wurde das ausgeführt?
        Und warum darf der iobroker nicht da herumschreiben?
        iobroker fix
        dmesg -T | grep -i ext4
          sunshineh
          Der Fix-Teil ist normal durchgelaufen, auf den 2. Befehl habe ich folgende antwort erhalten:
          /opt/iobroker $ dmesg -T | grep -i ext4
          [Fri May 14 08:56:39 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [Fri May 14 08:56:42 2021] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Fri May 14 08:56:42 2021] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Fri May 14 08:56:43 2021] EXT4-fs (mmcblk0p2): recovery complete
          [Fri May 14 08:56:43 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Fri May 14 08:56:43 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Fri May 14 08:56:45 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          Dann habe ich noch
          iobroker start
          eingegeben, aber die Oberfläche ist dennoch nicht erreichbar.
          Ich weiß nicht, ob's was hilft, aber ich hab noch folgenden Befehl getestet:
          sudo netstat -tulpen
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17583      642/sshd
          tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          16006      355/python
          tcp        0      0 127.0.0.1:7999          0.0.0.0:*               LISTEN      0          16517      498/motion
          tcp        0      0 0.0.0.0:8079            0.0.0.0:*               LISTEN      0          16515      498/motion
          tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      0          16516      498/motion
          tcp6       0      0 :::22                   :::*                    LISTEN      0          17585      642/sshd
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15037      634/dhcpcd
          udp        0      0 0.0.0.0:60003           0.0.0.0:*                           108        15733      386/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15731      386/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          15832      634/dhcpcd
          udp6       0      0 :::54391                :::*                                108        15734      386/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        15732      386/avahi-daemon: r
          • S sunshineh
            Dann habe ich noch
            iobroker start
            @sunshineh
            Da ist dein Dateisystem auf der SD-Karte zumindest angeschossen.
            Starte den Server nochmal durch
            sudo reboot
            und dann als erste Aktion nochmal
              @sunshineh
              sudo reboot
              sunshineh
              [Sat May 15 11:14:18 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=738a4d67-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
              [Sat May 15 11:14:21 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [Sat May 15 11:14:21 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Sat May 15 11:14:24 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              Ich bin hier auch diese Anleitung durch gegangen: elzershark.com
              Doch da erhalte ich während der Ausführung folgenden Fehler
                  Installing ioBroker (3/4)
              npm ERR! code 22
              npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
              npm ERR! command failed
              npm ERR! command sh -c node iobroker.js setup first
              npm ERR! No connection to databases possible ...
              npm ERR!     /home/pi/.npm/_logs/2021-05-15T09_09_16_803Z-debug.log
              Also ich hab immer Probleme mit dem js-controller, der lässt sich aber nicht neu installieren.
              • S sunshineh
                npm ERR! code 22
                @sunshineh
                Vergiss den Elsterhai. Da kommt erfahrunggemäß nur Mist bei rum.
                Hast du jetzt den ganzen Quatsch den der da in seiner Anleitung seinem Pfusch verzapft durchgeführt?
                  sunshineh
                  Ich bin bis Zeile 17 gekommen und hab dann nur Fehlermeldungen bekommen.
                  Glaubst du es wäre besser, das ganze System einfach neu aufzusetzen? Gibt es die Möglichkeit, dass ich mir Adapter oder meine erstellte VIS Oberfläche noch irgendwie sichere?
                  • S sunshineh
                    @sunshineh
                    Das heißt du hast bisher keine regelmäßigen Backups von deiner Installation?
                    Was passiert denn nun bei
                    cd /opt/iobroker
                    Bitte VOLLSTÄNDIGE Ein- und Ausgaben, inkl. login prompt. Kopier einfach die komplette Konsole.
                      @sunshineh
                      cd /opt/iobroker
                      sunshineh
                      login as:
                      pi@192.168.0.177's password:
                      Linux ioBroker-GartenHalle 5.10.17-v7+ #1414 SMP Fri Apr 30 13:18:35 BST 2021 armv7l
                      permitted by applicable law.
                      Last login: Sat May 15 11:14:35 2021 from 192.168.0.245
                      SSH is enabled and the default password for the 'pi' user has not been changed.
                      This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
                      Wi-Fi is currently blocked by rfkill.
                      Use raspi-config to set the country before use.
                      pi@ioBroker-GartenHalle:~ $ cd /opt/iobroker
                      pi@ioBroker-GartenHalle:/opt/iobroker $ sudo -H -u iobroker npm install iobroker
                      npm WARN deprecated request@2.88.0: request has been deprecated, see https://github.com/request/request/issues/3142
                      npm ERR! code 22
                      npm ERR!     /home/iobroker/.npm/_logs/2021-05-15T12_05_43_676Z-debug.log
                      • S sunshineh
                        login as:
                        npm ERR! code 22
                        @sunshineh sagte in ioBroker - keine Datenbank-Verbindung:
                        Merkwürdig.
                        Hast du da mal auf redis umgestellt?
                        Was liefert
                        iobroker status
                        Am Rande: Dein Passwort für den pi solltest du auch mal von 'raspberry' auf was individuelles ändern.
                        bringt?
                        • S sunshineh
                          login as:
                          npm ERR! code 22
                          @sunshineh
                          node/npm richtig installiert?
                          which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                            @sunshineh
                            sunshineh
                            Im Backup-Ordner habe ich folgendes gefunden
                            pi@ioBroker-GartenHalle:/opt/iobroker/backups $ dir
                            2021_04_12-22_58_14_backupiobroker.tar.gz
                            2021_05_03-00_16_22_backupiobroker.tar.gz
                            Kopier ich mir die jetzt auf meinen PC und setzt das System neu auf, oder kann ich die auch wieder einspielen?
                              Merkwürdig.
                              Was liefert
                              iobroker status
                              bringt?
                              @thomas-braun sagte in ioBroker - keine Datenbank-Verbindung:
                              Merkwürdig.
                              package-lock json?
                                sunshineh
                                pi@ioBroker-GartenHalle:/opt/iobroker $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.1.0
                                v16.1.0
                                • S sunshineh
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v16.1.0
                                  v16.1.0
                                  @sunshineh
                                  Das ist nicht die vollständige Ausgabe.
                                  Aber nodeJS16 kommt i.d.R. mit npm7 daher und das funktioniert noch nicht zusammen mit dem js-controller Setup. Da kommen deine Probleme her.
                                  Installier SAUBER nodeJS12 (max. nodeJS14). Anleitung wie das richtig geht in meiner Signatur.
                                  (Edit:) Warum hast du eigentlich im ersten Beitrag geschrieben, es sei nodeJS 12 installiert? Da ist vermutlich so einiges krumm in dem System, was nodeJS angeht. Kann aber auch zusätzlich noch durch den Murks den die Elsterforelle da immer fabriziert verfrickelt worden sein.
