  4. [gelöst] Warnung beim Das Wetter-Adapter
    6.4k
adapter problemdas wetterwarning
6 Beiträge 4 Kommentatoren 669 Aufrufe 2 Beobachtet
  • GregorSG Offline
    GregorSG Offline
    GregorS
    schrieb am zuletzt editiert von GregorS
    Hallo Zusammen,
    mir ist gerade aufgefallen, dass ich seit ein paar Tagen (ich glaube nach dem letzten Update)
    eine Liste von Warnungen vom o.g. Adapter erhalte.
    An der Einstellung des Adapters habe ich nichts verändert.
    daswetter.0	2021-05-12 18:00:12.796	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:12.713	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:12.575	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:12.483	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:12.342	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:12.215	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:12.102	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:11.934	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:11.685	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:11.590	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:11.481	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:11.330	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:11.246	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:11.158	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:11.055	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:10.924	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:10.699	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:10.556	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-12 18:00:10.368	warn	(21880) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
    Da ich den Fehler nicht deuten kann, bitte ich Euch um Hilfe.
    Gregor
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    HomoranH Dr. BakteriusD 2 Antworten Letzte Antwort
    • GregorSG GregorS
      Hallo Zusammen,
      Gregor
      @gregors sagte in Warnung beim Das Wetter-Adapter:
      ich sehe nur warn - und das auch noch nur teilweise, da die meldungen hinten abgeschnitten sind
      GregorSG 1 Antwort Letzte Antwort
        GregorSG Offline
        GregorSG Offline
        GregorS
        Ich glaube, jetzt ist es besser.
        Stimmt, ist eine Warnung und kein Fehler.
        2021-05-13 09:30:08.859 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889203562,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:08.974 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889204790,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:09.136 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889205030,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:09.270 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889205295,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:09.422 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889205527,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:09.524 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889205863,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:09.654 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889206200,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:09.791 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889206444,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:10.949 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889207044,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:11.049 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889207227,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:11.173 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889207402,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:11.352 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889207668,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:11.456 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889207984,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:11.559 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889208225,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:11.661 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889208462,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:11.864 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889208591,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:12.119 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889209021,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:12.213 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889209140,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:12.340 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889209317,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:12.478 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889209547,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:12.637 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889209667,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:12.778 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889210736,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:12.867 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889210845,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:12.995 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889210935,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:13.193 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889211198,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:13.281 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889211301,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:13.361 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889211411,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:13.486 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889211502,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:13.568 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889211618,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:13.673 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889211786,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:13.761 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889211879,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:13.836 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889211960,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:14.078 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889212216,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:14.186 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889212342,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:14.299 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889212464,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:14.385 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889212634,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:14.521 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889212721,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:14.653 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889212791,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:14.743 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889212859,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        2021-05-13 09:30:14.878 - warn: daswetter.0 (20575) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","ts":1620889212966,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"user":"system.user.admin"}
        • GregorSG GregorS
          Hallo Zusammen,
          Gregor
          Dr. BakteriusD Offline
          Dr. Bakterius
          @gregors Hatte ich unlängst auch. Ich habe daraufhin einfach alle Datenpunkte des Adapters gelöscht und neu anlegen lassen. Danach waren die Warnungen weg. Solltest du Werte aufzeichnen, muss die Aufzeichnung danach erneut aktiviert werden.
            GregorSG Offline
            GregorSG Offline
            GregorS
            @dr-bakterius
            Welche Datenpunkte hast du gelöscht.
            Geschieht das Neuanlegen automatisch?
            • GregorSG GregorS
              @dr-bakterius
              @gregors
              Bei einem Neustart des Adapters werden dann neue Datenpunkte gezogen.
