  4. Web Server Update geht nicht
    1.5k
7 Beiträge 3 Kommentatoren 713 Aufrufe 3 Beobachtet
  • J Offline
    jack99n
    Kann mir jemand Helfen ich bekomme den Web Server nicht von 3.1.0 auf 3.2.3
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.web@3.2.3',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.11
    3 info using node@v12.20.2
    4 verbose npm-session fd199d5b4a448cd9
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 warn registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EAI_AGAIN: request to https://registry.npmjs.org/iobroker.web failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
    8 warn registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
    9 http fetch GET 200 https://registry.npmjs.org/iobroker.web 138ms (from cache)
    10 silly fetchPackageMetaData error for iobroker.web@3.2.3 Unexpected end of JSON input while parsing near '...ckZbUcUg/BfCqLJSKMHNx'
    11 timing stage:rollbackFailedOptional Completed in 2ms
    12 timing stage:runTopLevelLifecycles Completed in 12135ms
    13 verbose stack SyntaxError: Unexpected end of JSON input while parsing near '...ckZbUcUg/BfCqLJSKMHNx'
    13 verbose stack     at JSON.parse (<anonymous>)
    13 verbose stack     at parseJson (/usr/lib/node_modules/npm/node_modules/json-parse-better-errors/index.js:7:17)
    13 verbose stack     at /usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/body.js:96:50
    13 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:97:5)
    14 verbose cwd /opt/iobroker
    15 verbose Linux 5.4.34-1-pve
    16 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.web@3.2.3" "--loglevel" "error" "--prefix" "/opt/iobroker"
    17 verbose node v12.20.2
    18 verbose npm  v6.14.11
    19 error Unexpected end of JSON input while parsing near '...ckZbUcUg/BfCqLJSKMHNx'
    20 verbose exit [ 1, true ]
    • J jack99n
      1 verbose cli [
      1 verbose cli ]
      @jack99n
      Wie genau gehst du vor?
      iobroker update
      iobroker upgrade
      in der Kommandozeile mal probiert?
      Zuvor
      cd /opt/iobroker
      npm cache clean --force
      kann auch helfen.
        @jack99n
        iobroker update
        iobroker upgrade
        Zuvor
        cd /opt/iobroker
        kann auch helfen.
        jack99n
        @thomas-braun Danke für deine Hilfe. Leider hat das auch nichts gebracht, und vorher habe ich es immer direkt in IoBroker versucht.
        root@iobroker-lxc:/opt/iobroker# npm cache clean --force
        npm WARN using --force I sure hope you know what you are doing.
        root@iobroker-lxc:/opt/iobroker# iobroker update
        Cannot download json from http://download.iobroker.net/sources-dist-hash.json. Error: Error: getaddrinfo EAI_AGAIN download.iobroker.net
        failed to download new sources, use cached sources
        update done
        1 verbose cli [
        1 verbose cli ]
        4 verbose npm-session 6bf6bd6c8f590318
        7 silly fetchPackageMetaData error for iobroker.web@3.2.3 request to https://registry.npmjs.org/iobroker.web failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
        8 timing stage:rollbackFailedOptional Completed in 2ms
        9 timing stage:runTopLevelLifecycles Completed in 11757ms
        10 verbose type system
        11 verbose stack FetchError: request to https://registry.npmjs.org/iobroker.web failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
        11 verbose stack     at ClientRequest.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/index.js:68:14)
        11 verbose stack     at ClientRequest.emit (events.js:314:20)
        11 verbose stack     at TLSSocket.socketErrorListener (_http_client.js:427:9)
        11 verbose stack     at TLSSocket.emit (events.js:314:20)
        11 verbose stack     at emitErrorNT (internal/streams/destroy.js:92:8)
        11 verbose stack     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
        11 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:84:21)
        12 verbose cwd /opt/iobroker
        13 verbose Linux 5.4.34-1-pve
        14 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.web@3.2.3" "--loglevel" "error" "--prefix" "/opt/iobroker"
        15 verbose node v12.20.2
        16 verbose npm  v6.14.11
        17 error code EAI_AGAIN
        18 error errno EAI_AGAIN
        19 error request to https://registry.npmjs.org/iobroker.web failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
        • J jack99n
          update done
          1 verbose cli [
          1 verbose cli ]
          @jack99n Dein Netzwerk ist 'kaputt', jedenfalls sind die externen Server für das Update nicht erreichbar.
            jack99n
            @thomas-braun Okay dann werde ich mich darum kümmern.
            • ? Offline
              Soll das so? Anzeigefehler?
              Aktualisieren oder lieber warten?
                @paul-ol
                Hat mit dem Thema hier nichts zu tun.
                Bitte eigenes Thema eröffnen und dort auch die Versionsnummer vom js-contoller reinpacken.
                82.7k
