  4. Gelöst IObroker Novelan WP Luxtronik
11 Beiträge 6 Kommentatoren 1.5k Aufrufe 5 Beobachtet
  • ? Offline
    Hallo zusamenn,
    leider habe ich keine Verbindung . woran könnte es liegen?
    Port 8888 und 8889 habe ich versuche .
    021-04-11 00:00:00.064  - info: host.raspberrypi2 instance system.adapter.dwd.0 started with pid 9940
    2021-04-11 00:00:01.779  - warn: luxtronik1.0 (9925) 3505 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:03.025  - info: dwd.0 (9940) starting. Version 2.7.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.1, js-controller: 3.2.16
    2021-04-11 00:00:03.780  - warn: luxtronik1.0 (9925) 3400 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:04.796  - warn: luxtronik1.0 (9925) 1800 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:06.797  - warn: luxtronik1.0 (9925) 2100 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:07.725  - info: dwd.0 (9940) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-04-11 00:00:08.313  - info: host.raspberrypi2 instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-04-11 00:00:08.796  - warn: luxtronik1.0 (9925) 3405 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:10.797  - warn: luxtronik1.0 (9925) 3505 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:12.798  - warn: luxtronik1.0 (9925) 3400 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:13.799  - warn: luxtronik1.0 (9925) 1800 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:13.802  - warn: luxtronik1.0 (9925) Achtung, mehrfach unvollständiger Datensatz 1800
    2021-04-11 00:00:13.803  - warn: luxtronik1.0 (9925) Adapter wird neu gestartet
    2021-04-11 00:00:13.930  - info: host.raspberrypi2 stopInstance system.adapter.luxtronik1.0 (force=false, process=true)
    2021-04-11 00:00:13.939  - info: luxtronik1.0 (9925) Got terminate signal TERMINATE_YOURSELF
    2021-04-11 00:00:13.940  - info: host.raspberrypi2 stopInstance system.adapter.luxtronik1.0 send kill signal
    2021-04-11 00:00:13.942  - info: luxtronik1.0 (9925) [END] Stopping luxtronik adapter...
    2021-04-11 00:00:13.944  - info: luxtronik1.0 (9925) terminating
    2021-04-11 00:00:13.946  - info: luxtronik1.0 (9925) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-04-11 00:00:14.559  - info: host.raspberrypi2 instance system.adapter.luxtronik1.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-04-11 00:00:17.011  - info: host.raspberrypi2 instance system.adapter.luxtronik1.0 started with pid 9964
    2021-04-11 00:00:20.146  - info: luxtronik1.0 (9964) starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v12.22.1, js-controller: 3.2.16
    2021-04-11 00:00:20.186  - info: luxtronik1.0 (9964) [START] Starting luxtronik adapter
    2021-04-11 00:00:20.215  - warn: luxtronik1.0 (9964) 1800 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:22.197  - warn: luxtronik1.0 (9964) 2100 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:24.196  - warn: luxtronik1.0 (9964) 3405 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:26.197  - warn: luxtronik1.0 (9964) 3505 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:28.197  - warn: luxtronik1.0 (9964) 3400 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:29.208  - warn: luxtronik1.0 (9964) 1800 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:31.208  - warn: luxtronik1.0 (9964) 2100 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:33.208  - warn: luxtronik1.0 (9964) 3405 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:35.212  - warn: luxtronik1.0 (9964) 3505 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:37.209  - warn: luxtronik1.0 (9964) 3400 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:38.211  - warn: luxtronik1.0 (9964) 1800 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:40.212  - warn: luxtronik1.0 (9964) 2100 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:42.214  - warn: luxtronik1.0 (9964) 3405 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:44.213  - warn: luxtronik1.0 (9964) 3505 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:46.213  - warn: luxtronik1.0 (9964) 3400 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:47.221  - warn: luxtronik1.0 (9964) 1800 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:49.222  - warn: luxtronik1.0 (9964) 2100 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:51.222  - warn: luxtronik1.0 (9964) 3405 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:53.223  - warn: luxtronik1.0 (9964) 3505 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    2021-04-11 00:00:55.221  - warn: luxtronik1.0 (9964) 3400 connection error: Error: connect ECONNREFUSED 192.168.178.37:8888
    Homer.J.H 1 Antwort Letzte Antwort
      Hallo zusamenn,
      Homer.J.H Offline
      Homer.J.H Offline
      Homer.J.
      @marcel-drzal könnte es vielleicht sein das du Luxtronik 2 hast, dann brauchst du auch den Luxtronik 2.0 Adapter.
      https://forum.iobroker.net/topic/38550/test-adapter-luxtronik2-v0-1-x?page=1
      ? 2 Antworten Letzte Antwort
      • Homer.J.H Homer.J.
        @homer-j Danke dir das war es
          @homer-j zu früh gefreut. Komisch ist nur das Daten an kommen in den Objekten
          aber im Log:
          luxtronik2.0	2021-04-11 14:59:00.369	error	(4579) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 192.168.178.37:8888
          smartmeter.1	2021-04-11 14:58:58.724	info	(701) Received 13 values, 5 updated
          smartmeter.0	2021-04-11 14:58:57.069	info	(686) Received 10 values, 4 updated
          luxtronik2.0	2021-04-11 14:58:55.365	error	(4579) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 192.168.178.37:8888
          luxtronik2.0	2021-04-11 14:58:50.362	error	(4579) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 192.168.178.37:8888
          smartmeter.1	2021-04-11 14:58:47.123	info	(701) Received 13 values, 5 updated
          smartmeter.0	2021-04-11 14:58:46.000	info	(686) Received 10 values, 6 updated
          luxtronik2.0	2021-04-11 14:58:45.359	error	(4579) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 192.168.178.37:8888
          luxtronik2.0	2021-04-11 14:58:40.356	error	(4579) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 192.168.178.37:8888
          smartmeter.1	2021-04-11 14:58:35.500	info	(701) Received 13 values, 6 updated
          luxtronik2.0	2021-04-11 14:58:35.353	error	(4579) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 192.168.178.37:8888
          smartmeter.0	2021-04-11 14:58:35.068	info	(686) Received 10 values, 6 updated
          luxtronik2.0	2021-04-11 14:58:30.349	error	(4579) Luxtronik read error, will retry later: Error: connect ECONNREFUSED 192.168.178.37:8888
            aber im Log:
            @marcel-drzal Jetzt geht es
            G 1 Antwort Letzte Antwort
              grogo
              @marcel-drzal Hallo, kannst du noch sagen voran es gelegen hat?
              Ich bekomme auch alle Werte im IOBroker der Heizung Novelan WP angezeigt, habe aber jede Minute (Aktivierungsintervall Einstellung 60sec in der Instanz eingestellt) die Meldung
              luxtronik2.0 2021-09-02 06:44:56.367 error Luxtronik read error, will retry later: Error: connect ECONNREFUSED 192.168.0.107:8888
              luxtronik2.0 2021-09-02 06:43:56.363 error Luxtronik read error, will retry later: Error: connect ECONNREFUSED 192.168.0.107:8888
              luxtronik2.0 2021-09-02 06:42:56.359 error Luxtronik read error, will retry later: Error: connect ECONNREFUSED 192.168.0.107:8888
              im Protokoll.
              In der Instanz ist der Adapter auch grün. Version 0.3.0
              Besten Dank für deine Hilfe,
              grogo
              L 1 Antwort Letzte Antwort
              • G grogo
                im Protokoll.
                grogo
                lessthanmore
                @grogo Probier mal den Port 8889.
                • L lessthanmore
                  grogo
                  @lessthanmore Ich sage Danke, das war der Fehler, seit gut 30min kein einziger Eintrag mehr.
                  • G grogo
                    TimoWald
                    Hallo bei mir kommt auch diese Fehlermeldung. Was kann ich dagegen tun?1111.JPG
                    Thomas BraunT L 2 Antworten Letzte Antwort
                    • T TimoWald
                      @timowald sagte in Gelöst IObroker Novelan WP Luxtronik:
                      Nein, bei dir kommt eine andere Fehlermeldung...
                      Bitte diese Meldungen in Textform, nicht als Screenshot in deinen anderen Thread zu deinem Thema posten.
                      https://forum.iobroker.net/topic/49782/luxtronik-adapter-fehler
                      • T TimoWald
                        lessthanmore
                        @timowald Oben ging es um Luxtronik2 und du hast Luxtronik1.
                        Das sind zwei unterschiedliche Adapter.
