  4. Homebridge-Adapter: Funktionierende Plugins und Beispiele
    6.3k
238 Beiträge 62 Kommentatoren 81.5k Aufrufe 44 Beobachtet
  • T TheAriba
    Hallo zusammen!
    Wie ich tatsächlich ein homebridge plugin in ioBroker zum Laufen bekomme würde mir an der Stelle auch helfen. Irgendwie verstehe ich da nur Bahnhof 🙂 .
    Fehlt hier noch etwas an den Einstellungen? Es knallt im Log ein wenig.
    f6789800-8d22-42df-a0b8-78640dd60144-image.png fd5a655d-ec1e-4207-b2cb-2ced501fb391-image.png
    host.raspberrypi	2021-01-13 23:38:00.586	info	Restart adapter system.adapter.ham.0 because enabled
    host.raspberrypi	2021-01-13 23:38:00.585	info	instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[3]: [1/13/2021, 22:38:00] Error loading platform requested in your config.json at position 1
    host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: [1/13/2021, 22:38:00] ====================
    host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: at Server.start (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:71:28)
    host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: at PluginManager.initializeInstalledPlugins (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js:61:22)
    host.raspberrypi	2021-01-13 23:38:00.585	error	Caught by controller[2]: at Map.forEach (<anonymous>)
    host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js:63:24
    host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Plugin.load (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/plugin.js:124:31)
    host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at require (internal/modules/cjs/helpers.js:74:18)
    host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Function.Module._load (/opt/iobroker/node_modules/mock-require/index.js:30:22)
    host.raspberrypi	2021-01-13 23:38:00.584	error	Caught by controller[2]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/iobroker.ham/main.js
    host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js
    host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js
    host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js
    host.raspberrypi	2021-01-13 23:38:00.583	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/api.js
    host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManager.js
    host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: - /opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/plugin.js
    host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: Require stack:
    host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: [1/13/2021, 22:38:00] Error: Cannot find module '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-doorbird/dist/index.js'
    host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[2]: [1/13/2021, 22:38:00] ERROR LOADING PLUGIN homebridge-doorbird:
    host.raspberrypi	2021-01-13 23:38:00.582	error	Caught by controller[1]: [1/13/2021, 22:38:00] ====================
    host.raspberrypi	2021-01-13 23:38:00.581	error	Caught by controller[0]: [1/13/2021, 22:38:00] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
    ham.0	2021-01-13 23:38:00.059	info	(4089) Terminated (NO_ERROR): Without reason
    ham.0	2021-01-13 23:38:00.058	info	(4089) terminating
    ham.0	2021-01-13 23:38:00.050	info	(4089) cleaned everything up...
    ham.0	2021-01-13 23:38:00.049	error	(4089) Error: The requested platform 'Doorbird' was not registered by any plugin. at PluginManager.getPluginForPlatform (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/pluginManag
    ham.0	2021-01-13 23:38:00.045	error	(4089) unhandled promise rejection: The requested platform 'Doorbird' was not registered by any plugin.
    ham.0	2021-01-13 23:38:00.045	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ham.0	2021-01-13 23:38:00.041	debug	(4089) [1/13/2021, 22:38:00] Loading 1 platforms...
    ham.0	2021-01-13 23:37:58.965	info	(4089) All Libraries installed/updated
    ham.0	2021-01-13 23:37:58.964	error	(4089) Error: Library https://github.com/hjdhjd/homebridge-doorbird not installed after 3 attempts
    ham.0	2021-01-13 23:37:58.925	info	(4089) found 0 vulnerabilities
    ham.0	2021-01-13 23:37:58.846	info	(4089) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 14.395s
    ham.0	2021-01-13 23:37:43.153	info	(4089) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
    ham.0	2021-01-13 23:37:43.119	info	(4089) found 0 vulnerabilities
    ham.0	2021-01-13 23:37:43.043	info	(4089) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 20.522s
    ham.0	2021-01-13 23:37:21.253	info	(4089) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
    ham.0	2021-01-13 23:37:21.213	info	(4089) found 0 vulnerabilities
    ham.0	2021-01-13 23:37:21.121	info	(4089) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 13.538s
    ham.0	2021-01-13 23:37:06.277	info	(4089) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
    ham.0	2021-01-13 23:37:06.276	info	(4089) Install/Update https://github.com/hjdhjd/homebridge-doorbird
    ham.0	2021-01-13 23:37:06.275	info	(4089) Install/Update the following Libraries: https://github.com/hjdhjd/homebridge-doorbird
    ham.0	2021-01-13 23:37:06.246	info	(4089) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.20.1, js-controller: 3.1.6
    host.raspberrypi	2021-01-13 23:37:05.107	info	instance system.adapter.ham.0 started with pid 4089
    host.raspberrypi	2021-01-13 23:37:02.604	info	instance system.adapter.ham.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    ham.0	2021-01-13 23:37:02.072	info	(3781) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    ham.0	2021-01-13 23:37:02.071	info	(3781) terminating
    ham.0	2021-01-13 23:37:02.070	info	(3781) cleaned everything up...
    ham.0	2021-01-13 23:37:02.069	info	(3781) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi	2021-01-13 23:37:02.066	info	stopInstance system.adapter.ham.0 send kill signal
    host.raspberrypi	2021-01-13 23:37:02.065	info	stopInstance system.adapter.ham.0 (force=false, process=true)
    ham.0	2021-01-13 23:37:02.042	info	(3781) All NPM Modules got reinstalled/updated ... restarting ...
    ham.0	2021-01-13 23:37:02.041	error	(3781) Error: Library https://github.com/hjdhjd/homebridge-doorbird not installed after 3 attempts
    ham.0	2021-01-13 23:37:02.001	info	(3781) found 0 vulnerabilities
    ham.0	2021-01-13 23:37:01.912	info	(3781) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 14.307s
    ham.0	2021-01-13 23:36:46.329	info	(3781) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
    ham.0	2021-01-13 23:36:46.296	info	(3781) found 0 vulnerabilities
    ham.0	2021-01-13 23:36:46.220	info	(3781) + homebridge-doorbird@1.0.1 updated 1 package and audited 39 packages in 14.364s
    ham.0	2021-01-13 22:36:30.521	info	(3781) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
    ham.0	2021-01-13 22:36:30.484	info	(3781) found 0 vulnerabilities
    ham.0	2021-01-13 22:36:30.402	info	updated 1 package and audited 39 packages in 14.212s
    ham.0	2021-01-13 22:36:30.402	info	(3781) + homebridge-doorbird@1.0.1
    ham.0	2021-01-13 22:36:14.865	info	(3781) npm install https://github.com/hjdhjd/homebridge-doorbird --production --loglevel error (System call)
    ham.0	2021-01-13 22:36:14.864	info	(3781) Install/Update https://github.com/hjdhjd/homebridge-doorbird
    ham.0	2021-01-13 22:36:14.863	info	(3781) Install/Update the following Libraries: https://github.com/hjdhjd/homebridge-doorbird
    ham.0	2021-01-13 22:36:14.834	info	(3781) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.20.1, js-controller: 3.1.6
    Ich bedanke mich vorab für eure Unterstützung!
    #103
    @enoceaneltako said in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
    Naja teht doch alles in der Fehlermeung. DU musst in der Liste der Pakete auch die nötigen Plugin Pakete aufzählen das Sie installiert werden können.
    • B Boardy
      @SkeeveKlah Hi, ich will meien AC Daten auslesen - klappt das mit dem debug Mode bei Dir? AC geräte werden nicht unterstützt, aber in der App im Debug mode sehe ich alles was ich benötige... nur im IOBroker kommt nicht mehr an...
      SkeeveKlah
      #104
      @boardy Tja... ich habe ne Waschmaschine im Adapter und die wird wohl nur als Schalter angezeigt, irgendwo hatte ich das auch mal gelesen, hatte etwas Hoffnung das mittlerweile ein bischen mehr geht, ist aber wohl nicht.
      ManN kann eben (noch) nicht alles haben 😳
      Grüße aus dem Sauerland
      Marc
      RPI4 8GB mit SSD-RAID1, ioBroker mit Debmatic
        amiethaner
        #105
        Hey @apollon77
        Ich kenn mich mit der Programmiererei so leider ned aus, aber wollte mal vorsichtig anfragen
        obs für Fibaro HC2 mal ne erweiterung geben wird, oder ob das technisch überhaupt geht.
        Hier wären ja deutlich mehr values der einzelnen Devices vorhanden als über den Ham zum IOB kommen.
        Ansonsten aber echt n dicken Danke für den Adapter! Super arbeit!
        • A amiethaner
          Hey @apollon77
          #106
          @amiethaner Keine ahnug obs das mal geben wird :-) Gibts einen Adapter Request dazu?
          • apollon77A apollon77
            amiethaner
            #107
            @apollon77 sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
            Ich glaub ned, meinst es bringt was wenn ich einen aufmach
              hier im Thread dürfen zu dem Homebridge -Adapter (iobroker.ham) gern funktioniernde Plugins berichtet werden, Konfigurationsbeispiele und sonstige Infos. lasst uns sammeln :-)
              Bitte packt auf jeden Fall Pluginname, Version des Plugins, die Version des ham Adapters und EUre nodejs Version mit rein. Danke!
              Danke Ingo
              #108
              @apollon77
              Hier ein Beispiel für die Govee-Ambiente H6104, hab 2 Stück, es werden beide automatisch gefunden, läuft so:
                "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                "accessories": [],
                "platforms": [
                    "platform": "Govee",
                    "name": "Govee",
                    "apiKey": "api-key",
                    "model": "H6104",
                    "controllable": true,
                    "retrievable": true,
                    "supportCmds": [
                      "turn",
                      "brightness",
                      "color",
                      "colorTem"
              gelberlemmyG 1 Antwort Letzte Antwort
                Danke Ingo
                marcfe
                schrieb am zuletzt editiert von marcfe
                #109
                homebridge-keylights (Version 1.2.4)funktioniert leider nicht richtig mit der Plugin-Version 4.0.1: https://www.npmjs.com/package/homebridge-keylights
                Meine NodeJS-Version war v10.24.0 und ist jetzt v12.22.1 (kein Unterschied)
                es wird zwar mit folgender Konfiguration erkannt (useIP muss true sein) und auch der Status aktualisiert, wenn ich zum Beispiel Setting über die App ändere, leider kann ich das Keylight über den iobroker nur ein und wieder aus-schalten.
                Konfig:
                  "platforms": [
                      "name": "Elgato Key Lights",
                      "switchOnDurationMs": 100,
                      "platform": "ElgatoKeyLights",
                      "useIP": true
                Objekte:
                Logs:
                # Ändern über Objekte (es passiert nichts am Licht)
                ham.0	2021-04-15 12:55:06.729	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.Brightness {"val":25,"ack":true,"ts":1618484106722,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1618484106712}
                ham.0	2021-04-15 12:55:06.717	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.Brightness {"val":25,"ack":false,"ts":1618484106712,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1618484106712}
                # Licht über Objekte ausschalten (funktioniert)
                ham.0	2021-04-15 12:59:00.943	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.On {"val":false,"ack":true,"ts":1618484340939,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1618484340708}
                ham.0	2021-04-15 12:59:00.767	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.On {"val":false,"ack":true,"ts":1618484340763,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1618484340708}
                ham.0	2021-04-15 12:59:00.713	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.On {"val":false,"ack":false,"ts":1618484340708,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1618484340708}
                # Ändern über die App (kommt im iobroker an)
                ham.0	2021-04-15 12:54:48.702	info	(14551) stateChange ham.0.Elgato-Key-Light-C70B.Lightbulb.Brightness {"val":52,"ack":true,"ts":1618484088698,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1618484088698}
                getestet im wrapper und local mode
                • M marcfe
                  Konfig:
                    "platforms": [
                        "useIP": true
                  Objekte:
                  Logs:
                  #110
                  @marcfe naja das brauchst man etwas mehr Log :-) Bitte Adaoter auf Debug Log stellen und starten. Dann gesamtes Log aus dem Logfile von der Platte /opt/iobroker/log/... und posten
                    M240-Swiss
                    #111
                    Nach dem Update auf 4.0.1 funktioniert das Plugin „homebridge-logi-circle-controls“ nicht mehr. Die Schalter zur Bedienung der Kameras sind zwar vorhanden aber ohne Funktion.
                    Ein Downgrade auf 3.0.2 und alles läuft wieder
                    • M M240-Swiss
                      #112
                      @m240-swiss auch hier ... log bitte
                      Und ggf auch im Plugin schauen ob das ggf ne neue Version braucht für homebridge 1.3.x ?! Da gab es Plugins die Updates brauchen.
                        #113
                        @apollon77 kann man in den HAM Adapter einbauen, dass er die Anzahl an Updates für installierte Plugins anzeigt, wie im Adapter-Tab ?
                          #114
                          @ilovegym Haste Dir mal den neuen Tab des Adapters angeschaut den es seit dern 4.0. gibt?? ggf ists da schon drin ... sonst wäre ein Feature Request im Github ne idee
                            #115
                            @apollon77 :) ja, da ist es mir ja auch aufgefallen, dass es neue Versionen gibt..
                            ich meine halt in der Leiste links, wie bei "Adapter" wenn da neue sind, zeigt er ja auch die Anzahl an Updates an..
                            ... halt für die ganz Blinden, wie mich, in extra groß und rot, wenn es geht..? :-)
                              #116
                              @ilovegym Ne für solche "sub updates" gibt es keine optionen die ich kennen würde
                                M240-Swiss
                                #117
                                @apollon77 : Es gibt tatsächlich eine neue Version des Plugins. Kannst Du mir sagen wie ich es im HAM Adapter Updaten kann? (Und vielleicht auch wie ich sehe welche Version eines Plugins installiert ist) Besten Dank im Voraus
                                • M M240-Swiss
                                  #118
                                  @m240-swiss Updaten: Im Admin gibts nen "update plugins" checkbox. drücken, speichern, warten.
                                  Sehen neue version sollte in dem neuen Homebridge Tab (siehe infos Changelog zur 4.0 version) drin sein
                                    M240-Swiss
                                    #119
                                    @apollon77 : Super, vielen Dank. Plugin upgedatet und die neue Version des Adapters geladen –> alles funktioniert
                                      @apollon77
                                        "accessories": [],
                                        "platforms": [
                                            "name": "Govee",
                                            "model": "H6104",
                                            "supportCmds": [
                                              "turn",
                                              "brightness",
                                              "color",
                                              "colorTem"
                                      gelberlemmyG Offline
                                      gelberlemmy
                                      #120
                                      @ilovegym sagte in Homebridge-Adapter: Funktionierende Plugins und Beispiele:
                                      @apollon77
                                        "accessories": [],
                                        "platforms": [
                                            "name": "Govee",
                                            "model": "H6104",
                                            "supportCmds": [
                                              "turn",
                                              "brightness",
                                              "color",
                                              "colorTem"
                                      Ich habe auch den Govee Adapter. Aber ich kann die Helligkeit und die Farbe meiner LED nicht steuern. An / Aus geht. Habe aber in den Config nur die API stehen. Muss ich für jeden Typen dies so einstellen ?
                                      ? apollon77A S 3 Antworten Letzte Antwort
                                      • gelberlemmyG gelberlemmy
                                        @apollon77
                                          "accessories": [],
                                          "platforms": [
                                              "name": "Govee",
                                              "model": "H6104",
                                              "supportCmds": [
                                                "turn",
                                                "brightness",
                                                "color",
                                                "colorTem"
                                        #121
                                        @gelberlemmy
                                        hmm hab ich nie getestet, da ich nur ein/aus benoetige, ist ja das Ambilight, das regelt von alleine...
                                        Hab 2 Stueck, die hat er automatisch gefunden ueber die API und angelegt.
                                          @apollon77
                                            "accessories": [],
                                            "platforms": [
                                                "name": "Govee",
                                                "model": "H6104",
                                                "supportCmds": [
                                                  "turn",
                                                  "brightness",
                                                  "color",
                                                  "colorTem"
                                          #122
                                          @gelberlemmy Was heisst "kann ich nicht steuern"? Die datenpunkte sehe ich alle. Passiert nichts wenn Du Sie änderst oder was ist los? Mehr details bitte!! Am besten ein Debug Log was genau zeigt wenn Du versuchst was zu steuern
                                          gelberlemmyG 2 Antworten Letzte Antwort
