  4. Deconz Adapter stürzt bei neuer Phoscon Version 2.11.00 ab.
    2.0k
7 Beiträge 2 Kommentatoren 865 Aufrufe 1 Beobachtet
  • H Offline
    hilde0407
    Der Deconz Adapter stürzt bei der neuen Phoscon Software 2.11.00 ab, sobald ein Sensor oder Schalter betätigt wird. Ein kompletten Debug Log habe ich mal angehängt:
    deconz.0	2021-04-18 15:57:04.427	debug	(18310) Subscribed to updates...
    deconz.0	2021-04-18 15:56:15.593	debug	(18310) system.adapter.admin.0: logging true
    deconz.0	2021-04-18 15:56:04.422	debug	(18310) Websocket connection closed
    deconz.0	2021-04-18 15:56:04.421	warn	(18310) Could not connect to websocket instance of deConz/Phoscon. Error: connect ECONNREFUSED 192.168.178.230:443
    deconz.0	2021-04-18 15:56:00.727	debug	(18310) system.adapter.admin.0: logging false
    deconz.0	2021-04-18 15:55:38.164	debug	(18310) system.adapter.admin.0: logging true
    deconz.0	2021-04-18 15:55:36.442	debug	(18310) system.adapter.admin.0: logging false
    deconz.0	2021-04-18 15:55:24.773	info	(18310) Adapter is ready
    deconz.0	2021-04-18 15:55:04.629	debug	(18310) Websocket connection closed
    deconz.0	2021-04-18 15:55:04.412	debug	(18310) Websocket message: {"attr":{"id":"1","lastannounced":null,"lastseen":"2021-04-18T13:55Z","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 1","swversion
    deconz.0	2021-04-18 15:54:59.525	debug	(18310) Websocket message: {"e":"changed","id":"35","r":"sensors","state":{"lastupdated":"2021-04-18T13:54:59.515","open":true},"t":"event","uniqueid":"00:15:8d:00:02:72:01:04-01-0006"}
    deconz.0	2021-04-18 15:54:55.553	debug	(18310) Websocket message: {"e":"changed","id":"9","r":"sensors","state":{"lastupdated":"2021-04-18T13:54:55.545","open":true},"t":"event","uniqueid":"00:15:8d:00:02:73:da:4e-01-0006"}
    deconz.0	2021-04-18 15:54:51.334	debug	(18310) Websocket message: {"e":"changed","id":"19","r":"sensors","state":{"lastupdated":"2021-04-18T13:54:51.324","presence":true},"t":"event","uniqueid":"00:15:8d:00:02:27:ce:92-01-0406"}
    deconz.0	2021-04-18 15:54:48.230	debug	(18310) Websocket message: {"config":{"battery":100,"duration":90,"on":true,"reachable":true,"temperature":0},"e":"changed","id":"19","r":"sensors","t":"event","uniqueid":"00:15:8d:00:02:27:ce:92-01-
    deconz.0	2021-04-18 15:54:39.779	debug	(18310) Subscribed to updates...
    deconz.0	2021-04-18 15:54:39.769	debug	(18310) Websocket connection closed
    deconz.0	2021-04-18 15:54:24.782	debug	(18310) Subscribed to updates...
    deconz.0	2021-04-18 15:54:24.779	debug	(18310) Code 200: Request succeded get group attributes 8: {"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemem
    deconz.0	2021-04-18 15:54:24.758	debug	(18310) Code 200: Request succeded get group attributes 7: {"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemem
    deconz.0	2021-04-18 15:54:24.739	debug	(18310) Code 200: Request succeded get group attributes 6: {"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemem
    deconz.0	2021-04-18 15:54:24.724	debug	(18310) Code 200: Request succeded get group attributes 4: {"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemem
    deconz.0	2021-04-18 15:54:24.709	debug	(18310) Code 200: Request succeded get group attributes 1: {"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemem
    deconz.0	2021-04-18 15:54:24.694	debug	(18310) Code 200: Request succeded get all groups: {"1":{"action":{"alert":"none","bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemember
    deconz.0	2021-04-18 15:54:23.568	debug	(18310) Code 200: Request succeded get all sensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"f22703a147e68ad8ba03fcc86680ee10","manufacturername":"Ph
    deconz.0	2021-04-18 15:54:22.980	debug	(18310) Code 200: Request succeded get all lights: {"1":{"etag":"742bd69a4307c446637c9853e09d8f31","hascolor":false,"lastannounced":null,"lastseen":"2021-04-18T13:53Z","manufacturername":"dresden ele
    deconz.0	2021-04-18 15:54:22.963	info	(18310) deConz Version: 2.11.0; API version: 1.16.0
    deconz.0	2021-04-18 15:54:22.962	debug	(18310) Code 200: Request succeded get config: {"UTC":"2021-04-18T13:54:22","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF054EC0","datastoreversion":"93","devi
    @Jey-Cee es wäre schön, wenn Du helfen könntest!
    Systemdata Beelink T45 mit Proxmox
    Hardwaresystem: NUC
    Arbeitsspeicher: 8GB
    Festplattenart: SSD
    Betriebssystem: Proxmox mit mehreren LXC Containern und einer VM für den Conbee 2 Stick
    Node-Version: 12.22.1
    Nodejs-Version: 12.22.1
    NPM-Version: 6.14.12
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    • H hilde0407
      Hardwaresystem: NUC
      Festplattenart: SSD
      Image genutzt: Nein
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      @hilde0407 welche version vom Adapter ist Installiert?
      Im Log sehe ich keinen Absturz, da sieht alles gut aus bsi auf das er keine Websocket Verbindung aufbauen kann.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      H 1 Antwort Letzte Antwort
      • Jey CeeJ Jey Cee
        hilde0407
        @jey-cee Es ist der Deconz Adapter 2.0.6 installiert!
        Sobald ich einen Schalter betätige wird der Adapter gelb und nach einiger Zeit wieder grün. Geschaltet wird aber nix!
        • H hilde0407
          Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          @hilde0407 sagte in Deconz Adapter stürzt bei neuer Phoscon Version 2.11.00 ab.:
          Gut dann hat sich das schon erledigt, alles was v2 ist wird nicht Supportet. Der Grund dafür steht im anderen Thema.
          Bitte die 1.3.11 verwenden.
          • Jey CeeJ Jey Cee
            hilde0407
            @jey-cee Habe ich eine Chance, dass es dort funktioniert? Es würde ja bedeuten, dass ich alles neu anlernen muss!
            • H hilde0407
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              @hilde0407 Eine bessere als mit der v2. Und Nein, anlernen musst du nicht alles neu. Das ist ja alles in deConz geregelt.
              Du musst nur deine Scripte anpassen, wegen der anderen Objekt Struktur.
              • Jey CeeJ Jey Cee
                hilde0407
                @jey-cee OK ! Ich versuche es mal! Dankeschön!
