  4. ioBrocker Neustart Änderung
    6.8k
iobrokertelegram adapterneustart
75 Beiträge 8 Kommentatoren 10.3k Aufrufe 8 Beobachtet
  • bergjetB bergjet
    #66
    @bergjet
    Und jetzt mal das Backup anstoßen.
    • bergjetB Offline
      bergjetB Offline
      bergjet
      #67
      Es steigt der Mem Verbrauch bis der pi abstürzt.
      homee, ioBroker, iMac, iPhone, Sonos, Alaxa
      • bergjetB bergjet
        #68
        @bergjet Das sollte so natürlich nicht sein.
        Da stimmt vermutlich 'tiefer' im System was nicht.
        dmesg -T
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        bergjetB 2 Antworten Letzte Antwort
          dmesg -T
          bergjetB Offline
          bergjetB Offline
          bergjet
          #69
          @thomas-braun sagte in ioBrocker Neustart Änderung:
          dmesg -T
          pi@raspberrypi:~ $ dmesg -T
          [Di Apr 20 20:13:13 2021] Booting Linux on physical CPU 0x0
          [Di Apr 20 20:13:13 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
          [Di Apr 20 20:13:13 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
          [Di Apr 20 20:13:13 2021] CPU: div instructions available: patching division code
          [Di Apr 20 20:13:13 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
          [Di Apr 20 20:13:13 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
          [Di Apr 20 20:13:13 2021] Memory policy: Data cache writealloc
          [Di Apr 20 20:13:13 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
          [Di Apr 20 20:13:13 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
          [Di Apr 20 20:13:13 2021] Zone ranges:
          [Di Apr 20 20:13:13 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
          [Di Apr 20 20:13:13 2021]   Normal   empty
          [Di Apr 20 20:13:13 2021]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
          [Di Apr 20 20:13:13 2021] Movable zone start for each node
          [Di Apr 20 20:13:13 2021] Early memory node ranges
          [Di Apr 20 20:13:13 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
          [Di Apr 20 20:13:13 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
          [Di Apr 20 20:13:13 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
          [Di Apr 20 20:13:13 2021] On node 0 totalpages: 1012736
          [Di Apr 20 20:13:13 2021]   DMA zone: 2304 pages used for memmap
          [Di Apr 20 20:13:13 2021]   DMA zone: 0 pages reserved
          [Di Apr 20 20:13:13 2021]   DMA zone: 196608 pages, LIFO batch:63
          [Di Apr 20 20:13:13 2021]   HighMem zone: 816128 pages, LIFO batch:63
          [Di Apr 20 20:13:13 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
          [Di Apr 20 20:13:13 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
          [Di Apr 20 20:13:13 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
          [Di Apr 20 20:13:13 2021] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
          [Di Apr 20 20:13:13 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:11:CE:96 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f546770a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [Di Apr 20 20:13:13 2021] Kernel parameter elevator= does not have any effect anymore.
                                    Please use sysfs to set IO scheduler for individual devices.
          [Di Apr 20 20:13:13 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
          [Di Apr 20 20:13:13 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
          [Di Apr 20 20:13:13 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
          [Di Apr 20 20:13:13 2021] software IO TLB: mapped [mem 0x0000000017cc0000-0x000000001bcc0000] (64MB)
          [Di Apr 20 20:13:13 2021] Memory: 3654940K/4050944K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133860K reserved, 262144K cma-reserved, 3264512K highmem)
          [Di Apr 20 20:13:13 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
          [Di Apr 20 20:13:13 2021] ftrace: allocating 33942 entries in 67 pages
          [Di Apr 20 20:13:13 2021] ftrace: allocated 67 pages with 3 groups
          [Di Apr 20 20:13:13 2021] rcu: Hierarchical RCU implementation.
          [Di Apr 20 20:13:13 2021] 	Rude variant of Tasks RCU enabled.
          [Di Apr 20 20:13:13 2021] 	Tracing variant of Tasks RCU enabled.
          [Di Apr 20 20:13:13 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
          [Di Apr 20 20:13:13 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
          [Di Apr 20 20:13:13 2021] GIC: Using split EOI/Deactivate mode
          [Di Apr 20 20:13:13 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
          [Di Apr 20 20:13:13 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
          [Di Apr 20 20:13:13 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
          [Di Apr 20 20:13:13 2021] bcm2835: system timer (irq = 25)
          [Di Apr 20 20:13:13 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
          [Di Apr 20 20:13:13 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
          [Di Apr 20 20:13:13 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
          [Di Apr 20 20:13:13 2021] Switching to timer-based delay loop, resolution 18ns
          [Di Apr 20 20:13:13 2021] Console: colour dummy device 80x30
          [Di Apr 20 20:13:13 2021] printk: console [tty1] enabled
          [Di Apr 20 20:13:13 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
          [Di Apr 20 20:13:13 2021] pid_max: default: 32768 minimum: 301
          [Di Apr 20 20:13:13 2021] LSM: Security Framework initializing
          [Di Apr 20 20:13:13 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
          [Di Apr 20 20:13:13 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
          [Di Apr 20 20:13:13 2021] Disabling memory control group subsystem
          [Di Apr 20 20:13:13 2021] CPU: Testing write buffer coherency: ok
          [Di Apr 20 20:13:13 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
          [Di Apr 20 20:13:13 2021] Setting up static identity map for 0x200000 - 0x20003c
          [Di Apr 20 20:13:13 2021] rcu: Hierarchical SRCU implementation.
          [Di Apr 20 20:13:13 2021] smp: Bringing up secondary CPUs ...
          [Di Apr 20 20:13:13 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
          [Di Apr 20 20:13:13 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
          [Di Apr 20 20:13:13 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
          [Di Apr 20 20:13:13 2021] smp: Brought up 1 node, 4 CPUs
          [Di Apr 20 20:13:13 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
          [Di Apr 20 20:13:13 2021] CPU: All CPU(s) started in HYP mode.
          [Di Apr 20 20:13:13 2021] CPU: Virtualization extensions available.
          [Di Apr 20 20:13:13 2021] devtmpfs: initialized
          [Di Apr 20 20:13:13 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
          [Di Apr 20 20:13:13 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
          [Di Apr 20 20:13:13 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
          [Di Apr 20 20:13:13 2021] pinctrl core: initialized pinctrl subsystem
          [Di Apr 20 20:13:13 2021] NET: Registered protocol family 16
          [Di Apr 20 20:13:13 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
          [Di Apr 20 20:13:13 2021] audit: initializing netlink subsys (disabled)
          [Di Apr 20 20:13:13 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
          [Di Apr 20 20:13:13 2021] thermal_sys: Registered thermal governor 'step_wise'
          [Di Apr 20 20:13:13 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
          [Di Apr 20 20:13:13 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
          [Di Apr 20 20:13:13 2021] Serial: AMBA PL011 UART driver
          [Di Apr 20 20:13:13 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
          [Di Apr 20 20:13:13 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
          [Di Apr 20 20:13:13 2021] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
          [Di Apr 20 20:13:13 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
          [Di Apr 20 20:13:13 2021] vgaarb: loaded
          [Di Apr 20 20:13:13 2021] SCSI subsystem initialized
          [Di Apr 20 20:13:13 2021] usbcore: registered new interface driver usbfs
          [Di Apr 20 20:13:13 2021] usbcore: registered new interface driver hub
          [Di Apr 20 20:13:13 2021] usbcore: registered new device driver usb
          [Di Apr 20 20:13:13 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
          [Di Apr 20 20:13:13 2021] clocksource: Switched to clocksource arch_sys_counter
          [Di Apr 20 20:13:14 2021] VFS: Disk quotas dquot_6.6.0
          [Di Apr 20 20:13:14 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
          [Di Apr 20 20:13:14 2021] FS-Cache: Loaded
          [Di Apr 20 20:13:14 2021] CacheFiles: Loaded
          [Di Apr 20 20:13:14 2021] NET: Registered protocol family 2
          [Di Apr 20 20:13:14 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
          [Di Apr 20 20:13:14 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
          [Di Apr 20 20:13:14 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
          [Di Apr 20 20:13:14 2021] TCP: Hash tables configured (established 8192 bind 8192)
          [Di Apr 20 20:13:14 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
          [Di Apr 20 20:13:14 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
          [Di Apr 20 20:13:14 2021] NET: Registered protocol family 1
          [Di Apr 20 20:13:14 2021] RPC: Registered named UNIX socket transport module.
          [Di Apr 20 20:13:14 2021] RPC: Registered udp transport module.
          [Di Apr 20 20:13:14 2021] RPC: Registered tcp transport module.
          [Di Apr 20 20:13:14 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
          [Di Apr 20 20:13:14 2021] PCI: CLS 0 bytes, default 64
          [Di Apr 20 20:13:14 2021] Initialise system trusted keyrings
          [Di Apr 20 20:13:14 2021] workingset: timestamp_bits=14 max_order=20 bucket_order=6
          [Di Apr 20 20:13:14 2021] zbud: loaded
          [Di Apr 20 20:13:14 2021] FS-Cache: Netfs 'nfs' registered for caching
          [Di Apr 20 20:13:14 2021] NFS: Registering the id_resolver key type
          [Di Apr 20 20:13:14 2021] Key type id_resolver registered
          [Di Apr 20 20:13:14 2021] Key type id_legacy registered
          [Di Apr 20 20:13:14 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
          [Di Apr 20 20:13:14 2021] Key type asymmetric registered
          [Di Apr 20 20:13:14 2021] Asymmetric key parser 'x509' registered
          [Di Apr 20 20:13:14 2021] bounce: pool size: 64 pages
          [Di Apr 20 20:13:14 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
          [Di Apr 20 20:13:14 2021] io scheduler mq-deadline registered
          [Di Apr 20 20:13:14 2021] io scheduler kyber registered
          [Di Apr 20 20:13:14 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
          [Di Apr 20 20:13:14 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
          [Di Apr 20 20:13:14 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
          [Di Apr 20 20:13:14 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
          [Di Apr 20 20:13:14 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
          [Di Apr 20 20:13:14 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
          [Di Apr 20 20:13:14 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
          [Di Apr 20 20:13:14 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
          [Di Apr 20 20:13:14 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
          [Di Apr 20 20:13:14 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
          [Di Apr 20 20:13:14 2021] PCI: bus0: Fast back to back transfers disabled
          [Di Apr 20 20:13:14 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
          [Di Apr 20 20:13:14 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
          [Di Apr 20 20:13:14 2021] pci 0000:01:00.0: PME# supported from D0 D3cold
          [Di Apr 20 20:13:14 2021] PCI: bus1: Fast back to back transfers disabled
          [Di Apr 20 20:13:14 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
          [Di Apr 20 20:13:14 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
          [Di Apr 20 20:13:14 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
          [Di Apr 20 20:13:14 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
          [Di Apr 20 20:13:14 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
          [Di Apr 20 20:13:14 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
          [Di Apr 20 20:13:14 2021] iproc-rng200 fe104000.rng: hwrng registered
          [Di Apr 20 20:13:14 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
          [Di Apr 20 20:13:14 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
          [Di Apr 20 20:13:14 2021] brd: module loaded
          [Di Apr 20 20:13:14 2021] loop: module loaded
          [Di Apr 20 20:13:14 2021] Loading iSCSI transport class v2.0-870.
          [Di Apr 20 20:13:14 2021] libphy: Fixed MDIO Bus: probed
          [Di Apr 20 20:13:14 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
          [Di Apr 20 20:13:14 2021] libphy: bcmgenet MII bus: probed
          [Di Apr 20 20:13:14 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
          [Di Apr 20 20:13:14 2021] usbcore: registered new interface driver r8152
          [Di Apr 20 20:13:14 2021] usbcore: registered new interface driver lan78xx
          [Di Apr 20 20:13:14 2021] usbcore: registered new interface driver smsc95xx
          [Di Apr 20 20:13:14 2021] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
          [Di Apr 20 20:13:14 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
          [Di Apr 20 20:13:14 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
          [Di Apr 20 20:13:14 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
          [Di Apr 20 20:13:14 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
          [Di Apr 20 20:13:14 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Di Apr 20 20:13:14 2021] usb usb1: Product: xHCI Host Controller
          [Di Apr 20 20:13:14 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
          [Di Apr 20 20:13:14 2021] usb usb1: SerialNumber: 0000:01:00.0
          [Di Apr 20 20:13:14 2021] hub 1-0:1.0: USB hub found
          [Di Apr 20 20:13:14 2021] hub 1-0:1.0: 1 port detected
          [Di Apr 20 20:13:14 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
          [Di Apr 20 20:13:14 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
          [Di Apr 20 20:13:14 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
          [Di Apr 20 20:13:14 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Di Apr 20 20:13:14 2021] usb usb2: Product: xHCI Host Controller
          [Di Apr 20 20:13:14 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
          [Di Apr 20 20:13:14 2021] usb usb2: SerialNumber: 0000:01:00.0
          [Di Apr 20 20:13:14 2021] hub 2-0:1.0: USB hub found
          [Di Apr 20 20:13:14 2021] hub 2-0:1.0: 4 ports detected
          [Di Apr 20 20:13:14 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
          [Di Apr 20 20:13:14 2021] dwc_otg: FIQ enabled
          [Di Apr 20 20:13:14 2021] dwc_otg: NAK holdoff enabled
          [Di Apr 20 20:13:14 2021] dwc_otg: FIQ split-transaction FSM enabled
          [Di Apr 20 20:13:14 2021] Module dwc_common_port init
          [Di Apr 20 20:13:14 2021] usbcore: registered new interface driver uas
          [Di Apr 20 20:13:14 2021] usbcore: registered new interface driver usb-storage
          [Di Apr 20 20:13:14 2021] mousedev: PS/2 mouse device common for all mice
          [Di Apr 20 20:13:14 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
          [Di Apr 20 20:13:14 2021] sdhci: Secure Digital Host Controller Interface driver
          [Di Apr 20 20:13:14 2021] sdhci: Copyright(c) Pierre Ossman
          [Di Apr 20 20:13:14 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
          [Di Apr 20 20:13:14 2021] sdhci-pltfm: SDHCI platform and OF driver helper
          [Di Apr 20 20:13:14 2021] ledtrig-cpu: registered to indicate activity on CPUs
          [Di Apr 20 20:13:14 2021] hid: raw HID events driver (C) Jiri Kosina
          [Di Apr 20 20:13:14 2021] usbcore: registered new interface driver usbhid
          [Di Apr 20 20:13:14 2021] usbhid: USB HID core driver
          [Di Apr 20 20:13:14 2021] Initializing XFRM netlink socket
          [Di Apr 20 20:13:14 2021] NET: Registered protocol family 17
          [Di Apr 20 20:13:14 2021] Key type dns_resolver registered
          [Di Apr 20 20:13:14 2021] Registering SWP/SWPB emulation handler
          [Di Apr 20 20:13:14 2021] registered taskstats version 1
          [Di Apr 20 20:13:14 2021] Loading compiled-in X.509 certificates
          [Di Apr 20 20:13:14 2021] Key type ._fscrypt registered
          [Di Apr 20 20:13:14 2021] Key type .fscrypt registered
          [Di Apr 20 20:13:14 2021] Key type fscrypt-provisioning registered
          [Di Apr 20 20:13:14 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
          [Di Apr 20 20:13:14 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
          [Di Apr 20 20:13:14 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
          [Di Apr 20 20:13:14 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
          [Di Apr 20 20:13:14 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
          [Di Apr 20 20:13:14 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
          [Di Apr 20 20:13:14 2021] of_cfs_init
          [Di Apr 20 20:13:14 2021] of_cfs_init: OK
          [Di Apr 20 20:13:14 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
          [Di Apr 20 20:13:14 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
          [Di Apr 20 20:13:14 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
          [Di Apr 20 20:13:14 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
          [Di Apr 20 20:13:14 2021] Waiting for root device PARTUUID=f546770a-02...
          [Di Apr 20 20:13:14 2021] random: fast init done
          [Di Apr 20 20:13:14 2021] mmc1: new high speed SDIO card at address 0001
          [Di Apr 20 20:13:14 2021] mmc0: new ultra high speed DDR50 SDHC card at address 0001
          [Di Apr 20 20:13:14 2021] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
          [Di Apr 20 20:13:14 2021]  mmcblk0: p1 p2
          [Di Apr 20 20:13:14 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Di Apr 20 20:13:14 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Di Apr 20 20:13:14 2021] devtmpfs: mounted
          [Di Apr 20 20:13:14 2021] Freeing unused kernel memory: 2048K
          [Di Apr 20 20:13:14 2021] Run /sbin/init as init process
          [Di Apr 20 20:13:14 2021]   with arguments:
          [Di Apr 20 20:13:14 2021]     /sbin/init
          [Di Apr 20 20:13:14 2021]   with environment:
          [Di Apr 20 20:13:14 2021]     HOME=/
          [Di Apr 20 20:13:14 2021]     TERM=linux
          [Di Apr 20 20:13:14 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
          [Di Apr 20 20:13:14 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
          [Di Apr 20 20:13:14 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
          [Di Apr 20 20:13:14 2021] usb 1-1: Product: USB2.0 Hub
          [Di Apr 20 20:13:14 2021] hub 1-1:1.0: USB hub found
          [Di Apr 20 20:13:14 2021] hub 1-1:1.0: 4 ports detected
          [Di Apr 20 20:13:15 2021] systemd[1]: System time before build time, advancing clock.
          [Di Apr 20 20:13:15 2021] NET: Registered protocol family 10
          [Di Apr 20 20:13:15 2021] Segment Routing with IPv6
          [Di Apr 20 20:13:15 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
          [Di Apr 20 20:13:15 2021] systemd[1]: Detected architecture arm.
          [Di Apr 20 20:13:15 2021] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
          [Di Apr 20 20:13:15 2021] systemd[1]: Set hostname to <raspberrypi>.
          [Di Apr 20 20:13:15 2021] usb 1-1.4: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
          [Di Apr 20 20:13:15 2021] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
          [Di Apr 20 20:13:15 2021] random: systemd: uninitialized urandom read (16 bytes read)
          [Di Apr 20 20:13:16 2021] random: systemd: uninitialized urandom read (16 bytes read)
          [Di Apr 20 20:13:16 2021] systemd[1]: Listening on Journal Socket.
          [Di Apr 20 20:13:16 2021] systemd[1]: Starting Restore / save the current clock...
          [Di Apr 20 20:13:16 2021] systemd[1]: Created slice system-getty.slice.
          [Di Apr 20 20:13:16 2021] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
          [Di Apr 20 20:13:16 2021] systemd[1]: Starting Set the console keyboard layout...
          [Di Apr 20 20:13:16 2021] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
          [Di Apr 20 20:13:16 2021] systemd[1]: Mounting RPC Pipe File System...
          [Di Apr 20 20:13:16 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          [Di Apr 20 20:13:16 2021] systemd-journald[124]: Received request to flush runtime journal from PID 1
          [Di Apr 20 20:13:17 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
          [Di Apr 20 20:13:17 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
          [Di Apr 20 20:13:17 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
          [Di Apr 20 20:13:17 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
          [Di Apr 20 20:13:17 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
          [Di Apr 20 20:13:17 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
          [Di Apr 20 20:13:17 2021] [vc_sm_connected_init]: start
          [Di Apr 20 20:13:17 2021] mc: Linux media interface: v0.10
          [Di Apr 20 20:13:17 2021] [vc_sm_connected_init]: installed successfully
          [Di Apr 20 20:13:17 2021] videodev: Linux video capture interface: v2.00
          [Di Apr 20 20:13:17 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
          [Di Apr 20 20:13:17 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
          [Di Apr 20 20:13:17 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
          [Di Apr 20 20:13:17 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
          [Di Apr 20 20:13:17 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
          [Di Apr 20 20:13:17 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
          [Di Apr 20 20:13:17 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
          [Di Apr 20 20:13:17 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
          [Di Apr 20 20:13:17 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
          [Di Apr 20 20:13:17 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
          [Di Apr 20 20:13:17 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
          [Di Apr 20 20:13:17 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
          [Di Apr 20 20:13:17 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
          [Di Apr 20 20:13:17 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
          [Di Apr 20 20:13:17 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
          [Di Apr 20 20:13:17 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
          [Di Apr 20 20:13:17 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
          [Di Apr 20 20:13:17 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
          [Di Apr 20 20:13:17 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
          [Di Apr 20 20:13:17 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
          [Di Apr 20 20:13:17 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
          [Di Apr 20 20:13:17 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
          [Di Apr 20 20:13:17 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
          [Di Apr 20 20:13:17 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
          [Di Apr 20 20:13:17 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
          [Di Apr 20 20:13:17 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [Di Apr 20 20:13:17 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
          [Di Apr 20 20:13:17 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
          [Di Apr 20 20:13:17 2021] usbcore: registered new interface driver brcmfmac
          [Di Apr 20 20:13:17 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
          [Di Apr 20 20:13:17 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
          [Di Apr 20 20:13:17 2021] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
          [Di Apr 20 20:13:17 2021] usbcore: registered new interface driver cdc_acm
          [Di Apr 20 20:13:17 2021] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
          [Di Apr 20 20:13:18 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
          [Di Apr 20 20:13:18 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
          [Di Apr 20 20:13:20 2021] uart-pl011 fe201000.serial: no DMA platform data
          [Di Apr 20 20:13:20 2021] random: crng init done
          [Di Apr 20 20:13:20 2021] random: 7 urandom warning(s) missed due to ratelimiting
          [Di Apr 20 20:13:20 2021] 8021q: 802.1Q VLAN Support v1.8
          [Di Apr 20 20:13:20 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
          [Di Apr 20 20:13:20 2021] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
          [Di Apr 20 20:13:20 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
          [Di Apr 20 20:13:20 2021] bcmgenet fd580000.ethernet eth0: Link is Down
          [Di Apr 20 20:13:23 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
          [Di Apr 20 20:13:23 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
          [Di Apr 20 20:13:25 2021] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
          [Di Apr 20 20:13:26 2021] Bluetooth: Core ver 2.22
          [Di Apr 20 20:13:26 2021] NET: Registered protocol family 31
          [Di Apr 20 20:13:26 2021] Bluetooth: HCI device and connection manager initialized
          [Di Apr 20 20:13:26 2021] Bluetooth: HCI socket layer initialized
          [Di Apr 20 20:13:26 2021] Bluetooth: L2CAP socket layer initialized
          [Di Apr 20 20:13:26 2021] Bluetooth: SCO socket layer initialized
          [Di Apr 20 20:13:26 2021] Bluetooth: HCI UART driver ver 2.3
          [Di Apr 20 20:13:26 2021] Bluetooth: HCI UART protocol H4 registered
          [Di Apr 20 20:13:26 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
          [Di Apr 20 20:13:26 2021] Bluetooth: HCI UART protocol Broadcom registered
          [Di Apr 20 20:13:27 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
          [Di Apr 20 20:13:27 2021] Bluetooth: BNEP filters: protocol multicast
          [Di Apr 20 20:13:27 2021] Bluetooth: BNEP socket layer initialized
          [Di Apr 20 22:31:45 2021] node invoked oom-killer: gfp_mask=0xcc0(GFP_KERNEL), order=0, oom_score_adj=0
          [Di Apr 20 22:31:45 2021] CPU: 3 PID: 558 Comm: node Tainted: G         C        5.10.17-v7l+ #1403
          [Di Apr 20 22:31:45 2021] Hardware name: BCM2711
          [Di Apr 20 22:31:45 2021] Backtrace:
          [Di Apr 20 22:31:45 2021] [<c0b63050>] (dump_backtrace) from [<c0b633e4>] (show_stack+0x20/0x24)
          [Di Apr 20 22:31:45 2021]  r7:ffffffff r6:00000000 r5:60000013 r4:c12e69fc
          [Di Apr 20 22:31:45 2021] [<c0b633c4>] (show_stack) from [<c0b67774>] (dump_stack+0xcc/0xf8)
          [Di Apr 20 22:31:45 2021] [<c0b676a8>] (dump_stack) from [<c0b65a04>] (dump_header+0x64/0x208)
          [Di Apr 20 22:31:45 2021]  r10:c120518c r9:00000cc0 r8:00000000 r7:c0e3709c r6:c3c6ea00 r5:c3ce0f80
          [Di Apr 20 22:31:45 2021]  r4:c3e4dc38 r3:eaf5c060
          [Di Apr 20 22:31:45 2021] [<c0b659a0>] (dump_header) from [<c03b6cd0>] (oom_kill_process+0x1b4/0x1c0)
          [Di Apr 20 22:31:45 2021]  r7:c0e3709c r6:c3e4dc38 r5:c3ce1500 r4:c3ce0f80
          [Di Apr 20 22:31:45 2021] [<c03b6b1c>] (oom_kill_process) from [<c03b7848>] (out_of_memory+0x2b8/0x390)
          [Di Apr 20 22:31:45 2021]  r7:c1208580 r6:c1205048 r5:c3ce0f80 r4:c3e4dc38
          [Di Apr 20 22:31:45 2021] [<c03b7590>] (out_of_memory) from [<c040a8bc>] (__alloc_pages_nodemask+0x7ec/0x1184)
          [Di Apr 20 22:31:45 2021]  r7:c1336790 r6:00001800 r5:00001ef8 r4:00000000
          [Di Apr 20 22:31:45 2021] [<c040a0d0>] (__alloc_pages_nodemask) from [<c09d9fd8>] (skb_page_frag_refill+0xe4/0x10c)
          [Di Apr 20 22:31:45 2021]  r10:83d7393e r9:00008766 r8:c3e4ddc0 r7:00000040 r6:c7658804 r5:00000cc0
          [Di Apr 20 22:31:45 2021]  r4:c3ce1650
          [Di Apr 20 22:31:45 2021] [<c09d9ef4>] (skb_page_frag_refill) from [<c09da84c>] (sk_page_frag_refill+0x24/0x78)
          [Di Apr 20 22:31:45 2021]  r5:c3ce1650 r4:c7658700
          [Di Apr 20 22:31:45 2021] [<c09da828>] (sk_page_frag_refill) from [<c0a8f190>] (tcp_sendmsg_locked+0x32c/0xdb4)
          [Di Apr 20 22:31:45 2021] [<c0a8ee64>] (tcp_sendmsg_locked) from [<c0a8fc50>] (tcp_sendmsg+0x38/0x4c)
          [Di Apr 20 22:31:45 2021]  r10:c893d180 r9:c7c15c00 r8:c3e4de30 r7:00000000 r6:032f5dc4 r5:c3e4ddc0
          [Di Apr 20 22:31:45 2021]  r4:c7658700
          [Di Apr 20 22:31:45 2021] [<c0a8fc18>] (tcp_sendmsg) from [<c0ac7f1c>] (inet_sendmsg+0x48/0x54)
          [Di Apr 20 22:31:45 2021]  r7:00000000 r6:032f5dc4 r5:c3e4ddc0 r4:c7658700
          [Di Apr 20 22:31:45 2021] [<c0ac7ed4>] (inet_sendmsg) from [<c09d5d40>] (sock_sendmsg+0x44/0x54)
          [Di Apr 20 22:31:45 2021]  r7:00000000 r6:00000000 r5:c893d180 r4:c3e4ddc0
          [Di Apr 20 22:31:45 2021] [<c09d5cfc>] (sock_sendmsg) from [<c09d5df4>] (sock_write_iter+0xa4/0xf8)
          [Di Apr 20 22:31:45 2021]  r5:c1205048 r4:c3e4ded4
          [Di Apr 20 22:31:45 2021] [<c09d5d50>] (sock_write_iter) from [<c04392e0>] (do_iter_readv_writev+0x13c/0x1c8)
          [Di Apr 20 22:31:45 2021]  r10:00000000 r9:00000000 r8:c1205048 r7:00000000 r6:00000000 r5:c7c15c00
          [Di Apr 20 22:31:45 2021]  r4:00000000
          [Di Apr 20 22:31:45 2021] [<c04391a4>] (do_iter_readv_writev) from [<c043a334>] (do_iter_write+0x94/0x1c4)
          [Di Apr 20 22:31:45 2021]  r10:00000013 r9:04c8af08 r8:00000000 r7:00000000 r6:c7c15c00 r5:c3e4ded4
          [Di Apr 20 22:31:45 2021] [<c043a2a0>] (do_iter_write) from [<c043a518>] (vfs_writev+0x80/0x19c)
          [Di Apr 20 22:31:45 2021]  r9:04c8af08 r8:00000000 r7:c3e4ded4 r6:032f5dc4 r5:c7c15c00 r4:c1205048
          [Di Apr 20 22:31:45 2021] [<c043a498>] (vfs_writev) from [<c043a754>] (do_writev+0x120/0x144)
          [Di Apr 20 22:31:45 2021]  r8:c7c15c00 r7:00000092 r6:00000000 r5:c7c15c01 r4:c1205048
          [Di Apr 20 22:31:45 2021] [<c043a634>] (do_writev) from [<c043bc5c>] (sys_writev+0x1c/0x20)
          [Di Apr 20 22:31:45 2021]  r10:00000092 r9:c3e4c000 r8:c0200204 r6:0000016d r5:04c8af08 r4:00000013
          [Di Apr 20 22:31:45 2021] [<c043bc40>] (sys_writev) from [<c0200040>] (ret_fast_syscall+0x0/0x28)
          [Di Apr 20 22:31:45 2021] Exception stack(0xc3e4dfa8 to 0xc3e4dff0)
          [Di Apr 20 22:31:45 2021] dfa0:                   00000013 04c8af08 0000016d 04c8af08 00000013 00000000
          [Di Apr 20 22:31:45 2021] dfc0: 00000013 04c8af08 0000016d 00000092 00000013 04c8af08 04820178 bea3d96c
          [Di Apr 20 22:31:45 2021] dfe0: 00000002 bea3d8d0 00000000 b6c54654
          [Di Apr 20 22:31:45 2021] Mem-Info:
          [Di Apr 20 22:31:45 2021] active_anon:362904 inactive_anon:581955 isolated_anon:0
                                     active_file:1309 inactive_file:1262 isolated_file:32
                                     unevictable:4 dirty:0 writeback:0
                                     slab_reclaimable:3180 slab_unreclaimable:5310
                                     mapped:1663 shmem:61 pagetables:8922 bounce:0
                                     free:8363 free_pcp:31 free_cma:1887
          [Di Apr 20 22:31:45 2021] Node 0 active_anon:1451616kB inactive_anon:2327820kB active_file:5236kB inactive_file:5048kB unevictable:16kB isolated(anon):0kB isolated(file):128kB mapped:6652kB dirty:0kB writeback:0kB shmem:244kB writeback_tmp:0kB kernel_stack:4872kB all_unreclaimable? no
          [Di Apr 20 22:31:45 2021] DMA free:28348kB min:24576kB low:28672kB high:32768kB reserved_highatomic:0KB active_anon:249892kB inactive_anon:317584kB active_file:3368kB inactive_file:668kB unevictable:0kB writepending:0kB present:786432kB managed:654620kB mlocked:0kB pagetables:1632kB bounce:0kB free_pcp:124kB local_pcp:0kB free_cma:7548kB
          [Di Apr 20 22:31:45 2021] lowmem_reserve[]: 0 0 3188 0
          [Di Apr 20 22:31:45 2021] HighMem free:5104kB min:4608kB low:25032kB high:45456kB reserved_highatomic:0KB active_anon:1201168kB inactive_anon:2010420kB active_file:2352kB inactive_file:5564kB unevictable:16kB writepending:0kB present:3264512kB managed:3264512kB mlocked:16kB pagetables:34056kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
          [Di Apr 20 22:31:45 2021] lowmem_reserve[]: 0 0 0 0
          [Di Apr 20 22:31:45 2021] DMA: 1116*4kB (UMEC) 976*8kB (UMEC) 513*16kB (UMEC) 139*32kB (UMEC) 47*64kB (UMEC) 7*128kB (UEC) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 28832kB
          [Di Apr 20 22:31:45 2021] HighMem: 204*4kB (UM) 80*8kB (UM) 42*16kB (UM) 17*32kB (UM) 9*64kB (UM) 4*128kB (UM) 3*256kB (M) 0*512kB 1*1024kB (M) 0*2048kB 0*4096kB = 5552kB
          [Di Apr 20 22:31:45 2021] 8254 total pagecache pages
          [Di Apr 20 22:31:45 2021] 5698 pages in swap cache
          [Di Apr 20 22:31:45 2021] Swap cache stats: add 27332, delete 21636, find 947/1196
          [Di Apr 20 22:31:45 2021] Free swap  = 0kB
          [Di Apr 20 22:31:45 2021] Total swap = 102396kB
          [Di Apr 20 22:31:45 2021] 1012736 pages RAM
          [Di Apr 20 22:31:45 2021] 816128 pages HighMem/MovableOnly
          [Di Apr 20 22:31:45 2021] 32953 pages reserved
          [Di Apr 20 22:31:45 2021] 65536 pages cma reserved
          [Di Apr 20 22:31:45 2021] Tasks state (memory values in pages):
          [Di Apr 20 22:31:45 2021] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
          [Di Apr 20 22:31:45 2021] [    124]     0   124     5311       54   139264      176             0 systemd-journal
          [Di Apr 20 22:31:45 2021] [    149]     0   149     4532       68    49152      149         -1000 systemd-udevd
          [Di Apr 20 22:31:45 2021] [    309]   100   309     5604       16    57344      147             0 systemd-timesyn
          [Di Apr 20 22:31:45 2021] [    342]     0   342     1987       25    36864       32             0 cron
          [Di Apr 20 22:31:45 2021] [    343]   104   343     1639        0    36864       88          -900 dbus-daemon
          [Di Apr 20 22:31:45 2021] [    344]     0   344     2686       30    45056       84             0 wpa_supplicant
          [Di Apr 20 22:31:45 2021] [    345]     0   345     6378        0    49152      101             0 rsyslogd
          [Di Apr 20 22:31:45 2021] [    346]     0   346      923        0    32768       40             0 alsactl
          [Di Apr 20 22:31:45 2021] [    349] 65534   349     1080        4    36864       39             0 thd
          [Di Apr 20 22:31:45 2021] [    352]   108   352     1574      224    36864        6             0 avahi-daemon
          [Di Apr 20 22:31:45 2021] [    372]     0   372     3261      176    49152        0             0 systemd-logind
          [Di Apr 20 22:31:45 2021] [    388]     0   388     6914       18    40960        2             0 rngd
          [Di Apr 20 22:31:45 2021] [    397]   108   397     1442       43    32768       20             0 avahi-daemon
          [Di Apr 20 22:31:45 2021] [    472]     0   472     2751       88    49152       79             0 wpa_supplicant
          [Di Apr 20 22:31:45 2021] [    486]     0   486      535       12    24576       20             0 hciattach
          [Di Apr 20 22:31:45 2021] [    491]     0   491     2384       71    45056        0             0 bluetoothd
          [Di Apr 20 22:31:45 2021] [    557]     0   557      726       67    32768       46             0 dhcpcd
          [Di Apr 20 22:31:45 2021] [    558]  1001   558   643071   596615  5562368    13470             0 node
          [Di Apr 20 22:31:45 2021] [    564]     0   564     1077       22    36864        0             0 agetty
          [Di Apr 20 22:31:45 2021] [    565]     0   565     2682      138    45056        0         -1000 sshd
          [Di Apr 20 22:31:45 2021] [    632]  1001   632    46061    13710   864256      379             0 node
          [Di Apr 20 22:31:45 2021] [    647]  1001   647    41241     8100   704512       32             0 node
          [Di Apr 20 22:31:45 2021] [    711]  1001   711    38237     5551   593920        0             0 node
          [Di Apr 20 22:31:45 2021] [    755]  1001   755    38229     5649   610304        3             0 node
          [Di Apr 20 22:31:45 2021] [    772]  1001   772    38012     5639   589824        0             0 node
          [Di Apr 20 22:31:45 2021] [    787]  1001   787    38025     5543   589824        2             0 node
          [Di Apr 20 22:31:45 2021] [    802]  1001   802    38913     6805   659456        8             0 node
          [Di Apr 20 22:31:45 2021] [    817]  1001   817    40404     7011   589824       32             0 node
          [Di Apr 20 22:31:45 2021] [    832]  1001   832    39928     6949   655360        0             0 node
          [Di Apr 20 22:31:45 2021] [    847]  1001   847    42624    12382   745472       30             0 node
          [Di Apr 20 22:31:45 2021] [    862]  1001   862    41718    10028   724992       68             0 node
          [Di Apr 20 22:31:45 2021] [    877]  1001   877    39760     6754   618496        5             0 node
          [Di Apr 20 22:31:45 2021] [    922]  1001   922    43705    11621   749568       57             0 node
          [Di Apr 20 22:31:45 2021] [    945]  1001   945    41379     8669   696320        0             0 node
          [Di Apr 20 22:31:45 2021] [   1460]  1001  1460    57962    26164  1097728       19             0 node
          [Di Apr 20 22:31:45 2021] [   1470]  1001  1470    40759     7361   692224        0             0 node
          [Di Apr 20 22:31:45 2021] [   1647]  1001  1647    43662    12119   876544       65             0 node
          [Di Apr 20 22:31:45 2021] [   1668]  1001  1668    39479     6046   593920        2             0 node
          [Di Apr 20 22:31:45 2021] [   1845]  1001  1845    37536     4401   573440        4             0 node
          [Di Apr 20 22:31:45 2021] [   1862]  1001  1862    38534     5929   610304       19             0 node
          [Di Apr 20 22:31:45 2021] [   1869]  1001  1869    55650    23784  1196032       10             0 node
          [Di Apr 20 22:31:45 2021] [   2048]  1001  2048    39085     7071   692224        2             0 node
          [Di Apr 20 22:31:45 2021] [   2070]  1001  2070    38431     5096   598016       10             0 node
          [Di Apr 20 22:31:45 2021] [   2258]  1001  2258    37530     5849   593920        0             0 node
          [Di Apr 20 22:31:45 2021] [   2309]  1001  2309    40395     7580   667648        0             0 node
          [Di Apr 20 22:31:45 2021] [   2489]  1001  2489    38403     6455   634880       12             0 node
          [Di Apr 20 22:31:45 2021] [   2514]  1001  2514    37723     5057   585728        6             0 node
          [Di Apr 20 22:31:45 2021] [   2701]  1001  2701    38211     5261   577536        6             0 node
          [Di Apr 20 22:31:45 2021] [   2726]  1001  2726    38871     6284   626688        2             0 node
          [Di Apr 20 22:31:45 2021] [   2919]  1001  2919    43033     8601   684032       34             0 node
          [Di Apr 20 22:31:45 2021] [   2939]  1001  2939    37766     5072   581632        7             0 node
          [Di Apr 20 22:31:45 2021] [   3129]  1001  3129    38499     5773   618496        0             0 node
          [Di Apr 20 22:31:45 2021] [   3147]  1001  3147    37914     4934   544768        0             0 node
          [Di Apr 20 22:31:45 2021] [   3354]  1001  3354    42414     9029   696320        0             0 node
          [Di Apr 20 22:31:45 2021] [   3547]  1001  3547    37804     5151   573440       86             0 node
          [Di Apr 20 22:31:45 2021] [   3561]  1001  3561    41124     9209   745472       24             0 node
          [Di Apr 20 22:31:45 2021] [   3757]  1001  3757    41762     8624   749568        0             0 node
          [Di Apr 20 22:31:45 2021] [   3773]  1001  3773    37112     4642   565248      339             0 node
          [Di Apr 20 22:31:45 2021] [   3994]  1001  3994    42394     7821   770048     2258             0 node
          [Di Apr 20 22:31:45 2021] [   4012]  1001  4012    37446     2156   577536     2672             0 node
          [Di Apr 20 22:31:45 2021] [   4213]  1001  4213    44240     9490   811008     2497             0 node
          [Di Apr 20 22:31:45 2021] [  10973]     0 10973     3060      211    49152        0             0 sshd
          [Di Apr 20 22:31:45 2021] [  11169]  1000 11169     3651      212    53248        0             0 systemd
          [Di Apr 20 22:31:45 2021] [  11170]  1000 11170     8805       81    65536      339             0 (sd-pam)
          [Di Apr 20 22:31:45 2021] [  11183]  1000 11183     3060      196    45056        2             0 sshd
          [Di Apr 20 22:31:45 2021] [  11184]  1000 11184     2123      235    49152        0             0 bash
          [Di Apr 20 22:31:45 2021] [   2336]  1001  2336    44540    12010   856064        0             0 node
          [Di Apr 20 22:31:45 2021] [  31775]  1000 31775     1919       39    40960        0             0 iobroker
          [Di Apr 20 22:31:45 2021] [  31777]     0 31777     2507       91    49152        0             0 sudo
          [Di Apr 20 22:31:45 2021] [  31778]  1001 31778    48966    20332   901120        0             0 node
          [Di Apr 20 22:31:45 2021] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=558,uid=1001
          [Di Apr 20 22:31:45 2021] Out of memory: Killed process 558 (node) total-vm:2572284kB, anon-rss:2381812kB, file-rss:4636kB, shmem-rss:0kB, UID:1001 pgtables:5432kB oom_score_adj:0
          [Di Apr 20 22:31:45 2021] oom_reaper: reaped process 558 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
          [Mi Apr 21 02:01:15 2021] node invoked oom-killer: gfp_mask=0x400dc0(GFP_KERNEL_ACCOUNT|__GFP_ZERO), order=1, oom_score_adj=0
          [Mi Apr 21 02:01:15 2021] CPU: 0 PID: 11078 Comm: node Tainted: G         C        5.10.17-v7l+ #1403
          [Mi Apr 21 02:01:15 2021] Hardware name: BCM2711
          [Mi Apr 21 02:01:15 2021] Backtrace:
          [Mi Apr 21 02:01:15 2021] [<c0b63050>] (dump_backtrace) from [<c0b633e4>] (show_stack+0x20/0x24)
          [Mi Apr 21 02:01:15 2021]  r7:ffffffff r6:00000000 r5:60000013 r4:c12e69fc
          [Mi Apr 21 02:01:15 2021] [<c0b633c4>] (show_stack) from [<c0b67774>] (dump_stack+0xcc/0xf8)
          [Mi Apr 21 02:01:15 2021] [<c0b676a8>] (dump_stack) from [<c0b65a04>] (dump_header+0x64/0x208)
          [Mi Apr 21 02:01:15 2021]  r10:c120518c r9:00400dc0 r8:00000001 r7:c0e3709c r6:c8d03600 r5:c7f08f80
          [Mi Apr 21 02:01:15 2021]  r4:c8e0de28 r3:eaf5c060
          [Mi Apr 21 02:01:15 2021] [<c0b659a0>] (dump_header) from [<c03b6cd0>] (oom_kill_process+0x1b4/0x1c0)
          [Mi Apr 21 02:01:15 2021]  r7:c0e3709c r6:c8e0de28 r5:c7f09500 r4:c7f08f80
          [Mi Apr 21 02:01:15 2021] [<c03b6b1c>] (oom_kill_process) from [<c03b7848>] (out_of_memory+0x2b8/0x390)
          [Mi Apr 21 02:01:15 2021]  r7:c1208580 r6:c1205048 r5:c7f08f80 r4:c8e0de28
          [Mi Apr 21 02:01:15 2021] [<c03b7590>] (out_of_memory) from [<c040a8bc>] (__alloc_pages_nodemask+0x7ec/0x1184)
          [Mi Apr 21 02:01:15 2021]  r7:c1336790 r6:00000001 r5:00000001 r4:00000000
          [Mi Apr 21 02:01:15 2021] [<c040a0d0>] (__alloc_pages_nodemask) from [<c021ddd4>] (copy_process+0x2d0/0x1908)
          [Mi Apr 21 02:01:15 2021]  r10:c8e0df50 r9:00000000 r8:ffffffff r7:c816dd00 r6:d72bbe00 r5:c1205048
          [Mi Apr 21 02:01:15 2021]  r4:01200000
          [Mi Apr 21 02:01:15 2021] [<c021db04>] (copy_process) from [<c021f654>] (kernel_clone+0xcc/0x4a0)
          [Mi Apr 21 02:01:15 2021]  r10:00000078 r9:c8e0c000 r8:c8e0df50 r7:00000078 r6:01200000 r5:c1205048
          [Mi Apr 21 02:01:15 2021]  r4:00000000
          [Mi Apr 21 02:01:15 2021] [<c021f588>] (kernel_clone) from [<c021fd1c>] (sys_clone+0x7c/0x98)
          [Mi Apr 21 02:01:15 2021]  r10:00000078 r9:c8e0c000 r8:c0200204 r7:00000078 r6:00000003 r5:eaf5c060
          [Mi Apr 21 02:01:15 2021]  r4:c1205048
          [Mi Apr 21 02:01:15 2021] [<c021fca0>] (sys_clone) from [<c0200040>] (ret_fast_syscall+0x0/0x28)
          [Mi Apr 21 02:01:15 2021] Exception stack(0xc8e0dfa8 to 0xc8e0dff0)
          [Mi Apr 21 02:01:15 2021] dfa0:                   b6f84708 00000001 01200011 00000000 00000000 00000000
          [Mi Apr 21 02:01:15 2021] dfc0: b6f84708 00000001 00000003 00000078 00000001 b6cfc000 b6f84b60 befdc7f4
          [Mi Apr 21 02:01:15 2021] dfe0: b6f846a0 befdc6c0 b6c51854 b6c51788
          [Mi Apr 21 02:01:15 2021]  r5:00000001 r4:b6f84708
          [Mi Apr 21 02:01:15 2021] Mem-Info:
          [Mi Apr 21 02:01:15 2021] active_anon:19059 inactive_anon:885013 isolated_anon:64
                                     active_file:12404 inactive_file:24758 isolated_file:0
                                     unevictable:4 dirty:6 writeback:160
                                     slab_reclaimable:3457 slab_unreclaimable:5616
                                     mapped:9402 shmem:324 pagetables:9150 bounce:0
                                     free:14579 free_pcp:0 free_cma:93
          [Mi Apr 21 02:01:15 2021] Node 0 active_anon:76236kB inactive_anon:3540052kB active_file:49616kB inactive_file:99032kB unevictable:16kB isolated(anon):256kB isolated(file):0kB mapped:37608kB dirty:24kB writeback:640kB shmem:1296kB writeback_tmp:0kB kernel_stack:5008kB all_unreclaimable? no
          [Mi Apr 21 02:01:15 2021] DMA free:44704kB min:53248kB low:57344kB high:61440kB reserved_highatomic:4096KB active_anon:12288kB inactive_anon:531104kB active_file:4920kB inactive_file:7608kB unevictable:0kB writepending:664kB present:786432kB managed:654620kB mlocked:0kB pagetables:1760kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:372kB
          [Mi Apr 21 02:01:15 2021] lowmem_reserve[]: 0 0 3188 0
          [Mi Apr 21 02:01:15 2021] HighMem free:13612kB min:512kB low:20936kB high:41360kB reserved_highatomic:0KB active_anon:63596kB inactive_anon:3009248kB active_file:44968kB inactive_file:91824kB unevictable:16kB writepending:0kB present:3264512kB managed:3264512kB mlocked:16kB pagetables:34840kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
          [Mi Apr 21 02:01:15 2021] lowmem_reserve[]: 0 0 0 0
          [Mi Apr 21 02:01:15 2021] DMA: 2051*4kB (UMEC) 990*8kB (UMEC) 583*16kB (UMEC) 292*32kB (UEC) 86*64kB (UMEC) 4*128kB (UE) 0*256kB 0*512kB 0*1024kB 0*2048kB 1*4096kB (H) = 44908kB
          [Mi Apr 21 02:01:15 2021] HighMem: 306*4kB (UM) 344*8kB (UM) 38*16kB (UM) 14*32kB (U) 5*64kB (UM) 1*128kB (M) 3*256kB (UM) 2*512kB (UM) 1*1024kB (U) 1*2048kB (M) 1*4096kB (M) = 14440kB
          [Mi Apr 21 02:01:15 2021] 26070 total pagecache pages
          [Mi Apr 21 02:01:15 2021] 1479 pages in swap cache
          [Mi Apr 21 02:01:15 2021] Swap cache stats: add 84707, delete 83231, find 5894/8802
          [Mi Apr 21 02:01:15 2021] Free swap  = 0kB
          [Mi Apr 21 02:01:15 2021] Total swap = 102396kB
          [Mi Apr 21 02:01:15 2021] 1012736 pages RAM
          [Mi Apr 21 02:01:15 2021] 816128 pages HighMem/MovableOnly
          [Mi Apr 21 02:01:15 2021] 32953 pages reserved
          [Mi Apr 21 02:01:15 2021] 65536 pages cma reserved
          [Mi Apr 21 02:01:15 2021] Tasks state (memory values in pages):
          [Mi Apr 21 02:01:15 2021] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
          [Mi Apr 21 02:01:15 2021] [    124]     0   124     5312      874   143360      168             0 systemd-journal
          [Mi Apr 21 02:01:15 2021] [    149]     0   149     4532      137    49152      192         -1000 systemd-udevd
          [Mi Apr 21 02:01:15 2021] [    309]   100   309     5604      384    57344      147             0 systemd-timesyn
          [Mi Apr 21 02:01:15 2021] [    342]     0   342     1987      182    36864       31             0 cron
          [Mi Apr 21 02:01:15 2021] [    343]   104   343     1639      197    36864       72          -900 dbus-daemon
          [Mi Apr 21 02:01:15 2021] [    344]     0   344     2686       74    45056       89             0 wpa_supplicant
          [Mi Apr 21 02:01:15 2021] [    345]     0   345     6378      395    49152      179             0 rsyslogd
          [Mi Apr 21 02:01:15 2021] [    346]     0   346      923       20    32768       46             0 alsactl
          [Mi Apr 21 02:01:15 2021] [    349] 65534   349     1080       50    36864       39             0 thd
          [Mi Apr 21 02:01:15 2021] [    352]   108   352     1640      689    36864       30             0 avahi-daemon
          [Mi Apr 21 02:01:15 2021] [    372]     0   372     3261      377    49152      135             0 systemd-logind
          [Mi Apr 21 02:01:15 2021] [    388]     0   388     6914       73    40960       24             0 rngd
          [Mi Apr 21 02:01:15 2021] [    397]   108   397     1442        4    32768       59             0 avahi-daemon
          [Mi Apr 21 02:01:15 2021] [    472]     0   472     2751       99    49152      136             0 wpa_supplicant
          [Mi Apr 21 02:01:15 2021] [    486]     0   486      535        1    24576       31             0 hciattach
          [Mi Apr 21 02:01:15 2021] [    491]     0   491     2384        0    45056       93             0 bluetoothd
          [Mi Apr 21 02:01:15 2021] [    557]     0   557      726        8    32768       93             0 dhcpcd
          [Mi Apr 21 02:01:15 2021] [    564]     0   564     1077        5    36864       17             0 agetty
          [Mi Apr 21 02:01:15 2021] [    565]     0   565     2682       57    45056       81         -1000 sshd
          [Mi Apr 21 02:01:15 2021] [  10973]     0 10973     3060       19    49152      192             0 sshd
          [Mi Apr 21 02:01:15 2021] [  11169]  1000 11169     3651        0    53248      227             0 systemd
          [Mi Apr 21 02:01:15 2021] [  11170]  1000 11170     8805       30    65536      390             0 (sd-pam)
          [Mi Apr 21 02:01:15 2021] [  11183]  1000 11183     3060      160    45056      173             0 sshd
          [Mi Apr 21 02:01:15 2021] [  11184]  1000 11184     2123      569    49152      111             0 bash
          [Mi Apr 21 02:01:15 2021] [   9699]  1001  9699   580136   548590  5402624     3114             0 node
          [Mi Apr 21 02:01:15 2021] [   9717]  1001  9717    45631    12220   851968     8096             0 node
          [Mi Apr 21 02:01:15 2021] [   9732]  1001  9732    41115    10748   663552     3599             0 node
          [Mi Apr 21 02:01:15 2021] [   9747]  1001  9747    44844    13230   909312     6118             0 node
          [Mi Apr 21 02:01:15 2021] [   9777]  1001  9777    37798    11340   593920        4             0 node
          [Mi Apr 21 02:01:15 2021] [   9792]  1001  9792    37821    11446   585728        5             0 node
          [Mi Apr 21 02:01:15 2021] [   9808]  1001  9808    37449    11208   565248        3             0 node
          [Mi Apr 21 02:01:15 2021] [   9823]  1001  9823    37608    11178   577536        3             0 node
          [Mi Apr 21 02:01:15 2021] [   9838]  1001  9838    38349    12680   614400        5             0 node
          [Mi Apr 21 02:01:15 2021] [   9853]  1001  9853    40811    12834   581632        6             0 node
          [Mi Apr 21 02:01:15 2021] [   9868]  1001  9868    39188    12920   634880        1             0 node
          [Mi Apr 21 02:01:15 2021] [   9883]  1001  9883    42782    18382   753664       14             0 node
          [Mi Apr 21 02:01:15 2021] [   9898]  1001  9898    41841    16642   724992        9             0 node
          [Mi Apr 21 02:01:15 2021] [   9913]  1001  9913    39283    13041   634880        5             0 node
          [Mi Apr 21 02:01:15 2021] [   9959]  1001  9959    43924    18795   700416        7             0 node
          [Mi Apr 21 02:01:15 2021] [  10041]  1001 10041    40598    15194   663552        1             0 node
          [Mi Apr 21 02:01:15 2021] [  10492]  1001 10492    57467    31974  1118208       29             0 node
          [Mi Apr 21 02:01:15 2021] [  10507]  1001 10507    40876    14051   688128        1             0 node
          [Mi Apr 21 02:01:15 2021] [  10679]  1001 10679    43756    18573   819200       15             0 node
          [Mi Apr 21 02:01:15 2021] [  10692]  1001 10692    39276    12379   589824       13             0 node
          [Mi Apr 21 02:01:15 2021] [  10867]  1001 10867    37884    11510   569344        4             0 node
          [Mi Apr 21 02:01:15 2021] [  10885]  1001 10885    55834    31338  1216512        3             0 node
          [Mi Apr 21 02:01:15 2021] [  10892]  1001 10892    38645    12071   630784        1             0 node
          [Mi Apr 21 02:01:15 2021] [  11078]  1001 11078    39442    13543   671744        4             0 node
          [Mi Apr 21 02:01:15 2021] [  11100]  1001 11100    37874    11266   557056        7             0 node
          [Mi Apr 21 02:01:15 2021] [  11291]  1001 11291    37235    11865   585728        1             0 node
          [Mi Apr 21 02:01:15 2021] [  11333]  1001 11333    40994    14231   720896        5             0 node
          [Mi Apr 21 02:01:15 2021] [  11514]  1001 11514    38240    12418   618496        1             0 node
          [Mi Apr 21 02:01:15 2021] [  11533]  1001 11533    37873    11775   606208        6             0 node
          [Mi Apr 21 02:01:15 2021] [  11716]  1001 11716    37871    11172   593920       16             0 node
          [Mi Apr 21 02:01:15 2021] [  11745]  1001 11745    38042    11783   618496        7             0 node
          [Mi Apr 21 02:01:15 2021] [  11930]  1001 11930    44351    15997   724992        9             0 node
          [Mi Apr 21 02:01:15 2021] [  11949]  1001 11949    37971    11545   585728        3             0 node
          [Mi Apr 21 02:01:15 2021] [  12135]  1001 12135    38192    12388   573440        4             0 node
          [Mi Apr 21 02:01:15 2021] [  12153]  1001 12153    37839    11134   585728        0             0 node
          [Mi Apr 21 02:01:15 2021] [  12375]  1001 12375    43826    18341   659456        7             0 node
          [Mi Apr 21 02:01:15 2021] [  12572]  1001 12572    40755    15434   696320       31             0 node
          [Mi Apr 21 02:01:15 2021] [  12759]  1001 12759    41747    14928   724992        0             0 node
          [Mi Apr 21 02:01:15 2021] [  12776]  1001 12776    37327    11279   585728        0             0 node
          [Mi Apr 21 02:01:15 2021] [  12988]  1001 12988    42062    16520   757760        5             0 node
          [Mi Apr 21 02:01:15 2021] [  13007]  1001 13007    37702    11240   585728        2             0 node
          [Mi Apr 21 02:01:15 2021] [  13203]  1001 13203    43800    19029   806912        8             0 node
          [Mi Apr 21 02:01:15 2021] [  13403]  1001 13403    37688    11717   581632        0             0 node
          [Mi Apr 21 02:01:15 2021] [  26289]  1001 26289    40403    17231   634880        2             0 node
          [Mi Apr 21 02:01:15 2021] [  26488]  1001 26488    38619    17186   638976        5             0 node
          [Mi Apr 21 02:01:15 2021] [  26503]  1001 26503    64663    47336  1060864      116             0 node
          [Mi Apr 21 02:01:15 2021] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=9699,uid=1001
          [Mi Apr 21 02:01:15 2021] Out of memory: Killed process 9699 (node) total-vm:2320544kB, anon-rss:2166496kB, file-rss:27864kB, shmem-rss:0kB, UID:1001 pgtables:5276kB oom_score_adj:0
          [Mi Apr 21 02:01:16 2021] oom_reaper: reaped process 9699 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
          [Mi Apr 21 11:01:43 2021] htop invoked oom-killer: gfp_mask=0x40cd0(GFP_KERNEL|__GFP_COMP|__GFP_RECLAIMABLE), order=0, oom_score_adj=0
          [Mi Apr 21 11:01:43 2021] CPU: 0 PID: 26752 Comm: htop Tainted: G         C        5.10.17-v7l+ #1403
          [Mi Apr 21 11:01:43 2021] Hardware name: BCM2711
          [Mi Apr 21 11:01:43 2021] Backtrace:
          [Mi Apr 21 11:01:43 2021] [<c0b63050>] (dump_backtrace) from [<c0b633e4>] (show_stack+0x20/0x24)
          [Mi Apr 21 11:01:43 2021]  r7:ffffffff r6:00000000 r5:60000113 r4:c12e69fc
          [Mi Apr 21 11:01:43 2021] [<c0b633c4>] (show_stack) from [<c0b67774>] (dump_stack+0xcc/0xf8)
          [Mi Apr 21 11:01:43 2021] [<c0b676a8>] (dump_stack) from [<c0b65a04>] (dump_header+0x64/0x208)
          [Mi Apr 21 11:01:43 2021]  r10:c120518c r9:00040cd0 r8:00000000 r7:c0e3709c r6:c7795800 r5:c8101f00
          [Mi Apr 21 11:01:43 2021]  r4:c4cf1b18 r3:eaf5c060
          [Mi Apr 21 11:01:43 2021] [<c0b659a0>] (dump_header) from [<c03b6cd0>] (oom_kill_process+0x1b4/0x1c0)
          [Mi Apr 21 11:01:43 2021]  r7:c0e3709c r6:c4cf1b18 r5:c8102480 r4:c8101f00
          [Mi Apr 21 11:01:43 2021] [<c03b6b1c>] (oom_kill_process) from [<c03b7848>] (out_of_memory+0x2b8/0x390)
          [Mi Apr 21 11:01:43 2021]  r7:c1208580 r6:c1205048 r5:c8101f00 r4:c4cf1b18
          [Mi Apr 21 11:01:43 2021] [<c03b7590>] (out_of_memory) from [<c040a8bc>] (__alloc_pages_nodemask+0x7ec/0x1184)
          [Mi Apr 21 11:01:43 2021]  r7:c1336790 r6:00001000 r5:00002566 r4:00000000
          [Mi Apr 21 11:01:43 2021] [<c040a0d0>] (__alloc_pages_nodemask) from [<c041d6a4>] (allocate_slab+0x290/0x334)
          [Mi Apr 21 11:01:43 2021]  r10:ffffffff r9:00000001 r8:00000000 r7:00000400 r6:00000009 r5:c18c7b40
          [Mi Apr 21 11:01:43 2021]  r4:00000000
          [Mi Apr 21 11:01:43 2021] [<c041d414>] (allocate_slab) from [<c04208c8>] (___slab_alloc.constprop.28+0x398/0x55c)
          [Mi Apr 21 11:01:43 2021]  r10:c18c7b40 r9:c04dc224 r8:00000000 r7:eff3e688 r6:c1800200 r5:c18c7b40
          [Mi Apr 21 11:01:43 2021]  r4:00000000 r3:003beee0
          [Mi Apr 21 11:01:43 2021] [<c0420530>] (___slab_alloc.constprop.28) from [<c0420afc>] (__slab_alloc.constprop.27+0x70/0x80)
          [Mi Apr 21 11:01:43 2021]  r10:c4cf1e10 r9:c04dc224 r8:eff3e688 r7:c04dc224 r6:00000cc0 r5:c18c7b40
          [Mi Apr 21 11:01:43 2021]  r4:60000013
          [Mi Apr 21 11:01:43 2021] [<c0420a8c>] (__slab_alloc.constprop.27) from [<c04226e8>] (kmem_cache_alloc+0x51c/0x568)
          [Mi Apr 21 11:01:43 2021]  r8:00000cc0 r7:c1205814 r6:00000000 r5:00000000 r4:c18c7b40
          [Mi Apr 21 11:01:43 2021] [<c04221cc>] (kmem_cache_alloc) from [<c04dc224>] (proc_alloc_inode+0x28/0x60)
          [Mi Apr 21 11:01:43 2021]  r10:c4cf1e10 r9:00000000 r8:cdff3e00 r7:cdff3e00 r6:c0c110c0 r5:c2a8c400
          [Mi Apr 21 11:01:43 2021]  r4:c0c11b38
          [Mi Apr 21 11:01:43 2021] [<c04dc1fc>] (proc_alloc_inode) from [<c045a334>] (alloc_inode+0x2c/0xac)
          [Mi Apr 21 11:01:43 2021] [<c045a308>] (alloc_inode) from [<c045cda4>] (new_inode_pseudo+0x18/0x5c)
          [Mi Apr 21 11:01:43 2021]  r7:cdff3e00 r6:00008124 r5:c1205048 r4:c0c11b38
          [Mi Apr 21 11:01:43 2021] [<c045cd8c>] (new_inode_pseudo) from [<c045ce04>] (new_inode+0x1c/0x30)
          [Mi Apr 21 11:01:43 2021]  r5:c1205048 r4:c0c11b38
          [Mi Apr 21 11:01:43 2021] [<c045cde8>] (new_inode) from [<c04e1e7c>] (proc_pid_make_inode+0x34/0x13c)
          [Mi Apr 21 11:01:43 2021] [<c04e1e48>] (proc_pid_make_inode) from [<c04e22a0>] (proc_pident_instantiate+0x2c/0xa4)
          [Mi Apr 21 11:01:43 2021]  r8:cdff3e00 r7:cdff3e00 r6:c833d990 r5:c0c11b38 r4:c0c11b38
          [Mi Apr 21 11:01:43 2021] [<c04e2274>] (proc_pident_instantiate) from [<c04e23ec>] (proc_pident_lookup+0xd4/0xec)
          [Mi Apr 21 11:01:43 2021]  r7:c833d990 r6:c0c11e50 r5:00000004 r4:c0c11b38
          [Mi Apr 21 11:01:43 2021] [<c04e2318>] (proc_pident_lookup) from [<c04e24b4>] (proc_tgid_base_lookup+0x2c/0x30)
          [Mi Apr 21 11:01:43 2021]  r9:00000000 r8:c4cf1ef0 r7:c3552f00 r6:c833d990 r5:c3a60770 r4:c3a19c28
          [Mi Apr 21 11:01:43 2021] [<c04e2488>] (proc_tgid_base_lookup) from [<c044cb0c>] (path_openat+0x5ac/0x1014)
          [Mi Apr 21 11:01:43 2021] [<c044c560>] (path_openat) from [<c044ee84>] (do_filp_open+0x84/0xec)
          [Mi Apr 21 11:01:43 2021]  r10:ffffff9c r9:00000000 r8:00000001 r7:c4cf1ef0 r6:c4cf1e10 r5:c1205048
          [Mi Apr 21 11:01:43 2021]  r4:c1205048
          [Mi Apr 21 11:01:43 2021] [<c044ee00>] (do_filp_open) from [<c0437120>] (do_sys_openat2+0x234/0x2f8)
          [Mi Apr 21 11:01:43 2021]  r8:00000000 r7:befdcb70 r6:c74db000 r5:c1205048 r4:00000004
          [Mi Apr 21 11:01:43 2021] [<c0436eec>] (do_sys_openat2) from [<c04389ec>] (do_sys_open+0x98/0xd4)
          [Mi Apr 21 11:01:43 2021]  r10:00000142 r9:c4cf0000 r8:befdcb70 r7:00000000 r6:00000000 r5:ffffff9c
          [Mi Apr 21 11:01:43 2021] [<c0438954>] (do_sys_open) from [<c0438a70>] (sys_openat+0x1c/0x20)
          [Mi Apr 21 11:01:43 2021]  r8:c0200204 r7:00000142 r6:0000013c r5:0003ccb8 r4:b6efe4e0
          [Mi Apr 21 11:01:43 2021] [<c0438a54>] (sys_openat) from [<c0200040>] (ret_fast_syscall+0x0/0x28)
          [Mi Apr 21 11:01:43 2021] Exception stack(0xc4cf1fa8 to 0xc4cf1ff0)
          [Mi Apr 21 11:01:43 2021] 1fa0:                   b6efe4e0 0003ccb8 ffffff9c befdcb70 00000000 00000000
          [Mi Apr 21 11:01:43 2021] 1fc0: b6efe4e0 0003ccb8 0000013c 00000142 001995b8 befdc908 00000000 00081378
          [Mi Apr 21 11:01:43 2021] 1fe0: b6dda000 befdc840 00025f64 b6d552f0
          [Mi Apr 21 11:01:43 2021] Mem-Info:
          [Mi Apr 21 11:01:43 2021] active_anon:434833 inactive_anon:501163 isolated_anon:0
                                     active_file:1766 inactive_file:1717 isolated_file:0
                                     unevictable:4 dirty:115 writeback:342
                                     slab_reclaimable:3131 slab_unreclaimable:5601
                                     mapped:2326 shmem:205 pagetables:9235 bounce:0
                                     free:14362 free_pcp:121 free_cma:4496
          [Mi Apr 21 11:01:43 2021] Node 0 active_anon:1739332kB inactive_anon:2004652kB active_file:7088kB inactive_file:6904kB unevictable:16kB isolated(anon):0kB isolated(file):0kB mapped:9288kB dirty:460kB writeback:1368kB shmem:820kB writeback_tmp:0kB kernel_stack:5056kB all_unreclaimable? no
          [Mi Apr 21 11:01:43 2021] DMA free:36612kB min:16384kB low:20480kB high:24576kB reserved_highatomic:4096KB active_anon:236824kB inactive_anon:316712kB active_file:1032kB inactive_file:680kB unevictable:0kB writepending:848kB present:786432kB managed:654620kB mlocked:0kB pagetables:1676kB bounce:0kB free_pcp:484kB local_pcp:132kB free_cma:17984kB
          [Mi Apr 21 11:01:43 2021] lowmem_reserve[]: 0 0 3188 0
          [Mi Apr 21 11:01:43 2021] HighMem free:20908kB min:512kB low:20936kB high:41360kB reserved_highatomic:0KB active_anon:1502508kB inactive_anon:1687940kB active_file:6440kB inactive_file:5824kB unevictable:16kB writepending:980kB present:3264512kB managed:3264512kB mlocked:16kB pagetables:35264kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
          [Mi Apr 21 11:01:43 2021] lowmem_reserve[]: 0 0 0 0
          [Mi Apr 21 11:01:43 2021] DMA: 637*4kB (UEC) 450*8kB (UEC) 295*16kB (UEC) 69*32kB (MEC) 22*64kB (EC) 13*128kB (UC) 38*256kB (UC) 7*512kB (C) 3*1024kB (C) 0*2048kB 1*4096kB (H) = 36628kB
          [Mi Apr 21 11:01:43 2021] HighMem: 199*4kB (U) 106*8kB (UM) 60*16kB (U) 16*32kB (U) 10*64kB (UM) 16*128kB (UM) 7*256kB (UM) 12*512kB (UM) 3*1024kB (UM) 2*2048kB (M) 0*4096kB = 20908kB
          [Mi Apr 21 11:01:43 2021] 4845 total pagecache pages
          [Mi Apr 21 11:01:43 2021] 1312 pages in swap cache
          [Mi Apr 21 11:01:43 2021] Swap cache stats: add 163718, delete 162409, find 24139/33929
          [Mi Apr 21 11:01:43 2021] Free swap  = 0kB
          [Mi Apr 21 11:01:43 2021] Total swap = 102396kB
          [Mi Apr 21 11:01:43 2021] 1012736 pages RAM
          [Mi Apr 21 11:01:43 2021] 816128 pages HighMem/MovableOnly
          [Mi Apr 21 11:01:43 2021] 32953 pages reserved
          [Mi Apr 21 11:01:43 2021] 65536 pages cma reserved
          [Mi Apr 21 11:01:43 2021] Tasks state (memory values in pages):
          [Mi Apr 21 11:01:43 2021] [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
          [Mi Apr 21 11:01:43 2021] [    124]     0   124     5312       48   143360      171             0 systemd-journal
          [Mi Apr 21 11:01:43 2021] [    149]     0   149     4532       12    49152      192         -1000 systemd-udevd
          [Mi Apr 21 11:01:43 2021] [    309]   100   309     5604       13    57344      150             0 systemd-timesyn
          [Mi Apr 21 11:01:43 2021] [    342]     0   342     1987       13    36864       32             0 cron
          [Mi Apr 21 11:01:43 2021] [    343]   104   343     1639       64    36864       94          -900 dbus-daemon
          [Mi Apr 21 11:01:43 2021] [    344]     0   344     2686       12    45056       89             0 wpa_supplicant
          [Mi Apr 21 11:01:43 2021] [    345]     0   345     6378       24    49152      201             0 rsyslogd
          [Mi Apr 21 11:01:43 2021] [    346]     0   346      923        8    32768       41             0 alsactl
          [Mi Apr 21 11:01:43 2021] [    349] 65534   349     1080        5    36864       39             0 thd
          [Mi Apr 21 11:01:43 2021] [    352]   108   352     1640      218    36864       51             0 avahi-daemon
          [Mi Apr 21 11:01:43 2021] [    372]     0   372     3261       34    49152      132             0 systemd-logind
          [Mi Apr 21 11:01:43 2021] [    388]     0   388     6914       13    40960       26             0 rngd
          [Mi Apr 21 11:01:43 2021] [    397]   108   397     1442        4    32768       59             0 avahi-daemon
          [Mi Apr 21 11:01:43 2021] [    472]     0   472     2751       56    49152      137             0 wpa_supplicant
          [Mi Apr 21 11:01:43 2021] [    486]     0   486      535        1    24576       31             0 hciattach
          [Mi Apr 21 11:01:43 2021] [    491]     0   491     2384        0    45056       93             0 bluetoothd
          [Mi Apr 21 11:01:43 2021] [    557]     0   557      726       42    32768       94             0 dhcpcd
          [Mi Apr 21 11:01:43 2021] [    564]     0   564     1077        0    36864       25             0 agetty
          [Mi Apr 21 11:01:43 2021] [    565]     0   565     2682       38    45056      134         -1000 sshd
          [Mi Apr 21 11:01:43 2021] [  10973]     0 10973     3060       19    49152      192             0 sshd
          [Mi Apr 21 11:01:43 2021] [  11169]  1000 11169     3651        0    53248      227             0 systemd
          [Mi Apr 21 11:01:43 2021] [  11170]  1000 11170     8805       22    65536      398             0 (sd-pam)
          [Mi Apr 21 11:01:43 2021] [  11183]  1000 11183     3060       38    45056      164             0 sshd
          [Mi Apr 21 11:01:43 2021] [  11184]  1000 11184     2123       56    49152      202             0 bash
          [Mi Apr 21 11:01:43 2021] [    574]  1001   574   636380   602865  5722112     2796             0 node
          [Mi Apr 21 11:01:43 2021] [    592]  1001   592    48654     7069   946176     9793             0 node
          [Mi Apr 21 11:01:43 2021] [    607]  1001   607    40667     5639   659456     2536             0 node
          [Mi Apr 21 11:01:43 2021] [    622]  1001   622    44197     8966   860160     3576             0 node
          [Mi Apr 21 11:01:43 2021] [    652]  1001   652    37264     5204   581632       26             0 node
          [Mi Apr 21 11:01:43 2021] [    667]  1001   667    37653     4809   552960      551             0 node
          [Mi Apr 21 11:01:43 2021] [    690]  1001   690    37050     4903   573440        6             0 node
          [Mi Apr 21 11:01:43 2021] [    705]  1001   705    37085     4912   602112       47             0 node
          [Mi Apr 21 11:01:43 2021] [    716]  1001   716    37989     6196   589824       39             0 node
          [Mi Apr 21 11:01:43 2021] [    735]  1001   735    37954     5816   602112       28             0 node
          [Mi Apr 21 11:01:43 2021] [    746]  1001   746    38398     6093   626688       17             0 node
          [Mi Apr 21 11:01:43 2021] [    765]  1001   765    41268    10551   724992      287             0 node
          [Mi Apr 21 11:01:43 2021] [    780]  1001   780    41254     9849   712704        9             0 node
          [Mi Apr 21 11:01:43 2021] [    795]  1001   795    38855     5993   598016       43             0 node
          [Mi Apr 21 11:01:43 2021] [    841]  1001   841    43573    11273   749568       18             0 node
          [Mi Apr 21 11:01:43 2021] [    958]  1001   958    40690     8935   675840       64             0 node
          [Mi Apr 21 11:01:43 2021] [   1373]  1001  1373    57399    25424  1118208      158             0 node
          [Mi Apr 21 11:01:43 2021] [   1388]  1001  1388    40151     7577   675840       43             0 node
          [Mi Apr 21 11:01:43 2021] [   1558]  1001  1558    42724    11460   774144       29             0 node
          [Mi Apr 21 11:01:43 2021] [   1575]  1001  1575    38600     5668   610304       28             0 node
          [Mi Apr 21 11:01:43 2021] [   1745]  1001  1745    37289     5355   569344       62             0 node
          [Mi Apr 21 11:01:43 2021] [   1762]  1001  1762    54339    22374  1163264       66             0 node
          [Mi Apr 21 11:01:43 2021] [   1769]  1001  1769    38103     5797   602112       14             0 node
          [Mi Apr 21 11:01:43 2021] [   1952]  1001  1952    38254     6423   630784       16             0 node
          [Mi Apr 21 11:01:43 2021] [   1973]  1001  1973    37793     5244   581632       77             0 node
          [Mi Apr 21 11:01:43 2021] [   2158]  1001  2158    36642     4735   573440       22             0 node
          [Mi Apr 21 11:01:43 2021] [   2200]  1001  2200    39250     6338   638976        5             0 node
          [Mi Apr 21 11:01:43 2021] [   2379]  1001  2379    37966     5824   589824       13             0 node
          [Mi Apr 21 11:01:43 2021] [   2398]  1001  2398    37605     5171   569344       99             0 node
          [Mi Apr 21 11:01:43 2021] [   2579]  1001  2579    37413     4964   581632       50             0 node
          [Mi Apr 21 11:01:43 2021] [   2605]  1001  2605    38353     5893   589824       37             0 node
          [Mi Apr 21 11:01:43 2021] [   2790]  1001  2790    40008     7355   663552       13             0 node
          [Mi Apr 21 11:01:43 2021] [   2810]  1001  2810    37622     5235   577536        6             0 node
          [Mi Apr 21 11:01:43 2021] [   2993]  1001  2993    38212     5827   610304       12             0 node
          [Mi Apr 21 11:01:43 2021] [   3014]  1001  3014    37201     4740   577536        9             0 node
          [Mi Apr 21 11:01:43 2021] [   3214]  1001  3214    46262    13595   778240       57             0 node
          [Mi Apr 21 11:01:43 2021] [   3399]  1001  3399    37258     5031   573440       26             0 node
          [Mi Apr 21 11:01:43 2021] [   3417]  1001  3417    40262     8387   692224       41             0 node
          [Mi Apr 21 11:01:43 2021] [   3607]  1001  3607    41144     8211   733184       69             0 node
          [Mi Apr 21 11:01:43 2021] [   3621]  1001  3621    36815     5129   585728        1             0 node
          [Mi Apr 21 11:01:43 2021] [   3835]  1001  3835    42233    10175   757760       28             0 node
          [Mi Apr 21 11:01:43 2021] [   3855]  1001  3855    37244     5012   577536        0             0 node
          [Mi Apr 21 11:01:43 2021] [   4056]  1001  4056    43200    11702   815104        6             0 node
          [Mi Apr 21 11:01:43 2021] [  26752]  1000 26752     2333      578    40960        0             0 htop
          [Mi Apr 21 11:01:43 2021] [  27318]     0 27318     3060      236    49152        0             0 sshd
          [Mi Apr 21 11:01:43 2021] [  27423]  1000 27423     3060      196    45056        2             0 sshd
          [Mi Apr 21 11:01:43 2021] [  27429]  1000 27429     2123      258    40960        0             0 bash
          [Mi Apr 21 11:01:43 2021] [  27702]  1000 27702     1919       39    40960        0             0 iobroker
          [Mi Apr 21 11:01:43 2021] [  27704]     0 27704     2507      108    45056        0             0 sudo
          [Mi Apr 21 11:01:43 2021] [  27705]  1001 27705    52557    28387   954368        0             0 node
          [Mi Apr 21 11:01:43 2021] [  32518]  1001 32518    24051     3548   331776        0             0 node
          [Mi Apr 21 11:01:43 2021] [  32703]  1001 32703    24228     4148   331776        0             0 node
          [Mi Apr 21 11:01:43 2021] [   2296]  1001  2296     2344       50    40960        0             0 ping
          [Mi Apr 21 11:01:43 2021] [   2371]  1001  2371    43573    10610   696320       18             0 node
          [Mi Apr 21 11:01:43 2021] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=node,pid=574,uid=1001
          [Mi Apr 21 11:01:43 2021] Out of memory: Killed process 574 (node) total-vm:2545520kB, anon-rss:2408364kB, file-rss:3096kB, shmem-rss:0kB, UID:1001 pgtables:5588kB oom_score_adj:0
          [Mi Apr 21 11:01:44 2021] oom_reaper: reaped process 574 (node), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
          pi@raspberrypi:~ $
          homee, ioBroker, iMac, iPhone, Sonos, Alaxa
            @bergjet Das sollte so natürlich nicht sein.
            Da stimmt vermutlich 'tiefer' im System was nicht.
            dmesg -T
            which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            bergjetB Offline
            bergjetB Offline
            bergjet
            #70
            @thomas-braun sagte in ioBrocker Neustart Änderung:
            pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.22.1
            /usr/bin/node
            v12.22.1
            /usr/bin/npm
            6.14.12
            nodejs:
              Installiert:           12.22.1-1nodesource1
              Installationskandidat: 12.22.1-1nodesource1
              Versionstabelle:
             *** 12.22.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                 10.24.0~dfsg-1~deb10u1 500
            pi@raspberrypi:~ $
            • bergjetB bergjet
              /usr/bin/nodejs
              v12.22.1
              /usr/bin/node
              v12.22.1
              /usr/bin/npm
              6.14.12
              nodejs:
                Versionstabelle:
              pi@raspberrypi:~ $
              #71
              @bergjet
              Ich sehe nix ungewöhnliches. Lediglich das der Speicher regelmäßig zur Neige geht.
              bergjetB 1 Antwort Letzte Antwort
                @bergjet
                bergjetB Offline
                bergjetB Offline
                bergjet
                #72
                Da muss ich vermutlich neu installieren.
                • bergjetB bergjet
                  #73
                  @bergjet
                  Ja, vielleicht.
                  Aber mit Backup ist das ja flugs erledigt.
                  • wendy2702W Online
                    wendy2702W Online
                    #74
                    Nur mal so, ist auf dem PI ausser iobroker noch etwas installiert?
                    Die Bilder will ich mir Mobil nicht angucken.
                    • bergjetB Offline
                      bergjetB Offline
                      bergjet
                      #75
                      Habe neu installiert, jetzt funktioniert wieder alles.
                      Danke an Alle, habe einiges dazugelernt an Befehlen.
