  4. Test Adapter speedport v0.0.x
68 Beiträge 6 Kommentatoren 11.2k Aufrufe 6 Beobachtet
  • O Oli
    @hacki11
    habe deinen Adapter installiert, aber leider verbindet er sich mit dem Speedport nicht, anbei das Log
    speedport.0	2021-03-24 18:44:04.821	error	(2696) Error: connect ECONNREFUSED 127.0.0.1:80 at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
    speedport.0	2021-03-24 18:44:04.820	error	(2696) connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:43:04.815	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
    speedport.0	2021-03-24 18:43:04.815	error	(2696) Error: connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:43:04.814	error	(2696) connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:42:04.807	error	(2696) Connection failed
    speedport.0	2021-03-24 18:42:04.806	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
    speedport.0	2021-03-24 18:42:04.806	error	(2696) Error: connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:42:04.805	error	(2696) connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:42:04.757	info	(2696) Establish connection to Speedport (192.168.2.1)
    speedport.0	2021-03-24 18:42:04.716	info	(2696) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.speedport, node: v12.20.2, js-controller: 3.2.16
    speedport.0	2021-03-24 18:41:58.131	info	(761) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    speedport.0	2021-03-24 18:41:58.130	info	(761) terminating
    speedport.0	2021-03-24 18:41:58.128	info	(761) cleaned everything.
    speedport.0	2021-03-24 18:41:58.122	info	(761) Got terminate signal TERMINATE_YOURSELF
    speedport.0	2021-03-24 18:41:37.558	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
    speedport.0	2021-03-24 18:41:37.558	error	(761) Error: connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:41:37.557	error	(761) connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:40:37.550	error	(761) Connection failed
    speedport.0	2021-03-24 18:40:37.549	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
    speedport.0	2021-03-24 18:40:37.549	error	(761) Error: connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:40:37.548	error	(761) connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:40:37.501	info	(761) Establish connection to Speedport (192.168.2.1)
    speedport.0	2021-03-24 18:40:37.467	info	(761) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.speedport, node: v12.20.2, js-controller: 3.2.16
    speedport.0	2021-03-24 18:40:34.261	info	(31991) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    speedport.0	2021-03-24 18:40:34.260	info	(31991) terminating
    speedport.0	2021-03-24 18:40:34.259	info	(31991) cleaned everything.
    speedport.0	2021-03-24 18:40:34.257	info	(31991) Got terminate signal TERMINATE_YOURSELF
    speedport.0	2021-03-24 18:39:43.148	error	(31991) Connection failed
    speedport.0	2021-03-24 18:39:43.147	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
    speedport.0	2021-03-24 18:39:43.147	error	(31991) Error: connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:39:43.146	error	(31991) connect ECONNREFUSED 127.0.0.1:80
    speedport.0	2021-03-24 18:39:43.101	info	(31991) Establish connection to Speedport (192.168.2.1)
    speedport.0	2021-03-24 18:39:43.060	info	(31991) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.speedport, node: v12.20.2, js-controller: 3.2.16
    speedport.0	2021-03-24 18:39:36.336	info	(30195) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    speedport.0	2021-03-24 18:39:36.334	info	(30195) terminating
    speedport.0	2021-03-24 18:39:36.333	info	(30195) cleaned everything.
    speedport.0	2021-03-24 18:39:36.332	info	(30195) Got terminate signal TERMINATE_YOURSELF
    speedport.0	2021-03-24 18:39:09.206	error	at async W925V.login (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:111:27)
    speedport.0	2021-03-24 18:39:09.206	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    speedport.0	2021-03-24 18:39:09.206	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:142:22
    speedport.0	2021-03-24 18:39:09.206	error	at W925V.checkStatus (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:156:29)
    speedport.0	2021-03-24 18:39:09.206	error	at W925V.findEntry (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:176:15)
    speedport.0	2021-03-24 18:39:09.206	error	(30195) Error: Could not find vartype status and status
    speedport.0	2021-03-24 18:39:09.204	error	(30195) Could not find vartype status and status
    speedport.0	2021-03-24 18:38:09.143	error	(30195) Connection failed
    speedport.0	2021-03-24 18:38:09.143	error	at async W925V.login (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:111:27)
    speedport.0	2021-03-24 18:38:09.143	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    speedport.0	2021-03-24 18:38:09.143	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:142:22
    speedport.0	2021-03-24 18:38:09.143	error	at W925V.checkStatus (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:156:29)
    speedport.0	2021-03-24 18:38:09.143	error	at W925V.findEntry (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:176:15)
    speedport.0	2021-03-24 18:38:09.143	error	(30195) Error: Could not find vartype status and status
    speedport.0	2021-03-24 18:38:09.141	error	(30195) Could not find vartype status and status
    speedport.0	2021-03-24 18:38:09.024	info	(30195) Establish connection to Speedport (http://speedport.ip)
    speedport.0	2021-03-24 18:38:08.981	info	(30195) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.speedport, node: v12.20.2, js-controller: 3.2.16
    speedport.0	2021-03-24 18:38:03.036	info	(29460) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    speedport.0	2021-03-24 18:38:03.034	info	(29460) terminating
    speedport.0	2021-03-24 18:38:03.033	info	(29460) cleaned everything.
    speedport.0	2021-03-24 18:38:03.032	info	(29460) Got terminate signal TERMINATE_YOURSELF
    speedport.0	2021-03-24 18:37:35.485	error	(29460) Connection failed
    speedport.0	2021-03-24 18:37:35.484	error	at async W925V.login (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:111:27)
    speedport.0	2021-03-24 18:37:35.484	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    speedport.0	2021-03-24 18:37:35.484	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:142:22
    speedport.0	2021-03-24 18:37:35.484	error	at W925V.checkStatus (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:156:29)
    speedport.0	2021-03-24 18:37:35.484	error	at W925V.findEntry (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:176:15)
    speedport.0	2021-03-24 18:37:35.484	error	(29460) Error: Could not find vartype status and status
    speedport.0	2021-03-24 18:37:35.483	error	(29460) Could not find vartype status and status
    speedport.0	2021-03-24 18:37:35.362	info	(29460) Establish connection to Speedport (http://speedport.ip)
    speedport.0	2021-03-24 18:37:35.324	info	(29460) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.speedport, node: v12.20.2, js-controller: 3.2.16
    hacki11
    schrieb am zuletzt editiert von hacki11
    @oli welche Adresse hast du konfiguriert? Der möchte auf localhost verbinden, das kann nicht stimmen.
    Ah weiter unten hat die Adresse gepasst, aber die Authentifizierung scheint anders zu sein.du könntest noch prüfen ob die Firmware aktuell ist. Ansonsten müsste ich das blind implementieren.
    Außer du weißt wie man wireshark traces aufzeichnet. Dann könntest du den Login Vorgang und das aufrufen der geheimen Seiten aufzeichnen. (Vorher Passwort ändern, das kann man dann Evtl lesen)
    O 1 Antwort Letzte Antwort
    • H hacki11
      O Online
      O Online
      Oli
      @hacki11
      so, neuste Firmeware ist drauf hier noch mal der Log
      speedport.0	2021-03-24 23:30:26.825	error	(24559) Error: Request failed with status code 404 at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15) at settle (/opt/iobroker/node_modules/axios/lib/core/settle.j
      speedport.0	2021-03-24 23:30:26.823	error	(24559) Request failed with status code 404
      speedport.0	2021-03-24 23:29:23.767	error	(24559) Connection failed
      speedport.0	2021-03-24 23:29:23.765	error	at async W925V.login (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:111:27)
      speedport.0	2021-03-24 23:29:23.765	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      speedport.0	2021-03-24 23:29:23.765	error	at /opt/iobroker/node_modules/axios-cookiejar-support/lib/index.js:130:67
      speedport.0	2021-03-24 23:29:23.765	error	at responseInterceptor (/opt/iobroker/node_modules/axios-cookiejar-support/lib/interceptors/response.js:82:9)
      speedport.0	2021-03-24 23:29:23.765	error	at new Promise (<anonymous>)
      speedport.0	2021-03-24 23:29:23.765	error	at /opt/iobroker/node_modules/axios-cookiejar-support/lib/interceptors/response.js:83:25
      speedport.0	2021-03-24 23:29:23.765	error	at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:17:12)
      speedport.0	2021-03-24 23:29:23.765	error	at createError (/opt/iobroker/node_modules/axios/lib/core/createError.js:16:15)
      speedport.0	2021-03-24 23:29:23.765	error	(24559) Error: Request failed with status code 404
      speedport.0	2021-03-24 23:29:23.763	error	(24559) Request failed with status code 404
      speedport.0	2021-03-24 23:29:20.598	info	(24559) Establish connection to Speedport (http://speedport.ip/html/login/index.html)
      speedport.0	2021-03-24 23:29:20.561	info	(24559) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.speedport, node: v12.20.2, js-controller: 3.2.16
      Hier meine Einstellungen
      Oliver
      H 1 Antwort Letzte Antwort
      • O Oli
        @hacki11
        hacki11
        @oli @oli als Adresse bitte nur http://speedport.ip eingeben
        O 2 Antworten Letzte Antwort
        • H hacki11
          O Online
          O Online
          Oli
          @hacki11
          sorry, aber er verbindet sich trotzdem nicht
          speedport.0	2021-03-25 16:18:19.049	error	(3215) Error: Could not find vartype status and status at W925V.findEntry (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:176:15) at W925V.checkStatus (/opt/iobroker/node_modules/i
          speedport.0	2021-03-25 16:18:19.048	error	(3215) Could not find vartype status and status
          speedport.0	2021-03-25 16:17:18.994	error	at async W925V.login (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:111:27)
          speedport.0	2021-03-25 16:17:18.994	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
          speedport.0	2021-03-25 16:17:18.994	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:142:22
          speedport.0	2021-03-25 16:17:18.994	error	at W925V.checkStatus (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:156:29)
          speedport.0	2021-03-25 16:17:18.994	error	at W925V.findEntry (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:176:15)
          speedport.0	2021-03-25 16:17:18.994	error	(3215) Error: Could not find vartype status and status
          speedport.0	2021-03-25 16:17:18.993	error	(3215) Could not find vartype status and status
          speedport.0	2021-03-25 16:16:18.925	error	(3215) Connection failed
          speedport.0	2021-03-25 16:16:18.924	error	at async W925V.login (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:111:27)
          speedport.0	2021-03-25 16:16:18.924	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
          speedport.0	2021-03-25 16:16:18.924	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:142:22
          speedport.0	2021-03-25 16:16:18.924	error	at W925V.checkStatus (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:156:29)
          speedport.0	2021-03-25 16:16:18.924	error	at W925V.findEntry (/opt/iobroker/node_modules/iobroker.speedport/lib/w925v.js:176:15)
          speedport.0	2021-03-25 16:16:18.924	error	(3215) Error: Could not find vartype status and status
          speedport.0	2021-03-25 16:16:18.921	error	(3215) Could not find vartype status and status
          Oliver
          • H hacki11
            O Online
            O Online
            Oli
            @hacki11
            Kannst du mit der Datei was anfangen?
            Oliver
            • O Oli
              @hacki11
              hacki11
              @oli ich hatte dir am Sonntag gleich noch zurückgemailt. Der Login fehlt leider, den brauch ich aber zum entschlüsseln. Hast du meine Mails bekommen?
              • H hacki11
                hacki11
                Speedport Smart 3 Support, so gut wie es ohne Gerät ging, implementiert.
                Jetzt bräuchte ich Tester und Logs der Fehlermeldungen.
                • H hacki11
                  O Online
                  O Online
                  Oli
                  @hacki11
                  habe mir gerade die neuste Version installiert.
                  Der Adapter wird nach Eingabe der Daten kurz grün und danach direkt auf gelb.
                  Hier das Log:
                  speedport.0	2021-04-04 18:40:31.039	error	(4574) Connection failed
                  speedport.0	2021-04-04 18:40:31.039	error	at async EngineerMenu.getAll (/opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:55:24)
                  speedport.0	2021-04-04 18:40:31.039	error	at async Promise.all (index 1)
                  speedport.0	2021-04-04 18:40:31.039	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                  speedport.0	2021-04-04 18:40:31.039	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:71:36
                  speedport.0	2021-04-04 18:40:31.039	error	at EngineerMenu.parse (/opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:95:32)
                  speedport.0	2021-04-04 18:40:31.039	error	(4574) TypeError: text.match is not a function
                  speedport.0	2021-04-04 18:40:31.037	error	(4574) text.match is not a function
                  Oliver
                  • O Oli
                    @hacki11
                    Hier das Log:
                    hacki11
                    @oli Bitte den Adapter auf Loglevel Debug stellen, dann kann ich mehr sehn.
                    Aber der Login klappt scheinbar, das würd ich als ersten Erfolg verbuchen!
                    • H hacki11
                      O Online
                      O Online
                      Oli
                      @hacki11
                      hier das Log im Debuglevel
                      speedport.0	2021-04-05 10:49:57.884	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:49:55.682	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:49:55.057	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:49:54.763	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:49:54.696	debug	(32121) Reset Timer
                      speedport.0	2021-04-05 10:49:54.696	error	(32121) Connection failed
                      speedport.0	2021-04-05 10:49:54.695	error	(32121) TypeError: text.match is not a function at EngineerMenu.parse (/opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:95:32) at /opt/iobroker/node_modules/iobroker.speedpor
                      speedport.0	2021-04-05 10:49:54.694	error	(32121) text.match is not a function
                      speedport.0	2021-04-05 10:49:54.693	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:49:54.476	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/module_versions.stm", "method": "get", "data": "password=e54057878c645fbe360220e1b50a256350e61ff69801037e78600a19aed2841c&sh
                      speedport.0	2021-04-05 10:49:54.475	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/mem_cpu_utilization.stm", "method": "get", "data": "password=e54057878c645fbe360220e1b50a256350e61ff69801037e78600a19aed2841
                      speedport.0	2021-04-05 10:49:54.474	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/interfaces_hidden_wan.stm", "method": "get", "data": "password=e54057878c645fbe360220e1b50a256350e61ff69801037e78600a19aed28
                      speedport.0	2021-04-05 10:49:54.473	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/interfaces_hidden_lan.stm", "method": "get", "data": "password=e54057878c645fbe360220e1b50a256350e61ff69801037e78600a19aed28
                      speedport.0	2021-04-05 10:49:54.472	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/dsl_hidden_status.stm", "method": "get", "data": "password=e54057878c645fbe360220e1b50a256350e61ff69801037e78600a19aed2841c&
                      speedport.0	2021-04-05 10:49:54.470	info	(32121) Connection established successfully
                      speedport.0	2021-04-05 10:49:54.469	debug	(32121) Response: [ { "vartype": "status", "varid": "status", "varvalue": "ok" }, { "vartype": "status", "varid": "login", "varvalue": "success" }, { "vartype": "
                      speedport.0	2021-04-05 10:49:54.370	debug	(32121) Starting Request: { "url": "http://speedport.ip/data/Login.json", "method": "post", "data": "password=e54057878c645fbe360220e1b50a256350e61ff69801037e78600a19aed2841c&showpw=0&httoken=60
                      speedport.0	2021-04-05 10:49:54.367	debug	(32121) Response: [ { "vartype": "status", "varid": "status", "varvalue": "ok" }, { "vartype": "value", "varid": "challenge", "varvalue": "5969942AC02F3D6CE047C471C84F578
                      speedport.0	2021-04-05 10:49:54.333	debug	(32121) Starting Request: { "url": "http://speedport.ip/data/Login.json", "method": "post", "data": "getChallenge=1&httoken=602509183", "headers": { "common": { "Accept": "applicatio
                      speedport.0	2021-04-05 10:49:54.331	debug	(32121) Response: "<!DOCTYPE html>\r\n<html>\r\n\r\n<head>\r\n <title>Speedport Konfigurationsprogramm</title>\r\n\r\n <meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\" />\r\n
                      speedport.0	2021-04-05 10:49:54.330	debug	(32121) Response: "<!DOCTYPE html>\r\n<html>\r\n\r\n<head>\r\n <title>Speedport Konfigurationsprogramm</title>\r\n\r\n <meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\" />\r\n
                      speedport.0	2021-04-05 10:49:54.309	debug	(32121) Starting Request: { "url": "http://speedport.ip/html/login/index.html", "method": "get", "headers": { "common": { "Accept": "application/json, text/plain, */*" }, "dele
                      speedport.0	2021-04-05 10:49:54.295	debug	(32121) Starting Request: { "url": "http://speedport.ip", "method": "get", "headers": { "common": { "Accept": "application/json, text/plain, */*" }, "delete": {}, "get": {}
                      speedport.0	2021-04-05 10:48:57.427	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:48:55.282	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:48:54.983	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:48:54.927	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:48:54.294	debug	(32121) Reset Timer
                      speedport.0	2021-04-05 10:48:54.294	error	(32121) Connection failed
                      speedport.0	2021-04-05 10:48:54.294	error	(32121) TypeError: text.match is not a function at EngineerMenu.parse (/opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:95:32) at /opt/iobroker/node_modules/iobroker.speedpor
                      speedport.0	2021-04-05 10:48:54.293	error	(32121) text.match is not a function
                      speedport.0	2021-04-05 10:48:54.292	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:48:54.067	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/module_versions.stm", "method": "get", "data": "password=cdf27813ffa6e9a0ad84002d9b2a0ab1efdab04baea6d940674e0370bcd07770&sh
                      speedport.0	2021-04-05 10:48:54.066	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/mem_cpu_utilization.stm", "method": "get", "data": "password=cdf27813ffa6e9a0ad84002d9b2a0ab1efdab04baea6d940674e0370bcd0777
                      speedport.0	2021-04-05 10:48:54.064	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/interfaces_hidden_wan.stm", "method": "get", "data": "password=cdf27813ffa6e9a0ad84002d9b2a0ab1efdab04baea6d940674e0370bcd07
                      speedport.0	2021-04-05 10:48:54.063	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/interfaces_hidden_lan.stm", "method": "get", "data": "password=cdf27813ffa6e9a0ad84002d9b2a0ab1efdab04baea6d940674e0370bcd07
                      speedport.0	2021-04-05 10:48:54.062	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/dsl_hidden_status.stm", "method": "get", "data": "password=cdf27813ffa6e9a0ad84002d9b2a0ab1efdab04baea6d940674e0370bcd07770&
                      speedport.0	2021-04-05 10:48:54.059	info	(32121) Connection established successfully
                      speedport.0	2021-04-05 10:48:54.058	debug	(32121) Response: [ { "vartype": "status", "varid": "status", "varvalue": "ok" }, { "vartype": "status", "varid": "login", "varvalue": "success" }, { "vartype": "
                      speedport.0	2021-04-05 10:48:53.944	debug	(32121) Starting Request: { "url": "http://speedport.ip/data/Login.json", "method": "post", "data": "password=cdf27813ffa6e9a0ad84002d9b2a0ab1efdab04baea6d940674e0370bcd07770&showpw=0&httoken=85
                      speedport.0	2021-04-05 10:48:53.942	debug	(32121) Response: [ { "vartype": "status", "varid": "status", "varvalue": "ok" }, { "vartype": "value", "varid": "challenge", "varvalue": "46AAE1ECB1B48AF6D5327799F0D3BEF
                      speedport.0	2021-04-05 10:48:53.904	debug	(32121) Starting Request: { "url": "http://speedport.ip/data/Login.json", "method": "post", "data": "getChallenge=1&httoken=855463173", "headers": { "common": { "Accept": "applicatio
                      speedport.0	2021-04-05 10:48:53.902	debug	(32121) Response: "<!DOCTYPE html>\r\n<html>\r\n\r\n<head>\r\n <title>Speedport Konfigurationsprogramm</title>\r\n\r\n <meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\" />\r\n
                      speedport.0	2021-04-05 10:48:53.900	debug	(32121) Response: "<!DOCTYPE html>\r\n<html>\r\n\r\n<head>\r\n <title>Speedport Konfigurationsprogramm</title>\r\n\r\n <meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\" />\r\n
                      speedport.0	2021-04-05 10:48:53.870	debug	(32121) Starting Request: { "url": "http://speedport.ip/html/login/index.html", "method": "get", "headers": { "common": { "Accept": "application/json, text/plain, */*" }, "dele
                      speedport.0	2021-04-05 10:48:53.855	debug	(32121) Starting Request: { "url": "http://speedport.ip", "method": "get", "headers": { "common": { "Accept": "application/json, text/plain, */*" }, "delete": {}, "get": {}
                      speedport.0	2021-04-05 10:47:57.225	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:47:54.916	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:47:54.252	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:47:54.095	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:47:53.855	debug	(32121) Reset Timer
                      speedport.0	2021-04-05 10:47:53.854	error	(32121) Connection failed
                      speedport.0	2021-04-05 10:47:53.854	error	(32121) TypeError: text.match is not a function at EngineerMenu.parse (/opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:95:32) at /opt/iobroker/node_modules/iobroker.speedpor
                      speedport.0	2021-04-05 10:47:53.853	error	(32121) text.match is not a function
                      speedport.0	2021-04-05 10:47:53.852	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:47:53.686	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/module_versions.stm", "method": "get", "data": "password=7e80e66ebf11e24032852d89f2df35c9c9c18ad5a1226bbeeed62e65fd1e2596&sh
                      speedport.0	2021-04-05 10:47:53.685	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/mem_cpu_utilization.stm", "method": "get", "data": "password=7e80e66ebf11e24032852d89f2df35c9c9c18ad5a1226bbeeed62e65fd1e259
                      speedport.0	2021-04-05 10:47:53.685	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/interfaces_hidden_wan.stm", "method": "get", "data": "password=7e80e66ebf11e24032852d89f2df35c9c9c18ad5a1226bbeeed62e65fd1e2
                      speedport.0	2021-04-05 10:47:53.684	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/interfaces_hidden_lan.stm", "method": "get", "data": "password=7e80e66ebf11e24032852d89f2df35c9c9c18ad5a1226bbeeed62e65fd1e2
                      speedport.0	2021-04-05 10:47:53.683	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/dsl_hidden_status.stm", "method": "get", "data": "password=7e80e66ebf11e24032852d89f2df35c9c9c18ad5a1226bbeeed62e65fd1e2596&
                      speedport.0	2021-04-05 10:47:53.680	info	(32121) Connection established successfully
                      speedport.0	2021-04-05 10:47:53.680	debug	(32121) Response: [ { "vartype": "status", "varid": "status", "varvalue": "ok" }, { "vartype": "status", "varid": "login", "varvalue": "success" }, { "vartype": "
                      speedport.0	2021-04-05 10:47:53.586	debug	(32121) Starting Request: { "url": "http://speedport.ip/data/Login.json", "method": "post", "data": "password=7e80e66ebf11e24032852d89f2df35c9c9c18ad5a1226bbeeed62e65fd1e2596&showpw=0&httoken=15
                      speedport.0	2021-04-05 10:47:53.584	debug	(32121) Response: [ { "vartype": "status", "varid": "status", "varvalue": "ok" }, { "vartype": "value", "varid": "challenge", "varvalue": "01AFA3DE0E384A9DD30E2E107E91E97
                      speedport.0	2021-04-05 10:47:53.552	debug	(32121) Starting Request: { "url": "http://speedport.ip/data/Login.json", "method": "post", "data": "getChallenge=1&httoken=1547166306", "headers": { "common": { "Accept": "applicati
                      speedport.0	2021-04-05 10:47:53.550	debug	(32121) Response: "<!DOCTYPE html>\r\n<html>\r\n\r\n<head>\r\n <title>Speedport Konfigurationsprogramm</title>\r\n\r\n <meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\" />\r\n
                      speedport.0	2021-04-05 10:47:53.549	debug	(32121) Response: "<!DOCTYPE html>\r\n<html>\r\n\r\n<head>\r\n <title>Speedport Konfigurationsprogramm</title>\r\n\r\n <meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\" />\r\n
                      speedport.0	2021-04-05 10:47:53.527	debug	(32121) Starting Request: { "url": "http://speedport.ip/html/login/index.html", "method": "get", "headers": { "common": { "Accept": "application/json, text/plain, */*" }, "dele
                      speedport.0	2021-04-05 10:47:53.511	debug	(32121) Starting Request: { "url": "http://speedport.ip", "method": "get", "headers": { "common": { "Accept": "application/json, text/plain, */*" }, "delete": {}, "get": {}
                      speedport.0	2021-04-05 10:46:56.751	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:46:54.726	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:46:53.977	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:46:53.595	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:46:53.509	debug	(32121) Reset Timer
                      speedport.0	2021-04-05 10:46:53.508	error	(32121) Connection failed
                      speedport.0	2021-04-05 10:46:53.508	error	(32121) TypeError: text.match is not a function at EngineerMenu.parse (/opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:95:32) at /opt/iobroker/node_modules/iobroker.speedpor
                      speedport.0	2021-04-05 10:46:53.507	error	(32121) text.match is not a function
                      speedport.0	2021-04-05 10:46:53.506	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:46:53.168	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/module_versions.stm", "method": "get", "data": "password=bb17f2cf873b1b207050303f3937fea25cc841a93ed500a3ee3ced953e3e7bfe&sh
                      speedport.0	2021-04-05 10:46:53.156	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/mem_cpu_utilization.stm", "method": "get", "data": "password=bb17f2cf873b1b207050303f3937fea25cc841a93ed500a3ee3ced953e3e7bf
                      speedport.0	2021-04-05 10:46:53.153	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/interfaces_hidden_wan.stm", "method": "get", "data": "password=bb17f2cf873b1b207050303f3937fea25cc841a93ed500a3ee3ced953e3e7
                      speedport.0	2021-04-05 10:46:53.150	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/interfaces_hidden_lan.stm", "method": "get", "data": "password=bb17f2cf873b1b207050303f3937fea25cc841a93ed500a3ee3ced953e3e7
                      speedport.0	2021-04-05 10:46:53.146	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/dsl_hidden_status.stm", "method": "get", "data": "password=bb17f2cf873b1b207050303f3937fea25cc841a93ed500a3ee3ced953e3e7bfe&
                      speedport.0	2021-04-05 10:46:53.143	info	(32121) Connection established successfully
                      speedport.0	2021-04-05 10:46:53.142	debug	(32121) Response: [ { "vartype": "status", "varid": "status", "varvalue": "ok" }, { "vartype": "status", "varid": "login", "varvalue": "success" }, { "vartype": "
                      speedport.0	2021-04-05 10:46:53.029	debug	(32121) Starting Request: { "url": "http://speedport.ip/data/Login.json", "method": "post", "data": "password=bb17f2cf873b1b207050303f3937fea25cc841a93ed500a3ee3ced953e3e7bfe&showpw=0&httoken=14
                      speedport.0	2021-04-05 10:46:53.027	debug	(32121) Response: [ { "vartype": "status", "varid": "status", "varvalue": "ok" }, { "vartype": "value", "varid": "challenge", "varvalue": "AAE1C850B9335C2D8606B369A534265
                      speedport.0	2021-04-05 10:46:52.986	debug	(32121) Starting Request: { "url": "http://speedport.ip/data/Login.json", "method": "post", "data": "getChallenge=1&httoken=1404093116", "headers": { "common": { "Accept": "applicati
                      speedport.0	2021-04-05 10:46:52.982	debug	(32121) Response: "<!DOCTYPE html>\r\n<html>\r\n\r\n<head>\r\n <title>Speedport Konfigurationsprogramm</title>\r\n\r\n <meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\" />\r\n
                      speedport.0	2021-04-05 10:46:52.979	debug	(32121) Response: "<!DOCTYPE html>\r\n<html>\r\n\r\n<head>\r\n <title>Speedport Konfigurationsprogramm</title>\r\n\r\n <meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\" />\r\n
                      speedport.0	2021-04-05 10:46:52.951	debug	(32121) Starting Request: { "url": "http://speedport.ip/html/login/index.html", "method": "get", "headers": { "common": { "Accept": "application/json, text/plain, */*" }, "dele
                      speedport.0	2021-04-05 10:46:52.933	debug	(32121) Starting Request: { "url": "http://speedport.ip", "method": "get", "headers": { "common": { "Accept": "application/json, text/plain, */*" }, "delete": {}, "get": {}
                      speedport.0	2021-04-05 10:45:56.120	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:45:54.154	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:45:53.403	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:45:53.257	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:45:52.933	debug	(32121) Reset Timer
                      speedport.0	2021-04-05 10:45:52.932	error	(32121) Connection failed
                      speedport.0	2021-04-05 10:45:52.932	error	(32121) TypeError: text.match is not a function at EngineerMenu.parse (/opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:95:32) at /opt/iobroker/node_modules/iobroker.speedpor
                      speedport.0	2021-04-05 10:45:52.931	error	(32121) text.match is not a function
                      speedport.0	2021-04-05 10:45:52.930	debug	(32121) Response: []
                      speedport.0	2021-04-05 10:45:52.566	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/module_versions.stm", "method": "get", "data": "password=b86aeaf9a3c431bbf316727d6f44cc96fa13a0aa087ecfe46f26734a702ff59a&sh
                      speedport.0	2021-04-05 10:45:52.565	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/mem_cpu_utilization.stm", "method": "get", "data": "password=b86aeaf9a3c431bbf316727d6f44cc96fa13a0aa087ecfe46f26734a702ff59
                      speedport.0	2021-04-05 10:45:52.565	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/interfaces_hidden_wan.stm", "method": "get", "data": "password=b86aeaf9a3c431bbf316727d6f44cc96fa13a0aa087ecfe46f26734a702ff
                      speedport.0	2021-04-05 10:45:52.564	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/interfaces_hidden_lan.stm", "method": "get", "data": "password=b86aeaf9a3c431bbf316727d6f44cc96fa13a0aa087ecfe46f26734a702ff
                      speedport.0	2021-04-05 10:45:52.563	debug	(32121) Starting Request: { "url": "http://speedport.ip/engineer/html/dsl_hidden_status.stm", "method": "get", "data": "password=b86aeaf9a3c431bbf316727d6f44cc96fa13a0aa087ecfe46f26734a702ff59a&
                      speedport.0	2021-04-05 10:45:52.559	info	(32121) Connection established successfully
                      speedport.0	2021-04-05 10:45:52.559	debug	(32121) Response: [ { "vartype": "status", "varid": "status", "varvalue": "ok" }, { "vartype": "status", "varid": "login", "varvalue": "success" }, { "vartype": "
                      speedport.0	2021-04-05 10:45:52.426	debug	(32121) Starting Request: { "url": "http://speedport.ip/data/Login.json", "method": "post", "data": "password=b86aeaf9a3c431bbf316727d6f44cc96fa13a0aa087ecfe46f26734a702ff59a&showpw=0&httoken=20
                      speedport.0	2021-04-05 10:45:52.419	debug	(32121) Response: [ { "vartype": "status", "varid": "status", "varvalue": "ok" }, { "vartype": "value", "varid": "challenge", "varvalue": "F99BE82B80096D0031FE0EABE2254C0
                      speedport.0	2021-04-05 10:45:52.356	debug	(32121) Starting Request: { "url": "http://speedport.ip/data/Login.json", "method": "post", "data": "getChallenge=1&httoken=2022548764", "headers": { "common": { "Accept": "applicati
                      speedport.0	2021-04-05 10:45:52.351	debug	(32121) Response: "<!DOCTYPE html>\r\n<html>\r\n\r\n<head>\r\n <title>Speedport Konfigurationsprogramm</title>\r\n\r\n <meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\" />\r\n
                      speedport.0	2021-04-05 10:45:52.347	debug	(32121) Response: "<!DOCTYPE html>\r\n<html>\r\n\r\n<head>\r\n <title>Speedport Konfigurationsprogramm</title>\r\n\r\n <meta http-equiv=\"content-type\" content=\"text/html; charset=utf-8\" />\r\n
                      speedport.0	2021-04-05 10:45:52.313	debug	(32121) Starting Request: { "url": "http://speedport.ip/html/login/index.html", "method": "get", "headers": { "common": { "Accept": "application/json, text/plain, */*" }, "dele
                      speedport.0	2021-04-05 10:45:52.293	debug	(32121) Starting Request: { "url": "http://speedport.ip", "method": "get", "headers": { "common": { "Accept": "application/json, text/plain, */*" }, "delete": {}, "get": {}
                      speedport.0	2021-04-05 10:44:55.457	debug	[]
                      speedport.0	2021-04-05 10:44:55.457	debug	(32121) Response:
                      speedport.0	2021-04-05 10:44:53.417	debug	[]
                      speedport.0	2021-04-05 10:44:53.417	debug	(32121) Response:
                      speedport.0	2021-04-05 10:44:52.723	debug	[]
                      speedport.0	2021-04-05 10:44:52.723	debug	(32121) Response:
                      speedport.0	2021-04-05 10:44:52.371	debug	[]
                      speedport.0	2021-04-05 10:44:52.371	debug	(32121) Response:
                      speedport.0	2021-04-05 10:44:52.290	debug	(32121) Reset Timer
                      speedport.0	2021-04-05 10:44:52.290	error	(32121) Connection failed
                      speedport.0	2021-04-05 10:44:52.289	error	at async EngineerMenu.getAll (/opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:55:24)
                      speedport.0	2021-04-05 10:44:52.289	error	at async Promise.all (index 1)
                      speedport.0	2021-04-05 10:44:52.289	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                      speedport.0	2021-04-05 10:44:52.289	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:71:36
                      speedport.0	2021-04-05 10:44:52.289	error	at EngineerMenu.parse (/opt/iobroker/node_modules/iobroker.speedport/lib/engineer_menu.js:95:32)
                      speedport.0	2021-04-05 10:44:52.289	error	(32121) TypeError: text.match is not a function
                      speedport.0	2021-04-05 10:44:52.288	error	(32121) text.match is not a function
                      speedport.0	2021-04-05 10:44:52.286	debug	[]
                      speedport.0	2021-04-05 10:44:52.286	debug	(32121) Response:
                      speedport.0	2021-04-05 10:44:52.007	debug	}
                      speedport.0	2021-04-05 10:44:52.007	debug	]
                      speedport.0	2021-04-05 10:44:52.007	debug	"lastAccessed": "2021-04-05T08:44:51.994Z"
                      speedport.0	2021-04-05 10:44:52.007	debug	"creation": "2021-04-05T08:44:51.993Z",
                      speedport.0	2021-04-05 10:44:52.007	debug	"hostOnly": true,
                      speedport.0	2021-04-05 10:44:52.007	debug	"httpOnly": true,
                      speedport.0	2021-04-05 10:44:52.007	debug	"path": "/",
                      speedport.0	2021-04-05 10:44:52.007	debug	"domain": "speedport.ip",
                      speedport.0	2021-04-05 10:44:52.007	debug	"value": "PGxVGEQ7yRgg5tubTyiSaRxocqWhGtjhKZO3UlTO9LWvrK#o75_Wap3TokSlKDQ",
                      speedport.0	2021-04-05 10:44:52.007	debug	"key": "aDuPtHhDA8023ae2993f",
                      speedport.0	2021-04-05 10:44:52.007	debug	{
                      speedport.0	2021-04-05 10:44:52.007	debug	"cookies": [
                      speedport.0	2021-04-05 10:44:52.007	debug	"rejectPublicSuffixes": true,
                      speedport.0	2021-04-05 10:44:52.007	debug	"storeType": "MemoryCookieStore",
                      speedport.0	2021-04-05 10:44:52.007	debug	"version": "tough-cookie@4.0.0",
                      speedport.0	2021-04-05 10:44:52.007	debug	"jar": {
                      speedport.0	2021-04-05 10:44:52.007	debug	"maxBodyLength": -1,
                      speedport.0	2021-04-05 10:44:52.007	debug	"maxContentLength": -1,
                      speedport.0	2021-04-05 10:44:52.007	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:52.007	debug	"xsrfCookieName": "XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:52.007	debug	"withCredentials": true,
                      speedport.0	2021-04-05 10:44:52.007	debug	"timeout": 0,
                      speedport.0	2021-04-05 10:44:52.007	debug	},
                      speedport.0	2021-04-05 10:44:52.007	debug	"Content-Type": "application/x-www-form-urlencoded"
                      speedport.0	2021-04-05 10:44:52.007	debug	"patch": {
                      speedport.0	2021-04-05 10:44:52.007	debug	"put": {
                      speedport.0	2021-04-05 10:44:52.007	debug	"post": {
                      speedport.0	2021-04-05 10:44:52.007	debug	"head": {},
                      speedport.0	2021-04-05 10:44:52.007	debug	"get": {},
                      speedport.0	2021-04-05 10:44:52.007	debug	"delete": {},
                      speedport.0	2021-04-05 10:44:52.007	debug	"Accept": "application/json, text/plain, */*"
                      speedport.0	2021-04-05 10:44:52.007	debug	"common": {
                      speedport.0	2021-04-05 10:44:52.007	debug	"headers": {
                      speedport.0	2021-04-05 10:44:52.007	debug	"data": "password=7c0a1621cb5d38b336dc2ff1c8df5e6dd77a14aa1296dd3d22c7d00c604299b2&showpw=0&httoken=1952788595",
                      speedport.0	2021-04-05 10:44:52.007	debug	"method": "get",
                      speedport.0	2021-04-05 10:44:52.007	debug	"url": "http://speedport.ip/engineer/html/module_versions.stm",
                      speedport.0	2021-04-05 10:44:52.007	debug	(32121) Starting Request:
                      speedport.0	2021-04-05 10:44:52.006	debug	}
                      speedport.0	2021-04-05 10:44:52.006	debug	]
                      speedport.0	2021-04-05 10:44:52.006	debug	"lastAccessed": "2021-04-05T08:44:51.994Z"
                      speedport.0	2021-04-05 10:44:52.006	debug	"creation": "2021-04-05T08:44:51.993Z",
                      speedport.0	2021-04-05 10:44:52.006	debug	"hostOnly": true,
                      speedport.0	2021-04-05 10:44:52.006	debug	"httpOnly": true,
                      speedport.0	2021-04-05 10:44:52.006	debug	"path": "/",
                      speedport.0	2021-04-05 10:44:52.006	debug	"domain": "speedport.ip",
                      speedport.0	2021-04-05 10:44:52.006	debug	"value": "PGxVGEQ7yRgg5tubTyiSaRxocqWhGtjhKZO3UlTO9LWvrK#o75_Wap3TokSlKDQ",
                      speedport.0	2021-04-05 10:44:52.006	debug	"key": "aDuPtHhDA8023ae2993f",
                      speedport.0	2021-04-05 10:44:52.006	debug	{
                      speedport.0	2021-04-05 10:44:52.006	debug	"cookies": [
                      speedport.0	2021-04-05 10:44:52.006	debug	"rejectPublicSuffixes": true,
                      speedport.0	2021-04-05 10:44:52.006	debug	"storeType": "MemoryCookieStore",
                      speedport.0	2021-04-05 10:44:52.006	debug	"version": "tough-cookie@4.0.0",
                      speedport.0	2021-04-05 10:44:52.006	debug	"jar": {
                      speedport.0	2021-04-05 10:44:52.006	debug	"maxBodyLength": -1,
                      speedport.0	2021-04-05 10:44:52.006	debug	"maxContentLength": -1,
                      speedport.0	2021-04-05 10:44:52.006	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:52.006	debug	"xsrfCookieName": "XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:52.006	debug	"withCredentials": true,
                      speedport.0	2021-04-05 10:44:52.006	debug	"timeout": 0,
                      speedport.0	2021-04-05 10:44:52.006	debug	},
                      speedport.0	2021-04-05 10:44:52.006	debug	"Content-Type": "application/x-www-form-urlencoded"
                      speedport.0	2021-04-05 10:44:52.006	debug	"patch": {
                      speedport.0	2021-04-05 10:44:52.006	debug	"put": {
                      speedport.0	2021-04-05 10:44:52.006	debug	"post": {
                      speedport.0	2021-04-05 10:44:52.006	debug	"head": {},
                      speedport.0	2021-04-05 10:44:52.006	debug	"get": {},
                      speedport.0	2021-04-05 10:44:52.006	debug	"delete": {},
                      speedport.0	2021-04-05 10:44:52.006	debug	"Accept": "application/json, text/plain, */*"
                      speedport.0	2021-04-05 10:44:52.006	debug	"common": {
                      speedport.0	2021-04-05 10:44:52.006	debug	"headers": {
                      speedport.0	2021-04-05 10:44:52.006	debug	"data": "password=7c0a1621cb5d38b336dc2ff1c8df5e6dd77a14aa1296dd3d22c7d00c604299b2&showpw=0&httoken=1952788595",
                      speedport.0	2021-04-05 10:44:52.006	debug	"method": "get",
                      speedport.0	2021-04-05 10:44:52.006	debug	"url": "http://speedport.ip/engineer/html/mem_cpu_utilization.stm",
                      speedport.0	2021-04-05 10:44:52.006	debug	(32121) Starting Request:
                      speedport.0	2021-04-05 10:44:52.005	debug	}
                      speedport.0	2021-04-05 10:44:52.005	debug	]
                      speedport.0	2021-04-05 10:44:52.005	debug	"lastAccessed": "2021-04-05T08:44:51.994Z"
                      speedport.0	2021-04-05 10:44:52.005	debug	"creation": "2021-04-05T08:44:51.993Z",
                      speedport.0	2021-04-05 10:44:52.005	debug	"hostOnly": true,
                      speedport.0	2021-04-05 10:44:52.005	debug	"httpOnly": true,
                      speedport.0	2021-04-05 10:44:52.005	debug	"path": "/",
                      speedport.0	2021-04-05 10:44:52.005	debug	"domain": "speedport.ip",
                      speedport.0	2021-04-05 10:44:52.005	debug	"value": "PGxVGEQ7yRgg5tubTyiSaRxocqWhGtjhKZO3UlTO9LWvrK#o75_Wap3TokSlKDQ",
                      speedport.0	2021-04-05 10:44:52.005	debug	"key": "aDuPtHhDA8023ae2993f",
                      speedport.0	2021-04-05 10:44:52.005	debug	{
                      speedport.0	2021-04-05 10:44:52.005	debug	"cookies": [
                      speedport.0	2021-04-05 10:44:52.005	debug	"rejectPublicSuffixes": true,
                      speedport.0	2021-04-05 10:44:52.005	debug	"storeType": "MemoryCookieStore",
                      speedport.0	2021-04-05 10:44:52.005	debug	"version": "tough-cookie@4.0.0",
                      speedport.0	2021-04-05 10:44:52.005	debug	"jar": {
                      speedport.0	2021-04-05 10:44:52.005	debug	"maxBodyLength": -1,
                      speedport.0	2021-04-05 10:44:52.005	debug	"maxContentLength": -1,
                      speedport.0	2021-04-05 10:44:52.005	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:52.005	debug	"xsrfCookieName": "XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:52.005	debug	"withCredentials": true,
                      speedport.0	2021-04-05 10:44:52.005	debug	"timeout": 0,
                      speedport.0	2021-04-05 10:44:52.005	debug	},
                      speedport.0	2021-04-05 10:44:52.005	debug	"Content-Type": "application/x-www-form-urlencoded"
                      speedport.0	2021-04-05 10:44:52.005	debug	"patch": {
                      speedport.0	2021-04-05 10:44:52.005	debug	"put": {
                      speedport.0	2021-04-05 10:44:52.005	debug	"post": {
                      speedport.0	2021-04-05 10:44:52.005	debug	"head": {},
                      speedport.0	2021-04-05 10:44:52.005	debug	"get": {},
                      speedport.0	2021-04-05 10:44:52.005	debug	"delete": {},
                      speedport.0	2021-04-05 10:44:52.005	debug	"Accept": "application/json, text/plain, */*"
                      speedport.0	2021-04-05 10:44:52.005	debug	"common": {
                      speedport.0	2021-04-05 10:44:52.005	debug	"headers": {
                      speedport.0	2021-04-05 10:44:52.005	debug	"data": "password=7c0a1621cb5d38b336dc2ff1c8df5e6dd77a14aa1296dd3d22c7d00c604299b2&showpw=0&httoken=1952788595",
                      speedport.0	2021-04-05 10:44:52.005	debug	"method": "get",
                      speedport.0	2021-04-05 10:44:52.005	debug	"url": "http://speedport.ip/engineer/html/interfaces_hidden_wan.stm",
                      speedport.0	2021-04-05 10:44:52.005	debug	(32121) Starting Request:
                      speedport.0	2021-04-05 10:44:52.004	debug	}
                      speedport.0	2021-04-05 10:44:52.004	debug	]
                      speedport.0	2021-04-05 10:44:52.004	debug	"lastAccessed": "2021-04-05T08:44:51.994Z"
                      speedport.0	2021-04-05 10:44:52.004	debug	"creation": "2021-04-05T08:44:51.993Z",
                      speedport.0	2021-04-05 10:44:52.004	debug	"hostOnly": true,
                      speedport.0	2021-04-05 10:44:52.004	debug	"httpOnly": true,
                      speedport.0	2021-04-05 10:44:52.004	debug	"path": "/",
                      speedport.0	2021-04-05 10:44:52.004	debug	"domain": "speedport.ip",
                      speedport.0	2021-04-05 10:44:52.004	debug	"value": "PGxVGEQ7yRgg5tubTyiSaRxocqWhGtjhKZO3UlTO9LWvrK#o75_Wap3TokSlKDQ",
                      speedport.0	2021-04-05 10:44:52.004	debug	"key": "aDuPtHhDA8023ae2993f",
                      speedport.0	2021-04-05 10:44:52.004	debug	{
                      speedport.0	2021-04-05 10:44:52.004	debug	"cookies": [
                      speedport.0	2021-04-05 10:44:52.004	debug	"rejectPublicSuffixes": true,
                      speedport.0	2021-04-05 10:44:52.004	debug	"storeType": "MemoryCookieStore",
                      speedport.0	2021-04-05 10:44:52.004	debug	"version": "tough-cookie@4.0.0",
                      speedport.0	2021-04-05 10:44:52.004	debug	"jar": {
                      speedport.0	2021-04-05 10:44:52.004	debug	"maxBodyLength": -1,
                      speedport.0	2021-04-05 10:44:52.004	debug	"maxContentLength": -1,
                      speedport.0	2021-04-05 10:44:52.004	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:52.004	debug	"xsrfCookieName": "XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:52.004	debug	"withCredentials": true,
                      speedport.0	2021-04-05 10:44:52.004	debug	"timeout": 0,
                      speedport.0	2021-04-05 10:44:52.004	debug	},
                      speedport.0	2021-04-05 10:44:52.004	debug	"Content-Type": "application/x-www-form-urlencoded"
                      speedport.0	2021-04-05 10:44:52.004	debug	"patch": {
                      speedport.0	2021-04-05 10:44:52.004	debug	"put": {
                      speedport.0	2021-04-05 10:44:52.004	debug	"post": {
                      speedport.0	2021-04-05 10:44:52.004	debug	"head": {},
                      speedport.0	2021-04-05 10:44:52.004	debug	"get": {},
                      speedport.0	2021-04-05 10:44:52.004	debug	"delete": {},
                      speedport.0	2021-04-05 10:44:52.004	debug	"Accept": "application/json, text/plain, */*"
                      speedport.0	2021-04-05 10:44:52.004	debug	"common": {
                      speedport.0	2021-04-05 10:44:52.004	debug	"headers": {
                      speedport.0	2021-04-05 10:44:52.004	debug	"data": "password=7c0a1621cb5d38b336dc2ff1c8df5e6dd77a14aa1296dd3d22c7d00c604299b2&showpw=0&httoken=1952788595",
                      speedport.0	2021-04-05 10:44:52.004	debug	"method": "get",
                      speedport.0	2021-04-05 10:44:52.004	debug	"url": "http://speedport.ip/engineer/html/interfaces_hidden_lan.stm",
                      speedport.0	2021-04-05 10:44:52.004	debug	(32121) Starting Request:
                      speedport.0	2021-04-05 10:44:52.002	debug	}
                      speedport.0	2021-04-05 10:44:52.002	debug	]
                      speedport.0	2021-04-05 10:44:52.002	debug	"lastAccessed": "2021-04-05T08:44:51.994Z"
                      speedport.0	2021-04-05 10:44:52.002	debug	"creation": "2021-04-05T08:44:51.993Z",
                      speedport.0	2021-04-05 10:44:52.002	debug	"hostOnly": true,
                      speedport.0	2021-04-05 10:44:52.002	debug	"httpOnly": true,
                      speedport.0	2021-04-05 10:44:52.002	debug	"path": "/",
                      speedport.0	2021-04-05 10:44:52.002	debug	"domain": "speedport.ip",
                      speedport.0	2021-04-05 10:44:52.002	debug	"value": "PGxVGEQ7yRgg5tubTyiSaRxocqWhGtjhKZO3UlTO9LWvrK#o75_Wap3TokSlKDQ",
                      speedport.0	2021-04-05 10:44:52.002	debug	"key": "aDuPtHhDA8023ae2993f",
                      speedport.0	2021-04-05 10:44:52.002	debug	{
                      speedport.0	2021-04-05 10:44:52.002	debug	"cookies": [
                      speedport.0	2021-04-05 10:44:52.002	debug	"rejectPublicSuffixes": true,
                      speedport.0	2021-04-05 10:44:52.002	debug	"storeType": "MemoryCookieStore",
                      speedport.0	2021-04-05 10:44:52.002	debug	"version": "tough-cookie@4.0.0",
                      speedport.0	2021-04-05 10:44:52.002	debug	"jar": {
                      speedport.0	2021-04-05 10:44:52.002	debug	"maxBodyLength": -1,
                      speedport.0	2021-04-05 10:44:52.002	debug	"maxContentLength": -1,
                      speedport.0	2021-04-05 10:44:52.002	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:52.002	debug	"xsrfCookieName": "XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:52.002	debug	"withCredentials": true,
                      speedport.0	2021-04-05 10:44:52.002	debug	"timeout": 0,
                      speedport.0	2021-04-05 10:44:52.002	debug	},
                      speedport.0	2021-04-05 10:44:52.002	debug	"Content-Type": "application/x-www-form-urlencoded"
                      speedport.0	2021-04-05 10:44:52.002	debug	"patch": {
                      speedport.0	2021-04-05 10:44:52.002	debug	"put": {
                      speedport.0	2021-04-05 10:44:52.002	debug	"post": {
                      speedport.0	2021-04-05 10:44:52.002	debug	"head": {},
                      speedport.0	2021-04-05 10:44:52.002	debug	"get": {},
                      speedport.0	2021-04-05 10:44:52.002	debug	"delete": {},
                      speedport.0	2021-04-05 10:44:52.002	debug	"Accept": "application/json, text/plain, */*"
                      speedport.0	2021-04-05 10:44:52.002	debug	"common": {
                      speedport.0	2021-04-05 10:44:52.002	debug	"headers": {
                      speedport.0	2021-04-05 10:44:52.002	debug	"data": "password=7c0a1621cb5d38b336dc2ff1c8df5e6dd77a14aa1296dd3d22c7d00c604299b2&showpw=0&httoken=1952788595",
                      speedport.0	2021-04-05 10:44:52.002	debug	"method": "get",
                      speedport.0	2021-04-05 10:44:52.002	debug	"url": "http://speedport.ip/engineer/html/dsl_hidden_status.stm",
                      speedport.0	2021-04-05 10:44:52.002	debug	(32121) Starting Request:
                      speedport.0	2021-04-05 10:44:51.995	info	(32121) Connection established successfully
                      speedport.0	2021-04-05 10:44:51.994	debug	]
                      speedport.0	2021-04-05 10:44:51.994	debug	}
                      speedport.0	2021-04-05 10:44:51.994	debug	"varvalue": ""
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "acsredir",
                      speedport.0	2021-04-05 10:44:51.994	debug	"vartype": "value",
                      speedport.0	2021-04-05 10:44:51.994	debug	{
                      speedport.0	2021-04-05 10:44:51.994	debug	},
                      speedport.0	2021-04-05 10:44:51.994	debug	"varvalue": "1"
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "acsreach",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "bngscrat",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "t_password",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "t_number",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "t_callident",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varvalue": "0"
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "other_dt",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varvalue": "99"
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "inet_isp",
                      speedport.0	2021-04-05 10:44:51.994	debug	"vartype": "option",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "isp_selection",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "wlanFinished",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "phoneFinished",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "internetFinished",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "dontstartAssist",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "askAssist",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "ap_mode",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varvalue": "online"
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "dsl_link_status",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "save_fails",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varvalue": "004"
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "provis_voip",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varvalue": "044"
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "provis_inet",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varvalue": "OK"
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "router_state",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varvalue": "success"
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "login",
                      speedport.0	2021-04-05 10:44:51.994	debug	"vartype": "status",
                      speedport.0	2021-04-05 10:44:51.994	debug	"varvalue": "ok"
                      speedport.0	2021-04-05 10:44:51.994	debug	"varid": "status",
                      speedport.0	2021-04-05 10:44:51.994	debug	[
                      speedport.0	2021-04-05 10:44:51.994	debug	(32121) Response:
                      speedport.0	2021-04-05 10:44:51.871	debug	}
                      speedport.0	2021-04-05 10:44:51.871	debug	"cookies": []
                      speedport.0	2021-04-05 10:44:51.871	debug	"rejectPublicSuffixes": true,
                      speedport.0	2021-04-05 10:44:51.871	debug	"storeType": "MemoryCookieStore",
                      speedport.0	2021-04-05 10:44:51.871	debug	"version": "tough-cookie@4.0.0",
                      speedport.0	2021-04-05 10:44:51.871	debug	"jar": {
                      speedport.0	2021-04-05 10:44:51.871	debug	"maxBodyLength": -1,
                      speedport.0	2021-04-05 10:44:51.871	debug	"maxContentLength": -1,
                      speedport.0	2021-04-05 10:44:51.871	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:51.871	debug	"xsrfCookieName": "XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:51.871	debug	"withCredentials": true,
                      speedport.0	2021-04-05 10:44:51.871	debug	"timeout": 0,
                      speedport.0	2021-04-05 10:44:51.871	debug	},
                      speedport.0	2021-04-05 10:44:51.871	debug	"Content-Type": "application/x-www-form-urlencoded"
                      speedport.0	2021-04-05 10:44:51.871	debug	"patch": {
                      speedport.0	2021-04-05 10:44:51.871	debug	"put": {
                      speedport.0	2021-04-05 10:44:51.871	debug	"post": {
                      speedport.0	2021-04-05 10:44:51.871	debug	"head": {},
                      speedport.0	2021-04-05 10:44:51.871	debug	"get": {},
                      speedport.0	2021-04-05 10:44:51.871	debug	"delete": {},
                      speedport.0	2021-04-05 10:44:51.871	debug	"Accept": "application/json, text/plain, */*"
                      speedport.0	2021-04-05 10:44:51.871	debug	"common": {
                      speedport.0	2021-04-05 10:44:51.871	debug	"headers": {
                      speedport.0	2021-04-05 10:44:51.871	debug	"data": "password=7c0a1621cb5d38b336dc2ff1c8df5e6dd77a14aa1296dd3d22c7d00c604299b2&showpw=0&httoken=1952788595",
                      speedport.0	2021-04-05 10:44:51.871	debug	"method": "post",
                      speedport.0	2021-04-05 10:44:51.871	debug	"url": "http://speedport.ip/data/Login.json",
                      speedport.0	2021-04-05 10:44:51.871	debug	{
                      speedport.0	2021-04-05 10:44:51.871	debug	(32121) Starting Request:
                      speedport.0	2021-04-05 10:44:51.867	debug	]
                      speedport.0	2021-04-05 10:44:51.867	debug	}
                      speedport.0	2021-04-05 10:44:51.867	debug	"varvalue": "0E19AEB4C1B22D6436DAF03959968EC8DC7A9586999840DFB5324100E8925249"
                      speedport.0	2021-04-05 10:44:51.867	debug	"varid": "challenge",
                      speedport.0	2021-04-05 10:44:51.867	debug	"vartype": "value",
                      speedport.0	2021-04-05 10:44:51.867	debug	{
                      speedport.0	2021-04-05 10:44:51.867	debug	},
                      speedport.0	2021-04-05 10:44:51.867	debug	"varvalue": "ok"
                      speedport.0	2021-04-05 10:44:51.867	debug	"varid": "status",
                      speedport.0	2021-04-05 10:44:51.867	debug	"vartype": "status",
                      speedport.0	2021-04-05 10:44:51.867	debug	[
                      speedport.0	2021-04-05 10:44:51.867	debug	(32121) Response:
                      speedport.0	2021-04-05 10:44:51.609	debug	}
                      speedport.0	2021-04-05 10:44:51.609	debug	"cookies": []
                      speedport.0	2021-04-05 10:44:51.609	debug	"rejectPublicSuffixes": true,
                      speedport.0	2021-04-05 10:44:51.609	debug	"storeType": "MemoryCookieStore",
                      speedport.0	2021-04-05 10:44:51.609	debug	"version": "tough-cookie@4.0.0",
                      speedport.0	2021-04-05 10:44:51.609	debug	"jar": {
                      speedport.0	2021-04-05 10:44:51.609	debug	"maxBodyLength": -1,
                      speedport.0	2021-04-05 10:44:51.609	debug	"maxContentLength": -1,
                      speedport.0	2021-04-05 10:44:51.609	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:51.609	debug	"xsrfCookieName": "XSRF-TOKEN",
                      speedport.0	2021-04-05 10:44:51.609	debug	"withCredentials": true,
                      speedport.0	2021-04-05 10:44:51.609	debug	"timeout": 0,
                      speedport.0	2021-04-05 10:44:51.609	debug	},
                      speedport.0	2021-04-05 10:44:51.609	debug	"Content-Type": "application/x-www-form-urlencoded"
                      speedport.0	2021-04-05 10:44:51.609	debug	"patch": {
                      speedport.0	2021-04-05 10:44:51.609	debug	"put": {
                      speedport.0	2021-04-05 10:44:51.609	debug	"post": {
                      speedport.0	2021-04-05 10:44:51.609	debug	"head": {},
                      speedport.0	2021-04-05 10:44:51.609	debug	"get": {},
                      speedport.0	2021-04-05 10:44:51.609	debug	"delete": {},
                      speedport.0	2021-04-05 10:44:51.609	debug	"Accept": "application/json, text/plain, */*"
                      speedport.0	2021-04-05 10:44:51.609	debug	"common": {
                      speedport.0	2021-04-05 10:44:51.609	debug	"headers": {
                      speedport.0	2021-04-05 10:44:51.609	debug	"data": "getChallenge=1&httoken=1952788595",
                      speedport.0	2021-04-05 10:44:51.609	debug	"method": "post",
                      speedport.0	2021-04-05 10:44:51.609	debug	"url": "http://speedport.ip/data/Login.json",
                      speedport.0	2021-04-05 10:44:51.609	debug	{
                      speedport.0	2021-04-05 10:44:51.609	debug	(32121) Starting Request:
                      Oliver
                      • O Oli
                        @hacki11
                        hacki11
                        @oli Login klappt, aber auf die Anfragen der geheimen Menüs kommt keine Antwort.
                        Entweder ich frage falsch an, oder die Menüs existieren gar nicht.
                        Ich hab nochmal eine kleine Änderung vorgenommen, glaube aber nicht, dass es das Problem löst.
                        D.h. ich bräuchte leider tatsächlich den Trace mit den Aufrufen der geheimen Menüs inkl. Login. (Gerne auch mit Screenshots damit ich sehe wie die Elemente heißen.
                        • H hacki11
                          O Online
                          O Online
                          Oli
                          @hacki11
                          ich habe dir eine neue Aufzeichnung geschickt
                          Oliver
                          • O Oli
                            @hacki11
                            hacki11
                            @oli Perfekt, alles da.
                            Es ist tatsächlich ein gänzlich anderes "geheimes" Menü als beim W925V.
                            Ich werd mal beginnen ein paar Objekte auszulesen.
                            • H hacki11
                              O Online
                              O Online
                              Oli
                              @hacki11
                              super, wenn du noch etwas brauchst, sagt einfach bescheid.
                              Oliver
                                tazdevil20
                                ich bekomme diese Woche einen Speedport Hybrid. Würde hier auch gerne entsprechende Werte auslesen. Kannst Du die Bibliothek aus dem zweiten Post mit einbinden oder kann ich dir dann auch einen Trace oder ähnliches zur Verfügung stellen?
                                Taz
                                • T tazdevil20
                                  Taz
                                  hacki11
                                  @tazdevil20
                                  Ich benötige einen Wireshark Trace während ihr euch anmeldet und die "geheimen" Menüs durchsurft.
                                  So geht das:
                                  1. Wireshark (https://www.wireshark.org/) starten und Aufzeichnung auf richtigem Interface beginnen
                                  2. Cookies löschen oder Inkognito Modus verwenden
                                  3. Speedport im Browser aufrufen und einloggen
                                  4. Die geheimen Menüs aus https://telekomhilft.telekom.de/t5/Geraete-Zubehoer/Speedport-Router-Hidden-Menues/ta-5) p/3101743 oder https://www.onlinekosten.de/forum/showthread.php?t=145605 aufrufen und am besten alle Einträge anklicken und laden lassen.
                                  5. Am besten Screenshots jeder Seite anfertigen und unter dem Namen des Menüs speichern.
                                  6. Trace und Screenshots speichern und mit Passwort zippen
                                  7. Mir zukommen lassen
                                  Anschließend kann ich prüfen, ob man die Lib von oben noch nutzen kann. Falls nicht fällt reverse Engineering an und eine Nachimplementierung.
                                  Euer Passwort wird übrigens gesaltet gehasht und ist für mich trotz unverschlüsseltem HTTP nicht sichbar!
                                  Was ich jedoch sehe, ist das WLAN Passwort.
                                  • O Oli
                                    @hacki11
                                    hacki11
                                    @oli Die Screenshots der einzelnen Seiten wäre noch gut. Nur so kann ich die gleichen Namen wie auf der Seite verwenden. Das aus dem Trace zu lesen ist ein bisschen umständlich.
                                    Ich habe soeben einen neuen Stand gepusht. Bitte erneut testen und debug log zur Verfügung stellen.
                                    • H hacki11
                                      O Online
                                      O Online
                                      Oli
                                      @hacki11
                                      anbei die Screenshots
                                      Ich hoffe ich habe alle, falls noch was fehlt, einfach melden.
                                      Danke schon mal im voraus für deine Arbeit, die du hier investierst,
                                      Oliver
                                      • O Oli
                                        @hacki11
                                        hacki11
                                        @oli Top Danke.
                                        Nur um auf Nummer sicher zu gehen. Wenn du auf http://speedport.ip/engineer/html/version.html gehst, dann kommst du auch auf eine Seite aus deinem Screenshot, oder?
                                        Quasi:
                                        1. Anmelden am Speedport
                                        2. URL in Browser kopieren und aufrufen
                                        • H hacki11
                                          @oli Top Danke.
                                          Quasi:
                                          O Online
                                          O Online
                                          Oli
                                          @hacki11
                                          ja teilweise, alles ist nicht dabei, die Anruflisten fehlen zB.
                                          hier mal das Log
                                           speedport.0	2021-04-06 21:45:30.762	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:45:30.761	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:45:30.761	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:45:30.761	error	at runMicrotasks (<anonymous>)
                                          speedport.0	2021-04-06 21:45:30.761	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:45:30.761	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:45:30.760	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:45:30.760	debug	[]
                                          speedport.0	2021-04-06 21:45:30.760	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:45:30.759	debug	[]
                                          speedport.0	2021-04-06 21:45:30.759	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:45:30.727	debug	}
                                          speedport.0	2021-04-06 21:45:30.727	debug	"cookies": []
                                          speedport.0	2021-04-06 21:45:30.727	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:45:30.727	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:45:30.727	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:45:30.727	debug	"jar": {
                                          speedport.0	2021-04-06 21:45:30.727	debug	"maxRedirects": 4,
                                          speedport.0	2021-04-06 21:45:30.727	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:45:30.727	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:45:30.727	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:45:30.727	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:45:30.727	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:45:30.727	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:45:30.727	debug	},
                                          speedport.0	2021-04-06 21:45:30.727	debug	"User-Agent": "axios/0.21.1"
                                          speedport.0	2021-04-06 21:45:30.727	debug	"Accept": "application/json, text/plain, */*",
                                          speedport.0	2021-04-06 21:45:30.727	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:45:30.727	debug	"patch": {
                                          speedport.0	2021-04-06 21:45:30.727	debug	"put": {
                                          speedport.0	2021-04-06 21:45:30.727	debug	"post": {
                                          speedport.0	2021-04-06 21:45:30.727	debug	"head": {},
                                          speedport.0	2021-04-06 21:45:30.727	debug	"get": {},
                                          speedport.0	2021-04-06 21:45:30.727	debug	"delete": {},
                                          speedport.0	2021-04-06 21:45:30.727	debug	"common": {
                                          speedport.0	2021-04-06 21:45:30.727	debug	"headers": {
                                          speedport.0	2021-04-06 21:45:30.727	debug	"method": "get",
                                          speedport.0	2021-04-06 21:45:30.727	debug	"url": "http://speedport.ip/html/login/index.html",
                                          speedport.0	2021-04-06 21:45:30.727	debug	{
                                          speedport.0	2021-04-06 21:45:30.727	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:45:30.696	debug	}
                                          speedport.0	2021-04-06 21:45:30.696	debug	"cookies": []
                                          speedport.0	2021-04-06 21:45:30.696	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:45:30.696	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:45:30.696	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:45:30.696	debug	"jar": {
                                          speedport.0	2021-04-06 21:45:30.696	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:45:30.696	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:45:30.696	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:45:30.696	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:45:30.696	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:45:30.696	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:45:30.696	debug	},
                                          speedport.0	2021-04-06 21:45:30.696	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:45:30.696	debug	"patch": {
                                          speedport.0	2021-04-06 21:45:30.696	debug	"put": {
                                          speedport.0	2021-04-06 21:45:30.696	debug	"post": {
                                          speedport.0	2021-04-06 21:45:30.696	debug	"head": {},
                                          speedport.0	2021-04-06 21:45:30.696	debug	"get": {},
                                          speedport.0	2021-04-06 21:45:30.696	debug	"delete": {},
                                          speedport.0	2021-04-06 21:45:30.696	debug	"Accept": "application/json, text/plain, */*"
                                          speedport.0	2021-04-06 21:45:30.696	debug	"common": {
                                          speedport.0	2021-04-06 21:45:30.696	debug	"headers": {
                                          speedport.0	2021-04-06 21:45:30.696	debug	"method": "get",
                                          speedport.0	2021-04-06 21:45:30.696	debug	"url": "http://speedport.ip",
                                          speedport.0	2021-04-06 21:45:30.696	debug	{
                                          speedport.0	2021-04-06 21:45:30.696	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:44:30.693	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:44:30.693	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:44:30.693	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:44:30.693	error	at runMicrotasks (<anonymous>)
                                          speedport.0	2021-04-06 21:44:30.693	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:44:30.693	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:44:30.692	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:44:30.691	debug	[]
                                          speedport.0	2021-04-06 21:44:30.691	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:44:30.646	debug	}
                                          speedport.0	2021-04-06 21:44:30.646	debug	"cookies": []
                                          speedport.0	2021-04-06 21:44:30.646	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:44:30.646	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:44:30.646	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:44:30.646	debug	"jar": {
                                          speedport.0	2021-04-06 21:44:30.646	debug	"maxRedirects": 4,
                                          speedport.0	2021-04-06 21:44:30.646	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:44:30.646	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:44:30.646	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:44:30.646	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:44:30.646	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:44:30.646	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:44:30.646	debug	},
                                          speedport.0	2021-04-06 21:44:30.646	debug	"User-Agent": "axios/0.21.1"
                                          speedport.0	2021-04-06 21:44:30.646	debug	"Accept": "application/json, text/plain, */*",
                                          speedport.0	2021-04-06 21:44:30.646	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:44:30.646	debug	"patch": {
                                          speedport.0	2021-04-06 21:44:30.646	debug	"put": {
                                          speedport.0	2021-04-06 21:44:30.646	debug	"post": {
                                          speedport.0	2021-04-06 21:44:30.646	debug	"head": {},
                                          speedport.0	2021-04-06 21:44:30.646	debug	"get": {},
                                          speedport.0	2021-04-06 21:44:30.646	debug	"delete": {},
                                          speedport.0	2021-04-06 21:44:30.646	debug	"common": {
                                          speedport.0	2021-04-06 21:44:30.646	debug	"headers": {
                                          speedport.0	2021-04-06 21:44:30.646	debug	"method": "get",
                                          speedport.0	2021-04-06 21:44:30.646	debug	"url": "http://speedport.ip/html/login/index.html",
                                          speedport.0	2021-04-06 21:44:30.646	debug	{
                                          speedport.0	2021-04-06 21:44:30.646	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:44:30.630	debug	}
                                          speedport.0	2021-04-06 21:44:30.630	debug	"cookies": []
                                          speedport.0	2021-04-06 21:44:30.630	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:44:30.630	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:44:30.630	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:44:30.630	debug	"jar": {
                                          speedport.0	2021-04-06 21:44:30.630	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:44:30.630	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:44:30.630	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:44:30.630	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:44:30.630	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:44:30.630	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:44:30.630	debug	},
                                          speedport.0	2021-04-06 21:44:30.630	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:44:30.630	debug	"patch": {
                                          speedport.0	2021-04-06 21:44:30.630	debug	"put": {
                                          speedport.0	2021-04-06 21:44:30.630	debug	"post": {
                                          speedport.0	2021-04-06 21:44:30.630	debug	"head": {},
                                          speedport.0	2021-04-06 21:44:30.630	debug	"get": {},
                                          speedport.0	2021-04-06 21:44:30.630	debug	"delete": {},
                                          speedport.0	2021-04-06 21:44:30.630	debug	"Accept": "application/json, text/plain, */*"
                                          speedport.0	2021-04-06 21:44:30.630	debug	"common": {
                                          speedport.0	2021-04-06 21:44:30.630	debug	"headers": {
                                          speedport.0	2021-04-06 21:44:30.630	debug	"method": "get",
                                          speedport.0	2021-04-06 21:44:30.630	debug	"url": "http://speedport.ip",
                                          speedport.0	2021-04-06 21:44:30.630	debug	{
                                          speedport.0	2021-04-06 21:44:30.630	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:43:30.628	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:43:30.628	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:43:30.628	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:43:30.628	error	at runMicrotasks (<anonymous>)
                                          speedport.0	2021-04-06 21:43:30.628	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:43:30.628	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:43:30.627	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:43:30.627	debug	[]
                                          speedport.0	2021-04-06 21:43:30.627	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:43:30.626	debug	[]
                                          speedport.0	2021-04-06 21:43:30.626	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:43:30.594	debug	}
                                          speedport.0	2021-04-06 21:43:30.594	debug	"cookies": []
                                          speedport.0	2021-04-06 21:43:30.594	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:43:30.594	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:43:30.594	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:43:30.594	debug	"jar": {
                                          speedport.0	2021-04-06 21:43:30.594	debug	"maxRedirects": 4,
                                          speedport.0	2021-04-06 21:43:30.594	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:43:30.594	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:43:30.594	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:43:30.594	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:43:30.594	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:43:30.594	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:43:30.594	debug	},
                                          speedport.0	2021-04-06 21:43:30.594	debug	"User-Agent": "axios/0.21.1"
                                          speedport.0	2021-04-06 21:43:30.594	debug	"Accept": "application/json, text/plain, */*",
                                          speedport.0	2021-04-06 21:43:30.594	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:43:30.594	debug	"patch": {
                                          speedport.0	2021-04-06 21:43:30.594	debug	"put": {
                                          speedport.0	2021-04-06 21:43:30.594	debug	"post": {
                                          speedport.0	2021-04-06 21:43:30.594	debug	"head": {},
                                          speedport.0	2021-04-06 21:43:30.594	debug	"get": {},
                                          speedport.0	2021-04-06 21:43:30.594	debug	"delete": {},
                                          speedport.0	2021-04-06 21:43:30.594	debug	"common": {
                                          speedport.0	2021-04-06 21:43:30.594	debug	"headers": {
                                          speedport.0	2021-04-06 21:43:30.594	debug	"method": "get",
                                          speedport.0	2021-04-06 21:43:30.594	debug	"url": "http://speedport.ip/html/login/index.html",
                                          speedport.0	2021-04-06 21:43:30.594	debug	{
                                          speedport.0	2021-04-06 21:43:30.594	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:43:30.577	debug	}
                                          speedport.0	2021-04-06 21:43:30.577	debug	"cookies": []
                                          speedport.0	2021-04-06 21:43:30.577	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:43:30.577	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:43:30.577	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:43:30.577	debug	"jar": {
                                          speedport.0	2021-04-06 21:43:30.577	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:43:30.577	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:43:30.577	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:43:30.577	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:43:30.577	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:43:30.577	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:43:30.577	debug	},
                                          speedport.0	2021-04-06 21:43:30.577	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:43:30.577	debug	"patch": {
                                          speedport.0	2021-04-06 21:43:30.577	debug	"put": {
                                          speedport.0	2021-04-06 21:43:30.577	debug	"post": {
                                          speedport.0	2021-04-06 21:43:30.577	debug	"head": {},
                                          speedport.0	2021-04-06 21:43:30.577	debug	"get": {},
                                          speedport.0	2021-04-06 21:43:30.577	debug	"delete": {},
                                          speedport.0	2021-04-06 21:43:30.577	debug	"Accept": "application/json, text/plain, */*"
                                          speedport.0	2021-04-06 21:43:30.577	debug	"common": {
                                          speedport.0	2021-04-06 21:43:30.577	debug	"headers": {
                                          speedport.0	2021-04-06 21:43:30.577	debug	"method": "get",
                                          speedport.0	2021-04-06 21:43:30.577	debug	"url": "http://speedport.ip",
                                          speedport.0	2021-04-06 21:43:30.577	debug	{
                                          speedport.0	2021-04-06 21:43:30.577	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:42:30.576	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:42:30.575	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:42:30.575	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:42:30.575	error	at runMicrotasks (<anonymous>)
                                          speedport.0	2021-04-06 21:42:30.575	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:42:30.575	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:42:30.575	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:42:30.574	debug	[]
                                          speedport.0	2021-04-06 21:42:30.574	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:42:30.573	debug	[]
                                          speedport.0	2021-04-06 21:42:30.573	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:42:30.540	debug	}
                                          speedport.0	2021-04-06 21:42:30.540	debug	"cookies": []
                                          speedport.0	2021-04-06 21:42:30.540	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:42:30.540	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:42:30.540	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:42:30.540	debug	"jar": {
                                          speedport.0	2021-04-06 21:42:30.540	debug	"maxRedirects": 4,
                                          speedport.0	2021-04-06 21:42:30.540	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:42:30.540	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:42:30.540	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:42:30.540	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:42:30.540	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:42:30.540	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:42:30.540	debug	},
                                          speedport.0	2021-04-06 21:42:30.540	debug	"User-Agent": "axios/0.21.1"
                                          speedport.0	2021-04-06 21:42:30.540	debug	"Accept": "application/json, text/plain, */*",
                                          speedport.0	2021-04-06 21:42:30.540	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:42:30.540	debug	"patch": {
                                          speedport.0	2021-04-06 21:42:30.540	debug	"put": {
                                          speedport.0	2021-04-06 21:42:30.540	debug	"post": {
                                          speedport.0	2021-04-06 21:42:30.540	debug	"head": {},
                                          speedport.0	2021-04-06 21:42:30.540	debug	"get": {},
                                          speedport.0	2021-04-06 21:42:30.540	debug	"delete": {},
                                          speedport.0	2021-04-06 21:42:30.540	debug	"common": {
                                          speedport.0	2021-04-06 21:42:30.540	debug	"headers": {
                                          speedport.0	2021-04-06 21:42:30.540	debug	"method": "get",
                                          speedport.0	2021-04-06 21:42:30.540	debug	"url": "http://speedport.ip/html/login/index.html",
                                          speedport.0	2021-04-06 21:42:30.540	debug	{
                                          speedport.0	2021-04-06 21:42:30.540	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:42:30.520	debug	}
                                          speedport.0	2021-04-06 21:42:30.520	debug	"cookies": []
                                          speedport.0	2021-04-06 21:42:30.520	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:42:30.520	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:42:30.520	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:42:30.520	debug	"jar": {
                                          speedport.0	2021-04-06 21:42:30.520	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:42:30.520	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:42:30.520	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:42:30.520	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:42:30.520	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:42:30.520	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:42:30.520	debug	},
                                          speedport.0	2021-04-06 21:42:30.520	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:42:30.520	debug	"patch": {
                                          speedport.0	2021-04-06 21:42:30.520	debug	"put": {
                                          speedport.0	2021-04-06 21:42:30.520	debug	"post": {
                                          speedport.0	2021-04-06 21:42:30.520	debug	"head": {},
                                          speedport.0	2021-04-06 21:42:30.520	debug	"get": {},
                                          speedport.0	2021-04-06 21:42:30.520	debug	"delete": {},
                                          speedport.0	2021-04-06 21:42:30.520	debug	"Accept": "application/json, text/plain, */*"
                                          speedport.0	2021-04-06 21:42:30.520	debug	"common": {
                                          speedport.0	2021-04-06 21:42:30.520	debug	"headers": {
                                          speedport.0	2021-04-06 21:42:30.520	debug	"method": "get",
                                          speedport.0	2021-04-06 21:42:30.520	debug	"url": "http://speedport.ip",
                                          speedport.0	2021-04-06 21:42:30.520	debug	{
                                          speedport.0	2021-04-06 21:42:30.520	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:41:30.518	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:41:30.518	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:41:30.518	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:41:30.518	error	at runMicrotasks (<anonymous>)
                                          speedport.0	2021-04-06 21:41:30.518	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:41:30.518	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:41:30.517	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:41:30.517	debug	[]
                                          speedport.0	2021-04-06 21:41:30.517	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:41:30.516	debug	[]
                                          speedport.0	2021-04-06 21:41:30.516	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:41:30.482	debug	}
                                          speedport.0	2021-04-06 21:41:30.482	debug	"cookies": []
                                          speedport.0	2021-04-06 21:41:30.482	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:41:30.482	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:41:30.482	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:41:30.482	debug	"jar": {
                                          speedport.0	2021-04-06 21:41:30.482	debug	"maxRedirects": 4,
                                          speedport.0	2021-04-06 21:41:30.482	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:41:30.482	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:41:30.482	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:41:30.482	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:41:30.482	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:41:30.482	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:41:30.482	debug	},
                                          speedport.0	2021-04-06 21:41:30.482	debug	"User-Agent": "axios/0.21.1"
                                          speedport.0	2021-04-06 21:41:30.482	debug	"Accept": "application/json, text/plain, */*",
                                          speedport.0	2021-04-06 21:41:30.482	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:41:30.482	debug	"patch": {
                                          speedport.0	2021-04-06 21:41:30.482	debug	"put": {
                                          speedport.0	2021-04-06 21:41:30.482	debug	"post": {
                                          speedport.0	2021-04-06 21:41:30.482	debug	"head": {},
                                          speedport.0	2021-04-06 21:41:30.482	debug	"get": {},
                                          speedport.0	2021-04-06 21:41:30.482	debug	"delete": {},
                                          speedport.0	2021-04-06 21:41:30.482	debug	"common": {
                                          speedport.0	2021-04-06 21:41:30.482	debug	"headers": {
                                          speedport.0	2021-04-06 21:41:30.482	debug	"method": "get",
                                          speedport.0	2021-04-06 21:41:30.482	debug	"url": "http://speedport.ip/html/login/index.html",
                                          speedport.0	2021-04-06 21:41:30.482	debug	{
                                          speedport.0	2021-04-06 21:41:30.482	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:41:30.465	debug	}
                                          speedport.0	2021-04-06 21:41:30.465	debug	"cookies": []
                                          speedport.0	2021-04-06 21:41:30.465	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:41:30.465	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:41:30.465	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:41:30.465	debug	"jar": {
                                          speedport.0	2021-04-06 21:41:30.465	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:41:30.465	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:41:30.465	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:41:30.465	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:41:30.465	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:41:30.465	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:41:30.465	debug	},
                                          speedport.0	2021-04-06 21:41:30.465	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:41:30.465	debug	"patch": {
                                          speedport.0	2021-04-06 21:41:30.465	debug	"put": {
                                          speedport.0	2021-04-06 21:41:30.465	debug	"post": {
                                          speedport.0	2021-04-06 21:41:30.465	debug	"head": {},
                                          speedport.0	2021-04-06 21:41:30.465	debug	"get": {},
                                          speedport.0	2021-04-06 21:41:30.465	debug	"delete": {},
                                          speedport.0	2021-04-06 21:41:30.465	debug	"Accept": "application/json, text/plain, */*"
                                          speedport.0	2021-04-06 21:41:30.465	debug	"common": {
                                          speedport.0	2021-04-06 21:41:30.465	debug	"headers": {
                                          speedport.0	2021-04-06 21:41:30.465	debug	"method": "get",
                                          speedport.0	2021-04-06 21:41:30.465	debug	"url": "http://speedport.ip",
                                          speedport.0	2021-04-06 21:41:30.465	debug	{
                                          speedport.0	2021-04-06 21:41:30.465	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:40:30.463	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:40:30.463	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:40:30.463	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:40:30.463	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:40:30.463	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:40:30.462	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:40:30.462	debug	[]
                                          speedport.0	2021-04-06 21:40:30.462	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:40:30.461	debug	[]
                                          speedport.0	2021-04-06 21:40:30.461	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:40:30.425	debug	}
                                          speedport.0	2021-04-06 21:40:30.425	debug	"cookies": []
                                          speedport.0	2021-04-06 21:40:30.425	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:40:30.425	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:40:30.425	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:40:30.425	debug	"jar": {
                                          speedport.0	2021-04-06 21:40:30.425	debug	"maxRedirects": 4,
                                          speedport.0	2021-04-06 21:40:30.425	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:40:30.425	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:40:30.425	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:40:30.425	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:40:30.425	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:40:30.425	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:40:30.425	debug	},
                                          speedport.0	2021-04-06 21:40:30.425	debug	"User-Agent": "axios/0.21.1"
                                          speedport.0	2021-04-06 21:40:30.425	debug	"Accept": "application/json, text/plain, */*",
                                          speedport.0	2021-04-06 21:40:30.425	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:40:30.425	debug	"patch": {
                                          speedport.0	2021-04-06 21:40:30.425	debug	"put": {
                                          speedport.0	2021-04-06 21:40:30.425	debug	"post": {
                                          speedport.0	2021-04-06 21:40:30.425	debug	"head": {},
                                          speedport.0	2021-04-06 21:40:30.425	debug	"get": {},
                                          speedport.0	2021-04-06 21:40:30.425	debug	"delete": {},
                                          speedport.0	2021-04-06 21:40:30.425	debug	"common": {
                                          speedport.0	2021-04-06 21:40:30.425	debug	"headers": {
                                          speedport.0	2021-04-06 21:40:30.425	debug	"method": "get",
                                          speedport.0	2021-04-06 21:40:30.425	debug	"url": "http://speedport.ip/html/login/index.html",
                                          speedport.0	2021-04-06 21:40:30.425	debug	{
                                          speedport.0	2021-04-06 21:40:30.425	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:40:30.390	debug	}
                                          speedport.0	2021-04-06 21:40:30.390	debug	"cookies": []
                                          speedport.0	2021-04-06 21:40:30.390	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:40:30.390	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:40:30.390	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:40:30.390	debug	"jar": {
                                          speedport.0	2021-04-06 21:40:30.390	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:40:30.390	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:40:30.390	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:40:30.390	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:40:30.390	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:40:30.390	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:40:30.390	debug	},
                                          speedport.0	2021-04-06 21:40:30.390	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:40:30.390	debug	"patch": {
                                          speedport.0	2021-04-06 21:40:30.390	debug	"put": {
                                          speedport.0	2021-04-06 21:40:30.390	debug	"post": {
                                          speedport.0	2021-04-06 21:40:30.390	debug	"head": {},
                                          speedport.0	2021-04-06 21:40:30.390	debug	"get": {},
                                          speedport.0	2021-04-06 21:40:30.390	debug	"delete": {},
                                          speedport.0	2021-04-06 21:40:30.390	debug	"Accept": "application/json, text/plain, */*"
                                          speedport.0	2021-04-06 21:40:30.390	debug	"common": {
                                          speedport.0	2021-04-06 21:40:30.390	debug	"headers": {
                                          speedport.0	2021-04-06 21:40:30.390	debug	"method": "get",
                                          speedport.0	2021-04-06 21:40:30.390	debug	"url": "http://speedport.ip",
                                          speedport.0	2021-04-06 21:40:30.390	debug	{
                                          speedport.0	2021-04-06 21:40:30.390	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:39:30.389	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:39:30.388	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:39:30.388	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:39:30.388	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:39:30.388	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:39:30.387	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:39:30.386	debug	[]
                                          speedport.0	2021-04-06 21:39:30.386	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:39:30.385	debug	[]
                                          speedport.0	2021-04-06 21:39:30.385	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:39:30.348	debug	}
                                          speedport.0	2021-04-06 21:39:30.348	debug	"cookies": []
                                          speedport.0	2021-04-06 21:39:30.348	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:39:30.348	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:39:30.348	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:39:30.348	debug	"jar": {
                                          speedport.0	2021-04-06 21:39:30.348	debug	"maxRedirects": 4,
                                          speedport.0	2021-04-06 21:39:30.348	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:39:30.348	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:39:30.348	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:39:30.348	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:39:30.348	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:39:30.348	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:39:30.348	debug	},
                                          speedport.0	2021-04-06 21:39:30.348	debug	"User-Agent": "axios/0.21.1"
                                          speedport.0	2021-04-06 21:39:30.348	debug	"Accept": "application/json, text/plain, */*",
                                          speedport.0	2021-04-06 21:39:30.348	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:39:30.348	debug	"patch": {
                                          speedport.0	2021-04-06 21:39:30.348	debug	"put": {
                                          speedport.0	2021-04-06 21:39:30.348	debug	"post": {
                                          speedport.0	2021-04-06 21:39:30.348	debug	"head": {},
                                          speedport.0	2021-04-06 21:39:30.348	debug	"get": {},
                                          speedport.0	2021-04-06 21:39:30.348	debug	"delete": {},
                                          speedport.0	2021-04-06 21:39:30.348	debug	"common": {
                                          speedport.0	2021-04-06 21:39:30.348	debug	"headers": {
                                          speedport.0	2021-04-06 21:39:30.348	debug	"method": "get",
                                          speedport.0	2021-04-06 21:39:30.348	debug	"url": "http://speedport.ip/html/login/index.html",
                                          speedport.0	2021-04-06 21:39:30.348	debug	{
                                          speedport.0	2021-04-06 21:39:30.348	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:39:30.325	debug	}
                                          speedport.0	2021-04-06 21:39:30.325	debug	"cookies": []
                                          speedport.0	2021-04-06 21:39:30.325	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:39:30.325	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:39:30.325	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:39:30.325	debug	"jar": {
                                          speedport.0	2021-04-06 21:39:30.325	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:39:30.325	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:39:30.325	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:39:30.325	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:39:30.325	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:39:30.325	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:39:30.325	debug	},
                                          speedport.0	2021-04-06 21:39:30.325	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:39:30.325	debug	"patch": {
                                          speedport.0	2021-04-06 21:39:30.325	debug	"put": {
                                          speedport.0	2021-04-06 21:39:30.325	debug	"post": {
                                          speedport.0	2021-04-06 21:39:30.325	debug	"head": {},
                                          speedport.0	2021-04-06 21:39:30.325	debug	"get": {},
                                          speedport.0	2021-04-06 21:39:30.325	debug	"delete": {},
                                          speedport.0	2021-04-06 21:39:30.325	debug	"Accept": "application/json, text/plain, */*"
                                          speedport.0	2021-04-06 21:39:30.325	debug	"common": {
                                          speedport.0	2021-04-06 21:39:30.325	debug	"headers": {
                                          speedport.0	2021-04-06 21:39:30.325	debug	"method": "get",
                                          speedport.0	2021-04-06 21:39:30.325	debug	"url": "http://speedport.ip",
                                          speedport.0	2021-04-06 21:39:30.325	debug	{
                                          speedport.0	2021-04-06 21:39:30.325	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:38:30.323	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:38:30.323	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:38:30.323	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:38:30.323	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:38:30.323	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:38:30.322	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:38:30.322	debug	[]
                                          speedport.0	2021-04-06 21:38:30.322	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:38:30.321	debug	[]
                                          speedport.0	2021-04-06 21:38:30.321	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:38:30.277	debug	}
                                          speedport.0	2021-04-06 21:38:30.277	debug	"cookies": []
                                          speedport.0	2021-04-06 21:38:30.277	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:38:30.277	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:38:30.277	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:38:30.277	debug	"jar": {
                                          speedport.0	2021-04-06 21:38:30.277	debug	"maxRedirects": 4,
                                          speedport.0	2021-04-06 21:38:30.277	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:38:30.277	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:38:30.277	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:38:30.277	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:38:30.277	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:38:30.277	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:38:30.277	debug	},
                                          speedport.0	2021-04-06 21:38:30.277	debug	"User-Agent": "axios/0.21.1"
                                          speedport.0	2021-04-06 21:38:30.277	debug	"Accept": "application/json, text/plain, */*",
                                          speedport.0	2021-04-06 21:38:30.277	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:38:30.277	debug	"patch": {
                                          speedport.0	2021-04-06 21:38:30.277	debug	"put": {
                                          speedport.0	2021-04-06 21:38:30.277	debug	"post": {
                                          speedport.0	2021-04-06 21:38:30.277	debug	"head": {},
                                          speedport.0	2021-04-06 21:38:30.277	debug	"get": {},
                                          speedport.0	2021-04-06 21:38:30.277	debug	"delete": {},
                                          speedport.0	2021-04-06 21:38:30.277	debug	"common": {
                                          speedport.0	2021-04-06 21:38:30.277	debug	"headers": {
                                          speedport.0	2021-04-06 21:38:30.277	debug	"method": "get",
                                          speedport.0	2021-04-06 21:38:30.277	debug	"url": "http://speedport.ip/html/login/index.html",
                                          speedport.0	2021-04-06 21:38:30.277	debug	{
                                          speedport.0	2021-04-06 21:38:30.277	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:38:30.256	debug	}
                                          speedport.0	2021-04-06 21:38:30.256	debug	"cookies": []
                                          speedport.0	2021-04-06 21:38:30.256	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:38:30.256	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:38:30.256	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:38:30.256	debug	"jar": {
                                          speedport.0	2021-04-06 21:38:30.256	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:38:30.256	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:38:30.256	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:38:30.256	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:38:30.256	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:38:30.256	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:38:30.256	debug	},
                                          speedport.0	2021-04-06 21:38:30.256	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:38:30.256	debug	"patch": {
                                          speedport.0	2021-04-06 21:38:30.256	debug	"put": {
                                          speedport.0	2021-04-06 21:38:30.256	debug	"post": {
                                          speedport.0	2021-04-06 21:38:30.256	debug	"head": {},
                                          speedport.0	2021-04-06 21:38:30.256	debug	"get": {},
                                          speedport.0	2021-04-06 21:38:30.256	debug	"delete": {},
                                          speedport.0	2021-04-06 21:38:30.256	debug	"Accept": "application/json, text/plain, */*"
                                          speedport.0	2021-04-06 21:38:30.256	debug	"common": {
                                          speedport.0	2021-04-06 21:38:30.256	debug	"headers": {
                                          speedport.0	2021-04-06 21:38:30.256	debug	"method": "get",
                                          speedport.0	2021-04-06 21:38:30.256	debug	"url": "http://speedport.ip",
                                          speedport.0	2021-04-06 21:38:30.256	debug	{
                                          speedport.0	2021-04-06 21:38:30.256	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:37:30.255	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:37:30.254	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:37:30.254	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:37:30.254	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:37:30.254	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:37:30.254	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:37:30.253	debug	[]
                                          speedport.0	2021-04-06 21:37:30.253	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:37:30.210	debug	}
                                          speedport.0	2021-04-06 21:37:30.210	debug	"cookies": []
                                          speedport.0	2021-04-06 21:37:30.210	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:37:30.210	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:37:30.210	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:37:30.210	debug	"jar": {
                                          speedport.0	2021-04-06 21:37:30.210	debug	"maxRedirects": 4,
                                          speedport.0	2021-04-06 21:37:30.210	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:37:30.210	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:37:30.210	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:37:30.210	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:37:30.210	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:37:30.210	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:37:30.210	debug	},
                                          speedport.0	2021-04-06 21:37:30.210	debug	"User-Agent": "axios/0.21.1"
                                          speedport.0	2021-04-06 21:37:30.210	debug	"Accept": "application/json, text/plain, */*",
                                          speedport.0	2021-04-06 21:37:30.210	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:37:30.210	debug	"patch": {
                                          speedport.0	2021-04-06 21:37:30.210	debug	"put": {
                                          speedport.0	2021-04-06 21:37:30.210	debug	"post": {
                                          speedport.0	2021-04-06 21:37:30.210	debug	"head": {},
                                          speedport.0	2021-04-06 21:37:30.210	debug	"get": {},
                                          speedport.0	2021-04-06 21:37:30.210	debug	"delete": {},
                                          speedport.0	2021-04-06 21:37:30.210	debug	"common": {
                                          speedport.0	2021-04-06 21:37:30.210	debug	"headers": {
                                          speedport.0	2021-04-06 21:37:30.210	debug	"method": "get",
                                          speedport.0	2021-04-06 21:37:30.210	debug	"url": "http://speedport.ip/html/login/index.html",
                                          speedport.0	2021-04-06 21:37:30.210	debug	{
                                          speedport.0	2021-04-06 21:37:30.210	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:37:30.184	debug	}
                                          speedport.0	2021-04-06 21:37:30.184	debug	"cookies": []
                                          speedport.0	2021-04-06 21:37:30.184	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:37:30.184	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:37:30.184	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:37:30.184	debug	"jar": {
                                          speedport.0	2021-04-06 21:37:30.184	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:37:30.184	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:37:30.184	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:37:30.184	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:37:30.184	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:37:30.184	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:37:30.184	debug	},
                                          speedport.0	2021-04-06 21:37:30.184	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:37:30.184	debug	"patch": {
                                          speedport.0	2021-04-06 21:37:30.184	debug	"put": {
                                          speedport.0	2021-04-06 21:37:30.184	debug	"post": {
                                          speedport.0	2021-04-06 21:37:30.184	debug	"head": {},
                                          speedport.0	2021-04-06 21:37:30.184	debug	"get": {},
                                          speedport.0	2021-04-06 21:37:30.184	debug	"delete": {},
                                          speedport.0	2021-04-06 21:37:30.184	debug	"Accept": "application/json, text/plain, */*"
                                          speedport.0	2021-04-06 21:37:30.184	debug	"common": {
                                          speedport.0	2021-04-06 21:37:30.184	debug	"headers": {
                                          speedport.0	2021-04-06 21:37:30.184	debug	"method": "get",
                                          speedport.0	2021-04-06 21:37:30.184	debug	"url": "http://speedport.ip",
                                          speedport.0	2021-04-06 21:37:30.184	debug	{
                                          speedport.0	2021-04-06 21:37:30.184	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:36:30.182	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:36:30.181	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:36:30.181	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:36:30.181	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:36:30.181	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:36:30.181	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:36:30.180	debug	[]
                                          speedport.0	2021-04-06 21:36:30.180	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:36:30.176	debug	[]
                                          speedport.0	2021-04-06 21:36:30.176	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:36:30.111	debug	}
                                          speedport.0	2021-04-06 21:36:30.111	debug	"cookies": []
                                          speedport.0	2021-04-06 21:36:30.111	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:36:30.111	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:36:30.111	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:36:30.111	debug	"jar": {
                                          speedport.0	2021-04-06 21:36:30.111	debug	"maxRedirects": 4,
                                          speedport.0	2021-04-06 21:36:30.111	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:36:30.111	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:36:30.111	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:36:30.111	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:36:30.111	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:36:30.111	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:36:30.111	debug	},
                                          speedport.0	2021-04-06 21:36:30.111	debug	"User-Agent": "axios/0.21.1"
                                          speedport.0	2021-04-06 21:36:30.111	debug	"Accept": "application/json, text/plain, */*",
                                          speedport.0	2021-04-06 21:36:30.111	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:36:30.111	debug	"patch": {
                                          speedport.0	2021-04-06 21:36:30.111	debug	"put": {
                                          speedport.0	2021-04-06 21:36:30.111	debug	"post": {
                                          speedport.0	2021-04-06 21:36:30.111	debug	"head": {},
                                          speedport.0	2021-04-06 21:36:30.111	debug	"get": {},
                                          speedport.0	2021-04-06 21:36:30.111	debug	"delete": {},
                                          speedport.0	2021-04-06 21:36:30.111	debug	"common": {
                                          speedport.0	2021-04-06 21:36:30.111	debug	"headers": {
                                          speedport.0	2021-04-06 21:36:30.111	debug	"method": "get",
                                          speedport.0	2021-04-06 21:36:30.111	debug	"url": "http://speedport.ip/html/login/index.html",
                                          speedport.0	2021-04-06 21:36:30.111	debug	{
                                          speedport.0	2021-04-06 21:36:30.111	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:36:30.079	debug	}
                                          speedport.0	2021-04-06 21:36:30.079	debug	"cookies": []
                                          speedport.0	2021-04-06 21:36:30.079	debug	"rejectPublicSuffixes": true,
                                          speedport.0	2021-04-06 21:36:30.079	debug	"storeType": "MemoryCookieStore",
                                          speedport.0	2021-04-06 21:36:30.079	debug	"version": "tough-cookie@4.0.0",
                                          speedport.0	2021-04-06 21:36:30.079	debug	"jar": {
                                          speedport.0	2021-04-06 21:36:30.079	debug	"maxBodyLength": -1,
                                          speedport.0	2021-04-06 21:36:30.079	debug	"maxContentLength": -1,
                                          speedport.0	2021-04-06 21:36:30.079	debug	"xsrfHeaderName": "X-XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:36:30.079	debug	"xsrfCookieName": "XSRF-TOKEN",
                                          speedport.0	2021-04-06 21:36:30.079	debug	"withCredentials": true,
                                          speedport.0	2021-04-06 21:36:30.079	debug	"timeout": 0,
                                          speedport.0	2021-04-06 21:36:30.079	debug	},
                                          speedport.0	2021-04-06 21:36:30.079	debug	"Content-Type": "application/x-www-form-urlencoded"
                                          speedport.0	2021-04-06 21:36:30.079	debug	"patch": {
                                          speedport.0	2021-04-06 21:36:30.079	debug	"put": {
                                          speedport.0	2021-04-06 21:36:30.079	debug	"post": {
                                          speedport.0	2021-04-06 21:36:30.079	debug	"head": {},
                                          speedport.0	2021-04-06 21:36:30.079	debug	"get": {},
                                          speedport.0	2021-04-06 21:36:30.079	debug	"delete": {},
                                          speedport.0	2021-04-06 21:36:30.079	debug	"Accept": "application/json, text/plain, */*"
                                          speedport.0	2021-04-06 21:36:30.079	debug	"common": {
                                          speedport.0	2021-04-06 21:36:30.079	debug	"headers": {
                                          speedport.0	2021-04-06 21:36:30.079	debug	"method": "get",
                                          speedport.0	2021-04-06 21:36:30.079	debug	"url": "http://speedport.ip",
                                          speedport.0	2021-04-06 21:36:30.079	debug	{
                                          speedport.0	2021-04-06 21:36:30.079	debug	(19030) Starting Request:
                                          speedport.0	2021-04-06 21:35:30.077	debug	(19030) Reset Timer
                                          speedport.0	2021-04-06 21:35:30.076	error	at async Smart3.login (/opt/iobroker/node_modules/iobroker.speedport/lib/smart3.js:42:24)
                                          speedport.0	2021-04-06 21:35:30.076	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          speedport.0	2021-04-06 21:35:30.076	error	at /opt/iobroker/node_modules/iobroker.speedport/lib/sputils.js:40:23
                                          speedport.0	2021-04-06 21:35:30.076	error	(19030) Error: Could not find _httoken in response
                                          speedport.0	2021-04-06 21:35:30.075	error	(19030) Could not find _httoken in response
                                          speedport.0	2021-04-06 21:35:30.075	debug	[]
                                          speedport.0	2021-04-06 21:35:30.075	debug	(19030) Response:
                                          speedport.0	2021-04-06 21:35:30.074	debug	[]
                                          speedport.0	2021-04-06 21:35:30.074	debug	(19030) Response:
                                          Habe allerdings nur darüber installiert, oder sollte ich alles löschen und neu installieren?
                                          Oliver
                                          H 1 Antwort Letzte Antwort
